[mapguide-commits] r6750 - in trunk/Tools/Maestro: Maestro.Editors/FeatureSource/Providers/Odbc Maestro.Editors/FeatureSource/Providers/Odbc/OverrideEditor OSGeo.MapGuide.MaestroAPI/Schema OSGeo.MapGuide.MaestroAPI/SchemaOverrides
svn_mapguide at osgeo.org
Mon Jun 11 07:29:04 PDT 2012
Author: jng
Date: 2012-06-11 07:29:04 -0700 (Mon, 11 Jun 2012)
New Revision: 6750
trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/OdbcProviderCtrl.cs
trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/OverrideEditor/TableConfigurationDialog.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/OverrideEditor/TableConfigurationDialog.cs
trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/OverrideEditor/TableConfigurationDialog.resx
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/ClassDefinition.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/ConfigurationDocument.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/OdbcConfigurationDocument.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/OdbcTableItem.cs
#1980: Fix broken ODBC configuration. The problem was that our OdbcTableItem was writing XML like this:
<complexType name="Foo">
<Table name="Foo">
<element name="Bar">
<Column name="Bar" />
</element>
</Table>
</complexType>
Instead of this:
<Table name="Foo" />
</element>
</complexType>
Which basically made all our ODBC configuration documents thus far invalid and useless.
Other changes include:
- Add ability to set the coordinate system for the ODBC configuration document
- Add a new RemoveProperty() API to ClassDefinition that takes a property name
Modified: trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/OdbcProviderCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/OdbcProviderCtrl.cs 2012-06-11 13:33:49 UTC (rev 6749)
+++ trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/OdbcProviderCtrl.cs 2012-06-11 14:29:04 UTC (rev 6750)
@@ -276,7 +276,7 @@
- var diag = new TableConfigurationDialog(_doc, _defaultSchemaName);
+ var diag = new TableConfigurationDialog(_service, _doc, _defaultSchemaName);
if (diag.ShowDialog() == DialogResult.OK)
_doc.ClearMappings();
@@ -285,6 +285,10 @@
_doc.AddOverride(table);
string updatedContent = _doc.ToXml();
+ foreach (var sc in _doc.SpatialContexts)
+ sc.CoordinateSystemWkt = diag.CoordinateSystemWkt;
_fs.SetConfigurationContent(updatedContent);
OnResourceChanged();
@@ -323,6 +327,7 @@
classNames = names.Select(x => x.Contains(":") ? x.Split(':')[1] : x).ToArray();
var schema = _fs.CurrentConnection.FeatureService.DescribeFeatureSourcePartial(_fs.ResourceID, schemaName, classNames);
_doc.AddSchema(schema); //Only one schema is supported by ODBC so this is ok
var scList = _fs.GetSpatialInfo(false);
foreach (var sc in scList.SpatialContext)
Modified: trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/OverrideEditor/TableConfigurationDialog.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/OverrideEditor/TableConfigurationDialog.Designer.cs 2012-06-11 13:33:49 UTC (rev 6749)
+++ trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/OverrideEditor/TableConfigurationDialog.Designer.cs 2012-06-11 14:29:04 UTC (rev 6750)
@@ -34,17 +34,25 @@
this.label1 = new System.Windows.Forms.Label();
this.splitContainer1 = new System.Windows.Forms.SplitContainer();
this.grdTables = new System.Windows.Forms.DataGridView();
- this.tableConfigCtrl = new Maestro.Editors.FeatureSource.Providers.Odbc.OverrideEditor.TableConfigCtrl();
this.COL_OVERRIDE = new System.Windows.Forms.DataGridViewCheckBoxColumn();
this.COL_NAME = new System.Windows.Forms.DataGridViewTextBoxColumn();
this.COL_KEY = new System.Windows.Forms.DataGridViewTextBoxColumn();
this.COL_X = new System.Windows.Forms.DataGridViewTextBoxColumn();
