[mapguide-commits] r6551 - in trunk/Installer: FdoRegUtil
Installers/MapGuide Installers/MapGuide/Lang
Libraries/MapGuide Server Libraries/MapGuide Web Extensions
svn_mapguide at osgeo.org
Sat Mar 17 10:39:44 EDT 2012
Author: jng
Date: 2012-03-17 07:39:44 -0700 (Sat, 17 Mar 2012)
New Revision: 6551
trunk/Installer/FdoRegUtil/FdoRegUtil.cpp
trunk/Installer/FdoRegUtil/stdafx.h
trunk/Installer/Installers/MapGuide/Lang/MapGuide_en-US.wxl
trunk/Installer/Installers/MapGuide/MapGuide.wxs
trunk/Installer/Libraries/MapGuide Server/FDO.wxs
trunk/Installer/Libraries/MapGuide Web Extensions/Apache.wxs
#1970: Restore old FDO provider registration method in installer
#953: Add tomcat service installation to the installer. This is not fully working yet. The service is installed, but does not start up.
Modified: trunk/Installer/FdoRegUtil/FdoRegUtil.cpp
--- trunk/Installer/FdoRegUtil/FdoRegUtil.cpp 2012-03-16 05:52:32 UTC (rev 6550)
+++ trunk/Installer/FdoRegUtil/FdoRegUtil.cpp 2012-03-17 14:39:44 UTC (rev 6551)
@@ -4,12 +4,19 @@
#include "stdafx.h"
// usage: FdoRegUtil.exe [-r] <provider dll>
+// FdoRegUtil.exe [-r] <provider name> <display name> <provider description> <version> <fdo version> <provider dll path>
// FdoRegUtil.exe [-u] <provider name>
int _tmain(int argc, _TCHAR* argv[])
int ret = 0;
- if (argc == 3)
+ if (argc == 8)
+ if (wcscmp(argv[1], L"-r") != 0)
+ Usage();
+ ret = Register(argv[2], argv[3], argv[4], argv[5], argv[6], argv[7]);
+ else if (argc == 3)
if(wcscmp(argv[1], L"-u") == 0)
ret = Unregister(argv[2]);
@@ -24,7 +31,8 @@
void Usage()
printf("usage\n");
- printf("registering: FdoRegUtil.exe -r <provider dll path>\n");
+ printf("registering (method 1): FdoRegUtil.exe -r <provider dll path>\n");
+ printf("registering (method 2): FdoRegUtil.exe -r <provider name> <display name> <provider description> <version> <fdo version> <provider dll path>\n");
printf("unregistering: FdoRegUtil.exe -u <provider name>\n");
@@ -56,6 +64,22 @@
return ret;
+int Register(_TCHAR* name, _TCHAR* displayName, _TCHAR* description, _TCHAR* version, _TCHAR* fdoVersion, _TCHAR* path)
+ int ret = 0;
+ FdoPtr<IProviderRegistry> prvReg = FdoFeatureAccessManager::GetProviderRegistry();
+ try
+ prvReg->RegisterProvider(name, displayName, description, version, fdoVersion, path, false);
+ catch(FdoException* ex)
+ ex->Release();
+ ret = -1;
+ return ret;
int Unregister(_TCHAR* name)
int ret = 0;
Modified: trunk/Installer/FdoRegUtil/stdafx.h
--- trunk/Installer/FdoRegUtil/stdafx.h 2012-03-16 05:52:32 UTC (rev 6550)
+++ trunk/Installer/FdoRegUtil/stdafx.h 2012-03-17 14:39:44 UTC (rev 6551)
