[mapguide-commits] r7125 - in trunk/Tools/Maestro: MaestroAPITestRunner MaestroAPITests OSGeo.MapGuide.MaestroAPI OSGeo.MapGuide.MaestroAPI/ObjectModels OSGeo.MapGuide.MaestroAPI/SchemaOverrides OSGeo.MapGuide.MaestroAPI/Services OSGeo.MapGuide.MaestroAPI.Http OSGeo.MapGuide.MaestroAPI.Local OSGeo.MapGuide.MaestroAPI.Native
svn_mapguide at osgeo.org
Wed Oct 17 06:29:39 PDT 2012
Author: jng
Date: 2012-10-17 06:29:39 -0700 (Wed, 17 Oct 2012)
New Revision: 7125
Added:
trunk/Tools/Maestro/MaestroAPITests/ConnectionTestBase.cs
trunk/Tools/Maestro/MaestroAPITests/LocalConnectionTests.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/LongTransaction.cs
trunk/Tools/Maestro/MaestroAPITestRunner/MaestroAPITestRunner.csproj
trunk/Tools/Maestro/MaestroAPITests/HttpConnectionTests.cs
trunk/Tools/Maestro/MaestroAPITests/LocalNativeFeatureTests.cs
trunk/Tools/Maestro/MaestroAPITests/MaestroAPITests.csproj
trunk/Tools/Maestro/MaestroAPITests/ObjectTests.cs
trunk/Tools/Maestro/MaestroAPITests/ValidationTests.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/RequestBuilder.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Local/LocalConnection.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeConnection.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/ConfigurationDocument.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Services/IFeatureService.cs
This submission contains the following changes:
- #2152: Expose the GetSchemaMapping API to IFeatureService, we'll be using this to construct default WMS configuration documents. A unit test has been added to excercise this API
- Restructure the connection-based test fixtures. Since most of these tests are the same with the only difference being the IServerConnection implementation we're testing against, these test fixtures now all inherit from a ConnectionTestBase class that defines all of the common tests. Ones that are applicable for a given provider are overridden in the subclass and have the [Test] attribute applied so NUnit will execute them.
- Expose the GetLongTransactions API to IFeatureService
Modified: trunk/Tools/Maestro/MaestroAPITestRunner/MaestroAPITestRunner.csproj
--- trunk/Tools/Maestro/MaestroAPITestRunner/MaestroAPITestRunner.csproj 2012-10-17 06:46:38 UTC (rev 7124)
+++ trunk/Tools/Maestro/MaestroAPITestRunner/MaestroAPITestRunner.csproj 2012-10-17 13:29:39 UTC (rev 7125)
@@ -83,7 +83,7 @@
<Name>MaestroAPITests</Name>
</ProjectReference>
<ProjectReference Include="..\OSGeo.MapGuide.MaestroAPI.Local\OSGeo.MapGuide.MaestroAPI.Local.csproj">
- <Project>{3DDF6501-0148-474C-8674-7C7DA49C7F02}</Project>
+ <Project>{3ddf6501-0148-474c-8674-7c7da49c7f02}</Project>
<Name>OSGeo.MapGuide.MaestroAPI.Local</Name>
</ProjectReference>
<ProjectReference Include="..\OSGeo.MapGuide.MaestroAPI\OSGeo.MapGuide.MaestroAPI.csproj">
Added: trunk/Tools/Maestro/MaestroAPITests/ConnectionTestBase.cs
--- trunk/Tools/Maestro/MaestroAPITests/ConnectionTestBase.cs (rev 0)
+++ trunk/Tools/Maestro/MaestroAPITests/ConnectionTestBase.cs 2012-10-17 13:29:39 UTC (rev 7125)
@@ -0,0 +1,535 @@
+#region Disclaimer / License
+// Copyright (C) 2012, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.Text;
+using NUnit.Framework;
+using OSGeo.MapGuide.MaestroAPI;
+using OSGeo.MapGuide.MaestroAPI.Services;
+using OSGeo.MapGuide.MaestroAPI.Resource;
+using System.IO;
+using OSGeo.MapGuide.ObjectModels.Common;
+using OSGeo.MapGuide.ObjectModels;
+using OSGeo.MapGuide.MaestroAPI.SchemaOverrides;
+using System;
+using System.IO;
+using System.Linq;
+using System.Text;
+using OSGeo.MapGuide.MaestroAPI.Schema;
+using OSGeo.MapGuide.MaestroAPI.Commands;
+using OSGeo.MapGuide.MaestroAPI.CoordinateSystem;
+using OSGeo.MapGuide.MaestroAPI.Internal;
+using OSGeo.MapGuide.MaestroAPI.Feature;
+namespace MaestroAPITests
+ public abstract class ConnectionTestBase
+ protected abstract IServerConnection CreateTestConnection();
+ protected void TestFeatureSourceCaching(string fsName)
+ var conn = CreateTestConnection();
+ string fsId = "Library://UnitTests/" + fsName + ".FeatureSource";
+ if (!conn.ResourceService.ResourceExists(fsId))
+ var fs = ObjectFactory.CreateFeatureSource(conn, "OSGeo.SDF");
+ fs.SetConnectionProperty("File", "%MG_DATA_FILE_PATH%Sheboygan_Parcels.sdf");
+ fs.ResourceID = fsId;
+ conn.ResourceService.SaveResourceAs(fs, fsId);
+ using (var stream = File.OpenRead("TestData/FeatureService/SDF/Sheboygan_Parcels.sdf"))
+ fs.SetResourceData("Sheboygan_Parcels.sdf", ResourceDataType.File, stream);
+ Assert.True(Convert.ToBoolean(conn.FeatureService.TestConnection(fsId)));
+ var pc = (PlatformConnectionBase)conn;
+ pc.ResetFeatureSourceSchemaCache();
+ Assert.AreEqual(0, pc.CachedClassDefinitions);
+ Assert.AreEqual(0, pc.CachedFeatureSources);
+ var fsd = conn.FeatureService.DescribeFeatureSource(fsId);
+ Assert.AreEqual(1, pc.CachedFeatureSources);
+ Assert.AreEqual(1, pc.CachedClassDefinitions);
+ var fsd2 = conn.FeatureService.DescribeFeatureSource(fsId);
+ //Each cached instance returned is a clone
+ Assert.False(object.ReferenceEquals(fsd, fsd2));
+ protected void TestClassDefinitionCaching(string fsName)
+ var conn = ConnectionUtil.CreateTestHttpConnection();
+ var cls = conn.FeatureService.GetClassDefinition(fsId, "SHP_Schema:Parcels");
+ var cls2 = conn.FeatureService.GetClassDefinition(fsId, "SHP_Schema:Parcels");
+ Assert.False(object.ReferenceEquals(cls, cls2));
