[mapguide-commits] r7237 - in sandbox/jng/swig-java: . BuildTools Oem/SQLite/src/SQLitePhpApi
svn_mapguide at osgeo.org
Wed Nov 28 01:03:39 PST 2012
Author: jng
Date: 2012-11-28 01:03:38 -0800 (Wed, 28 Nov 2012)
New Revision: 7237
Removed:
sandbox/jng/swig-java/BuildTools/DoxyTransform/
sandbox/jng/swig-java/Oem/SQLite/src/SQLitePhpApi/SQliteApiGen.xml
sandbox/jng/swig-java/build.bat
sandbox/jng/swig-java/build64.bat
#9, #2114:
- Remove the DoxyTransform tool and update build scripts to no longer call them. The updated SWIG/IMake infrastructure has eliminated the need for this tool
- Update SQLitePhpApiGen.xml with a dummy DocTarget
Modified: sandbox/jng/swig-java/Oem/SQLite/src/SQLitePhpApi/SQliteApiGen.xml
--- sandbox/jng/swig-java/Oem/SQLite/src/SQLitePhpApi/SQliteApiGen.xml 2012-11-27 15:29:57 UTC (rev 7236)
+++ sandbox/jng/swig-java/Oem/SQLite/src/SQLitePhpApi/SQliteApiGen.xml 2012-11-28 09:03:38 UTC (rev 7237)
@@ -9,6 +9,7 @@
Target section.
<Target path="./SQLitePhpApi.i"/>
+<DocTarget path="./SQLitePhpApi_Doc.i"/>
C++ inline section.
Modified: sandbox/jng/swig-java/build.bat
--- sandbox/jng/swig-java/build.bat 2012-11-27 15:29:57 UTC (rev 7236)
+++ sandbox/jng/swig-java/build.bat 2012-11-28 09:03:38 UTC (rev 7237)
@@ -388,8 +388,6 @@
echo [install]: Copy dlls into .net samples
%XCOPY% "%MG_OUTPUT_WEB%\www\mapviewernet\bin\*.dll" "%MG_OUTPUT_WEB%\www\dotnetsamples\bin" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
%XCOPY% "%MG_OUTPUT_WEB%\www\mapviewernet\bin\*.dll" "%MG_OUTPUT_WEB%\www\dotnetviewersample\bin" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
-echo [build]: .net intellisense files
-DoxyTransform.exe dotnet "%MG_DOC_XML%" "%MG_OUTPUT_WEB%\www\mapviewernet\bin"
goto quit
:error
Modified: sandbox/jng/swig-java/build64.bat
--- sandbox/jng/swig-java/build64.bat 2012-11-27 15:29:57 UTC (rev 7236)
+++ sandbox/jng/swig-java/build64.bat 2012-11-28 09:03:38 UTC (rev 7237)
@@ -420,8 +420,6 @@
goto quit
:error
More information about the mapguide-commits
