[mapguide-commits] r7196 - in trunk/Tools/Maestro: Maestro.Base/Commands Maestro.Base/Services Maestro.Base/UI OSGeo.MapGuide.MaestroAPI.Native
svn_mapguide at osgeo.org
Tue Nov 6 21:28:58 PST 2012
Author: jng
Date: 2012-11-06 21:28:58 -0800 (Tue, 06 Nov 2012)
New Revision: 7196
trunk/Tools/Maestro/Maestro.Base/Commands/StartupCommand.cs
trunk/Tools/Maestro/Maestro.Base/Services/ResourcePreviewerFactory.cs
trunk/Tools/Maestro/Maestro.Base/UI/MapPreviewDialog.Designer.cs
trunk/Tools/Maestro/Maestro.Base/UI/MapPreviewDialog.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeConnection.cs
This submission contains the following changes:
- Fix incorrect MPU calculation in the LocalNative provider
- Register a stub previewer for the LocalNative provider, meaning some resources can still be previewed via the new local map preview if the option is enabled.
- Show the coordinate system WKT of the runtime map in the MapPreviewDialog
Modified: trunk/Tools/Maestro/Maestro.Base/Commands/StartupCommand.cs
--- trunk/Tools/Maestro/Maestro.Base/Commands/StartupCommand.cs 2012-11-06 16:18:45 UTC (rev 7195)
+++ trunk/Tools/Maestro/Maestro.Base/Commands/StartupCommand.cs 2012-11-07 05:28:58 UTC (rev 7196)
@@ -42,6 +42,9 @@
ResourceService.RegisterNeutralStrings(Strings.ResourceManager);
ResourcePreviewerFactory.RegisterPreviewer("Maestro.Http", new DefaultResourcePreviewer()); //NOXLATE
+ //A stub previewer does nothing, but will use local map previews for applicable resources if the configuration
+ //property is set
+ ResourcePreviewerFactory.RegisterPreviewer("Maestro.LocalNative", new StubPreviewer()); //NOXLATE
Workbench.WorkbenchInitialized += (sender, e) =>
Modified: trunk/Tools/Maestro/Maestro.Base/Services/ResourcePreviewerFactory.cs
--- trunk/Tools/Maestro/Maestro.Base/Services/ResourcePreviewerFactory.cs 2012-11-06 16:18:45 UTC (rev 7195)
+++ trunk/Tools/Maestro/Maestro.Base/Services/ResourcePreviewerFactory.cs 2012-11-07 05:28:58 UTC (rev 7196)
@@ -71,6 +71,25 @@
void Preview(IResource res, IEditorService edSvc, string locale);
+ internal class StubPreviewer : IResourcePreviewer
+ public bool IsPreviewable(IResource res)
+ return false;
+ public void Preview(IResource res, IEditorService edSvc)
+ public void Preview(IResource res, IEditorService edSvc, string locale)
public class LocalMapPreviewer : IResourcePreviewer
private IResourcePreviewer _inner;
Modified: trunk/Tools/Maestro/Maestro.Base/UI/MapPreviewDialog.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/MapPreviewDialog.Designer.cs 2012-11-06 16:18:45 UTC (rev 7195)
+++ trunk/Tools/Maestro/Maestro.Base/UI/MapPreviewDialog.Designer.cs 2012-11-07 05:28:58 UTC (rev 7196)
@@ -53,6 +53,8 @@
this.label2 = new System.Windows.Forms.Label();
this.txtMinX = new System.Windows.Forms.TextBox();
this.label1 = new System.Windows.Forms.Label();
+ this.label6 = new System.Windows.Forms.Label();
+ this.txtCoordinateSystem = new System.Windows.Forms.TextBox();
this.statusStrip1.SuspendLayout();
this.splitContainer1.Panel1.SuspendLayout();
this.splitContainer1.Panel2.SuspendLayout();
@@ -197,16 +199,16 @@
this.grpOtherTools.Controls.Add(this.lnkZoomToScale);
this.grpOtherTools.Controls.Add(this.numZoomToScale);
this.grpOtherTools.Controls.Add(this.label5);
- this.grpOtherTools.Location = new System.Drawing.Point(16, 222);
+ this.grpOtherTools.Location = new System.Drawing.Point(16, 367);
this.grpOtherTools.Name = "grpOtherTools";
- this.grpOtherTools.Size = new System.Drawing.Size(165, 260);
+ this.grpOtherTools.Size = new System.Drawing.Size(165, 115);
