[mapguide-commits] r6748 - in trunk/Tools/Maestro/Maestro.Editors: FeatureSource/Preview Properties
svn_mapguide at osgeo.org
Mon Jun 11 04:47:09 PDT 2012
Author: jng
Date: 2012-06-11 04:47:09 -0700 (Mon, 11 Jun 2012)
New Revision: 6748
trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Preview/LocalFeatureSourcePreviewCtrl.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Preview/LocalFeatureSourcePreviewCtrl.cs
trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Preview/LocalFeatureSourcePreviewCtrl.resx
trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx
#2004: Do not full schema walk when presenting the schema tree in the Feature Source Preview. Lazy load our nodes like we do in FDO Toolbox
Modified: trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Preview/LocalFeatureSourcePreviewCtrl.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Preview/LocalFeatureSourcePreviewCtrl.Designer.cs 2012-06-11 11:11:59 UTC (rev 6747)
+++ trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Preview/LocalFeatureSourcePreviewCtrl.Designer.cs 2012-06-11 11:47:09 UTC (rev 6748)
@@ -40,6 +40,7 @@
this.btnStandard = new System.Windows.Forms.ToolStripButton();
this.btnClose = new System.Windows.Forms.ToolStripButton();
this.tabPreviews = new System.Windows.Forms.TabControl();
+ ((System.ComponentModel.ISupportInitialize)(this.splitContainer1)).BeginInit();
this.splitContainer1.Panel1.SuspendLayout();
this.splitContainer1.Panel2.SuspendLayout();
this.splitContainer1.SuspendLayout();
@@ -66,6 +67,7 @@
this.trvSchema.ImageList = this.schemaImageList;
this.trvSchema.Name = "trvSchema";
this.trvSchema.ShowNodeToolTips = true;
+ this.trvSchema.AfterExpand += new System.Windows.Forms.TreeViewEventHandler(this.trvSchema_AfterExpand);
this.trvSchema.AfterSelect += new System.Windows.Forms.TreeViewEventHandler(this.trvSchema_AfterSelect);
// schemaImageList
@@ -142,6 +144,7 @@
this.splitContainer1.Panel1.ResumeLayout(false);
this.splitContainer1.Panel1.PerformLayout();
this.splitContainer1.Panel2.ResumeLayout(false);
+ ((System.ComponentModel.ISupportInitialize)(this.splitContainer1)).EndInit();
this.splitContainer1.ResumeLayout(false);
this.toolStrip1.ResumeLayout(false);
this.toolStrip1.PerformLayout();
Modified: trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Preview/LocalFeatureSourcePreviewCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Preview/LocalFeatureSourcePreviewCtrl.cs 2012-06-11 11:11:59 UTC (rev 6747)
+++ trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Preview/LocalFeatureSourcePreviewCtrl.cs 2012-06-11 11:47:09 UTC (rev 6748)
@@ -77,6 +77,39 @@
private FdoProviderCapabilities _caps;
+ class SchemaNodeTag
+ public string SchemaName { get; set; }
+ public bool Loaded { get; set; }
+ public SchemaNodeTag(string name)
+ this.SchemaName = name;
+ this.Loaded = false;
+ class ClassNodeTag
+ public string ClassName { get; set; }
+ public string QualifiedName { get { return this.SchemaName + ":" + this.ClassName; } }
+ public ClassDefinition Class { get; set; }
+ public ClassNodeTag(string schemaName, string className)
+ this.SchemaName = schemaName;
+ this.ClassName = className;
/// <summary>
/// Reloads the tree.
