[mapguide-commits] r7176 - in branches/maestro-4.0.x: . Maestro.Base/Commands Maestro.Base/Editor Maestro.Base/Properties Maestro.Base/UI Maestro.Editors/Common Maestro.Editors/FeatureSource/Providers Maestro.Editors/FeatureSource/Providers/Rdbms Maestro.Editors/FeatureSource/Providers/Wms Maestro.Editors/Fusion Maestro.Editors/LayerDefinition/Drawing Maestro.Editors/LayerDefinition/Raster Maestro.Editors/LayerDefinition/Vector Maestro.Editors/LayerDefinition/Vector/Scales Maestro.Editors/LayerDefinition/Vector/StyleEditors Maestro.Editors/LayerDefinition/Vector/Thematics Maestro.Editors/MapDefinition
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Oct 31 05:37:34 PDT 2012
Author: jng
Date: 2012-10-31 05:37:34 -0700 (Wed, 31 Oct 2012)
New Revision: 7176
   branches/maestro-4.0.x/
   branches/maestro-4.0.x/Maestro.Base/Commands/ValidateEditedResourceCommand.cs
   branches/maestro-4.0.x/Maestro.Base/Editor/EditorContentBase.cs
   branches/maestro-4.0.x/Maestro.Base/Properties/Resources.resx
   branches/maestro-4.0.x/Maestro.Base/UI/OpenResourceIdDialog.resx
   branches/maestro-4.0.x/Maestro.Base/UI/ValidationResultsDialog.cs
   branches/maestro-4.0.x/Maestro.Base/UI/ValidationResultsDialog.designer.cs
   branches/maestro-4.0.x/Maestro.Base/UI/ValidationResultsDialog.resx
   branches/maestro-4.0.x/Maestro.Editors/Common/ExpressionEditor.resx
   branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/GenericCtrl.resx
   branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/Rdbms/RdbmsBaseCtrl.resx
   branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/SetCredentialsDialog.resx
   branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/Wms/WmsAdvancedConfigurationDialog.resx
   branches/maestro-4.0.x/Maestro.Editors/Fusion/MapCtrl.resx
   branches/maestro-4.0.x/Maestro.Editors/LayerDefinition/Drawing/DrawingLayerSettingsCtrl.resx
   branches/maestro-4.0.x/Maestro.Editors/LayerDefinition/Raster/RasterLayerSettingsSectionCtrl.resx
   branches/maestro-4.0.x/Maestro.Editors/LayerDefinition/Vector/Scales/PointStylePanel.resx
   branches/maestro-4.0.x/Maestro.Editors/LayerDefinition/Vector/Scales/VectorScaleRangeCtrl.resx
   branches/maestro-4.0.x/Maestro.Editors/LayerDefinition/Vector/StyleEditors/AreaFeatureStyleEditor.resx
   branches/maestro-4.0.x/Maestro.Editors/LayerDefinition/Vector/StyleEditors/FontStyleEditor.resx
   branches/maestro-4.0.x/Maestro.Editors/LayerDefinition/Vector/StyleEditors/PointFeatureStyleEditor.resx
   branches/maestro-4.0.x/Maestro.Editors/LayerDefinition/Vector/Thematics/ThemeCreator.resx
   branches/maestro-4.0.x/Maestro.Editors/LayerDefinition/Vector/VectorLayerSettingsSectionCtrl.resx
   branches/maestro-4.0.x/Maestro.Editors/MapDefinition/FiniteScaleListCtrl.resx
#2147: Backport to 4.0.x. Also fix assorted resx fubar from previous merges
Property changes on: branches/maestro-4.0.x
___________________________________________________________________
Modified: svn:mergeinfo
   - /trunk/Tools/Maestro:6490-6494,6923-6924,6926,6928,7026,7034,7056,7058,7060-7061,7073-7074,7125-7128,7164,7166,7168
   + /trunk/Tools/Maestro:6490-6494,6923-6924,6926,6928,7026,7034,7056,7058,7060-7061,7073-7074,7125-7128,7164,7166,7168,7175
Modified: branches/maestro-4.0.x/Maestro.Base/Commands/ValidateEditedResourceCommand.cs
--- branches/maestro-4.0.x/Maestro.Base/Commands/ValidateEditedResourceCommand.cs	2012-10-31 12:21:00 UTC (rev 7175)
+++ branches/maestro-4.0.x/Maestro.Base/Commands/ValidateEditedResourceCommand.cs	2012-10-31 12:37:34 UTC (rev 7176)
@@ -90,6 +90,16 @@
             return set.GetAllIssues();
+        private static void OpenAffectedResource(IResource res)
+            var wb = Workbench.Instance;
+            var siteExp = wb.ActiveSiteExplorer;
+            var omgr = ServiceRegistry.GetService<OpenResourceManager>();
+            var connMgr = ServiceRegistry.GetService<ServerConnectionManager>();
+            var conn = connMgr.GetConnection(siteExp.ConnectionName);
+            omgr.Open(res, conn, false, siteExp);
         protected static void CollectAndDisplayIssues(ValidationIssue[] issues)
             if (issues != null)
@@ -117,7 +127,7 @@
                                 kvp.Value.ToArray()));
-                    var resDlg = new ValidationResultsDialog(groupedIssues);
+                    var resDlg = new ValidationResultsDialog(groupedIssues, OpenAffectedResource);
                     resDlg.Show();
                 else
Modified: branches/maestro-4.0.x/Maestro.Base/Editor/EditorContentBase.cs
--- branches/maestro-4.0.x/Maestro.Base/Editor/EditorContentBase.cs	2012-10-31 12:21:00 UTC (rev 7175)
+++ branches/maestro-4.0.x/Maestro.Base/Editor/EditorContentBase.cs	2012-10-31 12:37:34 UTC (rev 7176)
@@ -102,6 +102,11 @@
         public IResource Resource { get { return this.EditorService.GetEditedResource(); } }
+        private void OpenAffectedResource(IResource res)
+            _svc.OpenResource(res.ResourceID);
         /// <summary>
         /// Performs any pre-save validation logic. The base implementation performs
         /// a <see cref="ResourceValidatorSet"/> validation (non-casccading) on the
Modified: branches/maestro-4.0.x/Maestro.Base/Properties/Resources.resx
--- branches/maestro-4.0.x/Maestro.Base/Properties/Resources.resx	2012-10-31 12:21:00 UTC (rev 7175)
+++ branches/maestro-4.0.x/Maestro.Base/Properties/Resources.resx	2012-10-31 12:37:34 UTC (rev 7176)
@@ -1092,7 +1092,7 @@
     <value>Invalid Resource ID</value>
   </data>
   <data name="folder_open_document" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\folder-open-document.png;System.Drawing.Bitmap, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+    <value>..\Resources\folder-open-document.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
   </data>
   <data name="Menu_File_OpenResource" xml:space="preserve">
     <value>Open Resource</value>
Modified: branches/maestro-4.0.x/Maestro.Base/UI/OpenResourceIdDialog.resx
--- branches/maestro-4.0.x/Maestro.Base/UI/OpenResourceIdDialog.resx	2012-10-31 12:21:00 UTC (rev 7175)
+++ branches/maestro-4.0.x/Maestro.Base/UI/OpenResourceIdDialog.resx	2012-10-31 12:37:34 UTC (rev 7176)
@@ -112,9 +112,9 @@
     <value>2.0</value>
   </resheader>
   <resheader name="reader">
-    <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </resheader>
   <resheader name="writer">
-    <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </resheader>
 </root>
\ No newline at end of file
Modified: branches/maestro-4.0.x/Maestro.Base/UI/ValidationResultsDialog.cs
--- branches/maestro-4.0.x/Maestro.Base/UI/ValidationResultsDialog.cs	2012-10-31 12:21:00 UTC (rev 7175)
+++ branches/maestro-4.0.x/Maestro.Base/UI/ValidationResultsDialog.cs	2012-10-31 12:37:34 UTC (rev 7176)
@@ -34,24 +34,61 @@
         private List<KeyValuePair<string, ValidationIssue[]>> m_issues = new List<KeyValuePair<string, ValidationIssue[]>>();
+        private Action<IResource> _openAction;
+        /// <summary>
+        /// Creates a new instance
+        /// </summary>
+        /// <param name="resourceId"></param>
+        /// <param name="issues"></param>
         public ValidationResultsDialog(string resourceId, ValidationIssue[] issues)
+            : this(resourceId, issues, null)
+        /// <summary>
+        /// </summary>
+        /// <param name="openAction"></param>
+        public ValidationResultsDialog(string resourceId, ValidationIssue[] issues, Action<IResource> openAction)
             : this(
                     new KeyValuePair<string, ValidationIssue[]>[] {
                         new KeyValuePair<string, ValidationIssue[]>(resourceId, issues)
+                openAction
         public ValidationResultsDialog(List<KeyValuePair<string, ValidationIssue[]>> issues)
+            : this(issues, null)
+        /// <summary>
+        /// </summary>
+        public ValidationResultsDialog(List<KeyValuePair<string, ValidationIssue[]>> issues, Action<IResource> openAction)
             : this()
-            listView1.Items.Clear();
+            lstIssues.Items.Clear();
             m_issues = issues;
+            PopulateIssues();
+            _openAction = openAction;
+            btnOpen.Visible = (_openAction != null);
+            btnOpen.Enabled = false;
-            foreach (KeyValuePair<string, ValidationIssue[]> e in issues)
+        private void PopulateIssues()
+            foreach (KeyValuePair<string, ValidationIssue[]> e in m_issues)
                 foreach (ValidationIssue issue in e.Value)
@@ -74,9 +111,10 @@
                             lvi.ImageIndex = -1;
                             break;
+                    lvi.Tag = issue;
                     lvi.SubItems.Add(issue.Message);
                     lvi.SubItems.Add(issue.StatusCode.ToString());
-                    listView1.Items.Add(lvi);
+                    lstIssues.Items.Add(lvi);
@@ -120,5 +158,19 @@
                 MessageBox.Show(this, string.Format(Properties.Resources.ValidationFailedError, msg), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
+        private void btnOpen_Click(object sender, EventArgs e)
+            if (_openAction != null && lstIssues.SelectedItems.Count == 1)
+                _openAction(((ValidationIssue)lstIssues.SelectedItems[0].Tag).Resource);
+        private void lstIssues_SelectedIndexChanged(object sender, EventArgs e)
+            btnOpen.Enabled = (lstIssues.SelectedItems.Count == 1);
Modified: branches/maestro-4.0.x/Maestro.Base/UI/ValidationResultsDialog.designer.cs
--- branches/maestro-4.0.x/Maestro.Base/UI/ValidationResultsDialog.designer.cs	2012-10-31 12:21:00 UTC (rev 7175)
+++ branches/maestro-4.0.x/Maestro.Base/UI/ValidationResultsDialog.designer.cs	2012-10-31 12:37:34 UTC (rev 7176)
@@ -33,17 +33,19 @@
             this.panel1 = new System.Windows.Forms.Panel();
             this.SaveReportBtn = new System.Windows.Forms.Button();
             this.CancelBtn = new System.Windows.Forms.Button();
-            this.listView1 = new System.Windows.Forms.ListView();
+            this.lstIssues = new System.Windows.Forms.ListView();
             this.columnHeader1 = new System.Windows.Forms.ColumnHeader();
             this.columnHeader2 = new System.Windows.Forms.ColumnHeader();
+            this.columnHeader3 = new System.Windows.Forms.ColumnHeader();
             this.imageList1 = new System.Windows.Forms.ImageList(this.components);
             this.saveFileDialog = new System.Windows.Forms.SaveFileDialog();
-            this.columnHeader3 = ((System.Windows.Forms.ColumnHeader)(new System.Windows.Forms.ColumnHeader()));
+            this.btnOpen = new System.Windows.Forms.Button();
             this.panel1.SuspendLayout();
             this.SuspendLayout();
             // panel1
+            this.panel1.Controls.Add(this.btnOpen);
             this.panel1.Controls.Add(this.SaveReportBtn);
             this.panel1.Controls.Add(this.CancelBtn);
             resources.ApplyResources(this.panel1, "panel1");
@@ -64,18 +66,20 @@
             this.CancelBtn.UseVisualStyleBackColor = true;
             this.CancelBtn.Click += new System.EventHandler(this.CancelBtn_Click);
-            // listView1
+            // lstIssues
-            this.listView1.Columns.AddRange(new System.Windows.Forms.ColumnHeader[] {
+            this.lstIssues.Columns.AddRange(new System.Windows.Forms.ColumnHeader[] {
             this.columnHeader1,
             this.columnHeader2,
             this.columnHeader3});
-            resources.ApplyResources(this.listView1, "listView1");
-            this.listView1.GridLines = true;
-            this.listView1.Name = "listView1";
-            this.listView1.SmallImageList = this.imageList1;
-            this.listView1.UseCompatibleStateImageBehavior = false;
-            this.listView1.View = System.Windows.Forms.View.Details;
+            resources.ApplyResources(this.lstIssues, "lstIssues");
+            this.lstIssues.GridLines = true;
+            this.lstIssues.MultiSelect = false;
+            this.lstIssues.Name = "lstIssues";
+            this.lstIssues.SmallImageList = this.imageList1;
+            this.lstIssues.UseCompatibleStateImageBehavior = false;
+            this.lstIssues.View = System.Windows.Forms.View.Details;
+            this.lstIssues.SelectedIndexChanged += new System.EventHandler(this.lstIssues_SelectedIndexChanged);
             // columnHeader1
@@ -85,6 +89,10 @@
             resources.ApplyResources(this.columnHeader2, "columnHeader2");
+            // columnHeader3
+            resources.ApplyResources(this.columnHeader3, "columnHeader3");
             // imageList1
             this.imageList1.ImageStream = ((System.Windows.Forms.ImageListStreamer)(resources.GetObject("imageList1.ImageStream")));
