[mapguide-commits] r7100 - in trunk/MgDev: . nuget/cs-map-dicts nuget/cs-map-dicts/tools/net40
svn_mapguide at osgeo.org
Tue Oct 9 08:44:41 PDT 2012
Author: jng
Date: 2012-10-09 08:44:40 -0700 (Tue, 09 Oct 2012)
New Revision: 7100
Added:
trunk/MgDev/Desktop/
trunk/MgDev/base_package_excludes.txt
trunk/MgDev/desktop_package_excludes.txt
trunk/MgDev/dll_excludes.txt
trunk/MgDev/nuget/
trunk/MgDev/nuget/cs-map-dicts/content/
trunk/MgDev/nuget/cs-map-dicts/tools/net40/install.ps1
trunk/MgDev/nuget_pack.bat
trunk/MgDev/nuget_prepare.bat
trunk/MgDev/package_excludes.txt
trunk/MgDev/viewer_package_excludes.txt
Removed:
Add in desktop and nuget files from 2.4 branch
Copied: trunk/MgDev/base_package_excludes.txt (from rev 7094, branches/2.4/MgDev/base_package_excludes.txt)
--- trunk/MgDev/base_package_excludes.txt (rev 0)
+++ trunk/MgDev/base_package_excludes.txt 2012-10-09 15:44:40 UTC (rev 7100)
@@ -0,0 +1,43 @@
+Backup
+Logs
+Repositories
+FDO
+Temp
+Dictionaries
+Resources
+Schema
+OSGeo.MapGuide.Desktop.dll
+OSGeo.MapGuide.Viewer.dll
+OSGeo.MapGuide.Viewer.Desktop.dll
+OSGeo.MapGuide.Viewer.xml
+MapGuideDesktopUnmanagedApi.dll
+Platform.ini
+gd.dll
+MgGwsCommon.dll
+MgGwsQueryEngine.dll
+MgGwsResource.dll
+MgDesktop.dll
+MgRenderers.dll
+MgStylization.dll
+OSGeo.MapGuide.Foundation.dll
+OSGeo.MapGuide.Geometry.dll
+OSGeo.MapGuide.PlatformBase.dll
+OSGeo.MapGuide.Foundation.xml
+OSGeo.MapGuide.Geometry.xml
+OSGeo.MapGuide.PlatformBase.xml
+maestroapi.key
+DotNetHarness.exe
+DotNetHarness.exe.config
+DotNetHarness.vshost.exe
+DotNetHarness.vshost.exe.config
+DotNetHarness.vshost.exe.manifest
+DotNetUnitTest.exe
+DotNetUnitTest.exe.config
+MapViewerTest.exe
+MapViewerTest.exe.config
+SignMapGuideApi.exe
+UnitTest.exe
+SampleExtension.dll
+Sheboygan.AppLayout
+SheboyganTiled.AppLayout
+MgAppLayout.exe
\ No newline at end of file
Copied: trunk/MgDev/desktop_package_excludes.txt (from rev 7094, branches/2.4/MgDev/desktop_package_excludes.txt)
--- trunk/MgDev/desktop_package_excludes.txt (rev 0)
+++ trunk/MgDev/desktop_package_excludes.txt 2012-10-09 15:44:40 UTC (rev 7100)
@@ -0,0 +1,39 @@
+Backup
+Logs
+Temp
+Repositories
+Dictionaries
+ACE.dll
+FoundationUnmanagedApi.dll
+GeometryUnmanagedApi.dll
+GEOS.dll
+MgFoundation.dll
+MgGeometry.dll
+MgMdfModel.dll
+MgMdfParser.dll
+MgPlatformBase.dll
+PlatformBaseUnmanagedApi.dll
+xerces-c_3_1mg.dll
+maestroapi.key
+DotNetHarness.exe
+DotNetUnitTest.exe
+MapViewerTest.exe
+UnitTest.exe
+MgAppLayout.exe
Copied: trunk/MgDev/dll_excludes.txt (from rev 7094, branches/2.4/MgDev/dll_excludes.txt)
--- trunk/MgDev/dll_excludes.txt (rev 0)
+++ trunk/MgDev/dll_excludes.txt 2012-10-09 15:44:40 UTC (rev 7100)
@@ -0,0 +1,9 @@
+MgMapGuideCommon.dll
