[mapguide-commits] r7160 - in trunk/Tools/Maestro: Maestro.Editors/Common OSGeo.MapGuide.MaestroAPI OSGeo.MapGuide.MaestroAPI/Resource/Conversion
svn_mapguide at osgeo.org
Mon Oct 29 00:59:12 PDT 2012
Author: jng
Date: 2012-10-29 00:59:12 -0700 (Mon, 29 Oct 2012)
New Revision: 7160
Added:
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Conversion/ImageSymbolConverter.cs
trunk/Tools/Maestro/Maestro.Editors/Common/SymbolPicker.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs
#2131: Add a new ImageSymbolConverter class to support the ability to extract image symbols in a DWF-based SymbolLibrary into individual image-based SymbolDefinition resources. Functionality verified against the Sheboygan dataset using brand spanking new IronPython REPL!
Modified: trunk/Tools/Maestro/Maestro.Editors/Common/SymbolPicker.cs
--- trunk/Tools/Maestro/Maestro.Editors/Common/SymbolPicker.cs 2012-10-26 19:40:55 UTC (rev 7159)
+++ trunk/Tools/Maestro/Maestro.Editors/Common/SymbolPicker.cs 2012-10-29 07:59:12 UTC (rev 7160)
@@ -31,6 +31,7 @@
using Maestro.Editors.Generic;
using System.IO;
using OSGeo.MapGuide.ObjectModels.DrawingSource;
+using OSGeo.MapGuide.MaestroAPI.Resource.Conversion;
namespace Maestro.Editors.Common
@@ -104,7 +105,7 @@
//But these types of symbols are deprecated anyway, so we can live with it, because people
//shouldn't be using these anymore (and thus this method by extension)
- var ds = PrepareSymbolDrawingSource(conn, symbolLibId);
+ var ds = ImageSymbolConverter.PrepareSymbolDrawingSource(conn, symbolLibId);
//Now we should be able to query it via Drawing Service APIs
var drawSvc = (IDrawingService)conn.GetService((int)ServiceType.Drawing);
@@ -135,7 +136,7 @@
private void LoadSymbols(string symResId)
- var ds = PrepareSymbolDrawingSource(_conn, symResId);
+ var ds = ImageSymbolConverter.PrepareSymbolDrawingSource(_conn, symResId);
var drawSvc = (IDrawingService)_conn.GetService((int)ServiceType.Drawing);
@@ -180,33 +181,6 @@
- private static IDrawingSource PrepareSymbolDrawingSource(IServerConnection conn, string symResId)
- //Extract the symbols.dwf resource data and copy to a session based drawing source
- var dwf = conn.ResourceService.GetResourceData(symResId, "symbols.dwf"); //NOXLATE
- if (!dwf.CanSeek)
- //House in MemoryStream
- var ms = new MemoryStream();
- Utility.CopyStream(dwf, ms);
- ms.Position = 0L;
- //Replace old stream with new
- dwf.Dispose();
- dwf = ms;
- var ds = OSGeo.MapGuide.ObjectModels.ObjectFactory.CreateDrawingSource(conn);
- ds.SourceName = "symbols.dwf"; //NOXLATE
- ds.ResourceID = "Session:" + conn.SessionID + "//" + Guid.NewGuid() + ".DrawingSource"; //NOXLATE
- conn.ResourceService.SaveResource(ds);
- using (dwf)
- conn.ResourceService.SetResourceData(ds.ResourceID, "symbols.dwf", OSGeo.MapGuide.ObjectModels.Common.ResourceDataType.File, dwf); //NOXLATE
- return ds;
private void btnCancel_Click(object sender, EventArgs e)
this.DialogResult = DialogResult.Cancel;
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj 2012-10-26 19:40:55 UTC (rev 7159)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj 2012-10-29 07:59:12 UTC (rev 7160)
@@ -259,6 +259,7 @@
<Compile Include="Resource\Comparison\CharData.cs" />
<Compile Include="Resource\Comparison\DiffEngine.cs" />
<Compile Include="Resource\Comparison\TextFile.cs" />
+ <Compile Include="Resource\Conversion\ImageSymbolConverter.cs" />
<Compile Include="Resource\Conversion\NsDoc.cs" />
