[mapguide-commits] r6973 - in branches/maestro-4.0.x: Maestro Maestro.Editors/Common OSGeo.MapGuide.MaestroAPI/Expression OSGeo.MapGuide.MaestroAPI/Feature OSGeo.MapGuide.MaestroAPI.Http OSGeo.MapGuide.MaestroAPI.Native
svn_mapguide at osgeo.org
Mon Sep 3 05:48:48 PDT 2012
Author: jng
Date: 2012-09-03 05:48:48 -0700 (Mon, 03 Sep 2012)
New Revision: 6973
branches/maestro-4.0.x/Maestro.Editors/Common/ExpressionEditor.cs
branches/maestro-4.0.x/Maestro.Editors/Common/ExpressionEditor.designer.cs
branches/maestro-4.0.x/Maestro.Editors/Common/ExpressionEditor.resx
branches/maestro-4.0.x/Maestro/changelog.txt
branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI.Http/XmlReaderBase.cs
branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeDataReader.cs
branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeFeatureReader.cs
branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeSqlReader.cs
branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI/Expression/ExpressionFeatureReader.cs
branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI/Feature/FeatureBase.cs
branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI/Feature/ReaderBase.cs
#2100: Backport to 4.0.x. We had to fix some reader methods due to some methods not being present in the 4.0.x iteration of the MaestroAPI
Modified: branches/maestro-4.0.x/Maestro/changelog.txt
--- branches/maestro-4.0.x/Maestro/changelog.txt 2012-09-03 12:32:42 UTC (rev 6972)
+++ branches/maestro-4.0.x/Maestro/changelog.txt 2012-09-03 12:48:48 UTC (rev 6973)
@@ -1,5 +1,9 @@
-4.0.2
+4.0.3
+ - Use UNIQUE() for fetching distinct values in Expression Editor
+4.0.2
- mg-desktop binary update (20 July 2012 release)
- Added validation rules for Feature Sources regarding secured credentials
- Added support for creating Feature Sources with secured credentials
Modified: branches/maestro-4.0.x/Maestro.Editors/Common/ExpressionEditor.cs
--- branches/maestro-4.0.x/Maestro.Editors/Common/ExpressionEditor.cs 2012-09-03 12:32:42 UTC (rev 6972)
+++ branches/maestro-4.0.x/Maestro.Editors/Common/ExpressionEditor.cs 2012-09-03 12:48:48 UTC (rev 6973)
@@ -750,16 +750,58 @@
private void LookupValues_Click(object sender, EventArgs e)
+ //Use UNIQUE() method first. This should work in most cases
using (new WaitCursor(this))
+ string filter = null;
+ var expr = "UNIQUE(" + ColumnName.Text + ")";
+ bool bFallback = false;
+ ColumnValue.Items.Clear();
+ ColumnValue.Tag = null;
try
+ using (var rdr = _featSvc.AggregateQueryFeatureSource(m_featureSource, _cls.QualifiedName, filter, new System.Collections.Specialized.NameValueCollection() {
+ { "UNIQ_VALS", expr }
+ for (int i = 0; i < rdr.FieldCount; i++)
+ if (rdr.GetName(i) == "UNIQ_VALS")
+ ColumnName.Tag = rdr.GetFieldType(i);
+ while (rdr.ReadNext())
+ if (!rdr.IsNull("UNIQ_VALS"))
+ object value = rdr["UNIQ_VALS"];
+ ColumnValue.Items.Add(value);
+ rdr.Close();
+ catch
+ bFallback = true;
+ if (!bFallback)
+ ColumnValue.Enabled = true;
+ ColumnValue.SelectedIndex = -1;
+ ColumnValue.DroppedDown = true;
+ return;
+ try
SortedList<string, PropertyDefinition> cols = (SortedList<string, PropertyDefinition>)ColumnName.Tag;
PropertyDefinition col = cols[ColumnName.Text];
bool retry = true;
Exception rawEx = null;
- string filter = null;
SortedList<string, string> values = new SortedList<string, string>();
bool hasNull = false;
@@ -825,12 +867,27 @@
private void ColumnValue_SelectedIndexChanged(object sender, EventArgs e)
- if (ColumnValue.SelectedIndex >= 0 && ColumnValue.Tag as Type != null)
+ if (ColumnValue.SelectedIndex >= 0)
- if (ColumnValue.Tag == typeof(string) && (ColumnValue.SelectedIndex != 0 || ColumnValue.Text != "NULL"))
- ExpressionText.SelectedText = " '" + ColumnValue.Text + "' ";
- else
- ExpressionText.SelectedText = " " + ColumnValue.Text + " ";
+ var tag = ColumnValue.Tag;
+ if (tag != null)
+ if (ColumnValue.Tag == typeof(string) && (ColumnValue.SelectedIndex != 0 || ColumnValue.Text != "NULL"))
+ InsertText("'" + ColumnValue.Text + "'");
+ else
+ if (tag is PropertyValueType && (PropertyValueType)tag == PropertyValueType.String)
+ else
+ InsertText(ColumnValue.Text);
+ else
Modified: branches/maestro-4.0.x/Maestro.Editors/Common/ExpressionEditor.designer.cs
--- branches/maestro-4.0.x/Maestro.Editors/Common/ExpressionEditor.designer.cs 2012-09-03 12:32:42 UTC (rev 6972)
