[mapguide-commits] r6823 - branches/2.4/MgDev/Desktop/MapViewer
svn_mapguide at osgeo.org
Wed Jun 27 04:51:39 PDT 2012
Author: jng
Date: 2012-06-27 04:51:39 -0700 (Wed, 27 Jun 2012)
New Revision: 6823
branches/2.4/MgDev/Desktop/MapViewer/MapViewer.csproj
branches/2.4/MgDev/Desktop/MapViewer/MgMapViewer.cs
mg-desktop: Implement mouse wheel zoom!
Modified: branches/2.4/MgDev/Desktop/MapViewer/MapViewer.csproj
--- branches/2.4/MgDev/Desktop/MapViewer/MapViewer.csproj 2012-06-26 16:28:02 UTC (rev 6822)
+++ branches/2.4/MgDev/Desktop/MapViewer/MapViewer.csproj 2012-06-27 11:51:39 UTC (rev 6823)
@@ -29,8 +29,7 @@
<DebugType>pdbonly</DebugType>
<Optimize>true</Optimize>
<OutputPath>bin\Release\</OutputPath>
- <DefineConstants>
- </DefineConstants>
+ <DefineConstants>TRACE</DefineConstants>
<ErrorReport>prompt</ErrorReport>
<WarningLevel>4</WarningLevel>
<DocumentationFile>bin\Release\OSGeo.MapGuide.Viewer.XML</DocumentationFile>
Modified: branches/2.4/MgDev/Desktop/MapViewer/MgMapViewer.cs
--- branches/2.4/MgDev/Desktop/MapViewer/MgMapViewer.cs 2012-06-26 16:28:02 UTC (rev 6822)
+++ branches/2.4/MgDev/Desktop/MapViewer/MgMapViewer.cs 2012-06-27 11:51:39 UTC (rev 6823)
@@ -62,8 +62,6 @@
- const double MINIMUM_ZOOM_SCALE = 5.0;
#if VIEWER_DEBUG
private MgdLayer _debugLayer;
@@ -174,11 +172,15 @@
this.SelectionColor = Color.Blue;
this.PointPixelBuffer = 2;
+ this.MinScale = 10;
+ this.MaxScale = 1000000000;
this.DigitizingFillTransparency = 100;
this.DigitizingOutline = Brushes.Red;
this.DigitzingFillColor = Color.White;
this.TooltipFillColor = Color.LightYellow;
this.TooltipFillTransparency = 200;
+ this.MouseWheelDelayRenderInterval = 800;
this.ActiveTool = MapActiveTool.None;
this.DoubleBuffered = true;
@@ -203,6 +205,7 @@
base.MouseDoubleClick += OnMapMouseDoubleClick;
base.MouseHover += OnMapMouseHover;
base.MouseEnter += OnMouseEnter;
+ base.MouseWheel += OnMapMouseWheel;
/// <summary>
@@ -318,6 +321,27 @@
base.Dispose(disposing);
+ /// <summary>
+ /// Gets or sets the minimum allowed zoom scale for this viewer
+ /// </summary>
+ [Category("MapGuide Viewer")]
+ [Description("The minimum allowed zoom scale for this viewer")]
+ public int MinScale { get; set; }
+ /// <summary>
+ /// Gets or sets the maximum allowed zoom scale for this viewer
+ /// </summary>
+ [Description("The maximum allowed zoom scale for this viewer")]
+ public int MaxScale { get; set; }
+ /// <summary>
+ /// The amount of time (in ms) to wait to re-render after a mouse wheel scroll
+ /// </summary>
+ [Description("The amount of time (in ms) to wait to re-render after a mouse wheel scroll")]
+ public int MouseWheelDelayRenderInterval { get; set; }
private Color _selColor;
/// <summary>
@@ -436,18 +460,33 @@
Trace.TraceInformation("OnPaint(e)");
if (!translate.IsEmpty)
- e.Graphics.TranslateTransform(translate.X, translate.Y);
+ if (mouseWheelTx.HasValue && mouseWheelTy.HasValue)
+ e.Graphics.TranslateTransform(translate.X + mouseWheelTx.Value, translate.Y + mouseWheelTy.Value);