this.COL_Y = new System.Windows.Forms.DataGridViewTextBoxColumn();
this.COL_Z = new System.Windows.Forms.DataGridViewTextBoxColumn();
+ this.tableConfigCtrl = new Maestro.Editors.FeatureSource.Providers.Odbc.OverrideEditor.TableConfigCtrl();
+ this.groupBox1 = new System.Windows.Forms.GroupBox();
+ this.groupBox2 = new System.Windows.Forms.GroupBox();
+ this.label2 = new System.Windows.Forms.Label();
+ this.txtCoordinateSystem = new System.Windows.Forms.TextBox();
+ this.btnPickCs = new System.Windows.Forms.Button();
+ ((System.ComponentModel.ISupportInitialize)(this.splitContainer1)).BeginInit();
this.splitContainer1.Panel1.SuspendLayout();
this.splitContainer1.Panel2.SuspendLayout();
this.splitContainer1.SuspendLayout();
((System.ComponentModel.ISupportInitialize)(this.grdTables)).BeginInit();
+ this.groupBox1.SuspendLayout();
+ this.groupBox2.SuspendLayout();
this.SuspendLayout();
// btnSave
@@ -96,14 +104,9 @@
this.grdTables.Name = "grdTables";
this.grdTables.RowHeadersVisible = false;
this.grdTables.CellClick += new System.Windows.Forms.DataGridViewCellEventHandler(this.grdTables_CellContentClick);
+ this.grdTables.CellContentClick += new System.Windows.Forms.DataGridViewCellEventHandler(this.grdTables_CellContentClick);
this.grdTables.CurrentCellDirtyStateChanged += new System.EventHandler(this.grdTables_CurrentCellDirtyStateChanged);
- this.grdTables.CellContentClick += new System.Windows.Forms.DataGridViewCellEventHandler(this.grdTables_CellContentClick);
- // tableConfigCtrl
- resources.ApplyResources(this.tableConfigCtrl, "tableConfigCtrl");
- this.tableConfigCtrl.Name = "tableConfigCtrl";
// COL_OVERRIDE
this.COL_OVERRIDE.DataPropertyName = "Override";
@@ -146,22 +149,66 @@
this.COL_Z.Name = "COL_Z";
this.COL_Z.ReadOnly = true;
+ // tableConfigCtrl
+ resources.ApplyResources(this.tableConfigCtrl, "tableConfigCtrl");
+ this.tableConfigCtrl.Name = "tableConfigCtrl";
+ // groupBox1
+ resources.ApplyResources(this.groupBox1, "groupBox1");
+ this.groupBox1.Controls.Add(this.label1);
+ this.groupBox1.Controls.Add(this.splitContainer1);
+ this.groupBox1.Name = "groupBox1";
+ this.groupBox1.TabStop = false;
+ // groupBox2
+ resources.ApplyResources(this.groupBox2, "groupBox2");
+ this.groupBox2.Controls.Add(this.btnPickCs);
+ this.groupBox2.Controls.Add(this.txtCoordinateSystem);
+ this.groupBox2.Controls.Add(this.label2);
+ this.groupBox2.Name = "groupBox2";
+ this.groupBox2.TabStop = false;
+ // label2
+ resources.ApplyResources(this.label2, "label2");
+ this.label2.Name = "label2";
+ // txtCoordinateSystem
+ resources.ApplyResources(this.txtCoordinateSystem, "txtCoordinateSystem");
+ this.txtCoordinateSystem.Name = "txtCoordinateSystem";
+ this.txtCoordinateSystem.ReadOnly = true;
+ // btnPickCs
+ resources.ApplyResources(this.btnPickCs, "btnPickCs");
+ this.btnPickCs.Name = "btnPickCs";
+ this.btnPickCs.UseVisualStyleBackColor = true;
+ this.btnPickCs.Click += new System.EventHandler(this.btnPickCs_Click);
// TableConfigurationDialog
this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.None;
resources.ApplyResources(this, "$this");
- this.Controls.Add(this.splitContainer1);
- this.Controls.Add(this.label1);
+ this.Controls.Add(this.groupBox2);
+ this.Controls.Add(this.groupBox1);
this.Controls.Add(this.btnCancel);
this.Controls.Add(this.btnSave);
this.Name = "TableConfigurationDialog";
this.ShowIcon = false;
this.splitContainer1.Panel1.ResumeLayout(false);
this.splitContainer1.Panel2.ResumeLayout(false);
+ ((System.ComponentModel.ISupportInitialize)(this.splitContainer1)).EndInit();
this.splitContainer1.ResumeLayout(false);
((System.ComponentModel.ISupportInitialize)(this.grdTables)).EndInit();
+ this.groupBox1.ResumeLayout(false);
+ this.groupBox1.PerformLayout();
+ this.groupBox2.ResumeLayout(false);
