[mapguide-commits] r6739 - in branches/2.4/MgDev: . BuildTools/WebTools BuildTools/WebTools/SetAssemblyVersion BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion/Properties BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion/bin BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion/bin/Release
svn_mapguide at osgeo.org
Fri Jun 8 23:50:00 PDT 2012
Author: jng
Date: 2012-06-08 23:50:00 -0700 (Fri, 08 Jun 2012)
New Revision: 6739
Added:
branches/2.4/MgDev/BuildTools/WebTools/SetAssemblyVersion/
branches/2.4/MgDev/BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion.sln
branches/2.4/MgDev/BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion/
branches/2.4/MgDev/BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion/Program.cs
branches/2.4/MgDev/BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion/Properties/
branches/2.4/MgDev/BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion/Properties/AssemblyInfo.cs
branches/2.4/MgDev/BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion/SetAssemblyVersion.csproj
branches/2.4/MgDev/BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion/bin/
branches/2.4/MgDev/BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion/bin/Release/
branches/2.4/MgDev/BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion/bin/Release/SetAssemblyVersion.exe
branches/2.4/MgDev/BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion/bin/Release/SetAssemblyVersion.pdb
branches/2.4/MgDev/stampassemblies.bat
#2024: Add a SetAssemblyInfo project to BuildTools/WebTools. This is a small utility to set the appropriate version number in an AssemblyInfo.cs file. Add a new stampassemblies.bat, which takes a single parameter (the version in major.minor.build.revision format). This will stamp the .net API and the mg-desktop .net API AssemblyInfo files.
Property changes on: branches/2.4/MgDev/BuildTools/WebTools/SetAssemblyVersion
___________________________________________________________________
Added: svn:ignore
+ *.suo
Property changes on: branches/2.4/MgDev/BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion
Added: svn:ignore
+ obj
Added: branches/2.4/MgDev/BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion/Program.cs
--- branches/2.4/MgDev/BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion/Program.cs (rev 0)
+++ branches/2.4/MgDev/BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion/Program.cs 2012-06-09 06:50:00 UTC (rev 6739)
@@ -0,0 +1,139 @@
+using System;
+using System.IO;
+using System.Text;
+namespace SetAssemblyVersion
+ /// <summary>
+ /// A small utility to stamp the version of our .net API assemblies
+ /// Original source: http://www.codeproject.com/Articles/31236/How-To-Update-Assembly-Version-Number-Automaticall
+ /// </summary>
+ class AssemblyInfoUtil
+ private static int incParamNum = 0;
+ private static string fileName = "";
+ private static string versionStr = null;
+ private static bool isVB = false;
+ /// <summary>
+ /// The main entry point for the application.
+ /// </summary>
+ [STAThread]
+ static void Main(string[] args)
+ for (int i = 0; i < args.Length; i++)
+ if (args[i].StartsWith("-inc:"))
+ string s = args[i].Substring("-inc:".Length);
+ incParamNum = int.Parse(s);
+ else if (args[i].StartsWith("-set:"))
+ versionStr = args[i].Substring("-set:".Length);
+ else
+ fileName = args[i];
+ if (Path.GetExtension(fileName).ToLower() == ".vb")
+ isVB = true;
+ if (fileName == "")
+ System.Console.WriteLine("Usage: AssemblyInfoUtil <path to AssemblyInfo.cs or AssemblyInfo.vb file> [options]");
+ System.Console.WriteLine("Options: ");
+ System.Console.WriteLine(" -set:<new version number> - set new version number (in NN.NN.NN.NN format)");
+ System.Console.WriteLine(" -inc:<parameter index> - increases the parameter with specified index (can be from 1 to 4)");
+ return;
+ if (!File.Exists(fileName))
+ System.Console.WriteLine("Error: Can not find file \"" + fileName + "\"");
+ return;
+ System.Console.Write("Processing \"" + fileName + "\"...");
+ StreamReader reader = new StreamReader(fileName);
+ StreamWriter writer = new StreamWriter(fileName + ".out");
+ String line;
+ while ((line = reader.ReadLine()) != null)
+ line = ProcessLine(line);
+ writer.WriteLine(line);
+ reader.Close();
+ writer.Close();
+ File.Delete(fileName);
+ File.Move(fileName + ".out", fileName);
+ System.Console.WriteLine("Done!");
+ private static string ProcessLine(string line)
+ if (isVB)
+ line = ProcessLinePart(line, "<Assembly: AssemblyVersion(\"");
+ line = ProcessLinePart(line, "<Assembly: AssemblyFileVersion(\"");
+ else
+ line = ProcessLinePart(line, "[assembly: AssemblyVersion(\"");
+ line = ProcessLinePart(line, "[assembly: AssemblyFileVersion(\"");
+ return line;
+ private static string ProcessLinePart(string line, string part)
