[mapguide-commits] r7061 - trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI
svn_mapguide at osgeo.org
Mon Oct 1 10:24:15 PDT 2012
Author: jng
Date: 2012-10-01 10:24:15 -0700 (Mon, 01 Oct 2012)
New Revision: 7061
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs
#2136: Fix FDO class name encoding/decoding. The previously introduced failing test case now passes.
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs 2012-10-01 16:28:35 UTC (rev 7060)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs 2012-10-01 17:24:15 UTC (rev 7061)
@@ -31,6 +31,7 @@
using System.Globalization;
using OSGeo.MapGuide.MaestroAPI.Resource;
using System.Text;
+using System.Text.RegularExpressions;
namespace OSGeo.MapGuide.MaestroAPI
@@ -604,8 +605,12 @@
return string.Format("{0} bytes", size); //NOXLATE
- private static System.Text.RegularExpressions.Regex EncRegExp = new System.Text.RegularExpressions.Regex(@"(\-x([0-9]|[a-e]|[A-E])([0-9]|[a-e]|[A-E])\-)|(\-dot\-)|(\-colon\-)", System.Text.RegularExpressions.RegexOptions.Compiled);
+ private static Regex EncRegExp = new System.Text.RegularExpressions.Regex(@"(\-x[0-2a-fA-F][0-9a-fA-F]\-)|(\-dot\-)|(\-colon\-)", System.Text.RegularExpressions.RegexOptions.Compiled);
+ private static Regex TokenRegex = new Regex("^x[0-9a-fA-F][0-9a-fA-F]", RegexOptions.Compiled);
+ private static Regex TokenRegex2 = new Regex("^_x[0-9a-fA-F][0-9a-fA-F]", RegexOptions.Compiled);
/// <summary>
/// FDO encodes a string
/// </summary>
@@ -613,51 +618,153 @@
/// <returns></returns>
public static string EncodeFDOName(string name)
- return name.Replace("\"", "-x22-") //NOXLATE
- .Replace("&", "-x26-") //NOXLATE
- .Replace("'", "-x27-") //NOXLATE
- .Replace("<", "-x3C-") //NOXLATE
- .Replace(">", "-x3E-") //NOXLATE
- .Replace("~", "-x7E-") //NOXLATE
- .Replace(" ", "-x20-"); //NOXLATE
+ //Decode characters not allowed by FDO
+ string lName = name.Replace("-dot-", ".")
+ .Replace("-colon-", ":");
+ //Break the name up by '-' delimiters
+ string[] tokens = lName.Split(new char[] { '-' }, StringSplitOptions.None);
+ StringBuilder outName = new StringBuilder();
+ // Encode any characters that are not allowed in XML names.
+ // The encoding pattern is "-x%x-" where %x is the character value in hexidecimal.
+ // The dash delimeters were an unfortunate choice since dash cannot be the 1st character
+ // in an XML name. When the 1st character needs to be encoded, it is encoded as "_x%x-" to
+ // resolve this issue.
+ for (int i = 0; i < tokens.Length; i++)
+ string token = tokens[i];
+ if (TokenRegex.Match(token, 0).Success)
+ // the token happens to match the encoding pattern. We want to avoid
+ // decoding this sub-string on decode. This is done by encoding the leading
+ // dash.
+ if (outName.Length == 0)
+ outName.Append(string.Format("_x{0:X}-", Convert.ToInt32('-')).ToLower());
+ else
+ outName.Append(string.Format("-x{0:X}-", Convert.ToInt32('-')).ToLower());
+ else if (TokenRegex2.Match(token, 0).Success && i == 0)
+ // the token happens to match the encoding pattern for the 1st character.
+ // We want to avoid decoding this sub-string on decode.
+ // This is done by prepending a dummy encoding for character 0. This character is
+ // discarded on decode.
+ outName.Append("_x00-");
+ else
+ // The token doesn't match the encoding pattern, just write the dash
+ // that was discarded by the tokenizer.
+ if (i > 0)
+ outName.Append("_x2d-"); // 1st character so lead with '_'
+ else
+ outName.Append("-");
+ outName.Append(ReplaceBadChars(token));
+ char c = outName[0];
+ //Perform actual substitutions of bad characters
+ outName = outName.Remove(0, 1);
+ //Check if the first character requires a meta-escape character replacement
+ string prefix = c + "";
+ switch (c)
+ case ' ':
+ prefix = "_x20-";
+ break;
+ case '-':
+ prefix = "_x2d-";
+ break;
+ case '&':
+ prefix = "_x26-";
+ break;
+ default:
+ if (Char.IsDigit(c))
+ prefix = "_x3" + c + "-";
+ break;
+ string result = prefix + outName.ToString();
+ return result;
+ private static string ReplaceBadChars(string token)
+ StringBuilder sb = new StringBuilder();
+ bool bFirstChar = true;
+ foreach (char c in token)
+ if (XmlConvert.IsNCNameChar(c))
+ sb.Append(c);
+ else
+ sb.AppendFormat("{0}x{1:X}-", bFirstChar ? "_" : "-", Convert.ToInt32(c));
+ bFirstChar = false;
+ return sb.ToString();
/// <summary>
/// Converts FDO encoded characters into their original character.
- /// Encoded characters have the form -x00-.
/// </summary>
/// <param name="name">The FDO encoded string</param>
/// <returns>The unencoded version of the string</returns>
public static string DecodeFDOName(string name)
- System.Text.RegularExpressions.Match m = EncRegExp.Match(name);
- System.Text.StringBuilder sb = new System.Text.StringBuilder();
- int previndex = 0;
+ // The encoding pattern is delimited by '-' so break string up by '-'.
+ string[] tokens = name.Split(new char[] { '-' }, StringSplitOptions.None);
+ bool prevDecode = true;
+ StringBuilder decoded = new StringBuilder();
+ //This is a special character inserted during the encoding process.
+ //If we find this at the beginning, discard it
+ if (i == 0 && token == "_x00")
+ continue;
- while (m != null && m.Success)
- string replaceval;
- if (m.Value == "-dot-") //NOXLATE
- replaceval = "."; //NOXLATE
- else if (m.Value == "-colon-") //NOXLATE
- replaceval = ":"; //NOXLATE
+ var m = TokenRegex.Match(token, 0);
+ var m2 = TokenRegex2.Match(token, 0);
+ if (token.Length == 4 && token.StartsWith("_x3") && Char.IsDigit(token[3]))
+ decoded.Append(token[3]);
+ prevDecode = true;
else
- replaceval = ((char)int.Parse(m.Value.Substring(2, 2), System.Globalization.NumberStyles.HexNumber)).ToString();
+ if ((!prevDecode) && m.Success)
+ string replace = ((char)int.Parse(m.Value.Substring(1, 2), System.Globalization.NumberStyles.HexNumber)).ToString();
+ decoded.Append(replace);
+ else if ((i == 0) && m2.Success)
+ string replace = ((char)int.Parse(m2.Value.Substring(2, 2), System.Globalization.NumberStyles.HexNumber)).ToString();
+ else
+ if (i > 0 && !prevDecode)
+ decoded.Append("-");
- sb.Append(name.Substring(previndex, m.Index - previndex));
- sb.Append(replaceval);
- previndex = m.Index + m.Value.Length;
- m = m.NextMatch();
+ decoded.Append(token);
+ prevDecode = false;
- if (sb.Length == 0)
- return name;
- else
- sb.Append(name.Substring(previndex));
- return sb.ToString();
+ return decoded.ToString();
More information about the mapguide-commits
