[mapguide-commits] r7096 - in branches/2.4/MgDev/nuget/cs-map-dicts: . content tools/net40
svn_mapguide at osgeo.org
Mon Oct 8 06:55:53 PDT 2012
Author: jng
Date: 2012-10-08 06:55:53 -0700 (Mon, 08 Oct 2012)
New Revision: 7096
Added:
branches/2.4/MgDev/nuget/cs-map-dicts/content/
branches/2.4/MgDev/nuget/cs-map-dicts/content/cs-map-dummy-C008508B-11C9-40D0-B0CB-4AA35B6EE010.txt
branches/2.4/MgDev/nuget/cs-map-dicts/tools/net40/install.ps1
Add a dummy content file to force the cs-map nuget package to be project level.
Property changes on: branches/2.4/MgDev/nuget/cs-map-dicts/content
___________________________________________________________________
Added: bugtraq:number
+ true
Added: branches/2.4/MgDev/nuget/cs-map-dicts/content/cs-map-dummy-C008508B-11C9-40D0-B0CB-4AA35B6EE010.txt
--- branches/2.4/MgDev/nuget/cs-map-dicts/content/cs-map-dummy-C008508B-11C9-40D0-B0CB-4AA35B6EE010.txt (rev 0)
+++ branches/2.4/MgDev/nuget/cs-map-dicts/content/cs-map-dummy-C008508B-11C9-40D0-B0CB-4AA35B6EE010.txt 2012-10-08 13:55:53 UTC (rev 7096)
@@ -0,0 +1 @@
+This is a dummy file to force cs-map-dictionaries to not be a solution level nuget package. Dirty hack I know, but desperate times call for desperate measures :)
\ No newline at end of file
Modified: branches/2.4/MgDev/nuget/cs-map-dicts/tools/net40/install.ps1
--- branches/2.4/MgDev/nuget/cs-map-dicts/tools/net40/install.ps1 2012-10-08 12:50:46 UTC (rev 7095)
+++ branches/2.4/MgDev/nuget/cs-map-dicts/tools/net40/install.ps1 2012-10-08 13:55:53 UTC (rev 7096)
@@ -9,4 +9,8 @@
if (!$currentPostBuildCmd.Contains($CsMapDictPostBuildCmd)) {
$project.Properties.Item("PostBuildEvent").Value += $CsMapDictPostBuildCmd
Write-Host "Updated Post-Build event for project"
+$project.ProjectItems | ForEach { if ($_.Name -eq "cs-map-dummy-C008508B-11C9-40D0-B0CB-4AA35B6EE010.txt") { $_.Remove() } }
+$projectPath = Split-Path $project.FullName -Parent
+Join-Path $projectPath "cs-map-dummy-C008508B-11C9-40D0-B0CB-4AA35B6EE010.txt" | Remove-Item
More information about the mapguide-commits
