[mapguide-commits] r6815 - in trunk/Tools/Maestro: Maestro.Editors/MapDefinition Maestro.MapViewer
svn_mapguide at osgeo.org
Tue Jun 26 04:58:17 PDT 2012
Author: jng
Date: 2012-06-26 04:58:17 -0700 (Tue, 26 Jun 2012)
New Revision: 6815
trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapEditorLegend.Designer.cs
trunk/Tools/Maestro/Maestro.MapViewer/Legend.cs
#2044: Show all layers and groups regardless of visibility in the live editor. Otherwise we can't actually select these groups/layers in question to edit them!
Modified: trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapEditorLegend.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapEditorLegend.Designer.cs 2012-06-26 11:39:14 UTC (rev 6814)
+++ trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapEditorLegend.Designer.cs 2012-06-26 11:58:17 UTC (rev 6815)
@@ -156,6 +156,7 @@
this.legendCtrl.Location = new System.Drawing.Point(0, 25);
this.legendCtrl.Name = "legendCtrl";
this.legendCtrl.SelectOnRightClick = true;
+ this.legendCtrl.ShowAllLayersAndGroups = true;
this.legendCtrl.ShowTooltips = true;
this.legendCtrl.Size = new System.Drawing.Size(275, 356);
this.legendCtrl.TabIndex = 1;
Modified: trunk/Tools/Maestro/Maestro.MapViewer/Legend.cs
--- trunk/Tools/Maestro/Maestro.MapViewer/Legend.cs 2012-06-26 11:39:14 UTC (rev 6814)
+++ trunk/Tools/Maestro/Maestro.MapViewer/Legend.cs 2012-06-26 11:58:17 UTC (rev 6815)
@@ -59,8 +59,15 @@
InitializeComponent();
this.ThemeCompressionLimit = 25;
+ this.ShowAllLayersAndGroups = false;
+ /// <summary>
+ /// Gets whether to display all layers and groups regardless of display settings
+ /// and visibility
+ /// </summary>
+ public bool ShowAllLayersAndGroups { get; set; }
private IMapViewer _viewer;
public IMapViewer Viewer
@@ -94,6 +101,16 @@
private Dictionary<string, RuntimeMapGroup> _groups = new Dictionary<string, RuntimeMapGroup>();
private Dictionary<string, string> _layerDefinitionContents = new Dictionary<string, string>();
+ private bool GetVisibilityFlag(RuntimeMapGroup group)
+ return this.ShowAllLayersAndGroups;
+ private bool GetVisibilityFlag(RuntimeMapLayer layer)
+ return layer.IsVisibleAtScale(_map.ViewScale);
/// <summary>
/// Refreshes this component
/// </summary>
@@ -127,7 +144,7 @@
var group = groups[i];
_groups.Add(group.ObjectId, group);
- if (!group.ShowInLegend)
+ if (!this.ShowAllLayersAndGroups && !group.ShowInLegend)
continue;
//Add ones without parents first.
@@ -137,7 +154,7 @@
else
- var node = CreateGroupNode(group);
+ var node = CreateGroupNode(group, GetVisibilityFlag(group));
trvLegend.Nodes.Add(node);
@@ -153,7 +170,7 @@
var nodes = trvLegend.Nodes.Find(parentId, false);
if (nodes.Length == 1)
- var node = CreateGroupNode(remainingNodes[j]);
+ var node = CreateGroupNode(remainingNodes[j], GetVisibilityFlag(remainingNodes[j]));
nodes[0].Nodes.Add(node);
toRemove.Add(remainingNodes[j]);
@@ -199,10 +216,10 @@
bool display = layer.ShowInLegend;
bool visible = layer.IsVisibleAtScale(_map.ViewScale);
- if (!display)
+ if (!this.ShowAllLayersAndGroups && !display)
continue;
- if (!visible)
+ if (!this.ShowAllLayersAndGroups && !visible)
continue;
@@ -212,7 +229,7 @@
else
- var node = CreateLayerNode(layer);
+ var node = CreateLayerNode(layer, GetVisibilityFlag(layer));
if (node != null)
@@ -231,7 +248,7 @@
- var node = CreateLayerNode(remainingLayers[j]);
+ var node = CreateLayerNode(remainingLayers[j], GetVisibilityFlag(remainingLayers[j]));