+++ branches/maestro-4.0.x/Maestro.Editors/Common/ExpressionEditor.designer.cs 2012-09-03 12:48:48 UTC (rev 6973)
@@ -35,6 +35,8 @@
this.panel1 = new System.Windows.Forms.Panel();
this.lblHint = new System.Windows.Forms.Label();
this.toolStrip1 = new System.Windows.Forms.ToolStrip();
+ this.btnProperties = new System.Windows.Forms.ToolStripDropDownButton();
+ this.btnFunctions = new System.Windows.Forms.ToolStripDropDownButton();
this.btnFilter = new System.Windows.Forms.ToolStripDropDownButton();
this.btnCondition = new System.Windows.Forms.ToolStripMenuItem();
this.btnSpatial = new System.Windows.Forms.ToolStripMenuItem();
@@ -45,8 +47,6 @@
this.ColumnName = new System.Windows.Forms.ToolStripComboBox();
this.ExpressionText = new System.Windows.Forms.TextBox();
this._autoCompleteTooltip = new System.Windows.Forms.ToolTip(this.components);
- this.btnFunctions = new System.Windows.Forms.ToolStripDropDownButton();
- this.btnProperties = new System.Windows.Forms.ToolStripDropDownButton();
this.panel1.SuspendLayout();
this.toolStrip1.SuspendLayout();
this.SuspendLayout();
@@ -92,6 +92,18 @@
resources.ApplyResources(this.toolStrip1, "toolStrip1");
this.toolStrip1.Name = "toolStrip1";
+ // btnProperties
+ this.btnProperties.Image = global::Maestro.Editors.Properties.Resources.property;
+ resources.ApplyResources(this.btnProperties, "btnProperties");
+ this.btnProperties.Name = "btnProperties";
+ // btnFunctions
+ this.btnFunctions.Image = global::Maestro.Editors.Properties.Resources.function;
+ resources.ApplyResources(this.btnFunctions, "btnFunctions");
+ this.btnFunctions.Name = "btnFunctions";
// btnFilter
this.btnFilter.DropDownItems.AddRange(new System.Windows.Forms.ToolStripItem[] {
@@ -160,22 +172,10 @@
this.ExpressionText.KeyDown += new System.Windows.Forms.KeyEventHandler(this.ExpressionText_KeyDown);
this.ExpressionText.KeyUp += new System.Windows.Forms.KeyEventHandler(this.ExpressionText_KeyUp);
- // btnFunctions
- this.btnFunctions.Image = global::Maestro.Editors.Properties.Resources.function;
- resources.ApplyResources(this.btnFunctions, "btnFunctions");
- this.btnFunctions.Name = "btnFunctions";
- // btnProperties
- this.btnProperties.Image = global::Maestro.Editors.Properties.Resources.property;
- resources.ApplyResources(this.btnProperties, "btnProperties");
- this.btnProperties.Name = "btnProperties";
// ExpressionEditor
+ this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.None;
resources.ApplyResources(this, "$this");
- this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.None;
this.ControlBox = false;
this.Controls.Add(this.ExpressionText);
this.Controls.Add(this.toolStrip1);
Modified: branches/maestro-4.0.x/Maestro.Editors/Common/ExpressionEditor.resx
--- branches/maestro-4.0.x/Maestro.Editors/Common/ExpressionEditor.resx 2012-09-03 12:32:42 UTC (rev 6972)
+++ branches/maestro-4.0.x/Maestro.Editors/Common/ExpressionEditor.resx 2012-09-03 12:48:48 UTC (rev 6973)
@@ -112,23 +112,23 @@
<value>2.0</value>
</resheader>
<resheader name="reader">
- <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</resheader>
<resheader name="writer">
- <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</resheader>
- <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
<data name="OKBtn.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
<value>Bottom, Right</value>
</data>
- <assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+ <assembly alias="System.Drawing" name="System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
<data name="OKBtn.Location" type="System.Drawing.Point, System.Drawing">
<value>342, 6</value>
</data>
<data name="OKBtn.Size" type="System.Drawing.Size, System.Drawing">
<value>75, 23</value>
</data>
- <assembly alias="mscorlib" name="mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <assembly alias="mscorlib" name="mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
<data name="OKBtn.TabIndex" type="System.Int32, mscorlib">
<value>2</value>
</data>
@@ -139,7 +139,7 @@
<value>OKBtn</value>
</data>
<data name=">>OKBtn.Type" xml:space="preserve">
- <value>System.Windows.Forms.Button, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.Button, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>OKBtn.Parent" xml:space="preserve">
<value>panel1</value>
@@ -166,7 +166,7 @@
<value>CancelBtn</value>
</data>
<data name=">>CancelBtn.Type" xml:space="preserve">
</data>
<data name=">>CancelBtn.Parent" xml:space="preserve">