@@ -11,6 +11,7 @@
#include <tchar.h>
int Register(_TCHAR* path);
+int Register(_TCHAR* name, _TCHAR* displayName, _TCHAR* description, _TCHAR* version, _TCHAR* fdoVersion, _TCHAR* path);
int Unregister(_TCHAR* name);
void Usage();
Modified: trunk/Installer/Installers/MapGuide/Lang/MapGuide_en-US.wxl
--- trunk/Installer/Installers/MapGuide/Lang/MapGuide_en-US.wxl 2012-03-16 05:52:32 UTC (rev 6550)
+++ trunk/Installer/Installers/MapGuide/Lang/MapGuide_en-US.wxl 2012-03-17 14:39:44 UTC (rev 6551)
@@ -75,8 +75,9 @@
<String Id="UpdateApacheConfig">Setting values for httpd.conf</String>
<String Id="UpdatePhpIni">Setting values for php.ini</String>
<String Id="InstallApacheServiceCA">Installing Apache Service</String>
+ <String Id="InstallTomcatServiceCA">Installing Tomcat Service</String>
<String Id="MgServerInstallCA">Installing MapGuide Service</String>
<String Id="MgServerUninstallCA">Removing MapGuide Service</String>
<String Id="RemoveApacheServiceCA">Removing Apache Service</String>
+ <String Id="RemoveTomcatServiceCA">Removing Tomcat Service</String>
</WixLocalization>
\ No newline at end of file
Modified: trunk/Installer/Installers/MapGuide/MapGuide.wxs
--- trunk/Installer/Installers/MapGuide/MapGuide.wxs 2012-03-16 05:52:32 UTC (rev 6550)
+++ trunk/Installer/Installers/MapGuide/MapGuide.wxs 2012-03-17 14:39:44 UTC (rev 6551)
@@ -644,9 +644,11 @@
<ProgressText Action="UpdateApacheConfig">!(loc.UpdateApacheConfig)</ProgressText>
<ProgressText Action="UpdatePhpIni">!(loc.UpdatePhpIni)</ProgressText>
<ProgressText Action="InstallApacheServiceCA">!(loc.InstallApacheServiceCA)</ProgressText>
+ <ProgressText Action="InstallTomcatServiceCA">!(loc.InstallTomcatServiceCA)</ProgressText>
<ProgressText Action="MgServerInstallCA">!(loc.MgServerInstallCA)</ProgressText>
<ProgressText Action="MgServerUninstallCA">!(loc.MgServerUninstallCA)</ProgressText>
<ProgressText Action="RemoveApacheServiceCA">!(loc.RemoveApacheServiceCA)</ProgressText>
+ <ProgressText Action="RemoveTomcatServiceCA">!(loc.RemoveTomcatServiceCA)</ProgressText>
</UI>
@@ -840,6 +842,12 @@
Action="StartApacheServiceCA"
After="InstallApacheServiceCA">MGWEB_CONFIG="APACHE" AND &WebExtApacheFeature>2</Custom>
<Custom
+ Action="InstallTomcatServiceCA"
+ Before="InstallFinalize">MGWEB_CONFIG="APACHE" AND &WebExtTomcatFeature>2</Custom>
+ <Custom
+ Action="StartTomcatServiceCA"
+ Before="InstallTomcatServiceCA">MGWEB_CONFIG="APACHE" AND &WebExtTomcatFeature>2</Custom>
+ <Custom
Before="InstallFinalize">&ServerFeature>2</Custom>
<Custom
@@ -848,6 +856,9 @@
<Custom
Before="RemoveFiles">MGWEB_CONFIG="APACHE" AND &WebExtApacheFeature=2</Custom>
