[mapguide-commits] r7142 - sandbox/jng/weblayout/Common/Schema
svn_mapguide at osgeo.org
Fri Oct 19 10:19:42 PDT 2012
Author: jng
Date: 2012-10-19 10:19:41 -0700 (Fri, 19 Oct 2012)
New Revision: 7142
Added:
sandbox/jng/weblayout/Common/Schema/WebLayout-2.5.0.xsd
Add proposed new schema
Added: sandbox/jng/weblayout/Common/Schema/WebLayout-2.5.0.xsd
--- sandbox/jng/weblayout/Common/Schema/WebLayout-2.5.0.xsd (rev 0)
+++ sandbox/jng/weblayout/Common/Schema/WebLayout-2.5.0.xsd 2012-10-19 17:19:41 UTC (rev 7142)
@@ -0,0 +1,349 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" elementFormDefault="qualified" attributeFormDefault="unqualified">
+ <xs:element name="WebLayout" type="WebLayoutType"/>
+ <xs:complexType name="WebLayoutType">
+ <xs:sequence>
+ <xs:element name="Title" type="xs:string"/>
+ <xs:element name="Map" type="MapType"/>
+ <xs:element name="EnablePingServer" type="xs:boolean" minOccurs="0" />
+ <xs:element name="SelectionColor" type="xs:string" minOccurs="0" />
+ <xs:element name="PointSelectionBuffer" type="xs:integer" minOccurs="0" />
+ <xs:element name="MapImageFormat" type="xs:string" minOccurs="0" />
+ <xs:element name="SelectionImageFormat" type="xs:string" minOccurs="0" />
+ <xs:element name="StartupScript" type="xs:string" minOccurs="0" />
+ <xs:element name="ToolBar" type="ToolBarType"/>
+ <xs:element name="InformationPane" type="InformationPaneType"/>
+ <xs:element name="ContextMenu" type="ContextMenuType"/>
+ <xs:element name="TaskPane" type="TaskPaneType"/>
+ <xs:element name="StatusBar" type="StatusBarType"/>
+ <xs:element name="ZoomControl" type="ZoomControlType"/>
+ <xs:element name="CommandSet" type="CommandSetType"/>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="ResourceReferenceType">
+ <xs:sequence>
+ <xs:element name="ResourceId" type="xs:string"/>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="MapType">
+ <xs:complexContent>
+ <xs:extension base="ResourceReferenceType">
+ <xs:sequence>
+ <xs:element name="InitialView" type="MapViewType" minOccurs="0"/>
+ <xs:element name="HyperlinkTarget" type="TargetType"/>
+ <xs:element name="HyperlinkTargetFrame" type="xs:string" minOccurs="0"/>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexContent>
+ </xs:complexType>
+ <xs:complexType name="WebLayoutControlType">
+ <xs:sequence>
+ <xs:element name="Visible" type="xs:boolean"/>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="WebLayoutResizableControlType">
+ <xs:extension base="WebLayoutControlType">
+ <xs:sequence>
+ <xs:element name="Width" type="xs:int"/>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="ToolBarType">
+ <xs:sequence>
+ <xs:element name="Button" type="UIItemType" minOccurs="0" maxOccurs="unbounded"/>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="ContextMenuType">
+ <xs:sequence>
+ <xs:element name="MenuItem" type="UIItemType" minOccurs="0" maxOccurs="unbounded"/>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="StatusBarType">
+ <xs:extension base="WebLayoutControlType"/>
+ </xs:complexType>
+ <xs:complexType name="ZoomControlType">
+ </xs:complexType>
+ <xs:complexType name="InformationPaneType">
+ <xs:extension base="WebLayoutResizableControlType">
+ <xs:sequence>
+ <xs:element name="LegendVisible" type="xs:boolean"/>
+ <xs:element name="PropertiesVisible" type="xs:boolean"/>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="TaskPaneType">
+ <xs:sequence>
+ <xs:element name="TaskBar" type="TaskBarType"/>
+ <xs:element name="InitialTask" type="xs:string" minOccurs="0"/>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="TaskButtonType">
+ <xs:sequence>
+ <xs:element name="Name" type="xs:string"/>
+ <xs:element name="Tooltip" type="xs:string" minOccurs="0"/>
+ <xs:element name="Description" type="xs:string" minOccurs="0"/>
+ <xs:element name="ImageURL" type="xs:string" minOccurs="0"/>
+ <xs:element name="DisabledImageURL" type="xs:string" minOccurs="0"/>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="TaskBarType">
+ <xs:sequence>
+ <xs:element name="Home" type="TaskButtonType"/>
+ <xs:element name="Forward" type="TaskButtonType"/>
+ <xs:element name="Back" type="TaskButtonType"/>
+ <xs:element name="Tasks" type="TaskButtonType"/>
+ <xs:element name="MenuButton" type="UIItemType" minOccurs="0" maxOccurs="unbounded"/>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="CommandSetType">
+ <xs:sequence>
+ <xs:element name="Command" type="CommandType" minOccurs="0" maxOccurs="unbounded"/>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="MapViewType">
+ <xs:sequence>
+ <xs:element name="CenterX" type="xs:double"/>
+ <xs:element name="CenterY" type="xs:double"/>
+ <xs:element name="Scale" type="xs:double"/>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="UIItemType">
+ <xs:sequence>
+ <xs:element name="Function" type="UIItemFunctionType"/>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:simpleType name="UIItemFunctionType">
+ <xs:restriction base="xs:string">
+ <xs:enumeration value="Separator"/>
+ <xs:enumeration value="Command"/>
