[mapguide-commits] r6825 - in branches/2.4/MgDev/Desktop: MapViewer MapViewer/Properties MapViewerTest
svn_mapguide at osgeo.org
Wed Jun 27 06:07:17 PDT 2012
Author: jng
Date: 2012-06-27 06:07:09 -0700 (Wed, 27 Jun 2012)
New Revision: 6825
branches/2.4/MgDev/Desktop/MapViewer/IMapViewer.cs
branches/2.4/MgDev/Desktop/MapViewer/MgMapViewer.cs
branches/2.4/MgDev/Desktop/MapViewer/Properties/Resources.Designer.cs
branches/2.4/MgDev/Desktop/MapViewer/Properties/Resources.resx
branches/2.4/MgDev/Desktop/MapViewerTest/MgAppWindow.Designer.cs
branches/2.4/MgDev/Desktop/MapViewerTest/MgAppWindow.cs
branches/2.4/MgDev/Desktop/MapViewerTest/MgAppWindow.resx
mg-desktop: Add viewer support for custom tooltip prompts and the ability to undo digitized segments for linestring and polygon digitizations by pressing Ctrl-Z during digitization
Modified: branches/2.4/MgDev/Desktop/MapViewer/IMapViewer.cs
--- branches/2.4/MgDev/Desktop/MapViewer/IMapViewer.cs 2012-06-27 12:01:50 UTC (rev 6824)
+++ branches/2.4/MgDev/Desktop/MapViewer/IMapViewer.cs 2012-06-27 13:07:09 UTC (rev 6825)
@@ -107,6 +107,56 @@
void DigitizeRectangle(RectangleDigitizationCallback callback);
/// <summary>
+ /// Starts the digitization process for a circle
+ /// </summary>
+ /// <param name="callback">The callback to be invoked when the digitization process completes</param>
+ /// <param name="customPrompt">The custom prompt to use for the tracking tooltip</param>
+ void DigitizeCircle(CircleDigitizationCallback callback, string customPrompt);
+ /// <summary>
+ /// Starts the digitization process for a line
+ /// </summary>
+ void DigitizeLine(LineDigitizationCallback callback, string customPrompt);
+ /// <summary>
+ /// Starts the digitization process for a point
+ /// </summary>
+ void DigitizePoint(PointDigitizationCallback callback, string customPrompt);
+ /// <summary>
+ /// Starts the digitization process for a polygon
+ /// </summary>
+ void DigitizePolygon(PolygonDigitizationCallback callback, string customPrompt);
+ /// <summary>
+ /// Starts the digitization process for a line string (polyline)
+ /// </summary>
+ void DigitizeLineString(LineStringDigitizationCallback callback, string customPrompt);
+ /// <summary>
+ /// </summary>
+ /// <param name="segmentDigitized">The callback to be invoked when a new segment of the current line string is digitized</param>
+ void DigitizeLineString(LineStringDigitizationCallback callback, LineDigitizationCallback segmentDigitized, string customPrompt);
+ /// <summary>
+ /// Starts the digitization process for a rectangle
+ /// </summary>
+ void DigitizeRectangle(RectangleDigitizationCallback callback, string customPrompt);
+ /// <summary>
/// Gets the current runtime map
/// </summary>
/// <returns></returns>
Modified: branches/2.4/MgDev/Desktop/MapViewer/MgMapViewer.cs
--- branches/2.4/MgDev/Desktop/MapViewer/MgMapViewer.cs 2012-06-27 12:01:50 UTC (rev 6824)
+++ branches/2.4/MgDev/Desktop/MapViewer/MgMapViewer.cs 2012-06-27 13:07:09 UTC (rev 6825)
@@ -192,7 +192,16 @@
SetStyle(ControlStyles.DoubleBuffer, true);
_mapBgColor = Color.Transparent;
+ _defaultDigitizationInstructions = Properties.Resources.GeneralDigitizationInstructions;
+ _defaultMultiSegmentDigitizationInstructions = Properties.Resources.MultiSegmentDigitzationInstructions;
+ _defaultPointDigitizationPrompt = Properties.Resources.PointDigitizationPrompt;
+ _defaultLineDigitizationPrompt = Properties.Resources.LineDigitizationPrompt;
+ _defaultCircleDigitizationPrompt = Properties.Resources.CircleDigitizationPrompt;
+ _defaultLineStringDigitizationPrompt = Properties.Resources.LineStringDigitizationPrompt;
+ _defaultPolygonDigitizationPrompt = Properties.Resources.PolygonDigitizationPrompt;
+ _defaultRectangleDigitizationPrompt = Properties.Resources.RectangleDigitizationPrompt;
renderWorker = new BackgroundWorker();
renderWorker.DoWork += renderWorker_DoWork;
@@ -218,6 +227,18 @@
CancelDigitization();
+ else if (e.KeyCode == Keys.Z && e.Modifiers == Keys.Control)
+ if (this.DigitizingType == MapDigitizationType.LineString ||
+ this.DigitizingType == MapDigitizationType.Polygon)
+ if (dPath.Count > 1) //Slice off the last recorded point
+ dPath.RemoveAt(dPath.Count - 1);
+ Invalidate();
private void CancelDigitization()
@@ -450,6 +471,23 @@
+ private string _defaultDigitizationInstructions;
+ private string _defaultMultiSegmentDigitizationInstructions;
+ private string _defaultPointDigitizationPrompt;
+ private string _defaultLineDigitizationPrompt;
+ private string _defaultCircleDigitizationPrompt;
+ private string _defaultLineStringDigitizationPrompt;
+ private string _defaultPolygonDigitizationPrompt;
+ private string _defaultRectangleDigitizationPrompt;
+ private string _pointCustomDigitizationPrompt;
+ private string _lineCustomDigitizationPrompt;
+ private string _circleCustomDigitizationPrompt;
+ private string _lineStringCustomDigitizationPrompt;
+ private string _polygonCustomDigitizationPrompt;
+ private string _rectangleCustomDigitizationPrompt;
/// <summary>
/// Raises the <see cref="E:System.Windows.Forms.Control.Paint"/> event.
/// </summary>
@@ -459,18 +497,7 @@
base.OnPaint(e);
Trace.TraceInformation("OnPaint(e)");
- if (!translate.IsEmpty)
- if (mouseWheelTx.HasValue && mouseWheelTy.HasValue)
- e.Graphics.TranslateTransform(translate.X + mouseWheelTx.Value, translate.Y + mouseWheelTy.Value);
- else
- e.Graphics.TranslateTransform(translate.X, translate.Y);
- else
- e.Graphics.TranslateTransform(mouseWheelTx.Value, mouseWheelTy.Value);
+ ApplyPaintTranslateTransform(e);
if (mouseWheelSx.HasValue && mouseWheelSy.HasValue && mouseWheelSx.Value != 0.0 && mouseWheelSy.Value != 0.0)
@@ -490,6 +517,8 @@
e.Graphics.DrawImage(_selectionImage, new PointF(0, 0));
+ //TODO: We could add support here for map-space persistent digitizations
if (isDragging && (this.ActiveTool == MapActiveTool.Select || this.ActiveTool == MapActiveTool.ZoomIn))
DrawDragRectangle(e);
@@ -500,7 +529,8 @@
if (this.DigitizingType == MapDigitizationType.Point)
- DrawTrackingTooltip(e, "Click to finish. Press ESC to cancel");
+ string str = (_pointCustomDigitizationPrompt ?? _defaultPointDigitizationPrompt) + Environment.NewLine + _defaultDigitizationInstructions;
+ DrawTrackingTooltip(e, str);
else
@@ -544,6 +574,22 @@
+ private void ApplyPaintTranslateTransform(PaintEventArgs e)
+ if (!translate.IsEmpty)
+ if (mouseWheelTx.HasValue && mouseWheelTy.HasValue)
+ e.Graphics.TranslateTransform(translate.X + mouseWheelTx.Value, translate.Y + mouseWheelTy.Value);
+ else
+ e.Graphics.TranslateTransform(translate.X, translate.Y);
+ else
+ e.Graphics.TranslateTransform(mouseWheelTx.Value, mouseWheelTy.Value);
private Brush _digitizingOutline;
[Category("MapGuide Viewer")]
@@ -678,7 +724,8 @@
e.Graphics.DrawEllipse(CreateOutlinePen(), pt2.X, pt2.Y, diameter, diameter);
e.Graphics.FillEllipse(CreateFillBrush(), pt2.X, pt2.Y, diameter, diameter);
+ string str = (_circleCustomDigitizationPrompt ?? _defaultCircleDigitizationPrompt) + Environment.NewLine + _defaultDigitizationInstructions;
private void DrawTracingLine(PaintEventArgs e)
@@ -686,7 +733,8 @@
e.Graphics.DrawLine(CreateOutlinePen(), dPtStart, new Point(_mouseX, _mouseY));
DrawVertexCoordinates(e, dPtStart.X, dPtStart.Y, true);
DrawVertexCoordinates(e, _mouseX, _mouseY, true);
+ string str = (_lineCustomDigitizationPrompt ?? _defaultLineDigitizationPrompt) + Environment.NewLine + _defaultDigitizationInstructions;
private void DrawTracingLineString(PaintEventArgs e)
@@ -700,8 +748,8 @@
DrawVertexCoordinates(e, pt.X, pt.Y, true);
- DrawTrackingTooltip(e, "Click again to add a new vertex.\nDouble-click to finish. Press ESC to cancel");
+ string str = (_lineStringCustomDigitizationPrompt ?? _defaultLineStringDigitizationPrompt) + Environment.NewLine + _defaultMultiSegmentDigitizationInstructions;
private void DrawTracingPolygon(PaintEventArgs e)
@@ -716,8 +764,8 @@
+ string str = (_polygonCustomDigitizationPrompt ?? _defaultPolygonDigitizationPrompt) + Environment.NewLine + _defaultMultiSegmentDigitizationInstructions;
private void DrawTracingRectangle(PaintEventArgs e)
@@ -735,7 +783,8 @@
DrawVertexCoordinates(e, r.Left, r.Bottom, true);
DrawVertexCoordinates(e, r.Right, r.Top, true);
DrawVertexCoordinates(e, r.Right, r.Bottom, true);
+ string str = (_rectangleCustomDigitizationPrompt ?? _defaultRectangleDigitizationPrompt) + Environment.NewLine + _defaultDigitizationInstructions;
@@ -840,55 +889,65 @@
/// </summary>
- public void DigitizeCircle(CircleDigitizationCallback callback)
+ public void DigitizeCircle(CircleDigitizationCallback callback, string customPrompt)
this.DigitizingType = MapDigitizationType.Circle;
_digitzationCallback = callback;
_digitizationYetToStart = true;
+ _circleCustomDigitizationPrompt = customPrompt;
/// <summary>
/// </summary>
- public void DigitizeLine(LineDigitizationCallback callback)
+ public void DigitizeLine(LineDigitizationCallback callback, string customPrompt)
this.DigitizingType = MapDigitizationType.Line;
+ _lineCustomDigitizationPrompt = customPrompt;
/// <summary>
/// </summary>
- public void DigitizePoint(PointDigitizationCallback callback)
+ public void DigitizePoint(PointDigitizationCallback callback, string customPrompt)
this.DigitizingType = MapDigitizationType.Point;
+ _pointCustomDigitizationPrompt = customPrompt;
/// <summary>
/// </summary>
- public void DigitizePolygon(PolygonDigitizationCallback callback)
+ public void DigitizePolygon(PolygonDigitizationCallback callback, string customPrompt)
this.DigitizingType = MapDigitizationType.Polygon;
+ _polygonCustomDigitizationPrompt = customPrompt;
/// <summary>
/// </summary>
- public void DigitizeLineString(LineStringDigitizationCallback callback)
+ public void DigitizeLineString(LineStringDigitizationCallback callback, string customPrompt)
this.DigitizingType = MapDigitizationType.LineString;
+ _lineStringCustomDigitizationPrompt = customPrompt;
private LineDigitizationCallback _segmentCallback;
@@ -898,25 +957,64 @@
/// </summary>
/// <param name="segmentCallback">The callback to be invoked when a new segment of the current line string is digitized</param>
- public void DigitizeLineString(LineStringDigitizationCallback callback, LineDigitizationCallback segmentCallback)
+ public void DigitizeLineString(LineStringDigitizationCallback callback, LineDigitizationCallback segmentCallback, string customPrompt)
_segmentCallback = segmentCallback;
/// <summary>
/// </summary>
- public void DigitizeRectangle(RectangleDigitizationCallback callback)
+ public void DigitizeRectangle(RectangleDigitizationCallback callback, string customPrompt)
this.DigitizingType = MapDigitizationType.Rectangle;
+ _rectangleCustomDigitizationPrompt = customPrompt;
+ public void DigitizeCircle(CircleDigitizationCallback callback)
+ DigitizeCircle(callback, null);
+ public void DigitizeLine(LineDigitizationCallback callback)
+ DigitizeLine(callback, null);
+ public void DigitizePoint(PointDigitizationCallback callback)
+ DigitizePoint(callback, null);
+ public void DigitizePolygon(PolygonDigitizationCallback callback)
+ DigitizePolygon(callback, null);
+ public void DigitizeLineString(LineStringDigitizationCallback callback)
+ DigitizeLineString(callback, (string)null);
+ public void DigitizeLineString(LineStringDigitizationCallback callback, LineDigitizationCallback segmentDigitized)
+ DigitizeLineString(callback, segmentDigitized, null);
+ public void DigitizeRectangle(RectangleDigitizationCallback callback)
+ DigitizeRectangle(callback, null);
private void ResetDigitzationState()
_digitzationCallback = null;
@@ -925,6 +1023,12 @@
dPtEnd.X = dPtStart.Y = 0;
dPtStart.X = dPtStart.Y = 0;
this.DigitizingType = MapDigitizationType.None;
+ _circleCustomDigitizationPrompt = null;
+ _lineCustomDigitizationPrompt = null;
+ _lineStringCustomDigitizationPrompt = null;
+ _polygonCustomDigitizationPrompt = null;
+ _pointCustomDigitizationPrompt = null;
+ _rectangleCustomDigitizationPrompt = null;
Invalidate();
Modified: branches/2.4/MgDev/Desktop/MapViewer/Properties/Resources.Designer.cs
--- branches/2.4/MgDev/Desktop/MapViewer/Properties/Resources.Designer.cs 2012-06-27 12:01:50 UTC (rev 6824)
+++ branches/2.4/MgDev/Desktop/MapViewer/Properties/Resources.Designer.cs 2012-06-27 13:07:09 UTC (rev 6825)
@@ -122,6 +122,15 @@
+ /// <summary>
+ /// Looks up a localized string similar to Click to finish.
+ /// </summary>
+ internal static string CircleDigitizationPrompt {
+ get {
+ return ResourceManager.GetString("CircleDigitizationPrompt", resourceCulture);
internal static System.Drawing.Bitmap control {
get {
object obj = ResourceManager.GetObject("control", resourceCulture);
@@ -219,6 +228,15 @@
+ /// <summary>
+ /// Looks up a localized string similar to Press ESC to cancel.
+ /// </summary>
+ internal static string GeneralDigitizationInstructions {
+ get {
+ return ResourceManager.GetString("GeneralDigitizationInstructions", resourceCulture);
internal static byte[] grab {
get {
object obj = ResourceManager.GetObject("grab", resourceCulture);
@@ -408,6 +426,24 @@
+ /// <summary>
+ /// </summary>
+ internal static string LineDigitizationPrompt {
+ get {
+ return ResourceManager.GetString("LineDigitizationPrompt", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Click again to add a new vertex.\nDouble-click to finish.
+ /// </summary>
+ internal static string LineStringDigitizationPrompt {
+ get {
+ return ResourceManager.GetString("LineStringDigitizationPrompt", resourceCulture);
internal static System.Drawing.Bitmap load_package {
get {
object obj = ResourceManager.GetObject("load_package", resourceCulture);
@@ -429,6 +465,15 @@
+ /// <summary>
+ /// Looks up a localized string similar to Press Ctrl-Z to undo last point.\nPress ESC to cancel.