@@ -98,16 +106,19 @@
             this.saveFileDialog.DefaultExt = "txt";
             resources.ApplyResources(this.saveFileDialog, "saveFileDialog");
-            // columnHeader3
+            // btnOpen
-            resources.ApplyResources(this.columnHeader3, "columnHeader3");
+            resources.ApplyResources(this.btnOpen, "btnOpen");
+            this.btnOpen.Name = "btnOpen";
+            this.btnOpen.UseVisualStyleBackColor = true;
+            this.btnOpen.Click += new System.EventHandler(this.btnOpen_Click);
             // ValidationResultsDialog
             this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.None;
             this.CancelButton = this.CancelBtn;
             resources.ApplyResources(this, "$this");
-            this.Controls.Add(this.listView1);
+            this.Controls.Add(this.lstIssues);
             this.Controls.Add(this.panel1);
             this.Name = "ValidationResultsDialog";
             this.ShowIcon = false;
@@ -120,12 +131,13 @@
         private System.Windows.Forms.Panel panel1;
         private System.Windows.Forms.Button CancelBtn;
-        private System.Windows.Forms.ListView listView1;
+        private System.Windows.Forms.ListView lstIssues;
         private System.Windows.Forms.ColumnHeader columnHeader1;
         private System.Windows.Forms.ColumnHeader columnHeader2;
         private System.Windows.Forms.ImageList imageList1;
         private System.Windows.Forms.Button SaveReportBtn;
         private System.Windows.Forms.SaveFileDialog saveFileDialog;
         private System.Windows.Forms.ColumnHeader columnHeader3;
+        private System.Windows.Forms.Button btnOpen;
Modified: branches/maestro-4.0.x/Maestro.Base/UI/ValidationResultsDialog.resx
--- branches/maestro-4.0.x/Maestro.Base/UI/ValidationResultsDialog.resx	2012-10-31 12:21:00 UTC (rev 7175)
+++ branches/maestro-4.0.x/Maestro.Base/UI/ValidationResultsDialog.resx	2012-10-31 12:37:34 UTC (rev 7176)
@@ -118,17 +118,44 @@
   </resheader>
   <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+  <data name="btnOpen.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+    <value>Bottom, Right</value>
+  </data>
+  <assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+  <data name="btnOpen.Location" type="System.Drawing.Point, System.Drawing">
+    <value>402, 8</value>
+  </data>
+  <data name="btnOpen.Size" type="System.Drawing.Size, System.Drawing">
+    <value>100, 23</value>
+  </data>
+  <assembly alias="mscorlib" name="mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+  <data name="btnOpen.TabIndex" type="System.Int32, mscorlib">
+    <value>2</value>
+  </data>
+  <data name="btnOpen.Text" xml:space="preserve">
+    <value>Open Resource</value>
+  </data>
+  <data name=">>btnOpen.Name" xml:space="preserve">
+    <value>btnOpen</value>
+  </data>
+  <data name=">>btnOpen.Type" xml:space="preserve">
+    <value>System.Windows.Forms.Button, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </data>
+  <data name=">>btnOpen.Parent" xml:space="preserve">
+    <value>panel1</value>
+  </data>
+  <data name=">>btnOpen.ZOrder" xml:space="preserve">
+    <value>0</value>
+  </data>
   <data name="SaveReportBtn.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
     <value>Bottom, Left</value>
   </data>
-  <assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
   <data name="SaveReportBtn.Location" type="System.Drawing.Point, System.Drawing">
     <value>12, 8</value>
   </data>
   <data name="SaveReportBtn.Size" type="System.Drawing.Size, System.Drawing">
     <value>91, 23</value>
   </data>
-  <assembly alias="mscorlib" name="mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
   <data name="SaveReportBtn.TabIndex" type="System.Int32, mscorlib">
     <value>1</value>
   </data>
@@ -145,7 +172,7 @@
   </data>
   <data name=">>SaveReportBtn.ZOrder" xml:space="preserve">
-    <value>0</value>
+    <value>1</value>
   </data>
   <data name="CancelBtn.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
@@ -172,7 +199,7 @@
   </data>
   <data name=">>CancelBtn.ZOrder" xml:space="preserve">
-    <value>1</value>
+    <value>2</value>
   </data>
   <data name="panel1.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
     <value>Bottom</value>
@@ -222,13 +249,13 @@
   <data name="columnHeader3.Width" type="System.Int32, mscorlib">
     <value>200</value>
   </data>
-  <data name="listView1.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
+  <data name="lstIssues.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
     <value>Fill</value>
   </data>
-  <data name="listView1.Location" type="System.Drawing.Point, System.Drawing">
+  <data name="lstIssues.Location" type="System.Drawing.Point, System.Drawing">
     <value>0, 0</value>
   </data>
-  <data name="listView1.Size" type="System.Drawing.Size, System.Drawing">
+  <data name="lstIssues.Size" type="System.Drawing.Size, System.Drawing">
     <value>595, 232</value>
   </data>
   <metadata name="imageList1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
@@ -238,86 +265,85 @@
     <value>
         AAEAAAD/////AQAAAAAAAAAMAgAAAFdTeXN0ZW0uV2luZG93cy5Gb3JtcywgVmVyc2lvbj0yLjAuMC4w
         LCBDdWx0dXJlPW5ldXRyYWwsIFB1YmxpY0tleVRva2VuPWI3N2E1YzU2MTkzNGUwODkFAQAAACZTeXN0
-        ZW0uV2luZG93cy5Gb3Jtcy5JbWFnZUxpc3RTdHJlYW1lcgEAAAAERGF0YQcCAgAAAAkDAAAADwMAAADI
-        DgAAAk1TRnQBSQFMAgEBAwEAARwBAAEcAQABEAEAARABAAT/ASEBAAj/AUIBTQE2BwABNgMAASgDAAFA
+        ZW0uV2luZG93cy5Gb3Jtcy5JbWFnZUxpc3RTdHJlYW1lcgEAAAAERGF0YQcCAgAAAAkDAAAADwMAAAC8
+        DgAAAk1TRnQBSQFMAgEBAwEAASQBAAEkAQABEAEAARABAAT/ASEBAAj/AUIBTQE2BwABNgMAASgDAAFA
         AwABEAMAAQEBAAEgBgABEC4AAwwBEAMVAR0kAAMQARUDEQEXAxEBFwMRARcDEQEXAxEBFwMRARcDEQEX
-        AxEBFwMRARcDEQEXAxUBHRwAAwkBDAMWAR8DFgEfAxYBHwMWAR8DFgEfZAADEgEYAX0BMwEgAfcBxAFF
-        ASwB/wHNAUkBLwH/Ac4BSQEvAf8BygFIAS4B/wGkATkBJAH/AUgCRwGGFAABVQFJAUwBzQEAAbsB6wH/
-        AQABvQHsAf8BAAHBAe4B/wEAAcQB8AH/AQABxQHwAf8BAAHFAfAB/wEAAcUB8AH/AQABxQHwAf8BAAHF
-        AfAB/wEAAcMB7wH/AQABvwHtAf8BAAG7AesB/wEEAZcBvgH/FAABVAJNAasBKAE6AbYB/wEqAT0BwAH/
-        ASsBPwHGAf8BKwE/AccB/wEqAT4BwwH/ASkBPAG7Af8BIQEoAYEB/1wAAUoCSAGKAcYBRgEtAf8B1wFM
-        ATEB/wHjAVABNAH/AekBUgE1Af8B6gFSATUB/wHmAVEBNAH/Ad0BTgEyAf8BzwFJAS8B/wF/ASsBJAH8
-        EAABBgGCAaMB/wEAAbwB7AH/AQABxQHwAf8BAAHLAfMB/wEAAc4B9QH/AQAB0AH2Af8BAAHQAfYB/wEA
-        AdAB9gH/AQAB0AH2Af8BAAHPAfYB/wEAAc0B9AH/AQAByAHyAf8BAAHAAe4B/wEAAbsB6wH/AxIBGAwA
-        AVQCTQGrASoBPgHBAf8BLQFCAdAB/wEvAUUB2QH/ATABRwHeAf8BMAFHAd8B/wEwAUYB3AH/AS4BRAHV
-        Af8BKwFAAcgB/wEiASoBhAH/VAABOwI6AWMBygFHAS4B/wHfAU8BMwH/Ae8BVAE3Af8B+wHxAe8B/wH9
-        AvkB/wHhAWUBTgH/AfwBWQE6Af8B9QFWATgB/wHnAVEBNQH/AdMBSwEwAf8BfwErASQB/AwAAT4CPQFr
-        AQABvwHtAf8BAAHJAfIB/wEAAdAB9gH/AQAB1AH5Af8BAAHUAfcB/wGFAdwB6wH/AYEB2wHqAf8BAAHQ
-        AfMB/wEAAdYB+gH/AQAB0gH4Af8BAAHNAfQB/wEAAcMB7wH/AQcBgAGdAf8MAAFUAk0BqwEqAT4BwwH/
-        AS8BRAHWAf8BMgFJAeQB/wEzAUsB7AH/ATQBTAHvAf8BNAFNAfAB/wE0AUwB7gH/ATIBSgHmAf8BMAFH
-        Ad0B/wEsAUEBzAH/ASIBKgGEAf9QAAG3AUABKQH/Ad0BTgEyAf8B8gFVATcB/wH+AVwBPgn/AeMBiQF3
-        Af8B6AGbAY0C/wFgAUIB/wH5AVgBOQH/AecBUQE1Af8BzwFJAS8B/wFIAkcBhgwAARABjgGuAf8BOwHW
-        AfUB/wFBAd0B+QH/ATcB4AH7Af8BHAHNAekJ/wEqAcoB4wH/AQAB2QH7Af8BAAHUAfkB/wEAAc0B9QH/
-        AQABwwHvAf8DLwFJCAABUAJLAZ8BKQE9Ab0B/wEuAUQB1QH/ATIBSgHmAf8BqgGzAesB/wGcAaYB6QH/
-        ATcBUAH6Af8BNwFQAfsB/wFXAWkB4AH/AeUB6AH4Af8BMwFKAegB/wEwAUcB3QH/ASsBQAHIAf8BIQEo
-        AYEB/0gAAUcCRQGBAdEBSgEwAf8B6wFSATYB/wH+AVoBPAL/AWYBSQH/AewBsQGlBf8B8wHMAcQB/wHh
-        AXABWQH/AfwBaAFMAv8BYAFCAf8B9QFWATgB/wHdAU4BMgH/AaQBOQEkAf8MAAE9AjwBaAFJAdYB9QH/
-        AVAB3gH5Af8BVgHkAfsB/wFdAegB/QH/AXIB2QHpAf8BgQHeAesB/wEJAdsB+wH/AQAB2AH7Af8BAAHT
-        AfgB/wEAAcoB8wH/AQcBgQGeAf8MAAEiASoBgwH/ASwBQAHKAf8BMQFIAeAB/wGIAZQB4gn/AZwBpwHs
-        Af8BWAFrAeQJ/wHeAeEB9wH/ATIBSgHoAf8BLgFEAdUB/wEpATwBuwH/AxYBH0QAAYEBJwEhAfsB2gFN
-        ATIB/wH0AVUBNwL/AWQBSAL/AXMBWAH/AewBbgFVCf8B+AF0AVkC/wF1AVoC/wFtAVIB/wH8AVkBOgH/
-        AeYBUQE0Af8BygFIAS4B/xAAAS4BlgGwAf8BXgHeAfgB/wFlAeUB+wH/AWwB6QH9Cf8BgQHoAfkB/wFW
-        AeQB+wH/AQABzwH2Af8BAAHFAfAB/wMuAUcMAAEjASwBiQH/ATYBSwHUAf8BRAFaAekB/wFQAWUB9QH/
-        AdcB2wH3Ef8B9wH4Af0B/wE0AU0B8AH/ATQBTAHuAf8BMAFGAdwB/wEqAT4BwwH/AxYBH0QAAZ4BNgEj
-        Af8B3wFPATMB/wH3AWUBSQL/AXcBXgH/AfgBgAFlAf8B7AF6AWMB/wH8AfMB8QX/AeYBiwF5Av8BgQFo
-        Av8BewFjAf8B/gFwAVYB/wHqAVIBNQH/Ac4BSQEvAf8DFQEdDAADPAFmAW0B3gH3Af8BdAHlAfoB/wF7
-        AeoB/An/AY8B6gH5Af8BlgHtAfwB/wFbAd0B9wH/AQcBgQGeAf8QAAEvATcBjwH/AUoBXAHbAf8BUwFn
-        Ae0B/wFcAXEB+AH/AWQBdwH8Af8B3wHiAfkJ/wH8Af0B/gH/AYUBlAH5Af8BcQGDAfwB/wE0AU0B8AH/
-        ATABRwHfAf8BKwE/AccB/wMWAR9EAAGXATQBIQH/Ad4BTwEzAf8B+AGAAWUC/wGFAW8B/wH+AY0BdwH/
-        AfUB2AHSAf8B5wGbAY0F/wH5AecB5AL/AY4BeAL/AYkBcwH/Af4BgQFoAf8B7QF0AV0B/wHNAUkBLwH/
-        AwwBEBAAAT4BmgGxAf8BgwHmAfkB/wGKAesB/An/AZ4B7AH5Af8BpAHuAfsB/wGqAewB+gH/Ay0BRhAA
-        ATQBOwGQAf8BVAFmAdwB/wFeAXEB7QH/AWcBegH4Af8BhgGTAeoR/wHJAc8B9AH/AZkBpgH8Af8BoAGr
-        AfcB/wFWAWkB5AH/ASsBPwHGAf8DFgEfRAABYgFEAUAB1QHcAWYBTwH/AfUBjQF6Av8BkwGBAv8BmwGI
-        Af8B/gGeAYoB/wHtAbEBpgH/AfwB9gH0Af8B7wG8AbIC/wGdAYoC/wGXAYQB/wH7AY8BewH/AewBigF3
-        Af8BxAFFASwB/xQAAzsBZQGSAeYB+QH/AZkB7AH7Cf8BrAHuAfkB/wGyAe8B+wH/AUIBjgGiAf8UAAE5
-        AT8BjwH/AV4BbgHaAf8BaQF6AesB/wGJAZUB5gn/AfoB+wH+Af8B5AHnAfoJ/wHTAdcB9QH/AawBtQH3
-        Af8BsQG5AfEB/wFhAW8BzwH/AxYBH0QAAx8BLQHUAWkBVAH/AfEBngGOAf8B/AGiAZEC/wGnAZcC/wGr
-        AZsC/wGtAZ0B/wHvAbYBqwH/Af4B/QH8Af8B8QGlAZcB/wH+AaQBkwH/AfYBnwGPAf8B6QGbAYwB/wF9
-        ATMBIAH3GAABTgGdAbIB/wGnAe0B+wn/AbkB7wH5Af8BvgHwAfsB/wMtAUUUAAEwATMBeAH/AWkBdwHW
-        Af8BdAGDAecB/wF8AYoB6QH/A/4B/wL7Af4B/wGVAaIB+QH/AZ0BqQH9Af8B6QHrAfoF/wG2Ab0B8AH/
-        AbcBvwH1Af8BvAHDAfAB/wHBAcYB6gH/AwkBDEgAAYIBMQEdAfkB7AGuAaIB/wH1AbEBpAH/AfwBtAGm
-        Av8BtgGpAv8BuAGrAf8B9wHdAdkF/wH1AdUBzwH/AfkBsgGlAf8B8AGwAaMB/wHeAZgBigH/AxIBGBgA
-        AzsBZAG0Ae0B+gn/AcUB8AH6Af8BRwGPAaIB/xgAAwgBCwFXAV8BqgH/AYEBiwHhAf8BiAGWAe0B/wGQ
-        AZwB7QH/AZkBpAH0Af8BoQGtAfsB/wGoAbMB+wH/Aa8BuQH6Af8BuQHAAfEB/wG8AcMB9wH/AcEByAHz
-        Af8BxwHMAe4B/wFUAk0Bq08AAQEBvgF3AWkB/wHwAcEBtwH/AfYBwgG5Af8B+gHEAboB/wH8AcQBugH/
-        AfsBxAG6Af8B8gHGAb0B/wH2AcIBuQH/AfMBwgG4Af8B7AG+AbUB/wFKAkgBiiAAAVsBnwGyAf8BxgHx
-        AfsB/wHLAfIB/AH/AdAB8wH8Af8DLAFEHAADCAELAWYBbQGwAf8BkwGeAeYB/wGcAacB7gH/AaUBrwHz
-        Af8BrAG2AfYB/wGzAbwB9wH/AboBwgH3Af8BwAHHAfUB/wHGAcwB8wH/AcsB0AHwAf8BVAJNAatXAAEB
-        AYoBQQE6AfkB8gHQAckB/wH0AdEBygH/AfYB0gHKAf8B9gHSAcoB/wH1AdEBygH/AfMB0AHKAf8B1AGe
-        AZMB/wE7AjoBYyQAAzsBZAHRAfIB+wH/AdUB9AH8Af8BTQGQAaMB/yQAAwgBCwF0AXkBswH/AacBrwHn
-        Af8BrwG3Ae0B/wG2Ab4B8AH/Ab0BxAHyAf8BxAHKAfIB/wHKAc8B8QH/Ac8B0wHwAf8BVAJNAatgAAMf
-        AS0BYgFEAUAB1QGpAWsBYAH/AbQBewFwAf8BigFGATMB+wFHAkUBgTAAAVIBSAFMAdwBTwGRAaQB/wMW
-        AR4oAAMIAQsBSAFJAYEB/wFrAW0BnwH/AW4BcQGiAf8BcgF0AaQB/wF1AXYBpAH/AXMBdAGgAf8BUAJL
-        AZ//AFEAAUIBTQE+BwABPgMAASgDAAFAAwABEAMAAQEBAAEBBQABgBcAA/8BAAH+AX8BwAEDAfgBHwIA
-        AfABDwGAAQEB8AEPAgAB4AEHAYABAAHgAQcCAAHAAQMBgAEBAcABAwIAAcABAQHAAQEBgAEBAgABgAEB
-        AcABAwGAAwABgAEBAeABAwGAAwABgAEAAeABBwGAAwABgAEAAfABBwGAAwABgAEBAfABDwGAAwABgAEB
-        AfgBDwGAAwABwAEBAfgBHwGAAQECAAHAAQMB/AEfAcABAwIAAeABBwH8AT8B4AEHAgAB+AEfAf4BPwHw
-        AQ8CAAb/AgAL
+        AxEBFwMRARcDEQEXAxUBHRwAAwkBDAMWAR8DFgEfAxYBHwMWAR8DFgEfZAADEgEYAXoBNQEkAfcBxAFE
+        ASsB/wHNAUgBLgH/Ac4BSAEuAf8BygFHAS0B/wGkATgBIwH/A0gBhhQAAVcCUAHNAQABuwHrAf8BAAG9
+        AewB/wEAAcEB7gH/AQABxAHwAf8BAAHFAfAB/wEAAcUB8AH/AQABxQHwAf8BAAHFAfAB/wEAAcUB8AH/
+        AQABwwHvAf8BAAG/Ae0B/wEAAbsB6wH/AQMBlwG+Af8UAAFUAlEBqwEnATkBtgH/ASkBPAHAAf8BKgE+
+        AcYB/wEqAT4BxwH/ASkBPQHDAf8BKAE7AbsB/wEgAScBgQH/XAABSgJJAYoBxgFFASwB/wHXAUsBMAH/
+        AeMBTwEzAf8B6QFRATQB/wHqAVEBNAH/AeYBUAEzAf8B3QFNATEB/wHPAUgBLgH/AX4BKwElAfwQAAEF
+        AYIBowH/AQABvAHsAf8BAAHFAfAB/wEAAcsB8wH/AQABzgH1Af8BAAHQAfYB/wEAAdAB9gH/AQAB0AH2
+        Af8BAAHQAfYB/wEAAc8B9gH/AQABzQH0Af8BAAHIAfIB/wEAAcAB7gH/AQABuwHrAf8DEgEYDAABVAJR
+        AasBKQE9AcEB/wEsAUEB0AH/AS4BRAHZAf8BLwFGAd4B/wEvAUYB3wH/AS8BRQHcAf8BLQFDAdUB/wEq
+        AT8ByAH/ASEBKQGEAf9UAAM7AWMBygFGAS0B/wHfAU4BMgH/Ae8BUwE2Af8B+wHxAe8B/wH9AvkB/wHh
+        AWQBTQH/AfwBWAE5Af8B9QFVATcB/wHnAVABNAH/AdMBSgEvAf8BfgErASUB/AwAAz4BawEAAb8B7QH/
+        AQAByQHyAf8BAAHQAfYB/wEAAdQB+QH/AQAB1AH3Af8BhQHcAesB/wGBAdsB6gH/AQAB0AHzAf8BAAHW
+        AfoB/wEAAdIB+AH/AQABzQH0Af8BAAHDAe8B/wEGAYABnQH/DAABVAJRAasBKQE9AcMB/wEuAUMB1gH/
+        ATEBSAHkAf8BMgFKAewB/wEzAUsB7wH/ATMBTAHwAf8BMwFLAe4B/wExAUkB5gH/AS8BRgHdAf8BKwFA
+        AcwB/wEhASkBhAH/UAABtwE/ASgB/wHdAU0BMQH/AfIBVAE2Af8B/gFbAT0J/wHjAYkBdgH/AegBmwGN
+        Av8BXwFBAf8B+QFXATgB/wHnAVABNAH/Ac8BSAEuAf8DSAGGDAABDwGOAa4B/wE6AdYB9QH/AUAB3QH5