<Compile Include="Resource\NsDoc.cs" />
<Compile Include="Resource\Validation\BaseMapDefinitionValidator.cs" />
Added: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Conversion/ImageSymbolConverter.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Conversion/ImageSymbolConverter.cs (rev 0)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Conversion/ImageSymbolConverter.cs 2012-10-29 07:59:12 UTC (rev 7160)
@@ -0,0 +1,175 @@
+#region Disclaimer / License
+// Copyright (C) 2012, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using OSGeo.MapGuide.MaestroAPI.Services;
+using OSGeo.MapGuide.ObjectModels;
+using OSGeo.MapGuide.ObjectModels.DrawingSource;
+using OSGeo.MapGuide.ObjectModels.SymbolLibrary;
+using System;
+using System.Collections.Generic;
+using System.Diagnostics;
+using System.Drawing;
+using System.Drawing.Imaging;
+using System.Globalization;
+using System.IO;
+using System.Linq;
+using System.Text;
+namespace OSGeo.MapGuide.MaestroAPI.Resource.Conversion
+ /// <summary>
+ /// A utility class that extracts image symbols from a Symbol Library and converts them
+ /// to image-based Symbol Definition resources
+ /// </summary>
+ public class ImageSymbolConverter
+ private string _symbolLibId;
+ private IServerConnection _conn;
+ public ImageSymbolConverter(IServerConnection conn, string symbolLibId)
+ Check.NotNull(conn, "conn"); //NOXLATE
+ Check.NotEmpty(symbolLibId, "symbolLibId"); //NOXLATE
+ Check.Precondition(ResourceIdentifier.GetResourceType(symbolLibId) == ResourceTypes.SymbolLibrary, "ResourceIdentifier.GetResourceType(symbolLibId) == ResourceTypes.SymbolLibrary"); //NOXLATE
+ Check.Precondition(Array.IndexOf(conn.Capabilities.SupportedServices, (int)ServiceType.Drawing) >= 0, "Array.IndexOf(conn.Capabilities.SupportedServices, (int)ServiceType.Drawing) >= 0"); //NOXLATE
+ _symbolLibId = symbolLibId;
+ _conn = conn;
+ /// <summary>
+ /// Creates an image-based Symbol Definition in the specified folder for each image symbol in the Symbol Library.
+ /// Any existing resource names are overwritten
+ /// </summary>
+ /// <param name="targetFolder"></param>
+ public void ExtractSymbols(string targetFolder)
+ Check.NotEmpty(targetFolder, "targetFolder"); //NOXLATE
+ Check.Precondition(ResourceIdentifier.IsFolderResource(targetFolder), "ResourceIdentifier.IsFolderResource(targetFolder)"); //NOXLATE
+ IDrawingService drawSvc = (IDrawingService)_conn.GetService((int)ServiceType.Drawing);
+ IDrawingSource ds = PrepareSymbolDrawingSource(_conn, _symbolLibId);
+ //Each section in the symbols.dwf represents a symbol
+ var sectionList = drawSvc.EnumerateDrawingSections(ds.ResourceID);
+ foreach (var sect in sectionList.Section)
+ var sectResources = drawSvc.EnumerateDrawingSectionResources(ds.ResourceID, sect.Name);
+ foreach (var res in sectResources.SectionResource)
+ if (res.Role.ToUpper() == StringConstants.Thumbnail.ToUpper())
+ using (var rs = drawSvc.GetSectionResource(ds.ResourceID, res.Href))
+ using (Image img = Image.FromStream(rs))
+ string targetId = targetFolder + sect.Title + "." + ResourceTypes.SymbolDefinition.ToString();
+ string dataName = sect.Title + "." + GetImageFormat(img.RawFormat);
+ var symDef = ObjectFactory.CreateSimpleSymbol(_conn, sect.Title, "Image symbol definition extracted from a Symbol Library by Maestro"); //NOXLATE
+ var imgGraphics = symDef.CreateImageGraphics();
+ symDef.AddGraphics(imgGraphics);