+ this.groupBox2.PerformLayout();
this.ResumeLayout(false);
- this.PerformLayout();
@@ -179,5 +226,10 @@
private System.Windows.Forms.DataGridViewTextBoxColumn COL_X;
private System.Windows.Forms.DataGridViewTextBoxColumn COL_Y;
private System.Windows.Forms.DataGridViewTextBoxColumn COL_Z;
+ private System.Windows.Forms.GroupBox groupBox1;
+ private System.Windows.Forms.GroupBox groupBox2;
+ private System.Windows.Forms.Button btnPickCs;
+ private System.Windows.Forms.TextBox txtCoordinateSystem;
+ private System.Windows.Forms.Label label2;
\ No newline at end of file
Modified: trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/OverrideEditor/TableConfigurationDialog.cs
--- trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/OverrideEditor/TableConfigurationDialog.cs 2012-06-11 13:33:49 UTC (rev 6749)
+++ trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/OverrideEditor/TableConfigurationDialog.cs 2012-06-11 14:29:04 UTC (rev 6750)
@@ -22,10 +22,16 @@
grdTables.DataSource = _tables;
- public TableConfigurationDialog(OdbcConfigurationDocument doc, string schemaName)
+ private IEditorService _edSvc;
+ public TableConfigurationDialog(IEditorService edSvc, OdbcConfigurationDocument doc, string schemaName)
: this()
- tableConfigCtrl.SetSpatialContexts(doc.GetSpatialContextNames());
+ _edSvc = edSvc;
+ var scNames = doc.GetSpatialContextNames();
+ tableConfigCtrl.SetSpatialContexts(scNames);
+ var sc = doc.GetSpatialContext(scNames[0]);
+ txtCoordinateSystem.Text = sc.CoordinateSystemWkt;
var schema = doc.GetSchema(schemaName);
Dictionary<string, TableOverrideItem> tables = new Dictionary<string, TableOverrideItem>();
@@ -72,6 +78,8 @@
+ public string CoordinateSystemWkt { get { return txtCoordinateSystem.Text; } }
public OdbcTableItem[] ConfiguredTables
get
@@ -138,5 +146,12 @@
+ private void btnPickCs_Click(object sender, EventArgs e)
+ var cs = _edSvc.GetCoordinateSystem();
+ if (!string.IsNullOrEmpty(cs))
+ txtCoordinateSystem.Text = cs;
Modified: trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/OverrideEditor/TableConfigurationDialog.resx
--- trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/OverrideEditor/TableConfigurationDialog.resx 2012-06-11 13:33:49 UTC (rev 6749)
+++ trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/OverrideEditor/TableConfigurationDialog.resx 2012-06-11 14:29:04 UTC (rev 6750)
@@ -112,26 +112,26 @@
<value>2.0</value>
</resheader>
<resheader name="reader">
- <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</resheader>
<resheader name="writer">
- <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</resheader>
- <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
<data name="btnSave.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
<value>Bottom, Right</value>
</data>
<data name="btnSave.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
<value>NoControl</value>
</data>
- <assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+ <assembly alias="System.Drawing" name="System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
<data name="btnSave.Location" type="System.Drawing.Point, System.Drawing">
- <value>512, 306</value>
+ <value>512, 445</value>
</data>
<data name="btnSave.Size" type="System.Drawing.Size, System.Drawing">
<value>75, 23</value>
</data>
- <assembly alias="mscorlib" name="mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <assembly alias="mscorlib" name="mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
<data name="btnSave.TabIndex" type="System.Int32, mscorlib">
<value>1</value>
</data>
@@ -142,7 +142,7 @@
<value>btnSave</value>
</data>
<data name=">>btnSave.Type" xml:space="preserve">