+ /// </summary>
+ internal static string MultiSegmentDigitzationInstructions {
+ get {
+ return ResourceManager.GetString("MultiSegmentDigitzationInstructions", resourceCulture);
internal static System.Drawing.Bitmap options {
get {
object obj = ResourceManager.GetObject("options", resourceCulture);
@@ -443,6 +488,24 @@
+ /// <summary>
+ /// </summary>
+ internal static string PointDigitizationPrompt {
+ get {
+ return ResourceManager.GetString("PointDigitizationPrompt", resourceCulture);
+ /// <summary>
+ /// </summary>
+ internal static string PolygonDigitizationPrompt {
+ get {
+ return ResourceManager.GetString("PolygonDigitizationPrompt", resourceCulture);
internal static System.Drawing.Bitmap PoweredBy_en {
get {
object obj = ResourceManager.GetObject("PoweredBy_en", resourceCulture);
@@ -464,6 +527,15 @@
+ /// <summary>
+ /// </summary>
+ internal static string RectangleDigitizationPrompt {
+ get {
+ return ResourceManager.GetString("RectangleDigitizationPrompt", resourceCulture);
internal static System.Drawing.Bitmap search {
get {
object obj = ResourceManager.GetObject("search", resourceCulture);
Modified: branches/2.4/MgDev/Desktop/MapViewer/Properties/Resources.resx
--- branches/2.4/MgDev/Desktop/MapViewer/Properties/Resources.resx 2012-06-27 12:01:50 UTC (rev 6824)
+++ branches/2.4/MgDev/Desktop/MapViewer/Properties/Resources.resx 2012-06-27 13:07:09 UTC (rev 6825)
@@ -451,4 +451,28 @@
<data name="TextZoomPrevious" xml:space="preserve">
<value>Zoom Previous</value>
</data>
+ <data name="CircleDigitizationPrompt" xml:space="preserve">
+ <value>Click to finish</value>
+ </data>
+ <data name="LineDigitizationPrompt" xml:space="preserve">
+ </data>
+ <data name="LineStringDigitizationPrompt" xml:space="preserve">
+ <value>Click again to add a new vertex.\nDouble-click to finish</value>
+ </data>
+ <data name="PointDigitizationPrompt" xml:space="preserve">
+ </data>
+ <data name="PolygonDigitizationPrompt" xml:space="preserve">
+ </data>
+ <data name="GeneralDigitizationInstructions" xml:space="preserve">
+ <value>Press ESC to cancel</value>
+ </data>
+ <data name="MultiSegmentDigitzationInstructions" xml:space="preserve">
+ <value>Press Ctrl-Z to undo last point.\nPress ESC to cancel</value>
+ </data>
+ <data name="RectangleDigitizationPrompt" xml:space="preserve">
+ </data>
</root>
\ No newline at end of file
Modified: branches/2.4/MgDev/Desktop/MapViewerTest/MgAppWindow.Designer.cs
--- branches/2.4/MgDev/Desktop/MapViewerTest/MgAppWindow.Designer.cs 2012-06-27 12:01:50 UTC (rev 6824)
+++ branches/2.4/MgDev/Desktop/MapViewerTest/MgAppWindow.Designer.cs 2012-06-27 13:07:09 UTC (rev 6825)
@@ -32,92 +32,92 @@
System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(MgAppWindow));
this.appMenu = new System.Windows.Forms.MenuStrip();
this.fileToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
+ this.toolStripMenuItem30 = new System.Windows.Forms.ToolStripMenuItem();
+ this.toolStripMenuItem1 = new System.Windows.Forms.ToolStripMenuItem();
this.toolsToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
+ this.toolStripMenuItem2 = new System.Windows.Forms.ToolStripMenuItem();
+ this.toolStripMenuItem3 = new System.Windows.Forms.ToolStripMenuItem();
+ this.toolStripMenuItem4 = new System.Windows.Forms.ToolStripMenuItem();
+ this.toolStripMenuItem28 = new System.Windows.Forms.ToolStripMenuItem();
this.toolStripSeparator9 = new System.Windows.Forms.ToolStripSeparator();
+ this.toolStripMenuItem12 = new System.Windows.Forms.ToolStripMenuItem();
this.appContextMenu = new System.Windows.Forms.ContextMenuStrip(this.components);
+ this.toolStripMenuItem13 = new System.Windows.Forms.ToolStripMenuItem();
this.toolStripSeparator10 = new System.Windows.Forms.ToolStripSeparator();
+ this.toolStripMenuItem14 = new System.Windows.Forms.ToolStripMenuItem();
+ this.toolStripMenuItem15 = new System.Windows.Forms.ToolStripMenuItem();
+ this.toolStripMenuItem16 = new System.Windows.Forms.ToolStripMenuItem();
+ this.toolStripMenuItem17 = new System.Windows.Forms.ToolStripMenuItem();
this.toolStripSeparator11 = new System.Windows.Forms.ToolStripSeparator();
+ this.toolStripMenuItem18 = new System.Windows.Forms.ToolStripMenuItem();
+ this.toolStripMenuItem19 = new System.Windows.Forms.ToolStripMenuItem();
+ this.toolStripMenuItem20 = new System.Windows.Forms.ToolStripMenuItem();
this.toolStripSeparator12 = new System.Windows.Forms.ToolStripSeparator();
+ this.toolStripMenuItem21 = new System.Windows.Forms.ToolStripMenuItem();
+ this.toolStripMenuItem22 = new System.Windows.Forms.ToolStripMenuItem();
+ this.toolStripMenuItem23 = new System.Windows.Forms.ToolStripMenuItem();
this.toolStripSeparator13 = new System.Windows.Forms.ToolStripSeparator();
+ this.toolStripMenuItem24 = new System.Windows.Forms.ToolStripMenuItem();
this.appContainer = new System.Windows.Forms.SplitContainer();
this.toolStripContainer = new System.Windows.Forms.ToolStripContainer();
this.infoPaneViewerContainer = new System.Windows.Forms.SplitContainer();
this.infoPaneContainer = new System.Windows.Forms.SplitContainer();
this.layersTabs = new System.Windows.Forms.TabControl();
this.tabPage1 = new System.Windows.Forms.TabPage();
+ this.legendCtrl = new OSGeo.MapGuide.Viewer.MgLegend();
this.propertiesTabs = new System.Windows.Forms.TabControl();
this.tabPage3 = new System.Windows.Forms.TabPage();
- this.appToolbar = new System.Windows.Forms.ToolStrip();
- this.toolStripSeparator1 = new System.Windows.Forms.ToolStripSeparator();
- this.toolStripSeparator2 = new System.Windows.Forms.ToolStripSeparator();
- this.toolStripSeparator3 = new System.Windows.Forms.ToolStripSeparator();
- this.toolStripSeparator4 = new System.Windows.Forms.ToolStripSeparator();
- this.toolStripSeparator5 = new System.Windows.Forms.ToolStripSeparator();
- this.toolStripSeparator6 = new System.Windows.Forms.ToolStripSeparator();
- this.toolStripDropDownButton1 = new System.Windows.Forms.ToolStripDropDownButton();
- this.toolStripSeparator8 = new System.Windows.Forms.ToolStripSeparator();
- this.toolStripDropDownButton2 = new System.Windows.Forms.ToolStripDropDownButton();
- this.lblLoading = new System.Windows.Forms.ToolStripLabel();
- this.toolStrip1 = new System.Windows.Forms.ToolStrip();
- this.btnInitialTask = new System.Windows.Forms.ToolStripButton();
- this.taskMenu = new System.Windows.Forms.ToolStripSplitButton();
- this.statusBar = new System.Windows.Forms.StatusStrip();
- this.lblPosition = new System.Windows.Forms.ToolStripStatusLabel();
- this.lblSelected = new System.Windows.Forms.ToolStripStatusLabel();
- this.lblScale = new System.Windows.Forms.ToolStripStatusLabel();
- this.lblSize = new System.Windows.Forms.ToolStripStatusLabel();
- this.lblLogo = new System.Windows.Forms.ToolStripStatusLabel();
- this.toolStripSeparator14 = new System.Windows.Forms.ToolStripSeparator();
- this.toolStripSeparator7 = new System.Windows.Forms.ToolStripSeparator();
- this.legendCtrl = new OSGeo.MapGuide.Viewer.MgLegend();
this.propertiesCtrl = new OSGeo.MapGuide.Viewer.MgPropertyPane();
this.mapViewer = new OSGeo.MapGuide.Viewer.MgMapViewer();
+ this.appToolbar = new System.Windows.Forms.ToolStrip();
this.toolStripButton1 = new System.Windows.Forms.ToolStripButton();
+ this.toolStripSeparator1 = new System.Windows.Forms.ToolStripSeparator();
this.toolStripButton2 = new System.Windows.Forms.ToolStripButton();
+ this.toolStripSeparator2 = new System.Windows.Forms.ToolStripSeparator();
this.toolStripButton3 = new System.Windows.Forms.ToolStripButton();
this.toolStripButton4 = new System.Windows.Forms.ToolStripButton();
this.toolStripButton5 = new System.Windows.Forms.ToolStripButton();
+ this.toolStripSeparator7 = new System.Windows.Forms.ToolStripSeparator();
+ this.toolStripButton13 = new System.Windows.Forms.ToolStripButton();
this.toolStripButton14 = new System.Windows.Forms.ToolStripButton();
- this.toolStripButton13 = new System.Windows.Forms.ToolStripButton();
+ this.toolStripSeparator3 = new System.Windows.Forms.ToolStripSeparator();
this.toolStripButton6 = new System.Windows.Forms.ToolStripButton();
this.toolStripButton7 = new System.Windows.Forms.ToolStripButton();
this.toolStripButton8 = new System.Windows.Forms.ToolStripButton();
this.toolStripButton9 = new System.Windows.Forms.ToolStripButton();
+ this.toolStripSeparator4 = new System.Windows.Forms.ToolStripSeparator();
this.toolStripButton10 = new System.Windows.Forms.ToolStripButton();
this.toolStripButton11 = new System.Windows.Forms.ToolStripButton();
+ this.toolStripSeparator5 = new System.Windows.Forms.ToolStripSeparator();
this.toolStripButton12 = new System.Windows.Forms.ToolStripButton();
+ this.toolStripSeparator6 = new System.Windows.Forms.ToolStripSeparator();
+ this.toolStripDropDownButton1 = new System.Windows.Forms.ToolStripDropDownButton();
this.toolStripMenuItem9 = new System.Windows.Forms.ToolStripMenuItem();
this.toolStripMenuItem10 = new System.Windows.Forms.ToolStripMenuItem();
this.toolStripMenuItem11 = new System.Windows.Forms.ToolStripMenuItem();
this.toolStripMenuItem27 = new System.Windows.Forms.ToolStripMenuItem();
+ this.toolStripSeparator14 = new System.Windows.Forms.ToolStripSeparator();
this.toolStripMenuItem31 = new System.Windows.Forms.ToolStripMenuItem();
+ this.toolStripSeparator8 = new System.Windows.Forms.ToolStripSeparator();
+ this.toolStripDropDownButton2 = new System.Windows.Forms.ToolStripDropDownButton();
this.toolStripMenuItem8 = new System.Windows.Forms.ToolStripMenuItem();
this.toolStripMenuItem25 = new System.Windows.Forms.ToolStripMenuItem();
this.toolStripMenuItem26 = new System.Windows.Forms.ToolStripMenuItem();
+ this.lblLoading = new System.Windows.Forms.ToolStripLabel();
this.taskPane = new OSGeo.MapGuide.Viewer.MgTaskPane();
+ this.toolStrip1 = new System.Windows.Forms.ToolStrip();
+ this.btnInitialTask = new System.Windows.Forms.ToolStripButton();
+ this.taskMenu = new System.Windows.Forms.ToolStripSplitButton();
this.toolStripMenuItem5 = new System.Windows.Forms.ToolStripMenuItem();
this.toolStripMenuItem6 = new System.Windows.Forms.ToolStripMenuItem();
this.toolStripMenuItem7 = new System.Windows.Forms.ToolStripMenuItem();
this.toolStripMenuItem29 = new System.Windows.Forms.ToolStripMenuItem();
- this.toolStripMenuItem30 = new System.Windows.Forms.ToolStripMenuItem();
- this.toolStripMenuItem1 = new System.Windows.Forms.ToolStripMenuItem();
- this.toolStripMenuItem2 = new System.Windows.Forms.ToolStripMenuItem();
- this.toolStripMenuItem3 = new System.Windows.Forms.ToolStripMenuItem();
- this.toolStripMenuItem4 = new System.Windows.Forms.ToolStripMenuItem();
- this.toolStripMenuItem28 = new System.Windows.Forms.ToolStripMenuItem();
- this.toolStripMenuItem12 = new System.Windows.Forms.ToolStripMenuItem();
- this.toolStripMenuItem13 = new System.Windows.Forms.ToolStripMenuItem();
- this.toolStripMenuItem14 = new System.Windows.Forms.ToolStripMenuItem();
- this.toolStripMenuItem15 = new System.Windows.Forms.ToolStripMenuItem();
- this.toolStripMenuItem16 = new System.Windows.Forms.ToolStripMenuItem();
- this.toolStripMenuItem17 = new System.Windows.Forms.ToolStripMenuItem();
- this.toolStripMenuItem18 = new System.Windows.Forms.ToolStripMenuItem();
- this.toolStripMenuItem19 = new System.Windows.Forms.ToolStripMenuItem();
- this.toolStripMenuItem20 = new System.Windows.Forms.ToolStripMenuItem();
- this.toolStripMenuItem21 = new System.Windows.Forms.ToolStripMenuItem();
- this.toolStripMenuItem22 = new System.Windows.Forms.ToolStripMenuItem();
- this.toolStripMenuItem23 = new System.Windows.Forms.ToolStripMenuItem();
- this.toolStripMenuItem24 = new System.Windows.Forms.ToolStripMenuItem();
+ this.statusBar = new System.Windows.Forms.StatusStrip();
+ this.lblPosition = new System.Windows.Forms.ToolStripStatusLabel();
+ this.lblSelected = new System.Windows.Forms.ToolStripStatusLabel();
+ this.lblScale = new System.Windows.Forms.ToolStripStatusLabel();
+ this.lblSize = new System.Windows.Forms.ToolStripStatusLabel();
+ this.lblLogo = new System.Windows.Forms.ToolStripStatusLabel();
this.mgPrintComponent1 = new OSGeo.MapGuide.Viewer.MgPrintComponent();
this.mgCopyMapComponent1 = new OSGeo.MapGuide.Viewer.MgCopyMapComponent();
this.mgZoomInComponent1 = new OSGeo.MapGuide.Viewer.MgZoomInComponent();
@@ -146,6 +146,13 @@
this.mgZoomNextComponent1 = new OSGeo.MapGuide.Viewer.MgZoomNextComponent();
this.mgZoomPreviousComponent1 = new OSGeo.MapGuide.Viewer.MgZoomPreviousComponent();
this.mgLayerSelectionHandler1 = new OSGeo.MapGuide.Viewer.MgLayerSelectionHandler();
+ this.toolStripSplitButton1 = new System.Windows.Forms.ToolStripSplitButton();
+ this.pointToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
+ this.lineToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
+ this.rectangleToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
+ this.lineStringToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
+ this.polygonToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