Deleted: trunk/MgDev/nuget/cs-map-dicts/tools/net40/install.ps1
--- branches/2.4/MgDev/nuget/cs-map-dicts/tools/net40/install.ps1 2012-10-08 12:04:00 UTC (rev 7094)
+++ trunk/MgDev/nuget/cs-map-dicts/tools/net40/install.ps1 2012-10-09 15:44:40 UTC (rev 7100)
@@ -1,12 +0,0 @@
-param($installPath, $toolsPath, $package, $project)
-. (Join-Path $toolsPath "GetCsMapDictPostBuildCmd.ps1")
-# Get the current Post Build Event cmd
-$currentPostBuildCmd = $project.Properties.Item("PostBuildEvent").Value
-# Append our post build command if it's not already there
-if (!$currentPostBuildCmd.Contains($CsMapDictPostBuildCmd)) {
- $project.Properties.Item("PostBuildEvent").Value += $CsMapDictPostBuildCmd
- Write-Host "Updated Post-Build event for project"
Copied: trunk/MgDev/nuget/cs-map-dicts/tools/net40/install.ps1 (from rev 7096, branches/2.4/MgDev/nuget/cs-map-dicts/tools/net40/install.ps1)
--- trunk/MgDev/nuget/cs-map-dicts/tools/net40/install.ps1 (rev 0)
@@ -0,0 +1,16 @@
+param($installPath, $toolsPath, $package, $project)
+. (Join-Path $toolsPath "GetCsMapDictPostBuildCmd.ps1")
+# Get the current Post Build Event cmd
+$currentPostBuildCmd = $project.Properties.Item("PostBuildEvent").Value
+# Append our post build command if it's not already there
+if (!$currentPostBuildCmd.Contains($CsMapDictPostBuildCmd)) {
+ $project.Properties.Item("PostBuildEvent").Value += $CsMapDictPostBuildCmd
+ Write-Host "Updated Post-Build event for project"
+$project.ProjectItems | ForEach { if ($_.Name -eq "cs-map-dummy-C008508B-11C9-40D0-B0CB-4AA35B6EE010.txt") { $_.Remove() } }
+$projectPath = Split-Path $project.FullName -Parent
+Join-Path $projectPath "cs-map-dummy-C008508B-11C9-40D0-B0CB-4AA35B6EE010.txt" | Remove-Item
Copied: trunk/MgDev/nuget_pack.bat (from rev 7094, branches/2.4/MgDev/nuget_pack.bat)
--- trunk/MgDev/nuget_pack.bat (rev 0)
+++ trunk/MgDev/nuget_pack.bat 2012-10-09 15:44:40 UTC (rev 7100)
@@ -0,0 +1,10 @@
+ at echo off
+SET MG_CPU=x86
+IF NOT "%1" == "" SET MG_CPU=%1
+pushd nuget
+nuget pack mapguide-api-base-%MG_CPU%.nuspec -BasePath %MG_CPU%\api-base
+nuget pack mg-desktop-net40-%MG_CPU%.nuspec -BasePath %MG_CPU%\api-desktop
+nuget pack mg-desktop-viewer-net40-%MG_CPU%.nuspec -BasePath %MG_CPU%\api-desktop-viewer
+nuget pack mapguide-api-web-%MG_CPU%.nuspec -BasePath %MG_CPU%\api-web
+nuget pack cs-map-dictionaries.nuspec -BasePath cs-map-dicts
+popd
Copied: trunk/MgDev/nuget_prepare.bat (from rev 7094, branches/2.4/MgDev/nuget_prepare.bat)
--- trunk/MgDev/nuget_prepare.bat (rev 0)
+++ trunk/MgDev/nuget_prepare.bat 2012-10-09 15:44:40 UTC (rev 7100)
@@ -0,0 +1,149 @@
+ at echo off
+rem Top-level build script for mg-desktop
+rem
+rem Author: Jackie Ng (jumpinjackie at gmail.com)