if (node != null)
@@ -307,7 +324,7 @@
imgLegend.Images.Add(IMG_OTHER, Properties.Resources.icon_etc);
- private TreeNode CreateLayerNode(RuntimeMapLayer layer)
+ private TreeNode CreateLayerNode(RuntimeMapLayer layer, bool visibilityFlag)
var node = new TreeNode();
node.Name = layer.ObjectId;
@@ -320,7 +337,7 @@
if (fsId.EndsWith("DrawingSource"))
node.SelectedImageKey = node.ImageKey = IMG_DWF;
- node.Tag = new LayerNodeMetadata(layer);
+ node.Tag = new LayerNodeMetadata(layer, visibilityFlag);
node.ToolTipText = string.Format(Properties.Resources.DrawingLayerTooltip, Environment.NewLine, layer.Name, layer.FeatureSourceID);
else
@@ -368,7 +385,7 @@
string id = Guid.NewGuid().ToString();
imgLegend.Images.Add(id, layerIcon);
node.SelectedImageKey = node.ImageKey = id;
ThemeIcon = layerIcon
@@ -377,11 +394,19 @@
else
node.SelectedImageKey = node.ImageKey = IMG_BROKEN;
+ ThemeIcon = imgLegend.Images[IMG_BROKEN]
catch
for (int sc = 0; sc < scaleRanges.Count; sc++)
@@ -424,15 +449,15 @@
if (this.ThemeCompressionLimit > 0 && rules.Count > this.ThemeCompressionLimit)
- AddThemeRuleNode(layer, node, geomType, 0, rules, 0);
- node.Nodes.Add(CreateCompressedThemeNode(rules.Count - 2));
- AddThemeRuleNode(layer, node, geomType, rules.Count - 1, rules, rules.Count - 1);
+ AddThemeRuleNode(layer, node, geomType, 0, rules, 0, visibilityFlag);
+ node.Nodes.Add(CreateCompressedThemeNode(rules.Count - 2, visibilityFlag));
+ AddThemeRuleNode(layer, node, geomType, rules.Count - 1, rules, rules.Count - 1, visibilityFlag);
else
for (int r = 0; r < rules.Count; r++)
- AddThemeRuleNode(layer, node, geomType, catIndex++, rules, r);
+ AddThemeRuleNode(layer, node, geomType, catIndex++, rules, r, visibilityFlag);
@@ -444,7 +469,7 @@
return node;
- private void AddThemeRuleNode(RuntimeMapLayer layer, TreeNode node, int geomType, int catIndex, XmlNodeList rules, int r)
+ private void AddThemeRuleNode(RuntimeMapLayer layer, TreeNode node, int geomType, int catIndex, XmlNodeList rules, int r, bool visibilityFlag)
XmlElement rule = (XmlElement)rules[r];
XmlNodeList label = rule.GetElementsByTagName("LegendLabel");
@@ -457,16 +482,16 @@
//if (filter != null && filter.Count > 0 && filter[0].ChildNodes.Count > 0)
// filterText = filter[0].ChildNodes[0].Value;
- var child = CreateThemeRuleNode(layer.LayerDefinitionID, _map.ViewScale, labelText, (geomType + 1), catIndex);
+ var child = CreateThemeRuleNode(layer.LayerDefinitionID, _map.ViewScale, labelText, (geomType + 1), catIndex, visibilityFlag);
node.Nodes.Add(child);
- private TreeNode CreateCompressedThemeNode(int count)
+ private TreeNode CreateCompressedThemeNode(int count, bool visibilityFlag)
TreeNode node = new TreeNode();
node.Text = (count + " other styles");
node.ImageKey = node.SelectedImageKey = IMG_OTHER;
- node.Tag = new LayerNodeMetadata(null) {
+ node.Tag = new LayerNodeMetadata(null, visibilityFlag) {
IsBaseLayer = false,
ThemeIcon = Properties.Resources.icon_etc,
IsThemeRule = true
@@ -474,7 +499,7 @@
return node;
- private TreeNode CreateThemeRuleNode(string layerDefId, double viewScale, string labelText, int geomType, int categoryIndex)
+ private TreeNode CreateThemeRuleNode(string layerDefId, double viewScale, string labelText, int geomType, int categoryIndex, bool visibilityFlag)
Image layerIcon = null;
try
@@ -495,7 +520,7 @@
node.Text = labelText;
if (layerIcon != null)