+ imgGraphics.Item = symDef.CreateImageReference(string.Empty, Utility.FdoStringifiyLiteral(dataName)); //Empty resource id = self reference
+ imgGraphics.SizeScalable = "True"; //NOXLATE
+ imgGraphics.ResizeControl = Utility.FdoStringifiyLiteral("ResizeNone"); //NOXLATE
+ imgGraphics.Angle = "0.0"; //NOXLATE
+ imgGraphics.PositionX = "0.0"; //NOXLATE
+ imgGraphics.PositionY = "4.0"; //NOXLATE
+ imgGraphics.SizeX = PxToMillimeters(img.Width).ToString(CultureInfo.InvariantCulture);
+ imgGraphics.SizeY = PxToMillimeters(img.Height).ToString(CultureInfo.InvariantCulture);
+ symDef.PointUsage = symDef.CreatePointUsage();
+ symDef.PointUsage.Angle = "%ROTATION_ANGLE%"; //NOXLATE
+ var rotParam = symDef.CreateParameter();
+ rotParam.DataType = "String"; //NOXLATE
+ rotParam.Identifier = "ROTATION_ANGLE"; //NOXLATE
+ rotParam.DisplayName = "Angle to rotate symbol"; //NOXLATE
+ rotParam.DefaultValue = "0.0"; //NOXLATE
+ symDef.ParameterDefinition.AddParameter(rotParam);
+ _conn.ResourceService.SaveResourceAs(symDef, targetId);
+ using (var ms = new MemoryStream())
+ img.Save(ms, ImageFormat.Png);
+ ms.Position = 0L; //Rewind
+ _conn.ResourceService.SetResourceData(targetId, dataName, ObjectModels.Common.ResourceDataType.File, ms);
+ Trace.TraceInformation("Extracted symbol: " + targetId);
+ private string GetImageFormat(ImageFormat imageFormat)
+ if (imageFormat.Guid == ImageFormat.Png.Guid)
+ return "png"; //NOXLATE
+ else if (imageFormat.Guid == ImageFormat.Jpeg.Guid)
+ return "jpg"; //NOXLATE
+ else
+ throw new NotSupportedException();
+ const int DPI = 96;
+ private static double PxToMillimeters(int pixels)
+ var res = (pixels * 2.54 / DPI) * 10;
+ return Math.Round(res, 1);
+ public static IDrawingSource PrepareSymbolDrawingSource(IServerConnection conn, string symResId)
+ //Extract the symbols.dwf resource data and copy to a session based drawing source
+ var dwf = conn.ResourceService.GetResourceData(symResId, "symbols.dwf"); //NOXLATE
+ if (!dwf.CanSeek)
+ //House in MemoryStream
+ var ms = new MemoryStream();
+ Utility.CopyStream(dwf, ms);
+ ms.Position = 0L;
+ //Replace old stream with new
+ dwf.Dispose();
+ dwf = ms;
+ var ds = OSGeo.MapGuide.ObjectModels.ObjectFactory.CreateDrawingSource(conn);
+ ds.SourceName = "symbols.dwf"; //NOXLATE
+ ds.ResourceID = "Session:" + conn.SessionID + "//" + Guid.NewGuid() + ".DrawingSource"; //NOXLATE
+ conn.ResourceService.SaveResource(ds);
+ using (dwf)
+ conn.ResourceService.SetResourceData(ds.ResourceID, "symbols.dwf", OSGeo.MapGuide.ObjectModels.Common.ResourceDataType.File, dwf); //NOXLATE
+ return ds;
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs 2012-10-26 19:40:55 UTC (rev 7159)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs 2012-10-29 07:59:12 UTC (rev 7160)
@@ -1102,6 +1102,17 @@
parentRange.MinScale.HasValue ? parentRange.MinScale.Value.ToString(CultureInfo.InvariantCulture) : "0", //NOXLATE
parentRange.MaxScale.HasValue ? parentRange.MaxScale.Value.ToString(CultureInfo.InvariantCulture) : "Infinity"); //NOXLATE
+ /// <summary>
+ /// Surrounds the given string with single-quotes. Mainly used for FDO expressions where string literals are required as un-quoted
+ /// strings will trigger the FDO expression engine.
+ /// </summary>
+ /// <param name="str"></param>
+ /// <returns></returns>
+ public static string FdoStringifiyLiteral(string str)
+ return "'" + str + "'"; //NOXLATE
/// <summary>
More information about the mapguide-commits
