[mapguide-commits] r6818 - in trunk/Tools/Maestro: Maestro.MapViewer OSGeo.MapGuide.MaestroAPI/Mapping OSGeo.MapGuide.MaestroAPI.Local
svn_mapguide at osgeo.org
Tue Jun 26 07:37:26 PDT 2012
Author: jng
Date: 2012-06-26 07:37:25 -0700 (Tue, 26 Jun 2012)
New Revision: 6818
trunk/Tools/Maestro/Maestro.MapViewer/MapViewer.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Local/LocalRuntimeMap.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs
#2020: Make RuntimeMap.ViewCenter readonly. Add a new SetViewCenter API to allow changing the map's view center. The LocalRuntimeMap overrides this to delegate straight to the underlying MgdMap.
Modified: trunk/Tools/Maestro/Maestro.MapViewer/MapViewer.cs
--- trunk/Tools/Maestro/Maestro.MapViewer/MapViewer.cs 2012-06-26 14:24:03 UTC (rev 6817)
+++ trunk/Tools/Maestro/Maestro.MapViewer/MapViewer.cs 2012-06-26 14:37:25 UTC (rev 6818)
@@ -1522,8 +1522,7 @@
OnPropertyChanged("ViewHistoryIndex");
- _map.ViewCenter.X = x;
- _map.ViewCenter.Y = y;
+ _map.SetViewCenter(x, y);
#if VIEWER_DEBUG
UpdateCenterDebugPoint();
//var mapExt = _map.MapExtent;
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs 2012-06-26 14:24:03 UTC (rev 6817)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs 2012-06-26 14:37:25 UTC (rev 6818)
@@ -318,7 +318,8 @@
this.DisplayDpi = 96;
this.DisplayWidth = 0;
this.DisplayHeight = 0;
- this.ViewCenter = this.DataExtent.Center();
+ var pt = this.DataExtent.Center();
+ this.SetViewCenter(pt.X, pt.Y);
_disableChangeTracking = false;
@@ -475,10 +476,19 @@
return _viewCenter;
- set
+ public virtual void SetViewCenter(double x, double y)
+ if (_viewCenter == null)
- _viewCenter = value;
+ _viewCenter = ObjectFactory.CreatePoint2D(x, y);
+ else
+ _viewCenter.X = x;
+ _viewCenter.Y = y;
/// <summary>
@@ -804,7 +814,7 @@
else
- this.ViewCenter = ObjectFactory.CreatePoint2D(cc[0], cc[1]);
+ this.SetViewCenter(cc[0], cc[1]);
this.ViewScale = d.ReadDouble();
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Local/LocalRuntimeMap.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Local/LocalRuntimeMap.cs 2012-06-26 14:24:03 UTC (rev 6817)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Local/LocalRuntimeMap.cs 2012-06-26 14:37:25 UTC (rev 6818)
@@ -27,6 +27,12 @@
namespace OSGeo.MapGuide.MaestroAPI.Local
+ // A general note about this implementation
+ // The only thing this shares with RuntimeMap is the ancestry (which is needed if we want to use rendering APIs) because
+ // other than that, these implementations are complete wrappers around their respective MgdMap, MgLayerGroup and MgLayerBase
+ // classes, barely touching anything from their respective superclasses (and almost overriding everything from their parents)
internal class LocalRuntimeMap : RuntimeMap
private MgdMap _impl;
@@ -194,13 +200,11 @@
var coord = pt.Coordinate;
return ObjectFactory.CreatePoint2D(coord.X, coord.Y);
- set
- if (value == null)
- throw new ArgumentNullException();
- _impl.SetViewCenterXY(value.X, value.Y);
+ public override void SetViewCenter(double x, double y)
+ _impl.SetViewCenterXY(x, y);
public override double ViewScale
More information about the mapguide-commits