+ int spos = line.IndexOf(part);
+ if (spos >= 0)
+ spos += part.Length;
+ int epos = line.IndexOf('"', spos);
+ string oldVersion = line.Substring(spos, epos - spos);
+ string newVersion = "";
+ bool performChange = false;
+ if (incParamNum > 0)
+ string[] nums = oldVersion.Split('.');
+ if (nums.Length >= incParamNum && nums[incParamNum - 1] != "*")
+ Int64 val = Int64.Parse(nums[incParamNum - 1]);
+ val++;
+ nums[incParamNum - 1] = val.ToString();
+ newVersion = nums[0];
+ for (int i = 1; i < nums.Length; i++)
+ newVersion += "." + nums[i];
+ performChange = true;
+ else if (versionStr != null)
+ newVersion = versionStr;
+ if (performChange)
+ StringBuilder str = new StringBuilder(line);
+ str.Remove(spos, epos - spos);
+ str.Insert(spos, newVersion);
+ line = str.ToString();
+ return line;
Added: branches/2.4/MgDev/BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion/Properties/AssemblyInfo.cs
--- branches/2.4/MgDev/BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion/Properties/AssemblyInfo.cs (rev 0)
+++ branches/2.4/MgDev/BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion/Properties/AssemblyInfo.cs 2012-06-09 06:50:00 UTC (rev 6739)
@@ -0,0 +1,36 @@
+using System.Reflection;
+using System.Runtime.CompilerServices;
+using System.Runtime.InteropServices;
+// General Information about an assembly is controlled through the following
+// set of attributes. Change these attribute values to modify the information
+// associated with an assembly.
+[assembly: AssemblyTitle("SetAssemblyVersion")]
+[assembly: AssemblyDescription("")]
+[assembly: AssemblyConfiguration("")]
+[assembly: AssemblyCompany("")]
+[assembly: AssemblyProduct("SetAssemblyVersion")]
+[assembly: AssemblyCopyright("Copyright © 2012")]
+[assembly: AssemblyTrademark("")]
+[assembly: AssemblyCulture("")]
+// Setting ComVisible to false makes the types in this assembly not visible
+// to COM components. If you need to access a type in this assembly from
+// COM, set the ComVisible attribute to true on that type.
+[assembly: ComVisible(false)]
+// The following GUID is for the ID of the typelib if this project is exposed to COM
+[assembly: Guid("742bc60a-1bd9-47a1-8bbc-51827d2ba415")]
+// Version information for an assembly consists of the following four values:
+// Major Version
+// Minor Version
+// Build Number
+// Revision
+// You can specify all the values or you can default the Build and Revision Numbers
+// by using the '*' as shown below:
+// [assembly: AssemblyVersion("1.0.*")]
+[assembly: AssemblyVersion("1.0.0.0")]
+[assembly: AssemblyFileVersion("1.0.0.0")]
Added: branches/2.4/MgDev/BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion/SetAssemblyVersion.csproj
--- branches/2.4/MgDev/BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion/SetAssemblyVersion.csproj (rev 0)
+++ branches/2.4/MgDev/BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion/SetAssemblyVersion.csproj 2012-06-09 06:50:00 UTC (rev 6739)
@@ -0,0 +1,51 @@
+<?xml version="1.0" encoding="utf-8"?>
+<Project ToolsVersion="3.5" DefaultTargets="Build" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
+ <PropertyGroup>
+ <Configuration Condition=" '$(Configuration)' == '' ">Debug</Configuration>
+ <Platform Condition=" '$(Platform)' == '' ">AnyCPU</Platform>
+ <ProductVersion>9.0.30729</ProductVersion>
+ <SchemaVersion>2.0</SchemaVersion>
+ <ProjectGuid>{FB6810AB-F710-4542-A55C-9DB8AB151B06}</ProjectGuid>
+ <OutputType>Exe</OutputType>
+ <AppDesignerFolder>Properties</AppDesignerFolder>
+ <RootNamespace>SetAssemblyVersion</RootNamespace>
+ <AssemblyName>SetAssemblyVersion</AssemblyName>
+ <TargetFrameworkVersion>v2.0</TargetFrameworkVersion>
+ <FileAlignment>512</FileAlignment>
+ </PropertyGroup>
+ <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Debug|AnyCPU' ">
+ <DebugSymbols>true</DebugSymbols>
+ <DebugType>full</DebugType>
+ <Optimize>false</Optimize>
+ <OutputPath>bin\Debug\</OutputPath>
+ <DefineConstants>DEBUG;TRACE</DefineConstants>
+ <ErrorReport>prompt</ErrorReport>
+ <WarningLevel>4</WarningLevel>
+ </PropertyGroup>
+ <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Release|AnyCPU' ">
+ <DebugType>pdbonly</DebugType>
+ <Optimize>true</Optimize>
+ <OutputPath>bin\Release\</OutputPath>
+ <DefineConstants>TRACE</DefineConstants>
+ <UseVSHostingProcess>false</UseVSHostingProcess>
+ </PropertyGroup>
+ <ItemGroup>
+ <Reference Include="System" />
+ <Reference Include="System.Data" />
+ <Reference Include="System.Xml" />
+ </ItemGroup>
+ <ItemGroup>
+ <Compile Include="Program.cs" />
+ <Compile Include="Properties\AssemblyInfo.cs" />
+ </ItemGroup>
+ <Import Project="$(MSBuildToolsPath)\Microsoft.CSharp.targets" />
+ <!-- To modify your build process, add your task inside one of the targets below and uncomment it.
