[mapguide-commits] r7085 - in branches/2.4/MgDev/Desktop: . nuget nuget/api-web nuget/api-web/content nuget/api-web/content/net40 nuget/api-web/content/net40/mapguide-api-web nuget/api-web/lib nuget/api-web/lib/net40 nuget/api-web/tools nuget/api-web/tools/net40
svn_mapguide at osgeo.org
Sun Oct 7 02:27:53 PDT 2012
Author: jng
Date: 2012-10-07 02:27:53 -0700 (Sun, 07 Oct 2012)
New Revision: 7085
Added:
branches/2.4/MgDev/Desktop/nuget/api-web/
branches/2.4/MgDev/Desktop/nuget/api-web/content/
branches/2.4/MgDev/Desktop/nuget/api-web/content/net40/
branches/2.4/MgDev/Desktop/nuget/api-web/content/net40/mapguide-api-web/
branches/2.4/MgDev/Desktop/nuget/api-web/lib/
branches/2.4/MgDev/Desktop/nuget/api-web/lib/net40/
branches/2.4/MgDev/Desktop/nuget/api-web/tools/
branches/2.4/MgDev/Desktop/nuget/api-web/tools/net40/
branches/2.4/MgDev/Desktop/nuget/mapguide-api-web.nuspec
branches/2.4/MgDev/Desktop/base_package_excludes.txt
branches/2.4/MgDev/Desktop/desktop_package_excludes.txt
branches/2.4/MgDev/Desktop/nuget/mapguide-api-base.nuspec
branches/2.4/MgDev/Desktop/nuget_pack.bat
branches/2.4/MgDev/Desktop/nuget_prepare.bat
Update nuget scripts to include the MapGuide Web API. This is to get the changes in before we move this folder out to its own top-level directory
Modified: branches/2.4/MgDev/Desktop/base_package_excludes.txt
--- branches/2.4/MgDev/Desktop/base_package_excludes.txt 2012-10-07 09:25:39 UTC (rev 7084)
+++ branches/2.4/MgDev/Desktop/base_package_excludes.txt 2012-10-07 09:27:53 UTC (rev 7085)
@@ -2,6 +2,8 @@
Logs
Repositories
+Temp
+Dictionaries
Schema
OSGeo.MapGuide.Desktop.dll
@@ -23,11 +25,15 @@
maestroapi.key
DotNetHarness.exe
DotNetHarness.exe.config
+DotNetHarness.vshost.exe
+DotNetHarness.vshost.exe.config
+DotNetHarness.vshost.exe.manifest
DotNetUnitTest.exe
DotNetUnitTest.exe.config
MapViewerTest.exe
MapViewerTest.exe.config
SignMapGuideApi.exe
UnitTest.exe
+SampleExtension.dll
Sheboygan.AppLayout
MgAppLayout.exe
\ No newline at end of file
Modified: branches/2.4/MgDev/Desktop/desktop_package_excludes.txt
--- branches/2.4/MgDev/Desktop/desktop_package_excludes.txt 2012-10-07 09:25:39 UTC (rev 7084)
+++ branches/2.4/MgDev/Desktop/desktop_package_excludes.txt 2012-10-07 09:27:53 UTC (rev 7085)
@@ -1,5 +1,7 @@
Backup
Logs
+Schema
+Temp
Repositories
Dictionaries
ACE.dll
@@ -23,6 +25,9 @@
maestroapi.key
DotNetHarness.exe
DotNetUnitTest.exe
MapViewerTest.exe
@@ -30,4 +35,5 @@
SignMapGuideApi.exe
UnitTest.exe
Sheboygan.AppLayout
MgAppLayout.exe
Property changes on: branches/2.4/MgDev/Desktop/nuget/api-web
___________________________________________________________________
Added: bugtraq:number
+ true
Property changes on: branches/2.4/MgDev/Desktop/nuget/api-web/content
+ true
Property changes on: branches/2.4/MgDev/Desktop/nuget/api-web/content/net40
+ true
Property changes on: branches/2.4/MgDev/Desktop/nuget/api-web/content/net40/mapguide-api-web