- <value>System.Windows.Forms.Button, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.Button, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>btnSave.Parent" xml:space="preserve">
<value>$this</value>
@@ -157,7 +157,7 @@
</data>
<data name="btnCancel.Location" type="System.Drawing.Point, System.Drawing">
- <value>593, 306</value>
+ <value>593, 445</value>
</data>
<data name="btnCancel.Size" type="System.Drawing.Size, System.Drawing">
@@ -172,7 +172,7 @@
<value>btnCancel</value>
</data>
<data name=">>btnCancel.Type" xml:space="preserve">
</data>
<data name=">>btnCancel.Parent" xml:space="preserve">
@@ -187,7 +187,7 @@
</data>
<data name="label1.Location" type="System.Drawing.Point, System.Drawing">
- <value>13, 13</value>
+ <value>15, 26</value>
</data>
<data name="label1.Size" type="System.Drawing.Size, System.Drawing">
<value>467, 13</value>
@@ -202,68 +202,38 @@
<value>label1</value>
</data>
<data name=">>label1.Type" xml:space="preserve">
- <value>System.Windows.Forms.Label, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.Label, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>label1.Parent" xml:space="preserve">
- <value>$this</value>
+ <value>groupBox1</value>
</data>
<data name=">>label1.ZOrder" xml:space="preserve">
- <value>1</value>
+ <value>0</value>
</data>
<data name="splitContainer1.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
<value>Top, Bottom, Left, Right</value>
</data>
<data name="splitContainer1.Location" type="System.Drawing.Point, System.Drawing">
- <value>16, 39</value>
+ <value>18, 47</value>
</data>
- <metadata name="COL_OVERRIDE.UserAddedColumn" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+ <metadata name="COL_OVERRIDE.UserAddedColumn" type="System.Boolean, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
<value>True</value>
</metadata>
- <data name="COL_OVERRIDE.HeaderText" xml:space="preserve">
- <value>Override</value>
- </data>
- <data name="COL_OVERRIDE.Width" type="System.Int32, mscorlib">
- <value>60</value>
- </data>
- <metadata name="COL_NAME.UserAddedColumn" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+ <metadata name="COL_NAME.UserAddedColumn" type="System.Boolean, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
<value>True</value>
</metadata>
- <data name="COL_NAME.HeaderText" xml:space="preserve">
- <value>Name</value>
- </data>
- <metadata name="COL_KEY.UserAddedColumn" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+ <metadata name="COL_KEY.UserAddedColumn" type="System.Boolean, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
<value>True</value>
</metadata>
- <data name="COL_KEY.HeaderText" xml:space="preserve">
- <value>Key</value>
- </data>
- <data name="COL_KEY.Width" type="System.Int32, mscorlib">
- <value>50</value>
- </data>
- <metadata name="COL_X.UserAddedColumn" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+ <metadata name="COL_X.UserAddedColumn" type="System.Boolean, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
<value>True</value>
</metadata>
- <data name="COL_X.HeaderText" xml:space="preserve">
- <value>X Column</value>
- </data>
- <data name="COL_X.Width" type="System.Int32, mscorlib">
- <value>50</value>
- </data>
- <metadata name="COL_Y.UserAddedColumn" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+ <metadata name="COL_Y.UserAddedColumn" type="System.Boolean, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
<value>True</value>
</metadata>
- <data name="COL_Y.HeaderText" xml:space="preserve">
- <value>Y Column</value>
- </data>
- <data name="COL_Y.Width" type="System.Int32, mscorlib">
- <value>50</value>
- </data>
- <metadata name="COL_Z.UserAddedColumn" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+ <metadata name="COL_Z.UserAddedColumn" type="System.Boolean, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
