[mapguide-commits] r7150 - in sandbox/jng/weblayout: Common/Schema Web/src/DotNetUnmanagedApi/Web Web/src/MapGuideApi Web/src/WebApp
svn_mapguide at osgeo.org
Mon Oct 22 01:19:48 PDT 2012
Author: jng
Date: 2012-10-22 01:19:48 -0700 (Mon, 22 Oct 2012)
New Revision: 7150
Added:
sandbox/jng/weblayout/Web/src/WebApp/WebMeasureUnits.cpp
sandbox/jng/weblayout/Web/src/WebApp/WebMeasureUnits.h
sandbox/jng/weblayout/Common/Schema/WebLayout-2.5.0.xsd
sandbox/jng/weblayout/Web/src/DotNetUnmanagedApi/Web/WebConstants.xml
sandbox/jng/weblayout/Web/src/MapGuideApi/Constants.xml
sandbox/jng/weblayout/Web/src/WebApp/WebApp.h
sandbox/jng/weblayout/Web/src/WebApp/WebApp.vcxproj
sandbox/jng/weblayout/Web/src/WebApp/WebAppBuild.cpp
sandbox/jng/weblayout/Web/src/WebApp/WebLayout.cpp
sandbox/jng/weblayout/Web/src/WebApp/WebLayout.h
Expose the following properties in the new WebLayout schema and MgWebLayout:
* UseUsEnglishUnits - Defines whether the viewer will default to imperial or metric units
* MeasureUnits - Defines the default units for a measure command
Modified: sandbox/jng/weblayout/Common/Schema/WebLayout-2.5.0.xsd
--- sandbox/jng/weblayout/Common/Schema/WebLayout-2.5.0.xsd 2012-10-22 07:10:20 UTC (rev 7149)
+++ sandbox/jng/weblayout/Common/Schema/WebLayout-2.5.0.xsd 2012-10-22 08:19:48 UTC (rev 7150)
@@ -6,6 +6,8 @@
<xs:element name="Title" type="xs:string"/>
<xs:element name="Map" type="MapType"/>
<xs:element name="EnablePingServer" type="xs:boolean" minOccurs="0" />
+ <xs:element name="UseUsEnglishUnits" type="xs:boolean" minOccurs="0" />
+ <xs:element name="MeasureUnits" type="xs:string" minOccurs="0" />
<xs:element name="SelectionColor" type="xs:string" minOccurs="0" />
<xs:element name="PointSelectionBuffer" type="xs:integer" minOccurs="0" />
<xs:element name="MapImageFormat" type="xs:string" minOccurs="0" />
Modified: sandbox/jng/weblayout/Web/src/DotNetUnmanagedApi/Web/WebConstants.xml
--- sandbox/jng/weblayout/Web/src/DotNetUnmanagedApi/Web/WebConstants.xml 2012-10-22 07:10:20 UTC (rev 7149)
+++ sandbox/jng/weblayout/Web/src/DotNetUnmanagedApi/Web/WebConstants.xml 2012-10-22 08:19:48 UTC (rev 7150)
@@ -63,6 +63,7 @@
<Classes>
<Class name="MgWebWidgetType" />
+ <Class name="MgWebMeasureUnits" />
<Class name="MgWebTaskButtonType" />
<Class name="MgWebTargetType" />
<Class name="MgWebTargetViewerType" />
@@ -77,6 +78,7 @@
<!-- API -->
<Header path="../../WebApp/WebActions.h" />
+ <Header path="../../WebApp/WebMeasureUnits.h" />
<Header path="../../WebApp/WebTargetType.h" />
<Header path="../../WebApp/WebTargetViewerType.h" />
<Header path="../../WebApp/WebTaskButtonType.h" />
Modified: sandbox/jng/weblayout/Web/src/MapGuideApi/Constants.xml
--- sandbox/jng/weblayout/Web/src/MapGuideApi/Constants.xml 2012-10-22 07:10:20 UTC (rev 7149)
+++ sandbox/jng/weblayout/Web/src/MapGuideApi/Constants.xml 2012-10-22 08:19:48 UTC (rev 7150)
@@ -100,6 +100,7 @@
<Class name="MgWebActions" />
<Class name="MgConfigProperties" />
<Class name="MgLogFileType" />
<Class name="MgServerInformationProperties" />
@@ -188,6 +189,7 @@
<Header path="../../../Common/MapGuideCommon/System/ConfigProperties.h" />
<Header path="../WebApp/WebActions.h" />
+ <Header path="../WebApp/WebMeasureUnits.h" />
<Header path="../WebApp/WebTargetType.h" />
<Header path="../WebApp/WebTargetViewerType.h" />