this.grpOtherTools.TabIndex = 1;
this.grpOtherTools.TabStop = false;
this.grpOtherTools.Text = "Other Tools";
// btnGetMapKml
- this.btnGetMapKml.Location = new System.Drawing.Point(10, 108);
+ this.btnGetMapKml.Location = new System.Drawing.Point(10, 74);
this.btnGetMapKml.Name = "btnGetMapKml";
this.btnGetMapKml.Size = new System.Drawing.Size(94, 23);
this.btnGetMapKml.TabIndex = 4;
@@ -245,6 +247,8 @@
this.groupBox1.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
| System.Windows.Forms.AnchorStyles.Right)));
+ this.groupBox1.Controls.Add(this.txtCoordinateSystem);
+ this.groupBox1.Controls.Add(this.label6);
this.groupBox1.Controls.Add(this.txtMaxY);
this.groupBox1.Controls.Add(this.label4);
this.groupBox1.Controls.Add(this.txtMaxX);
@@ -255,7 +259,7 @@
this.groupBox1.Controls.Add(this.label1);
this.groupBox1.Location = new System.Drawing.Point(16, 10);
this.groupBox1.Name = "groupBox1";
- this.groupBox1.Size = new System.Drawing.Size(165, 205);
+ this.groupBox1.Size = new System.Drawing.Size(165, 351);
this.groupBox1.TabIndex = 0;
this.groupBox1.TabStop = false;
this.groupBox1.Text = "Current Extents";
@@ -336,6 +340,27 @@
this.label1.TabIndex = 0;
this.label1.Text = "Min X";
+ // label6
+ this.label6.AutoSize = true;
+ this.label6.Location = new System.Drawing.Point(7, 190);
+ this.label6.Name = "label6";
+ this.label6.Size = new System.Drawing.Size(95, 13);
+ this.label6.TabIndex = 8;
+ this.label6.Text = "Coordinate System";
+ // txtCoordinateSystem
+ this.txtCoordinateSystem.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ | System.Windows.Forms.AnchorStyles.Right)));
+ this.txtCoordinateSystem.Location = new System.Drawing.Point(10, 207);
+ this.txtCoordinateSystem.Multiline = true;
+ this.txtCoordinateSystem.Name = "txtCoordinateSystem";
+ this.txtCoordinateSystem.ReadOnly = true;
+ this.txtCoordinateSystem.ScrollBars = System.Windows.Forms.ScrollBars.Vertical;
+ this.txtCoordinateSystem.Size = new System.Drawing.Size(135, 123);
+ this.txtCoordinateSystem.TabIndex = 9;
// MapPreviewDialog
this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
@@ -392,5 +417,7 @@
private System.Windows.Forms.TextBox txtMinX;
private System.Windows.Forms.Label label1;
private System.Windows.Forms.Button btnGetMapKml;
+ private System.Windows.Forms.TextBox txtCoordinateSystem;
+ private System.Windows.Forms.Label label6;
\ No newline at end of file
Modified: trunk/Tools/Maestro/Maestro.Base/UI/MapPreviewDialog.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/MapPreviewDialog.cs 2012-11-06 16:18:45 UTC (rev 7195)
+++ trunk/Tools/Maestro/Maestro.Base/UI/MapPreviewDialog.cs 2012-11-07 05:28:58 UTC (rev 7196)
@@ -45,6 +45,7 @@
if (!string.IsNullOrEmpty(resourceId))
this.Text += " - " + resourceId;
+ txtCoordinateSystem.Text = map.CoordinateSystem;
numZoomToScale.Minimum = 1;
numZoomToScale.Maximum = Int32.MaxValue;
_launcher = urlLauncher;
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeConnection.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeConnection.cs 2012-11-06 16:18:45 UTC (rev 7195)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeConnection.cs 2012-11-07 05:28:58 UTC (rev 7196)
@@ -170,7 +170,7 @@
MgCoordinateSystemFactory csFact = new MgCoordinateSystemFactory();
MgCoordinateSystem cs = csFact.Create(csWkt);
- return cs.ConvertMetersToCoordinateSystemUnits(units);
+ return cs.ConvertCoordinateSystemUnitsToMeters(units);
catch (MgException ex) //Not implemented due to wrapping Proj.4?
More information about the mapguide-commits
