[mapguide-commits] r6758 - in trunk/MgDev: . Common/MapGuideCommon/MapLayer Common/MapGuideCommon/Resources Common/PlatformBase/MapLayer Common/Stylization Desktop Server/src/Services/Feature Server/src/Services/Mapping Server/src/UnitTesting Web/src/mapadmin/HelpDocs Web/src/mapviewerphp Web/src/schemareport Web/src/viewerfiles
svn_mapguide at osgeo.org
Wed Jun 13 06:11:50 PDT 2012
Author: jng
Date: 2012-06-13 06:11:49 -0700 (Wed, 13 Jun 2012)
New Revision: 6758
trunk/MgDev/
trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.cpp
trunk/MgDev/Common/MapGuideCommon/Resources/mapguide_en.res
trunk/MgDev/Common/PlatformBase/MapLayer/SelectionBase.cpp
trunk/MgDev/Common/PlatformBase/MapLayer/SelectionBase.h
trunk/MgDev/Common/Stylization/SE_Renderer.cpp
trunk/MgDev/Desktop/
trunk/MgDev/Server/src/Services/Feature/ServerFeatureUtil.cpp
trunk/MgDev/Server/src/Services/Mapping/MappingUtil.cpp
trunk/MgDev/Server/src/UnitTesting/TestMisc.cpp
trunk/MgDev/Server/src/UnitTesting/TestMisc.h
trunk/MgDev/Web/src/mapadmin/HelpDocs/
trunk/MgDev/Web/src/mapadmin/HelpDocs/configuring_servers.htm
trunk/MgDev/Web/src/mapviewerphp/quickplotgeneratepicture.php
trunk/MgDev/Web/src/schemareport/showgeom.php
trunk/MgDev/Web/src/viewerfiles/
trunk/MgDev/Web/src/viewerfiles/quickplot.js
#611, #1304: Merge r6749, r6753 and r6756 into trunk.
Property changes on: trunk/MgDev
___________________________________________________________________
Modified: svn:mergeinfo
- /sandbox/rfc94:5099-5163
+ /branches/2.4/MgDev:6749-6756
Modified: trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.cpp
--- trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.cpp 2012-06-13 13:07:42 UTC (rev 6757)
+++ trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.cpp 2012-06-13 13:11:49 UTC (rev 6758)
@@ -799,6 +799,9 @@
Ptr<MgMemoryStreamHelper> streamHelper = new MgMemoryStreamHelper();
Ptr<MgStream> stream = new MgStream(streamHelper);
+ //This is to trap layers attached to groups not in this map
+ std::map<STRING, MgLayerGroup*> groups;
//groups
INT32 groupCount = m_groups->GetCount();
stream->WriteInt32(groupCount);
@@ -806,6 +809,7 @@
Ptr<MgLayerGroup> group = m_groups->GetItem(groupIndex);
Ptr<MgLayerGroup> parent = group->GetGroup();
+ groups[group->GetObjectId()] = group;
stream->WriteString(parent != NULL? parent->GetName(): L"");
stream->WriteObject(group);
@@ -817,6 +821,13 @@
Ptr<MgLayerBase> layer = m_layers->GetItem(layerIndex);
Ptr<MgLayerGroup> parent = layer->GetGroup();
+ if (NULL != parent.p && groups.find(parent->GetObjectId()) == groups.end())
+ MgStringCollection args;
+ args.Add(layer->GetName());
+ args.Add(parent->GetName());
+ throw new MgGroupNotFoundException(L"MgMap.PackLayersAndGroups", __LINE__, __WFILE__, NULL, L"MgLayerBelongsToGroupNotInMap", &args);
stream->WriteObject(layer);
Modified: trunk/MgDev/Common/MapGuideCommon/Resources/mapguide_en.res
--- trunk/MgDev/Common/MapGuideCommon/Resources/mapguide_en.res 2012-06-13 13:07:42 UTC (rev 6757)
+++ trunk/MgDev/Common/MapGuideCommon/Resources/mapguide_en.res 2012-06-13 13:11:49 UTC (rev 6758)
@@ -288,6 +288,7 @@
MgInvalidWebWidgetType = The web widget type is invalid because it is not recognized.
