[mapguide-commits] r6799 - branches/2.4/MgDev/Server/src/Services/Feature
svn_mapguide at osgeo.org
Thu Jun 21 08:00:23 PDT 2012
Author: jng
Date: 2012-06-21 08:00:23 -0700 (Thu, 21 Jun 2012)
New Revision: 6799
branches/2.4/MgDev/Server/src/Services/Feature/ServerSelectFeatures.cpp
The SQL Server implementation of the FDO Join APIs does not properly handle the select aggregate cases as I hoped. This submission disables the FDO join optimization for select aggregates for all providers except SQLite
Modified: branches/2.4/MgDev/Server/src/Services/Feature/ServerSelectFeatures.cpp
--- branches/2.4/MgDev/Server/src/Services/Feature/ServerSelectFeatures.cpp 2012-06-21 14:59:13 UTC (rev 6798)
+++ branches/2.4/MgDev/Server/src/Services/Feature/ServerSelectFeatures.cpp 2012-06-21 15:00:23 UTC (rev 6799)
@@ -99,6 +99,22 @@
bool bFeatureCalculation = FindFeatureCalculation(resource, className);
//Test for the FDO join optimization, because performance is **substantially** better
bool bSupportsFdoJoin = SupportsFdoJoin(resource, className, isSelectAggregate);
+ // HACK: Sorry, we have to do this for now. Only SQLite provider satisifes the original
+ // FDO join optimization in both regular select and select aggregate modes
+ // SQL Server has problems in aggregate mode. So we'll say the FDO join optimization is
+ // not supported when this is in aggregate mode. This means the join is handled by the
+ // GWS query engine. SQL Server on SQL Server join will use the best algorithm (sort merge)
+ // as both sides are sortable so we won't suffer too much of a performance penalty.
+ if (isSelectAggregate)
+ MdfModel::FeatureSource* featureSource = m_featureSourceCacheItem->Get();
+ const MdfModel::MdfString& providerName = featureSource->GetProvider();
+ if (providerName.find(L"OSGeo.SQLite") == MdfString::npos) //NOXLATE
+ bSupportsFdoJoin = false;
#ifdef DEBUG_FDO_JOIN
STRING fsIdStr = resource->ToString();
ACE_DEBUG((LM_INFO, ACE_TEXT("\n(%t) Testing Feature Source (%W, %W) for FDO join optimization"), fsIdStr.c_str(), className.c_str()));
@@ -1769,7 +1785,7 @@
if (NULL == (FdoClassDefinition*)classDef)
//TODO: Refine message if available
- throw new MgClassNotFoundException(L"MgServerSelectFeatures.SelectFdoJoin", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgClassNotFoundException(L"MgServerSelectFeatures.IsFunctionOnPrimaryProperty", __LINE__, __WFILE__, NULL, L"", NULL);
FdoPtr<FdoPropertyDefinitionCollection> properties = classDef->GetProperties();
@@ -1843,7 +1859,7 @@
+ throw new MgClassNotFoundException(L"MgServerSelectFeatures.FilterContainsSecondaryProperties", __LINE__, __WFILE__, NULL, L"", NULL);
FdoPtr<FdoPropertyDefinitionCollection> propDefs = classDef->GetProperties();
@@ -2162,7 +2178,7 @@
+ throw new MgClassNotFoundException(L"MgServerSelectFeatures.ApplyClassProperties", __LINE__, __WFILE__, NULL, L"", NULL);
FdoPtr<FdoIdentifierCollection> propNames = m_command->GetPropertyNames();
More information about the mapguide-commits
