[mapguide-commits] r6796 - branches/2.4/MgDev/Web/src/schemareport
svn_mapguide at osgeo.org
Wed Jun 20 02:49:01 PDT 2012
Author: jng
Date: 2012-06-20 02:49:00 -0700 (Wed, 20 Jun 2012)
New Revision: 6796
branches/2.4/MgDev/Web/src/schemareport/showgeom.php
Schema report fixes for MBR calculations:
- Spatial context extent was never set due to an incorrect null check.
- Use the EXTENT() custom MapGuide function as a last-resort method for MBR calculation.
Modified: branches/2.4/MgDev/Web/src/schemareport/showgeom.php
--- branches/2.4/MgDev/Web/src/schemareport/showgeom.php 2012-06-19 14:57:53 UTC (rev 6795)
+++ branches/2.4/MgDev/Web/src/schemareport/showgeom.php 2012-06-20 09:49:00 UTC (rev 6796)
@@ -76,6 +76,13 @@
$geomProp = $classDef->GetProperties()->GetItem($geomName);
$spatialContext = $geomProp->GetSpatialContextAssociation();
+ //TODO: Worse case scenario is no provider support for Count() or SpatialExtents()
+ //In such cases, we should piggy-back off of the same raw-spun feature reader to compile the count and MBR
+ //instead of having to raw-spin twice (once to get the count, another to get the MBR via EXTENT())
+ //TODO: Have a way to do this purely mgserver-side so we don't have row transmission overhead by doing the counting
+ //on the web tier
//Try the SelectAggregate shortcut. This is faster than raw spinning a feature reader
//NOTE: If MapGuide supported scrollable readers like FDO, we'd have also tried
@@ -187,7 +194,7 @@
$spatialcontextReader->Close();
- if ($extentByteReader == null)
+ if ($extentByteReader != null)
// Get the extent geometry from the spatial context
$extentGeometrySc = $agfReaderWriter->Read($extentByteReader);
@@ -212,11 +219,33 @@
catch (MgException $e)
+ if ($extentGeometryAgg == null)
+ //We do have one last hope. EXTENT() is an internal MapGuide custom function that's universally supported
+ //as it operates against an underlying select query result. This raw-spins the reader server-side so there
+ //is no server -> web tier transmission overhead involved.
+ try
+ $aggregateOptions = new MgFeatureAggregateOptions();
+ $aggregateOptions->AddComputedProperty("COMP_EXTENT", "EXTENT(".$geomName.")");
+ $dataReader = $featureSrvc->SelectAggregate($featuresId, $className, $aggregateOptions);
+ if($dataReader->ReadNext())
+ // Get the extents information
+ $byteReader = $dataReader->GetGeometry('COMP_EXTENT');
+ $extentGeometryAgg = $agfReaderWriter->Read($byteReader);
+ $dataReader->Close();
+ catch (MgException $e2)
$extentGeometry = null;
- // Prefer SpatialExtents() extent over spatial context extent
+ // Prefer SpatialExtents() of EXTENT() result over spatial context extent
if ($extentGeometryAgg != null)
$extentGeometry = $extentGeometryAgg;
if ($extentGeometry == null) { //Stil null? Now try spatial context
More information about the mapguide-commits