+ this.circleToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
this.appMenu.SuspendLayout();
this.appContextMenu.SuspendLayout();
this.appContainer.Panel1.SuspendLayout();
@@ -195,6 +202,24 @@
this.fileToolStripMenuItem.Size = new System.Drawing.Size(37, 20);
this.fileToolStripMenuItem.Text = "File";
+ // toolStripMenuItem30
+ this.toolStripMenuItem30.Image = global::MapViewerTest.Properties.Resources.map__arrow;
+ this.toolStripMenuItem30.Name = "toolStripMenuItem30";
+ this.toolStripMenuItem30.Size = new System.Drawing.Size(189, 22);
+ this.mgMenuItemComponentInvoker1.SetTargetComponent(this.toolStripMenuItem30, this.mgLoadMapComponent1);
+ this.toolStripMenuItem30.Text = "Load Sheboygan Map";
+ this.toolStripMenuItem30.ToolTipText = "Load the Sheboygan Map";
+ // toolStripMenuItem1
+ this.toolStripMenuItem1.Image = ((System.Drawing.Image)(resources.GetObject("toolStripMenuItem1.Image")));
+ this.toolStripMenuItem1.Name = "toolStripMenuItem1";
+ this.toolStripMenuItem1.Size = new System.Drawing.Size(189, 22);
+ this.mgMenuItemComponentInvoker1.SetTargetComponent(this.toolStripMenuItem1, this.mgLoadPackageComponent1);
+ this.toolStripMenuItem1.Text = "Load Package";
+ this.toolStripMenuItem1.ToolTipText = "Load Package";
// toolsToolStripMenuItem
this.toolsToolStripMenuItem.DropDownItems.AddRange(new System.Windows.Forms.ToolStripItem[] {
@@ -208,11 +233,58 @@
this.toolsToolStripMenuItem.Size = new System.Drawing.Size(48, 20);
this.toolsToolStripMenuItem.Text = "Tools";
+ // toolStripMenuItem2
+ this.toolStripMenuItem2.Enabled = false;
+ this.toolStripMenuItem2.Image = ((System.Drawing.Image)(resources.GetObject("toolStripMenuItem2.Image")));
+ this.toolStripMenuItem2.Name = "toolStripMenuItem2";
+ this.toolStripMenuItem2.Size = new System.Drawing.Size(154, 22);
+ this.mgMenuItemComponentInvoker1.SetTargetComponent(this.toolStripMenuItem2, this.mgBufferComponent1);
+ this.toolStripMenuItem2.Text = "Buffer";
+ this.toolStripMenuItem3.Enabled = false;
+ this.toolStripMenuItem3.Image = ((System.Drawing.Image)(resources.GetObject("toolStripMenuItem3.Image")));
+ this.toolStripMenuItem3.Name = "toolStripMenuItem3";
+ this.toolStripMenuItem3.Size = new System.Drawing.Size(154, 22);
+ this.mgMenuItemComponentInvoker1.SetTargetComponent(this.toolStripMenuItem3, this.mgMeasureComponent1);
+ this.toolStripMenuItem3.Text = "Measure";
+ // toolStripMenuItem4
+ this.toolStripMenuItem4.Enabled = false;
+ this.toolStripMenuItem4.Image = ((System.Drawing.Image)(resources.GetObject("toolStripMenuItem4.Image")));
+ this.toolStripMenuItem4.Name = "toolStripMenuItem4";
+ this.toolStripMenuItem4.Size = new System.Drawing.Size(154, 22);
+ this.mgMenuItemComponentInvoker1.SetTargetComponent(this.toolStripMenuItem4, this.mgQueryComponent1);
+ this.toolStripMenuItem4.Text = "Query";
+ // toolStripMenuItem28
+ this.toolStripMenuItem28.Enabled = false;
+ this.toolStripMenuItem28.Image = ((System.Drawing.Image)(resources.GetObject("toolStripMenuItem28.Image")));
+ this.toolStripMenuItem28.Name = "toolStripMenuItem28";
+ this.toolStripMenuItem28.Size = new System.Drawing.Size(154, 22);
+ this.mgMenuItemComponentInvoker1.SetTargetComponent(this.toolStripMenuItem28, this.mgThemeComponent1);
+ this.toolStripMenuItem28.Text = "Theme";
+ this.toolStripMenuItem28.ToolTipText = "Theme";
// toolStripSeparator9
this.toolStripSeparator9.Name = "toolStripSeparator9";
this.toolStripSeparator9.Size = new System.Drawing.Size(151, 6);
+ // toolStripMenuItem12
+ this.toolStripMenuItem12.Enabled = false;
+ this.toolStripMenuItem12.Image = ((System.Drawing.Image)(resources.GetObject("toolStripMenuItem12.Image")));
+ this.toolStripMenuItem12.Name = "toolStripMenuItem12";
+ this.toolStripMenuItem12.Size = new System.Drawing.Size(154, 22);
+ this.mgMenuItemComponentInvoker1.SetTargetComponent(this.toolStripMenuItem12, this.mgViewerOptionsComponent1);
+ this.toolStripMenuItem12.Text = "Viewer Options";
+ this.toolStripMenuItem12.ToolTipText = "Viewer Options";
// appContextMenu
this.appContextMenu.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
@@ -235,26 +307,143 @@
this.appContextMenu.Name = "appContextMenu";
this.appContextMenu.Size = new System.Drawing.Size(172, 292);
+ // toolStripMenuItem13
+ this.toolStripMenuItem13.Enabled = false;
+ this.toolStripMenuItem13.Image = ((System.Drawing.Image)(resources.GetObject("toolStripMenuItem13.Image")));
+ this.toolStripMenuItem13.Name = "toolStripMenuItem13";
+ this.toolStripMenuItem13.Size = new System.Drawing.Size(171, 22);
+ this.mgMenuItemComponentInvoker1.SetTargetComponent(this.toolStripMenuItem13, this.mgRefreshMapComponent1);
+ this.toolStripMenuItem13.Text = "Refresh Map";
+ this.toolStripMenuItem13.ToolTipText = "Refresh Map";
// toolStripSeparator10
this.toolStripSeparator10.Name = "toolStripSeparator10";
this.toolStripSeparator10.Size = new System.Drawing.Size(168, 6);
+ // toolStripMenuItem14
+ this.toolStripMenuItem14.Enabled = false;
+ this.toolStripMenuItem14.Image = ((System.Drawing.Image)(resources.GetObject("toolStripMenuItem14.Image")));
+ this.toolStripMenuItem14.Name = "toolStripMenuItem14";
+ this.toolStripMenuItem14.Size = new System.Drawing.Size(171, 22);
+ this.mgMenuItemComponentInvoker1.SetTargetComponent(this.toolStripMenuItem14, this.mgZoomInComponent1);
+ this.toolStripMenuItem14.Text = "Zoom In";
+ this.toolStripMenuItem14.ToolTipText = "Zoom In";
+ // toolStripMenuItem15
+ this.toolStripMenuItem15.Enabled = false;
+ this.toolStripMenuItem15.Image = ((System.Drawing.Image)(resources.GetObject("toolStripMenuItem15.Image")));
+ this.toolStripMenuItem15.Name = "toolStripMenuItem15";
+ this.toolStripMenuItem15.Size = new System.Drawing.Size(171, 22);
+ this.mgMenuItemComponentInvoker1.SetTargetComponent(this.toolStripMenuItem15, this.mgZoomOutComponent1);
+ this.toolStripMenuItem15.Text = "Zoom Out";
+ this.toolStripMenuItem15.ToolTipText = "Zoom Out";
+ // toolStripMenuItem16
+ this.toolStripMenuItem16.Enabled = false;
+ this.toolStripMenuItem16.Image = ((System.Drawing.Image)(resources.GetObject("toolStripMenuItem16.Image")));
+ this.toolStripMenuItem16.Name = "toolStripMenuItem16";
+ this.toolStripMenuItem16.Size = new System.Drawing.Size(171, 22);
+ this.mgMenuItemComponentInvoker1.SetTargetComponent(this.toolStripMenuItem16, this.mgZoomToSelectionComponent1);
+ this.toolStripMenuItem16.Text = "Zoom to Selection";
+ this.toolStripMenuItem16.ToolTipText = "Zoom to Selection";
+ // toolStripMenuItem17
+ this.toolStripMenuItem17.Enabled = false;
+ this.toolStripMenuItem17.Image = ((System.Drawing.Image)(resources.GetObject("toolStripMenuItem17.Image")));
+ this.toolStripMenuItem17.Name = "toolStripMenuItem17";
+ this.toolStripMenuItem17.Size = new System.Drawing.Size(171, 22);
+ this.mgMenuItemComponentInvoker1.SetTargetComponent(this.toolStripMenuItem17, this.mgInitialViewComponent1);
+ this.toolStripMenuItem17.Text = "Zoom Extents";
+ this.toolStripMenuItem17.ToolTipText = "Zoom Extents";
// toolStripSeparator11
this.toolStripSeparator11.Name = "toolStripSeparator11";
this.toolStripSeparator11.Size = new System.Drawing.Size(168, 6);
+ // toolStripMenuItem18
+ this.toolStripMenuItem18.Enabled = false;
+ this.toolStripMenuItem18.Image = ((System.Drawing.Image)(resources.GetObject("toolStripMenuItem18.Image")));
+ this.toolStripMenuItem18.Name = "toolStripMenuItem18";
+ this.toolStripMenuItem18.Size = new System.Drawing.Size(171, 22);
+ this.mgMenuItemComponentInvoker1.SetTargetComponent(this.toolStripMenuItem18, this.mgPanComponent1);
+ this.toolStripMenuItem18.Text = "Pan";
+ this.toolStripMenuItem18.ToolTipText = "Pan";
+ // toolStripMenuItem19
+ this.toolStripMenuItem19.Enabled = false;
+ this.toolStripMenuItem19.Image = ((System.Drawing.Image)(resources.GetObject("toolStripMenuItem19.Image")));
+ this.toolStripMenuItem19.Name = "toolStripMenuItem19";
+ this.toolStripMenuItem19.Size = new System.Drawing.Size(171, 22);
+ this.mgMenuItemComponentInvoker1.SetTargetComponent(this.toolStripMenuItem19, this.mgSelectComponent1);
+ this.toolStripMenuItem19.Text = "Select";
+ this.toolStripMenuItem19.ToolTipText = "Select";
+ // toolStripMenuItem20
+ this.toolStripMenuItem20.Enabled = false;
+ this.toolStripMenuItem20.Image = ((System.Drawing.Image)(resources.GetObject("toolStripMenuItem20.Image")));
+ this.toolStripMenuItem20.Name = "toolStripMenuItem20";
+ this.toolStripMenuItem20.Size = new System.Drawing.Size(171, 22);
+ this.mgMenuItemComponentInvoker1.SetTargetComponent(this.toolStripMenuItem20, this.mgClearSelectionComponent1);
+ this.toolStripMenuItem20.Text = "Clear Selection";
+ this.toolStripMenuItem20.ToolTipText = "Clear Selection";
// toolStripSeparator12
this.toolStripSeparator12.Name = "toolStripSeparator12";
this.toolStripSeparator12.Size = new System.Drawing.Size(168, 6);
+ // toolStripMenuItem21
+ this.toolStripMenuItem21.Enabled = false;
+ this.toolStripMenuItem21.Image = ((System.Drawing.Image)(resources.GetObject("toolStripMenuItem21.Image")));
+ this.toolStripMenuItem21.Name = "toolStripMenuItem21";
+ this.toolStripMenuItem21.Size = new System.Drawing.Size(171, 22);
+ this.mgMenuItemComponentInvoker1.SetTargetComponent(this.toolStripMenuItem21, this.mgBufferComponent1);
+ this.toolStripMenuItem21.Text = "Buffer";
+ // toolStripMenuItem22
+ this.toolStripMenuItem22.Enabled = false;
+ this.toolStripMenuItem22.Image = ((System.Drawing.Image)(resources.GetObject("toolStripMenuItem22.Image")));
+ this.toolStripMenuItem22.Name = "toolStripMenuItem22";
+ this.toolStripMenuItem22.Size = new System.Drawing.Size(171, 22);
+ this.mgMenuItemComponentInvoker1.SetTargetComponent(this.toolStripMenuItem22, this.mgMeasureComponent1);
+ this.toolStripMenuItem22.Text = "Measure";
+ // toolStripMenuItem23
+ this.toolStripMenuItem23.Enabled = false;
+ this.toolStripMenuItem23.Image = ((System.Drawing.Image)(resources.GetObject("toolStripMenuItem23.Image")));
+ this.toolStripMenuItem23.Name = "toolStripMenuItem23";
+ this.toolStripMenuItem23.Size = new System.Drawing.Size(171, 22);
+ this.mgMenuItemComponentInvoker1.SetTargetComponent(this.toolStripMenuItem23, this.mgQueryComponent1);
+ this.toolStripMenuItem23.Text = "Query";
// toolStripSeparator13
this.toolStripSeparator13.Name = "toolStripSeparator13";
this.toolStripSeparator13.Size = new System.Drawing.Size(168, 6);
+ // toolStripMenuItem24
+ this.toolStripMenuItem24.Enabled = false;
+ this.toolStripMenuItem24.Image = ((System.Drawing.Image)(resources.GetObject("toolStripMenuItem24.Image")));
+ this.toolStripMenuItem24.Name = "toolStripMenuItem24";
+ this.toolStripMenuItem24.Size = new System.Drawing.Size(171, 22);
+ this.mgMenuItemComponentInvoker1.SetTargetComponent(this.toolStripMenuItem24, this.mgViewerOptionsComponent1);
+ this.toolStripMenuItem24.Text = "Viewer Options";
+ this.toolStripMenuItem24.ToolTipText = "Viewer Options";
// appContainer
this.appContainer.Dock = System.Windows.Forms.DockStyle.Fill;
@@ -349,6 +538,18 @@
this.tabPage1.Text = "Layers";
this.tabPage1.UseVisualStyleBackColor = true;
+ // legendCtrl
+ this.legendCtrl.Dock = System.Windows.Forms.DockStyle.Fill;
+ this.legendCtrl.GroupContextMenu = null;
+ this.legendCtrl.LayerContextMenu = null;
+ this.legendCtrl.Location = new System.Drawing.Point(3, 3);
+ this.legendCtrl.Name = "legendCtrl";
+ this.legendCtrl.ShowTooltips = true;
+ this.legendCtrl.Size = new System.Drawing.Size(235, 246);
+ this.legendCtrl.TabIndex = 0;
+ this.legendCtrl.ThemeCompressionLimit = 0;
// propertiesTabs
this.propertiesTabs.Controls.Add(this.tabPage3);
@@ -370,6 +571,34 @@
this.tabPage3.Text = "Properties";
this.tabPage3.UseVisualStyleBackColor = true;
+ // propertiesCtrl
+ this.propertiesCtrl.Dock = System.Windows.Forms.DockStyle.Fill;
+ this.propertiesCtrl.Location = new System.Drawing.Point(3, 3);
+ this.propertiesCtrl.Name = "propertiesCtrl";
+ this.propertiesCtrl.Size = new System.Drawing.Size(235, 344);
+ this.propertiesCtrl.TabIndex = 0;
+ // mapViewer
+ this.mapViewer.ContextMenuStrip = this.appContextMenu;
+ this.mapViewer.ConvertTiledGroupsToNonTiled = true;
+ this.mapViewer.Cursor = System.Windows.Forms.Cursors.Default;
+ this.mapViewer.Dock = System.Windows.Forms.DockStyle.Fill;
+ this.mapViewer.Location = new System.Drawing.Point(0, 0);
+ this.mapViewer.MaxScale = 1000000000;
+ this.mapViewer.MinScale = 10;
+ this.mapViewer.MouseWheelDelayRenderInterval = 800;
+ this.mapViewer.Name = "mapViewer";
+ this.mapViewer.PointPixelBuffer = 2;
+ this.mapViewer.SelectionColor = System.Drawing.Color.Blue;
+ this.mapViewer.Size = new System.Drawing.Size(495, 658);
+ this.mapViewer.TabIndex = 0;
+ this.mapViewer.Text = "mgMapViewer1";
+ this.mapViewer.ZoomInFactor = 0.5;
+ this.mapViewer.ZoomOutFactor = 2;
+ this.mapViewer.PropertyChanged += new System.ComponentModel.PropertyChangedEventHandler(this.OnViewerPropertyChanged);
// appToolbar
this.appToolbar.Dock = System.Windows.Forms.DockStyle.None;
@@ -398,208 +627,14 @@