+        Af8BNgHgAfsB/wEbAc0B6Qn/ASkBygHjAf8BAAHZAfsB/wEAAdQB+QH/AQABzQH1Af8BAAHDAe8B/wMv
+        AUkIAAFQAk4BnwEoATwBvQH/AS0BQwHVAf8BMQFJAeYB/wGqAbMB6wH/AZwBpgHpAf8BNgFPAfoB/wE2
+        AU8B+wH/AVYBaAHgAf8B5QHoAfgB/wEyAUkB6AH/AS8BRgHdAf8BKgE/AcgB/wEgAScBgQH/SAABRwJG
+        AYEB0QFJAS8B/wHrAVEBNQH/Af4BWQE7Av8BZQFIAf8B7AGxAaUF/wHzAcwBxAH/AeEBbwFYAf8B/AFn
+        AUsC/wFfAUEB/wH1AVUBNwH/Ad0BTQExAf8BpAE4ASMB/wwAAT0CPAFoAUgB1gH1Af8BTwHeAfkB/wFV
+        AeQB+wH/AVwB6AH9Af8BcQHZAekB/wGBAd4B6wH/AQgB2wH7Af8BAAHYAfsB/wEAAdMB+AH/AQABygHz
+        Af8BBgGBAZ4B/wwAASEBKQGDAf8BKwE/AcoB/wEwAUcB4AH/AYgBlAHiCf8BnAGnAewB/wFXAWoB5An/
+        Ad4B4QH3Af8BMQFJAegB/wEtAUMB1QH/ASgBOwG7Af8DFgEfRAABgAEnASEB+wHaAUwBMQH/AfQBVAE2
+        Av8BYwFHAv8BcgFXAf8B7AFtAVQJ/wH4AXMBWAL/AXQBWQL/AWwBUQH/AfwBWAE5Af8B5gFQATMB/wHK
+        AUcBLQH/EAABLQGWAbAB/wFdAd4B+AH/AWQB5QH7Af8BawHpAf0J/wGBAegB+QH/AVUB5AH7Af8BAAHP
+        AfYB/wEAAcUB8AH/Ay4BRwwAASIBKwGJAf8BNQFKAdQB/wFDAVkB6QH/AU8BZAH1Af8B1wHbAfcR/wH3
+        AfgB/QH/ATMBTAHwAf8BMwFLAe4B/wEvAUUB3AH/ASkBPQHDAf8DFgEfRAABngE1ASIB/wHfAU4BMgH/
+        AfcBZAFIAv8BdgFdAf8B+AGAAWQB/wHsAXkBYgH/AfwB8wHxBf8B5gGLAXgC/wGBAWcC/wF6AWIB/wH+
+        AW8BVQH/AeoBUQE0Af8BzgFIAS4B/wMVAR0MAAM8AWYBbAHeAfcB/wFzAeUB+gH/AXoB6gH8Cf8BjwHq
+        AfkB/wGWAe0B/AH/AVoB3QH3Af8BBgGBAZ4B/xAAAS4BNgGPAf8BSQFbAdsB/wFSAWYB7QH/AVsBcAH4
+        Af8BYwF2AfwB/wHfAeIB+Qn/AfwB/QH+Af8BhQGUAfkB/wFwAYMB/AH/ATMBTAHwAf8BLwFGAd8B/wEq
+        AT4BxwH/AxYBH0QAAZcBMwEgAf8B3gFOATIB/wH4AYABZAL/AYUBbgH/Af4BjQF2Af8B9QHYAdIB/wHn
+        AZsBjQX/AfkB5wHkAv8BjgF3Av8BiQFyAf8B/gGBAWcB/wHtAXMBXAH/Ac0BSAEuAf8DDAEQEAABPQGa
+        AbEB/wGDAeYB+QH/AYoB6wH8Cf8BngHsAfkB/wGkAe4B+wH/AaoB7AH6Af8DLQFGEAABMwE6AZAB/wFT
+        AWUB3AH/AV0BcAHtAf8BZgF5AfgB/wGGAZMB6hH/AckBzwH0Af8BmQGmAfwB/wGgAasB9wH/AVUBaAHk
+        Af8BKgE+AcYB/wMWAR9EAAFhAUwBSQHVAdwBZQFOAf8B9QGNAXkC/wGTAYEC/wGbAYgB/wH+AZ4BigH/
+        Ae0BsQGmAf8B/AH2AfQB/wHvAbwBsgL/AZ0BigL/AZcBhAH/AfsBjwF6Af8B7AGKAXYB/wHEAUQBKwH/
+        FAADOwFlAZIB5gH5Af8BmQHsAfsJ/wGsAe4B+QH/AbIB7wH7Af8BQQGOAaIB/xQAATgBPgGPAf8BXQFt
+        AdoB/wFoAXkB6wH/AYkBlQHmCf8B+gH7Af4B/wHkAecB+gn/AdMB1wH1Af8BrAG1AfcB/wGxAbkB8QH/
+        AWABbgHPAf8DFgEfRAADHwEtAdQBaAFTAf8B8QGeAY4B/wH8AaIBkQL/AacBlwL/AasBmwL/Aa0BnQH/
+        Ae8BtgGrAf8B/gH9AfwB/wHxAaUBlwH/Af4BpAGTAf8B9gGfAY8B/wHpAZsBjAH/AXoBNQEkAfcYAAFN
+        AZ0BsgH/AacB7QH7Cf8BuQHvAfkB/wG+AfAB+wH/Ay0BRRQAAS8BMgF3Af8BaAF2AdYB/wFzAYMB5wH/
+        AXsBigHpAf8D/gH/AvsB/gH/AZUBogH5Af8BnQGpAf0B/wHpAesB+gX/AbYBvQHwAf8BtwG/AfUB/wG8
+        AcMB8AH/AcEBxgHqAf8DCQEMSAABgQEzAR8B+QHsAa4BogH/AfUBsQGkAf8B/AG0AaYC/wG2AakC/wG4
+        AasB/wH3Ad0B2QX/AfUB1QHPAf8B+QGyAaUB/wHwAbABowH/Ad4BmAGKAf8DEgEYGAADOwFkAbQB7QH6
+        Cf8BxQHwAfoB/wFGAY8BogH/GAADCAELAVYBXgGqAf8BgQGLAeEB/wGIAZYB7QH/AZABnAHtAf8BmQGk
+        AfQB/wGhAa0B+wH/AagBswH7Af8BrwG5AfoB/wG5AcAB8QH/AbwBwwH3Af8BwQHIAfMB/wHHAcwB7gH/
+        AVQCUQGrTwABAQG+AXYBaAH/AfABwQG3Af8B9gHCAbkB/wH6AcQBugH/AfwBxAG6Af8B+wHEAboB/wHy
+        AcYBvQH/AfYBwgG5Af8B8wHCAbgB/wHsAb4BtQH/AUoCSQGKIAABWgGfAbIB/wHGAfEB+wH/AcsB8gH8
+        Af8B0AHzAfwB/wMsAUQcAAMIAQsBZQFsAbAB/wGTAZ4B5gH/AZwBpwHuAf8BpQGvAfMB/wGsAbYB9gH/
+        AbMBvAH3Af8BugHCAfcB/wHAAccB9QH/AcYBzAHzAf8BywHQAfAB/wFUAlEBq1cAAQEBiQFBATwB+QHy
+        AdAByQH/AfQB0QHKAf8B9gHSAcoB/wH2AdIBygH/AfUB0QHKAf8B8wHQAcoB/wHUAZ4BkwH/AzsBYyQA
+        AzsBZAHRAfIB+wH/AdUB9AH8Af8BTAGQAaMB/yQAAwgBCwFzAXgBswH/AacBrwHnAf8BrwG3Ae0B/wG2
+        Ab4B8AH/Ab0BxAHyAf8BxAHKAfIB/wHKAc8B8QH/Ac8B0wHwAf8BVAJRAatgAAMfAS0BYQFMAUkB1QGp
+        AWoBXwH/AbQBegFvAf8BiQFGATIB+wFHAkYBgTAAAVUBTQFRAdwBTgGRAaQB/wMWAR4oAAMIAQsBRwFI
+        AYEB/wFqAWwBnwH/AW0BcAGiAf8BcQFzAaQB/wF0AXUBpAH/AXIBcwGgAf8BUAJOAZ//AFEAAUIBTQE+
+        BwABPgMAASgDAAFAAwABEAMAAQEBAAEBBQABgBcAA/8BAAH+AX8BwAEDAfgBHwIAAfABDwGAAQEB8AEP
+        AgAB4AEHAYABAAHgAQcCAAHAAQMBgAEBAcABAwIAAcABAQHAAQEBgAEBAgABgAEBAcABAwGAAwABgAEB
+        AeABAwGAAwABgAEAAeABBwGAAwABgAEAAfABBwGAAwABgAEBAfABDwGAAwABgAEBAfgBDwGAAwABwAEB
+        AfgBHwGAAQECAAHAAQMB/AEfAcABAwIAAeABBwH8AT8B4AEHAgAB+AEfAf4BPwHwAQ8CAAb/AgAL
 </value>
   </data>
-  <data name="listView1.TabIndex" type="System.Int32, mscorlib">
-    <value>1</value>
+  <data name="lstIssues.TabIndex" type="System.Int32, mscorlib">
+    <value>0</value>
   </data>
-  <data name=">>listView1.Name" xml:space="preserve">
-    <value>listView1</value>
+  <data name=">>lstIssues.Name" xml:space="preserve">
+    <value>lstIssues</value>
   </data>
-  <data name=">>listView1.Type" xml:space="preserve">
+  <data name=">>lstIssues.Type" xml:space="preserve">
     <value>System.Windows.Forms.ListView, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
-  <data name=">>listView1.Parent" xml:space="preserve">
+  <data name=">>lstIssues.Parent" xml:space="preserve">
     <value>$this</value>
   </data>
-  <data name=">>listView1.ZOrder" xml:space="preserve">
+  <data name=">>lstIssues.ZOrder" xml:space="preserve">
     <value>0</value>
   </data>
   <metadata name="saveFileDialog.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
@@ -353,6 +379,12 @@
   <data name=">>columnHeader2.Type" xml:space="preserve">
     <value>System.Windows.Forms.ColumnHeader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
+  <data name=">>columnHeader3.Name" xml:space="preserve">
+    <value>columnHeader3</value>
+  </data>
+  <data name=">>columnHeader3.Type" xml:space="preserve">
+    <value>System.Windows.Forms.ColumnHeader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </data>
   <data name=">>imageList1.Name" xml:space="preserve">
     <value>imageList1</value>
   </data>
@@ -365,12 +397,6 @@
   <data name=">>saveFileDialog.Type" xml:space="preserve">
     <value>System.Windows.Forms.SaveFileDialog, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
-  <data name=">>columnHeader3.Name" xml:space="preserve">
-    <value>columnHeader3</value>
-  </data>
-  <data name=">>columnHeader3.Type" xml:space="preserve">
-    <value>System.Windows.Forms.ColumnHeader, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
-  </data>
   <data name=">>$this.Name" xml:space="preserve">
     <value>ValidationResultsDialog</value>
   </data>
Modified: branches/maestro-4.0.x/Maestro.Editors/Common/ExpressionEditor.resx
--- branches/maestro-4.0.x/Maestro.Editors/Common/ExpressionEditor.resx	2012-10-31 12:21:00 UTC (rev 7175)
+++ branches/maestro-4.0.x/Maestro.Editors/Common/ExpressionEditor.resx	2012-10-31 12:37:34 UTC (rev 7176)
@@ -112,23 +112,23 @@
     <value>2.0</value>
   </resheader>
   </resheader>
   </resheader>
-  <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+  <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
   <data name="OKBtn.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
   </data>
-  <assembly alias="System.Drawing" name="System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
   <data name="OKBtn.Location" type="System.Drawing.Point, System.Drawing">
     <value>342, 6</value>
   </data>
   <data name="OKBtn.Size" type="System.Drawing.Size, System.Drawing">
     <value>75, 23</value>
   </data>
-  <assembly alias="mscorlib" name="mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
   <data name="OKBtn.TabIndex" type="System.Int32, mscorlib">
     <value>2</value>
   </data>
@@ -139,7 +139,7 @@
     <value>OKBtn</value>
   </data>
   <data name=">>OKBtn.Type" xml:space="preserve">
-    <value>System.Windows.Forms.Button, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name=">>OKBtn.Parent" xml:space="preserve">
@@ -166,7 +166,7 @@
     <value>CancelBtn</value>
   </data>
   <data name=">>CancelBtn.Type" xml:space="preserve">
   </data>
   <data name=">>CancelBtn.Parent" xml:space="preserve">
@@ -193,7 +193,7 @@
     <value>lblHint</value>
   </data>
   <data name=">>lblHint.Type" xml:space="preserve">
-    <value>System.Windows.Forms.Label, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.Label, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name=">>lblHint.Parent" xml:space="preserve">
@@ -217,7 +217,7 @@
   </data>
   <data name=">>panel1.Type" xml:space="preserve">
-    <value>System.Windows.Forms.Panel, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.Panel, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name=">>panel1.Parent" xml:space="preserve">
@@ -225,7 +225,7 @@
   <data name=">>panel1.ZOrder" xml:space="preserve">
     <value>2</value>
   </data>
-  <metadata name="toolStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+  <metadata name="toolStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
     <value>17, 17</value>
   </metadata>
   <data name="btnProperties.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
@@ -316,7 +316,7 @@
     <value>toolStrip1</value>
   </data>
   <data name=">>toolStrip1.Type" xml:space="preserve">
-    <value>System.Windows.Forms.ToolStrip, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.ToolStrip, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name=">>toolStrip1.Parent" xml:space="preserve">
@@ -346,7 +346,7 @@
     <value>ExpressionText</value>
   </data>
   <data name=">>ExpressionText.Type" xml:space="preserve">
-    <value>System.Windows.Forms.TextBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.TextBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name=">>ExpressionText.Parent" xml:space="preserve">
@@ -354,10 +354,10 @@
   <data name=">>ExpressionText.ZOrder" xml:space="preserve">
     <value>0</value>
   </data>
-  <metadata name="_autoCompleteTooltip.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+  <metadata name="_autoCompleteTooltip.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
     <value>116, 17</value>
   </metadata>
-  <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+  <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
     <value>True</value>
   </metadata>
   <data name="$this.ClientSize" type="System.Drawing.Size, System.Drawing">
@@ -376,72 +376,72 @@
     <value>btnProperties</value>
   </data>
   <data name=">>btnProperties.Type" xml:space="preserve">
-    <value>System.Windows.Forms.ToolStripDropDownButton, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.ToolStripDropDownButton, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name=">>btnFunctions.Name" xml:space="preserve">
     <value>btnFunctions</value>
   </data>
   <data name=">>btnFunctions.Type" xml:space="preserve">
   </data>
   <data name=">>btnFilter.Name" xml:space="preserve">
     <value>btnFilter</value>
   </data>
   <data name=">>btnFilter.Type" xml:space="preserve">
   </data>
   <data name=">>btnCondition.Name" xml:space="preserve">
     <value>btnCondition</value>
   </data>
   <data name=">>btnCondition.Type" xml:space="preserve">
-    <value>System.Windows.Forms.ToolStripMenuItem, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.ToolStripMenuItem, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name=">>btnSpatial.Name" xml:space="preserve">
     <value>btnSpatial</value>
   </data>
   <data name=">>btnSpatial.Type" xml:space="preserve">
   </data>
   <data name=">>btnDistance.Name" xml:space="preserve">
     <value>btnDistance</value>
   </data>
   <data name=">>btnDistance.Type" xml:space="preserve">
   </data>
   <data name=">>toolStripSeparator1.Name" xml:space="preserve">
     <value>toolStripSeparator1</value>
   </data>
   <data name=">>toolStripSeparator1.Type" xml:space="preserve">
-    <value>System.Windows.Forms.ToolStripSeparator, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.ToolStripSeparator, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name=">>ColumnValue.Name" xml:space="preserve">
     <value>ColumnValue</value>
   </data>
   <data name=">>ColumnValue.Type" xml:space="preserve">
-    <value>System.Windows.Forms.ToolStripComboBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.ToolStripComboBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name=">>LookupValues.Name" xml:space="preserve">
     <value>LookupValues</value>
   </data>
   <data name=">>LookupValues.Type" xml:space="preserve">
-    <value>System.Windows.Forms.ToolStripButton, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.ToolStripButton, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name=">>ColumnName.Name" xml:space="preserve">
     <value>ColumnName</value>
   </data>
   <data name=">>ColumnName.Type" xml:space="preserve">
   </data>
   <data name=">>_autoCompleteTooltip.Name" xml:space="preserve">
     <value>_autoCompleteTooltip</value>
   </data>
   <data name=">>_autoCompleteTooltip.Type" xml:space="preserve">
-    <value>System.Windows.Forms.ToolTip, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.ToolTip, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
