[mapguide-commits] r7165 - in branches/maestro-4.0.x: . Maestro Maestro.Editors/WebLayout
svn_mapguide at osgeo.org
Mon Oct 29 08:45:09 PDT 2012
Author: jng
Date: 2012-10-29 08:45:08 -0700 (Mon, 29 Oct 2012)
New Revision: 7165
branches/maestro-4.0.x/
branches/maestro-4.0.x/Maestro.Editors/WebLayout/WebLayoutMenusCtrl.Designer.cs
branches/maestro-4.0.x/Maestro.Editors/WebLayout/WebLayoutMenusCtrl.cs
branches/maestro-4.0.x/Maestro/changelog.txt
#2160: Backport r7164 to 4.0.x
Property changes on: branches/maestro-4.0.x
___________________________________________________________________
Modified: svn:mergeinfo
- /trunk/Tools/Maestro:6490-6494,6923-6924,6926,6928,7026,7034,7056,7058,7060-7061,7073-7074,7125-7128
+ /trunk/Tools/Maestro:6490-6494,6923-6924,6926,6928,7026,7034,7056,7058,7060-7061,7073-7074,7125-7128,7164
Modified: branches/maestro-4.0.x/Maestro/changelog.txt
--- branches/maestro-4.0.x/Maestro/changelog.txt 2012-10-29 15:35:21 UTC (rev 7164)
+++ branches/maestro-4.0.x/Maestro/changelog.txt 2012-10-29 15:45:08 UTC (rev 7165)
@@ -1,6 +1,7 @@
4.0.4
- Improved WMS Feature Source editor
+ - Fix: Web Layout editor - Available command selection wackiness
- Fix: XSD data type case-sensitivity when parsing FDO Data properties
- Fix: Improve memory usage in SetResourceData (Local/LocalNative) for really large files
- Fix: FDO class name encoding/decoding
Modified: branches/maestro-4.0.x/Maestro.Editors/WebLayout/WebLayoutMenusCtrl.Designer.cs
--- branches/maestro-4.0.x/Maestro.Editors/WebLayout/WebLayoutMenusCtrl.Designer.cs 2012-10-29 15:35:21 UTC (rev 7164)
+++ branches/maestro-4.0.x/Maestro.Editors/WebLayout/WebLayoutMenusCtrl.Designer.cs 2012-10-29 15:45:08 UTC (rev 7165)
@@ -107,12 +107,15 @@
// grdCommands
+ this.grdCommands.AllowUserToAddRows = false;
+ this.grdCommands.AllowUserToDeleteRows = false;
resources.ApplyResources(this.grdCommands, "grdCommands");
this.grdCommands.ColumnHeadersHeightSizeMode = System.Windows.Forms.DataGridViewColumnHeadersHeightSizeMode.AutoSize;
this.grdCommands.Name = "grdCommands";
+ this.grdCommands.ReadOnly = true;
this.grdCommands.CellClick += new System.Windows.Forms.DataGridViewCellEventHandler(this.grdCommands_CellClick);
+ this.grdCommands.CellContentClick += new System.Windows.Forms.DataGridViewCellEventHandler(this.grdCommands_CellClick);
this.grdCommands.DragLeave += new System.EventHandler(this.grdCommands_DragLeave);
- this.grdCommands.CellContentClick += new System.Windows.Forms.DataGridViewCellEventHandler(this.grdCommands_CellClick);
// groupBox1
@@ -193,9 +196,8 @@
// WebLayoutMenusCtrl
this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.None;
- this.HeaderText = "Menus and Toolbars";
+ resources.ApplyResources(this, "$this");
this.Name = "WebLayoutMenusCtrl";
- resources.ApplyResources(this, "$this");
this.contentPanel.ResumeLayout(false);
((System.ComponentModel.ISupportInitialize)(this.grdCommands)).EndInit();
this.groupBox1.ResumeLayout(false);
Modified: branches/maestro-4.0.x/Maestro.Editors/WebLayout/WebLayoutMenusCtrl.cs
--- branches/maestro-4.0.x/Maestro.Editors/WebLayout/WebLayoutMenusCtrl.cs 2012-10-29 15:35:21 UTC (rev 7164)
+++ branches/maestro-4.0.x/Maestro.Editors/WebLayout/WebLayoutMenusCtrl.cs 2012-10-29 15:45:08 UTC (rev 7165)
@@ -106,6 +106,10 @@
grdCommands.Rows[cell.RowIndex].Selected = true;
btnAddFromCmdSet.Enabled = true;
+ else if (grdCommands.SelectedRows.Count == 1)
+ btnAddFromCmdSet.Enabled = true;
else
btnAddFromCmdSet.Enabled = false;
More information about the mapguide-commits