+ true
Property changes on: branches/2.4/MgDev/Desktop/nuget/api-web/lib
+ true
Property changes on: branches/2.4/MgDev/Desktop/nuget/api-web/lib/net40
+ true
Property changes on: branches/2.4/MgDev/Desktop/nuget/api-web/tools
+ true
Property changes on: branches/2.4/MgDev/Desktop/nuget/api-web/tools/net40
+ true
Modified: branches/2.4/MgDev/Desktop/nuget/mapguide-api-base.nuspec
(Binary files differ)
Added: branches/2.4/MgDev/Desktop/nuget/mapguide-api-web.nuspec
Property changes on: branches/2.4/MgDev/Desktop/nuget/mapguide-api-web.nuspec
Added: svn:mime-type
+ application/octet-stream
Modified: branches/2.4/MgDev/Desktop/nuget_pack.bat
--- branches/2.4/MgDev/Desktop/nuget_pack.bat 2012-10-07 09:25:39 UTC (rev 7084)
+++ branches/2.4/MgDev/Desktop/nuget_pack.bat 2012-10-07 09:27:53 UTC (rev 7085)
@@ -3,4 +3,5 @@
nuget pack mapguide-api-base.nuspec -BasePath api-base
nuget pack mg-desktop-net40.nuspec -BasePath api-desktop
nuget pack mg-desktop-viewer-net40.nuspec -BasePath api-desktop-viewer
+nuget pack mapguide-api-web.nuspec -BasePath api-web
popd
Modified: branches/2.4/MgDev/Desktop/nuget_prepare.bat
--- branches/2.4/MgDev/Desktop/nuget_prepare.bat 2012-10-07 09:25:39 UTC (rev 7084)
+++ branches/2.4/MgDev/Desktop/nuget_prepare.bat 2012-10-07 09:27:53 UTC (rev 7085)
@@ -6,26 +6,55 @@
rem You must call setenvironment[64].bat first with any appropriate
rem parameters before calling this script
+SET NUGET_BASEDIR=%CD%\nuget
SET NUGET_TARGET=net40
-SET NUGET_CONTENT_BASE=%CD%\nuget\api-base\content\%NUGET_TARGET%\mapguide-api-base
-SET NUGET_LIB_BASE=%CD%\nuget\api-base\lib\%NUGET_TARGET%
-SET NUGET_CONTENT_DESKTOP=%CD%\nuget\api-desktop\content\%NUGET_TARGET%\mg-desktop
-SET NUGET_LIB_DESKTOP=%CD%\nuget\api-desktop\lib\%NUGET_TARGET%
-SET NUGET_CONTENT_VIEWER=%CD%\nuget\api-desktop-viewer\content\%NUGET_TARGET%\mg-desktop-viewer
-SET NUGET_LIB_VIEWER=%CD%\nuget\api-desktop-viewer\lib\%NUGET_TARGET%
+SET NUGET_CONTENT_BASE=%NUGET_BASEDIR%\api-base\content\%NUGET_TARGET%\mapguide-api-base
+SET NUGET_LIB_BASE=%NUGET_BASEDIR%\api-base\lib\%NUGET_TARGET%
+SET NUGET_CONTENT_DESKTOP=%NUGET_BASEDIR%\api-desktop\content\%NUGET_TARGET%\mg-desktop
+SET NUGET_LIB_DESKTOP=%NUGET_BASEDIR%\api-desktop\lib\%NUGET_TARGET%
+SET NUGET_CONTENT_VIEWER=%NUGET_BASEDIR%\api-desktop-viewer\content\%NUGET_TARGET%\mg-desktop-viewer
+SET NUGET_LIB_VIEWER=%NUGET_BASEDIR%\api-desktop-viewer\lib\%NUGET_TARGET%
+SET NUGET_CONTENT_WEB=%NUGET_BASEDIR%\api-web\content\%NUGET_TARGET%\mapguide-api-web
+SET NUGET_LIB_WEB=%NUGET_BASEDIR%\api-web\lib\%NUGET_TARGET%
+SET WEB_BASEDIR=%CD%\..\Web\bin\%TYPEBUILD%
+SET DESKTOP_BASEDIR=bin\%TYPEBUILD%
+SET SIGNER_ROOT=%CD%\DesktopUnmanagedApi\DotNet
echo [install]: Copy api-base files to nuget staging
-%XCOPY% "bin\%TYPEBUILD%\*" "%NUGET_CONTENT_BASE%" /EXCLUDE:package_excludes.txt+base_package_excludes.txt
