[mapguide-commits] r6752 - branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI/SchemaOverrides
svn_mapguide at osgeo.org
Mon Jun 11 19:12:46 PDT 2012
Author: jng
Date: 2012-06-11 19:12:46 -0700 (Mon, 11 Jun 2012)
New Revision: 6752
branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/OdbcTableItem.cs
#1980: Backport ODBC configuration fix to 4.0.x
Modified: branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/OdbcTableItem.cs
--- branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/OdbcTableItem.cs 2012-06-11 14:30:25 UTC (rev 6751)
+++ branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/OdbcTableItem.cs 2012-06-12 02:12:46 UTC (rev 6752)
@@ -76,44 +76,43 @@
var table = doc.CreateElement("Table");
table.SetAttribute("name", this.ClassName);
+ ctype.AppendChild(table);
+ PropertyDefinition geomProp = null;
+ foreach (var prop in cls.Properties)
- PropertyDefinition geomProp = null;
- foreach (var prop in cls.Properties)
+ //If this is geometry, we'll handle it later
+ if (prop.Name == cls.DefaultGeometryPropertyName)
- //If this is geometry, we'll handle it later
- if (prop.Name == cls.DefaultGeometryPropertyName)
- geomProp = prop;
- continue;
+ geomProp = prop;
+ continue;
- var el = doc.CreateElement("element");
- el.SetAttribute("name", Utility.EncodeFDOName(prop.Name));
+ var el = doc.CreateElement("element");
+ el.SetAttribute("name", Utility.EncodeFDOName(prop.Name));
- var col = doc.CreateElement("Column");
- col.SetAttribute("name", prop.Name);
+ var col = doc.CreateElement("Column");
+ col.SetAttribute("name", prop.Name);
- el.AppendChild(col);
- table.AppendChild(el);
+ el.AppendChild(col);
+ ctype.AppendChild(el);
- //Append geometry mapping
- if (geomProp != null)
- el.SetAttribute("name", geomProp.Name);
+ //Append geometry mapping
+ if (geomProp != null)
+ el.SetAttribute("name", geomProp.Name);
- if (!string.IsNullOrEmpty(this.XColumn))
- el.SetAttribute("xColumnName", this.XColumn);
- if (!string.IsNullOrEmpty(this.YColumn))
- el.SetAttribute("yColumnName", this.YColumn);
- if (!string.IsNullOrEmpty(this.ZColumn))
- el.SetAttribute("zColumnName", this.ZColumn);
+ if (!string.IsNullOrEmpty(this.XColumn))
+ el.SetAttribute("xColumnName", this.XColumn);
+ if (!string.IsNullOrEmpty(this.YColumn))
+ el.SetAttribute("yColumnName", this.YColumn);
+ if (!string.IsNullOrEmpty(this.ZColumn))
+ el.SetAttribute("zColumnName", this.ZColumn);
- ctype.AppendChild(table);
currentNode.AppendChild(ctype);
@@ -144,7 +143,9 @@
var table = node["Table"];
- foreach (System.Xml.XmlNode el in table.ChildNodes)
+ var el = table.NextSibling;
+ //foreach (System.Xml.XmlNode el in table.ChildNodes)
+ while(el != null)
var colName = el.Attributes["name"];
@@ -161,6 +162,7 @@
if (z != null)
this.ZColumn = z.Value;
+ el = el.NextSibling;
More information about the mapguide-commits