this.toolStripDropDownButton1,
this.toolStripSeparator8,
this.toolStripDropDownButton2,
- this.lblLoading});
+ this.lblLoading,
+ this.toolStripSplitButton1});
this.appToolbar.Location = new System.Drawing.Point(0, 0);
this.appToolbar.Name = "appToolbar";
this.appToolbar.Size = new System.Drawing.Size(748, 25);
this.appToolbar.Stretch = true;
this.appToolbar.TabIndex = 0;
- // toolStripSeparator1
- this.toolStripSeparator1.Name = "toolStripSeparator1";
- this.toolStripSeparator1.Size = new System.Drawing.Size(6, 25);
- // toolStripSeparator2
- this.toolStripSeparator2.Name = "toolStripSeparator2";
- this.toolStripSeparator2.Size = new System.Drawing.Size(6, 25);
- // toolStripSeparator3
- this.toolStripSeparator3.Name = "toolStripSeparator3";
- this.toolStripSeparator3.Size = new System.Drawing.Size(6, 25);
- // toolStripSeparator4
- this.toolStripSeparator4.Name = "toolStripSeparator4";
- this.toolStripSeparator4.Size = new System.Drawing.Size(6, 25);
- // toolStripSeparator5
- this.toolStripSeparator5.Name = "toolStripSeparator5";
- this.toolStripSeparator5.Size = new System.Drawing.Size(6, 25);
- // toolStripSeparator6
- this.toolStripSeparator6.Name = "toolStripSeparator6";
- this.toolStripSeparator6.Size = new System.Drawing.Size(6, 25);
- // toolStripDropDownButton1
- this.toolStripDropDownButton1.DropDownItems.AddRange(new System.Windows.Forms.ToolStripItem[] {
- this.toolStripMenuItem9,
- this.toolStripMenuItem10,
- this.toolStripMenuItem11,
- this.toolStripMenuItem27,
- this.toolStripSeparator14,
- this.toolStripMenuItem31});
- this.toolStripDropDownButton1.Image = global::MapViewerTest.Properties.Resources.icon_tasks;
- this.toolStripDropDownButton1.ImageTransparentColor = System.Drawing.Color.Magenta;
- this.toolStripDropDownButton1.Name = "toolStripDropDownButton1";
- this.toolStripDropDownButton1.Size = new System.Drawing.Size(65, 22);
- this.toolStripDropDownButton1.Text = "Tools";
- // toolStripSeparator8
- this.toolStripSeparator8.Name = "toolStripSeparator8";
- this.toolStripSeparator8.Size = new System.Drawing.Size(6, 25);
- // toolStripDropDownButton2
- this.toolStripDropDownButton2.DropDownItems.AddRange(new System.Windows.Forms.ToolStripItem[] {
- this.toolStripMenuItem8,
- this.toolStripMenuItem25,
- this.toolStripMenuItem26});
- this.toolStripDropDownButton2.Image = global::MapViewerTest.Properties.Resources.icon_tasks;
- this.toolStripDropDownButton2.ImageTransparentColor = System.Drawing.Color.Magenta;
- this.toolStripDropDownButton2.Name = "toolStripDropDownButton2";
- this.toolStripDropDownButton2.Size = new System.Drawing.Size(78, 22);
- this.toolStripDropDownButton2.Text = "Custom";
- // lblLoading
- this.lblLoading.Alignment = System.Windows.Forms.ToolStripItemAlignment.Right;
- this.lblLoading.Image = global::MapViewerTest.Properties.Resources.icon_loading;
- this.lblLoading.ImageScaling = System.Windows.Forms.ToolStripItemImageScaling.None;
- this.lblLoading.Name = "lblLoading";
- this.lblLoading.Size = new System.Drawing.Size(30, 22);
- this.lblLoading.Visible = false;
- // toolStrip1
- this.toolStrip1.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
- this.btnInitialTask,
- this.taskMenu});
- this.toolStrip1.Location = new System.Drawing.Point(0, 0);
- this.toolStrip1.Name = "toolStrip1";
- this.toolStrip1.Size = new System.Drawing.Size(256, 25);
- this.toolStrip1.TabIndex = 1;
- this.toolStrip1.Text = "toolStrip1";
- // btnInitialTask
- this.btnInitialTask.Image = global::MapViewerTest.Properties.Resources.icon_home;
- this.btnInitialTask.ImageTransparentColor = System.Drawing.Color.Magenta;
- this.btnInitialTask.Name = "btnInitialTask";
- this.btnInitialTask.Size = new System.Drawing.Size(83, 22);
- this.btnInitialTask.Text = "Initial Task";
- this.btnInitialTask.Click += new System.EventHandler(this.btnInitialTask_Click);
- // taskMenu
- this.taskMenu.Alignment = System.Windows.Forms.ToolStripItemAlignment.Right;
- this.taskMenu.DropDownItems.AddRange(new System.Windows.Forms.ToolStripItem[] {
- this.toolStripMenuItem5,
- this.toolStripMenuItem6,
- this.toolStripMenuItem7,
- this.toolStripMenuItem29});
- this.taskMenu.Image = global::MapViewerTest.Properties.Resources.icon_tasks;
- this.taskMenu.ImageTransparentColor = System.Drawing.Color.Magenta;
- this.taskMenu.Name = "taskMenu";
- this.taskMenu.Size = new System.Drawing.Size(68, 22);
- this.taskMenu.Text = "Tasks";
- // statusBar
- this.statusBar.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
- this.lblPosition,
- this.lblSelected,
- this.lblScale,
- this.lblSize,
- this.lblLogo});
- this.statusBar.Location = new System.Drawing.Point(0, 707);
- this.statusBar.Name = "statusBar";
- this.statusBar.Size = new System.Drawing.Size(1008, 23);
- this.statusBar.TabIndex = 2;
- this.statusBar.Text = "statusStrip1";
- // lblPosition
- this.lblPosition.Name = "lblPosition";
- this.lblPosition.Size = new System.Drawing.Size(0, 18);
- // lblSelected
- this.lblSelected.Name = "lblSelected";
- this.lblSelected.Size = new System.Drawing.Size(856, 18);
- this.lblSelected.Spring = true;
- this.lblSelected.TextAlign = System.Drawing.ContentAlignment.MiddleLeft;
- // lblScale
- this.lblScale.Name = "lblScale";
- this.lblScale.Size = new System.Drawing.Size(0, 18);
- // lblSize
- this.lblSize.Name = "lblSize";
- this.lblSize.Size = new System.Drawing.Size(0, 18);
- // lblLogo
- this.lblLogo.Image = global::MapViewerTest.Properties.Resources.PoweredBy_en;
- this.lblLogo.ImageScaling = System.Windows.Forms.ToolStripItemImageScaling.None;
- this.lblLogo.Name = "lblLogo";
- this.lblLogo.Size = new System.Drawing.Size(137, 18);
- // toolStripSeparator14
- this.toolStripSeparator14.Name = "toolStripSeparator14";
- this.toolStripSeparator14.Size = new System.Drawing.Size(151, 6);
- // toolStripSeparator7
- this.toolStripSeparator7.Name = "toolStripSeparator7";
- this.toolStripSeparator7.Size = new System.Drawing.Size(6, 25);
- // legendCtrl
- this.legendCtrl.Dock = System.Windows.Forms.DockStyle.Fill;
- this.legendCtrl.GroupContextMenu = null;
- this.legendCtrl.LayerContextMenu = null;
- this.legendCtrl.Location = new System.Drawing.Point(3, 3);
- this.legendCtrl.Name = "legendCtrl";
- this.legendCtrl.ShowTooltips = true;
- this.legendCtrl.Size = new System.Drawing.Size(235, 246);
- this.legendCtrl.TabIndex = 0;
- this.legendCtrl.ThemeCompressionLimit = 0;
- // propertiesCtrl
- this.propertiesCtrl.Dock = System.Windows.Forms.DockStyle.Fill;
- this.propertiesCtrl.Location = new System.Drawing.Point(3, 3);
- this.propertiesCtrl.Name = "propertiesCtrl";
- this.propertiesCtrl.Size = new System.Drawing.Size(235, 344);
- this.propertiesCtrl.TabIndex = 0;
- // mapViewer
- this.mapViewer.ContextMenuStrip = this.appContextMenu;
- this.mapViewer.ConvertTiledGroupsToNonTiled = true;
- this.mapViewer.Cursor = System.Windows.Forms.Cursors.Default;
- this.mapViewer.Dock = System.Windows.Forms.DockStyle.Fill;
- this.mapViewer.Location = new System.Drawing.Point(0, 0);
- this.mapViewer.Name = "mapViewer";
- this.mapViewer.PointPixelBuffer = 2;
- this.mapViewer.SelectionColor = System.Drawing.Color.Blue;
- this.mapViewer.Size = new System.Drawing.Size(495, 658);
- this.mapViewer.TabIndex = 0;
- this.mapViewer.Text = "mgMapViewer1";
- this.mapViewer.ZoomInFactor = 0.5;
- this.mapViewer.ZoomOutFactor = 2;
- this.mapViewer.PropertyChanged += new System.ComponentModel.PropertyChangedEventHandler(this.OnViewerPropertyChanged);
// toolStripButton1
this.toolStripButton1.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
@@ -612,6 +647,11 @@
this.toolStripButton1.Text = "Print";
this.toolStripButton1.ToolTipText = "Print";
+ // toolStripSeparator1
+ this.toolStripSeparator1.Name = "toolStripSeparator1";
+ this.toolStripSeparator1.Size = new System.Drawing.Size(6, 25);
// toolStripButton2
this.toolStripButton2.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
@@ -624,6 +664,11 @@
this.toolStripButton2.Text = "Copy map to clipboard";
this.toolStripButton2.ToolTipText = "Copy map to clipboard";
+ // toolStripSeparator2
+ this.toolStripSeparator2.Name = "toolStripSeparator2";
+ this.toolStripSeparator2.Size = new System.Drawing.Size(6, 25);
// toolStripButton3
this.toolStripButton3.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
@@ -660,17 +705,10 @@
this.toolStripButton5.Text = "Zoom Extents";
this.toolStripButton5.ToolTipText = "Zoom Extents";
- // toolStripButton14
+ // toolStripSeparator7
- this.toolStripButton14.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
- this.toolStripButton14.Enabled = false;
- this.toolStripButton14.Image = ((System.Drawing.Image)(resources.GetObject("toolStripButton14.Image")));
- this.toolStripButton14.ImageTransparentColor = System.Drawing.Color.Magenta;
- this.toolStripButton14.Name = "toolStripButton14";
- this.toolStripButton14.Size = new System.Drawing.Size(23, 22);
- this.mgToolButtonComponentInvoker1.SetTargetComponent(this.toolStripButton14, this.mgZoomNextComponent1);
- this.toolStripButton14.Text = "Zoom Next";
- this.toolStripButton14.ToolTipText = "Zoom Next";
+ this.toolStripSeparator7.Name = "toolStripSeparator7";
+ this.toolStripSeparator7.Size = new System.Drawing.Size(6, 25);
// toolStripButton13
@@ -684,6 +722,23 @@
this.toolStripButton13.Text = "Zoom Previous";
this.toolStripButton13.ToolTipText = "Zoom Previous";
+ // toolStripButton14
+ this.toolStripButton14.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ this.toolStripButton14.Enabled = false;
+ this.toolStripButton14.Image = ((System.Drawing.Image)(resources.GetObject("toolStripButton14.Image")));
+ this.toolStripButton14.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.toolStripButton14.Name = "toolStripButton14";
+ this.toolStripButton14.Size = new System.Drawing.Size(23, 22);
+ this.mgToolButtonComponentInvoker1.SetTargetComponent(this.toolStripButton14, this.mgZoomNextComponent1);
+ this.toolStripButton14.Text = "Zoom Next";
+ this.toolStripButton14.ToolTipText = "Zoom Next";
+ // toolStripSeparator3
+ this.toolStripSeparator3.Name = "toolStripSeparator3";
+ this.toolStripSeparator3.Size = new System.Drawing.Size(6, 25);
// toolStripButton6
this.toolStripButton6.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
@@ -732,6 +787,11 @@
this.toolStripButton9.Text = "Pan";
this.toolStripButton9.ToolTipText = "Pan";
+ // toolStripSeparator4
+ this.toolStripSeparator4.Name = "toolStripSeparator4";
+ this.toolStripSeparator4.Size = new System.Drawing.Size(6, 25);
// toolStripButton10
this.toolStripButton10.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
@@ -756,6 +816,11 @@
this.toolStripButton11.Text = "Refresh Map";
this.toolStripButton11.ToolTipText = "Refresh Map";
+ // toolStripSeparator5
+ this.toolStripSeparator5.Name = "toolStripSeparator5";
+ this.toolStripSeparator5.Size = new System.Drawing.Size(6, 25);
// toolStripButton12
this.toolStripButton12.Enabled = false;
@@ -767,6 +832,26 @@
this.toolStripButton12.Text = "Enable Tooltips";
this.toolStripButton12.ToolTipText = "Enable Tooltips";
+ // toolStripSeparator6
+ this.toolStripSeparator6.Name = "toolStripSeparator6";
+ this.toolStripSeparator6.Size = new System.Drawing.Size(6, 25);
+ // toolStripDropDownButton1
+ this.toolStripDropDownButton1.DropDownItems.AddRange(new System.Windows.Forms.ToolStripItem[] {
+ this.toolStripMenuItem9,
+ this.toolStripMenuItem10,
+ this.toolStripMenuItem11,
+ this.toolStripMenuItem27,
+ this.toolStripSeparator14,
+ this.toolStripMenuItem31});
+ this.toolStripDropDownButton1.Image = global::MapViewerTest.Properties.Resources.icon_tasks;
+ this.toolStripDropDownButton1.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.toolStripDropDownButton1.Name = "toolStripDropDownButton1";
+ this.toolStripDropDownButton1.Size = new System.Drawing.Size(65, 22);
+ this.toolStripDropDownButton1.Text = "Tools";
// toolStripMenuItem9
this.toolStripMenuItem9.Enabled = false;
@@ -804,6 +889,11 @@
this.toolStripMenuItem27.Text = "Theme";
this.toolStripMenuItem27.ToolTipText = "Theme";
+ // toolStripSeparator14
+ this.toolStripSeparator14.Name = "toolStripSeparator14";
+ this.toolStripSeparator14.Size = new System.Drawing.Size(151, 6);
// toolStripMenuItem31
this.toolStripMenuItem31.Enabled = false;
@@ -814,6 +904,23 @@
this.toolStripMenuItem31.Text = "Viewer Options";
this.toolStripMenuItem31.ToolTipText = "Viewer Options";
+ // toolStripSeparator8
+ this.toolStripSeparator8.Name = "toolStripSeparator8";
+ this.toolStripSeparator8.Size = new System.Drawing.Size(6, 25);
+ // toolStripDropDownButton2
+ this.toolStripDropDownButton2.DropDownItems.AddRange(new System.Windows.Forms.ToolStripItem[] {
+ this.toolStripMenuItem8,
+ this.toolStripMenuItem25,
+ this.toolStripMenuItem26});
+ this.toolStripDropDownButton2.Image = global::MapViewerTest.Properties.Resources.icon_tasks;
+ this.toolStripDropDownButton2.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.toolStripDropDownButton2.Name = "toolStripDropDownButton2";
+ this.toolStripDropDownButton2.Size = new System.Drawing.Size(78, 22);