-copy /y "bin\%TYPEBUILD%\OSGeo.MapGuide.Foundation.dll" "%NUGET_LIB_BASE%"
-copy /y "bin\%TYPEBUILD%\OSGeo.MapGuide.Geometry.dll" "%NUGET_LIB_BASE%"
-copy /y "bin\%TYPEBUILD%\OSGeo.MapGuide.PlatformBase.dll" "%NUGET_LIB_BASE%"
+%XCOPY% "%DESKTOP_BASEDIR%\*" "%NUGET_CONTENT_BASE%" /EXCLUDE:package_excludes.txt+base_package_excludes.txt
+copy /y "%DESKTOP_BASEDIR%\OSGeo.MapGuide.Foundation.dll" "%NUGET_LIB_BASE%"
+copy /y "%DESKTOP_BASEDIR%\OSGeo.MapGuide.Geometry.dll" "%NUGET_LIB_BASE%"
+copy /y "%DESKTOP_BASEDIR%\OSGeo.MapGuide.PlatformBase.dll" "%NUGET_LIB_BASE%"
+copy /y "%DESKTOP_BASEDIR%\OSGeo.MapGuide.Foundation.xml" "%NUGET_LIB_BASE%"
+copy /y "%DESKTOP_BASEDIR%\OSGeo.MapGuide.Geometry.xml" "%NUGET_LIB_BASE%"
+copy /y "%DESKTOP_BASEDIR%\OSGeo.MapGuide.PlatformBase.xml" "%NUGET_LIB_BASE%"
echo [install]: Copy api-desktop files to nuget staging
-%XCOPY% "bin\%TYPEBUILD%\*" "%NUGET_CONTENT_DESKTOP%" /EXCLUDE:package_excludes.txt+desktop_package_excludes.txt
-copy /y "bin\%TYPEBUILD%\OSGeo.MapGuide.Desktop.dll" "%NUGET_LIB_DESKTOP%"
+%XCOPY% "%DESKTOP_BASEDIR%\*" "%NUGET_CONTENT_DESKTOP%" /EXCLUDE:package_excludes.txt+desktop_package_excludes.txt
+copy /y "%DESKTOP_BASEDIR%\OSGeo.MapGuide.Desktop.dll" "%NUGET_LIB_DESKTOP%"
+echo [install]: Copy api-web files to nuget staging
+copy /y "%WEB_BASEDIR%\MgWebApp.dll" "%NUGET_CONTENT_WEB%"
+copy /y "%WEB_BASEDIR%\MgWebSupport.dll" "%NUGET_CONTENT_WEB%"
+copy /y "%WEB_BASEDIR%\MgMapGuideCommon.dll" "%NUGET_CONTENT_WEB%"
+copy /y "%WEB_BASEDIR%\MapGuideCommonUnmanagedApi.dll" "%NUGET_CONTENT_WEB%"
+copy /y "%WEB_BASEDIR%\lib_json.dll" "%NUGET_CONTENT_WEB%"
+copy /y "%WEB_BASEDIR%\WebUnmanagedApi.dll" "%NUGET_CONTENT_WEB%"
+copy /y "%WEB_BASEDIR%\OSGeo.MapGuide.MapGuideCommon.dll" "%NUGET_LIB_WEB%"
+copy /y "%WEB_BASEDIR%\OSGeo.MapGuide.Web.dll" "%NUGET_LIB_WEB%"
+copy /y "%WEB_BASEDIR%\OSGeo.MapGuide.MapGuideCommon.xml" "%NUGET_LIB_WEB%"
+copy /y "%WEB_BASEDIR%\OSGeo.MapGuide.Web.xml" "%NUGET_LIB_WEB%"
+copy /y "%SIGNER_ROOT%\SignMapGuideApi.exe" "%NUGET_LIB_WEB%"
+copy /y "%SIGNER_ROOT%\maestroapi.key" "%NUGET_LIB_WEB%"
+echo [build]: Signing MapGuide API assemblies
+pushd "%NUGET_LIB_WEB%"
+SignMapGuideApi.exe
+rd /S /Q Backup
+del maestroapi.key
+del SignMapGuideApi.exe
+popd
echo [install]: Copy api-desktop-viewer files to nuget staging
-copy /y "bin\%TYPEBUILD%\OSGeo.MapGuide.Viewer.xml" "%NUGET_LIB_VIEWER%"
-copy /y "bin\%TYPEBUILD%\OSGeo.MapGuide.Viewer.dll" "%NUGET_LIB_VIEWER%"
-copy /y "bin\%TYPEBUILD%\OSGeo.MapGuide.Viewer.Desktop.dll" "%NUGET_LIB_VIEWER%"
+copy /y "%DESKTOP_BASEDIR%\OSGeo.MapGuide.Viewer.xml" "%NUGET_LIB_VIEWER%"
+copy /y "%DESKTOP_BASEDIR%\OSGeo.MapGuide.Viewer.dll" "%NUGET_LIB_VIEWER%"
+copy /y "%DESKTOP_BASEDIR%\OSGeo.MapGuide.Viewer.Desktop.dll" "%NUGET_LIB_VIEWER%"
echo mg-desktop is ready for nuget packaging and publishing
goto quit
More information about the mapguide-commits