+ protected void CreateTestDataStore(IServerConnection conn, string fsId, ref FeatureSchema schema, ref ClassDefinition cls)
+ schema = new FeatureSchema("Default", "");
+ cls = new ClassDefinition("Class1", "");
+ try
+ if (conn.ResourceService.ResourceExists(fsId))
+ conn.ResourceService.DeleteResource(fsId);
+ cls.DefaultGeometryPropertyName = "GEOM";
+ cls.AddProperty(new DataPropertyDefinition("KEY", "")
+ DataType = DataPropertyType.Int32,
+ IsAutoGenerated = true,
+ IsReadOnly = true,
+ IsNullable = false
+ }, true);
+ cls.AddProperty(new DataPropertyDefinition("NAME", "")
+ DataType = DataPropertyType.String,
+ Length = 255,
+ IsNullable = true,
+ IsReadOnly = false
+ cls.AddProperty(new GeometricPropertyDefinition("GEOM", "")
+ GeometricTypes = FeatureGeometricType.Point,
+ SpatialContextAssociation = "Default"
+ schema.AddClass(cls);
+ ICreateDataStore create = (ICreateDataStore)conn.CreateCommand((int)CommandType.CreateDataStore);
+ CoordinateSystemDefinitionBase coordSys = conn.CoordinateSystemCatalog.FindCoordSys("LL84");
+ create.FeatureSourceId = fsId;
+ create.CoordinateSystemWkt = coordSys.WKT;
+ create.Name = "Default";
+ create.ExtentType = OSGeo.MapGuide.ObjectModels.Common.FdoSpatialContextListSpatialContextExtentType.Dynamic;
+ create.FileName = "Test.sdf";
+ create.Provider = "OSGeo.SDF";
+ create.Schema = schema;
+ create.XYTolerance = 0.001;
+ create.ZTolerance = 0.001;
+ create.Execute();
+ catch
+ schema = null;
+ cls = null;
+ throw;
+ protected void PopulateTestDataStore(IServerConnection conn, string fsId, ref FeatureSchema schema, ref ClassDefinition cls)
+ CreateTestDataStore(conn, fsId, ref schema, ref cls);
+ IInsertFeatures insert = (IInsertFeatures)conn.CreateCommand((int)CommandType.InsertFeature);
+ insert.ClassName = cls.Name;
+ insert.FeatureSourceId = fsId;
+ var feat = new MutableRecord();
+ var reader = new FixedWKTReader();
+ //Initialize this record
+ feat.PutValue("GEOM", new GeometryValue(reader.Read("POINT (0 0)")));
+ feat.PutValue("NAME", new StringValue("Test1"));
+ //Attach to command.
+ insert.RecordToInsert = feat;
+ var res = insert.Execute();
+ feat.SetGeometry("GEOM", reader.Read("POINT (0 1)"));
+ feat.SetString("NAME", "Test2");
+ res = insert.Execute();
+ feat.SetGeometry("GEOM", reader.Read("POINT (1 1)"));
+ feat.SetString("NAME", "Test3");
+ feat.SetGeometry("GEOM", reader.Read("POINT (1 0)"));
+ feat.SetString("NAME", "Test4");
+ public virtual void TestInsertFeatures()
+ var fsId = "Library://UnitTests/Data/TestInsertFeatures.FeatureSource";
+ ClassDefinition cls = null;
+ FeatureSchema schema = null;
+ Assert.True(feat.PropertyExists("GEOM"));
+ Assert.True(feat.PropertyExists("NAME"));
+ Assert.Null(res.Error);
+ int count = 0;
+ using (var rdr = conn.FeatureService.QueryFeatureSource(fsId, cls.Name))
+ while (rdr.ReadNext())
+ count++;
+ rdr.Close();
+ Assert.AreEqual(4, count);
+ public virtual void TestUpdateFeatures()
+ var fsId = "Library://UnitTests/Data/TestUpdateFeatures.FeatureSource";
+ PopulateTestDataStore(conn, fsId, ref schema, ref cls);
+ IUpdateFeatures update = (IUpdateFeatures)conn.CreateCommand((int)CommandType.UpdateFeatures);
+ update.ClassName = cls.Name;
+ update.FeatureSourceId = fsId;
+ update.Filter = "NAME = 'Test4'";
+ update.ValuesToUpdate = new MutableRecord();
+ update.ValuesToUpdate.PutValue("NAME", new StringValue("Test4Modified"));
+ Assert.AreEqual(1, update.Execute());
+ public virtual void TestDeleteFeatures()
+ var fsId = "Library://UnitTests/Data/TestDeleteFeatures.FeatureSource";
+ IDeleteFeatures delete = (IDeleteFeatures)conn.CreateCommand((int)CommandType.DeleteFeatures);
+ delete.ClassName = cls.Name;
+ delete.FeatureSourceId = fsId;
+ delete.Filter = "NAME = 'Test4'";
+ Assert.AreEqual(1, delete.Execute());
+ int count = 0;
+ while (rdr.ReadNext()) { count++; }
+ Assert.AreEqual(3, count);
+ public virtual void TestCreateDataStore()
+ var fsId = "Library://UnitTests/Data/TestCreateDataStore.FeatureSource";
+ ClassDefinition cls2 = conn.FeatureService.GetClassDefinition(fsId, "Class1");
+ Assert.NotNull(cls2);
+ Assert.False(ClassDefinition.ReferenceEquals(cls, cls2));
+ Assert.AreEqual(cls.Name, cls2.Name);
+ Assert.AreEqual(cls.DefaultGeometryPropertyName, cls2.DefaultGeometryPropertyName);
+ Assert.AreEqual(cls.Properties.Count, cls2.Properties.Count);
+ Assert.AreEqual(cls.IdentityProperties.Count, cls2.IdentityProperties.Count);
+ foreach (var prop in cls.Properties)
+ var prop2 = cls2.FindProperty(prop.Name);
+ Assert.AreEqual(prop.Name, prop2.Name);
+ Assert.AreEqual(prop.Type, prop2.Type);
+ public virtual void TestApplySchema()
+ var fsId = "Library://UnitTests/Data/TestMaestroLocalApplySchema.FeatureSource";
+ cls.AddProperty(new DataPropertyDefinition("ExtraProp", "")
+ IsNullable = false,
+ Length = 255
+ //Apply changes
+ IApplySchema cmd = (IApplySchema)conn.CreateCommand((int)CommandType.ApplySchema);
+ cmd.Schema = schema;
+ cmd.FeatureSourceId = fsId;
+ cmd.Execute();
+ ClassDefinition cls2 = conn.FeatureService.GetClassDefinition(cmd.FeatureSourceId, "Class1");
+ //[Test]
+ public virtual void TestEncryptedFeatureSourceCredentials()
+ //Sensitive data redacted, nevertheless you can test and verify this by filling in the
+ //blanks here and uncommenting the above [Test] attribute. If the test passes, credential encryption is working
+ string server = "";
+ string database = "";