<value>True</value>
</metadata>
- <data name="COL_Z.HeaderText" xml:space="preserve">
- <value>Z Column</value>
- </data>
<data name="grdTables.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
<value>Fill</value>
</data>
@@ -271,7 +241,7 @@
<value>0, 0</value>
</data>
<data name="grdTables.Size" type="System.Drawing.Size, System.Drawing">
- <value>454, 250</value>
+ <value>422, 298</value>
</data>
<data name="grdTables.TabIndex" type="System.Int32, mscorlib">
<value>0</value>
@@ -280,7 +250,7 @@
<value>grdTables</value>
</data>
<data name=">>grdTables.Type" xml:space="preserve">
- <value>System.Windows.Forms.DataGridView, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.DataGridView, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>grdTables.Parent" xml:space="preserve">
<value>splitContainer1.Panel1</value>
@@ -292,7 +262,7 @@
</data>
<data name=">>splitContainer1.Panel1.Type" xml:space="preserve">
- <value>System.Windows.Forms.SplitterPanel, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.SplitterPanel, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>splitContainer1.Panel1.Parent" xml:space="preserve">
<value>splitContainer1</value>
@@ -307,7 +277,7 @@
<value>0, 0</value>
</data>
<data name="tableConfigCtrl.Size" type="System.Drawing.Size, System.Drawing">
- <value>194, 250</value>
+ <value>194, 298</value>
</data>
<data name="tableConfigCtrl.TabIndex" type="System.Int32, mscorlib">
<value>0</value>
@@ -316,7 +286,7 @@
<value>tableConfigCtrl</value>
</data>
<data name=">>tableConfigCtrl.Type" xml:space="preserve">
- <value>Maestro.Editors.FeatureSource.Providers.Odbc.OverrideEditor.TableConfigCtrl, Maestro.Editors, Version=3.0.0.5475, Culture=neutral, PublicKeyToken=null</value>
+ <value>Maestro.Editors.FeatureSource.Providers.Odbc.OverrideEditor.TableConfigCtrl, Maestro.Editors, Version=5.0.0.6640, Culture=neutral, PublicKeyToken=f526c48929fda856</value>
</data>
<data name=">>tableConfigCtrl.Parent" xml:space="preserve">
<value>splitContainer1.Panel2</value>
@@ -328,7 +298,7 @@
</data>
<data name=">>splitContainer1.Panel2.Type" xml:space="preserve">
</data>
<data name=">>splitContainer1.Panel2.Parent" xml:space="preserve">
@@ -337,10 +307,10 @@
<value>1</value>
</data>
<data name="splitContainer1.Size" type="System.Drawing.Size, System.Drawing">
- <value>652, 250</value>
+ <value>620, 298</value>
</data>
<data name="splitContainer1.SplitterDistance" type="System.Int32, mscorlib">
- <value>454</value>
+ <value>422</value>
</data>
<data name="splitContainer1.TabIndex" type="System.Int32, mscorlib">
<value>4</value>
@@ -349,19 +319,193 @@
</data>
<data name=">>splitContainer1.Type" xml:space="preserve">
- <value>System.Windows.Forms.SplitContainer, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.SplitContainer, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>splitContainer1.Parent" xml:space="preserve">
+ </data>
+ <data name=">>splitContainer1.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <value>True</value>
+ </metadata>
+ <data name="COL_OVERRIDE.HeaderText" xml:space="preserve">
+ <value>Override</value>
+ </data>
+ <data name="COL_OVERRIDE.Width" type="System.Int32, mscorlib">
+ <value>60</value>
+ </data>
+ </metadata>
+ <data name="COL_NAME.HeaderText" xml:space="preserve">
+ <value>Name</value>
+ </data>
+ </metadata>
+ <data name="COL_KEY.HeaderText" xml:space="preserve">
+ <value>Key</value>
+ </data>
+ <data name="COL_KEY.Width" type="System.Int32, mscorlib">
+ <value>50</value>
+ </data>
+ </metadata>
+ <data name="COL_X.HeaderText" xml:space="preserve">
+ <value>X Column</value>
+ </data>
+ <data name="COL_X.Width" type="System.Int32, mscorlib">
+ <value>50</value>
+ </data>
+ </metadata>
+ <data name="COL_Y.HeaderText" xml:space="preserve">
