[mapguide-commits] r6786 - branches/2.4/MgDev/Web/src/mapviewerjava
svn_mapguide at osgeo.org
Mon Jun 18 07:40:53 PDT 2012
Author: jng
Date: 2012-06-18 07:40:52 -0700 (Mon, 18 Jun 2012)
New Revision: 6786
branches/2.4/MgDev/Web/src/mapviewerjava/mainframe.jsp
branches/2.4/MgDev/Web/src/mapviewerjava/taskframe.jsp
#1684: Pass MAPNAME to the task pane frame. This ensures that on initial load and on the click of the home button the frame will always at a minimum have the parameters of: SESSION, MAPNAME and LOCALE. This fix is for the Java viewer.
Modified: branches/2.4/MgDev/Web/src/mapviewerjava/mainframe.jsp
--- branches/2.4/MgDev/Web/src/mapviewerjava/mainframe.jsp 2012-06-18 14:39:52 UTC (rev 6785)
+++ branches/2.4/MgDev/Web/src/mapviewerjava/mainframe.jsp 2012-06-18 14:40:52 UTC (rev 6786)
@@ -34,6 +34,7 @@
String username = "";
String password = "";
String locale = "";
+String mapName = "";
int curFlyout = 0;
Hashtable cmds = new Hashtable();
@@ -127,6 +128,14 @@
String mapDefinitionUrl = URLEncoder.encode(mapDef, "UTF-8");
+ // NOTE:
+ // We don't open a MgMap because it is being created by mapframe.jsp that is also probably running
+ // as this script is running. However the naming convention is fixed enough that we can figure out
+ // what to pass to the Task Pane
+ MgResourceIdentifier resId = new MgResourceIdentifier(mapDef);
+ mapName = resId.GetName();
String title = webLayout.GetTitle();
boolean showLegend = infoPane.IsLegendBandVisible();
@@ -149,7 +158,7 @@
String srcToolbar = showToolbar ? ( "src=\"" + vpath + "toolbar.jsp?LOCALE=" + locale + "\"" ) : "";
String srcStatusbar = showStatusbar ? ( "src=\"" + vpath + "statusbar.jsp?LOCALE=" + locale + "\"" ) : "";
- String srcTaskFrame = showTaskPane? ("src=\"" + vpath + "taskframe.jsp?WEBLAYOUT=" + URLEncoder.encode(webLayoutDefinition, "UTF-8") + "&DWF=" + (forDwf!=0? "1": "0") + "&SESSION=" + (sessionId != ""? sessionId: "") + "&LOCALE=" + locale + "\"") : "";
+ String srcTaskFrame = showTaskPane? ("src=\"" + vpath + "taskframe.jsp?MAPNAME=" + mapName + "&WEBLAYOUT=" + URLEncoder.encode(webLayoutDefinition, "UTF-8") + "&DWF=" + (forDwf!=0? "1": "0") + "&SESSION=" + (sessionId != ""? sessionId: "") + "&LOCALE=" + locale + "\"") : "";
String srcTaskBar = "src=\"" + vpath + "taskbar.jsp?LOCALE=" + locale + "\"";
//view center
Modified: branches/2.4/MgDev/Web/src/mapviewerjava/taskframe.jsp
--- branches/2.4/MgDev/Web/src/mapviewerjava/taskframe.jsp 2012-06-18 14:39:52 UTC (rev 6785)
+++ branches/2.4/MgDev/Web/src/mapviewerjava/taskframe.jsp 2012-06-18 14:40:52 UTC (rev 6786)
@@ -29,6 +29,7 @@
String webLayoutId = "";
int dwf = 0;
String locale = "";
@@ -69,13 +70,13 @@
String query = url.substring(index+1);
if(query.length() > 0)
- url = String.format("%s?SESSION=%s&WEBLAYOUT=%s&DWF=%s&LOCALE=%s&%s", path, sessionId, URLEncoder.encode(webLayoutId, "UTF-8"), dwf, locale, query);
+ url = String.format("%s?SESSION=%s&MAPNAME=%s&WEBLAYOUT=%s&DWF=%s&LOCALE=%s&%s", path, sessionId, mapName, URLEncoder.encode(webLayoutId, "UTF-8"), dwf, locale, query);
else
- url = String.format("%s?SESSION=%s&WEBLAYOUT=%s&DWF=%s&LOCALE=%s", path, sessionId, URLEncoder.encode(webLayoutId, "UTF-8"), dwf, locale);
+ url = String.format("%s?SESSION=%s&MAPNAME=%s&WEBLAYOUT=%s&DWF=%s&LOCALE=%s", path, sessionId, mapName, URLEncoder.encode(webLayoutId, "UTF-8"), dwf, locale);
else
- url = String.format("%s?SESSION=%s&WEBLAYOUT=%s&DWF=%s&LOCALE=%s", taskPaneUrl, sessionId, URLEncoder.encode(webLayoutId), dwf, locale);
+ url = String.format("%s?SESSION=%s&MAPNAME=%s&WEBLAYOUT=%s&DWF=%s&LOCALE=%s", taskPaneUrl, sessionId, mapName, URLEncoder.encode(webLayoutId), dwf, locale);
String templ = LoadTemplate("/viewerfiles/taskframe.templ");
String[] vals = { vpath + "tasklist.jsp",
@@ -103,6 +104,7 @@
locale = ValidateLocaleString(GetParameter(request, "LOCALE"));
webLayoutId = ValidateResourceId(GetParameter(request, "WEBLAYOUT"));
dwf = GetIntParameter(request, "DWF");
+ mapName = ValidateMapName(GetParameter(request, "MAPNAME"));
void OnError(String title, String msg, PrintWriter outStream, HttpServletRequest request) throws FileNotFoundException, IOException
More information about the mapguide-commits