/// </summary>
@@ -88,108 +121,101 @@
_caps = caps;
ClearPreviewPanes();
trvSchema.Nodes.Clear();
- //FIXME: Do this lazily ala. FDO Toolbox
- var schema = _fsvc.DescribeFeatureSource(currentFsId);
- Dictionary<string, List<ClassDefinition>> classes = new Dictionary<string, List<ClassDefinition>>();
- foreach (var cls in schema.AllClasses)
- string[] tokens = cls.QualifiedName.Split(':');
- if (!classes.ContainsKey(tokens[0]))
- classes[tokens[0]] = new List<ClassDefinition>();
- classes[tokens[0]].Add(cls);
- string[] schemaNames = schema.SchemaNames;
+ string[] schemaNames = _fsvc.GetSchemas(currentFsId);
foreach (var s in schemaNames)
var schemaNode = new TreeNode(s);
- schemaNode.Tag = s;
+ schemaNode.Tag = new SchemaNodeTag(s);
schemaNode.ImageIndex = schemaNode.SelectedImageIndex = IDX_SCHEMA;
+ schemaNode.Nodes.Add(Properties.Resources.TextLoading);
trvSchema.Nodes.Add(schemaNode);
- if (classes.ContainsKey(s))
- foreach (var cls in classes[s])
- var classNode = new TreeNode(cls.Name);
- classNode.Text = cls.Name;
- classNode.Tag = cls;
- classNode.ImageIndex = classNode.SelectedImageIndex = IDX_CLASS;
+ private static void UpdateClassNode(TreeNode classNode, ClassDefinition cls)
+ //var classNode = new TreeNode(cls.Name);
+ classNode.Nodes.Clear();
+ classNode.Name = cls.Name;
+ classNode.Text = cls.Name;
+ var clsTag = classNode.Tag as ClassNodeTag;
+ if (clsTag == null)
+ classNode.Tag = new ClassNodeTag(cls.Parent.Name, cls.Name) { Loaded = true, Class = cls };
+ else
+ clsTag.Loaded = true;
+ clsTag.Class = cls;
+ classNode.ImageIndex = classNode.SelectedImageIndex = IDX_CLASS;
- classNode.ToolTipText = string.Format(Properties.Resources.FsPreview_ClassNodeTooltip,
- cls.Name,
- cls.Description,
- cls.DefaultGeometryPropertyName,
- Environment.NewLine);
+ classNode.ToolTipText = string.Format(Properties.Resources.FsPreview_ClassNodeTooltip,
+ cls.Name,
+ cls.Description,
+ cls.DefaultGeometryPropertyName,
+ Environment.NewLine);
- foreach (var prop in cls.Properties)
- var propNode = new TreeNode(prop.Name);
- propNode.Text = prop.Name;
- propNode.Tag = prop;
+ foreach (var prop in cls.Properties)
+ var propNode = new TreeNode(prop.Name);
+ propNode.Text = prop.Name;
+ propNode.Tag = prop;
- if (prop.Type == PropertyDefinitionType.Geometry)
- var g = (GeometricPropertyDefinition)prop;
- propNode.ImageIndex = propNode.SelectedImageIndex = IDX_GEOMETRY;
- propNode.ToolTipText = string.Format(Properties.Resources.FsPreview_GeometryPropertyNodeTooltip,
- g.Name,
- g.Description,
- g.GeometryTypesToString(),
- g.IsReadOnly,
- g.HasElevation,
- g.HasMeasure,
- g.SpatialContextAssociation,
- else if (prop.Type == PropertyDefinitionType.Data)
- var d = (DataPropertyDefinition)prop;
- if (cls.IdentityProperties.Contains((DataPropertyDefinition)prop))
- propNode.ImageIndex = propNode.SelectedImageIndex = IDX_IDENTITY;
- else
- propNode.ImageIndex = propNode.SelectedImageIndex = IDX_PROP;
+ if (prop.Type == PropertyDefinitionType.Geometry)
+ var g = (GeometricPropertyDefinition)prop;
+ propNode.ImageIndex = propNode.SelectedImageIndex = IDX_GEOMETRY;
+ propNode.ToolTipText = string.Format(Properties.Resources.FsPreview_GeometryPropertyNodeTooltip,
+ g.Name,
+ g.Description,
+ g.GeometryTypesToString(),
+ g.IsReadOnly,
+ g.HasElevation,
+ g.HasMeasure,
+ g.SpatialContextAssociation,
+ else if (prop.Type == PropertyDefinitionType.Data)
+ var d = (DataPropertyDefinition)prop;
+ if (cls.IdentityProperties.Contains((DataPropertyDefinition)prop))
