[mapguide-commits] r6669 - trunk/MgDev/Web/src/schemareport
svn_mapguide at osgeo.org
Fri May 18 11:54:58 EDT 2012
Author: jng
Date: 2012-05-18 08:54:57 -0700 (Fri, 18 May 2012)
New Revision: 6669
trunk/MgDev/Web/src/schemareport/showgeom.php
Schema Report: Add extra robustness for counting totals and getting the required bounding box
Modified: trunk/MgDev/Web/src/schemareport/showgeom.php
--- trunk/MgDev/Web/src/schemareport/showgeom.php 2012-05-18 15:48:03 UTC (rev 6668)
+++ trunk/MgDev/Web/src/schemareport/showgeom.php 2012-05-18 15:54:57 UTC (rev 6669)
@@ -48,7 +48,8 @@
$firstTime = true;
$validSession = 1;
$useBasicViewer = ($_GET['viewer'] == 'basic');
+ $viewerRequest = '../schemareport/blank.php';
try
$thisFile = __FILE__;
@@ -100,41 +101,60 @@
$expr = "COUNT(" .$pd->GetName(). ")";
$query = new MgFeatureAggregateOptions();
$query->AddComputedProperty("TotalCount", $expr);
- $dataReader = $featureSrvc->SelectAggregate($featuresId, $featureName, $query);
- if ($dataReader->ReadNext())
+ try
- // When there is no data, the property will be null.
- if($dataReader->IsNull("TotalCount"))
+ $dataReader = $featureSrvc->SelectAggregate($featuresId, $featureName, $query);
+ if ($dataReader->ReadNext())
- $totalEntries = 0;
- $gotCount = true;
- else
- $ptype = $dataReader->GetPropertyType("TotalCount");
- switch ($ptype)
+ // When there is no data, the property will be null.
+ if($dataReader->IsNull("TotalCount"))
- case MgPropertyType::Int32:
- $totalEntries = $dataReader->GetInt32("TotalCount");
- $gotCount = true;
- break;
- case MgPropertyType::Int64:
- $totalEntries = $dataReader->GetInt64("TotalCount");
- $gotCount = true;
- break;
+ $totalEntries = 0;
+ $gotCount = true;
- $dataReader->Close();
+ else
+ $ptype = $dataReader->GetPropertyType("TotalCount");
+ switch ($ptype)
+ case MgPropertyType::Int32:
+ $totalEntries = $dataReader->GetInt32("TotalCount");
+ $gotCount = true;
+ break;
+ case MgPropertyType::Int64:
+ $totalEntries = $dataReader->GetInt64("TotalCount");
+ $gotCount = true;
+ break;
+ $dataReader->Close();
+ catch (MgException $ex) //Some providers like OGR can lie
+ $gotCount = false;
if ($gotCount == false)
- $featureReader = $featureSrvc->SelectFeatures($featuresId, $featureName, null);
- while($featureReader->ReadNext())
- $totalEntries++;
- $featureReader->Close();
+ $featureReader = null;
+ try
+ $featureReader = $featureSrvc->SelectFeatures($featuresId, $featureName, null);
+ $totalEntries = -1; //Can't Count() or raw spin? Oh dear!
+ if ($featureReader != null)
+ while($featureReader->ReadNext())
+ $totalEntries++;
+ $featureReader->Close();
// Create a layer definition
@@ -148,6 +168,9 @@
$resId = new MgResourceIdentifier($resName);
$resourceSrvc->SetResource($resId, $byteSource->GetReader(), null);
+ $extentGeometryAgg = null;
+ $extentGeometrySc = null;
// Finds the coordinate system
$agfReaderWriter = new MgAgfReaderWriter();
$spatialcontextReader = $featureSrvc->GetSpatialContexts($featuresId, false);
@@ -159,23 +182,21 @@
// Finds the extent
$extentByteReader = $spatialcontextReader->GetExtent();
- if($extentByteReader->ToString()==null)
- throw new Exception(ErrorMessages::NullExtent);
break;
$spatialcontextReader->Close();
+ if ($extentByteReader == null)
+ // Get the extent geometry from the spatial context
+ $extentGeometrySc = $agfReaderWriter->Read($extentByteReader);
- // Get the extent geometry from the spatial context
- $extentGeometry = $agfReaderWriter->Read($extentByteReader);
// Try to get the extents using the selectaggregate as sometimes the spatial context
// information is not set
$aggregateOptions = new MgFeatureAggregateOptions();
$featureProp = 'SPATIALEXTENTS("' . $geomName . '")';
- $aggregateOptions->AddComputedProperty('extents', $featureProp);
+ $aggregateOptions->AddComputedProperty('EXTENTS', $featureProp);
try
@@ -183,15 +204,26 @@
if($dataReader->ReadNext())
// Get the extents information
- $byteReader = $dataReader->GetGeometry('extents');
- $extentGeometry = $agfReaderWriter->Read($byteReader);
+ $byteReader = $dataReader->GetGeometry('EXTENTS');
+ $extentGeometryAgg = $agfReaderWriter->Read($byteReader);
catch (MgException $e)
+ $extentGeometry = null;
+ // Prefer SpatialExtents() extent over spatial context extent
+ if ($extentGeometryAgg != null)
+ $extentGeometry = $extentGeometryAgg;
+ if ($extentGeometry == null) { //Stil null? Now try spatial context
+ if ($extentGeometrySc != null)
+ $extentGeometry = $extentGeometrySc;
+ else
+ throw new Exception(ErrorMessages::NullExtent);
// Get the coordinates
$iterator = $extentGeometry->GetCoordinates();
while($iterator->MoveNext())
@@ -234,6 +266,7 @@
// Save the web layout to a resource stored in the session repository
$byteSource = new MgByteSource($webLayout, strlen($webLayout));
$byteSource->SetMimeType(MgMimeType::Xml);
if($useBasicViewer)
$resName = 'Session:' . $sessionId . '//' . $className . '.WebLayout';
More information about the mapguide-commits