+ <Custom
+ Action="RemoveTomcatServiceCA"
+ Before="RemoveFiles">MGWEB_CONFIG="APACHE" AND &WebExtTomcatFeature>2</Custom>
</InstallExecuteSequence>
</Product>
</Wix>
Modified: trunk/Installer/Libraries/MapGuide Server/FDO.wxs
--- trunk/Installer/Libraries/MapGuide Server/FDO.wxs 2012-03-16 05:52:32 UTC (rev 6550)
+++ trunk/Installer/Libraries/MapGuide Server/FDO.wxs 2012-03-17 14:39:44 UTC (rev 6551)
@@ -15,19 +15,19 @@
<Fragment>
<CustomAction Id="FdoRegCmd" Property="FdoReg" Execute="immediate" Value=""[FDOLOCATION]FdoRegUtil.exe"" />
- <CustomAction Execute="immediate" Id="FdoRegArcSdeCmd" Property="FdoRegArcSde" Value="[FdoReg] -r ".\ArcSDEProvider.dll"" />
- <CustomAction Execute="immediate" Id="FdoRegSdfCmd" Property="FdoRegSdf" Value="[FdoReg] -r ".\SDFProvider.dll"" />
- <CustomAction Execute="immediate" Id="FdoRegShpCmd" Property="FdoRegShp" Value="[FdoReg] -r ".\SHPProvider.dll"" />
- <CustomAction Execute="immediate" Id="FdoRegWfsCmd" Property="FdoRegWfs" Value="[FdoReg] -r ".\WFSProvider.dll"" />
- <CustomAction Execute="immediate" Id="FdoRegWmsCmd" Property="FdoRegWms" Value="[FdoReg] -r ".\WMSProvider.dll"" />
- <CustomAction Execute="immediate" Id="FdoRegOdbcCmd" Property="FdoRegOdbc" Value="[FdoReg] -r ".\ODBCProvider.dll"" />
- <CustomAction Execute="immediate" Id="FdoRegMySqlCmd" Property="FdoRegMySql" Value="[FdoReg] -r ".\MySQLProvider.dll"" />
- <CustomAction Execute="immediate" Id="FdoRegGdalCmd" Property="FdoRegGdal" Value="[FdoReg] -r ".\GRFPProvider.dll"" />
- <CustomAction Execute="immediate" Id="FdoRegOgrCmd" Property="FdoRegOgr" Value="[FdoReg] -r ".\OGRProvider.dll"" />
- <CustomAction Execute="immediate" Id="FdoRegPostgreSqlCmd" Property="FdoRegPostgreSql" Value="[FdoReg] -r ".\PostgreSQLProvider.dll"" />
- <CustomAction Execute="immediate" Id="FdoRegOracleCmd" Property="FdoRegOracle" Value="[FdoReg] -r ".\KingOracleProvider.dll"" />
- <CustomAction Execute="immediate" Id="FdoRegSqlServerCmd" Property="FdoRegSqlServer" Value="[FdoReg] -r ".\SQLServerSpatialProvider.dll"" />
- <CustomAction Execute="immediate" Id="FdoRegSltCmd" Property="FdoRegSlt" Value="[FdoReg] -r ".\SQLiteProvider.dll"" />
+ <CustomAction Execute="immediate" Id="FdoRegArcSdeCmd" Property="FdoRegArcSde" Value="[FdoReg] -r "OSGeo.ArcSDE.[FDO_VERSION_SMALL]" "!(loc.ArcSdeProvider)" "!(loc.ArcSdeProviderDesc)" "[FDO_VERSION]" "[FDO_VERSION]" ".\ArcSDEProvider.dll"" />
+ <CustomAction Execute="immediate" Id="FdoRegSdfCmd" Property="FdoRegSdf" Value="[FdoReg] -r "OSGeo.SDF.[FDO_VERSION_SMALL]" "!(loc.SdfProvider)" "!(loc.SdfProviderDesc)" "[FDO_VERSION]" "[FDO_VERSION]" ".\SDFProvider.dll"" />