+ string actualUser = "";
+ string actualPass = "";
+ string bogusUser = "foo";
+ string bogusPass = "bar";
+ string fsId = "Library://UnitTests/EncryptedCredentials.FeatureSource";
+ var fs = ObjectFactory.CreateFeatureSource(conn, "OSGeo.SQLServerSpatial");
+ fs.SetConnectionProperty("Username", "%MG_USERNAME%");
+ fs.SetConnectionProperty("Password", "%MG_PASSWORD%");
+ fs.SetConnectionProperty("Service", server);
+ fs.SetConnectionProperty("DataStore", database);
+ conn.ResourceService.SaveResource(fs);
+ using (var ms = CredentialWriter.Write(actualUser, actualPass))
+ conn.ResourceService.SetResourceData(fsId, "MG_USER_CREDENTIALS", ResourceDataType.String, ms);
+ string result = conn.FeatureService.TestConnection(fsId);
+ Assert.AreEqual("TRUE", result.ToUpper());
+ //Test convenience method
+ fsId = "Library://UnitTests/EncryptedCredentials2.FeatureSource";
+ fs = ObjectFactory.CreateFeatureSource(conn, "OSGeo.SQLServerSpatial");
+ fs.SetEncryptedCredentials(actualUser, actualPass);
+ result = conn.FeatureService.TestConnection(fsId);
+ Assert.AreEqual(actualUser, fs.GetEncryptedUsername());
+ //Do not set encrypted credentials
+ fsId = "Library://UnitTests/EncryptedCredentials3.FeatureSource";
+ try
+ Assert.AreEqual("FALSE", result.ToUpper());
+ catch //Exception or false I can't remember, as long as the result is not "true"
+ //Encrypt credentials, but use bogus username/password
+ fsId = "Library://UnitTests/EncryptedCredentials4.FeatureSource";
+ fs.SetEncryptedCredentials(bogusUser, bogusPass);
+ try
+ catch
+ //Exception or false I can't remember, as long as the result is not "true"
+ Assert.AreEqual(bogusUser, fs.GetEncryptedUsername());
+ public virtual void TestTouch()
+ var resSvc = conn.ResourceService;
+ if (!resSvc.ResourceExists("Library://UnitTests/Data/HydrographicPolygons.FeatureSource"))
+ resSvc.SetResourceXmlData("Library://UnitTests/Data/HydrographicPolygons.FeatureSource", File.OpenRead("TestData/MappingService/UT_HydrographicPolygons.fs"));
+ resSvc.Touch("Library://UnitTests/Data/HydrographicPolygons.FeatureSource");
+ public virtual void TestAnyStreamInput()
+ string source = "Library://UnitTests/Data/HydrographicPolygons.FeatureSource";
+ string target = "Library://UnitTests/Data/TestAnyStreamInput.FeatureSource";
+ if (!resSvc.ResourceExists(source))
+ resSvc.SetResourceXmlData(source, File.OpenRead("TestData/MappingService/UT_HydrographicPolygons.fs"));
+ resSvc.SetResourceXmlData(target, resSvc.GetResourceXmlData(source));
+ string dataName = "UT_HydrographicPolygons.sdf";
+ var resDataList = resSvc.EnumerateResourceData(source);
+ if (resDataList.ResourceData.Count == 1)
+ dataName = resDataList.ResourceData[0].Name;
+ else
+ resSvc.SetResourceData(source, dataName, ResourceDataType.File, File.OpenRead("TestData/MappingService/UT_HydrographicPolygons.sdf"));
+ resSvc.SetResourceData(target,
+ dataName,
+ ResourceDataType.File,
+ resSvc.GetResourceData(source, dataName));
+ public abstract IServerConnection CreateFromExistingSession(IServerConnection orig);
+ public virtual void TestCreateFromExistingSession()
+ var conn2 = CreateFromExistingSession(conn);
+ //This connection cannot restart sessions, and cannot be set to restart sessions
+ Assert.False(conn2.AutoRestartSession);
+ Assert.Throws<InvalidOperationException>(() => { conn2.AutoRestartSession = true; });
+ //Exercise an API to check the minimum parameters are met
+ try
+ var result = conn2.ResourceService.GetRepositoryResources();
+ catch (Exception ex)
+ Assert.Fail(ex.ToString());
+ public virtual void TestSchemaMapping()
+ var doc1 = conn.FeatureService.GetSchemaMapping("OSGeo.WMS", "FeatureServer=http://wms.jpl.nasa.gov/wms.cgi");
+ Assert.NotNull(doc1);
+ Assert.True(doc1 is WmsConfigurationDocument);
Modified: trunk/Tools/Maestro/MaestroAPITests/HttpConnectionTests.cs
--- trunk/Tools/Maestro/MaestroAPITests/HttpConnectionTests.cs 2012-10-17 06:46:38 UTC (rev 7124)
+++ trunk/Tools/Maestro/MaestroAPITests/HttpConnectionTests.cs 2012-10-17 13:29:39 UTC (rev 7125)
@@ -27,170 +27,65 @@
using System.IO;
[TestFixture(Ignore = TestControl.IgnoreHttpConnectionTests)]
- public class HttpConnectionTests
+ public class HttpConnectionTests : ConnectionTestBase
//[Test]
- public void TestEncryptedFeatureSourceCredentials()
+ public override void TestEncryptedFeatureSourceCredentials()
- //Sensitive data redacted, nevertheless you can test and verify this by filling in the
- //blanks here and uncommenting the above [Test] attribute. If the test passes, credential encryption is working
- string server = "";
- string database = "";
- string actualUser = "";
- string actualPass = "";
- string bogusUser = "foo";
- string bogusPass = "bar";
- var conn = ConnectionUtil.CreateTestHttpConnection();
- string fsId = "Library://UnitTests/EncryptedCredentials.FeatureSource";
- var fs = ObjectFactory.CreateFeatureSource(conn, "OSGeo.SQLServerSpatial");
- fs.SetConnectionProperty("Username", "%MG_USERNAME%");
- fs.SetConnectionProperty("Password", "%MG_PASSWORD%");
- fs.SetConnectionProperty("Service", server);
- fs.SetConnectionProperty("DataStore", database);
- fs.ResourceID = fsId;
- conn.ResourceService.SaveResource(fs);
- using (var ms = CredentialWriter.Write(actualUser, actualPass))
- conn.ResourceService.SetResourceData(fsId, "MG_USER_CREDENTIALS", ResourceDataType.String, ms);
- string result = conn.FeatureService.TestConnection(fsId);