@@ -174,11 +174,26 @@
<data name=">>CancelBtn.ZOrder" xml:space="preserve">
<value>1</value>
</data>
+ <data name="lblHint.AutoSize" type="System.Boolean, mscorlib">
+ <value>True</value>
+ </data>
+ <data name="lblHint.Location" type="System.Drawing.Point, System.Drawing">
+ <value>12, 11</value>
+ </data>
+ <data name="lblHint.Size" type="System.Drawing.Size, System.Drawing">
+ <value>202, 13</value>
+ </data>
+ <data name="lblHint.TabIndex" type="System.Int32, mscorlib">
+ <value>4</value>
+ </data>
+ <data name="lblHint.Text" xml:space="preserve">
+ <value>Press Alt + Right to invoke auto-complete</value>
+ </data>
<data name=">>lblHint.Name" xml:space="preserve">
<value>lblHint</value>
</data>
<data name=">>lblHint.Type" xml:space="preserve">
- <value>System.Windows.Forms.Label, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.Label, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>lblHint.Parent" xml:space="preserve">
@@ -202,7 +217,7 @@
</data>
<data name=">>panel1.Type" xml:space="preserve">
- <value>System.Windows.Forms.Panel, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.Panel, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>panel1.Parent" xml:space="preserve">
<value>$this</value>
@@ -210,41 +225,14 @@
<data name=">>panel1.ZOrder" xml:space="preserve">
<value>2</value>
</data>
- <data name="lblHint.AutoSize" type="System.Boolean, mscorlib">
- <value>True</value>
- </data>
- <data name="lblHint.Location" type="System.Drawing.Point, System.Drawing">
- <value>12, 11</value>
- </data>
- <data name="lblHint.Size" type="System.Drawing.Size, System.Drawing">
- <value>202, 13</value>
- </data>
- <data name="lblHint.TabIndex" type="System.Int32, mscorlib">
- <value>4</value>
- </data>
- <data name="lblHint.Text" xml:space="preserve">
- <value>Press Alt + Right to invoke auto-complete</value>
- </data>
- <data name=">>lblHint.Name" xml:space="preserve">
- <value>lblHint</value>
- </data>
- <data name=">>lblHint.Type" xml:space="preserve">
- </data>
- <data name=">>lblHint.Parent" xml:space="preserve">
- <value>panel1</value>
- </data>
- <data name=">>lblHint.ZOrder" xml:space="preserve">
- <value>0</value>
- </data>
- <metadata name="toolStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <metadata name="toolStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
<value>17, 17</value>
</metadata>
<data name="btnProperties.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
<value>Magenta</value>
</data>
<data name="btnProperties.Size" type="System.Drawing.Size, System.Drawing">
- <value>85, 22</value>
+ <value>89, 22</value>
</data>
<data name="btnProperties.Text" xml:space="preserve">
<value>Properties</value>
@@ -253,16 +241,34 @@
</data>
<data name="btnFunctions.Size" type="System.Drawing.Size, System.Drawing">
- <value>82, 22</value>
+ <value>88, 22</value>
</data>
<data name="btnFunctions.Text" xml:space="preserve">
<value>Functions</value>
</data>
+ <data name="btnCondition.Size" type="System.Drawing.Size, System.Drawing">
+ <value>127, 22</value>
+ </data>
+ <data name="btnCondition.Text" xml:space="preserve">
+ <value>Condition</value>
+ </data>
+ <data name="btnSpatial.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="btnSpatial.Text" xml:space="preserve">
+ <value>Spatial</value>
+ </data>
+ <data name="btnDistance.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="btnDistance.Text" xml:space="preserve">
+ <value>Distance</value>
+ </data>
<data name="btnFilter.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
</data>
<data name="btnFilter.Size" type="System.Drawing.Size, System.Drawing">
- <value>60, 22</value>
+ <value>62, 22</value>
</data>
<data name="btnFilter.Text" xml:space="preserve">
<value>Filter</value>
@@ -310,7 +316,7 @@
<value>toolStrip1</value>
</data>
<data name=">>toolStrip1.Type" xml:space="preserve">
- <value>System.Windows.Forms.ToolStrip, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.ToolStrip, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>toolStrip1.Parent" xml:space="preserve">
@@ -318,24 +324,6 @@
<data name=">>toolStrip1.ZOrder" xml:space="preserve">
<value>1</value>
</data>
- <data name="btnCondition.Size" type="System.Drawing.Size, System.Drawing">
- <value>152, 22</value>
- </data>
- <data name="btnCondition.Text" xml:space="preserve">
- <value>Condition</value>
- </data>
- <data name="btnSpatial.Size" type="System.Drawing.Size, System.Drawing">