+rem
+rem You must call setenvironment[64].bat first with any appropriate
+rem parameters before calling this script
+SET MG_VERSION=2.4.0.0
+SET MG_CPU=x86
+IF NOT "%1" == "" SET MG_VERSION=%1
+IF NOT "%2" == "" SET MG_CPU=%2
+echo Version: %MG_VERSION%
+echo CPU: %MG_CPU%
+IF "%MG_CPU%" == "x64" (
+ SET TYPEBUILD=release64
+) ELSE (
+SET NUGET_ROOT=%CD%\nuget
+SET NUGET_BASEDIR=%NUGET_ROOT%\%MG_CPU%
+SET NUGET_TARGET=net40
+SET NUGET_BASE_ROOT=%NUGET_BASEDIR%\api-base
+SET NUGET_CONTENT_BASE=%NUGET_BASE_ROOT%\mapguide-api-base
+SET NUGET_LIB_BASE=%NUGET_BASE_ROOT%\lib\%NUGET_TARGET%
+SET NUGET_DESKTOP_ROOT=%NUGET_BASEDIR%\api-desktop
+SET NUGET_CONTENT_DESKTOP=%NUGET_DESKTOP_ROOT%\mg-desktop
+SET NUGET_LIB_DESKTOP=%NUGET_DESKTOP_ROOT%\lib\%NUGET_TARGET%
+SET NUGET_VIEWER_ROOT=%NUGET_BASEDIR%\api-desktop-viewer
+SET NUGET_CONTENT_VIEWER=%NUGET_VIEWER_ROOT%\mg-desktop-viewer
+SET NUGET_LIB_VIEWER=%NUGET_VIEWER_ROOT%\lib\%NUGET_TARGET%
+SET NUGET_WEB_ROOT=%NUGET_BASEDIR%\api-web
+SET NUGET_CONTENT_WEB=%NUGET_WEB_ROOT%\mapguide-api-web
+SET NUGET_LIB_WEB=%NUGET_WEB_ROOT%\lib\%NUGET_TARGET%
+SET NUGET_CSMAP_ROOT=%NUGET_ROOT%\cs-map-dicts
+SET NUGET_CONTENT_CSMAP=%NUGET_CSMAP_ROOT%\dictionaries
+SET WEB_BASEDIR=%CD%\Web\bin\%TYPEBUILD%
+SET DESKTOP_SRC=%CD%\Desktop\MgDesktop
+SET DESKTOP_BASEDIR=%CD%\%TYPEBUILD%\Desktop
+SET SIGNER_ROOT=%CD%\Desktop\DesktopUnmanagedApi\DotNet
+IF NOT EXIST "%DESKTOP_BASEDIR%" (
+ echo mg-desktop base directory not found: %DESKTOP_BASEDIR%
+ goto error
+) ELSE (
+ echo mg-desktop base directory: %DESKTOP_BASEDIR%
+IF NOT EXIST "%WEB_BASEDIR%" (
+ echo MapGuide Web base directory not found: %WEB_BASEDIR%
+ goto error
+) ELSE (
+ echo MapGuide Web base directory: %WEB_BASEDIR%
+IF NOT EXIST "%DESKTOP_BASEDIR%\Dictionaries" (
+ echo CS-Map dictionaries directory not found: "%DESKTOP_BASEDIR%\Dictionaries"
+ goto error
+) ELSE (
+ echo CS-Map dictionaries directory: "%DESKTOP_BASEDIR%\Dictionaries"
+IF NOT EXIST "%SIGNER_ROOT%" (
+ echo Signer root directory not found: %SIGNER_ROOT%
+ goto error
+) ELSE (
+ echo Signer root directory: %SIGNER_ROOT%
+IF NOT EXIST "%NUGET_CONTENT_BASE%" MKDIR "%NUGET_CONTENT_BASE%"
+IF NOT EXIST "%NUGET_CONTENT_DESKTOP%" MKDIR "%NUGET_CONTENT_DESKTOP%"
+IF NOT EXIST "%NUGET_CONTENT_WEB%" MKDIR "%NUGET_CONTENT_WEB%"
+IF NOT EXIST "%NUGET_CONTENT_CSMAP%" MKDIR "%NUGET_CONTENT_CSMAP%"
+echo [install]: Copy api-base files to nuget staging
+xcopy /S /Y "%DESKTOP_BASEDIR%\*" "%NUGET_CONTENT_BASE%" /EXCLUDE:package_excludes.txt+base_package_excludes.txt
+xcopy /Y /I "%DESKTOP_BASEDIR%\OSGeo.MapGuide.Foundation.dll" "%NUGET_LIB_BASE%"
+xcopy /Y /I "%DESKTOP_BASEDIR%\OSGeo.MapGuide.Geometry.dll" "%NUGET_LIB_BASE%"