<Header path="../WebApp/WebTaskButtonType.h" />
Modified: sandbox/jng/weblayout/Web/src/WebApp/WebApp.h
--- sandbox/jng/weblayout/Web/src/WebApp/WebApp.h 2012-10-22 07:10:20 UTC (rev 7149)
+++ sandbox/jng/weblayout/Web/src/WebApp/WebApp.h 2012-10-22 08:19:48 UTC (rev 7150)
@@ -28,6 +28,7 @@
#include "WebAppClassId.h"
#include "WebActions.h"
+#include "WebMeasureUnits.h"
#include "WebTargetType.h"
#include "WebTargetViewerType.h"
#include "WebCommand.h"
Modified: sandbox/jng/weblayout/Web/src/WebApp/WebApp.vcxproj
--- sandbox/jng/weblayout/Web/src/WebApp/WebApp.vcxproj 2012-10-22 07:10:20 UTC (rev 7149)
+++ sandbox/jng/weblayout/Web/src/WebApp/WebApp.vcxproj 2012-10-22 08:19:48 UTC (rev 7150)
@@ -209,6 +209,7 @@
<ClInclude Include="WebInvokeUrlCommand.h" />
<ClInclude Include="WebLayout.h" />
<ClInclude Include="WebMeasureCommand.h" />
+ <ClInclude Include="WebMeasureUnits.h" />
<ClInclude Include="WebPrintCommand.h" />
<ClInclude Include="WebSearchCommand.h" />
<ClInclude Include="WebSelectWithinCommand.h" />
@@ -316,6 +317,12 @@
<ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">true</ExcludedFromBuild>
<ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|x64'">true</ExcludedFromBuild>
</ClCompile>
+ <ClCompile Include="WebMeasureUnits.cpp">
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">true</ExcludedFromBuild>
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">true</ExcludedFromBuild>
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">true</ExcludedFromBuild>
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|x64'">true</ExcludedFromBuild>
+ </ClCompile>
<ClCompile Include="WebPrintCommand.cpp">
Modified: sandbox/jng/weblayout/Web/src/WebApp/WebAppBuild.cpp
--- sandbox/jng/weblayout/Web/src/WebApp/WebAppBuild.cpp 2012-10-22 07:10:20 UTC (rev 7149)
+++ sandbox/jng/weblayout/Web/src/WebApp/WebAppBuild.cpp 2012-10-22 08:19:48 UTC (rev 7150)
@@ -29,6 +29,7 @@
#include "WebInvokeUrlCommand.cpp"
#include "WebLayout.cpp"
#include "WebMeasureCommand.cpp"
+#include "WebMeasureUnits.cpp"
#include "WebPrintCommand.cpp"
#include "WebSearchCommand.cpp"
#include "WebSelectWithinCommand.cpp"
Modified: sandbox/jng/weblayout/Web/src/WebApp/WebLayout.cpp
--- sandbox/jng/weblayout/Web/src/WebApp/WebLayout.cpp 2012-10-22 07:10:20 UTC (rev 7149)
+++ sandbox/jng/weblayout/Web/src/WebApp/WebLayout.cpp 2012-10-22 08:19:48 UTC (rev 7150)
@@ -28,7 +28,9 @@
m_pointPixelBuffer(2),
m_mapImageFormat(MgImageFormats::Png),
m_selectionImageFormat(MgImageFormats::Png),
- m_startupScript(L"") //NOXLATE
+ m_startupScript(L""), //NOXLATE
+ m_defaultMeasureUnits(MgWebMeasureUnits::Miles),
+ m_useUsEnglishUnits(true)
MG_TRY()
@@ -88,6 +90,30 @@
/// <summary>
+/// Gets whether to use US english units for display of distances
+/// </summary>
+/// <returns>
+/// true if US english units are to be used. If false, metric units will be used instead
+/// </returns>
+bool MgWebLayout::GetUseUsEnglishUnits()
+ return m_useUsEnglishUnits;
+/// <summary>
+/// Returns the unit of measurement that the Measure command will default to
+/// </summary>
+/// <returns>
+/// The unit of measurement that the Measure command will default to
+/// </returns>
+STRING MgWebLayout::GetDefaultMeasureUnit()
+ return m_defaultMeasureUnits;
+/// <summary>
/// Returns the selection color in HTML RGBA format
/// </summary>