+ propNode.ImageIndex = propNode.SelectedImageIndex = IDX_IDENTITY;
+ else
+ propNode.ImageIndex = propNode.SelectedImageIndex = IDX_PROP;
- propNode.ToolTipText = string.Format(Properties.Resources.FsPreview_DataPropertyNodeTooltip,
- d.Name,
- d.Description,
- d.DataType.ToString(),
- d.IsNullable,
- d.IsReadOnly,
- d.Length,
- d.Precision,
- d.Scale,
- else if (prop.Type == PropertyDefinitionType.Raster)
- var r = (RasterPropertyDefinition)prop;
- propNode.ImageIndex = propNode.SelectedImageIndex = IDX_RASTER;
+ propNode.ToolTipText = string.Format(Properties.Resources.FsPreview_DataPropertyNodeTooltip,
+ d.Name,
+ d.Description,
+ d.DataType.ToString(),
+ d.IsNullable,
+ d.IsReadOnly,
+ d.Length,
+ d.Precision,
+ d.Scale,
+ else if (prop.Type == PropertyDefinitionType.Raster)
+ var r = (RasterPropertyDefinition)prop;
+ propNode.ImageIndex = propNode.SelectedImageIndex = IDX_RASTER;
- propNode.ToolTipText = string.Format(Properties.Resources.FsPreview_RasterPropertyNodeTooltip,
- r.Name,
- r.Description,
- r.IsNullable,
- r.DefaultImageXSize,
- r.DefaultImageYSize,
- r.SpatialContextAssociation,
- else
+ propNode.ToolTipText = string.Format(Properties.Resources.FsPreview_RasterPropertyNodeTooltip,
+ r.Name,
+ r.Description,
+ r.IsNullable,
+ r.DefaultImageXSize,
+ r.DefaultImageYSize,
+ r.SpatialContextAssociation,
+ else
- classNode.Nodes.Add(propNode);
- schemaNode.Nodes.Add(classNode);
+ classNode.Nodes.Add(propNode);
@@ -260,7 +286,9 @@
if (trvSchema.SelectedNode != null)
- return trvSchema.SelectedNode.Tag as ClassDefinition;
+ var tag = trvSchema.SelectedNode.Tag as ClassNodeTag;
+ if (tag != null)
+ return tag.Class;
return null;
@@ -270,12 +298,17 @@
switch (e.Node.Level)
case 1: //Class
- var cls = e.Node.Tag as ClassDefinition;
- if (cls != null)
+ var cls = e.Node.Tag as ClassNodeTag;
+ if (cls != null && cls.Class != null)
btnStandard.Enabled = true;
btnSql.Enabled = this.SupportsSQL;
+ else
+ btnStandard.Enabled = false;
+ btnSql.Enabled = false;
break;
default:
@@ -323,5 +356,42 @@
btnClose.Enabled = (tabPreviews.TabPages.Count > 0);
+ private void trvSchema_AfterExpand(object sender, TreeViewEventArgs e)
+ var schTag = e.Node.Tag as SchemaNodeTag;
+ var clsTag = e.Node.Tag as ClassNodeTag;
+ if (schTag != null)
+ if (schTag.Loaded)
+ return;
+ e.Node.Nodes.Clear();
+ var classNames = _fsvc.GetClassNames(currentFsId, schTag.SchemaName);
+ foreach (var qClsName in classNames)
+ var clsName = qClsName.Split(':')[1];
+ var node = new TreeNode(clsName);
+ node.Text = clsName;
+ node.Tag = new ClassNodeTag(schTag.SchemaName, clsName);
+ node.ImageIndex = node.SelectedImageIndex = IDX_CLASS;
+ node.Nodes.Add(Properties.Resources.TextLoading);
+ e.Node.Nodes.Add(node);
+ schTag.Loaded = true;
+ else if (clsTag != null)
+ if (clsTag.Loaded)
+ return;
+ var cls = _fsvc.GetClassDefinition(currentFsId, clsTag.QualifiedName);
+ UpdateClassNode(e.Node, cls);
Modified: trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Preview/LocalFeatureSourcePreviewCtrl.resx
--- trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Preview/LocalFeatureSourcePreviewCtrl.resx 2012-06-11 11:11:59 UTC (rev 6747)
+++ trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Preview/LocalFeatureSourcePreviewCtrl.resx 2012-06-11 11:47:09 UTC (rev 6748)
@@ -112,35 +112,35 @@
<value>2.0</value>
</resheader>
<resheader name="reader">
- <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</resheader>
<resheader name="writer">
- <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</resheader>
- <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
