[mapguide-commits] r7222 - sandbox/jng/swig-java/Web/src/JavaApiEx
svn_mapguide at osgeo.org
Fri Nov 23 07:55:15 PST 2012
Author: jng
Date: 2012-11-23 07:55:14 -0800 (Fri, 23 Nov 2012)
New Revision: 7222
sandbox/jng/swig-java/Web/src/JavaApiEx/DIFFERENCES.txt
sandbox/jng/swig-java/Web/src/JavaApiEx/javaextensions.i
#9: Add Iterable support for MgReadOnlyLayerCollection
Modified: sandbox/jng/swig-java/Web/src/JavaApiEx/DIFFERENCES.txt
--- sandbox/jng/swig-java/Web/src/JavaApiEx/DIFFERENCES.txt 2012-11-23 14:29:55 UTC (rev 7221)
+++ sandbox/jng/swig-java/Web/src/JavaApiEx/DIFFERENCES.txt 2012-11-23 15:55:14 UTC (rev 7222)
@@ -32,9 +32,13 @@
- MgFeatureSchemaCollection (T is MgFeatureSchema)
- MgPropertyCollection (T is MgProperty)
- MgStringCollection (T is String)
+4. The following classes now implement java.util.Iterable<T> allowing them to be used in an enhanced for-loop
-4. To avoid naming conflicts with SWIG generated code and methods from inherited java classes or interfaces as a result of the above changes, the following class methods have been renamed in the Java MapGuide API:
+ - MgReadOnlyLayerCollection (T is MgLayerBase)
+5. To avoid naming conflicts with SWIG generated code and methods from inherited java classes or interfaces as a result of the above changes, the following class methods have been renamed in the Java MapGuide API:
- MgPropertyDefinition.Delete is now MgPropertyDefinition.markAsDeleted
- MgClassDefinition.Delete is now MgClassDefinition.markAsDeleted
- MgFeatureSchema.Delete is now MgFeatureSchema.markAsDeleted
Modified: sandbox/jng/swig-java/Web/src/JavaApiEx/javaextensions.i
--- sandbox/jng/swig-java/Web/src/JavaApiEx/javaextensions.i 2012-11-23 14:29:55 UTC (rev 7221)
+++ sandbox/jng/swig-java/Web/src/JavaApiEx/javaextensions.i 2012-11-23 15:55:14 UTC (rev 7222)
@@ -53,6 +53,9 @@
//that needs one
//Kinda like C++ templates for Java without the suck. And we all know how much Java generics suck :D
+//TODO: Not sure if a SWIG macro can call into another SWIG macro, but if it can it should call into
+//the IMPLEMENT_MG_JAVA_ITERABLE_API
%define IMPLEMENT_MG_JAVA_COLLECTION_API(collection_type, item_type)
//Necessary imports
%typemap(javaimports) collection_type %{
@@ -90,6 +93,8 @@
throw new UnsupportedOperationException();
+ public Iterator<item_type> iterator() { return new ItemIterator(this); }
public boolean add(item_type item) {
this.addItem(item);
@@ -122,8 +127,6 @@
public boolean isEmpty() { return this.getCount() == 0; }
- public Iterator<item_type> iterator() { return new ItemIterator(this); }
public boolean remove(Object o) {
if (o instanceof item_type) {
return this.remove((item_type)o);
@@ -184,10 +187,53 @@
%enddef
+//This helper macro implements the java.lang.Iterable API allowing the instance of the
+//java proxy to be used in an enhanced for loop (akin to IEnumerable/foreach in C#)
+%define IMPLEMENT_MG_JAVA_ITERABLE_API(collection_type, item_type)
+//Necessary imports
+%typemap(javaimports) collection_type %{
+import java.util.Iterator;
+import java.util.NoSuchElementException;
+//Java Interfaces implemented by the java proxy class
+%typemap(javainterfaces) collection_type "java.lang.Iterable<item_type>"
+//This is the java.lang.Iterable<T> implementation that is injected into each java proxy class
+%typemap(javacode) collection_type %{
+ class ItemIterator implements Iterator<item_type> {
+ private collection_type _collection;
+ private int _pos;
+ public ItemIterator(collection_type c) {
+ _collection = c;
+ _pos = -1;
+ public boolean hasNext() {
+ return _pos + 1 <= _collection.getCount();
+ public item_type next() {
+ _pos++;
+ if (_pos >= _collection.getCount())
+ throw new NoSuchElementException();
+ return _collection.getItem(_pos);
+ public void remove() {
+ throw new UnsupportedOperationException();
+%enddef
//Plug the stock implementation for our MapGuide collection classes
IMPLEMENT_MG_JAVA_COLLECTION_API(MgBatchPropertyCollection, MgPropertyCollection)
IMPLEMENT_MG_JAVA_COLLECTION_API(MgClassDefinitionCollection, MgClassDefinition)
IMPLEMENT_MG_JAVA_COLLECTION_API(MgFeatureSchemaCollection, MgFeatureSchema)
-//IMPLEMENT_MG_JAVA_COLLECTION_API(MgIntCollection, Integer)
IMPLEMENT_MG_JAVA_COLLECTION_API(MgPropertyCollection, MgProperty)
-IMPLEMENT_MG_JAVA_COLLECTION_API(MgStringCollection, String)
\ No newline at end of file
+IMPLEMENT_MG_JAVA_COLLECTION_API(MgStringCollection, String)
+IMPLEMENT_MG_JAVA_ITERABLE_API(MgReadOnlyLayerCollection, MgLayerBase)
More information about the mapguide-commits