+ Other similar extension points exist, see Microsoft.Common.targets.
+ <Target Name="BeforeBuild">
+ </Target>
+ <Target Name="AfterBuild">
+ </Target>
+</Project>
\ No newline at end of file
Property changes on: branches/2.4/MgDev/BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion/bin
Added: svn:ignore
+ Debug
Added: branches/2.4/MgDev/BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion/bin/Release/SetAssemblyVersion.exe
(Binary files differ)
Property changes on: branches/2.4/MgDev/BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion/bin/Release/SetAssemblyVersion.exe
Added: svn:mime-type
+ application/octet-stream
Added: branches/2.4/MgDev/BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion/bin/Release/SetAssemblyVersion.pdb
Property changes on: branches/2.4/MgDev/BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion/bin/Release/SetAssemblyVersion.pdb
Added: branches/2.4/MgDev/BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion.sln
--- branches/2.4/MgDev/BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion.sln (rev 0)
+++ branches/2.4/MgDev/BuildTools/WebTools/SetAssemblyVersion/SetAssemblyVersion.sln 2012-06-09 06:50:00 UTC (rev 6739)
@@ -0,0 +1,20 @@
+Microsoft Visual Studio Solution File, Format Version 10.00
+# Visual Studio 2008
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "SetAssemblyVersion", "SetAssemblyVersion\SetAssemblyVersion.csproj", "{FB6810AB-F710-4542-A55C-9DB8AB151B06}"
+EndProject
+Global
+ GlobalSection(SolutionConfigurationPlatforms) = preSolution
+ Debug|Any CPU = Debug|Any CPU
+ Release|Any CPU = Release|Any CPU
+ EndGlobalSection
+ GlobalSection(ProjectConfigurationPlatforms) = postSolution
+ {FB6810AB-F710-4542-A55C-9DB8AB151B06}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
+ {FB6810AB-F710-4542-A55C-9DB8AB151B06}.Debug|Any CPU.Build.0 = Debug|Any CPU
+ {FB6810AB-F710-4542-A55C-9DB8AB151B06}.Release|Any CPU.ActiveCfg = Release|Any CPU
+ {FB6810AB-F710-4542-A55C-9DB8AB151B06}.Release|Any CPU.Build.0 = Release|Any CPU
+ EndGlobalSection
+ GlobalSection(SolutionProperties) = preSolution
+ HideSolutionNode = FALSE
+ EndGlobalSection
+EndGlobal
Added: branches/2.4/MgDev/stampassemblies.bat
--- branches/2.4/MgDev/stampassemblies.bat (rev 0)
+++ branches/2.4/MgDev/stampassemblies.bat 2012-06-09 06:50:00 UTC (rev 6739)
@@ -0,0 +1,25 @@
+ at echo off
+SET PATH=%PATH%;%CD%\BuildTools\WebTools\SetAssemblyVersion\SetAssemblyVersion\bin\Release
+SET VERSION=%1
+echo Stamping version %VERSION% to all instances of AssemblyInfo.cs
+pushd "%CD%\Web\src\DotNetApi"
+SetAssemblyVersion.exe -set:%1 AssemblyInfo.cs
+popd
+pushd "%CD%\Web\src\DotNetApi\Foundation"
+popd
+pushd "%CD%\Web\src\DotNetApi\Geometry"
+popd
+pushd "%CD%\Web\src\DotNetApi\MapGuideCommon"
+popd
+pushd "%CD%\Web\src\DotNetApi\PlatformBase"
+popd
+pushd "%CD%\Web\src\DotNetApi\Web"
+popd
+pushd "%CD%\Desktop\DesktopUnmanagedApi\DotNet\Partials"
+popd
More information about the mapguide-commits