<data name="splitContainer1.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
<value>Fill</value>
</data>
- <assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+ <assembly alias="System.Drawing" name="System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
<data name="splitContainer1.Location" type="System.Drawing.Point, System.Drawing">
<value>0, 0</value>
</data>
<data name="trvSchema.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
<value>Fill</value>
</data>
- <assembly alias="mscorlib" name="mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <assembly alias="mscorlib" name="mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
<data name="trvSchema.ImageIndex" type="System.Int32, mscorlib">
<value>0</value>
</data>
- <metadata name="schemaImageList.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <metadata name="schemaImageList.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
<value>116, 17</value>
</metadata>
<data name="schemaImageList.ImageStream" mimetype="application/x-microsoft.net.object.binary.base64">
<value>
- AAEAAAD/////AQAAAAAAAAAMAgAAAFdTeXN0ZW0uV2luZG93cy5Gb3JtcywgVmVyc2lvbj0yLjAuMC4w
+ AAEAAAD/////AQAAAAAAAAAMAgAAAFdTeXN0ZW0uV2luZG93cy5Gb3JtcywgVmVyc2lvbj00LjAuMC4w
LCBDdWx0dXJlPW5ldXRyYWwsIFB1YmxpY0tleVRva2VuPWI3N2E1YzU2MTkzNGUwODkFAQAAACZTeXN0
ZW0uV2luZG93cy5Gb3Jtcy5JbWFnZUxpc3RTdHJlYW1lcgEAAAAERGF0YQcCAgAAAAkDAAAADwMAAAAw
- DQAAAk1TRnQBSQFMAgEBBgEAASwBAAEsAQABEAEAARABAAT/AQkBAAj/AUIBTQE2AQQGAAE2AQQCAAEo
+ DQAAAk1TRnQBSQFMAgEBBgEAATQBAAE0AQABEAEAARABAAT/AQkBAAj/AUIBTQE2AQQGAAE2AQQCAAEo
AwABQAMAASADAAEBAQABCAYAAQgYAAGAAgABgAMAAoABAAGAAwABgAEAAYABAAKAAgADwAEAAcAB3AHA
AQAB8AHKAaYBAAEzBQABMwEAATMBAAEzAQACMwIAAxYBAAMcAQADIgEAAykBAANVAQADTQEAA0IBAAM5
AQABgAF8Af8BAAJQAf8BAAGTAQAB1gEAAf8B7AHMAQABxgHWAe8BAAHWAucBAAGQAakBrQIAAf8BMwMA
@@ -215,7 +215,7 @@
<value>trvSchema</value>
</data>
<data name=">>trvSchema.Type" xml:space="preserve">
- <value>System.Windows.Forms.TreeView, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.TreeView, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>trvSchema.Parent" xml:space="preserve">
<value>splitContainer1.Panel1</value>
@@ -223,7 +223,7 @@
<data name=">>trvSchema.ZOrder" xml:space="preserve">
<value>0</value>
</data>
- <metadata name="toolStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <metadata name="toolStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
<value>0, 0</value>
</metadata>
<data name="btnRefresh.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
@@ -290,7 +290,7 @@
<value>toolStrip1</value>
</data>
<data name=">>toolStrip1.Type" xml:space="preserve">
- <value>System.Windows.Forms.ToolStrip, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.ToolStrip, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>toolStrip1.Parent" xml:space="preserve">
@@ -302,7 +302,7 @@
</data>
<data name=">>splitContainer1.Panel1.Type" xml:space="preserve">
- <value>System.Windows.Forms.SplitterPanel, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.SplitterPanel, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>splitContainer1.Panel1.Parent" xml:space="preserve">
<value>splitContainer1</value>
@@ -326,7 +326,7 @@
<value>tabPreviews</value>
</data>
<data name=">>tabPreviews.Type" xml:space="preserve">
- <value>System.Windows.Forms.TabControl, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.TabControl, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>tabPreviews.Parent" xml:space="preserve">
<value>splitContainer1.Panel2</value>
@@ -338,7 +338,7 @@