- Assert.AreEqual("TRUE", result.ToUpper());
- //Test convenience method
- fsId = "Library://UnitTests/EncryptedCredentials2.FeatureSource";
- fs = ObjectFactory.CreateFeatureSource(conn, "OSGeo.SQLServerSpatial");
- fs.SetEncryptedCredentials(actualUser, actualPass);
- result = conn.FeatureService.TestConnection(fsId);
- Assert.AreEqual(actualUser, fs.GetEncryptedUsername());
- //Do not set encrypted credentials
- fsId = "Library://UnitTests/EncryptedCredentials3.FeatureSource";
- try
- Assert.AreEqual("FALSE", result.ToUpper());
- catch //Exception or false I can't remember, as long as the result is not "true"
- //Encrypt credentials, but use bogus username/password
- fsId = "Library://UnitTests/EncryptedCredentials4.FeatureSource";
- fs.SetEncryptedCredentials(bogusUser, bogusPass);
- try
- catch
- //Exception or false I can't remember, as long as the result is not "true"
- Assert.AreEqual(bogusUser, fs.GetEncryptedUsername());
+ base.TestEncryptedFeatureSourceCredentials();
[Test]
public void TestFeatureSourceCaching()
- string fsId = "Library://UnitTests/HttpCaching.FeatureSource";
- if (!conn.ResourceService.ResourceExists(fsId))
- var fs = ObjectFactory.CreateFeatureSource(conn, "OSGeo.SDF");
- fs.SetConnectionProperty("File", "%MG_DATA_FILE_PATH%Sheboygan_Parcels.sdf");
- conn.ResourceService.SaveResourceAs(fs, fsId);
- using (var stream = File.OpenRead("TestData/FeatureService/SDF/Sheboygan_Parcels.sdf"))
- fs.SetResourceData("Sheboygan_Parcels.sdf", ResourceDataType.File, stream);
- Assert.True(Convert.ToBoolean(conn.FeatureService.TestConnection(fsId)));
- var pc = (PlatformConnectionBase)conn;
- pc.ResetFeatureSourceSchemaCache();
- Assert.AreEqual(0, pc.CachedClassDefinitions);
- Assert.AreEqual(0, pc.CachedFeatureSources);
- var fsd = conn.FeatureService.DescribeFeatureSource(fsId);
- Assert.AreEqual(1, pc.CachedFeatureSources);
- Assert.AreEqual(1, pc.CachedClassDefinitions);
- var fsd2 = conn.FeatureService.DescribeFeatureSource(fsId);
- //Each cached instance returned is a clone
- Assert.False(object.ReferenceEquals(fsd, fsd2));
+ base.TestFeatureSourceCaching("HttpCaching");
[Test]
public void TestClassDefinitionCaching()
+ base.TestClassDefinitionCaching("HttpCaching");
+ [Test]
+ public override void TestTouch()
+ base.TestTouch();
- var cls = conn.FeatureService.GetClassDefinition(fsId, "SHP_Schema:Parcels");
+ [Test]
+ public override void TestAnyStreamInput()
+ base.TestAnyStreamInput();
+ [Test]
+ public override void TestCreateFromExistingSession()
+ base.TestCreateFromExistingSession();
+ [Test]
+ public override void TestSchemaMapping()
+ base.TestSchemaMapping();
- var cls2 = conn.FeatureService.GetClassDefinition(fsId, "SHP_Schema:Parcels");
+ protected override IServerConnection CreateTestConnection()
+ return ConnectionUtil.CreateTestHttpConnection();
- Assert.False(object.ReferenceEquals(cls, cls2));
+ public override IServerConnection CreateFromExistingSession(IServerConnection orig)
+ return ConnectionProviderRegistry.CreateConnection("Maestro.Http",
+ HttpServerConnection.PARAM_URL, orig.GetCustomProperty(HttpServerConnection.PROP_BASE_URL).ToString(),
+ HttpServerConnection.PARAM_SESSION, orig.SessionID);
[Test]
@@ -198,7 +93,7 @@
//Purpose: Unit test to guard against regression as a result of updating/replacing NTS
var srcWkt = "GEOGCS[\"WGS84 Lat/Long's, Degrees, -180 ==> +180\",DATUM[\"D_WGS_1984\",SPHEROID[\"World_Geodetic_System_of_1984\",6378137,298.257222932867]],PRIMEM[\"Greenwich\",0],UNIT[\"Degree\",0.017453292519943295]]";
var dstCs = conn.CoordinateSystemCatalog.FindCoordSys("WGS84.PseudoMercator");
var dstWkt = dstCs.WKT;
@@ -220,24 +115,6 @@
[Test]
- public void TestConnectionString()
- System.Data.Common.DbConnectionStringBuilder builder = new System.Data.Common.DbConnectionStringBuilder();
- builder["Foo"] = "sdfjkg";
- builder["Bar"] = "skgjuksdf";
- builder["Snafu"] = "asjdgjh;sdgj"; //Note the ; in the value
- builder["Whatever"] = "asjd=gjh;sdgj"; //Note the ; and = in the value
- var values = ConnectionProviderRegistry.ParseConnectionString(builder.ToString());
- Assert.AreEqual(values.Count, 4);
- Assert.AreEqual(builder["Foo"].ToString(), values["Foo"]);
- Assert.AreEqual(builder["Bar"].ToString(), values["Bar"]);
- Assert.AreEqual(builder["Snafu"].ToString(), values["Snafu"]);
- Assert.AreEqual(builder["Whatever"].ToString(), values["Whatever"]);
- [Test]
public void TestCustomProperties()
var builder = new RequestBuilder(new Uri("http://tempuri.org"), "en");
@@ -271,7 +148,7 @@
isvc.SetCustomProperty(HttpServerConnection.PROP_BASE_URL, "http://mylocalhost/mapguide");
Assert.Fail("Should've thrown exception");
- catch { }
+ catch { }
[Test]
@@ -311,66 +188,5 @@
- [Test]
- public void TestTouch()
- var resSvc = conn.ResourceService;
- if (!resSvc.ResourceExists("Library://UnitTests/Data/HydrographicPolygons.FeatureSource"))
- resSvc.SetResourceXmlData("Library://UnitTests/Data/HydrographicPolygons.FeatureSource", File.OpenRead("TestData/MappingService/UT_HydrographicPolygons.fs"));
- resSvc.Touch("Library://UnitTests/Data/HydrographicPolygons.FeatureSource");
- [Test]
- public void TestAnyStreamInput()
- string source = "Library://UnitTests/Data/HydrographicPolygons.FeatureSource";
- string target = "Library://UnitTests/Data/TestAnyStreamInput.FeatureSource";
- if (!resSvc.ResourceExists(source))