+ <value>Y Column</value>
+ </data>
+ <data name="COL_Y.Width" type="System.Int32, mscorlib">
+ <value>50</value>
+ </data>
+ </metadata>
+ <data name="COL_Z.HeaderText" xml:space="preserve">
+ <value>Z Column</value>
+ </data>
+ <data name="groupBox1.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Top, Bottom, Left, Right</value>
+ </data>
+ <data name="groupBox1.Location" type="System.Drawing.Point, System.Drawing">
+ <value>12, 75</value>
+ </data>
+ <data name="groupBox1.Size" type="System.Drawing.Size, System.Drawing">
+ <value>656, 364</value>
+ </data>
+ <data name="groupBox1.TabIndex" type="System.Int32, mscorlib">
+ <value>5</value>
+ </data>
+ <data name="groupBox1.Text" xml:space="preserve">
+ <value>Overrides</value>
+ </data>
+ <data name=">>groupBox1.Name" xml:space="preserve">
+ </data>
+ <data name=">>groupBox1.Type" xml:space="preserve">
+ <value>System.Windows.Forms.GroupBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>groupBox1.Parent" xml:space="preserve">
</data>
- <data name=">>splitContainer1.ZOrder" xml:space="preserve">
+ <data name=">>groupBox1.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name="groupBox2.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Top, Left, Right</value>
+ </data>
+ <data name="btnPickCs.Location" type="System.Drawing.Point, System.Drawing">
+ <value>606, 21</value>
+ </data>
+ <data name="btnPickCs.Size" type="System.Drawing.Size, System.Drawing">
+ <value>32, 23</value>
+ </data>
+ <data name="btnPickCs.TabIndex" type="System.Int32, mscorlib">
+ <value>2</value>
+ </data>
+ <data name="btnPickCs.Text" xml:space="preserve">
+ <value>...</value>
+ </data>
+ <data name=">>btnPickCs.Name" xml:space="preserve">
+ <value>btnPickCs</value>
+ </data>
+ <data name=">>btnPickCs.Type" xml:space="preserve">
+ </data>
+ <data name=">>btnPickCs.Parent" xml:space="preserve">
+ <value>groupBox2</value>
+ </data>
+ <data name=">>btnPickCs.ZOrder" xml:space="preserve">
<value>0</value>
</data>
- <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+ <data name="txtCoordinateSystem.Location" type="System.Drawing.Point, System.Drawing">
+ <value>168, 23</value>
+ </data>
+ <data name="txtCoordinateSystem.Size" type="System.Drawing.Size, System.Drawing">
+ <value>432, 20</value>
+ </data>
+ <data name="txtCoordinateSystem.TabIndex" type="System.Int32, mscorlib">
+ <value>1</value>
+ </data>
+ <data name=">>txtCoordinateSystem.Name" xml:space="preserve">
+ <value>txtCoordinateSystem</value>
+ </data>
+ <data name=">>txtCoordinateSystem.Type" xml:space="preserve">
+ <value>System.Windows.Forms.TextBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>txtCoordinateSystem.Parent" xml:space="preserve">
+ </data>
+ <data name=">>txtCoordinateSystem.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name="label2.AutoSize" type="System.Boolean, mscorlib">
<value>True</value>
+ </data>
+ <data name="label2.Location" type="System.Drawing.Point, System.Drawing">
+ <value>14, 26</value>
+ </data>
+ <data name="label2.Size" type="System.Drawing.Size, System.Drawing">
+ <value>136, 13</value>
+ </data>
+ <data name="label2.TabIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ <data name="label2.Text" xml:space="preserve">
+ <value>Use this Coordinate System</value>
+ </data>
+ <data name=">>label2.Name" xml:space="preserve">
+ <value>label2</value>
+ </data>
+ <data name=">>label2.Type" xml:space="preserve">
+ </data>
+ <data name=">>label2.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label2.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
+ <data name="groupBox2.Location" type="System.Drawing.Point, System.Drawing">
+ <value>13, 13</value>
+ </data>
+ <data name="groupBox2.Size" type="System.Drawing.Size, System.Drawing">