/// <returns>
@@ -324,6 +350,14 @@
m_enablePingServer = GetBooleanFromElement(elt);
+ else if(strName == L"UseUsEnglishUnits") //NOXLATE
+ m_useUsEnglishUnits = GetBooleanFromElement(elt);
+ else if(strName == L"MeasureUnits") //NOXLATE
+ m_defaultMeasureUnits = GetStringFromElement(elt);
else if(strName == L"SelectionColor") //NOXLATE
m_selectionColor = GetStringFromElement(elt);
Modified: sandbox/jng/weblayout/Web/src/WebApp/WebLayout.h
--- sandbox/jng/weblayout/Web/src/WebApp/WebLayout.h 2012-10-22 07:10:20 UTC (rev 7149)
+++ sandbox/jng/weblayout/Web/src/WebApp/WebLayout.h 2012-10-22 08:19:48 UTC (rev 7150)
@@ -62,6 +62,24 @@
/// </returns>
bool GetEnablePingServer();
+ /// <summary>
+ /// Gets whether to use US english units for display of distances
+ /// </summary>
+ /// <returns>
+ /// true if US english units are to be used. If false, metric units will be used instead
+ /// </returns>
+ bool GetUseUsEnglishUnits();
+ /// <summary>
+ /// Returns the unit of measurement that the Measure command will default to
+ /// </summary>
+ /// <returns>
+ /// The unit of measurement that the Measure command will default to
+ /// </returns>
+ STRING GetDefaultMeasureUnit();
/// <summary>
@@ -427,6 +445,8 @@
STRING m_title;
STRING m_mapDefinition;
bool m_enablePingServer;
+ bool m_useUsEnglishUnits;
+ STRING m_defaultMeasureUnits;
STRING m_mapImageFormat;
STRING m_selectionImageFormat;
INT32 m_pointPixelBuffer;
Added: sandbox/jng/weblayout/Web/src/WebApp/WebMeasureUnits.cpp
--- sandbox/jng/weblayout/Web/src/WebApp/WebMeasureUnits.cpp (rev 0)
+++ sandbox/jng/weblayout/Web/src/WebApp/WebMeasureUnits.cpp 2012-10-22 08:19:48 UTC (rev 7150)
@@ -0,0 +1,30 @@
+// Copyright (C) 2004-2011 by Autodesk, Inc.
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of version 2.1 of the GNU Lesser
+// General Public License as published by the Free Software Foundation.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+#include "WebApp.h"
+/// Image formats supported by the rendering service.
+/// The exact list of supported formats is not defined yet.
+/// At least PNG will be supported.
+const STRING MgWebMeasureUnits::Miles = L"mi";
+const STRING MgWebMeasureUnits::Kilometers = L"km";
+const STRING MgWebMeasureUnits::UsSurveyFeet = L"usft";
+const STRING MgWebMeasureUnits::Feet = L"ft";
+const STRING MgWebMeasureUnits::Meters = L"m";
Added: sandbox/jng/weblayout/Web/src/WebApp/WebMeasureUnits.h
--- sandbox/jng/weblayout/Web/src/WebApp/WebMeasureUnits.h (rev 0)
+++ sandbox/jng/weblayout/Web/src/WebApp/WebMeasureUnits.h 2012-10-22 08:19:48 UTC (rev 7150)
@@ -0,0 +1,37 @@
+#ifndef _MGWEBMEASUREUNITS_H_
+#define _MGWEBMEASUREUNITS_H_
+/// \brief
+/// Measurement units supported by the AJAX Viewer Measure command
+class MG_WEBAPP_API MgWebMeasureUnits
+PUBLISHED_API:
+ /// \internal
+ /// The "value(xxx)" comments are used by SWIG to build constants.php. Do not alter them.
+ static const STRING Miles; /// \if INTERNAL value("mi") \endif
+ static const STRING Kilometers; /// \if INTERNAL value("km") \endif
+ static const STRING UsSurveyFeet; /// \if INTERNAL value("usft") \endif
+ static const STRING Feet; /// \if INTERNAL value("ft") \endif
+ static const STRING Meters; /// \if INTERNAL value("m") \endif
+#endif
\ No newline at end of file
More information about the mapguide-commits