- resSvc.SetResourceXmlData(source, File.OpenRead("TestData/MappingService/UT_HydrographicPolygons.fs"));
- resSvc.SetResourceXmlData(target, resSvc.GetResourceXmlData(source));
- string dataName = "UT_HydrographicPolygons.sdf";
- var resDataList = resSvc.EnumerateResourceData(source);
- if (resDataList.ResourceData.Count == 1)
- dataName = resDataList.ResourceData[0].Name;
- else
- resSvc.SetResourceData(source, dataName, ResourceDataType.File, File.OpenRead("TestData/MappingService/UT_HydrographicPolygons.sdf"));
- resSvc.SetResourceData(target,
- dataName,
- ResourceDataType.File,
- resSvc.GetResourceData(source, dataName));
- [Test]
- public void TestCreateFromExistingSession()
- var conn2 = ConnectionProviderRegistry.CreateConnection("Maestro.Http",
- HttpServerConnection.PARAM_SESSION, conn.SessionID,
- HttpServerConnection.PARAM_URL, conn.GetCustomProperty(HttpServerConnection.PROP_BASE_URL).ToString(),
- HttpServerConnection.PARAM_UNTESTED, "true");
- //This connection cannot restart sessions, and cannot be set to restart sessions
- Assert.False(conn2.AutoRestartSession);
- Assert.Throws<InvalidOperationException>(() => { conn2.AutoRestartSession = true; });
- //Exercise an API to check the minimum parameters are met
- try
- var result = conn2.ResourceService.GetRepositoryResources();
- catch (Exception ex)
- Assert.Fail(ex.ToString());
Added: trunk/Tools/Maestro/MaestroAPITests/LocalConnectionTests.cs
--- trunk/Tools/Maestro/MaestroAPITests/LocalConnectionTests.cs (rev 0)
+++ trunk/Tools/Maestro/MaestroAPITests/LocalConnectionTests.cs 2012-10-17 13:29:39 UTC (rev 7125)
@@ -0,0 +1,111 @@
+#endregion
+using System;
+using System.Text;
+using System.IO;
+ [TestFixture(Ignore = TestControl.IgnoreLocalNativeFeatureTests)]
+ public class LocalConnectionTests : ConnectionTestBase
+ return ConnectionUtil.CreateTestLocalConnection();
+ [Test]
+ base.TestTouch();
+ [Test]
+ [Test]
+ public void TestFeatureSourceCaching()
+ base.TestFeatureSourceCaching("LocalFeatureSourceCaching");
+ [Test]
+ public void TestClassDefinitionCaching()
+ base.TestClassDefinitionCaching("LocalClassCaching");
+ [Test]
+ public override void TestApplySchema()
+ base.TestApplySchema();
+ [Test]
+ public override void TestCreateDataStore()
+ base.TestCreateDataStore();
+ [Test]
+ public override void TestDeleteFeatures()
+ base.TestDeleteFeatures();
+ [Test]
+ public override void TestInsertFeatures()
+ base.TestInsertFeatures();
+ [Test]
+ public override void TestUpdateFeatures()
+ base.TestUpdateFeatures();
+ [Test]
+ throw new NotImplementedException();
Modified: trunk/Tools/Maestro/MaestroAPITests/LocalNativeFeatureTests.cs
--- trunk/Tools/Maestro/MaestroAPITests/LocalNativeFeatureTests.cs 2012-10-17 06:46:38 UTC (rev 7124)
+++ trunk/Tools/Maestro/MaestroAPITests/LocalNativeFeatureTests.cs 2012-10-17 13:29:39 UTC (rev 7125)
@@ -31,351 +31,36 @@
using System.IO;
- public abstract class LocalNativeFeatureTestsBase
+ public class LocalNativeFeatureTests : ConnectionTestBase
- protected abstract IServerConnection CreateTestConnection();
- protected void TestFeatureSourceCaching(string fsName)
- string fsId = "Library://UnitTests/" + fsName + ".FeatureSource";
+ return ConnectionUtil.CreateTestLocalNativeConnection();
- protected void TestClassDefinitionCaching(string fsName)
+ [Test]
+ base.TestTouch();
- protected void CreateTestDataStore(IServerConnection conn, string fsId, ref FeatureSchema schema, ref ClassDefinition cls)
+ [Test]
- schema = new FeatureSchema("Default", "");
- cls = new ClassDefinition("Class1", "");
- try
- if (conn.ResourceService.ResourceExists(fsId))
- conn.ResourceService.DeleteResource(fsId);
- cls.DefaultGeometryPropertyName = "GEOM";
- cls.AddProperty(new DataPropertyDefinition("KEY", "")
- DataType = DataPropertyType.Int32,
- IsAutoGenerated = true,
- IsReadOnly = true,
- IsNullable = false
- }, true);
- cls.AddProperty(new DataPropertyDefinition("NAME", "")
- DataType = DataPropertyType.String,
- Length = 255,
- IsNullable = true,
- IsReadOnly = false
- cls.AddProperty(new GeometricPropertyDefinition("GEOM", "")
- GeometricTypes = FeatureGeometricType.Point,
- SpatialContextAssociation = "Default"
- schema.AddClass(cls);
- ICreateDataStore create = (ICreateDataStore)conn.CreateCommand((int)CommandType.CreateDataStore);
- CoordinateSystemDefinitionBase coordSys = conn.CoordinateSystemCatalog.FindCoordSys("LL84");
- create.FeatureSourceId = fsId;
- create.CoordinateSystemWkt = coordSys.WKT;
- create.Name = "Default";
- create.ExtentType = OSGeo.MapGuide.ObjectModels.Common.FdoSpatialContextListSpatialContextExtentType.Dynamic;
- create.FileName = "Test.sdf";
- create.Provider = "OSGeo.SDF";
- create.Schema = schema;
- create.XYTolerance = 0.001;
- create.ZTolerance = 0.001;
- create.Execute();
- catch
- schema = null;
- cls = null;
- throw;
- protected void PopulateTestDataStore(IServerConnection conn, string fsId, ref FeatureSchema schema, ref ClassDefinition cls)
+ [Test]
- CreateTestDataStore(conn, fsId, ref schema, ref cls);
- IInsertFeatures insert = (IInsertFeatures)conn.CreateCommand((int)CommandType.InsertFeature);
- insert.ClassName = cls.Name;
- insert.FeatureSourceId = fsId;
- var feat = new MutableRecord();
- var reader = new FixedWKTReader();
- //Initialize this record
- feat.PutValue("GEOM", new GeometryValue(reader.Read("POINT (0 0)")));
- feat.PutValue("NAME", new StringValue("Test1"));
- //Attach to command.