+ <value>655, 56</value>
+ </data>
+ <data name="groupBox2.TabIndex" type="System.Int32, mscorlib">
+ <value>6</value>
+ </data>
+ <data name="groupBox2.Text" xml:space="preserve">
+ <value>Coordinate System</value>
+ </data>
+ <data name=">>groupBox2.Name" xml:space="preserve">
+ </data>
+ <data name=">>groupBox2.Type" xml:space="preserve">
+ </data>
+ <data name=">>groupBox2.Parent" xml:space="preserve">
+ <value>$this</value>
+ </data>
+ <data name=">>groupBox2.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
</metadata>
<data name="$this.ClientSize" type="System.Drawing.Size, System.Drawing">
- <value>680, 341</value>
+ <value>680, 480</value>
</data>
<data name="$this.StartPosition" type="System.Windows.Forms.FormStartPosition, System.Windows.Forms">
<value>WindowsDefaultBounds</value>
@@ -373,42 +517,42 @@
<value>COL_OVERRIDE</value>
</data>
<data name=">>COL_OVERRIDE.Type" xml:space="preserve">
- <value>System.Windows.Forms.DataGridViewCheckBoxColumn, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.DataGridViewCheckBoxColumn, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>COL_NAME.Name" xml:space="preserve">
<value>COL_NAME</value>
</data>
<data name=">>COL_NAME.Type" xml:space="preserve">
- <value>System.Windows.Forms.DataGridViewTextBoxColumn, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.DataGridViewTextBoxColumn, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>COL_KEY.Name" xml:space="preserve">
<value>COL_KEY</value>
</data>
<data name=">>COL_KEY.Type" xml:space="preserve">
</data>
<data name=">>COL_X.Name" xml:space="preserve">
<value>COL_X</value>
</data>
<data name=">>COL_X.Type" xml:space="preserve">
</data>
<data name=">>COL_Y.Name" xml:space="preserve">
<value>COL_Y</value>
</data>
<data name=">>COL_Y.Type" xml:space="preserve">
</data>
<data name=">>COL_Z.Name" xml:space="preserve">
<value>COL_Z</value>
</data>
<data name=">>COL_Z.Type" xml:space="preserve">
</data>
<data name=">>$this.Name" xml:space="preserve">
<value>TableConfigurationDialog</value>
</data>
<data name=">>$this.Type" xml:space="preserve">
- <value>System.Windows.Forms.Form, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.Form, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
</root>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/ClassDefinition.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/ClassDefinition.cs 2012-06-11 13:33:49 UTC (rev 6749)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/ClassDefinition.cs 2012-06-11 14:29:04 UTC (rev 6750)
@@ -167,8 +167,28 @@
return _properties.IndexOf(prop);
/// <summary>
+ /// Removes the property definition of the specified name. If it is a data property
+ /// it is also removed from the identity properties (if it is specified as one)
+ /// </summary>
+ /// <param name="propertyName"></param>
+ public void RemoveProperty(string propertyName)
+ int idx = -1;
+ for (int i = 0; i < _properties.Count; i++)
+ if (_properties[i].Name == propertyName)
+ idx = i;
+ break;
+ if (idx >= 0)
+ RemovePropertyAt(idx);
+ /// <summary>
/// Removes the property definition at the specified index. If it is a data property
/// is is also removed from the identity properties (if it is specified as one)
/// </summary>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/ConfigurationDocument.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/ConfigurationDocument.cs 2012-06-11 13:33:49 UTC (rev 6749)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/ConfigurationDocument.cs 2012-06-11 14:29:04 UTC (rev 6750)
@@ -147,7 +147,7 @@
/// </summary>
/// <param name="doc"></param>
/// <param name="currentNode"></param>
- public void WriteXml(System.Xml.XmlDocument doc, System.Xml.XmlNode currentNode)