+ <CustomAction Execute="immediate" Id="FdoRegShpCmd" Property="FdoRegShp" Value="[FdoReg] -r "OSGeo.SHP.[FDO_VERSION_SMALL]" "!(loc.ShpProvider)" "!(loc.ShpProviderDesc)" "[FDO_VERSION]" "[FDO_VERSION]" ".\SHPProvider.dll"" />
+ <CustomAction Execute="immediate" Id="FdoRegWfsCmd" Property="FdoRegWfs" Value="[FdoReg] -r "OSGeo.WFS.[FDO_VERSION_SMALL]" "!(loc.WfsProvider)" "!(loc.WfsProviderDesc)" "[FDO_VERSION]" "[FDO_VERSION]" ".\WFSProvider.dll"" />
+ <CustomAction Execute="immediate" Id="FdoRegWmsCmd" Property="FdoRegWms" Value="[FdoReg] -r "OSGeo.WMS.[FDO_VERSION_SMALL]" "!(loc.WmsProvider)" "!(loc.WmsProviderDesc)" "[FDO_VERSION]" "[FDO_VERSION]" ".\WMSProvider.dll"" />
+ <CustomAction Execute="immediate" Id="FdoRegOdbcCmd" Property="FdoRegOdbc" Value="[FdoReg] -r "OSGeo.ODBC.[FDO_VERSION_SMALL]" "!(loc.OdbcProvider)" "!(loc.OdbcProviderDesc)" "[FDO_VERSION]" "[FDO_VERSION]" ".\ODBCProvider.dll"" />
+ <CustomAction Execute="immediate" Id="FdoRegMySqlCmd" Property="FdoRegMySql" Value="[FdoReg] -r "OSGeo.MySQL.[FDO_VERSION_SMALL]" "!(loc.MySqlProvider)" "!(loc.MySqlProviderDesc)" "[FDO_VERSION]" "[FDO_VERSION]" ".\MySQLProvider.dll"" />
+ <CustomAction Execute="immediate" Id="FdoRegGdalCmd" Property="FdoRegGdal" Value="[FdoReg] -r "OSGeo.Gdal.[FDO_VERSION_SMALL]" "!(loc.GdalProvider)" "!(loc.GdalProviderDesc)" "[FDO_VERSION]" "[FDO_VERSION]" ".\GRFPProvider.dll"" />
+ <CustomAction Execute="immediate" Id="FdoRegOgrCmd" Property="FdoRegOgr" Value="[FdoReg] -r "OSGeo.OGR.[FDO_VERSION_SMALL]" "!(loc.OgrProvider)" "!(loc.OgrProviderDesc)" "[FDO_VERSION]" "[FDO_VERSION]" ".\OGRProvider.dll"" />
+ <CustomAction Execute="immediate" Id="FdoRegPostgreSqlCmd" Property="FdoRegPostgreSql" Value="[FdoReg] -r "OSGeo.PostgreSQL.[FDO_VERSION_SMALL]" "!(loc.PostgreSqlProvider)" "!(loc.PostgreSqlProviderDesc)" "[FDO_VERSION]" "[FDO_VERSION]" ".\PostgreSQLProvider.dll"" />
+ <CustomAction Execute="immediate" Id="FdoRegOracleCmd" Property="FdoRegOracle" Value="[FdoReg] -r "King.Oracle.[FDO_VERSION_SMALL]" "!(loc.KingOracleProvider)" "!(loc.KingOracleProviderDesc)" "[FDO_VERSION]" "[FDO_VERSION]" ".\KingOracleProvider.dll"" />
+ <CustomAction Execute="immediate" Id="FdoRegSqlServerCmd" Property="FdoRegSqlServer" Value="[FdoReg] -r "OSGeo.SQLServerSpatial.[FDO_VERSION_SMALL]" "!(loc.SqlServerProvider)" "!(loc.SqlServerProviderDesc)" "[FDO_VERSION]" "[FDO_VERSION]" ".\SQLServerSpatialProvider.dll"" />
