[mapguide-commits] r6756 - in branches/2.4/MgDev: Common/PlatformBase/MapLayer Server/src/UnitTesting
svn_mapguide at osgeo.org
Wed Jun 13 01:57:02 PDT 2012
Author: jng
Date: 2012-06-13 01:57:02 -0700 (Wed, 13 Jun 2012)
New Revision: 6756
branches/2.4/MgDev/Common/PlatformBase/MapLayer/SelectionBase.cpp
branches/2.4/MgDev/Common/PlatformBase/MapLayer/SelectionBase.h
branches/2.4/MgDev/Server/src/UnitTesting/TestMisc.cpp
branches/2.4/MgDev/Server/src/UnitTesting/TestMisc.h
#1304: Fix MgSelection constructor bug when an empty XML selection string is passed. Reviewed by Walt Welton-Lair
Modified: branches/2.4/MgDev/Common/PlatformBase/MapLayer/SelectionBase.cpp
--- branches/2.4/MgDev/Common/PlatformBase/MapLayer/SelectionBase.cpp 2012-06-13 08:01:46 UTC (rev 6755)
+++ branches/2.4/MgDev/Common/PlatformBase/MapLayer/SelectionBase.cpp 2012-06-13 08:57:02 UTC (rev 6756)
@@ -51,6 +51,13 @@
// Destructor
MgSelectionBase::~MgSelectionBase()
+ ClearSelections();
+ delete m_stream;
+ m_stream = NULL;
+void MgSelectionBase::ClearSelections()
// Delete selection manually instead of relying on deep template deletion
SelectionMap::iterator lIter;
for (lIter = m_selections.begin(); lIter != m_selections.end(); ++lIter)
@@ -67,12 +74,8 @@
delete clsmap;
m_selections.clear();
- delete m_stream;
- m_stream = NULL;
void MgSelectionBase::Dispose()
delete this;
@@ -100,6 +103,10 @@
// Read selection from XML document. Previous selection is cleared.
void MgSelectionBase::FromXml(CREFSTRING xmlSelectionString)
+ if (xmlSelectionString.empty())
+ return;
// TODO: Validate that data is legal by parsing each selection
// string. MgMap will be required to do this.
Modified: branches/2.4/MgDev/Common/PlatformBase/MapLayer/SelectionBase.h
--- branches/2.4/MgDev/Common/PlatformBase/MapLayer/SelectionBase.h 2012-06-13 08:01:46 UTC (rev 6755)
+++ branches/2.4/MgDev/Common/PlatformBase/MapLayer/SelectionBase.h 2012-06-13 08:57:02 UTC (rev 6756)
@@ -622,6 +622,9 @@
SelectionMap m_selections;
Ptr<MgMapBase> m_map;
MgMemoryStreamHelper* m_stream;
+private:
+ void ClearSelections();
Modified: branches/2.4/MgDev/Server/src/UnitTesting/TestMisc.cpp
--- branches/2.4/MgDev/Server/src/UnitTesting/TestMisc.cpp 2012-06-13 08:01:46 UTC (rev 6755)
+++ branches/2.4/MgDev/Server/src/UnitTesting/TestMisc.cpp 2012-06-13 08:57:02 UTC (rev 6756)
@@ -480,4 +480,31 @@
throw;
+void TestMisc::TestCase_1304()
+ try
+ Ptr<MgResourceIdentifier> mapRes1 = new MgResourceIdentifier(L"Library://UnitTests/Maps/Sheboygan.MapDefinition");
+ Ptr<MgMap> map1 = new MgMap(m_siteConnection);
+ map1->Create(mapRes1, L"UnitTestSheboygan1");
+ Ptr<MgSelection> sel = new MgSelection(map1, L"");
+ Ptr<MgReadOnlyLayerCollection> selLayers = sel->GetLayers();
+ CPPUNIT_ASSERT_MESSAGE("Expected null MgReadOnlyLayerCollection", NULL == selLayers.p);
+ sel->FromXml(L""); //Should be same result
+ selLayers = sel->GetLayers();
+ catch (MgException* e)
+ STRING message = e->GetDetails(TEST_LOCALE);
+ SAFE_RELEASE(e);
+ CPPUNIT_FAIL(MG_WCHAR_TO_CHAR(message.c_str()));
+ catch (...)
+ throw;
\ No newline at end of file
Modified: branches/2.4/MgDev/Server/src/UnitTesting/TestMisc.h
--- branches/2.4/MgDev/Server/src/UnitTesting/TestMisc.h 2012-06-13 08:01:46 UTC (rev 6755)
+++ branches/2.4/MgDev/Server/src/UnitTesting/TestMisc.h 2012-06-13 08:57:02 UTC (rev 6756)
@@ -27,6 +27,7 @@
CPPUNIT_TEST(TestCase_CommonExceptionMessages);
CPPUNIT_TEST(TestCase_611);
+ CPPUNIT_TEST(TestCase_1304);
CPPUNIT_TEST(TestEnd); // This must be the very last unit test
CPPUNIT_TEST_SUITE_END();
@@ -42,6 +43,7 @@
void TestCase_CommonExceptionMessages();
void TestCase_611();
+ void TestCase_1304();
private:
Ptr<MgSiteConnection> m_siteConnection;
More information about the mapguide-commits