+xcopy /Y /I "%DESKTOP_BASEDIR%\OSGeo.MapGuide.PlatformBase.dll" "%NUGET_LIB_BASE%"
+xcopy /Y /I "%DESKTOP_BASEDIR%\OSGeo.MapGuide.Foundation.xml" "%NUGET_LIB_BASE%"
+xcopy /Y /I "%DESKTOP_BASEDIR%\OSGeo.MapGuide.Geometry.xml" "%NUGET_LIB_BASE%"
+xcopy /Y /I "%DESKTOP_BASEDIR%\OSGeo.MapGuide.PlatformBase.xml" "%NUGET_LIB_BASE%"
+echo [install]: Copy api-desktop files to nuget staging
+xcopy /S /Y "%DESKTOP_BASEDIR%\*" "%NUGET_CONTENT_DESKTOP%" /EXCLUDE:package_excludes.txt+desktop_package_excludes.txt
+xcopy /Y /I "%DESKTOP_BASEDIR%\OSGeo.MapGuide.Desktop.dll" "%NUGET_LIB_DESKTOP%"
+echo [install]: Copy api-web files to nuget staging
+REM Just in case
+DoxyTransform.exe dotnet "%MG_DOC_XML%" "%WEB_BASEDIR%"
+xcopy /Y /I "%WEB_BASEDIR%\MgWebApp.dll" "%NUGET_CONTENT_WEB%"
+xcopy /Y /I "%WEB_BASEDIR%\MgWebSupport.dll" "%NUGET_CONTENT_WEB%"
+xcopy /Y /I "%WEB_BASEDIR%\MgHttpHandler.dll" "%NUGET_CONTENT_WEB%"
+xcopy /Y /I "%WEB_BASEDIR%\MgMapGuideCommon.dll" "%NUGET_CONTENT_WEB%"
+xcopy /Y /I "%WEB_BASEDIR%\MapGuideCommonUnmanagedApi.dll" "%NUGET_CONTENT_WEB%"
+xcopy /Y /I "%WEB_BASEDIR%\lib_json.dll" "%NUGET_CONTENT_WEB%"
+xcopy /Y /I "%WEB_BASEDIR%\WebUnmanagedApi.dll" "%NUGET_CONTENT_WEB%"
+xcopy /Y /I "%WEB_BASEDIR%\OSGeo.MapGuide.MapGuideCommon.dll" "%NUGET_LIB_WEB%"
+xcopy /Y /I "%WEB_BASEDIR%\OSGeo.MapGuide.Web.dll" "%NUGET_LIB_WEB%"
+xcopy /Y /I "%WEB_BASEDIR%\OSGeo.MapGuide.MapGuideCommon.xml" "%NUGET_LIB_WEB%"
+xcopy /Y /I "%WEB_BASEDIR%\OSGeo.MapGuide.Web.xml" "%NUGET_LIB_WEB%"
+xcopy /Y /I "%SIGNER_ROOT%\SignMapGuideApi.exe" "%NUGET_LIB_WEB%"
+xcopy /Y /I "%SIGNER_ROOT%\maestroapi.key" "%NUGET_LIB_WEB%"
+echo [install]: Copy cs-map dictionaries to nuget staging
+xcopy /S /Y "%DESKTOP_BASEDIR%\Dictionaries\*" "%NUGET_CONTENT_CSMAP%"
+echo [build]: Signing MapGuide API assemblies
+pushd "%NUGET_LIB_WEB%"
+rd /S /Q Backup
+del maestroapi.key
+del SignMapGuideApi.exe
+popd
+echo [install]: Copy api-desktop-viewer files to nuget staging
+xcopy /Y /I "%DESKTOP_BASEDIR%\OSGeo.MapGuide.Viewer.xml" "%NUGET_LIB_VIEWER%"
+xcopy /Y /I "%DESKTOP_BASEDIR%\OSGeo.MapGuide.Viewer.dll" "%NUGET_LIB_VIEWER%"
+xcopy /Y /I "%DESKTOP_BASEDIR%\OSGeo.MapGuide.Viewer.Desktop.dll" "%NUGET_LIB_VIEWER%"
+echo [prepare]: Nuspec files for %MG_VERSION% (%MG_CPU%)
+REM prep nuspec files
+pushd "%NUGET_ROOT%"
+echo [prepare]: mapguide-api-base
+call BatchSubstitute.bat MG_CPU %MG_CPU% mapguide-api-base.nuspec.tpl > temp.txt
+call BatchSubstitute.bat MG_VERSION %MG_VERSION% temp.txt > mapguide-api-base-%MG_CPU%.nuspec
+echo [prepare]: mapguide-api-web
+call BatchSubstitute.bat MG_CPU %MG_CPU% mapguide-api-web.nuspec.tpl > temp.txt