+ else
+ e.Graphics.TranslateTransform(translate.X, translate.Y);
+ else
+ e.Graphics.TranslateTransform(mouseWheelTx.Value, mouseWheelTy.Value);
+ if (mouseWheelSx.HasValue && mouseWheelSy.HasValue && mouseWheelSx.Value != 0.0 && mouseWheelSy.Value != 0.0)
+ e.Graphics.ScaleTransform(mouseWheelSx.Value, mouseWheelSy.Value);
if (_mapImage != null)
- Trace.TraceInformation("Render Map");
+ Trace.TraceInformation("Render buffered map image");
e.Graphics.DrawImage(_mapImage, new PointF(0, 0));
//Thread.Sleep(100);
if (_selectionImage != null)
- Trace.TraceInformation("Render Selection");
+ Trace.TraceInformation("Render buffered map selection");
e.Graphics.DrawImage(_selectionImage, new PointF(0, 0));
@@ -1133,6 +1172,7 @@
var action = new MethodInvoker(() =>
+ ResetMouseWheelPaintTransforms();
if (_map != null)
Trace.TraceInformation("Performing delayed resize to (" + this.Width + ", " + this.Height + ")");
@@ -1643,7 +1683,7 @@
Trace.TraceInformation("Center is (" + x + ", " + y + ")");
#endif
var oldScale = _map.ViewScale;
- _provider.SetViewScale(Math.Max(scale, MINIMUM_ZOOM_SCALE));
+ _provider.SetViewScale(NormalizeScale(scale));
if (oldScale != _map.ViewScale)
@@ -2195,6 +2235,12 @@
HandleMouseUp(e);
+ private void OnMapMouseWheel(object sender, MouseEventArgs e)
+ this.Focus();
+ HandleMouseWheel(e);
private void OnMapMouseClick(object sender, MouseEventArgs e)
this.Focus();
@@ -2229,6 +2275,152 @@
+ private double? delayRenderScale;
+ private PointF? delayRenderViewCenter;
+ private float? mouseWheelSx = null;
+ private float? mouseWheelSy = null;
+ private float? mouseWheelTx = null;
+ private float? mouseWheelTy = null;
+ private int? mouseWheelDelta = null;
+ private System.Timers.Timer delayRenderTimer = null;
+ private void HandleMouseWheel(MouseEventArgs e)
+ if (delayRenderTimer == null)
+ delayRenderTimer = new System.Timers.Timer();
+ delayRenderTimer.Enabled = false;
+ delayRenderTimer.Elapsed += new System.Timers.ElapsedEventHandler(OnDelayRender);
+ delayRenderTimer.Interval = this.MouseWheelDelayRenderInterval;
+ delayRenderTimer.Stop();
+ delayRenderTimer.Start();
+ Trace.TraceInformation("Postponed delay render");
+ Trace.TraceInformation("Mouse delta: " + e.Delta + " (" + (e.Delta > 0 ? "Zoom in" : "Zoom out") + ")");
+ //Negative delta = zoom out, Positive delta = zoom in
+ //deltas are in units of 120, so treat each multiple of 120 as a "zoom unit"
+ if (!mouseWheelSx.HasValue && !mouseWheelSy.HasValue)
+ mouseWheelSx = 1.0f;
+ mouseWheelSy = 1.0f;
+ if (!mouseWheelDelta.HasValue)
+ mouseWheelDelta = 0;
+ if (e.Delta > 0) //Zoom In
+ mouseWheelDelta++;
+ mouseWheelSx -= 0.1f;
+ mouseWheelSy -= 0.1f;
+ Invalidate();
+ else if (e.Delta < 0) //Zoom Out
+ mouseWheelDelta--;
+ mouseWheelSx += 0.1f;
+ mouseWheelSy += 0.1f;
+ Invalidate();
+ Trace.TraceInformation("Delta units is: " + mouseWheelDelta);
+ //Completely ripped the number crunching here from the AJAX viewer with no sense of shame whatsoever :)