- insert.RecordToInsert = feat;
- var res = insert.Execute();
- feat.SetGeometry("GEOM", reader.Read("POINT (0 1)"));
- feat.SetString("NAME", "Test2");
- res = insert.Execute();
- feat.SetGeometry("GEOM", reader.Read("POINT (1 1)"));
- feat.SetString("NAME", "Test3");
- feat.SetGeometry("GEOM", reader.Read("POINT (1 0)"));
- feat.SetString("NAME", "Test4");
- public virtual void TestInsertFeatures()
- var conn = CreateTestConnection();
- var fsId = "Library://UnitTests/Data/TestInsertFeatures.FeatureSource";
- ClassDefinition cls = null;
- FeatureSchema schema = null;
- Assert.True(feat.PropertyExists("GEOM"));
- Assert.True(feat.PropertyExists("NAME"));
- Assert.Null(res.Error);
- int count = 0;
- using (var rdr = conn.FeatureService.QueryFeatureSource(fsId, cls.Name))
- while (rdr.ReadNext())
- count++;
- rdr.Close();
- Assert.AreEqual(4, count);
- public virtual void TestUpdateFeatures()
- var fsId = "Library://UnitTests/Data/TestUpdateFeatures.FeatureSource";
- PopulateTestDataStore(conn, fsId, ref schema, ref cls);
- IUpdateFeatures update = (IUpdateFeatures)conn.CreateCommand((int)CommandType.UpdateFeatures);
- update.ClassName = cls.Name;
- update.FeatureSourceId = fsId;
- update.Filter = "NAME = 'Test4'";
- update.ValuesToUpdate = new MutableRecord();
- update.ValuesToUpdate.PutValue("NAME", new StringValue("Test4Modified"));
- Assert.AreEqual(1, update.Execute());
- public virtual void TestDeleteFeatures()
- var fsId = "Library://UnitTests/Data/TestDeleteFeatures.FeatureSource";
- IDeleteFeatures delete = (IDeleteFeatures)conn.CreateCommand((int)CommandType.DeleteFeatures);
- delete.ClassName = cls.Name;
- delete.FeatureSourceId = fsId;
- delete.Filter = "NAME = 'Test4'";
- Assert.AreEqual(1, delete.Execute());
- int count = 0;
- while (rdr.ReadNext()) { count++; }
- Assert.AreEqual(3, count);
- public virtual void TestCreateDataStore()
- var fsId = "Library://UnitTests/Data/TestCreateDataStore.FeatureSource";
- ClassDefinition cls2 = conn.FeatureService.GetClassDefinition(fsId, "Class1");
- Assert.NotNull(cls2);
- Assert.False(ClassDefinition.ReferenceEquals(cls, cls2));
- Assert.AreEqual(cls.Name, cls2.Name);
- Assert.AreEqual(cls.DefaultGeometryPropertyName, cls2.DefaultGeometryPropertyName);
- Assert.AreEqual(cls.Properties.Count, cls2.Properties.Count);
- Assert.AreEqual(cls.IdentityProperties.Count, cls2.IdentityProperties.Count);
- foreach (var prop in cls.Properties)
- var prop2 = cls2.FindProperty(prop.Name);
- Assert.AreEqual(prop.Name, prop2.Name);
- Assert.AreEqual(prop.Type, prop2.Type);
- public virtual void TestApplySchema()
- var fsId = "Library://UnitTests/Data/TestMaestroLocalApplySchema.FeatureSource";
- cls.AddProperty(new DataPropertyDefinition("ExtraProp", "")
- IsNullable = false,
- Length = 255
- //Apply changes
- IApplySchema cmd = (IApplySchema)conn.CreateCommand((int)CommandType.ApplySchema);
- cmd.Schema = schema;
- cmd.FeatureSourceId = fsId;
- cmd.Execute();
- ClassDefinition cls2 = conn.FeatureService.GetClassDefinition(cmd.FeatureSourceId, "Class1");
- [TestFixture(Ignore = TestControl.IgnoreLocalNativeFeatureTests)]
- public class LocalNativeFeatureTests : LocalNativeFeatureTestsBase
- protected override IServerConnection CreateTestConnection()
- return ConnectionUtil.CreateTestLocalNativeConnection();
[Test]
@@ -417,57 +102,17 @@
- [TestFixture(Ignore = TestControl.IgnoreLocalFeatureTests)]
- public class LocalFeatureTests : LocalNativeFeatureTestsBase
- return ConnectionUtil.CreateTestLocalConnection();
[Test]
- public void TestFeatureSourceCaching()
- base.TestFeatureSourceCaching("LocalFeatureSourceCaching");
- [Test]
- public void TestClassDefinitionCaching()
- base.TestClassDefinitionCaching("LocalClassCaching");
+ return ConnectionProviderRegistry.CreateConnection("Maestro.LocalNative",
+ "SessionId", orig.SessionID);
- [Test]
- public override void TestApplySchema()
- base.TestApplySchema();
- [Test]
- public override void TestCreateDataStore()
- base.TestCreateDataStore();
- [Test]
- public override void TestDeleteFeatures()
- base.TestDeleteFeatures();
- [Test]
- public override void TestInsertFeatures()
- base.TestInsertFeatures();
- [Test]
- public override void TestUpdateFeatures()
- base.TestUpdateFeatures();
Modified: trunk/Tools/Maestro/MaestroAPITests/MaestroAPITests.csproj
--- trunk/Tools/Maestro/MaestroAPITests/MaestroAPITests.csproj 2012-10-17 06:46:38 UTC (rev 7124)
+++ trunk/Tools/Maestro/MaestroAPITests/MaestroAPITests.csproj 2012-10-17 13:29:39 UTC (rev 7125)
@@ -79,11 +79,13 @@
</Compile>
<Compile Include="CapabilityTests.cs" />
<Compile Include="ConfigurationTests.cs" />
+ <Compile Include="ConnectionTestBase.cs" />
<Compile Include="ExpressionTests.cs" />
<Compile Include="FeatureReaderTests.cs" />
<Compile Include="GeoRestTests.cs" />
<Compile Include="HttpConnectionTests.cs" />
<Compile Include="HttpSiteTests.cs" />
+ <Compile Include="LocalConnectionTests.cs" />
<Compile Include="LocalNativeFeatureTests.cs" />
<Compile Include="LocalNativePerformanceTests.cs" />
<Compile Include="MiscTests.cs" />
Modified: trunk/Tools/Maestro/MaestroAPITests/ObjectTests.cs
--- trunk/Tools/Maestro/MaestroAPITests/ObjectTests.cs 2012-10-17 06:46:38 UTC (rev 7124)
+++ trunk/Tools/Maestro/MaestroAPITests/ObjectTests.cs 2012-10-17 13:29:39 UTC (rev 7125)
@@ -36,6 +36,24 @@
public class ObjectTests
[Test]
+ public void TestConnectionString()
+ System.Data.Common.DbConnectionStringBuilder builder = new System.Data.Common.DbConnectionStringBuilder();