MgInvalidXmlDateTime = The Xml date time is invalid because not all of the fields were found.
MgInvalidYear = The year is invalid because it must be between 1 and 9999.
+MgLayerBelongsToGroupNotInMap = The layer (%1) belongs to a group (%2) which is not part of the map.
MgMachineIpMustBeLocalHost = The machine IP address must be a local host.
MgMapCacheCleared = The Tile Service map cache has been cleared. Please increase TiledMapCacheSize in serverconfig.ini.
MgMapDisplayDpiCannotBeLessThanOrEqualToZero = The map DPI cannot be less than or equal to zero.
Modified: trunk/MgDev/Common/PlatformBase/MapLayer/SelectionBase.cpp
--- trunk/MgDev/Common/PlatformBase/MapLayer/SelectionBase.cpp 2012-06-13 13:07:42 UTC (rev 6757)
+++ trunk/MgDev/Common/PlatformBase/MapLayer/SelectionBase.cpp 2012-06-13 13:11:49 UTC (rev 6758)
@@ -51,6 +51,13 @@
// Destructor
MgSelectionBase::~MgSelectionBase()
+ ClearSelections();
+ delete m_stream;
+ m_stream = NULL;
+void MgSelectionBase::ClearSelections()
// Delete selection manually instead of relying on deep template deletion
SelectionMap::iterator lIter;
for (lIter = m_selections.begin(); lIter != m_selections.end(); ++lIter)
@@ -67,12 +74,8 @@
delete clsmap;
m_selections.clear();
- delete m_stream;
- m_stream = NULL;
void MgSelectionBase::Dispose()
delete this;
@@ -100,6 +103,10 @@
// Read selection from XML document. Previous selection is cleared.
void MgSelectionBase::FromXml(CREFSTRING xmlSelectionString)
+ if (xmlSelectionString.empty())
+ return;
// TODO: Validate that data is legal by parsing each selection
// string. MgMap will be required to do this.
Modified: trunk/MgDev/Common/PlatformBase/MapLayer/SelectionBase.h
--- trunk/MgDev/Common/PlatformBase/MapLayer/SelectionBase.h 2012-06-13 13:07:42 UTC (rev 6757)
+++ trunk/MgDev/Common/PlatformBase/MapLayer/SelectionBase.h 2012-06-13 13:11:49 UTC (rev 6758)
@@ -622,6 +622,9 @@
SelectionMap m_selections;
Ptr<MgMapBase> m_map;
MgMemoryStreamHelper* m_stream;
+private:
+ void ClearSelections();
Property changes on: trunk/MgDev/Common/Stylization/SE_Renderer.cpp
- /sandbox/adsk/2.4j/Common/Stylization/SE_Renderer.cpp:6327-6445
/sandbox/rfc94/Common/Stylization/SE_Renderer.cpp:5099-5163
/trunk/MgDev/Common/Stylization/SE_Renderer.cpp:6250-6326
+ /branches/2.4/MgDev/Common/Stylization/SE_Renderer.cpp:6749-6756
Property changes on: trunk/MgDev/Desktop
- /branches/2.4/MgDev/Desktop:6612-6613,6615-6616
/sandbox/rfc94/Desktop:5099-5163
+ /branches/2.4/MgDev/Desktop:6612-6613,6615-6616,6749-6756
Property changes on: trunk/MgDev/Server/src/Services/Feature/ServerFeatureUtil.cpp
- /branches/2.4/MgDev/Server/src/Services/Feature/ServerFeatureUtil.cpp:6738-6741
/sandbox/adsk/2.4j/Server/src/Services/Feature/ServerFeatureUtil.cpp:6327-6481
/sandbox/rfc94/Server/src/Services/Feature/ServerFeatureUtil.cpp:5099-5163
/trunk/MgDev/Server/src/Services/Feature/ServerFeatureUtil.cpp:6250-6326
+ /branches/2.4/MgDev/Server/src/Services/Feature/ServerFeatureUtil.cpp:6738-6741,6749-6756
Property changes on: trunk/MgDev/Server/src/Services/Mapping/MappingUtil.cpp
- /branches/2.4/MgDev/Server/src/Services/Mapping/MappingUtil.cpp:6738-6741
/sandbox/adsk/2.4j/Server/src/Services/Mapping/MappingUtil.cpp:6327-6535
/sandbox/rfc94/Server/src/Services/Mapping/MappingUtil.cpp:5099-5163
