[mapguide-commits] r6770 - trunk/Tools/MgInstantSetup/InstantSetup
svn_mapguide at osgeo.org
Fri Jun 15 04:31:37 PDT 2012
Author: jng
Date: 2012-06-15 04:31:36 -0700 (Fri, 15 Jun 2012)
New Revision: 6770
trunk/Tools/MgInstantSetup/InstantSetup/Form1.Designer.cs
trunk/Tools/MgInstantSetup/InstantSetup/Form1.cs
trunk/Tools/MgInstantSetup/InstantSetup/Form1.resx
MgInstantSetup: Fix non-functional browse buttons for FDO and FdoRegUtil path fields
Modified: trunk/Tools/MgInstantSetup/InstantSetup/Form1.Designer.cs
--- trunk/Tools/MgInstantSetup/InstantSetup/Form1.Designer.cs 2012-06-15 08:05:29 UTC (rev 6769)
+++ trunk/Tools/MgInstantSetup/InstantSetup/Form1.Designer.cs 2012-06-15 11:31:36 UTC (rev 6770)
@@ -49,12 +49,13 @@
this.label7 = new System.Windows.Forms.Label();
this.chkProviders = new System.Windows.Forms.CheckedListBox();
this.label6 = new System.Windows.Forms.Label();
- this.button3 = new System.Windows.Forms.Button();
- this.button2 = new System.Windows.Forms.Button();
+ this.btnFdoRegUtilPath = new System.Windows.Forms.Button();
+ this.btnFdoPath = new System.Windows.Forms.Button();
this.txtFdoRegUtilPath = new System.Windows.Forms.TextBox();
this.label5 = new System.Windows.Forms.Label();
this.txtFdoDir = new System.Windows.Forms.TextBox();
this.label4 = new System.Windows.Forms.Label();
+ this.openFileDialog = new System.Windows.Forms.OpenFileDialog();
this.tabControl1.SuspendLayout();
this.groupBox1.SuspendLayout();
this.groupBox2.SuspendLayout();
@@ -97,7 +98,7 @@
this.TAB_IIS7.Location = new System.Drawing.Point(4, 22);
this.TAB_IIS7.Name = "TAB_IIS7";
this.TAB_IIS7.Padding = new System.Windows.Forms.Padding(3);
- this.TAB_IIS7.Size = new System.Drawing.Size(466, 343);
+ this.TAB_IIS7.Size = new System.Drawing.Size(466, 397);
this.TAB_IIS7.TabIndex = 2;
this.TAB_IIS7.Text = "IIS7";
this.TAB_IIS7.UseVisualStyleBackColor = true;
@@ -235,8 +236,8 @@
this.groupBox2.Controls.Add(this.label7);
this.groupBox2.Controls.Add(this.chkProviders);
this.groupBox2.Controls.Add(this.label6);
- this.groupBox2.Controls.Add(this.button3);
- this.groupBox2.Controls.Add(this.button2);
+ this.groupBox2.Controls.Add(this.btnFdoRegUtilPath);
+ this.groupBox2.Controls.Add(this.btnFdoPath);
this.groupBox2.Controls.Add(this.txtFdoRegUtilPath);
this.groupBox2.Controls.Add(this.label5);
this.groupBox2.Controls.Add(this.txtFdoDir);
@@ -277,23 +278,25 @@
this.label6.TabIndex = 6;
this.label6.Text = "Provider dlls to register";
- // button3
+ // btnFdoRegUtilPath
- this.button3.Location = new System.Drawing.Point(216, 86);
- this.button3.Name = "button3";
- this.button3.Size = new System.Drawing.Size(27, 23);
- this.button3.TabIndex = 5;
- this.button3.Text = "...";
- this.button3.UseVisualStyleBackColor = true;
+ this.btnFdoRegUtilPath.Location = new System.Drawing.Point(216, 86);
+ this.btnFdoRegUtilPath.Name = "btnFdoRegUtilPath";
+ this.btnFdoRegUtilPath.Size = new System.Drawing.Size(27, 23);
+ this.btnFdoRegUtilPath.TabIndex = 5;
+ this.btnFdoRegUtilPath.Text = "...";
+ this.btnFdoRegUtilPath.UseVisualStyleBackColor = true;
+ this.btnFdoRegUtilPath.Click += new System.EventHandler(this.btnFdoRegUtilPath_Click);
- // button2
+ // btnFdoPath
- this.button2.Location = new System.Drawing.Point(216, 41);
- this.button2.Name = "button2";
- this.button2.Size = new System.Drawing.Size(27, 23);
- this.button2.TabIndex = 4;
- this.button2.Text = "...";
- this.button2.UseVisualStyleBackColor = true;
+ this.btnFdoPath.Location = new System.Drawing.Point(216, 41);
+ this.btnFdoPath.Name = "btnFdoPath";
+ this.btnFdoPath.Size = new System.Drawing.Size(27, 23);
+ this.btnFdoPath.TabIndex = 4;
+ this.btnFdoPath.Text = "...";
+ this.btnFdoPath.UseVisualStyleBackColor = true;
+ this.btnFdoPath.Click += new System.EventHandler(this.btnFdoPath_Click);
// txtFdoRegUtilPath
@@ -383,10 +386,11 @@
private System.Windows.Forms.Label label7;
private System.Windows.Forms.CheckedListBox chkProviders;
private System.Windows.Forms.Label label6;
- private System.Windows.Forms.Button button3;
- private System.Windows.Forms.Button button2;
+ private System.Windows.Forms.Button btnFdoRegUtilPath;
+ private System.Windows.Forms.Button btnFdoPath;
private System.Windows.Forms.TextBox txtFdoRegUtilPath;
private System.Windows.Forms.Label label5;
+ private System.Windows.Forms.OpenFileDialog openFileDialog;
Modified: trunk/Tools/MgInstantSetup/InstantSetup/Form1.cs
--- trunk/Tools/MgInstantSetup/InstantSetup/Form1.cs 2012-06-15 08:05:29 UTC (rev 6769)
+++ trunk/Tools/MgInstantSetup/InstantSetup/Form1.cs 2012-06-15 11:31:36 UTC (rev 6770)
@@ -187,5 +187,21 @@
chkProviders.Items.Add(item, false);
+ private void btnFdoPath_Click(object sender, EventArgs e)
+ if (folderBrowser.ShowDialog() == DialogResult.OK)
+ txtFdoDir.Text = folderBrowser.SelectedPath;
+ private void btnFdoRegUtilPath_Click(object sender, EventArgs e)
+ if (openFileDialog.ShowDialog() == DialogResult.OK)
+ txtFdoRegUtilPath.Text = openFileDialog.FileName;
Modified: trunk/Tools/MgInstantSetup/InstantSetup/Form1.resx
--- trunk/Tools/MgInstantSetup/InstantSetup/Form1.resx 2012-06-15 08:05:29 UTC (rev 6769)
+++ trunk/Tools/MgInstantSetup/InstantSetup/Form1.resx 2012-06-15 11:31:36 UTC (rev 6770)
@@ -120,4 +120,7 @@
<metadata name="folderBrowser.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
<value>17, 17</value>
</metadata>
+ <metadata name="openFileDialog.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>144, 17</value>
+ </metadata>
</root>
\ No newline at end of file
More information about the mapguide-commits