+ builder["Foo"] = "sdfjkg";
+ builder["Bar"] = "skgjuksdf";
+ builder["Snafu"] = "asjdgjh;sdgj"; //Note the ; in the value
+ builder["Whatever"] = "asjd=gjh;sdgj"; //Note the ; and = in the value
+ var values = ConnectionProviderRegistry.ParseConnectionString(builder.ToString());
+ Assert.AreEqual(values.Count, 4);
+ Assert.AreEqual(builder["Foo"].ToString(), values["Foo"]);
+ Assert.AreEqual(builder["Bar"].ToString(), values["Bar"]);
+ Assert.AreEqual(builder["Snafu"].ToString(), values["Snafu"]);
+ Assert.AreEqual(builder["Whatever"].ToString(), values["Whatever"]);
+ [Test]
public void TestArgParser()
string[] args = new string[] { "-foo", "-bar:snafu", "-whatever:" };
Modified: trunk/Tools/Maestro/MaestroAPITests/ValidationTests.cs
--- trunk/Tools/Maestro/MaestroAPITests/ValidationTests.cs 2012-10-17 06:46:38 UTC (rev 7124)
+++ trunk/Tools/Maestro/MaestroAPITests/ValidationTests.cs 2012-10-17 13:29:39 UTC (rev 7125)
@@ -406,6 +406,17 @@
+ public OSGeo.MapGuide.ObjectModels.Common.ILongTransactionList GetLongTransactions(string resourceId, bool activeOnly)
+ public OSGeo.MapGuide.MaestroAPI.SchemaOverrides.ConfigurationDocument GetSchemaMapping(string provider, string partialConnString)
#endregion
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj 2012-10-17 06:46:38 UTC (rev 7124)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj 2012-10-17 13:29:39 UTC (rev 7125)
@@ -250,6 +250,7 @@
<Compile Include="NsDoc.cs" />
<Compile Include="ObjectModels\CommonTypes.cs" />
<Compile Include="ObjectModels\IFdoSpatialContext.cs" />
+ <Compile Include="ObjectModels\LongTransaction.cs" />
<Compile Include="ObjectModels\NsDoc.cs" />
<Compile Include="ObjectModels\SymbolDefFactory.cs" />
<Compile Include="ObjectModels\WatermarkCollectionUtil.cs" />
Added: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/LongTransaction.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/LongTransaction.cs (rev 0)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/LongTransaction.cs 2012-10-17 13:29:39 UTC (rev 7125)
@@ -0,0 +1,70 @@
+using System;
+using System.Linq;
+using System.Text;
+namespace OSGeo.MapGuide.ObjectModels.Common
+ /// <summary>
+ /// Represents a list of long transactions
+ /// </summary>
+ public interface ILongTransactionList
+ /// <summary>
+ /// Gets the long transactions in this list
+ /// </summary>
+ IEnumerable<ILongTransaction> Transactions { get; }
+ /// <summary>
+ /// Represents a long transaction
+ /// </summary>
+ /// <summary>
+ /// Gets the name of the long transaction
+ /// </summary>
+ string Name { get; }
+ /// <summary>
+ /// Gets the description of the long transaction
+ /// </summary>
+ string Description { get; }
+ /// <summary>
+ /// Gets the owner of the long transaction
+ /// </summary>
+ string Owner { get; }
+ /// <summary>
+ /// Gets the creation date of the long transaction
+ /// </summary>
+ string CreationDate { get; }
+ /// <summary>
+ /// Gets whether the long transaction is active
+ /// </summary>
+ bool IsActive { get; }
+ /// <summary>
+ /// Gets whether the long transaction is frozen
+ /// </summary>
+ bool IsFrozen { get; }
+ partial class FdoLongTransactionList : ILongTransactionList
+ public IEnumerable<ILongTransaction> Transactions
+ get
+ return this.LongTransaction;
+ partial class FdoLongTransactionListLongTransaction : ILongTransaction
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs 2012-10-17 06:46:38 UTC (rev 7124)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs 2012-10-17 13:29:39 UTC (rev 7125)
@@ -40,6 +40,8 @@
using OSGeo.MapGuide.ObjectModels.LayerDefinition;
using OSGeo.MapGuide.MaestroAPI.Exceptions;
using GeoAPI.Geometries;
+using OSGeo.MapGuide.ObjectModels.FeatureSource;
namespace OSGeo.MapGuide.MaestroAPI
@@ -1786,6 +1788,23 @@
/// <returns></returns>
public abstract string[] GetClassNames(string resourceId, string schemaName);
+ /// <summary>
+ /// Gets the long transactions for the specified feature source
+ /// </summary>
+ /// <param name="resourceId">The feature source id</param>
+ /// <param name="activeOnly">If true, will only return active long transactions</param>
+ /// <returns></returns>
+ public abstract ILongTransactionList GetLongTransactions(string resourceId, bool activeOnly);
+ /// <summary>
+ /// Gets the schema mappings for the given FDO provider. These mappings form the basis for a custom configuration document
+ /// for a feature source that supports configuration
+ /// </summary>
+ /// <param name="provider">The FDO provider</param>
+ /// <param name="partialConnString">The connection string</param>
+ public abstract ConfigurationDocument GetSchemaMapping(string provider, string partialConnString);
#endregion
#region Feature/Capability Discovery
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/ConfigurationDocument.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/ConfigurationDocument.cs 2012-10-17 06:46:38 UTC (rev 7124)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/ConfigurationDocument.cs 2012-10-17 13:29:39 UTC (rev 7125)
@@ -236,6 +236,11 @@
XmlDocument doc = new XmlDocument();
doc.LoadXml(xml);
+ return LoadInternal(doc);
+ private static ConfigurationDocument LoadInternal(XmlDocument doc)
var mgr = new XmlNamespaceManager(doc.NameTable);
mgr.AddNamespace("xs", XmlNamespaces.XS); //NOXLATE
mgr.AddNamespace("xsi", XmlNamespaces.XSI); //NOXLATE
@@ -279,5 +284,17 @@
return null;
+ /// <summary>
+ /// Creates a configuration document from the specified stream.