     <value>ExpressionEditor</value>
   </data>
   <data name=">>$this.Type" xml:space="preserve">
-    <value>System.Windows.Forms.Form, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.Form, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
 </root>
Modified: branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/GenericCtrl.resx
--- branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/GenericCtrl.resx	2012-10-31 12:21:00 UTC (rev 7175)
+++ branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/GenericCtrl.resx	2012-10-31 12:37:34 UTC (rev 7176)
@@ -112,16 +112,16 @@
     <value>2.0</value>
   </resheader>
   </resheader>
   </resheader>
   <data name="lnkSetCredentials.AutoSize" type="System.Boolean, mscorlib">
     <value>True</value>
   </data>
   <data name="lnkSetCredentials.Location" type="System.Drawing.Point, System.Drawing">
     <value>137, 46</value>
   </data>
@@ -138,7 +138,7 @@
     <value>lnkSetCredentials</value>
   </data>
   <data name=">>lnkSetCredentials.Type" xml:space="preserve">
-    <value>System.Windows.Forms.LinkLabel, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.LinkLabel, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name=">>lnkSetCredentials.Parent" xml:space="preserve">
     <value>contentPanel</value>
@@ -146,7 +146,7 @@
   <data name=">>lnkSetCredentials.ZOrder" xml:space="preserve">
     <value>0</value>
   </data>
   <data name="txtTestResult.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
     <value>Bottom, Left, Right</value>
   </data>
@@ -169,7 +169,7 @@
     <value>txtTestResult</value>
   </data>
   <data name=">>txtTestResult.Type" xml:space="preserve">
   </data>
   <data name=">>txtTestResult.Parent" xml:space="preserve">
@@ -196,7 +196,7 @@
     <value>btnTest</value>
   </data>
   <data name=">>btnTest.Type" xml:space="preserve">
   </data>
   <data name=">>btnTest.Parent" xml:space="preserve">
@@ -220,7 +220,7 @@
     <value>cmbLongTransaction</value>
   </data>
   <data name=">>cmbLongTransaction.Type" xml:space="preserve">
-    <value>System.Windows.Forms.ComboBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.ComboBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name=">>cmbLongTransaction.Parent" xml:space="preserve">
@@ -250,7 +250,7 @@
     <value>label4</value>
   </data>
   <data name=">>label4.Type" xml:space="preserve">
   </data>
   <data name=">>label4.Parent" xml:space="preserve">
@@ -301,7 +301,7 @@
     <value>label3</value>
   </data>
   <data name=">>label3.Type" xml:space="preserve">
   </data>
   <data name=">>label3.Parent" xml:space="preserve">
@@ -328,7 +328,7 @@
     <value>label2</value>
   </data>
   <data name=">>label2.Type" xml:space="preserve">
   </data>
   <data name=">>label2.Parent" xml:space="preserve">
@@ -352,7 +352,7 @@
     <value>grdConnectionParameters</value>
   </data>
   <data name=">>grdConnectionParameters.Type" xml:space="preserve">
-    <value>System.Windows.Forms.DataGridView, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.DataGridView, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name=">>grdConnectionParameters.Parent" xml:space="preserve">
@@ -376,7 +376,7 @@
     <value>txtProvider</value>
   </data>
   <data name=">>txtProvider.Type" xml:space="preserve">
   </data>
   <data name=">>txtProvider.Parent" xml:space="preserve">
@@ -403,7 +403,7 @@
     <value>label1</value>
   </data>
   <data name=">>label1.Type" xml:space="preserve">
   </data>
   <data name=">>label1.Parent" xml:space="preserve">
@@ -418,7 +418,7 @@
   </data>
   <data name=">>contentPanel.Type" xml:space="preserve">
   </data>
   <data name=">>contentPanel.Parent" xml:space="preserve">
@@ -426,7 +426,7 @@
   <data name=">>contentPanel.ZOrder" xml:space="preserve">
     <value>0</value>
   </data>
-  <metadata name="ctxEnumerable.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+  <metadata name="ctxEnumerable.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
   </metadata>
   <data name="pickAValueToolStripMenuItem.Size" type="System.Drawing.Size, System.Drawing">
@@ -448,9 +448,9 @@
     <value>ctxEnumerable</value>
   </data>
   <data name=">>ctxEnumerable.Type" xml:space="preserve">
-    <value>System.Windows.Forms.ContextMenuStrip, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.ContextMenuStrip, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
-  <metadata name="ctxProperty.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+  <metadata name="ctxProperty.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
     <value>149, 17</value>
   </metadata>
   <data name="pickAnAliasedFileToolStripMenuItem.Size" type="System.Drawing.Size, System.Drawing">
@@ -478,9 +478,9 @@
     <value>ctxProperty</value>
   </data>
   <data name=">>ctxProperty.Type" xml:space="preserve">
   </data>
     <value>True</value>
   </metadata>
   <data name="$this.HeaderText" xml:space="preserve">
@@ -493,31 +493,31 @@
     <value>pickAValueToolStripMenuItem</value>
   </data>
   <data name=">>pickAValueToolStripMenuItem.Type" xml:space="preserve">
   </data>
   <data name=">>pickADataStoreFromListToolStripMenuItem.Name" xml:space="preserve">
     <value>pickADataStoreFromListToolStripMenuItem</value>
   </data>
   <data name=">>pickADataStoreFromListToolStripMenuItem.Type" xml:space="preserve">
   </data>
   <data name=">>pickAnAliasedFileToolStripMenuItem.Name" xml:space="preserve">
     <value>pickAnAliasedFileToolStripMenuItem</value>
   </data>
   <data name=">>pickAnAliasedFileToolStripMenuItem.Type" xml:space="preserve">
   </data>
   <data name=">>pickAnAliasedDirectoryToolStripMenuItem.Name" xml:space="preserve">
     <value>pickAnAliasedDirectoryToolStripMenuItem</value>
   </data>
   <data name=">>pickAnAliasedDirectoryToolStripMenuItem.Type" xml:space="preserve">
   </data>
   <data name=">>mGDATAFILEPATHToolStripMenuItem.Name" xml:space="preserve">
     <value>mGDATAFILEPATHToolStripMenuItem</value>
   </data>
   <data name=">>mGDATAFILEPATHToolStripMenuItem.Type" xml:space="preserve">
   </data>
     <value>GenericCtrl</value>
Modified: branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/Rdbms/RdbmsBaseCtrl.resx
--- branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/Rdbms/RdbmsBaseCtrl.resx	2012-10-31 12:21:00 UTC (rev 7175)
+++ branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/Rdbms/RdbmsBaseCtrl.resx	2012-10-31 12:37:34 UTC (rev 7176)
@@ -112,20 +112,20 @@
     <value>2.0</value>
   </resheader>
   </resheader>
   </resheader>
   <data name="txtStatus.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
     <value>Top, Left, Right</value>
   </data>
   <data name="txtStatus.Location" type="System.Drawing.Point, System.Drawing">
     <value>130, 178</value>
   </data>
   <data name="txtStatus.Multiline" type="System.Boolean, mscorlib">
     <value>True</value>
   </data>
@@ -142,7 +142,7 @@
     <value>txtStatus</value>
   </data>
   <data name=">>txtStatus.Type" xml:space="preserve">
   </data>
   <data name=">>txtStatus.Parent" xml:space="preserve">
@@ -169,7 +169,7 @@
   </data>
   </data>
@@ -199,7 +199,7 @@
     <value>btnBrowseDataStore</value>
   </data>
   <data name=">>btnBrowseDataStore.Type" xml:space="preserve">
   </data>
   <data name=">>btnBrowseDataStore.Parent" xml:space="preserve">
     <value>groupBox2</value>
@@ -223,7 +223,7 @@
     <value>txtDataStore</value>
   </data>
   <data name=">>txtDataStore.Type" xml:space="preserve">
   </data>
   <data name=">>txtDataStore.Parent" xml:space="preserve">
@@ -250,7 +250,7 @@
   </data>
   </data>
@@ -274,7 +274,7 @@
   </data>
   <data name=">>groupBox2.Type" xml:space="preserve">
-    <value>System.Windows.Forms.GroupBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.GroupBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name=">>groupBox2.Parent" xml:space="preserve">
@@ -301,7 +301,7 @@
     <value>txtService</value>
   </data>
   <data name=">>txtService.Type" xml:space="preserve">
   </data>
   <data name=">>txtService.Parent" xml:space="preserve">
     <value>groupBox1</value>
@@ -328,7 +328,7 @@
     <value>txtPassword</value>
   </data>
   <data name=">>txtPassword.Type" xml:space="preserve">
   </data>
   <data name=">>txtPassword.Parent" xml:space="preserve">
@@ -355,7 +355,7 @@
   </data>
   </data>
@@ -382,7 +382,7 @@
   </data>
   </data>
@@ -409,7 +409,7 @@
   </data>
   </data>
@@ -433,7 +433,7 @@
     <value>txtUsername</value>
   </data>
   <data name=">>txtUsername.Type" xml:space="preserve">
   </data>
   <data name=">>txtUsername.Parent" xml:space="preserve">
@@ -457,7 +457,7 @@
   </data>
   <data name=">>groupBox1.Type" xml:space="preserve">
   </data>
   <data name=">>groupBox1.Parent" xml:space="preserve">
@@ -472,7 +472,7 @@
   </data>
   </data>
@@ -480,7 +480,7 @@
     <value>0</value>
   </data>
     <value>True</value>
   </metadata>
   <data name="$this.Size" type="System.Drawing.Size, System.Drawing">
Modified: branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/SetCredentialsDialog.resx
--- branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/SetCredentialsDialog.resx	2012-10-31 12:21:00 UTC (rev 7175)
+++ branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/SetCredentialsDialog.resx	2012-10-31 12:37:34 UTC (rev 7176)
@@ -112,9 +112,9 @@
     <value>2.0</value>
   </resheader>
   </resheader>
   </resheader>
 </root>
Modified: branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/Wms/WmsAdvancedConfigurationDialog.resx
--- branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/Wms/WmsAdvancedConfigurationDialog.resx	2012-10-31 12:21:00 UTC (rev 7175)
+++ branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/Wms/WmsAdvancedConfigurationDialog.resx	2012-10-31 12:37:34 UTC (rev 7176)
@@ -252,7 +252,7 @@
   <data name=">>btnCancel.ZOrder" xml:space="preserve">
     <value>5</value>
   </data>
   </metadata>
   <data name="groupBox2.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
@@ -262,7 +262,7 @@
     <value>lstFeatureClasses</value>
   </data>
   <data name=">>lstFeatureClasses.Type" xml:space="preserve">
-    <value>System.Windows.Forms.ListBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.ListBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name=">>lstFeatureClasses.Parent" xml:space="preserve">
@@ -274,7 +274,7 @@
   </data>
   </data>
@@ -298,7 +298,7 @@
   </data>
   </data>
@@ -415,7 +415,7 @@
     <value>grdSpatialContexts</value>
   </data>
   <data name=">>grdSpatialContexts.Type" xml:space="preserve">
   </data>
   <data name=">>grdSpatialContexts.Parent" xml:space="preserve">
@@ -439,7 +439,7 @@
   </data>
   </data>
@@ -447,7 +447,7 @@
   <data name=">>groupBox1.ZOrder" xml:space="preserve">
     <value>2</value>
   </data>
-  <metadata name="COL_NAME.UserAddedColumn" type="System.Boolean, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+  <metadata name="COL_NAME.UserAddedColumn" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
     <value>True</value>
   </metadata>
   <metadata name="COL_CS.UserAddedColumn" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
@@ -477,13 +477,13 @@
   <data name=">>grdSpatialContexts.ZOrder" xml:space="preserve">
     <value>0</value>
   </data>
     <value>True</value>
   </metadata>
   <data name="COL_NAME.HeaderText" xml:space="preserve">
     <value>Name</value>
   </data>
-  <metadata name="COL_CS.UserAddedColumn" type="System.Boolean, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+  <metadata name="COL_CS.UserAddedColumn" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
     <value>True</value>
   </metadata>
   <data name="COL_CS.HeaderText" xml:space="preserve">
@@ -496,7 +496,7 @@
     <value>lnkSwap</value>
   </data>
   <data name=">>lnkSwap.Type" xml:space="preserve">
   </data>
   <data name=">>lnkSwap.Parent" xml:space="preserve">
     <value>grpLogicalClass</value>
@@ -508,7 +508,7 @@
     <value>txtClassDescription</value>
   </data>
   <data name=">>txtClassDescription.Type" xml:space="preserve">
   </data>
   <data name=">>txtClassDescription.Parent" xml:space="preserve">
@@ -520,7 +520,7 @@
   </data>
   </data>
@@ -532,7 +532,7 @@
     <value>txtClassName</value>
   </data>
   <data name=">>txtClassName.Type" xml:space="preserve">
   </data>
   <data name=">>txtClassName.Parent" xml:space="preserve">
@@ -544,7 +544,7 @@
   </data>
   </data>
@@ -598,7 +598,7 @@
   </data>
   </data>
@@ -622,7 +622,7 @@
   </data>
   </data>
@@ -652,7 +652,7 @@
   </data>
   </data>
@@ -676,7 +676,7 @@
   </data>
   </data>
@@ -703,7 +703,7 @@
   </data>
   </data>
@@ -730,7 +730,7 @@
     <value>btnSwapAll</value>
   </data>
   <data name=">>btnSwapAll.Type" xml:space="preserve">
   </data>