/trunk/MgDev/Server/src/Services/Mapping/MappingUtil.cpp:6250-6326
+ /branches/2.4/MgDev/Server/src/Services/Mapping/MappingUtil.cpp:6738-6741,6749-6756
Modified: trunk/MgDev/Server/src/UnitTesting/TestMisc.cpp
--- trunk/MgDev/Server/src/UnitTesting/TestMisc.cpp 2012-06-13 13:07:42 UTC (rev 6757)
+++ trunk/MgDev/Server/src/UnitTesting/TestMisc.cpp 2012-06-13 13:11:49 UTC (rev 6758)
@@ -17,6 +17,9 @@
#include "MapGuideCommon.h"
#include "TestMisc.h"
+#include "ServiceManager.h"
+#include "ServerResourceService.h"
+#include "ServerSiteService.h"
#include "../UnitTesting/CppUnitExtensions.h"
#include "FoundationDefs.h"
const STRING TEST_LOCALE = L"en";
@@ -25,6 +28,35 @@
TestMisc::TestMisc()
+ // Initialize service objects.
+ MgServiceManager* serviceManager = MgServiceManager::GetInstance();
+ m_svcResource = dynamic_cast<MgResourceService*>(
+ serviceManager->RequestService(MgServiceType::ResourceService));
+ assert(m_svcResource != NULL);
+ // Initialize a site connection.
+ Ptr<MgServerSiteService> svcSite = dynamic_cast<MgServerSiteService*>(
+ serviceManager->RequestService(MgServiceType::SiteService));
+ assert(svcSite != NULL);
+ Ptr<MgUserInformation> userInfo = new MgUserInformation(
+ L"Administrator", L"admin");
+ userInfo->SetLocale(TEST_LOCALE);
+ // Set the current MgUserInformation
+ // This must be done before calling CreateSession()
+ MgUserInformation::SetCurrentUserInfo(userInfo);
+ STRING session = svcSite->CreateSession();
+ assert(!session.empty());
+ userInfo->SetMgSessionId(session);
+ m_siteConnection = new MgSiteConnection();
+ m_siteConnection->Open(userInfo);
@@ -46,11 +78,170 @@
void TestMisc::TestStart()
ACE_DEBUG((LM_INFO, ACE_TEXT("\nRunning Miscellaneous tests.\n")));
+ //Reusing Mapping Service test data
+ try
+ #ifdef _DEBUG
+ MgFdoConnectionManager* pFdoConnectionManager = MgFdoConnectionManager::GetInstance();
+ if(pFdoConnectionManager)
+ pFdoConnectionManager->ShowCache();
+ #endif
+ //set user info
+ Ptr<MgUserInformation> userInfo = new MgUserInformation(L"Administrator", L"admin");
+ //publish the map definition
+ Ptr<MgResourceIdentifier> mapres = new MgResourceIdentifier(L"Library://UnitTests/Maps/Sheboygan.MapDefinition");
+ Ptr<MgByteSource> mdfsrc = new MgByteSource(L"../UnitTestFiles/UT_Sheboygan.mdf", false);
+ Ptr<MgByteReader> mdfrdr = mdfsrc->GetReader();
+ m_svcResource->SetResource(mapres, mdfrdr, NULL);
+ //publish the layer definitions
+ Ptr<MgResourceIdentifier> ldfres1 = new MgResourceIdentifier(L"Library://UnitTests/Layers/HydrographicPolygons.LayerDefinition");
+ Ptr<MgByteSource> ldfsrc1 = new MgByteSource(L"../UnitTestFiles/UT_HydrographicPolygons.ldf", false);
+ Ptr<MgByteReader> ldfrdr1 = ldfsrc1->GetReader();
+ m_svcResource->SetResource(ldfres1, ldfrdr1, NULL);
+ Ptr<MgResourceIdentifier> ldfres2 = new MgResourceIdentifier(L"Library://UnitTests/Layers/Parcels.LayerDefinition");
+ Ptr<MgByteSource> ldfsrc2 = new MgByteSource(L"../UnitTestFiles/UT_Parcels.ldf", false);
+ Ptr<MgByteReader> ldfrdr2 = ldfsrc2->GetReader();
+ m_svcResource->SetResource(ldfres2, ldfrdr2, NULL);
+ Ptr<MgResourceIdentifier> ldfres3 = new MgResourceIdentifier(L"Library://UnitTests/Layers/Rail.LayerDefinition");