+ <CustomAction Execute="immediate" Id="FdoRegSltCmd" Property="FdoRegSlt" Value="[FdoReg] -r "OSGeo.SQLite.[FDO_VERSION_SMALL]" "!(loc.SltProvider)" "!(loc.SltProviderDesc)" "[FDO_VERSION]" "[FDO_VERSION]" ".\SQLiteProvider.dll"" />
<CustomAction Id="FdoRegArcSde" BinaryKey="WixCA" DllEntry="CAQuietExec" Execute="deferred" Return="ignore" Impersonate="no"/>
<CustomAction Id="FdoRegSdf" BinaryKey="WixCA" DllEntry="CAQuietExec" Execute="deferred" Return="ignore" Impersonate="no"/>
Modified: trunk/Installer/Libraries/MapGuide Web Extensions/Apache.wxs
--- trunk/Installer/Libraries/MapGuide Web Extensions/Apache.wxs 2012-03-16 05:52:32 UTC (rev 6550)
+++ trunk/Installer/Libraries/MapGuide Web Extensions/Apache.wxs 2012-03-17 14:39:44 UTC (rev 6551)
@@ -1,8 +1,21 @@
<Wix xmlns="http://schemas.microsoft.com/wix/2006/wi">
- <!-- httpd.exe -->
- <?define HTTP_MAP = "file_APACHEFILES_19" ?>
- <Fragment>
+ <?if "$(var.MgPlatform)" = "x64" ?>
+ <!-- httpd.exe -->
+ <?define HTTP_MAP = "file_APACHEFILES_19" ?>
+ <!-- tomcat7.exe -->
+ <?define TOMCAT_MAP = "file_TOMCATFILES_39" ?>
+ <!-- service.bat -->
+ <?define TOMCAT_BAT = "file_TOMCATFILES_29" ?>
+ <?else ?>
+ <?endif ?>
+ <Fragment>
<Binary Id="ApacheActions" SourceFile="..\..\Custom\bin\apache_actions.dll" />
<CustomAction Id="UpdateApacheConfig.SetValues" Property="UpdateApacheConfig" Value="[WEBEXTENSIONSLOCATION];[APACHE_API_TYPE];[APACHE_PORT];[APACHELOCATION];[PHPLOCATION];[WEBROOTLOCATION];[VIRTUALDIR]" />
<CustomAction Id="UpdateApacheConfig" Return="check" BinaryKey="ApacheActions" Execute="deferred" DllEntry="UpdateApacheConfig" />
@@ -11,5 +24,8 @@
<CustomAction Id="RemoveApacheServiceCA" Execute="immediate" Return="ignore" FileKey="$(var.HTTP_MAP)" ExeCommand="-k uninstall -n "ApacheMapGuide[MG_VERSION_MAJOR_MINOR]"" />
<CustomAction Id="InstallApacheServiceCA" Execute="deferred" Return="ignore" FileKey="$(var.HTTP_MAP)" ExeCommand="-k install -n "ApacheMapGuide[MG_VERSION_MAJOR_MINOR]"" />
<CustomAction Id="StartApacheServiceCA" Execute="deferred" Return="ignore" FileKey="$(var.HTTP_MAP)" ExeCommand="-k start -n "ApacheMapGuide[MG_VERSION_MAJOR_MINOR]"" />
+ <CustomAction Id="RemoveTomcatServiceCA" Execute="immediate" Return="ignore" FileKey="$(var.TOMCAT_MAP)" ExeCommand="//DS//TomcatMapGuide[MG_VERSION_MAJOR_MINOR]" />
+ <CustomAction Id="InstallTomcatServiceCA" Execute="deferred" Return="ignore" FileKey="$(var.TOMCAT_BAT)" ExeCommand="install TomcatMapGuide[MG_VERSION_MAJOR_MINOR]" />
+ <CustomAction Id="StartTomcatServiceCA" Execute="deferred" Return="ignore" FileKey="$(var.TOMCAT_MAP)" ExeCommand="//RS//TomcatMapGuide[MG_VERSION_MAJOR_MINOR]" />
</Fragment>
</Wix>
More information about the mapguide-commits