   <data name=">>btnSwapAll.Parent" xml:space="preserve">
@@ -738,7 +738,7 @@
   <data name=">>btnSwapAll.ZOrder" xml:space="preserve">
     <value>0</value>
   </data>
     <value>True</value>
   </metadata>
Modified: branches/maestro-4.0.x/Maestro.Editors/Fusion/MapCtrl.resx
--- branches/maestro-4.0.x/Maestro.Editors/Fusion/MapCtrl.resx	2012-10-31 12:21:00 UTC (rev 7175)
+++ branches/maestro-4.0.x/Maestro.Editors/Fusion/MapCtrl.resx	2012-10-31 12:37:34 UTC (rev 7176)
     <value>2.0</value>
   </resheader>
   </resheader>
   </resheader>
   <data name="label1.AutoSize" type="System.Boolean, mscorlib">
     <value>True</value>
   </data>
   <data name="label1.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
     <value>NoControl</value>
   </data>
   <data name="label1.Location" type="System.Drawing.Point, System.Drawing">
     <value>14, 22</value>
   </data>
@@ -142,7 +142,7 @@
   </data>
   </data>
@@ -166,7 +166,7 @@
     <value>txtMapId</value>
   </data>
   <data name=">>txtMapId.Type" xml:space="preserve">
   </data>
   <data name=">>txtMapId.Parent" xml:space="preserve">
@@ -199,7 +199,7 @@
     <value>chkOverride</value>
   </data>
   <data name=">>chkOverride.Type" xml:space="preserve">
-    <value>System.Windows.Forms.CheckBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.CheckBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name=">>chkOverride.Parent" xml:space="preserve">
@@ -220,7 +220,7 @@
     <value>txtViewScale</value>
   </data>
   <data name=">>txtViewScale.Type" xml:space="preserve">
   </data>
   <data name=">>txtViewScale.Parent" xml:space="preserve">
@@ -241,7 +241,7 @@
     <value>txtViewY</value>
   </data>
   <data name=">>txtViewY.Type" xml:space="preserve">
   </data>
   <data name=">>txtViewY.Parent" xml:space="preserve">
@@ -262,7 +262,7 @@
     <value>txtViewX</value>
   </data>
   <data name=">>txtViewX.Type" xml:space="preserve">
   </data>
   <data name=">>txtViewX.Parent" xml:space="preserve">
@@ -292,7 +292,7 @@
   </data>
   </data>
@@ -322,7 +322,7 @@
   </data>
   </data>
@@ -352,7 +352,7 @@
   </data>
   </data>
@@ -373,7 +373,7 @@
   </data>
   </data>
@@ -403,7 +403,7 @@
     <value>label5</value>
   </data>
   <data name=">>label5.Type" xml:space="preserve">
   </data>
   <data name=">>label5.Parent" xml:space="preserve">
@@ -427,7 +427,7 @@
     <value>txtMapDefinition</value>
   </data>
   <data name=">>txtMapDefinition.Type" xml:space="preserve">
   </data>
   <data name=">>txtMapDefinition.Parent" xml:space="preserve">
@@ -457,7 +457,7 @@
     <value>btnBrowseMdf</value>
   </data>
   <data name=">>btnBrowseMdf.Type" xml:space="preserve">
   </data>
   <data name=">>btnBrowseMdf.Parent" xml:space="preserve">
@@ -487,7 +487,7 @@
     <value>chkSingleTiled</value>
   </data>
   <data name=">>chkSingleTiled.Type" xml:space="preserve">
   </data>
   <data name=">>chkSingleTiled.Parent" xml:space="preserve">
@@ -517,7 +517,7 @@
     <value>lblSelColor</value>
   </data>
   <data name=">>lblSelColor.Type" xml:space="preserve">
   </data>
   <data name=">>lblSelColor.Parent" xml:space="preserve">
@@ -547,7 +547,7 @@
     <value>chkSelectionAsOverlay</value>
   </data>
   <data name=">>chkSelectionAsOverlay.Type" xml:space="preserve">
   </data>
   <data name=">>chkSelectionAsOverlay.Parent" xml:space="preserve">
@@ -592,7 +592,7 @@
   </data>
   </data>
@@ -625,7 +625,7 @@
     <value>chkOsmMapnik</value>
   </data>
   <data name=">>chkOsmMapnik.Type" xml:space="preserve">
   </data>
   <data name=">>chkOsmMapnik.Parent" xml:space="preserve">
     <value>groupBox6</value>
@@ -655,7 +655,7 @@
     <value>chkOsmTransportMap</value>
   </data>
   <data name=">>chkOsmTransportMap.Type" xml:space="preserve">
   </data>
   <data name=">>chkOsmTransportMap.Parent" xml:space="preserve">
@@ -685,7 +685,7 @@
     <value>chkOsmCycleMap</value>
   </data>
   <data name=">>chkOsmCycleMap.Type" xml:space="preserve">
   </data>
   <data name=">>chkOsmCycleMap.Parent" xml:space="preserve">
@@ -709,7 +709,7 @@
   </data>
   <data name=">>groupBox6.Type" xml:space="preserve">
   </data>
   <data name=">>groupBox6.Parent" xml:space="preserve">
     <value>grpCms</value>
@@ -739,7 +739,7 @@
     <value>chkGoogTerrain</value>
   </data>
   <data name=">>chkGoogTerrain.Type" xml:space="preserve">
   </data>
   <data name=">>chkGoogTerrain.Parent" xml:space="preserve">
     <value>groupBox5</value>
@@ -769,7 +769,7 @@
     <value>chkGoogStreets</value>
   </data>
   <data name=">>chkGoogStreets.Type" xml:space="preserve">
   </data>
   <data name=">>chkGoogStreets.Parent" xml:space="preserve">
@@ -799,7 +799,7 @@
     <value>chkGoogSatellite</value>
   </data>
   <data name=">>chkGoogSatellite.Type" xml:space="preserve">
   </data>
   <data name=">>chkGoogSatellite.Parent" xml:space="preserve">
@@ -829,7 +829,7 @@
     <value>chkGoogHybrid</value>
   </data>
   <data name=">>chkGoogHybrid.Type" xml:space="preserve">
   </data>
   <data name=">>chkGoogHybrid.Parent" xml:space="preserve">
@@ -853,7 +853,7 @@
   </data>
   <data name=">>groupBox5.Type" xml:space="preserve">
   </data>
   <data name=">>groupBox5.Parent" xml:space="preserve">
@@ -883,7 +883,7 @@
     <value>chkBingStreets</value>
   </data>
   <data name=">>chkBingStreets.Type" xml:space="preserve">
   </data>
   <data name=">>chkBingStreets.Parent" xml:space="preserve">
     <value>groupBox4</value>
@@ -913,7 +913,7 @@
     <value>chkBingSatellite</value>
   </data>
   <data name=">>chkBingSatellite.Type" xml:space="preserve">
   </data>
   <data name=">>chkBingSatellite.Parent" xml:space="preserve">
@@ -943,7 +943,7 @@
     <value>chkBingHybrid</value>
   </data>
   <data name=">>chkBingHybrid.Type" xml:space="preserve">
   </data>
   <data name=">>chkBingHybrid.Parent" xml:space="preserve">
@@ -967,7 +967,7 @@
   </data>
   <data name=">>groupBox4.Type" xml:space="preserve">
   </data>
   <data name=">>groupBox4.Parent" xml:space="preserve">
@@ -997,7 +997,7 @@
     <value>chkYahooStreets</value>
   </data>
   <data name=">>chkYahooStreets.Type" xml:space="preserve">
   </data>
   <data name=">>chkYahooStreets.Parent" xml:space="preserve">
     <value>groupBox3</value>
@@ -1027,7 +1027,7 @@
     <value>chkYahooSatellite</value>
   </data>
   <data name=">>chkYahooSatellite.Type" xml:space="preserve">
   </data>
   <data name=">>chkYahooSatellite.Parent" xml:space="preserve">
@@ -1057,7 +1057,7 @@
     <value>chkYahooHybrid</value>
   </data>
   <data name=">>chkYahooHybrid.Type" xml:space="preserve">
   </data>
   <data name=">>chkYahooHybrid.Parent" xml:space="preserve">
@@ -1081,7 +1081,7 @@
   </data>
   <data name=">>groupBox3.Type" xml:space="preserve">
   </data>
   <data name=">>groupBox3.Parent" xml:space="preserve">
@@ -1111,7 +1111,7 @@
     <value>txtYahooApiKey</value>
   </data>
   <data name=">>txtYahooApiKey.Type" xml:space="preserve">
   </data>
   <data name=">>txtYahooApiKey.Parent" xml:space="preserve">
@@ -1141,7 +1141,7 @@
     <value>label7</value>
   </data>
   <data name=">>label7.Type" xml:space="preserve">
   </data>
   <data name=">>label7.Parent" xml:space="preserve">
@@ -1165,7 +1165,7 @@
   </data>
   <data name=">>grpCms.Type" xml:space="preserve">
   </data>
   <data name=">>grpCms.Parent" xml:space="preserve">
@@ -1173,7 +1173,7 @@
   <data name=">>grpCms.ZOrder" xml:space="preserve">
     <value>0</value>
   </data>
     <value>True</value>
   </metadata>
@@ -1183,6 +1183,6 @@
     <value>MapCtrl</value>
   </data>
-    <value>System.Windows.Forms.UserControl, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.UserControl, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
 </root>
Modified: branches/maestro-4.0.x/Maestro.Editors/LayerDefinition/Drawing/DrawingLayerSettingsCtrl.resx
--- branches/maestro-4.0.x/Maestro.Editors/LayerDefinition/Drawing/DrawingLayerSettingsCtrl.resx	2012-10-31 12:21:00 UTC (rev 7175)
+++ branches/maestro-4.0.x/Maestro.Editors/LayerDefinition/Drawing/DrawingLayerSettingsCtrl.resx	2012-10-31 12:37:34 UTC (rev 7176)
@@ -112,26 +112,26 @@
     <value>2.0</value>
   </resheader>
   </resheader>
   </resheader>
   <data name="btnGoToDrawingSource.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
     <value>Top, Right</value>
   </data>
   <data name="btnGoToDrawingSource.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
   </data>
   <data name="btnGoToDrawingSource.Location" type="System.Drawing.Point, System.Drawing">
     <value>408, 17</value>
   </data>
   <data name="btnGoToDrawingSource.Size" type="System.Drawing.Size, System.Drawing">
     <value>28, 23</value>
   </data>
   <data name="btnGoToDrawingSource.TabIndex" type="System.Int32, mscorlib">
     <value>4</value>
   </data>
@@ -139,7 +139,7 @@
     <value>btnGoToDrawingSource</value>
   </data>
   <data name=">>btnGoToDrawingSource.Type" xml:space="preserve">
   </data>
   <data name=">>btnGoToDrawingSource.Parent" xml:space="preserve">
@@ -169,7 +169,7 @@
     <value>lnkCheckAll</value>
   </data>
   <data name=">>lnkCheckAll.Type" xml:space="preserve">
   </data>
   <data name=">>lnkCheckAll.Parent" xml:space="preserve">
@@ -193,7 +193,7 @@
     <value>chkListDwfLayers</value>
   </data>
   <data name=">>chkListDwfLayers.Type" xml:space="preserve">
-    <value>System.Windows.Forms.CheckedListBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.CheckedListBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name=">>chkListDwfLayers.Parent" xml:space="preserve">
@@ -220,7 +220,7 @@
   </data>
   </data>
@@ -244,7 +244,7 @@
     <value>txtMaxScale</value>
   </data>
   <data name=">>txtMaxScale.Type" xml:space="preserve">
   </data>
   <data name=">>txtMaxScale.Parent" xml:space="preserve">
@@ -265,7 +265,7 @@
     <value>txtMinScale</value>
   </data>
   <data name=">>txtMinScale.Type" xml:space="preserve">
   </data>
   <data name=">>txtMinScale.Parent" xml:space="preserve">
@@ -292,7 +292,7 @@
   </data>
   </data>
@@ -319,7 +319,7 @@
   </data>
   </data>
@@ -343,7 +343,7 @@
     <value>cmbSheet</value>
   </data>
   <data name=">>cmbSheet.Type" xml:space="preserve">
   </data>
   <data name=">>cmbSheet.Parent" xml:space="preserve">
@@ -370,7 +370,7 @@
   </data>
   </data>
@@ -394,7 +394,7 @@
   </data>
   </data>
@@ -421,7 +421,7 @@
     <value>btnBrowse</value>
   </data>
   <data name=">>btnBrowse.Type" xml:space="preserve">
   </data>
   <data name=">>btnBrowse.Parent" xml:space="preserve">
@@ -445,7 +445,7 @@
     <value>txtDrawingSource</value>
   </data>
   <data name=">>txtDrawingSource.Type" xml:space="preserve">
   </data>
   <data name=">>txtDrawingSource.Parent" xml:space="preserve">
@@ -472,7 +472,7 @@
   </data>
   </data>
@@ -484,7 +484,7 @@
   </data>
   </data>
@@ -492,7 +492,7 @@
     <value>0</value>
   </data>
     <value>True</value>
   </metadata>
Modified: branches/maestro-4.0.x/Maestro.Editors/LayerDefinition/Raster/RasterLayerSettingsSectionCtrl.resx
--- branches/maestro-4.0.x/Maestro.Editors/LayerDefinition/Raster/RasterLayerSettingsSectionCtrl.resx	2012-10-31 12:21:00 UTC (rev 7175)
+++ branches/maestro-4.0.x/Maestro.Editors/LayerDefinition/Raster/RasterLayerSettingsSectionCtrl.resx	2012-10-31 12:37:34 UTC (rev 7176)
     <value>2.0</value>
   </resheader>
   </resheader>
   </resheader>
   <data name="btnGoToFeatureSource.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
   </data>
   <data name="btnGoToFeatureSource.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
   </data>
   <data name="btnGoToFeatureSource.Location" type="System.Drawing.Point, System.Drawing">
     <value>414, 4</value>
   </data>
   <data name="btnGoToFeatureSource.Size" type="System.Drawing.Size, System.Drawing">
     <value>24, 23</value>
   </data>
   <data name="btnGoToFeatureSource.TabIndex" type="System.Int32, mscorlib">
     <value>8</value>
   </data>
@@ -139,7 +139,7 @@
     <value>btnGoToFeatureSource</value>
   </data>
   <data name=">>btnGoToFeatureSource.Type" xml:space="preserve">
   </data>
   <data name=">>btnGoToFeatureSource.Parent" xml:space="preserve">
@@ -172,7 +172,7 @@
     <value>btnBrowseGeometry</value>
   </data>
   <data name=">>btnBrowseGeometry.Type" xml:space="preserve">
   </data>
   <data name=">>btnBrowseGeometry.Parent" xml:space="preserve">
     <value>grpFeatureClass</value>
@@ -202,7 +202,7 @@
   </data>
   </data>
@@ -232,7 +232,7 @@
     <value>btnBrowseSchema</value>
   </data>
   <data name=">>btnBrowseSchema.Type" xml:space="preserve">
   </data>
   <data name=">>btnBrowseSchema.Parent" xml:space="preserve">
@@ -262,7 +262,7 @@
   </data>
   </data>
@@ -286,7 +286,7 @@
     <value>txtGeometry</value>
   </data>
   <data name=">>txtGeometry.Type" xml:space="preserve">
   </data>