+ Ptr<MgByteSource> ldfsrc3 = new MgByteSource(L"../UnitTestFiles/UT_Rail.ldf", false);
+ Ptr<MgByteReader> ldfrdr3 = ldfsrc3->GetReader();
+ m_svcResource->SetResource(ldfres3, ldfrdr3, NULL);
+ //publish the feature sources
+ Ptr<MgResourceIdentifier> fsres1 = new MgResourceIdentifier(L"Library://UnitTests/Data/HydrographicPolygons.FeatureSource");
+ Ptr<MgByteSource> fssrc1 = new MgByteSource(L"../UnitTestFiles/UT_HydrographicPolygons.fs", false);
+ Ptr<MgByteReader> fsrdr1 = fssrc1->GetReader();
+ m_svcResource->SetResource(fsres1, fsrdr1, NULL);
+ Ptr<MgResourceIdentifier> fsres2 = new MgResourceIdentifier(L"Library://UnitTests/Data/Parcels.FeatureSource");
+ Ptr<MgByteSource> fssrc2 = new MgByteSource(L"../UnitTestFiles/UT_Parcels.fs", false);
+ Ptr<MgByteReader> fsrdr2 = fssrc2->GetReader();
+ m_svcResource->SetResource(fsres2, fsrdr2, NULL);
+ Ptr<MgResourceIdentifier> fsres3 = new MgResourceIdentifier(L"Library://UnitTests/Data/Rail.FeatureSource");
+ Ptr<MgByteSource> fssrc3 = new MgByteSource(L"../UnitTestFiles/UT_Rail.fs", false);
+ Ptr<MgByteReader> fsrdr3 = fssrc3->GetReader();
+ m_svcResource->SetResource(fsres3, fsrdr3, NULL);
+ // publish the resource data
+ Ptr<MgByteSource> dataSource1 = new MgByteSource(L"../UnitTestFiles/UT_HydrographicPolygons.sdf", false);
+ Ptr<MgByteReader> dataReader1 = dataSource1->GetReader();
+ m_svcResource->SetResourceData(fsres1, L"UT_HydrographicPolygons.sdf", L"File", dataReader1);
+ Ptr<MgByteSource> dataSource2 = new MgByteSource(L"../UnitTestFiles/UT_Parcels.sdf", false);
+ Ptr<MgByteReader> dataReader2 = dataSource2->GetReader();
+ m_svcResource->SetResourceData(fsres2, L"UT_Parcels.sdf", L"File", dataReader2);
+ Ptr<MgByteSource> dataSource3 = new MgByteSource(L"../UnitTestFiles/UT_Rail.sdf", false);
+ Ptr<MgByteReader> dataReader3 = dataSource3->GetReader();
+ m_svcResource->SetResourceData(fsres3, L"UT_Rail.sdf", L"File", dataReader3);
+ // publish the print layouts
+ Ptr<MgResourceIdentifier> plres1 = new MgResourceIdentifier(L"Library://UnitTests/PrintLayouts/AllElements.PrintLayout");
+ Ptr<MgByteSource> plsrc1 = new MgByteSource(L"../UnitTestFiles/UT_AllElements.pl", false);
+ Ptr<MgByteReader> plrdr1 = plsrc1->GetReader();
+ m_svcResource->SetResource(plres1, plrdr1, NULL);
+ Ptr<MgResourceIdentifier> plres2 = new MgResourceIdentifier(L"Library://UnitTests/PrintLayouts/NoLegend.PrintLayout");
+ Ptr<MgByteSource> plsrc2 = new MgByteSource(L"../UnitTestFiles/UT_NoLegend.pl", false);
+ Ptr<MgByteReader> plrdr2 = plsrc2->GetReader();
+ m_svcResource->SetResource(plres2, plrdr2, NULL);
+ // publish the symbol library
+ Ptr<MgResourceIdentifier> slres1 = new MgResourceIdentifier(L"Library://UnitTests/Symbols/SymbolMart.SymbolLibrary");
+ Ptr<MgByteSource> slsrc1 = new MgByteSource(L"../UnitTestFiles/UT_SymbolMart.sl", false);
+ Ptr<MgByteReader> slrdr1 = slsrc1->GetReader();
+ m_svcResource->SetResource(slres1, slrdr1, NULL);
+ Ptr<MgByteSource> datasrc = new MgByteSource(L"../UnitTestFiles/UT_Symbols.dwf", false);
+ Ptr<MgByteReader> datardr = datasrc->GetReader();
+ m_svcResource->SetResourceData(slres1, L"symbols.dwf", L"File", datardr);
+ catch (MgException* e)
+ STRING message = e->GetDetails(TEST_LOCALE);
+ SAFE_RELEASE(e);
+ CPPUNIT_FAIL(MG_WCHAR_TO_CHAR(message.c_str()));
+ catch (...)