+ this.toolStripDropDownButton2.Text = "Custom";
// toolStripMenuItem8
this.toolStripMenuItem8.Enabled = false;
@@ -844,6 +951,15 @@
this.toolStripMenuItem26.Text = "Profile";
this.toolStripMenuItem26.ToolTipText = "Profile this Map";
+ // lblLoading
+ this.lblLoading.Alignment = System.Windows.Forms.ToolStripItemAlignment.Right;
+ this.lblLoading.Image = global::MapViewerTest.Properties.Resources.icon_loading;
+ this.lblLoading.ImageScaling = System.Windows.Forms.ToolStripItemImageScaling.None;
+ this.lblLoading.Name = "lblLoading";
+ this.lblLoading.Size = new System.Drawing.Size(30, 22);
+ this.lblLoading.Visible = false;
// taskPane
this.taskPane.Dock = System.Windows.Forms.DockStyle.Fill;
@@ -852,6 +968,40 @@
this.taskPane.Size = new System.Drawing.Size(256, 658);
this.taskPane.TabIndex = 0;
+ // toolStrip1
+ this.toolStrip1.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
+ this.btnInitialTask,
+ this.taskMenu});
+ this.toolStrip1.Location = new System.Drawing.Point(0, 0);
+ this.toolStrip1.Name = "toolStrip1";
+ this.toolStrip1.Size = new System.Drawing.Size(256, 25);
+ this.toolStrip1.TabIndex = 1;
+ this.toolStrip1.Text = "toolStrip1";
+ // btnInitialTask
+ this.btnInitialTask.Image = global::MapViewerTest.Properties.Resources.icon_home;
+ this.btnInitialTask.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.btnInitialTask.Name = "btnInitialTask";
+ this.btnInitialTask.Size = new System.Drawing.Size(83, 22);
+ this.btnInitialTask.Text = "Initial Task";
+ this.btnInitialTask.Click += new System.EventHandler(this.btnInitialTask_Click);
+ // taskMenu
+ this.taskMenu.Alignment = System.Windows.Forms.ToolStripItemAlignment.Right;
+ this.taskMenu.DropDownItems.AddRange(new System.Windows.Forms.ToolStripItem[] {
+ this.toolStripMenuItem5,
+ this.toolStripMenuItem6,
+ this.toolStripMenuItem7,
+ this.toolStripMenuItem29});
+ this.taskMenu.Image = global::MapViewerTest.Properties.Resources.icon_tasks;
+ this.taskMenu.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.taskMenu.Name = "taskMenu";
+ this.taskMenu.Size = new System.Drawing.Size(68, 22);
+ this.taskMenu.Text = "Tasks";
// toolStripMenuItem5
this.toolStripMenuItem5.Enabled = false;
@@ -889,188 +1039,49 @@
this.toolStripMenuItem29.Text = "Theme";
this.toolStripMenuItem29.ToolTipText = "Theme";
- // toolStripMenuItem30
+ // statusBar
- this.toolStripMenuItem30.Image = global::MapViewerTest.Properties.Resources.map__arrow;
- this.toolStripMenuItem30.Name = "toolStripMenuItem30";
- this.toolStripMenuItem30.Size = new System.Drawing.Size(189, 22);
- this.mgMenuItemComponentInvoker1.SetTargetComponent(this.toolStripMenuItem30, this.mgLoadMapComponent1);
- this.toolStripMenuItem30.Text = "Load Sheboygan Map";
- this.toolStripMenuItem30.ToolTipText = "Load the Sheboygan Map";
+ this.statusBar.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
+ this.lblPosition,
+ this.lblSelected,
+ this.lblScale,
+ this.lblSize,
+ this.lblLogo});
+ this.statusBar.Location = new System.Drawing.Point(0, 707);
+ this.statusBar.Name = "statusBar";
+ this.statusBar.Size = new System.Drawing.Size(1008, 23);
+ this.statusBar.TabIndex = 2;
+ this.statusBar.Text = "statusStrip1";
- // toolStripMenuItem1
+ // lblPosition
- this.toolStripMenuItem1.Image = ((System.Drawing.Image)(resources.GetObject("toolStripMenuItem1.Image")));
- this.toolStripMenuItem1.Name = "toolStripMenuItem1";
- this.toolStripMenuItem1.Size = new System.Drawing.Size(189, 22);
- this.mgMenuItemComponentInvoker1.SetTargetComponent(this.toolStripMenuItem1, this.mgLoadPackageComponent1);
- this.toolStripMenuItem1.Text = "Load Package";
- this.toolStripMenuItem1.ToolTipText = "Load Package";
+ this.lblPosition.Name = "lblPosition";
+ this.lblPosition.Size = new System.Drawing.Size(0, 18);
- // toolStripMenuItem2
+ // lblSelected
- this.toolStripMenuItem2.Enabled = false;
- this.toolStripMenuItem2.Image = ((System.Drawing.Image)(resources.GetObject("toolStripMenuItem2.Image")));
- this.toolStripMenuItem2.Name = "toolStripMenuItem2";
- this.toolStripMenuItem2.Size = new System.Drawing.Size(154, 22);
- this.mgMenuItemComponentInvoker1.SetTargetComponent(this.toolStripMenuItem2, this.mgBufferComponent1);
- this.toolStripMenuItem2.Text = "Buffer";
+ this.lblSelected.Name = "lblSelected";
+ this.lblSelected.Size = new System.Drawing.Size(856, 18);
+ this.lblSelected.Spring = true;
+ this.lblSelected.TextAlign = System.Drawing.ContentAlignment.MiddleLeft;
+ // lblScale
- this.toolStripMenuItem3.Enabled = false;
- this.toolStripMenuItem3.Image = ((System.Drawing.Image)(resources.GetObject("toolStripMenuItem3.Image")));
- this.toolStripMenuItem3.Name = "toolStripMenuItem3";
- this.toolStripMenuItem3.Size = new System.Drawing.Size(154, 22);
- this.mgMenuItemComponentInvoker1.SetTargetComponent(this.toolStripMenuItem3, this.mgMeasureComponent1);
- this.toolStripMenuItem3.Text = "Measure";
+ this.lblScale.Name = "lblScale";
+ this.lblScale.Size = new System.Drawing.Size(0, 18);
- // toolStripMenuItem4
+ // lblSize
- this.toolStripMenuItem4.Enabled = false;
- this.toolStripMenuItem4.Image = ((System.Drawing.Image)(resources.GetObject("toolStripMenuItem4.Image")));
- this.toolStripMenuItem4.Name = "toolStripMenuItem4";
- this.toolStripMenuItem4.Size = new System.Drawing.Size(154, 22);
- this.mgMenuItemComponentInvoker1.SetTargetComponent(this.toolStripMenuItem4, this.mgQueryComponent1);
- this.toolStripMenuItem4.Text = "Query";
+ this.lblSize.Name = "lblSize";
+ this.lblSize.Size = new System.Drawing.Size(0, 18);
- // toolStripMenuItem28
+ // lblLogo
- this.toolStripMenuItem28.Enabled = false;
- this.toolStripMenuItem28.Image = ((System.Drawing.Image)(resources.GetObject("toolStripMenuItem28.Image")));
- this.toolStripMenuItem28.Name = "toolStripMenuItem28";
- this.toolStripMenuItem28.Size = new System.Drawing.Size(154, 22);
- this.mgMenuItemComponentInvoker1.SetTargetComponent(this.toolStripMenuItem28, this.mgThemeComponent1);
- this.toolStripMenuItem28.Text = "Theme";
- this.toolStripMenuItem28.ToolTipText = "Theme";
+ this.lblLogo.Image = global::MapViewerTest.Properties.Resources.PoweredBy_en;
+ this.lblLogo.ImageScaling = System.Windows.Forms.ToolStripItemImageScaling.None;
+ this.lblLogo.Name = "lblLogo";
+ this.lblLogo.Size = new System.Drawing.Size(137, 18);
- // toolStripMenuItem12
- this.toolStripMenuItem12.Enabled = false;
- this.toolStripMenuItem12.Image = ((System.Drawing.Image)(resources.GetObject("toolStripMenuItem12.Image")));
- this.toolStripMenuItem12.Name = "toolStripMenuItem12";
- this.toolStripMenuItem12.Size = new System.Drawing.Size(154, 22);
- this.mgMenuItemComponentInvoker1.SetTargetComponent(this.toolStripMenuItem12, this.mgViewerOptionsComponent1);
- this.toolStripMenuItem12.Text = "Viewer Options";
- this.toolStripMenuItem12.ToolTipText = "Viewer Options";
- // toolStripMenuItem13
- this.toolStripMenuItem13.Enabled = false;
- this.toolStripMenuItem13.Image = ((System.Drawing.Image)(resources.GetObject("toolStripMenuItem13.Image")));
- this.toolStripMenuItem13.Name = "toolStripMenuItem13";
- this.toolStripMenuItem13.Size = new System.Drawing.Size(171, 22);
- this.mgMenuItemComponentInvoker1.SetTargetComponent(this.toolStripMenuItem13, this.mgRefreshMapComponent1);
- this.toolStripMenuItem13.Text = "Refresh Map";
- this.toolStripMenuItem13.ToolTipText = "Refresh Map";
- // toolStripMenuItem14
- this.toolStripMenuItem14.Enabled = false;
- this.toolStripMenuItem14.Image = ((System.Drawing.Image)(resources.GetObject("toolStripMenuItem14.Image")));
- this.toolStripMenuItem14.Name = "toolStripMenuItem14";
- this.toolStripMenuItem14.Size = new System.Drawing.Size(171, 22);
- this.mgMenuItemComponentInvoker1.SetTargetComponent(this.toolStripMenuItem14, this.mgZoomInComponent1);
- this.toolStripMenuItem14.Text = "Zoom In";
- this.toolStripMenuItem14.ToolTipText = "Zoom In";
- // toolStripMenuItem15
- this.toolStripMenuItem15.Enabled = false;
- this.toolStripMenuItem15.Image = ((System.Drawing.Image)(resources.GetObject("toolStripMenuItem15.Image")));
- this.toolStripMenuItem15.Name = "toolStripMenuItem15";
- this.toolStripMenuItem15.Size = new System.Drawing.Size(171, 22);
- this.mgMenuItemComponentInvoker1.SetTargetComponent(this.toolStripMenuItem15, this.mgZoomOutComponent1);
- this.toolStripMenuItem15.Text = "Zoom Out";
- this.toolStripMenuItem15.ToolTipText = "Zoom Out";
- // toolStripMenuItem16
- this.toolStripMenuItem16.Enabled = false;
- this.toolStripMenuItem16.Image = ((System.Drawing.Image)(resources.GetObject("toolStripMenuItem16.Image")));
- this.toolStripMenuItem16.Name = "toolStripMenuItem16";
- this.toolStripMenuItem16.Size = new System.Drawing.Size(171, 22);
- this.mgMenuItemComponentInvoker1.SetTargetComponent(this.toolStripMenuItem16, this.mgZoomToSelectionComponent1);
- this.toolStripMenuItem16.Text = "Zoom to Selection";
- this.toolStripMenuItem16.ToolTipText = "Zoom to Selection";
- // toolStripMenuItem17
- this.toolStripMenuItem17.Enabled = false;
- this.toolStripMenuItem17.Image = ((System.Drawing.Image)(resources.GetObject("toolStripMenuItem17.Image")));
- this.toolStripMenuItem17.Name = "toolStripMenuItem17";
- this.toolStripMenuItem17.Size = new System.Drawing.Size(171, 22);
- this.mgMenuItemComponentInvoker1.SetTargetComponent(this.toolStripMenuItem17, this.mgInitialViewComponent1);
- this.toolStripMenuItem17.Text = "Zoom Extents";
- this.toolStripMenuItem17.ToolTipText = "Zoom Extents";
- // toolStripMenuItem18
- this.toolStripMenuItem18.Enabled = false;
- this.toolStripMenuItem18.Image = ((System.Drawing.Image)(resources.GetObject("toolStripMenuItem18.Image")));
- this.toolStripMenuItem18.Name = "toolStripMenuItem18";
- this.toolStripMenuItem18.Size = new System.Drawing.Size(171, 22);
- this.mgMenuItemComponentInvoker1.SetTargetComponent(this.toolStripMenuItem18, this.mgPanComponent1);
- this.toolStripMenuItem18.Text = "Pan";
- this.toolStripMenuItem18.ToolTipText = "Pan";
- // toolStripMenuItem19
- this.toolStripMenuItem19.Enabled = false;
- this.toolStripMenuItem19.Image = ((System.Drawing.Image)(resources.GetObject("toolStripMenuItem19.Image")));
- this.toolStripMenuItem19.Name = "toolStripMenuItem19";
- this.toolStripMenuItem19.Size = new System.Drawing.Size(171, 22);
- this.mgMenuItemComponentInvoker1.SetTargetComponent(this.toolStripMenuItem19, this.mgSelectComponent1);
- this.toolStripMenuItem19.Text = "Select";
- this.toolStripMenuItem19.ToolTipText = "Select";
- // toolStripMenuItem20
- this.toolStripMenuItem20.Enabled = false;
- this.toolStripMenuItem20.Image = ((System.Drawing.Image)(resources.GetObject("toolStripMenuItem20.Image")));
- this.toolStripMenuItem20.Name = "toolStripMenuItem20";
- this.toolStripMenuItem20.Size = new System.Drawing.Size(171, 22);
- this.mgMenuItemComponentInvoker1.SetTargetComponent(this.toolStripMenuItem20, this.mgClearSelectionComponent1);
- this.toolStripMenuItem20.Text = "Clear Selection";
- this.toolStripMenuItem20.ToolTipText = "Clear Selection";
- // toolStripMenuItem21
- this.toolStripMenuItem21.Enabled = false;
- this.toolStripMenuItem21.Image = ((System.Drawing.Image)(resources.GetObject("toolStripMenuItem21.Image")));
- this.toolStripMenuItem21.Name = "toolStripMenuItem21";
- this.toolStripMenuItem21.Size = new System.Drawing.Size(171, 22);
- this.mgMenuItemComponentInvoker1.SetTargetComponent(this.toolStripMenuItem21, this.mgBufferComponent1);
- this.toolStripMenuItem21.Text = "Buffer";
- // toolStripMenuItem22
- this.toolStripMenuItem22.Enabled = false;
- this.toolStripMenuItem22.Image = ((System.Drawing.Image)(resources.GetObject("toolStripMenuItem22.Image")));
- this.toolStripMenuItem22.Name = "toolStripMenuItem22";
- this.toolStripMenuItem22.Size = new System.Drawing.Size(171, 22);
- this.mgMenuItemComponentInvoker1.SetTargetComponent(this.toolStripMenuItem22, this.mgMeasureComponent1);
- this.toolStripMenuItem22.Text = "Measure";
- // toolStripMenuItem23
- this.toolStripMenuItem23.Enabled = false;
- this.toolStripMenuItem23.Image = ((System.Drawing.Image)(resources.GetObject("toolStripMenuItem23.Image")));
- this.toolStripMenuItem23.Name = "toolStripMenuItem23";
- this.toolStripMenuItem23.Size = new System.Drawing.Size(171, 22);
- this.mgMenuItemComponentInvoker1.SetTargetComponent(this.toolStripMenuItem23, this.mgQueryComponent1);
- this.toolStripMenuItem23.Text = "Query";
- // toolStripMenuItem24
- this.toolStripMenuItem24.Enabled = false;
- this.toolStripMenuItem24.Image = ((System.Drawing.Image)(resources.GetObject("toolStripMenuItem24.Image")));
- this.toolStripMenuItem24.Name = "toolStripMenuItem24";
- this.toolStripMenuItem24.Size = new System.Drawing.Size(171, 22);
- this.mgMenuItemComponentInvoker1.SetTargetComponent(this.toolStripMenuItem24, this.mgViewerOptionsComponent1);
- this.toolStripMenuItem24.Text = "Viewer Options";
- this.toolStripMenuItem24.ToolTipText = "Viewer Options";
// mgPrintComponent1
this.mgPrintComponent1.Icon = ((System.Drawing.Image)(resources.GetObject("mgPrintComponent1.Icon")));