   <data name=">>txtGeometry.Parent" xml:space="preserve">
@@ -310,7 +310,7 @@
     <value>txtFeatureClass</value>
   </data>
   <data name=">>txtFeatureClass.Type" xml:space="preserve">
   </data>
   <data name=">>txtFeatureClass.Parent" xml:space="preserve">
@@ -334,7 +334,7 @@
   </data>
   <data name=">>grpFeatureClass.Type" xml:space="preserve">
   </data>
   <data name=">>grpFeatureClass.Parent" xml:space="preserve">
@@ -358,7 +358,7 @@
     <value>txtFeatureSource</value>
   </data>
   <data name=">>txtFeatureSource.Type" xml:space="preserve">
   </data>
   <data name=">>txtFeatureSource.Parent" xml:space="preserve">
@@ -388,7 +388,7 @@
     <value>btnBrowseFeatureSource</value>
   </data>
   <data name=">>btnBrowseFeatureSource.Type" xml:space="preserve">
   </data>
   <data name=">>btnBrowseFeatureSource.Parent" xml:space="preserve">
@@ -418,7 +418,7 @@
   </data>
   </data>
@@ -433,7 +433,7 @@
   </data>
   </data>
@@ -441,7 +441,7 @@
     <value>0</value>
   </data>
     <value>True</value>
   </metadata>
Modified: branches/maestro-4.0.x/Maestro.Editors/LayerDefinition/Vector/Scales/PointStylePanel.resx
--- branches/maestro-4.0.x/Maestro.Editors/LayerDefinition/Vector/Scales/PointStylePanel.resx	2012-10-31 12:21:00 UTC (rev 7175)
+++ branches/maestro-4.0.x/Maestro.Editors/LayerDefinition/Vector/Scales/PointStylePanel.resx	2012-10-31 12:37:34 UTC (rev 7176)
@@ -112,9 +112,9 @@
     <value>2.0</value>
   </resheader>
   </resheader>
   </resheader>
 </root>
Modified: branches/maestro-4.0.x/Maestro.Editors/LayerDefinition/Vector/Scales/VectorScaleRangeCtrl.resx
--- branches/maestro-4.0.x/Maestro.Editors/LayerDefinition/Vector/Scales/VectorScaleRangeCtrl.resx	2012-10-31 12:21:00 UTC (rev 7175)
+++ branches/maestro-4.0.x/Maestro.Editors/LayerDefinition/Vector/Scales/VectorScaleRangeCtrl.resx	2012-10-31 12:37:34 UTC (rev 7176)
     <value>2.0</value>
   </resheader>
   </resheader>
   </resheader>
   <data name="chkLine.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
     <value>Top</value>
   </data>
   <data name="chkLine.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
   </data>
   <data name="chkLine.Location" type="System.Drawing.Point, System.Drawing">
     <value>0, 120</value>
   </data>
   <data name="chkLine.Size" type="System.Drawing.Size, System.Drawing">
     <value>598, 24</value>
   </data>
   <data name="chkLine.TabIndex" type="System.Int32, mscorlib">
     <value>2</value>
   </data>
@@ -142,7 +142,7 @@
     <value>chkLine</value>
   </data>
   <data name=">>chkLine.Type" xml:space="preserve">
   </data>
   <data name=">>chkLine.Parent" xml:space="preserve">
@@ -172,7 +172,7 @@
     <value>chkArea</value>
   </data>
   <data name=">>chkArea.Type" xml:space="preserve">
   </data>
   <data name=">>chkArea.Parent" xml:space="preserve">
@@ -202,7 +202,7 @@
     <value>chkComposite</value>
   </data>
   <data name=">>chkComposite.Type" xml:space="preserve">
   </data>
   <data name=">>chkComposite.Parent" xml:space="preserve">
@@ -330,7 +330,7 @@
   <data name=">>pointStylePanel.ZOrder" xml:space="preserve">
     <value>7</value>
   </data>
     <value>True</value>
   </metadata>
@@ -340,6 +340,6 @@
     <value>VectorScaleRangeCtrl</value>
   </data>
   </data>
 </root>
Modified: branches/maestro-4.0.x/Maestro.Editors/LayerDefinition/Vector/StyleEditors/AreaFeatureStyleEditor.resx
--- branches/maestro-4.0.x/Maestro.Editors/LayerDefinition/Vector/StyleEditors/AreaFeatureStyleEditor.resx	2012-10-31 12:21:00 UTC (rev 7175)
+++ branches/maestro-4.0.x/Maestro.Editors/LayerDefinition/Vector/StyleEditors/AreaFeatureStyleEditor.resx	2012-10-31 12:37:34 UTC (rev 7176)
     <value>2.0</value>
   </resheader>
   <resheader name="reader">
-    <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </resheader>
   <resheader name="writer">
-    <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </resheader>
   <data name="fillStyleEditor.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
   </data>
   <data name="fillStyleEditor.Location" type="System.Drawing.Point, System.Drawing">
     <value>16, 16</value>
   </data>
   <data name="fillStyleEditor.Size" type="System.Drawing.Size, System.Drawing">
     <value>274, 144</value>
   </data>
   <data name="fillStyleEditor.TabIndex" type="System.Int32, mscorlib">
     <value>0</value>
   </data>
@@ -184,7 +184,7 @@
     <value>sizeUnitsCombo</value>
   </data>
   <data name=">>sizeUnitsCombo.Type" xml:space="preserve">
   </data>
   <data name=">>sizeUnitsCombo.Parent" xml:space="preserve">
@@ -208,7 +208,7 @@
     <value>sizeContextCombo</value>
   </data>
   <data name=">>sizeContextCombo.Type" xml:space="preserve">
   </data>
   <data name=">>sizeContextCombo.Parent" xml:space="preserve">
@@ -232,7 +232,7 @@
   </data>
   </data>
@@ -256,7 +256,7 @@
   </data>
   </data>
@@ -283,7 +283,7 @@
   </data>
   </data>
@@ -310,7 +310,7 @@
   </data>
   </data>
@@ -337,7 +337,7 @@
     <value>previewPicture</value>
   </data>
   <data name=">>previewPicture.Type" xml:space="preserve">
-    <value>System.Windows.Forms.PictureBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.PictureBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name=">>previewPicture.Parent" xml:space="preserve">
     <value>previewGroup</value>
@@ -361,7 +361,7 @@
   </data>
   <data name=">>previewGroup.Type" xml:space="preserve">
   </data>
   <data name=">>previewGroup.Parent" xml:space="preserve">
@@ -369,10 +369,10 @@
   <data name=">>previewGroup.ZOrder" xml:space="preserve">
     <value>0</value>
   </data>
-  <metadata name="ComboBoxDataSet.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+  <metadata name="ComboBoxDataSet.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
   </metadata>
     <value>True</value>
   </metadata>
   <data name="$this.AutoScroll" type="System.Boolean, mscorlib">
@@ -388,48 +388,48 @@
     <value>UnitsTable</value>
   </data>
   <data name=">>UnitsTable.Type" xml:space="preserve">
-    <value>System.Data.DataTable, System.Data, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Data.DataTable, System.Data, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name=">>dataColumn5.Name" xml:space="preserve">
     <value>dataColumn5</value>
   </data>
   <data name=">>dataColumn5.Type" xml:space="preserve">
-    <value>System.Data.DataColumn, System.Data, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Data.DataColumn, System.Data, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name=">>dataColumn6.Name" xml:space="preserve">
     <value>dataColumn6</value>
   </data>
   <data name=">>dataColumn6.Type" xml:space="preserve">
   </data>
   <data name=">>SizeContextTable.Name" xml:space="preserve">
     <value>SizeContextTable</value>
   </data>
   <data name=">>SizeContextTable.Type" xml:space="preserve">
   </data>
   <data name=">>dataColumn3.Name" xml:space="preserve">
     <value>dataColumn3</value>
   </data>
   <data name=">>dataColumn3.Type" xml:space="preserve">
   </data>
   <data name=">>dataColumn4.Name" xml:space="preserve">
     <value>dataColumn4</value>
   </data>
   <data name=">>dataColumn4.Type" xml:space="preserve">
   </data>
   <data name=">>ComboBoxDataSet.Name" xml:space="preserve">
     <value>ComboBoxDataSet</value>
   </data>
   <data name=">>ComboBoxDataSet.Type" xml:space="preserve">
-    <value>System.Data.DataSet, System.Data, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Data.DataSet, System.Data, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
     <value>AreaFeatureStyleEditor</value>
   </data>
   </data>
 </root>
\ No newline at end of file
Modified: branches/maestro-4.0.x/Maestro.Editors/LayerDefinition/Vector/StyleEditors/FontStyleEditor.resx
--- branches/maestro-4.0.x/Maestro.Editors/LayerDefinition/Vector/StyleEditors/FontStyleEditor.resx	2012-10-31 12:21:00 UTC (rev 7175)
+++ branches/maestro-4.0.x/Maestro.Editors/LayerDefinition/Vector/StyleEditors/FontStyleEditor.resx	2012-10-31 12:37:34 UTC (rev 7176)
@@ -112,12 +112,12 @@
     <value>2.0</value>
   </resheader>
   </resheader>
   </resheader>
   <data name="fontGroup.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
   </data>
@@ -127,14 +127,14 @@
   <data name="sizeCombo.Items" xml:space="preserve">
     <value>Expression...</value>
   </data>
   <data name="sizeCombo.Location" type="System.Drawing.Point, System.Drawing">
     <value>112, 144</value>
   </data>
   <data name="sizeCombo.Size" type="System.Drawing.Size, System.Drawing">
     <value>176, 21</value>
   </data>
   <data name="sizeCombo.TabIndex" type="System.Int32, mscorlib">
     <value>10</value>
   </data>
@@ -142,7 +142,7 @@
     <value>sizeCombo</value>
   </data>
   <data name=">>sizeCombo.Type" xml:space="preserve">
   </data>
   <data name=">>sizeCombo.Parent" xml:space="preserve">
     <value>fontGroup</value>
@@ -166,7 +166,7 @@
     <value>unitsCombo</value>
   </data>
   <data name=">>unitsCombo.Type" xml:space="preserve">
   </data>
   <data name=">>unitsCombo.Parent" xml:space="preserve">
@@ -190,7 +190,7 @@
   </data>
   </data>
@@ -214,7 +214,7 @@
     <value>fontCombo</value>
   </data>
   <data name=">>fontCombo.Type" xml:space="preserve">
   </data>
   <data name=">>fontCombo.Parent" xml:space="preserve">
@@ -238,7 +238,7 @@
     <value>propertyCombo</value>
   </data>
   <data name=">>propertyCombo.Type" xml:space="preserve">
   </data>
   <data name=">>propertyCombo.Parent" xml:space="preserve">
@@ -265,7 +265,7 @@
     <value>label6</value>
   </data>
   <data name=">>label6.Type" xml:space="preserve">
   </data>
   <data name=">>label6.Parent" xml:space="preserve">
@@ -292,7 +292,7 @@
   </data>
   </data>
@@ -319,7 +319,7 @@
   </data>
   </data>
@@ -346,7 +346,7 @@
   </data>
   </data>
@@ -373,7 +373,7 @@
   </data>
   </data>
@@ -400,7 +400,7 @@
   </data>
   </data>
@@ -439,7 +439,7 @@
     <value>underlineCheck</value>
   </data>
   <data name=">>underlineCheck.Type" xml:space="preserve">
   </data>
   <data name=">>underlineCheck.Parent" xml:space="preserve">
@@ -475,7 +475,7 @@
     <value>italicCheck</value>
   </data>
   <data name=">>italicCheck.Type" xml:space="preserve">
   </data>
   <data name=">>italicCheck.Parent" xml:space="preserve">
@@ -511,7 +511,7 @@
     <value>boldCheck</value>
   </data>
   <data name=">>boldCheck.Type" xml:space="preserve">
   </data>
   <data name=">>boldCheck.Parent" xml:space="preserve">
@@ -532,7 +532,7 @@
   </data>
   </data>
@@ -556,7 +556,7 @@
   </data>
   <data name=">>fontGroup.Type" xml:space="preserve">
   </data>
   <data name=">>fontGroup.Parent" xml:space="preserve">
@@ -631,7 +631,7 @@
     <value>backgroundTypeCombo</value>
   </data>
   <data name=">>backgroundTypeCombo.Type" xml:space="preserve">
   </data>
   <data name=">>backgroundTypeCombo.Parent" xml:space="preserve">
     <value>colorGroup</value>
@@ -658,7 +658,7 @@
   </data>
   </data>
@@ -685,7 +685,7 @@
     <value>label8</value>
   </data>
   <data name=">>label8.Type" xml:space="preserve">
   </data>
   <data name=">>label8.Parent" xml:space="preserve">
@@ -712,7 +712,7 @@
     <value>label9</value>
   </data>
   <data name=">>label9.Type" xml:space="preserve">
   </data>
   <data name=">>label9.Parent" xml:space="preserve">
@@ -736,7 +736,7 @@
   </data>
   <data name=">>colorGroup.Type" xml:space="preserve">
   </data>
   <data name=">>colorGroup.Parent" xml:space="preserve">
@@ -763,7 +763,7 @@
     <value>rotationCombo</value>
   </data>
   <data name=">>rotationCombo.Type" xml:space="preserve">
   </data>
   <data name=">>rotationCombo.Parent" xml:space="preserve">
     <value>alignmentGroup</value>
@@ -787,7 +787,7 @@
     <value>verticalCombo</value>
   </data>
   <data name=">>verticalCombo.Type" xml:space="preserve">
   </data>
   <data name=">>verticalCombo.Parent" xml:space="preserve">
@@ -811,7 +811,7 @@
     <value>horizontalCombo</value>
   </data>
   <data name=">>horizontalCombo.Type" xml:space="preserve">
   </data>
   <data name=">>horizontalCombo.Parent" xml:space="preserve">
@@ -838,7 +838,7 @@
     <value>label10</value>
   </data>
   <data name=">>label10.Type" xml:space="preserve">
   </data>
   <data name=">>label10.Parent" xml:space="preserve">
@@ -865,7 +865,7 @@
     <value>verticalLabel</value>
   </data>
   <data name=">>verticalLabel.Type" xml:space="preserve">
   </data>
   <data name=">>verticalLabel.Parent" xml:space="preserve">
@@ -892,7 +892,7 @@
     <value>horizontalLabel</value>
   </data>
   <data name=">>horizontalLabel.Type" xml:space="preserve">
   </data>
   <data name=">>horizontalLabel.Parent" xml:space="preserve">
@@ -916,7 +916,7 @@
   </data>
   <data name=">>alignmentGroup.Type" xml:space="preserve">
   </data>