+ /// </summary>
+ /// <param name="stream">The stream.</param>
+ /// <returns>The configuration document</returns>
+ public static ConfigurationDocument Load(System.IO.Stream stream)
+ XmlDocument doc = new XmlDocument();
+ doc.Load(stream);
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Services/IFeatureService.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Services/IFeatureService.cs 2012-10-17 06:46:38 UTC (rev 7124)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Services/IFeatureService.cs 2012-10-17 13:29:39 UTC (rev 7125)
@@ -24,6 +24,9 @@
using ObjCommon = OSGeo.MapGuide.ObjectModels.Common;
namespace OSGeo.MapGuide.MaestroAPI.Services
@@ -280,5 +283,22 @@
/// </param>
+ /// <summary>
+ /// </summary>
+ ILongTransactionList GetLongTransactions(string resourceId, bool activeOnly);
+ /// <summary>
+ /// </summary>
+ ConfigurationDocument GetSchemaMapping(string provider, string partialConnString);
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs 2012-10-17 06:46:38 UTC (rev 7124)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs 2012-10-17 13:29:39 UTC (rev 7125)
@@ -43,6 +43,8 @@
using System.Drawing;
@@ -1750,6 +1752,18 @@
return o;
+ public override ILongTransactionList GetLongTransactions(string resourceId, bool activeOnly)
+ string req = m_reqBuilder.GetLongTransactions(resourceId, activeOnly);
+ return DeserializeObject<FdoLongTransactionList>(this.OpenRead(req));
+ public override ConfigurationDocument GetSchemaMapping(string provider, string partialConnString)
+ string req = m_reqBuilder.GetSchemaMapping(provider, partialConnString);
+ return ConfigurationDocument.Load(this.OpenRead(req));
public override bool MoveFolderWithReferences(string oldpath, string newpath, LengthyOperationCallBack callback, LengthyOperationProgressCallBack progress)
if (this.SiteVersion >= new Version(2, 2)) //new way
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/RequestBuilder.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/RequestBuilder.cs 2012-10-17 06:46:38 UTC (rev 7124)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/RequestBuilder.cs 2012-10-17 13:29:39 UTC (rev 7125)
@@ -1712,5 +1712,29 @@
return m_hosturi + "?" + EncodeParameters(param);
+ internal string GetLongTransactions(string resourceId, bool activeOnly)
+ NameValueCollection param = new NameValueCollection();
+ param.Add("OPERATION", "GETLONGTRANSACTIONS");
+ param.Add("VERSION", "1.0.0");
+ param.Add("SESSION", m_sessionID);
+ param.Add("RESOURCEID", resourceId);
+ param.Add("ACTIVEONLY", activeOnly ? "1" : "0");
+ return m_hosturi + "?" + EncodeParameters(param);
+ internal string GetSchemaMapping(string provider, string partialConnString)
+ param.Add("OPERATION", "GETSCHEMAMAPPING");
+ param.Add("PROVIDER", provider);
+ param.Add("CONNECTIONSTRING", partialConnString);
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Local/LocalConnection.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Local/LocalConnection.cs 2012-10-17 06:46:38 UTC (rev 7124)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Local/LocalConnection.cs 2012-10-17 13:29:39 UTC (rev 7125)
@@ -35,6 +35,8 @@
using OSGeo.MapGuide.MaestroAPI.Local.Commands;
using OSGeo.MapGuide.MaestroAPI.Mapping;
namespace OSGeo.MapGuide.MaestroAPI.Local
@@ -1350,5 +1352,96 @@
return xml;
+ var featSvc = GetFeatureService();
+ var resId = new MgResourceIdentifier(resourceId);
+ var rdr = featSvc.GetLongTransactions(resId, activeOnly);
+ return new LocalLongTransactionList(rdr);
+ GetByteReaderMethod fetch = () =>
+ return featSvc.GetSchemaMapping(provider, partialConnString);
+ using (var stream = new MgReadOnlyStream(fetch))
+ return ConfigurationDocument.Load(stream);
+ class LocalLongTransaction : ILongTransaction
+ public LocalLongTransaction(MgLongTransactionReader rdr)
+ this.Name = rdr.Name;
+ this.Description = rdr.Description;
+ this.Owner = rdr.Owner;
+ this.CreationDate = rdr.CreationDate.ToString();
+ this.IsActive = rdr.IsActive();
+ this.IsFrozen = rdr.IsFrozen();
+ public string Name
+ get;
+ private set;
+ public string Description
+ get;
+ private set;
+ public string Owner
+ get;
+ private set;
+ public string CreationDate
+ get;
+ private set;
+ public bool IsActive
+ get;
+ private set;
+ public bool IsFrozen
+ get;
+ private set;
+ class LocalLongTransactionList : ILongTransactionList
+ private List<LocalLongTransaction> _transactions;
+ public LocalLongTransactionList(MgLongTransactionReader rdr)
+ _transactions = new List<LocalLongTransaction>();
+ _transactions.Add(new LocalLongTransaction(rdr));
+ rdr.Close();
+ get { return _transactions; }
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeConnection.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeConnection.cs 2012-10-17 06:46:38 UTC (rev 7124)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeConnection.cs 2012-10-17 13:29:39 UTC (rev 7125)
@@ -39,6 +39,8 @@
using System.Globalization;
namespace OSGeo.MapGuide.MaestroAPI.Native
@@ -1535,5 +1537,95 @@
throw exMgd;
+ var featSvc = (MgFeatureService)this.Connection.CreateService(MgServiceType.FeatureService);
+ get;
+ private set;
+ get;
+ private set;
+ get;
+ private set;
+ get;
+ private set;
+ get;
+ private set;
+ get;
+ private set;
+ rdr.Close();
More information about the mapguide-commits
