[mapguide-commits] r6781 - branches/2.4/MgDev/Web/src/mapviewernet
svn_mapguide at osgeo.org
Mon Jun 18 06:11:32 PDT 2012
Author: jng
Date: 2012-06-18 06:11:32 -0700 (Mon, 18 Jun 2012)
New Revision: 6781
branches/2.4/MgDev/Web/src/mapviewernet/getselectedfeatures.aspx
#1780: Fix display of string properties containing line breaks. This for the .net viewer.
Modified: branches/2.4/MgDev/Web/src/mapviewernet/getselectedfeatures.aspx
--- branches/2.4/MgDev/Web/src/mapviewernet/getselectedfeatures.aspx 2012-06-18 12:56:03 UTC (rev 6780)
+++ branches/2.4/MgDev/Web/src/mapviewernet/getselectedfeatures.aspx 2012-06-18 13:11:32 UTC (rev 6781)
@@ -83,6 +83,7 @@
String sessionId;
String locale;
CultureInfo culture;
+ System.Text.RegularExpressions.Regex regex;
static NameValueCollection GetLayerPropertyMappings(MgResourceService resSvc, MgLayerBase layer)
@@ -132,6 +133,7 @@
break;
case MgPropertyType.String:
value = JsonEscape(reader.GetString(propName)); //String content is arbitrary
+ value = regex.Replace(value, " ").Trim();
break;
default: //NOT PRESENTABLE IN PROPERTY GRID
value = "";
@@ -260,6 +262,7 @@
locale = GetDefaultLocale();
culture = CultureInfo.GetCultureInfo(locale);
+ regex = new System.Text.RegularExpressions.Regex("\\s+");
//HACK: The default locale (en) resolves to a neutral culture, .net forbids the use of
//neutral cultures for formatting purposes, so default to InvariantCulture if the resolved
More information about the mapguide-commits