   <data name=">>alignmentGroup.Parent" xml:space="preserve">
@@ -943,7 +943,7 @@
   </data>
   </data>
@@ -967,7 +967,7 @@
   </data>
   </data>
@@ -975,7 +975,7 @@
     <value>1</value>
   </data>
   </metadata>
   <data name="DisplayLabel.AutoSize" type="System.Boolean, mscorlib">
@@ -997,7 +997,7 @@
     <value>DisplayLabel</value>
   </data>
   <data name=">>DisplayLabel.Type" xml:space="preserve">
   </data>
   <data name=">>DisplayLabel.Parent" xml:space="preserve">
@@ -1005,7 +1005,7 @@
   <data name=">>DisplayLabel.ZOrder" xml:space="preserve">
     <value>0</value>
   </data>
     <value>True</value>
   </metadata>
@@ -1021,138 +1021,138 @@
   </data>
   </data>
   </data>
   </data>
   </data>
   </data>
   </data>
   </data>
   </data>
   </data>
   </data>
   </data>
   <data name=">>FontTable.Name" xml:space="preserve">
     <value>FontTable</value>
   </data>
   <data name=">>FontTable.Type" xml:space="preserve">
   </data>
   <data name=">>dataColumn1.Name" xml:space="preserve">
     <value>dataColumn1</value>
   </data>
   <data name=">>dataColumn1.Type" xml:space="preserve">
   </data>
   <data name=">>dataColumn2.Name" xml:space="preserve">
     <value>dataColumn2</value>
   </data>
   <data name=">>dataColumn2.Type" xml:space="preserve">
   </data>
   <data name=">>BackgroundTypeTable.Name" xml:space="preserve">
     <value>BackgroundTypeTable</value>
   </data>
   <data name=">>BackgroundTypeTable.Type" xml:space="preserve">
   </data>
   <data name=">>dataColumn9.Name" xml:space="preserve">
     <value>dataColumn9</value>
   </data>
   <data name=">>dataColumn9.Type" xml:space="preserve">
   </data>
   <data name=">>dataColumn10.Name" xml:space="preserve">
     <value>dataColumn10</value>
   </data>
   <data name=">>dataColumn10.Type" xml:space="preserve">
   </data>
   <data name=">>RotationTable.Name" xml:space="preserve">
     <value>RotationTable</value>
   </data>
   <data name=">>RotationTable.Type" xml:space="preserve">
   </data>
   <data name=">>dataColumn7.Name" xml:space="preserve">
     <value>dataColumn7</value>
   </data>
   <data name=">>dataColumn7.Type" xml:space="preserve">
   </data>
   <data name=">>dataColumn8.Name" xml:space="preserve">
     <value>dataColumn8</value>
   </data>
   <data name=">>dataColumn8.Type" xml:space="preserve">
   </data>
   <data name=">>VerticalTable.Name" xml:space="preserve">
     <value>VerticalTable</value>
   </data>
   <data name=">>VerticalTable.Type" xml:space="preserve">
   </data>
   <data name=">>dataColumn13.Name" xml:space="preserve">
     <value>dataColumn13</value>
   </data>
   <data name=">>dataColumn13.Type" xml:space="preserve">
   </data>
   <data name=">>dataColumn14.Name" xml:space="preserve">
     <value>dataColumn14</value>
   </data>
   <data name=">>dataColumn14.Type" xml:space="preserve">
   </data>
   <data name=">>HorizontalTable.Name" xml:space="preserve">
     <value>HorizontalTable</value>
   </data>
   <data name=">>HorizontalTable.Type" xml:space="preserve">
   </data>
   <data name=">>dataColumn11.Name" xml:space="preserve">
     <value>dataColumn11</value>
   </data>
   <data name=">>dataColumn11.Type" xml:space="preserve">
   </data>
   <data name=">>dataColumn12.Name" xml:space="preserve">
     <value>dataColumn12</value>
   </data>
   <data name=">>dataColumn12.Type" xml:space="preserve">
   </data>
   </data>
   </data>
     <value>FontStyleEditor</value>
   </data>
   </data>
 </root>
Modified: branches/maestro-4.0.x/Maestro.Editors/LayerDefinition/Vector/StyleEditors/PointFeatureStyleEditor.resx
--- branches/maestro-4.0.x/Maestro.Editors/LayerDefinition/Vector/StyleEditors/PointFeatureStyleEditor.resx	2012-10-31 12:21:00 UTC (rev 7175)
+++ branches/maestro-4.0.x/Maestro.Editors/LayerDefinition/Vector/StyleEditors/PointFeatureStyleEditor.resx	2012-10-31 12:37:34 UTC (rev 7176)
     <value>2.0</value>
   </resheader>
   </resheader>
   </resheader>
   <data name="groupBox1.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
   </data>
   <data name="RotationBox.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
   </data>
+  <assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
   <data name="RotationBox.Location" type="System.Drawing.Point, System.Drawing">
     <value>128, 176</value>
   </data>
   <data name="RotationBox.Size" type="System.Drawing.Size, System.Drawing">
     <value>208, 21</value>
   </data>
+  <assembly alias="mscorlib" name="mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
   <data name="RotationBox.TabIndex" type="System.Int32, mscorlib">
     <value>29</value>
   </data>
@@ -139,7 +139,7 @@
     <value>RotationBox</value>
   </data>
   <data name=">>RotationBox.Type" xml:space="preserve">
   </data>
   <data name=">>RotationBox.Parent" xml:space="preserve">
@@ -166,7 +166,7 @@
   </data>
   </data>
@@ -193,7 +193,7 @@
     <value>HeightText</value>
   </data>
   <data name=">>HeightText.Type" xml:space="preserve">
   </data>
   <data name=">>HeightText.Parent" xml:space="preserve">
@@ -220,7 +220,7 @@
     <value>WidthText</value>
   </data>
   <data name=">>WidthText.Type" xml:space="preserve">
   </data>
   <data name=">>WidthText.Parent" xml:space="preserve">
@@ -244,7 +244,7 @@
     <value>SizeUnits</value>
   </data>
   <data name=">>SizeUnits.Type" xml:space="preserve">
   </data>
   <data name=">>SizeUnits.Parent" xml:space="preserve">
@@ -268,7 +268,7 @@
     <value>SizeContext</value>
   </data>
   <data name=">>SizeContext.Type" xml:space="preserve">
   </data>
   <data name=">>SizeContext.Parent" xml:space="preserve">
@@ -292,7 +292,7 @@
     <value>Symbol</value>
   </data>
   <data name=">>Symbol.Type" xml:space="preserve">
   </data>
   <data name=">>Symbol.Parent" xml:space="preserve">
@@ -319,7 +319,7 @@
   </data>
   </data>
@@ -346,7 +346,7 @@
   </data>
   </data>
@@ -373,7 +373,7 @@
   </data>
   </data>
@@ -400,7 +400,7 @@
   </data>
   </data>
@@ -427,7 +427,7 @@
   </data>
   </data>
@@ -451,7 +451,7 @@
   </data>
   </data>
@@ -502,7 +502,7 @@
     <value>grpSymbolFill</value>
   </data>
   <data name=">>grpSymbolFill.Type" xml:space="preserve">
   </data>
   <data name=">>grpSymbolFill.Parent" xml:space="preserve">
@@ -553,7 +553,7 @@
     <value>grpSymbolBorder</value>
   </data>
   <data name=">>grpSymbolBorder.Type" xml:space="preserve">
   </data>
   <data name=">>grpSymbolBorder.Parent" xml:space="preserve">
@@ -580,7 +580,7 @@
   </data>
   </data>
@@ -604,7 +604,7 @@
   </data>
   </data>
@@ -612,7 +612,7 @@
   <data name=">>groupBox4.ZOrder" xml:space="preserve">
     <value>4</value>
   </data>
     <value>122, 17</value>
   </metadata>
   <data name="DisplayPoints.AutoSize" type="System.Boolean, mscorlib">
@@ -634,7 +634,7 @@
     <value>DisplayPoints</value>
   </data>
   <data name=">>DisplayPoints.Type" xml:space="preserve">
   </data>
   <data name=">>DisplayPoints.Parent" xml:space="preserve">
@@ -667,7 +667,7 @@
     <value>label11</value>
   </data>
   <data name=">>label11.Type" xml:space="preserve">
   </data>
   <data name=">>label11.Parent" xml:space="preserve">
     <value>groupBoxFont</value>
@@ -699,7 +699,7 @@
   <data name=">>colorFontForeground.ZOrder" xml:space="preserve">
     <value>1</value>
   </data>
     <value>0, 0</value>
   </metadata>
   <data name="FontBoldButton.Font" type="System.Drawing.Font, System.Drawing">
@@ -808,7 +808,7 @@
   </data>
   </data>
     <value>panel1</value>
@@ -829,7 +829,7 @@
   </data>
   </data>
@@ -856,7 +856,7 @@
     <value>lblForeground</value>
   </data>
   <data name=">>lblForeground.Type" xml:space="preserve">
   </data>
   <data name=">>lblForeground.Parent" xml:space="preserve">
@@ -883,7 +883,7 @@
     <value>comboBoxCharacter</value>
   </data>
   <data name=">>comboBoxCharacter.Type" xml:space="preserve">
   </data>
   <data name=">>comboBoxCharacter.Parent" xml:space="preserve">
@@ -907,7 +907,7 @@
   </data>
   </data>
@@ -934,7 +934,7 @@
   </data>
   </data>
@@ -958,7 +958,7 @@
   </data>
   <data name=">>groupBoxFont.Type" xml:space="preserve">
   </data>
   <data name=">>groupBoxFont.Parent" xml:space="preserve">
@@ -988,7 +988,7 @@
     <value>button1</value>
   </data>
   <data name=">>button1.Type" xml:space="preserve">
+    <value>System.Windows.Forms.Button, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name=">>button1.Parent" xml:space="preserve">
     <value>groupBoxSymbolLocation</value>
@@ -1009,7 +1009,7 @@
     <value>ReferenceY</value>
   </data>
   <data name=">>ReferenceY.Type" xml:space="preserve">
   </data>
   <data name=">>ReferenceY.Parent" xml:space="preserve">
@@ -1033,7 +1033,7 @@
   </data>
   </data>
@@ -1054,7 +1054,7 @@
     <value>ReferenceX</value>
   </data>
   <data name=">>ReferenceX.Type" xml:space="preserve">
   </data>
   <data name=">>ReferenceX.Parent" xml:space="preserve">
@@ -1078,7 +1078,7 @@
   </data>
   </data>
@@ -1105,7 +1105,7 @@
   </data>
   </data>
@@ -1135,7 +1135,7 @@
     <value>MaintainAspectRatio</value>
   </data>
   <data name=">>MaintainAspectRatio.Type" xml:space="preserve">
   </data>
   <data name=">>MaintainAspectRatio.Parent" xml:space="preserve">
@@ -1159,7 +1159,7 @@
   </data>
   <data name=">>groupBoxSymbolLocation.Type" xml:space="preserve">
   </data>
   <data name=">>groupBoxSymbolLocation.Parent" xml:space="preserve">
@@ -1189,7 +1189,7 @@
     <value>chkW2DTextColor</value>
   </data>
   <data name=">>chkW2DTextColor.Type" xml:space="preserve">
   </data>
   <data name=">>chkW2DTextColor.Parent" xml:space="preserve">
     <value>grpW2DStyle</value>
@@ -1246,7 +1246,7 @@
     <value>chkW2DLineColor</value>
   </data>
   <data name=">>chkW2DLineColor.Type" xml:space="preserve">
   </data>
   <data name=">>chkW2DLineColor.Parent" xml:space="preserve">
@@ -1300,7 +1300,7 @@
     <value>chkW2DFillColor</value>
   </data>
   <data name=">>chkW2DFillColor.Type" xml:space="preserve">
   </data>
   <data name=">>chkW2DFillColor.Parent" xml:space="preserve">
@@ -1351,7 +1351,7 @@
   </data>
   <data name=">>grpW2DStyle.Type" xml:space="preserve">
   </data>
   <data name=">>grpW2DStyle.Parent" xml:space="preserve">
@@ -1359,7 +1359,7 @@
   <data name=">>grpW2DStyle.ZOrder" xml:space="preserve">
     <value>0</value>
   </data>
     <value>True</value>
   </metadata>
@@ -1375,102 +1375,102 @@
   </data>
   </data>
   </data>
   </data>
   </data>
   </data>
   <data name=">>UnitsTable.Name" xml:space="preserve">
   </data>
   </data>
   </data>
   </data>
   </data>
   </data>
   </data>
   </data>
   </data>
   </data>
   </data>
   </data>
   <data name=">>SymbolMarkTable.Name" xml:space="preserve">
     <value>SymbolMarkTable</value>
   </data>
   <data name=">>SymbolMarkTable.Type" xml:space="preserve">
   </data>
   </data>
   </data>
   </data>
   </data>
   </data>
   </data>
   <data name=">>FontBoldButton.Name" xml:space="preserve">
     <value>FontBoldButton</value>
   </data>
   <data name=">>FontBoldButton.Type" xml:space="preserve">
   </data>
   <data name=">>FontItalicButton.Name" xml:space="preserve">
     <value>FontItalicButton</value>
   </data>
   <data name=">>FontItalicButton.Type" xml:space="preserve">
   </data>
   <data name=">>FontUnderlineButton.Name" xml:space="preserve">
     <value>FontUnderlineButton</value>
   </data>
   <data name=">>FontUnderlineButton.Type" xml:space="preserve">
   </data>
     <value>PointFeatureStyleEditor</value>
   </data>
   </data>
 </root>
Modified: branches/maestro-4.0.x/Maestro.Editors/LayerDefinition/Vector/Thematics/ThemeCreator.resx
--- branches/maestro-4.0.x/Maestro.Editors/LayerDefinition/Vector/Thematics/ThemeCreator.resx	2012-10-31 12:21:00 UTC (rev 7175)
+++ branches/maestro-4.0.x/Maestro.Editors/LayerDefinition/Vector/Thematics/ThemeCreator.resx	2012-10-31 12:37:34 UTC (rev 7176)
     <value>2.0</value>
   </resheader>
   </resheader>
   </resheader>
     <value>True</value>
   </data>
     <value>8, 16</value>
   </data>
@@ -138,7 +138,7 @@
   </data>
   </data>
     <value>DataGroup</value>
@@ -165,7 +165,7 @@
   </data>
   </data>
     <value>RuleCountPanel</value>
@@ -192,7 +192,7 @@
     <value>AggregateLabel</value>
   </data>
   <data name=">>AggregateLabel.Type" xml:space="preserve">
   </data>
   <data name=">>AggregateLabel.Parent" xml:space="preserve">
     <value>GroupPanel</value>
@@ -219,7 +219,7 @@
     <value>OverwriteRules</value>
   </data>
   <data name=">>OverwriteRules.Type" xml:space="preserve">
-    <value>System.Windows.Forms.RadioButton, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.RadioButton, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name=">>OverwriteRules.Parent" xml:space="preserve">
@@ -246,7 +246,7 @@
     <value>AppendRules</value>