+ delayRenderScale = GetNewScale(_map.ViewScale, mouseWheelDelta.Value);
+ double zoomChange = _map.ViewScale / delayRenderScale.Value;
+ //Determine the center of the new, zoomed map, in current screen device coords
+ double screenZoomCenterX = e.X - (e.X - this.Width / 2) / zoomChange;
+ double screenZoomCenterY = e.Y - (e.Y - this.Height / 2) / zoomChange;
+ delayRenderViewCenter = ScreenToMapUnits(screenZoomCenterX, screenZoomCenterY);
+ var mpu = this.MetersPerUnit;
+ var mpp = GetMetersPerPixel(_map.DisplayDpi);
+ var w = (_extX2 - _extX1) * this.MetersPerUnit / (delayRenderScale * mpp);
+ if (w > 20000)
+ w = 20000;
+ var h = w * ((double)this.Height / (double)this.Width);
+ var xClickOffset = screenZoomCenterX - this.Width / 2;
+ var yClickOffset = screenZoomCenterY - this.Height / 2;
+ //Set the paint transforms. Will be reset once the delayed render is fired away
+ mouseWheelTx = (float)((double)this.Width / 2 - w / 2 - xClickOffset * zoomChange);
+ mouseWheelTy = (float)((double)this.Height / 2 - h / 2 - yClickOffset * zoomChange);
+ mouseWheelSx = (float)(w / (double)this.Width);
+ mouseWheelSy = (float)(h / (double)this.Height);
+ Trace.TraceInformation("Paint transform (tx: " + mouseWheelTx + ", ty: " + mouseWheelTy + ", sx: " + mouseWheelSx + ", sy: " + mouseWheelSy + ")");
+ static double GetMetersPerPixel(int dpi)
+ return 0.0254 / dpi;
+ double GetNewScale(double currentScale, int wheelZoomDelta)
+ var newScale = currentScale;
+ //handle finite zoom scales for tiled map
+ if (finscale)
+ var newScaleIndex = sci - wheelDelta;
+ if (newScaleIndex < 0)
+ newScaleIndex = 0;
+ if (newScaleIndex > scales.length - 1)
+ newScaleIndex = scales.length - 1;
+ newScale = scales[newScaleIndex];
+ //no finite zoom scales (untiled map)
+ else */
+ var zoomChange = Math.Pow(1.5, wheelZoomDelta);
+ newScale = zoomChange > 0 ? currentScale / zoomChange : this.MaxScale;
+ newScale = NormalizeScale(newScale);
+ return newScale;
+ double NormalizeScale(double scale)
+ if (scale < this.MinScale)
+ return this.MinScale;
+ if (scale > this.MaxScale)
+ return this.MaxScale;
+ return scale;
+ void OnDelayRender(object sender, System.Timers.ElapsedEventArgs e)
+ Trace.TraceInformation("Delay rendering");
+ Trace.TraceInformation("Set new map coordinates to (" + delayRenderViewCenter.Value.X + ", " + delayRenderViewCenter.Value.Y + " at " + delayRenderScale.Value + ")");
+ MethodInvoker action = () => { ZoomToView(delayRenderViewCenter.Value.X, delayRenderViewCenter.Value.Y, delayRenderScale.Value, true); };
+ if (this.InvokeRequired)
+ this.Invoke(action);
+ else
+ action();
+ private void ResetMouseWheelPaintTransforms()
+ mouseWheelSx = null;
+ mouseWheelSy = null;
+ mouseWheelTx = null;
+ mouseWheelTy = null;
+ Trace.TraceInformation("Mouse wheel paint transform reset");
private void HandleMouseClick(MouseEventArgs e)
if (e.Button == MouseButtons.Right)
More information about the mapguide-commits