- var tag = new LayerNodeMetadata(null)
+ var tag = new LayerNodeMetadata(null, visibilityFlag)
IsThemeRule = true
@@ -507,14 +532,14 @@
return node;
- private TreeNode CreateGroupNode(RuntimeMapGroup group)
+ private TreeNode CreateGroupNode(RuntimeMapGroup group, bool visibilityFlag)
node.Name = group.ObjectId;
node.Text = group.LegendLabel;
node.Checked = group.Visible;
node.SelectedImageKey = node.ImageKey = IMG_GROUP;
- node.Tag = new GroupNodeMetadata(group);
+ node.Tag = new GroupNodeMetadata(group, visibilityFlag);
node.ContextMenuStrip = this.GroupContextMenu;
return node;
@@ -542,12 +567,16 @@
[Browsable(false)]
internal RuntimeMapGroup WrappedGroupObject { get; set; }
- public GroupNodeMetadata(RuntimeMapGroup group)
+ public GroupNodeMetadata(RuntimeMapGroup group, bool visibilityFlag)
base.IsGroup = true;
this.WrappedGroupObject = group;
+ this.VisbilityFlag = visibilityFlag;
+ [Browsable(false)]
+ internal bool VisbilityFlag { get; private set; }
public bool Visible
get { return this.WrappedGroupObject.Visible; }
@@ -587,16 +616,20 @@
public class LayerNodeMetadata : LegendNodeMetadata
- public LayerNodeMetadata(RuntimeMapLayer layer)
+ public LayerNodeMetadata(RuntimeMapLayer layer, bool visibilityFlag)
base.IsGroup = false;
this.Layer = layer;
this.IsSelectable = (layer != null) ? layer.Selectable : false;
this.DrawSelectabilityIcon = (layer != null);
this.IsThemeRule = false;
+ this.VisibilityFlag = visibilityFlag;
[Browsable(false)]
+ internal bool VisibilityFlag { get; private set; }
internal RuntimeMapLayer Layer { get; set; }
[Browsable(false)]
@@ -787,11 +820,14 @@
//For some reason, the default bounds are way off from what you would
//expect it to be. So we apply this offset for any text/image draw operations
int xoffset = -36;
+ var tag = e.Node.Tag as LayerNodeMetadata;
+ bool bDrawSelection = false;
if ((e.State & TreeNodeStates.Selected) == TreeNodeStates.Selected)
backColor = SystemColors.Highlight;
foreColor = SystemColors.HighlightText;
+ bDrawSelection = true;
else if ((e.State & TreeNodeStates.Hot) == TreeNodeStates.Hot)
@@ -801,10 +837,9 @@
else
backColor = e.Node.BackColor;
- foreColor = e.Node.ForeColor;
+ foreColor = (tag != null && !tag.VisibilityFlag) ? SystemColors.InactiveCaptionText : Color.Black; //e.Node.ForeColor;
- var tag = e.Node.Tag as LayerNodeMetadata;
var checkBoxOffset = xoffset;
var selectabilityOffset = xoffset + 16;
var iconOffsetNoSelect = xoffset + 16;
@@ -849,8 +884,21 @@
- using (SolidBrush brush = new SolidBrush(Color.Black))
+ if (bDrawSelection)
+ var size = e.Graphics.MeasureString(e.Node.Text, trvLegend.Font);
+ using (var brush = new SolidBrush(backColor))
+ e.Graphics.FillRectangle(brush,
+ e.Node.Bounds.X + (tag.DrawSelectabilityIcon ? textOffset : textOffsetNoSelect),
+ e.Node.Bounds.Y,
+ size.Width,
+ size.Height);
+ using (SolidBrush brush = new SolidBrush(tag.VisibilityFlag ? foreColor : Color.Gray))
e.Graphics.DrawString(e.Node.Text, trvLegend.Font, brush, e.Node.Bounds.X + (tag.DrawSelectabilityIcon ? textOffset : textOffsetNoSelect), e.Node.Bounds.Y);
@@ -944,10 +992,7 @@
private void trvLegend_NodeMouseClick(object sender, TreeNodeMouseClickEventArgs e)
- if (e.Button == MouseButtons.Right)
- trvLegend.SelectedNode = e.Node;
+ trvLegend.SelectedNode = e.Node;
var meta = e.Node.Tag as LayerNodeMetadata;
if (meta != null && meta.DrawSelectabilityIcon)
More information about the mapguide-commits