+call BatchSubstitute.bat MG_VERSION %MG_VERSION% temp.txt > mapguide-api-web-%MG_CPU%.nuspec
+echo [prepare]: mg-desktop-net40
+call BatchSubstitute.bat MG_CPU %MG_CPU% mg-desktop-net40.nuspec.tpl > temp.txt
+call BatchSubstitute.bat MG_VERSION %MG_VERSION% temp.txt > mg-desktop-net40-%MG_CPU%.nuspec
+echo [prepare]: mg-desktop-viewer-net40
+call BatchSubstitute.bat MG_CPU %MG_CPU% mg-desktop-viewer-net40.nuspec.tpl > temp.txt
+call BatchSubstitute.bat MG_VERSION %MG_VERSION% temp.txt > mg-desktop-viewer-net40-%MG_CPU%.nuspec
+echo [prepare]: cs-map-dictionaries
+call BatchSubstitute.bat MG_CPU %MG_CPU% cs-map-dictionaries.nuspec.tpl > temp.txt
+call BatchSubstitute.bat MG_VERSION %MG_VERSION% temp.txt > cs-map-dictionaries.nuspec
+del temp.txt
+echo [prepare]: NuGet Package readmes
+type api-base-readme.txt > "%NUGET_BASE_ROOT%\readme.txt"
+type api-desktop-readme.txt > "%NUGET_DESKTOP_ROOT%\readme.txt"
+type "%DESKTOP_SRC%\changelog.txt" >> "%NUGET_DESKTOP_ROOT%\readme.txt"
+type api-desktop-viewer-readme.txt > "%NUGET_VIEWER_ROOT%\readme.txt"
+type "%DESKTOP_SRC%\changelog.txt" >> "%NUGET_VIEWER_ROOT%\readme.txt"
+type api-web-readme.txt > "%NUGET_WEB_ROOT%\readme.txt"
+type cs-map-dict-readme.txt > "%NUGET_CSMAP_ROOT%\readme.txt"
+popd
+echo mg-desktop is ready for nuget packaging and publishing
+goto quit
+:error
+echo [ERROR]: There was an error building the component
+exit /B 1
+:quit
Copied: trunk/MgDev/package_excludes.txt (from rev 7094, branches/2.4/MgDev/package_excludes.txt)
--- trunk/MgDev/package_excludes.txt (rev 0)
+++ trunk/MgDev/package_excludes.txt 2012-10-09 15:44:40 UTC (rev 7100)
@@ -0,0 +1,18 @@
+.pdb
+.exp
+.lib
+OSGeo.FDO.dll
+OSGeo.FDO.Common.dll
+OSGeo.FDO.Geometry.dll
+OSGeo.FDO.Spatial.dll
+OSGeo.FDO.Providers.MySQL.Overrides.dll
+OSGeo.FDO.Providers.ODBC.Overrides.dll
+OSGeo.FDO.Providers.Rdbms.dll
+OSGeo.FDO.Providers.Rdbms.Overrides.dll
+OSGeo.FDO.Providers.SHP.Overrides.dll
+OSGeo.FDO.Providers.SQLServerSpatial.Overrides.dll
+OSGeo.FDO.Providers.WMS.Overrides.dll
Copied: trunk/MgDev/viewer_package_excludes.txt (from rev 7094, branches/2.4/MgDev/viewer_package_excludes.txt)
--- trunk/MgDev/viewer_package_excludes.txt (rev 0)
+++ trunk/MgDev/viewer_package_excludes.txt 2012-10-09 15:44:40 UTC (rev 7100)
@@ -0,0 +1,48 @@
+Backup
+Logs
+Repositories
+FDO
+Dictionaries
+Resources
+Schema
+Platform.ini
+gd.dll
+MgGwsCommon.dll
+MgGwsResource.dll
+MgDesktop.dll
+MgRenderers.dll
+MgStylization.dll
+ACE.dll
+GEOS.dll
+MgFoundation.dll
+MgGeometry.dll
+MgMdfModel.dll
+MgMdfParser.dll
+MgPlatformBase.dll
+xerces-c_3_1mg.dll
+maestroapi.key
+DotNetHarness.exe
+DotNetUnitTest.exe
+MapViewerTest.exe
+UnitTest.exe
+MgAppLayout.exe
More information about the mapguide-commits