+ throw;
void TestMisc::TestEnd()
+ try
+ //set user info
+ //delete the map definition
+ m_svcResource->DeleteResource(mapres);
+ //delete the layer definitions
+ m_svcResource->DeleteResource(ldfres1);
+ m_svcResource->DeleteResource(ldfres2);
+ m_svcResource->DeleteResource(ldfres3);
+ //delete the feature sources
+ m_svcResource->DeleteResource(fsres1);
+ m_svcResource->DeleteResource(fsres2);
+ m_svcResource->DeleteResource(fsres3);
+ // delete the print layouts
+ m_svcResource->DeleteResource(plres1);
+ m_svcResource->DeleteResource(plres2);
+ // delete the symbol library
+ m_svcResource->DeleteResource(slres1);
+ #ifdef _DEBUG
+ #endif
+ SAFE_RELEASE(e);
+ catch (...)
+ throw;
ACE_DEBUG((LM_INFO, ACE_TEXT("\nMiscellaneous tests completed.\n\n")));
@@ -258,4 +449,62 @@
CPPUNIT_ASSERT_MESSAGE(assertMsg, msg.find(L"Foo") != STRING::npos);
ex->Release();
+void TestMisc::TestCase_611()
+ try
+ Ptr<MgResourceIdentifier> mapRes1 = new MgResourceIdentifier(L"Library://UnitTests/Maps/Sheboygan.MapDefinition");
+ Ptr<MgMap> map1 = new MgMap(m_siteConnection);
+ map1->Create(mapRes1, L"UnitTestSheboygan1");
+ Ptr<MgLayerGroup> detachedGroup = new MgLayerGroup(L"Detached");
+ Ptr<MgResourceIdentifier> ldf = new MgResourceIdentifier(L"Library://UnitTests/Layers/Parcels.LayerDefinition");
+ Ptr<MgLayer> layer = new MgLayer(ldf, m_svcResource);
+ layer->SetName(L"BelongsToDetachedGroup");
+ layer->SetLegendLabel(L"BelongsToDetachedGroup");
+ layer->SetGroup(detachedGroup);
+ Ptr<MgLayerCollection> mapLayers = map1->GetLayers();
+ mapLayers->Insert(0, layer);
+ CPPUNIT_ASSERT_THROW_MG(map1->Save(), MgGroupNotFoundException*);
+ SAFE_RELEASE(e);
+ catch (...)
+ throw;
+void TestMisc::TestCase_1304()
+ try
+ Ptr<MgSelection> sel = new MgSelection(map1, L"");
+ Ptr<MgReadOnlyLayerCollection> selLayers = sel->GetLayers();
+ CPPUNIT_ASSERT_MESSAGE("Expected null MgReadOnlyLayerCollection", NULL == selLayers.p);
+ sel->FromXml(L""); //Should be same result
+ selLayers = sel->GetLayers();
+ SAFE_RELEASE(e);
+ catch (...)