@@ -1277,6 +1288,63 @@
this.mgLayerSelectionHandler1.Viewer = this.mapViewer;
this.mgLayerSelectionHandler1.SelectionMade += new OSGeo.MapGuide.Viewer.MgLayerSelectionEventHandler(this.mgLayerSelectionHandler1_SelectionMade);
+ // toolStripSplitButton1
+ this.toolStripSplitButton1.DropDownItems.AddRange(new System.Windows.Forms.ToolStripItem[] {
+ this.pointToolStripMenuItem,
+ this.lineToolStripMenuItem,
+ this.rectangleToolStripMenuItem,
+ this.lineStringToolStripMenuItem,
+ this.polygonToolStripMenuItem,
+ this.circleToolStripMenuItem});
+ this.toolStripSplitButton1.Image = global::MapViewerTest.Properties.Resources.icon_tasks;
+ this.toolStripSplitButton1.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.toolStripSplitButton1.Name = "toolStripSplitButton1";
+ this.toolStripSplitButton1.Size = new System.Drawing.Size(78, 22);
+ this.toolStripSplitButton1.Text = "Digitize";
+ // pointToolStripMenuItem
+ this.pointToolStripMenuItem.Name = "pointToolStripMenuItem";
+ this.pointToolStripMenuItem.Size = new System.Drawing.Size(152, 22);
+ this.pointToolStripMenuItem.Text = "Point";
+ this.pointToolStripMenuItem.Click += new System.EventHandler(this.pointToolStripMenuItem_Click);
+ // lineToolStripMenuItem
+ this.lineToolStripMenuItem.Name = "lineToolStripMenuItem";
+ this.lineToolStripMenuItem.Size = new System.Drawing.Size(152, 22);
+ this.lineToolStripMenuItem.Text = "Line";
+ this.lineToolStripMenuItem.Click += new System.EventHandler(this.lineToolStripMenuItem_Click);
+ // rectangleToolStripMenuItem
+ this.rectangleToolStripMenuItem.Name = "rectangleToolStripMenuItem";
+ this.rectangleToolStripMenuItem.Size = new System.Drawing.Size(152, 22);
+ this.rectangleToolStripMenuItem.Text = "Rectangle";
+ this.rectangleToolStripMenuItem.Click += new System.EventHandler(this.rectangleToolStripMenuItem_Click);
+ // lineStringToolStripMenuItem
+ this.lineStringToolStripMenuItem.Name = "lineStringToolStripMenuItem";
+ this.lineStringToolStripMenuItem.Size = new System.Drawing.Size(152, 22);
+ this.lineStringToolStripMenuItem.Text = "LineString";
+ this.lineStringToolStripMenuItem.Click += new System.EventHandler(this.lineStringToolStripMenuItem_Click);
+ // polygonToolStripMenuItem
+ this.polygonToolStripMenuItem.Name = "polygonToolStripMenuItem";
+ this.polygonToolStripMenuItem.Size = new System.Drawing.Size(152, 22);
+ this.polygonToolStripMenuItem.Text = "Polygon";
+ this.polygonToolStripMenuItem.Click += new System.EventHandler(this.polygonToolStripMenuItem_Click);
+ // circleToolStripMenuItem
+ this.circleToolStripMenuItem.Name = "circleToolStripMenuItem";
+ this.circleToolStripMenuItem.Size = new System.Drawing.Size(152, 22);
+ this.circleToolStripMenuItem.Text = "Circle";
+ this.circleToolStripMenuItem.Click += new System.EventHandler(this.circleToolStripMenuItem_Click);
// MgAppWindow
this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
@@ -1445,6 +1513,13 @@
private OSGeo.MapGuide.Viewer.MgZoomNextComponent mgZoomNextComponent1;
private System.Windows.Forms.ToolStripButton toolStripButton13;
private OSGeo.MapGuide.Viewer.MgZoomPreviousComponent mgZoomPreviousComponent1;
+ private System.Windows.Forms.ToolStripSplitButton toolStripSplitButton1;
+ private System.Windows.Forms.ToolStripMenuItem pointToolStripMenuItem;
+ private System.Windows.Forms.ToolStripMenuItem lineToolStripMenuItem;
+ private System.Windows.Forms.ToolStripMenuItem rectangleToolStripMenuItem;
+ private System.Windows.Forms.ToolStripMenuItem lineStringToolStripMenuItem;
+ private System.Windows.Forms.ToolStripMenuItem polygonToolStripMenuItem;
+ private System.Windows.Forms.ToolStripMenuItem circleToolStripMenuItem;
Modified: branches/2.4/MgDev/Desktop/MapViewerTest/MgAppWindow.cs
--- branches/2.4/MgDev/Desktop/MapViewerTest/MgAppWindow.cs 2012-06-27 12:01:50 UTC (rev 6824)
+++ branches/2.4/MgDev/Desktop/MapViewerTest/MgAppWindow.cs 2012-06-27 13:07:09 UTC (rev 6825)
@@ -130,5 +130,35 @@
var result = prof.ProfileRenderDynamicOverlay((MgdMap)map, (MgdSelection)mapViewer.GetSelection(), opts);
new XmlResponseDialog(result).ShowDialog();
+ private void pointToolStripMenuItem_Click(object sender, EventArgs e)
+ mapViewer.DigitizePoint((x, y) => { MessageBox.Show("Done"); }, "Custom point digitization prompt");
+ private void lineToolStripMenuItem_Click(object sender, EventArgs e)
+ mapViewer.DigitizeLine((x1, y1, x2, y2) => { MessageBox.Show("Done"); }, "Custom line digitization prompt");
+ private void rectangleToolStripMenuItem_Click(object sender, EventArgs e)
+ mapViewer.DigitizeRectangle((x1, y1, x2, y2) => { MessageBox.Show("Done"); }, "Custom rectangle digitization prompt");
+ private void lineStringToolStripMenuItem_Click(object sender, EventArgs e)
+ mapViewer.DigitizeLineString((coords) => { MessageBox.Show("Done"); }, "Custom line string digitization prompt");
+ private void polygonToolStripMenuItem_Click(object sender, EventArgs e)
+ mapViewer.DigitizePolygon((coords) => { MessageBox.Show("Done"); }, "Custom polygon digitization prompt");
+ private void circleToolStripMenuItem_Click(object sender, EventArgs e)
+ mapViewer.DigitizeCircle((x, y, r) => { MessageBox.Show("Done"); }, "Custom circle digitization prompt");
Modified: branches/2.4/MgDev/Desktop/MapViewerTest/MgAppWindow.resx
--- branches/2.4/MgDev/Desktop/MapViewerTest/MgAppWindow.resx 2012-06-27 12:01:50 UTC (rev 6824)
+++ branches/2.4/MgDev/Desktop/MapViewerTest/MgAppWindow.resx 2012-06-27 13:07:09 UTC (rev 6825)
@@ -120,65 +120,186 @@
<metadata name="appMenu.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
<value>17, 17</value>
</metadata>
+ <metadata name="mgMenuItemComponentInvoker1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>576, 95</value>
+ </metadata>
+ <metadata name="mgLoadMapComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>1081, 173</value>
+ </metadata>
+ <assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+ <data name="toolStripMenuItem1.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ R0lGODlhEAAQAIMAAAAAAP///ydYF5fYTmBfDJlmAGYzALWEU8yZZtSmeP/jyP///wAAAAAAAAAAAAAA
+ ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAALACwAAAAAEAAQAAAIcwAXCBxIcIGAgwUTGhQQAKHAAhAj
+ FiDAcMAAhBATINioAEFFixchKhhJUsFBARcPFtC4kWNLlAIMLFiZoGZNBTZhyixwoKdPBT51zvT5M+jF
+ nSWTmjy4k2hPoE6bOoVKVCpRqj6tFo0604DXr2DBKhwrMCAAOw==
+</value>
+ </data>
+ <metadata name="mgLoadPackageComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>1019, 95</value>
+ </metadata>
+ <data name="mgLoadPackageComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+</value>
+ </data>
<metadata name="appContextMenu.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
<value>338, 17</value>
</metadata>
- <metadata name="appToolbar.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>121, 17</value>
+ <data name="toolStripMenuItem2.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
+ YQUAAAAJcEhZcwAADrwAAA68AZW8ckkAAAFoSURBVDhPpVNdKwRRGN47jZ/g57hQJGSzmxSTUv4DF26F
+ tRa12JLaXVtKMimJ3ZKLsUyWbEImdsUwF37C4zwzTZ2z7a4pp956v57ned9zZiIRcbTJgy5NNzIduvGj
+ jRtVbcKYY461UIeAWNpC2qxj/swG/U7dgAz2REhMgUYRJhaKNmZSOfR0R5GtfKA3YSokJIwLYvbR6HNq
+ T4QEiyJJcGD520/0LfskNPrMsT6byiNTfgdX9gnEaKMbFgp3fkNgjGWTa4mSDQr7BGI/qvQnTezdqySM
+ m+XGNsUKQli5ZJIMJC+xX3WUSWRl1tjD3qYvxcLhg+OZDKTP3OCKD275vCwePX55JhMwHkqFAA+vlnH8
+ /K2AGTPfUjm4xKhoOn1RwYyZbzs2b3Nq+wYl21WUGY+s/QEOPqTsVU0Bn7+6iK2HAAcEuesalrYKHsnF
+ m4t4WHDwJU7vVHDy5GDXqoN+250b3/A/v/MvkqOAAMpRUaEAAAAASUVORK5CYII=
+</value>
+ </data>
+ <metadata name="mgBufferComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>1019, 134</value>
</metadata>
- <assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
- <data name="toolStripButton1.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="mgBufferComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAD3SURBVDhPlZNLCoMwEIY9V5B241lcFEorUnqsLrxAT9C1
- W9GF+EARRfDBlH/AEGsiduADSTLfTBJjWUoIIQLbtsmE7/ukrt98I3EvINiVQBBFkREkI4wSCOI41pIk
- CScuoZWEYUjDMGip65oFv8hzECcnsM8O6bh5D5amaboCHUsBEk2BuXEcKcsyyvNcIgWu63LlPQHWQNK2
- LZVlybBAbX1PgAKe/6RpmqiqKoYFmOi6jjGdgToPQdM0jBQURUFHQIF5nnkbQApwfUdYBH3fE5ACU+u6
- cXRgFOAQX+/PCoypoo3gn1u4XO+81eW14vUe+hNRxPSMv4YPeJAk7UvrAAAAAElFTkSuQmCC
</value>
</data>
- <metadata name="mgToolButtonComponentInvoker1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>183, 95</value>
+ <data name="toolStripMenuItem3.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAJcEhZcwAADrwAAA68AZW8ckkAAABjSURBVDhPY2AY+sDGxuY/Ob6A64MxiDUIQz1IgFwMdjlV
+ XEBRGJCjGUXPxCC2VfVBbP/QMVD8PzZxmBhIH9ggkMD/Fyn/F5ea/SeFBumDG/D9FNt/UjDIIrgBFHuB
+ 4kAccAMAwje0sEjeZewAAAAASUVORK5CYII=
+</value>
+ </data>
+ <metadata name="mgMeasureComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>412, 173</value>
</metadata>
- <metadata name="mgPrintComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>17, 95</value>
+ <data name="mgMeasureComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+</value>
+ </data>
+ <data name="toolStripMenuItem4.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAJcEhZcwAADrwAAA68AZW8ckkAAAHySURBVDhPnZPLSxtRFMb9T6rUTW3Ulmw0GhqMNk0wSqCO
+ YhnNIkZUjCKUgvj4C7rSlUtXQksKRUHQxk0XhYpF8IETkpiHjxiT0TgTI0nm6z0DloxJbOmFj3Mf5/7u
+ me8wVVVFY2hyasLmcPjr6l8o1TW1eKZrVGhN+8V5ZeedbznB1PEGS5+82No/xHd/QI1Ln71oNppgc3D+
+ ipCuHk74uLCIH4EQdiIx/GLaDkfx8zii6ujsHIPDI6C8EsjY+w8TbRYbdo7D2D89Qzx9A+nuTp3vxk7+
+ aDsYQqupDZSvgXRz/cLK6hqOzuOIiSIKioLrTAZC/AKH7OViLXu/oJt7UIWu4aVyEI0hnEwhm8tBYYAT
+ 8QrBxCUCD7QXieI5M1hTwZPqpwhfJnF6da1eTkqyCoimxBKFLhKg7mgAOkaMsIPEjaRepkg+lFOQ+UL5
+ GgD3jhfWv/kgypm/yvt1FZSvAUxPz3qaDUbI2Sxk5n45kTepdBpNhlZQfkkr+/oG/J7JKci3t8gVCiWS
+ WFdGx8bBDzhhbn+t9eCexvO88Ir12efbgsS8yOfzLErY2NiEocWI3t5+2O12uN3uypDZ+XkPgepZa6k7
+ FGlN+/SyXq+H1WqFy+WqDHnsp7mHWCwWOJ2PfM6/QMxm8/9VQXCqhDQzM4ffTfzkLal2r4sAAAAASUVO
+ RK5CYII=
+</value>
+ </data>
+ <metadata name="mgQueryComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>238, 173</value>
</metadata>
- <data name="mgPrintComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="mgQueryComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
+ RK5CYII=
</value>
</data>
- <data name="toolStripButton2.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="toolStripMenuItem28.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
+ R0lGODlhEAAQAIMAAAAAAP///6e6zXG39mCc0bzd+87trIC4QpfYTv/eStm9P//vqmdnZywsLP///wAA
+ ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAAOACwAAAAAEAAQAAAIeQAdCBxIsKADBggTIjQokIGBhxAb
+ MDxoAIFFBAckMnRoUaFCghwRMFhAsqTGhhVFLkjAMoGCkxQPHBjJ0qPCBjhpJmBQoKfPBgKCCtDJc4DR
+ AQRgjlSgoOjRpCBxNnBqFOpAoUMLHEUKE2QBAmDBdh3IQKrZiVixBgQAOw==
+</value>
+ </data>
+ <metadata name="mgThemeComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>903, 173</value>
+ </metadata>
+ <data name="mgThemeComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+</value>
+ </data>
+ <data name="toolStripMenuItem12.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
- YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAADgSURBVDhPhZPNCoJAFIV9spZtepfeoGWP2CaCKKQwNf9K
- 848b58IZdGqcC4cDjvfzm4XBar0RV7a7vQS+wbJrLuFNkEUGAOdrqPm0rdMG7/01wgG/RIDLCIAfCADh
- PdK0XacGNLIby5gZBAu3KNYQQCO7CZhBAIjiRNP1vRrQyG5eYdoBFuL0qSGARr7GrgLSLNf0w6AGNJr2
- I0nFjgFkRSkIATTytQEU1UuQYRzVgEa+NoB3XQtCAI3QeVk5YwB10whCAI18bQD8mQ7Hk16BRr5WgD14
- SCNfOwFLv7h99gUnGcVV+atLwAAAAABJRU5ErkJggg==
+ YQUAAAAJcEhZcwAADr0AAA69AUf7kK0AAAC0SURBVDhPrZPLCsIwEEXzXeKyS/0bQUFxISiKK8EH/TXF
+ QtRiKBaLSqyrkQnkgovCkBg4zFyYOYRAlIo9raSTtpMuhcC7ihfPuQGD2Yak8K4TxOAEoQc3OGQnkrI/
+ avJAkOmcepMV4CwBAn0x1J+u6fmyrvrMfRM8A0F+LX5enrMECExRUggQ3MqKhvMt4CwBgnv1oNFiR3X9
+ cdVn7pvgGQj48cbLFHCWAIG1bwrhP4LY3/gFpD/IGPp59QYAAAAASUVORK5CYII=
</value>
</data>
- <metadata name="mgCopyMapComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>17, 56</value>
+ <metadata name="mgViewerOptionsComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>17, 173</value>
</metadata>
- <data name="mgCopyMapComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="mgViewerOptionsComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
</value>
</data>
- <data name="toolStripButton3.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="toolStripMenuItem13.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
+ YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAGDSURBVDhPY2AAAifP4P+4MEieKAAy4Oev3ygYJAbSHJOc
+ /K2itnX/lClz5PEaBtLw6MlLOIYZYGnvATY4Pq3gT0Nr72yshoAkcktq/99/+AyrARu37jkPksvMr/yP
+ YQjIaSDTQQqAhqyHuQTmAnt/fwEnr5A1IG/ce/AM7BIU79Q0dh3fsmP//zUbdhx28gpeihywyM519Aye
+ D3LJlu37/oMMg8uBAglkclB48iUXl1B+mATMBTC+jXeUoH9owjmQWpAeuAHO3mFgfzt5hYJDHR/Q0tL6
+ A1IL0gNXB9JIkQEwL4Cch+wFWFjAbHJzCxECefPeg6eoXiiva9+3def+/xu27r7g6BW8AtkLsBQKMSx0
+ 1frNu44AA/I/KODh6nqmzpMFRQ0ocEChC/TSQpBtMBeAEhHIIFAUw6IRpAclrBrb+mZlFVT9BynYuG3P
+ eVDqgxkAS50gp2fkV/wHqcWZGkEuAWnAZgA4oKH5A2dMgZwG8gYsntHzB1GGYAtEbNkdpA4A8r5nBCK/
+ IMoAAAAASUVORK5CYII=
+</value>
+ </data>
+ <metadata name="mgRefreshMapComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>813, 95</value>
+ </metadata>