+ <xs:enumeration value="Flyout"/>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:complexType name="FlyoutItemType">
+ <xs:extension base="UIItemType">
+ <xs:sequence>
+ <xs:element name="Label" type="xs:string"/>
+ <xs:element name="SubItem" type="UIItemType" minOccurs="0" maxOccurs="unbounded"/>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="SeparatorItemType">
+ <xs:extension base="UIItemType"/>
+ </xs:complexType>
+ <xs:complexType name="CommandItemType">
+ <xs:sequence>
+ <xs:element name="Command" type="xs:string"/>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="CommandType" abstract="true">
+ <xs:sequence>
+ <xs:element name="TargetViewer" type="TargetViewerType"/>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:simpleType name="BasicCommandActionType">
+ <xs:enumeration value="Pan"/>
+ <xs:enumeration value="PanUp"/>
+ <xs:enumeration value="PanDown"/>
+ <xs:enumeration value="PanRight"/>
+ <xs:enumeration value="PanLeft"/>
+ <xs:enumeration value="Zoom"/>
+ <xs:enumeration value="ZoomIn"/>
+ <xs:enumeration value="ZoomOut"/>
+ <xs:enumeration value="ZoomRectangle"/>
+ <xs:enumeration value="ZoomToSelection"/>
+ <xs:enumeration value="FitToWindow"/>
+ <xs:enumeration value="PreviousView"/>
+ <xs:enumeration value="NextView"/>
+ <xs:enumeration value="RestoreView"/>
+ <xs:enumeration value="Select"/>
+ <xs:enumeration value="SelectRadius"/>
+ <xs:enumeration value="SelectPolygon"/>
+ <xs:enumeration value="ClearSelection"/>
+ <xs:enumeration value="Refresh"/>
+ <xs:enumeration value="CopyMap"/>
+ <xs:enumeration value="About"/>
+ <xs:enumeration value="MapTip"/>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:complexType name="BasicCommandType">
+ <xs:extension base="CommandType">
+ <xs:sequence>
+ <xs:element name="Action" type="BasicCommandActionType"/>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:simpleType name="TargetViewerType">
+ <xs:enumeration value="Dwf"/>
+ <xs:enumeration value="Ajax"/>
+ <xs:enumeration value="All"/>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:complexType name="CustomCommandType" abstract="true">
+ <xs:extension base="CommandType"/>
+ </xs:complexType>
+ <xs:complexType name="TargetedCommandType" abstract="true">
+ <xs:extension base="CustomCommandType">
+ <xs:sequence>
+ <xs:element name="Target" type="TargetType"/>
+ <xs:element name="TargetFrame" type="xs:string" minOccurs="0"/>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:simpleType name="TargetType">
+ <xs:enumeration value="TaskPane"/>
+ <xs:enumeration value="NewWindow"/>
+ <xs:enumeration value="SpecifiedFrame"/>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:complexType name="SearchCommandType">
+ <xs:extension base="TargetedCommandType">
+ <xs:sequence>
+ <xs:element name="Layer" type="xs:string"/>
+ <xs:element name="Prompt" type="xs:string"/>
+ <xs:element name="ResultColumns" type="ResultColumnSetType"/>
+ <xs:element name="Filter" type="xs:string" minOccurs="0"/>
+ <xs:element name="MatchLimit" type="xs:integer"/>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="InvokeURLCommandType">
+ <xs:sequence>
+ <xs:element name="URL" type="xs:string"/>
+ <xs:element name="LayerSet" type="LayerSetType" minOccurs="0"/>
+ <xs:element name="AdditionalParameter" type="ParameterPairType" minOccurs="0" maxOccurs="unbounded"/>
+ <xs:element name="DisableIfSelectionEmpty" type="xs:boolean"/>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="BufferCommandType">
+ <xs:extension base="TargetedCommandType"/>
+ </xs:complexType>
+ <xs:complexType name="SelectWithinCommandType">
+ </xs:complexType>
+ <xs:complexType name="PrintCommandType">
+ <xs:sequence>
+ <xs:element name="PrintLayout" type="ResourceReferenceType" minOccurs="0" maxOccurs="unbounded"/>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="GetPrintablePageCommandType">
+ </xs:complexType>
+ <xs:complexType name="MeasureCommandType">
+ </xs:complexType>
+ <xs:complexType name="ViewOptionsCommandType">
+ </xs:complexType>
+ <xs:complexType name="HelpCommandType">
+ <xs:sequence>
+ <xs:element name="URL" type="xs:string" minOccurs="0"/>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="InvokeScriptCommandType">
+ <xs:sequence>
+ <xs:element name="Script" type="xs:string"/>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="ParameterPairType">
+ <xs:sequence>
+ <xs:element name="Key" type="xs:string"/>
+ <xs:element name="Value" type="xs:string"/>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="LayerSetType">
+ <xs:sequence>
+ <xs:element name="Layer" type="xs:string" minOccurs="0" maxOccurs="unbounded"/>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="ResultColumnType">
+ <xs:sequence>
+ <xs:element name="Property" type="xs:string"/>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="ResultColumnSetType">
+ <xs:sequence>
+ <xs:element name="Column" type="ResultColumnType" minOccurs="0" maxOccurs="unbounded"/>
+ </xs:sequence>
+ </xs:complexType>
+</xs:schema>
More information about the mapguide-commits