+ throw;
\ No newline at end of file
Modified: trunk/MgDev/Server/src/UnitTesting/TestMisc.h
--- trunk/MgDev/Server/src/UnitTesting/TestMisc.h 2012-06-13 13:07:42 UTC (rev 6757)
+++ trunk/MgDev/Server/src/UnitTesting/TestMisc.h 2012-06-13 13:11:49 UTC (rev 6758)
@@ -26,6 +26,8 @@
CPPUNIT_TEST(TestStart); // This must be the very first unit test
CPPUNIT_TEST(TestCase_CommonExceptionMessages);
+ CPPUNIT_TEST(TestCase_611);
+ CPPUNIT_TEST(TestCase_1304);
CPPUNIT_TEST(TestEnd); // This must be the very last unit test
CPPUNIT_TEST_SUITE_END();
@@ -40,6 +42,12 @@
void TestEnd();
void TestCase_CommonExceptionMessages();
+ void TestCase_611();
+ void TestCase_1304();
+private:
+ Ptr<MgSiteConnection> m_siteConnection;
+ Ptr<MgResourceService> m_svcResource;
#endif
Property changes on: trunk/MgDev/Web/src/mapadmin/HelpDocs
- /branches/2.4/MgDev/Web/src/mapadmin/HelpDocs:6738-6741
/sandbox/adsk/2.4j/Web/src/mapadmin/HelpDocs:6413
/sandbox/rfc94/Web/src/mapadmin/HelpDocs:5099-5163
+ /branches/2.4/MgDev/Web/src/mapadmin/HelpDocs:6738-6741,6749-6756
Property changes on: trunk/MgDev/Web/src/mapadmin/HelpDocs/configuring_servers.htm
- /branches/2.4/MgDev/Web/src/mapadmin/HelpDocs/configuring_servers.htm:6738-6741
/sandbox/adsk/2.4j/Web/src/mapadmin/HelpDocs/configuring_servers.htm:6327-6435
/sandbox/rfc94/Web/src/mapadmin/HelpDocs/configuring_servers.htm:5099-5163
/trunk/MgDev/Web/src/mapadmin/HelpDocs/configuring_servers.htm:6250-6326
+ /branches/2.4/MgDev/Web/src/mapadmin/HelpDocs/configuring_servers.htm:6738-6741,6749-6756
Property changes on: trunk/MgDev/Web/src/mapviewerphp/quickplotgeneratepicture.php
- /branches/2.4/MgDev/Web/src/mapviewerphp/quickplotgeneratepicture.php:6738-6741
/sandbox/adsk/2.4jbeta2/Web/src/mapviewerphp/quickplotgeneratepicture.php:6334-6374
/sandbox/rfc94/Web/src/mapviewerphp/quickplotgeneratepicture.php:5099-5163
+ /branches/2.4/MgDev/Web/src/mapviewerphp/quickplotgeneratepicture.php:6738-6741,6749-6756
Modified: trunk/MgDev/Web/src/schemareport/showgeom.php
--- trunk/MgDev/Web/src/schemareport/showgeom.php 2012-06-13 13:07:42 UTC (rev 6757)
+++ trunk/MgDev/Web/src/schemareport/showgeom.php 2012-06-13 13:11:49 UTC (rev 6758)
@@ -170,6 +170,7 @@
$extentGeometryAgg = null;
$extentGeometrySc = null;
+ $extentByteReader = null;
// Finds the coordinate system
$agfReaderWriter = new MgAgfReaderWriter();
Property changes on: trunk/MgDev/Web/src/viewerfiles
- /branches/2.4/MgDev/Web/src/viewerfiles:6738-6741
/sandbox/adsk/2.2gp/Web/src/viewerfiles:5392
+ /branches/2.4/MgDev/Web/src/viewerfiles:6738-6741,6749-6756
Property changes on: trunk/MgDev/Web/src/viewerfiles/quickplot.js
- /branches/2.4/MgDev/Web/src/viewerfiles/quickplot.js:6738-6741
/sandbox/adsk/2.2gp/Web/src/viewerfiles/quickplot.js:5392
/sandbox/adsk/2.4j/Web/src/viewerfiles/quickplot.js:6327-6474
/trunk/MgDev/Web/src/viewerfiles/quickplot.js:6250-6326
+ /branches/2.4/MgDev/Web/src/viewerfiles/quickplot.js:6738-6741,6749-6756
More information about the mapguide-commits