+ public virtual void WriteXml(System.Xml.XmlDocument doc, System.Xml.XmlNode currentNode)
var dstore = doc.CreateElement("fdo", "DataStore", XmlNamespaces.FDO);
dstore.SetAttribute("xmlns:xs", XmlNamespaces.XS);
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/OdbcConfigurationDocument.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/OdbcConfigurationDocument.cs 2012-06-11 13:33:49 UTC (rev 6749)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/OdbcConfigurationDocument.cs 2012-06-11 14:29:04 UTC (rev 6750)
@@ -69,6 +69,35 @@
return items;
+ public override void WriteXml(XmlDocument doc, XmlNode currentNode)
+ foreach (var schema in this.Schemas)
+ foreach (var cls in schema.Classes)
+ var ov = this.GetOverride(schema.Name, cls.Name);
+ if (ov != null)
+ if (!string.IsNullOrEmpty(ov.XColumn))
+ cls.RemoveProperty(ov.XColumn);
+ if (!string.IsNullOrEmpty(ov.YColumn))
+ cls.RemoveProperty(ov.YColumn);
+ if (!string.IsNullOrEmpty(ov.ZColumn))
+ cls.RemoveProperty(ov.ZColumn);
+ base.WriteXml(doc, currentNode);
/// <summary>
/// Write this document's schema mappings to the given XML document
/// </summary>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/OdbcTableItem.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/OdbcTableItem.cs 2012-06-11 13:33:49 UTC (rev 6749)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/OdbcTableItem.cs 2012-06-11 14:29:04 UTC (rev 6750)
@@ -76,44 +76,49 @@
var table = doc.CreateElement("Table");
table.SetAttribute("name", this.ClassName);
+ ctype.AppendChild(table);
+ PropertyDefinition geomProp = null;
+ foreach (var prop in cls.Properties)
- PropertyDefinition geomProp = null;
- foreach (var prop in cls.Properties)
+ //If this is geometry, we'll handle it later
+ if (prop.Name == cls.DefaultGeometryPropertyName)
- //If this is geometry, we'll handle it later
- if (prop.Name == cls.DefaultGeometryPropertyName)
- geomProp = prop;
- continue;
+ geomProp = prop;
+ continue;
- var el = doc.CreateElement("element");
- el.SetAttribute("name", Utility.EncodeFDOName(prop.Name));
+ //If this is a geometry mapped X/Y/Z property, skip it
+ if (prop.Name == this.XColumn ||
+ prop.Name == this.YColumn ||
+ prop.Name == this.ZColumn)
+ continue;
- var col = doc.CreateElement("Column");
- col.SetAttribute("name", prop.Name);
+ var el = doc.CreateElement("element");
+ el.SetAttribute("name", Utility.EncodeFDOName(prop.Name));
- el.AppendChild(col);
- table.AppendChild(el);
+ var col = doc.CreateElement("Column");
+ col.SetAttribute("name", prop.Name);
- //Append geometry mapping
- if (geomProp != null)
- el.SetAttribute("name", geomProp.Name);
+ el.AppendChild(col);
+ ctype.AppendChild(el);
- if (!string.IsNullOrEmpty(this.XColumn))
- el.SetAttribute("xColumnName", this.XColumn);
- if (!string.IsNullOrEmpty(this.YColumn))
- el.SetAttribute("yColumnName", this.YColumn);
- if (!string.IsNullOrEmpty(this.ZColumn))
- el.SetAttribute("zColumnName", this.ZColumn);
+ //Append geometry mapping
+ if (geomProp != null)
+ el.SetAttribute("name", geomProp.Name);
+ if (!string.IsNullOrEmpty(this.XColumn))
+ el.SetAttribute("xColumnName", this.XColumn);
+ if (!string.IsNullOrEmpty(this.YColumn))
+ el.SetAttribute("yColumnName", this.YColumn);
+ if (!string.IsNullOrEmpty(this.ZColumn))
+ el.SetAttribute("zColumnName", this.ZColumn);
- ctype.AppendChild(table);
currentNode.AppendChild(ctype);
@@ -143,8 +148,9 @@
var table = node["Table"];
- foreach (System.Xml.XmlNode el in table.ChildNodes)
+ var el = table.NextSibling;
+ //foreach (System.Xml.XmlNode el in table.ChildNodes)
+ while(el != null)
var colName = el.Attributes["name"];
@@ -161,6 +167,7 @@
if (z != null)
this.ZColumn = z.Value;
+ el = el.NextSibling;
More information about the mapguide-commits