+ <data name="mgRefreshMapComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+</value>
+ </data>
+ <data name="toolStripMenuItem14.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAIESURBVDhPnZPNSxtRFMX9T2ppN7axH2SjqaGpsU0TjJJi
RhsZm0WaUqVRBCmIMX9BV3Xl0pWgpFAsFNS46aJQsRRqxQkx5sPPmIzGmRhJMsd3B6ZkTCPFgcN9783h
9+6cyzQ0VD2vR0aHHS5X9E7zA6Xx5m00Ge4rtKfzat8/1509nGB5+hzTc2GsrG/gWzSm1un5MFrNFjhc
@@ -209,7 +330,7 @@
JC4A2evLqnFhjAkAAAAASUVORK5CYII=
</value>
</data>
- <data name="toolStripButton4.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="toolStripMenuItem15.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAH5SURBVDhPnZPLSxtRFMb9T2qpm7ZRW7KpqaHBaNMEU0kx
@@ -242,8 +363,41 @@
AAAAAElFTkSuQmCC
</value>
</data>
- <data name="toolStripButton5.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="toolStripMenuItem16.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
+ R0lGODlhEAAQAIZvAISChAEBAXBJJai7zsfb8Nrn9M/a5Nnm81tgZNDh8sXa77jH16jR4+fu9dDh8brT
+ 7erv89jm8uzw9ODq9Ku0vNHh8mRrcvT3+aStttri6oOGiJqbncrc7oaKjZ+fn9Di6JSVl67C1a6yt5u2
+ 0F5cWsjd5IiOlM3U2Tg3N398ezAvLujjjKCnr5u83uXq73V5fnh3d+nv9OLaid/s76/N6pyzy9fn65mi
+ rLCurXahzJDO1tfb3+Do8dDg8UdKTb7L2EpMTFhYWZy20K22v6jG5KWqsaq8z+7sj7C/z6amp6C50uLr
+ 9evw9aTF52RgX250esjQ2ISAf2xtb7S3u+Tr8WBocMPT43yQo7vU7cbb7+Hr9JGRkt7m7YSFiL7H0cza
+ 6IWUo7bBzeqxd6uvs6uoqOLs9c7X31xbXbe/x+fs8evv84SHi8vY5XyPoq7L5wAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQB
+ AABvACwAAAAAEAAQAAAIwgABvBFIcOCbgwgTJsQRxUkKMgkFBpj4xsMULz/CFNmiMMCRNxugcEkTg8cX
+ JGsOSlyRRAQENRcaTIjAAQwIhAFkwDghIQMVLQd6KKhxxuBEEi6YsLFSoIKCB0RQKJSyo0GZAgmyMKAh
+ xIfBNwFMjFlywAEBBjqaXHmCcwaaLmYSEMDSIoeSKhSM2njDQsONEG5GtLGAIGGADyXeDOkQRAWQFxgQ
+ CBAjECxFAwuMLDDwZoAAAQpDI/RcsHToAaJTvwkIADs=
+</value>
+ </data>
+ <metadata name="mgZoomToSelectionComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>590, 134</value>
+ </metadata>
+ <data name="mgZoomToSelectionComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+</value>
+ </data>
+ <data name="toolStripMenuItem17.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAFqSURBVDhPpZPbTsJAEIZ5NaPxAXgI5UK50Qt9LmPSeBYQ
g2gFEWiVIsUWSjm2pdfjzOyyFbyrF1/+Ofwz2c1mMztb2bPd7SykgWYzNOj5k1TQLC+o6K1UqAXVmgHV
@@ -269,19 +423,232 @@
AeYbqBNEyxii5RKJIWRF4qTG/VjWf3l5wX+/8w9/3Qe1qQ/dtwAAAABJRU5ErkJggg==
</value>
</data>
+ <data name="toolStripMenuItem18.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAGTSURBVDhPlVNNSwJRFPV/tQpaiW1qFrmKICIqKMmICjIw
+ A4tIRCNpIFFKkUgMQ8FKyz4ohBBh3BlFH5vqL5w4F5/OqBsvHObjvnPeuWfe2Gz9F/qnNBlOp5NkNK/9
+ 6ZhI4qD1/PP7h/L9A7a29+BaWoN7xYPQgY584RJGva7sys49MT23iHn3KoL7Eby9f6B4UxaBiB4VwWg8
+ gcenZ2iaZhZrOxifnAXr8+sbL9UaGo1X0BWL9ywKsedwDHdnQAGOYCZWKhVxw1r3BeVKJ3TXHKMdIEfY
+ 2PTLzLRqJnJXFt+z9KMYKG6Jn9Z3A2EMDNqRSKXFjSJysXLGsXjPvDLZXPdZYOIUSaVzkj5BcRLNuC6W
+ MDo20RZgc2rGBWbBBkU4TufuSoSiFgF+LkItiB0nxSZHIQyj0eXCIjBkHwGD5DngzleluxZyhVtk80UJ
+ Vm3AnOjSEiTn8nj90qCbs2xBsjg5vUA8eS6o1gwEQrqsYcg9fwQ2uMC3E0boMNECiQvLXumZjnfvn0mJ
+ cDSCJAV+xk7WP7yJ9EN8DX7nAAAAAElFTkSuQmCC
+</value>
+ </data>
+ <metadata name="mgPanComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>581, 56</value>
+ </metadata>
+ <data name="mgPanComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+</value>
+ </data>
+ <data name="toolStripMenuItem19.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAACcSURBVDhPY2BMZZzJmMb4nywM1MsA0rjxRDMcv//y7D8I
+ I4vhYoP0YjXA0t6DKEPwGkCMIXgN+PPn739ChuA14NWb9/9BGJ8heA34+u37fxjGZQheA/6jAWyGEG0A
+ SDMMI0cxQQNAmkAAZjt6+iAYjcgGfPz6EiNxEUxIIBvRXYGcKrEaAFIAcyrZBqDnDZKikZhMBFMD8QKF
+ 2RkA39ChmP3112gAAAAASUVORK5CYII=
+</value>
+ </data>
+ <metadata name="mgSelectComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>17, 134</value>
+ </metadata>
+ <data name="mgSelectComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+</value>
+ </data>
+ <data name="toolStripMenuItem20.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAEOSURBVDhPY2CgANjY2PwnWztI8+aOgP8Mbs5B/0EYZBIx
+ bJi6TW2+/799eQ0xgBhnwNSBbN7Y6gPWfO5QL1F64ebDNH//+gaseeMMH+JdgE0zyCVEeQGk+dSpU/9B
+ 9PnDfWCbQZoJxkKMAoM5SNGZM2f+f//+/f+FCxfAmlA04wrEWCUGmwRVhjWbXBkgNp8//3/FihX/Gxsb
+ UW3GZUCCIsOTwz4M/3+lMPzf4wkxpKGhgbCzYUEep8qw6UYYw/+bwQz/dzoz/G/WgxiCEeU4vaDMMLHP
+ nOH/CjuG/32GDP+LtRn+xyow2BNtQAgDA2e8MsOMBBWGI0nqDPDUSkyiI00NqUkZqxdIzUzIhgAAH4zC
+ 0srGPRUAAAAASUVORK5CYII=
+</value>
+ </data>
+ <metadata name="mgClearSelectionComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>906, 17</value>
+ </metadata>
+ <data name="mgClearSelectionComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+</value>
+ </data>
+ <data name="toolStripMenuItem21.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+</value>
+ </data>
+ <data name="toolStripMenuItem22.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+</value>
+ </data>
+ <data name="toolStripMenuItem23.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ RK5CYII=
+</value>
+ </data>
+ <data name="toolStripMenuItem24.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+</value>
+ </data>
+ <metadata name="appToolbar.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>121, 17</value>
+ </metadata>
+ <data name="toolStripButton1.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAD3SURBVDhPlZNLCoMwEIY9V5B241lcFEorUnqsLrxAT9C1
+ W9GF+EARRfDBlH/AEGsiduADSTLfTBJjWUoIIQLbtsmE7/ukrt98I3EvINiVQBBFkREkI4wSCOI41pIk
+ CScuoZWEYUjDMGip65oFv8hzECcnsM8O6bh5D5amaboCHUsBEk2BuXEcKcsyyvNcIgWu63LlPQHWQNK2
+ LZVlybBAbX1PgAKe/6RpmqiqKoYFmOi6jjGdgToPQdM0jBQURUFHQIF5nnkbQApwfUdYBH3fE5ACU+u6
+ cXRgFOAQX+/PCoypoo3gn1u4XO+81eW14vUe+hNRxPSMv4YPeJAk7UvrAAAAAElFTkSuQmCC
+</value>
+ </data>
+ <metadata name="mgToolButtonComponentInvoker1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>183, 95</value>
+ </metadata>
+ <metadata name="mgPrintComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>17, 95</value>
+ </metadata>
+ <data name="mgPrintComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+</value>
+ </data>
+ <data name="toolStripButton2.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAADgSURBVDhPhZPNCoJAFIV9spZtepfeoGWP2CaCKKQwNf9K
+ 848b58IZdGqcC4cDjvfzm4XBar0RV7a7vQS+wbJrLuFNkEUGAOdrqPm0rdMG7/01wgG/RIDLCIAfCADh
+ PdK0XacGNLIby5gZBAu3KNYQQCO7CZhBAIjiRNP1vRrQyG5eYdoBFuL0qSGARr7GrgLSLNf0w6AGNJr2
+ I0nFjgFkRSkIATTytQEU1UuQYRzVgEa+NoB3XQtCAI3QeVk5YwB10whCAI18bQD8mQ7Hk16BRr5WgD14
+ SCNfOwFLv7h99gUnGcVV+atLwAAAAABJRU5ErkJggg==
+</value>
+ </data>
+ <metadata name="mgCopyMapComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>17, 56</value>
+ </metadata>
+ <data name="mgCopyMapComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+</value>
+ </data>
+ <data name="toolStripButton3.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAIESURBVDhPnZPNSxtRFMX9T2ppN7axH2SjqaGpsU0TjJJi
+ RhsZm0WaUqVRBCmIMX9BV3Xl0pWgpFAsFNS46aJQsRRqxQkx5sPPmIzGmRhJMsd3B6ZkTCPFgcN9783h
+ 9+6cyzQ0VD2vR0aHHS5X9E7zA6Xx5m00Ge4rtKfzat8/1509nGB5+hzTc2GsrG/gWzSm1un5MFrNFjhc
+ XLQupMvNCR8+TuF7LI61ZBo/mVYTKfzYTqra3NvHqzdvQb4ayNDY++F2mwNr2wms7+7hIH8K6fwcTzrs
+ +JXe+avVrTjaLO0gvw7SzXmE2YUv2Nw/QFoUUVEUnBQKKmCD3VytmfAndHOXujDce6j8SaWRyOZQLJWg
+ MMCOeKwCYpkjnX4nU7jLAtZ1cKPxFhJHWewen6CH68cLtwcu90sVQFVTKicifpgBTUcHMDBikr3InErI
+ SrJaKQcCUK3WFsuI/DoA188LX5cjEOWCTgS4fBb+vADy6wDj48FAq8kMuViEzNLXRABtTdnk8nm0mNpA
+ /ppR9vUNRAMjo5DPzlCqVGoksakMDr0DP+CFteOZPgONxvO88JjNORJZgcSyKJfLrEpYXFyC6ZEZvb0e
+ OJ1O+P3++pBgKBQgUDMbLU2HKu3pnG42Go2w2+3w+Xz1IVf9NBrEZrPB673ic/4HYrVar9cFwakT0sTE
+ JC4A2evLqnFhjAkAAAAASUVORK5CYII=
+</value>
+ </data>
+ <data name="toolStripButton4.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAH5SURBVDhPnZPLSxtRFMb9T2qpm7ZRW7KpqaHBaNMEU0kx
+ o42MZpGmqDSKIIL4+Atc6cplVwUlhWKhoMaNi0LFUvCBE5KYh48Yk9E4EyNJ5vOegJIxiS0d+Dj33vn4
+ 3TPfYWpqSp4PwyNDFpvN/6T+mVL7sA6PNY0K7em81Fdx3d7JCYa2N5hf8GJtexfr/kCxzi960aQ3wGLj
+ /FUhb+2cMDM7h5+BEDYjMfxm2ghH8Ws/UtTe0TH6PvaDfGWQwdGxoRaTBZv7YWwfHiGevoB0dVVc/4kd
+ 3GojGEKzoQXkV0E6OIfwZek79o7jiIkiCoqC80wGQvwEu+zmUn32fkUHd6cLTcNzZScaQziZQjaXg8IA
+ B+IZgolTBO5oKxLFUxawqoMHtY8QPk3i8OwcnVwP3tkdsNnflymaEhE6SYCmowJoGDHCXiQuJCQluVgp
+ h0oKslzIrwJwPbzwY9UHUc78Vd5vSyC/CjA+Pulp0ukhZ7OQWfqVRNmk0mm80DWD/GWj7O7u9XuGRyBf
+ XiJXKJRJYlMZGPwEvtcJY+trdQY3NJ7nhVdszj7fGiSWRT6fZ1XC8vIKdC/16OpywGq1wu12V4dMTk97
+ CFTPRkvToUp7OqebtVotzGYzXC5Xdch9P80NxGQywem853P+BWI0Gv+vC4JTJ6SJiSlcA6LH15rL3j8W
+ AAAAAElFTkSuQmCC
+</value>
+ </data>
+ <data name="toolStripButton5.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAFqSURBVDhPpZPbTsJAEIZ5NaPxAXgI5UK50Qt9LmPSeBYQ
+ g2gFEWiVIsUWSjm2pdfjzOyyFbyrF1/+Ofwz2c1mMztb2bPd7SykgWYzNOj5k1TQLC+o6K1UqAXVmgHV
+ Whsh3Yhf23+uJ7yizifQGx/w8kaYoKOu0cAakts7Uot09pnJgnqzA2u0MCdk/Vy7Y3Nu/5i13vrknjpB
+ 0/iCpokYXQHFTBe0yyIbtYsCvGNOMSnNqAWm1QezYyOoGBsE5lfXJTaRmpbsr3zoVQss2wGr54JlIz2K
+ Hbi5f2TDLSr1OrLOPo7dZIHteEDQAGmx9MRxoVThXDAU+i3yvvTzK7hDH1xvzEP5gxPWh/IzDLDmeqJH
+ DCgekgrUFfzxDEbjqXqm/OEp5z4yot6EFFmp7KkF0/kCiM3/MJ0HXBesYqmzIDnBIgxhEUYQICIWeQLm
+ AeYbqBNEyxii5RKJIWRF4qTG/VjWf3l5wX+/8w9/3Qe1qQ/dtwAAAABJRU5ErkJggg==
+</value>
+ </data>
<data name="toolStripButton13.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAIWSURBVDhPnZNbaxNREMf3i9TGW0WbeosPQi/RJBoSGiWg
- 21LZmocYRCGpdyitfVD0xTfBFxH6DQSl+CCCILFCRX3xoZuiaRKj1babJptsLrv7d+ZAoJekiAPDnHN2
- 5nfm/IeVpHV2aex6IhgOpw70HLYdO/dgv/OQzXs+X5/Xcj14TlY9/iCmX8zg3XwKyYVvIk6/nEGv24Ng
- WE61hZw5L6sXL1/B3Pc0PmVy+Ez+cTGLuXQGC7+XUTQMPHn6DJy3BXL11p2ELzCIL5ksvuZ/YqlYgl6r
- iXV6ZRV108TRY8dFHPD4wPkbIGflEfX56zeY/7WEnKbBsm2sVSrIF9bQsCxRzM5mEkTTNGsDwHnwiK1S
- 8SLdVm00YBPgh1aAUa+Lwh2du1p6V1f3IwHqdOxGdlUTN3Lxil4WgGVdh7mpA/5ukB5cx2CCPJacNLI8
- Ffwp6aKYI+vAXqgY4kncCcccdXnv/gO7+QSGSPIFRX2bfA+tXGnperWGhmmB4yvSivObgI4OR1EaH5+M
- 9/WfQIlaK5P67bxIwvb2ucH5TcDefd0PxXp4eDR14+ZtVEk4Vn6z83k8cQ3KaARe32mhwRZTFEU96TmF
- 2dkPaNA02Dgm6Xn9A24MDY0gFAohFou1h0xOTcUZ1EOj5elw5D2f880ulwuBQADRaLQ9ZLufpgnx+/2I
- RLZ5zr9AvF7v/3XBcO6EfWLiLv4CUX/gaLRksWEAAAAASUVORK5CYII=
+ YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAIXSURBVDhPnZNbaxNREMf3i9TUW0WbeosPQi/RJBoSGiWg
+ 21LZmocYRCGp2iqUXqBFfPFN8EWEfgNBKT6IIEisUFFffOimaJrEaLXdTZNNNsle/p45EOglKdKBYc45
+ O/M7c/7DCsImuzFyNxEMh1PHuk7a7fsP4ajzhE17Ot+c13Tdf0WUPf4g5l7O4/1SCsnl7zzOvZpHt9uD
+ YFhMtYRcuirK12/ewuKPND5ncvjC/NNKFovpDJb/rKGo63j67Dkobwfk9tiDhC/Qj6+ZLL7lf2G1WIJW
+ q/F1el1B3TRx+sxZHvs8PlD+FshlcUh+8eYtln6vIqeqsGwbG5UK8oUNGJbFi8nJTAZRFMXaAnAeP2XL
+ rHiF3VY1DNgM8FMtQK/XeeE+x4Gm3tHR+ZiDHO0HkVVUfiMVr2tlDljTNJjbOqDvOtOD6gjMIE8EJxtZ
+ nhX8LWm8mCLpQF6o6PxJ1AnFHOtyZvah3XgCQQTxmiS/S36AWq40da1ag2FaoPiaaUX5DUBbm6MojI9P
+ xnt6z6HEWisz9Vt5kQnb3eMG5TcAh490PuLrwcHh1L3R+6gy4Uj57U7n8cQdSMMReH0XuQY7TJIk+bzn
+ AhYWPsJg0yCjmGTP6+1zY2BgCKFQCLFYrDVkcno6TqAuNlqaDkXa0znd7HK5EAgEEI1GW0N2+2kaEL/f
+ j0hkl+f8D8Tr9e6tC4JTJ+QTE1P4B0Dj4GE2TdATAAAAAElFTkSuQmCC
</value>
</data>
<metadata name="mgZoomPreviousComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
@@ -290,29 +657,29 @@
<data name="mgZoomPreviousComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
</value>
</data>
<data name="toolStripButton14.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAGQSURBVDhPrVPLTsJQEOUvjN/BAhIeG8W/kMRgKpEfgJ2G
- vUEjD/kFtrpywcbELjDoClATxWflUTB93rY4zlxpUgMFF05y0mk758yZ6W0g4IloNJpHvCK+pqA8762Z
- m8disdVwOPy2nU6r56Jo3nSf4PrhEc7qdba5taPRO6rxFaKuhXJFv/3oAaE7lOG+1+d5+12Cg8KhQTWu
- QDweB4TA78liKpXS7yQJiUMwLAso+ooCzLY5THzW7nQmtVrtlDhTgR8RslcXRfYsj8DEYgrLcYAhCqUS
- FS0EOYAXWYaBqnKyjcQedj8ql5eSSZwLSKMxDFUNVMb4daConFysnIA9mXBYtgOtVgtmRqDlXDYa7FPX
- wQsScJDoPrvAMd1F/lpiJBLZ381kNMUwQEMH8zDG8TaTScv3TNAiK9WqoaALWp4XKgofF4t8pPXEBh9h
- JkKh0ArZEwRBv2o2mWGaQKA8iZ3dL5HNZv1FSJXGmXeUqXMwGOQulor4Hdd/F8nlcovH+YsT36Uu+32J
- SFhLJPa+AcvEqpIKE7rWAAAAAElFTkSuQmCC
+ YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAGQSURBVDhPrVPLTsJQEOUvjN/BAhIeG8WvkMQEUSI/ADsN
+ eyVGKHwDW125YGEiJBiiqxI1UXxWHgXT522L48yVJjVQcOEkJ522c86cmd4GAp6IRqMFxCviawrKC96a
+ uXksFlsNh8Nv25mMet5smjfdJ7h+eISzep1tbu1q9I5qfIWoa1Go6LcfPSB0hzLc9/o877xLcHhUNKjG
+ FYjH44DY4fdkMZVK6XeShMQhGJYFFH1FAWbbHCY+EzudSa1WOyXOVOBHhOzVGw32LI/AxGIKy3GAIYrl
+ MhUtBDmAF1mGgapyso3EHnY/FoSlZBLnAtJoDENVA5Uxfh0oKieXKlWwJxMOy3ZAFEWYGYGWc9lqsU9d
+ By9IwEGi++wCx3QX+WuJkUjkYC+b1RTDAA0dzMMYx9tMJi3fM0GLFKpVQ0EXtDwvVBQ+KZX4SOuJDT7C
+ TIRCoRWyl06n9at2mxmmCQTKk9jZ/RK5XM5fhFRpnHlHmToHg0HuYqmI33H9d5F8Pr94nL848V3qst+X
+ iIS1RGL/G4UHqnEre6t4AAAAAElFTkSuQmCC
</value>
</data>
<metadata name="mgZoomNextComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
@@ -321,14 +688,14 @@
<data name="mgZoomNextComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
</value>
</data>
<data name="toolStripButton6.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -340,18 +707,6 @@
</value>
</data>
- <metadata name="mgSelectComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>17, 134</value>
- </metadata>
- <data name="mgSelectComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
- YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAACcSURBVDhPY2BMZZzJmMb4nywM1MsA0rjxRDMcv//y7D8I
- I4vhYoP0YjXA0t6DKEPwGkCMIXgN+PPn739ChuA14NWb9/9BGJ8heA34+u37fxjGZQheA/6jAWyGEG0A
- SDMMI0cxQQNAmkAAZjt6+iAYjcgGfPz6EiNxEUxIIBvRXYGcKrEaAFIAcyrZBqDnDZKikZhMBFMD8QKF
- 2RkA39ChmP3112gAAAAASUVORK5CYII=
-</value>
- </data>
<data name="toolStripButton7.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