</data>
<data name=">>splitContainer1.Panel2.Type" xml:space="preserve">
</data>
<data name=">>splitContainer1.Panel2.Parent" xml:space="preserve">
@@ -359,7 +359,7 @@
</data>
<data name=">>splitContainer1.Type" xml:space="preserve">
- <value>System.Windows.Forms.SplitContainer, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.SplitContainer, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>splitContainer1.Parent" xml:space="preserve">
<value>$this</value>
@@ -367,7 +367,7 @@
<data name=">>splitContainer1.ZOrder" xml:space="preserve">
<value>0</value>
</data>
- <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+ <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
<value>True</value>
</metadata>
<data name="$this.Size" type="System.Drawing.Size, System.Drawing">
@@ -377,42 +377,42 @@
<value>schemaImageList</value>
</data>
<data name=">>schemaImageList.Type" xml:space="preserve">
- <value>System.Windows.Forms.ImageList, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.ImageList, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>btnRefresh.Name" xml:space="preserve">
<value>btnRefresh</value>
</data>
<data name=">>btnRefresh.Type" xml:space="preserve">
- <value>System.Windows.Forms.ToolStripButton, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.ToolStripButton, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>toolStripSeparator1.Name" xml:space="preserve">
<value>toolStripSeparator1</value>
</data>
<data name=">>toolStripSeparator1.Type" xml:space="preserve">
- <value>System.Windows.Forms.ToolStripSeparator, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.ToolStripSeparator, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>btnSql.Name" xml:space="preserve">
<value>btnSql</value>
</data>
<data name=">>btnSql.Type" xml:space="preserve">
</data>
<data name=">>btnStandard.Name" xml:space="preserve">
<value>btnStandard</value>
</data>
<data name=">>btnStandard.Type" xml:space="preserve">
</data>
<data name=">>btnClose.Name" xml:space="preserve">
<value>btnClose</value>
</data>
<data name=">>btnClose.Type" xml:space="preserve">
</data>
<data name=">>$this.Name" xml:space="preserve">
<value>LocalFeatureSourcePreviewCtrl</value>
</data>
<data name=">>$this.Type" xml:space="preserve">
- <value>System.Windows.Forms.UserControl, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.UserControl, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
</root>
\ No newline at end of file
Modified: trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs 2012-06-11 11:11:59 UTC (rev 6747)
+++ trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs 2012-06-11 11:47:09 UTC (rev 6748)
@@ -3235,6 +3235,15 @@
/// <summary>
+ /// Looks up a localized string similar to Loading.
+ /// </summary>
+ internal static string TextLoading {
+ get {
+ return ResourceManager.GetString("TextLoading", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to No Items Selected.
/// </summary>
internal static string TextNoItemSelected {
Modified: trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx
--- trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx 2012-06-11 11:11:59 UTC (rev 6747)
+++ trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx 2012-06-11 11:47:09 UTC (rev 6748)
@@ -5698,4 +5698,7 @@
<data name="TextPreparingConfigurationDocument" xml:space="preserve">
<value>Preparing Configuration Document</value>
</data>
+ <data name="TextLoading" xml:space="preserve">
+ <value>Loading</value>
+ </data>
</root>
More information about the mapguide-commits