   </data>
   <data name=">>AppendRules.Type" xml:space="preserve">
   </data>
   <data name=">>AppendRules.Parent" xml:space="preserve">
@@ -254,7 +254,7 @@
   <data name=">>AppendRules.ZOrder" xml:space="preserve">
     <value>4</value>
   </data>
   <data name="ColumnCombo.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
   </data>
@@ -271,7 +271,7 @@
     <value>ColumnCombo</value>
   </data>
   <data name=">>ColumnCombo.Type" xml:space="preserve">
   </data>
   <data name=">>ColumnCombo.Parent" xml:space="preserve">
@@ -295,7 +295,7 @@
     <value>RuleCount</value>
   </data>
   <data name=">>RuleCount.Type" xml:space="preserve">
-    <value>System.Windows.Forms.NumericUpDown, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.NumericUpDown, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name=">>RuleCount.Parent" xml:space="preserve">
@@ -331,7 +331,7 @@
     <value>AggregateCombo</value>
   </data>
   <data name=">>AggregateCombo.Type" xml:space="preserve">
   </data>
   <data name=">>AggregateCombo.Parent" xml:space="preserve">
@@ -361,7 +361,7 @@
     <value>chkUseFirstRuleAsTemplate</value>
   </data>
   <data name=">>chkUseFirstRuleAsTemplate.Type" xml:space="preserve">
   </data>
   <data name=">>chkUseFirstRuleAsTemplate.Parent" xml:space="preserve">
@@ -382,7 +382,7 @@
   </data>
   <data name=">>GroupPanel.Type" xml:space="preserve">
   </data>
   <data name=">>GroupPanel.Parent" xml:space="preserve">
@@ -406,7 +406,7 @@
   </data>
   <data name=">>RuleCountPanel.Type" xml:space="preserve">
   </data>
   <data name=">>RuleCountPanel.Parent" xml:space="preserve">
@@ -430,7 +430,7 @@
   </data>
   <data name=">>DataGroup.Type" xml:space="preserve">
   </data>
   <data name=">>DataGroup.Parent" xml:space="preserve">
     <value>$this</value>
@@ -460,7 +460,7 @@
   </data>
   </data>
     <value>ColorBrewerPanel</value>
@@ -481,7 +481,7 @@
     <value>ColorBrewerDataType</value>
   </data>
   <data name=">>ColorBrewerDataType.Type" xml:space="preserve">
   </data>
   <data name=">>ColorBrewerDataType.Parent" xml:space="preserve">
@@ -523,7 +523,7 @@
   </data>
   <data name=">>ColorBrewerPanel.Type" xml:space="preserve">
   </data>
   <data name=">>ColorBrewerPanel.Parent" xml:space="preserve">
     <value>DisplayGroup</value>
@@ -550,7 +550,7 @@
     <value>ColorBrewerLabel</value>
   </data>
   <data name=">>ColorBrewerLabel.Type" xml:space="preserve">
   </data>
   <data name=">>ColorBrewerLabel.Parent" xml:space="preserve">
@@ -619,7 +619,7 @@
   </data>
   </data>
     <value>panel2</value>
@@ -640,7 +640,7 @@
   </data>
   <data name=">>panel2.Type" xml:space="preserve">
   </data>
   <data name=">>panel2.Parent" xml:space="preserve">
@@ -664,7 +664,7 @@
     <value>ColorBrewerColors</value>
   </data>
   <data name=">>ColorBrewerColors.Type" xml:space="preserve">
   </data>
   <data name=">>ColorBrewerColors.Parent" xml:space="preserve">
@@ -691,7 +691,7 @@
     <value>GradientColors</value>
   </data>
   <data name=">>GradientColors.Type" xml:space="preserve">
   </data>
   <data name=">>GradientColors.Parent" xml:space="preserve">
@@ -715,7 +715,7 @@
   </data>
   <data name=">>DisplayGroup.Type" xml:space="preserve">
   </data>
   <data name=">>DisplayGroup.Parent" xml:space="preserve">
@@ -739,7 +739,7 @@
     <value>PreviewPicture</value>
   </data>
   <data name=">>PreviewPicture.Type" xml:space="preserve">
   </data>
   <data name=">>PreviewPicture.Parent" xml:space="preserve">
     <value>PreviewGroup</value>
@@ -763,7 +763,7 @@
   </data>
   <data name=">>PreviewGroup.Type" xml:space="preserve">
   </data>
   <data name=">>PreviewGroup.Parent" xml:space="preserve">
@@ -790,7 +790,7 @@
     <value>CancelBtn</value>
   </data>
   <data name=">>CancelBtn.Type" xml:space="preserve">
-    <value>System.Windows.Forms.Button, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name=">>CancelBtn.Parent" xml:space="preserve">
     <value>ButtonPanel</value>
@@ -817,7 +817,7 @@
     <value>OKBtn</value>
   </data>
   <data name=">>OKBtn.Type" xml:space="preserve">
   </data>
   <data name=">>OKBtn.Parent" xml:space="preserve">
@@ -841,7 +841,7 @@
   </data>
   <data name=">>ButtonPanel.Type" xml:space="preserve">
-    <value>System.Windows.Forms.Panel, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.Panel, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name=">>ButtonPanel.Parent" xml:space="preserve">
@@ -864,7 +864,7 @@
   <data name=">>colorComboBox1.Type" xml:space="preserve">
     <value>Maestro.Editors.Common.ColorComboBox, Maestro.Editors, Version=5.0.0.6640, Culture=neutral, PublicKeyToken=f526c48929fda856</value>
   </data>
     <value>True</value>
   </metadata>
@@ -877,6 +877,6 @@
     <value>ThemeCreator</value>
   </data>
   </data>
 </root>
Modified: branches/maestro-4.0.x/Maestro.Editors/LayerDefinition/Vector/VectorLayerSettingsSectionCtrl.resx
--- branches/maestro-4.0.x/Maestro.Editors/LayerDefinition/Vector/VectorLayerSettingsSectionCtrl.resx	2012-10-31 12:21:00 UTC (rev 7175)
+++ branches/maestro-4.0.x/Maestro.Editors/LayerDefinition/Vector/VectorLayerSettingsSectionCtrl.resx	2012-10-31 12:37:34 UTC (rev 7176)
     <value>2.0</value>
   </resheader>
   </resheader>
   </resheader>
-  <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+  <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
   </data>
   </data>
-  <assembly alias="System.Drawing" name="System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
     <value>414, 17</value>
   </data>
     <value>26, 23</value>
   </data>
-  <assembly alias="mscorlib" name="mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
     <value>5</value>
   </data>
@@ -139,7 +139,7 @@
   </data>
   </data>
@@ -169,7 +169,7 @@
     <value>btnEditTooltip</value>
   </data>
   <data name=">>btnEditTooltip.Type" xml:space="preserve">
   </data>
   <data name=">>btnEditTooltip.Parent" xml:space="preserve">
     <value>grpLayerSettings</value>
@@ -196,7 +196,7 @@
     <value>btnEditHyperlink</value>
   </data>
   <data name=">>btnEditHyperlink.Type" xml:space="preserve">
   </data>
   <data name=">>btnEditHyperlink.Parent" xml:space="preserve">
@@ -223,7 +223,7 @@
     <value>btnEditFilter</value>
   </data>
   <data name=">>btnEditFilter.Type" xml:space="preserve">
   </data>
   <data name=">>btnEditFilter.Parent" xml:space="preserve">
@@ -247,7 +247,7 @@
     <value>txtTooltip</value>
   </data>
   <data name=">>txtTooltip.Type" xml:space="preserve">
-    <value>System.Windows.Forms.TextBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.TextBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name=">>txtTooltip.Parent" xml:space="preserve">
@@ -271,7 +271,7 @@
     <value>txtHyperlink</value>
   </data>
   <data name=">>txtHyperlink.Type" xml:space="preserve">
   </data>
   <data name=">>txtHyperlink.Parent" xml:space="preserve">
@@ -295,7 +295,7 @@
     <value>txtFilter</value>
   </data>
   <data name=">>txtFilter.Type" xml:space="preserve">
   </data>
   <data name=">>txtFilter.Parent" xml:space="preserve">
@@ -322,7 +322,7 @@
   </data>
-    <value>System.Windows.Forms.Label, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.Label, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
@@ -349,7 +349,7 @@
   </data>
   </data>
@@ -376,7 +376,7 @@
   </data>
   </data>
@@ -400,7 +400,7 @@
   </data>
   <data name=">>grpLayerSettings.Type" xml:space="preserve">
   </data>
   <data name=">>grpLayerSettings.Parent" xml:space="preserve">
@@ -430,7 +430,7 @@
   </data>
   </data>
@@ -457,7 +457,7 @@
   </data>
   </data>
@@ -484,7 +484,7 @@
   </data>
   </data>
@@ -511,7 +511,7 @@
   </data>
   </data>
@@ -535,7 +535,7 @@
   </data>
   </data>
@@ -559,7 +559,7 @@
   </data>
   </data>
@@ -583,7 +583,7 @@
   </data>
   </data>
@@ -610,7 +610,7 @@
   </data>
   </data>
@@ -634,7 +634,7 @@
   </data>
   </data>
@@ -661,7 +661,7 @@
   </data>
   </data>
@@ -676,7 +676,7 @@
   </data>
   </data>
@@ -684,7 +684,7 @@
     <value>0</value>
   </data>
-  <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+  <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
     <value>True</value>
   </metadata>
Modified: branches/maestro-4.0.x/Maestro.Editors/MapDefinition/FiniteScaleListCtrl.resx
--- branches/maestro-4.0.x/Maestro.Editors/MapDefinition/FiniteScaleListCtrl.resx	2012-10-31 12:21:00 UTC (rev 7175)
+++ branches/maestro-4.0.x/Maestro.Editors/MapDefinition/FiniteScaleListCtrl.resx	2012-10-31 12:37:34 UTC (rev 7176)
@@ -112,23 +112,23 @@
     <value>2.0</value>
   </resheader>
   </resheader>
   </resheader>
   </data>
   <data name="btnGenerateScales.Location" type="System.Drawing.Point, System.Drawing">
     <value>183, 86</value>
   </data>
   <data name="btnGenerateScales.Size" type="System.Drawing.Size, System.Drawing">
     <value>75, 23</value>
   </data>
   <data name="btnGenerateScales.TabIndex" type="System.Int32, mscorlib">
     <value>10</value>
   </data>
@@ -139,7 +139,7 @@
     <value>btnGenerateScales</value>
   </data>
   <data name=">>btnGenerateScales.Type" xml:space="preserve">
   </data>
   <data name=">>btnGenerateScales.Parent" xml:space="preserve">
@@ -160,7 +160,7 @@
     <value>numScales</value>
   </data>
   <data name=">>numScales.Type" xml:space="preserve">
   </data>
   <data name=">>numScales.Parent" xml:space="preserve">
@@ -187,7 +187,7 @@
   </data>
   </data>
@@ -211,7 +211,7 @@
     <value>cmbRounding</value>
   </data>
   <data name=">>cmbRounding.Type" xml:space="preserve">
   </data>
   <data name=">>cmbRounding.Parent" xml:space="preserve">
@@ -232,7 +232,7 @@
     <value>cmbMethod</value>
   </data>
   <data name=">>cmbMethod.Type" xml:space="preserve">
   </data>
   <data name=">>cmbMethod.Parent" xml:space="preserve">
@@ -259,7 +259,7 @@
   </data>
   </data>
@@ -286,7 +286,7 @@
   </data>
   </data>
@@ -310,7 +310,7 @@
     <value>numMaxScale</value>
   </data>
   <data name=">>numMaxScale.Type" xml:space="preserve">
   </data>
   <data name=">>numMaxScale.Parent" xml:space="preserve">
@@ -331,7 +331,7 @@
     <value>numMinScale</value>
   </data>
   <data name=">>numMinScale.Type" xml:space="preserve">
   </data>
   <data name=">>numMinScale.Parent" xml:space="preserve">
@@ -358,7 +358,7 @@
   </data>
   </data>
@@ -385,7 +385,7 @@
   </data>
   </data>
@@ -409,7 +409,7 @@
   </data>
   </data>
@@ -436,7 +436,7 @@
     <value>lstDisplayScales</value>
   </data>
   <data name=">>lstDisplayScales.Type" xml:space="preserve">
   </data>
   <data name=">>lstDisplayScales.Parent" xml:space="preserve">
@@ -444,7 +444,7 @@
   <data name=">>lstDisplayScales.ZOrder" xml:space="preserve">
     <value>0</value>
   </data>
-  <metadata name="toolStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+  <metadata name="toolStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
     <value>3, 16</value>
   </metadata>
   <data name="btnEditScalesManually.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
@@ -496,7 +496,7 @@
     <value>toolStrip1</value>
   </data>
   <data name=">>toolStrip1.Type" xml:space="preserve">
-    <value>System.Windows.Forms.ToolStrip, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.ToolStrip, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name=">>toolStrip1.Parent" xml:space="preserve">
@@ -520,7 +520,7 @@
   </data>
   </data>
@@ -528,7 +528,7 @@
   <data name=">>groupBox2.ZOrder" xml:space="preserve">
     <value>0</value>
   </data>
     <value>True</value>
   </metadata>
@@ -538,30 +538,30 @@
     <value>btnEditScalesManually</value>
   </data>
   <data name=">>btnEditScalesManually.Type" xml:space="preserve">
-    <value>System.Windows.Forms.ToolStripButton, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.ToolStripButton, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name=">>btnRemoveScale.Name" xml:space="preserve">
     <value>btnRemoveScale</value>
   </data>
   <data name=">>btnRemoveScale.Type" xml:space="preserve">
   </data>
   <data name=">>toolStripSeparator1.Name" xml:space="preserve">
     <value>toolStripSeparator1</value>
   </data>
   <data name=">>toolStripSeparator1.Type" xml:space="preserve">
-    <value>System.Windows.Forms.ToolStripSeparator, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.ToolStripSeparator, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name=">>btnCmsScaleList.Name" xml:space="preserve">
     <value>btnCmsScaleList</value>
   </data>
   <data name=">>btnCmsScaleList.Type" xml:space="preserve">
   </data>
   <data name=">>$this.Name" xml:space="preserve">
     <value>FiniteScaleListCtrl</value>
   </data>
   <data name=">>$this.Type" xml:space="preserve">
   </data>
 </root>
More information about the mapguide-commits mailing list