@@ -413,22 +768,6 @@
</value>
</data>
- <metadata name="mgPanComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>581, 56</value>
- </metadata>
- <data name="mgPanComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAGTSURBVDhPlVNNSwJRFPV/tQpaiW1qFrmKICIqKMmICjIw
- A4tIRCNpIFFKkUgMQ8FKyz4ohBBh3BlFH5vqL5w4F5/OqBsvHObjvnPeuWfe2Gz9F/qnNBlOp5NkNK/9
- 6ZhI4qD1/PP7h/L9A7a29+BaWoN7xYPQgY584RJGva7sys49MT23iHn3KoL7Eby9f6B4UxaBiB4VwWg8
- gcenZ2iaZhZrOxifnAXr8+sbL9UaGo1X0BWL9ywKsedwDHdnQAGOYCZWKhVxw1r3BeVKJ3TXHKMdIEfY
- 2PTLzLRqJnJXFt+z9KMYKG6Jn9Z3A2EMDNqRSKXFjSJysXLGsXjPvDLZXPdZYOIUSaVzkj5BcRLNuC6W
- MDo20RZgc2rGBWbBBkU4TufuSoSiFgF+LkItiB0nxSZHIQyj0eXCIjBkHwGD5DngzleluxZyhVtk80UJ
- Vm3AnOjSEiTn8nj90qCbs2xBsjg5vUA8eS6o1gwEQrqsYcg9fwQ2uMC3E0boMNECiQvLXumZjnfvn0mJ
- cDSCJAV+xk7WP7yJ9EN8DX7nAAAAAElFTkSuQmCC
-</value>
- </data>
<data name="toolStripButton10.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
@@ -440,20 +779,6 @@
</value>
</data>
- <metadata name="mgClearSelectionComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>906, 17</value>
- </metadata>
- <data name="mgClearSelectionComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAEOSURBVDhPY2CgANjY2PwnWztI8+aOgP8Mbs5B/0EYZBIx
- bJi6TW2+/799eQ0xgBhnwNSBbN7Y6gPWfO5QL1F64ebDNH//+gaseeMMH+JdgE0zyCVEeQGk+dSpU/9B
- 9PnDfWCbQZoJxkKMAoM5SNGZM2f+f//+/f+FCxfAmlA04wrEWCUGmwRVhjWbXBkgNp8//3/FihX/Gxsb
- UW3GZUCCIsOTwz4M/3+lMPzf4wkxpKGhgbCzYUEep8qw6UYYw/+bwQz/dzoz/G/WgxiCEeU4vaDMMLHP
- nOH/CjuG/32GDP+LtRn+xyow2BNtQAgDA2e8MsOMBBWGI0nqDPDUSkyiI00NqUkZqxdIzUzIhgAAH4zC
- 0srGPRUAAAAASUVORK5CYII=
-</value>
- </data>
<data name="toolStripButton11.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
@@ -467,22 +792,6 @@
</value>
</data>
- <metadata name="mgRefreshMapComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>813, 95</value>
- </metadata>
- <data name="mgRefreshMapComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAGDSURBVDhPY2AAAifP4P+4MEieKAAy4Oev3ygYJAbSHJOc
- /K2itnX/lClz5PEaBtLw6MlLOIYZYGnvATY4Pq3gT0Nr72yshoAkcktq/99/+AyrARu37jkPksvMr/yP
- YQjIaSDTQQqAhqyHuQTmAnt/fwEnr5A1IG/ce/AM7BIU79Q0dh3fsmP//zUbdhx28gpeihywyM519Aye
- D3LJlu37/oMMg8uBAglkclB48iUXl1B+mATMBTC+jXeUoH9owjmQWpAeuAHO3mFgfzt5hYJDHR/Q0tL6
- A1IL0gNXB9JIkQEwL4Cch+wFWFjAbHJzCxECefPeg6eoXiiva9+3def+/xu27r7g6BW8AtkLsBQKMSx0
- 1frNu44AA/I/KODh6nqmzpMFRQ0ocEChC/TSQpBtMBeAEhHIIFAUw6IRpAclrBrb+mZlFVT9BynYuG3P
- eVDqgxkAS50gp2fkV/wHqcWZGkEuAWnAZgA4oKH5A2dMgZwG8gYsntHzB1GGYAtEbNkdpA4A8r5nBCK/
- IMoAAAAASUVORK5CYII=
-</value>
- </data>
<data name="toolStripButton12.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
@@ -509,9 +818,6 @@
<metadata name="toolStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
<value>600, 173</value>
</metadata>
- <metadata name="statusBar.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>237, 17</value>
- </metadata>
<data name="toolStripMenuItem9.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
@@ -524,24 +830,6 @@
</value>
</data>
- <metadata name="mgMenuItemComponentInvoker1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>576, 95</value>
- </metadata>
- <metadata name="mgBufferComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>1019, 134</value>
- </metadata>
- <data name="mgBufferComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- YQUAAAAJcEhZcwAADrwAAA68AZW8ckkAAAFoSURBVDhPpVNdKwRRGN47jZ/g57hQJGSzmxSTUv4DF26F
- tRa12JLaXVtKMimJ3ZKLsUyWbEImdsUwF37C4zwzTZ2z7a4pp956v57ned9zZiIRcbTJgy5NNzIduvGj
- jRtVbcKYY461UIeAWNpC2qxj/swG/U7dgAz2REhMgUYRJhaKNmZSOfR0R5GtfKA3YSokJIwLYvbR6HNq
- T4QEiyJJcGD520/0LfskNPrMsT6byiNTfgdX9gnEaKMbFgp3fkNgjGWTa4mSDQr7BGI/qvQnTezdqySM
- m+XGNsUKQli5ZJIMJC+xX3WUSWRl1tjD3qYvxcLhg+OZDKTP3OCKD275vCwePX55JhMwHkqFAA+vlnH8
- /K2AGTPfUjm4xKhoOn1RwYyZbzs2b3Nq+wYl21WUGY+s/QEOPqTsVU0Bn7+6iK2HAAcEuesalrYKHsnF
- m4t4WHDwJU7vVHDy5GDXqoN+250b3/A/v/MvkqOAAMpRUaEAAAAASUVORK5CYII=
-</value>
- </data>
<data name="toolStripMenuItem10.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
@@ -550,17 +838,6 @@
</value>
</data>
- <metadata name="mgMeasureComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>412, 173</value>
- </metadata>
- <data name="mgMeasureComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- YQUAAAAJcEhZcwAADrwAAA68AZW8ckkAAABjSURBVDhPY2AY+sDGxuY/Ob6A64MxiDUIQz1IgFwMdjlV
- XEBRGJCjGUXPxCC2VfVBbP/QMVD8PzZxmBhIH9ggkMD/Fyn/F5ea/SeFBumDG/D9FNt/UjDIIrgBFHuB
- 4kAccAMAwje0sEjeZewAAAAASUVORK5CYII=
-</value>
- </data>
<data name="toolStripMenuItem11.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
@@ -576,24 +853,6 @@
RK5CYII=
</value>
</data>
- <metadata name="mgQueryComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>238, 173</value>
- </metadata>
- <data name="mgQueryComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- YQUAAAAJcEhZcwAADrwAAA68AZW8ckkAAAHySURBVDhPnZPLSxtRFMb9T6rUTW3Ulmw0GhqMNk0wSqCO
- YhnNIkZUjCKUgvj4C7rSlUtXQksKRUHQxk0XhYpF8IETkpiHjxiT0TgTI0nm6z0DloxJbOmFj3Mf5/7u
- me8wVVVFY2hyasLmcPjr6l8o1TW1eKZrVGhN+8V5ZeedbznB1PEGS5+82No/xHd/QI1Ln71oNppgc3D+
- ipCuHk74uLCIH4EQdiIx/GLaDkfx8zii6ujsHIPDI6C8EsjY+w8TbRYbdo7D2D89Qzx9A+nuTp3vxk7+
- aDsYQqupDZSvgXRz/cLK6hqOzuOIiSIKioLrTAZC/AKH7OViLXu/oJt7UIWu4aVyEI0hnEwhm8tBYYAT
- 8QrBxCUCD7QXieI5M1hTwZPqpwhfJnF6da1eTkqyCoimxBKFLhKg7mgAOkaMsIPEjaRepkg+lFOQ+UL5
- GgD3jhfWv/kgypm/yvt1FZSvAUxPz3qaDUbI2Sxk5n45kTepdBpNhlZQfkkr+/oG/J7JKci3t8gVCiWS
- WFdGx8bBDzhhbn+t9eCexvO88Ir12efbgsS8yOfzLErY2NiEocWI3t5+2O12uN3uypDZ+XkPgepZa6k7
- FGlN+/SyXq+H1WqFy+WqDHnsp7mHWCwWOJ2PfM6/QMxm8/9VQXCqhDQzM4ffTfzkLal2r4sAAAAASUVO
- RK5CYII=
-</value>
- </data>
<data name="toolStripMenuItem27.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
@@ -602,38 +861,15 @@
</value>
</data>
- <metadata name="mgThemeComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>903, 173</value>
- </metadata>
- <data name="mgThemeComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- R0lGODlhEAAQAIMAAAAAAP///6e6zXG39mCc0bzd+87trIC4QpfYTv/eStm9P//vqmdnZywsLP///wAA
- ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAAOACwAAAAAEAAQAAAIeQAdCBxIsKADBggTIjQokIGBhxAb
- MDxoAIFFBAckMnRoUaFCghwRMFhAsqTGhhVFLkjAMoGCkxQPHBjJ0qPCBjhpJmBQoKfPBgKCCtDJc4DR
- AQRgjlSgoOjRpCBxNnBqFOpAoUMLHEUKE2QBAmDBdh3IQKrZiVixBgQAOw==
-</value>
- </data>
<data name="toolStripMenuItem31.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAJcEhZcwAADr4AAA6+AepCscAAAAC0SURBVDhPrZPLCsIwEEXzXeKyS/0bQUFxISiKK8EH/TXF
</value>
</data>
- <metadata name="mgViewerOptionsComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>17, 173</value>
- </metadata>
- <data name="mgViewerOptionsComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- QtRiKBaLSqyrkQnkgovCkBg4zFyYOYRAlIo9raSTtpMuhcC7ihfPuQGD2Yak8K4TxOAEoQc3OGQnkrI/
- avJAkOmcepMV4CwBAn0x1J+u6fmyrvrMfRM8A0F+LX5enrMECExRUggQ3MqKhvMt4CwBgnv1oNFiR3X9
- cdVn7pvgGQj48cbLFHCWAIG1bwrhP4LY3/gFpD/IGPp59QYAAAAASUVORK5CYII=
-</value>
- </data>
<data name="toolStripMenuItem8.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
@@ -770,245 +1006,9 @@
</value>
</data>
- <metadata name="mgLoadMapComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>1081, 173</value>
+ <metadata name="statusBar.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>237, 17</value>
</metadata>
- <data name="toolStripMenuItem1.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- R0lGODlhEAAQAIMAAAAAAP///ydYF5fYTmBfDJlmAGYzALWEU8yZZtSmeP/jyP///wAAAAAAAAAAAAAA
- ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAALACwAAAAAEAAQAAAIcwAXCBxIcIGAgwUTGhQQAKHAAhAj
- FiDAcMAAhBATINioAEFFixchKhhJUsFBARcPFtC4kWNLlAIMLFiZoGZNBTZhyixwoKdPBT51zvT5M+jF
- nSWTmjy4k2hPoE6bOoVKVCpRqj6tFo0604DXr2DBKhwrMCAAOw==
-</value>
- </data>
- <metadata name="mgLoadPackageComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>1019, 95</value>
- </metadata>
- <data name="mgLoadPackageComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
-</value>
- </data>
- <data name="toolStripMenuItem2.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
-</value>
- </data>
- <data name="toolStripMenuItem3.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
-</value>
- </data>
- <data name="toolStripMenuItem4.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- RK5CYII=
-</value>
- </data>
- <data name="toolStripMenuItem28.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
-</value>
- </data>
- <data name="toolStripMenuItem12.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
-</value>
- </data>
- <data name="toolStripMenuItem13.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
-</value>
- </data>
- <data name="toolStripMenuItem14.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAIESURBVDhPnZPNSxtRFMX9T2ppN7axH2SjqaGpsU0TjJJi
- RhsZm0WaUqVRBCmIMX9BV3Xl0pWgpFAsFNS46aJQsRRqxQkx5sPPmIzGmRhJMsd3B6ZkTCPFgcN9783h
- 9+6cyzQ0VD2vR0aHHS5X9E7zA6Xx5m00Ge4rtKfzat8/1509nGB5+hzTc2GsrG/gWzSm1un5MFrNFjhc
- XLQupMvNCR8+TuF7LI61ZBo/mVYTKfzYTqra3NvHqzdvQb4ayNDY++F2mwNr2wms7+7hIH8K6fwcTzrs
- +JXe+avVrTjaLO0gvw7SzXmE2YUv2Nw/QFoUUVEUnBQKKmCD3VytmfAndHOXujDce6j8SaWRyOZQLJWg
- MMCOeKwCYpkjnX4nU7jLAtZ1cKPxFhJHWewen6CH68cLtwcu90sVQFVTKicifpgBTUcHMDBikr3InErI
- SrJaKQcCUK3WFsuI/DoA188LX5cjEOWCTgS4fBb+vADy6wDj48FAq8kMuViEzNLXRABtTdnk8nm0mNpA
- /ppR9vUNRAMjo5DPzlCqVGoksakMDr0DP+CFteOZPgONxvO88JjNORJZgcSyKJfLrEpYXFyC6ZEZvb0e
- OJ1O+P3++pBgKBQgUDMbLU2HKu3pnG42Go2w2+3w+Xz1IVf9NBrEZrPB673ic/4HYrVar9cFwakT0sTE
- JC4A2evLqnFhjAkAAAAASUVORK5CYII=
-</value>
- </data>
- <data name="toolStripMenuItem15.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAH5SURBVDhPnZPLSxtRFMb9T2qpm7ZRW7KpqaHBaNMEU0kx
- o42MZpGmqDSKIIL4+Atc6cplVwUlhWKhoMaNi0LFUvCBE5KYh48Yk9E4EyNJ5vOegJIxiS0d+Dj33vn4
- 3TPfYWpqSp4PwyNDFpvN/6T+mVL7sA6PNY0K7em81Fdx3d7JCYa2N5hf8GJtexfr/kCxzi960aQ3wGLj
- /FUhb+2cMDM7h5+BEDYjMfxm2ghH8Ws/UtTe0TH6PvaDfGWQwdGxoRaTBZv7YWwfHiGevoB0dVVc/4kd
- 3GojGEKzoQXkV0E6OIfwZek79o7jiIkiCoqC80wGQvwEu+zmUn32fkUHd6cLTcNzZScaQziZQjaXg8IA
- B+IZgolTBO5oKxLFUxawqoMHtY8QPk3i8OwcnVwP3tkdsNnflymaEhE6SYCmowJoGDHCXiQuJCQluVgp
- h0oKslzIrwJwPbzwY9UHUc78Vd5vSyC/CjA+Pulp0ukhZ7OQWfqVRNmk0mm80DWD/GWj7O7u9XuGRyBf
- XiJXKJRJYlMZGPwEvtcJY+trdQY3NJ7nhVdszj7fGiSWRT6fZ1XC8vIKdC/16OpywGq1wu12V4dMTk97
- CFTPRkvToUp7OqebtVotzGYzXC5Xdch9P80NxGQywem853P+BWI0Gv+vC4JTJ6SJiSlcA6LH15rL3j8W
- AAAAAElFTkSuQmCC
-</value>
- </data>
- <data name="toolStripMenuItem16.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- R0lGODlhEAAQAIZvAISChAEBAXBJJai7zsfb8Nrn9M/a5Nnm81tgZNDh8sXa77jH16jR4+fu9dDh8brT
- 7erv89jm8uzw9ODq9Ku0vNHh8mRrcvT3+aStttri6oOGiJqbncrc7oaKjZ+fn9Di6JSVl67C1a6yt5u2
- 0F5cWsjd5IiOlM3U2Tg3N398ezAvLujjjKCnr5u83uXq73V5fnh3d+nv9OLaid/s76/N6pyzy9fn65mi
- rLCurXahzJDO1tfb3+Do8dDg8UdKTb7L2EpMTFhYWZy20K22v6jG5KWqsaq8z+7sj7C/z6amp6C50uLr
- 9evw9aTF52RgX250esjQ2ISAf2xtb7S3u+Tr8WBocMPT43yQo7vU7cbb7+Hr9JGRkt7m7YSFiL7H0cza
- 6IWUo7bBzeqxd6uvs6uoqOLs9c7X31xbXbe/x+fs8evv84SHi8vY5XyPoq7L5wAAAAAAAAAAAAAAAAAA
- AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQB
- AABvACwAAAAAEAAQAAAIwgABvBFIcOCbgwgTJsQRxUkKMgkFBpj4xsMULz/CFNmiMMCRNxugcEkTg8cX
- JGsOSlyRRAQENRcaTIjAAQwIhAFkwDghIQMVLQd6KKhxxuBEEi6YsLFSoIKCB0RQKJSyo0GZAgmyMKAh
- xIfBNwFMjFlywAEBBjqaXHmCcwaaLmYSEMDSIoeSKhSM2njDQsONEG5GtLGAIGGADyXeDOkQRAWQFxgQ
- CBAjECxFAwuMLDDwZoAAAQpDI/RcsHToAaJTvwkIADs=
-</value>
- </data>
- <metadata name="mgZoomToSelectionComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>590, 134</value>
- </metadata>
- <data name="mgZoomToSelectionComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
-</value>
- </data>
- <data name="toolStripMenuItem17.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAFqSURBVDhPpZPbTsJAEIZ5NaPxAXgI5UK50Qt9LmPSeBYQ
- g2gFEWiVIsUWSjm2pdfjzOyyFbyrF1/+Ofwz2c1mMztb2bPd7SykgWYzNOj5k1TQLC+o6K1UqAXVmgHV
- Whsh3Yhf23+uJ7yizifQGx/w8kaYoKOu0cAakts7Uot09pnJgnqzA2u0MCdk/Vy7Y3Nu/5i13vrknjpB
- 0/iCpokYXQHFTBe0yyIbtYsCvGNOMSnNqAWm1QezYyOoGBsE5lfXJTaRmpbsr3zoVQss2wGr54JlIz2K
- Hbi5f2TDLSr1OrLOPo7dZIHteEDQAGmx9MRxoVThXDAU+i3yvvTzK7hDH1xvzEP5gxPWh/IzDLDmeqJH
- DCgekgrUFfzxDEbjqXqm/OEp5z4yot6EFFmp7KkF0/kCiM3/MJ0HXBesYqmzIDnBIgxhEUYQICIWeQLm
- AeYbqBNEyxii5RKJIWRF4qTG/VjWf3l5wX+/8w9/3Qe1qQ/dtwAAAABJRU5ErkJggg==
-</value>
- </data>
- <data name="toolStripMenuItem18.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
-</value>
- </data>
- <data name="toolStripMenuItem19.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
-</value>
- </data>
- <data name="toolStripMenuItem20.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
-</value>
- </data>
- <data name="toolStripMenuItem21.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
-</value>
- </data>
- <data name="toolStripMenuItem22.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
-</value>
- </data>
- <data name="toolStripMenuItem23.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- RK5CYII=
-</value>
- </data>
- <data name="toolStripMenuItem24.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
-</value>
- </data>
<metadata name="mgLayerSelectionHandler1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
<value>705, 173</value>
</metadata>
More information about the mapguide-commits