- </data>
- <data name="btnSpatial.Text" xml:space="preserve">
- <value>Spatial</value>
- </data>
- <data name="btnDistance.Size" type="System.Drawing.Size, System.Drawing">
- </data>
- <data name="btnDistance.Text" xml:space="preserve">
- <value>Distance</value>
- </data>
<data name="ExpressionText.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
<value>Fill</value>
</data>
@@ -358,7 +346,7 @@
<value>ExpressionText</value>
</data>
<data name=">>ExpressionText.Type" xml:space="preserve">
- <value>System.Windows.Forms.TextBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.TextBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>ExpressionText.Parent" xml:space="preserve">
@@ -366,15 +354,12 @@
<data name=">>ExpressionText.ZOrder" xml:space="preserve">
<value>0</value>
</data>
- <metadata name="_autoCompleteTooltip.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <metadata name="_autoCompleteTooltip.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
<value>116, 17</value>
</metadata>
- <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+ <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
<value>True</value>
</metadata>
- <data name="$this.AutoScaleDimensions" type="System.Drawing.SizeF, System.Drawing">
- <value>6, 13</value>
- </data>
<data name="$this.ClientSize" type="System.Drawing.Size, System.Drawing">
<value>510, 289</value>
</data>
@@ -387,76 +372,76 @@
<data name="$this.Text" xml:space="preserve">
<value>Expression Editor</value>
</data>
+ <data name=">>btnProperties.Name" xml:space="preserve">
+ <value>btnProperties</value>
+ </data>
+ <data name=">>btnProperties.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ToolStripDropDownButton, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>btnFunctions.Name" xml:space="preserve">
+ <value>btnFunctions</value>
+ </data>
+ <data name=">>btnFunctions.Type" xml:space="preserve">
+ </data>
<data name=">>btnFilter.Name" xml:space="preserve">
<value>btnFilter</value>
</data>
<data name=">>btnFilter.Type" xml:space="preserve">
- <value>System.Windows.Forms.ToolStripDropDownButton, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>btnCondition.Name" xml:space="preserve">
<value>btnCondition</value>
</data>
<data name=">>btnCondition.Type" xml:space="preserve">
- <value>System.Windows.Forms.ToolStripMenuItem, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.ToolStripMenuItem, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>btnSpatial.Name" xml:space="preserve">
<value>btnSpatial</value>
</data>
<data name=">>btnSpatial.Type" xml:space="preserve">
</data>
<data name=">>btnDistance.Name" xml:space="preserve">
<value>btnDistance</value>
</data>
<data name=">>btnDistance.Type" xml:space="preserve">
</data>
<data name=">>toolStripSeparator1.Name" xml:space="preserve">
<value>toolStripSeparator1</value>
</data>
<data name=">>toolStripSeparator1.Type" xml:space="preserve">
- <value>System.Windows.Forms.ToolStripSeparator, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.ToolStripSeparator, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>ColumnValue.Name" xml:space="preserve">
<value>ColumnValue</value>
</data>
<data name=">>ColumnValue.Type" xml:space="preserve">
- <value>System.Windows.Forms.ToolStripComboBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.ToolStripComboBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>LookupValues.Name" xml:space="preserve">
<value>LookupValues</value>
</data>
<data name=">>LookupValues.Type" xml:space="preserve">
- <value>System.Windows.Forms.ToolStripButton, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.ToolStripButton, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>ColumnName.Name" xml:space="preserve">
<value>ColumnName</value>
</data>
<data name=">>ColumnName.Type" xml:space="preserve">
</data>
<data name=">>_autoCompleteTooltip.Name" xml:space="preserve">
<value>_autoCompleteTooltip</value>
</data>
<data name=">>_autoCompleteTooltip.Type" xml:space="preserve">
- <value>System.Windows.Forms.ToolTip, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.ToolTip, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
- <data name=">>btnFunctions.Name" xml:space="preserve">
- <value>btnFunctions</value>
- </data>
- <data name=">>btnFunctions.Type" xml:space="preserve">
- </data>
- <data name=">>btnProperties.Name" xml:space="preserve">
- <value>btnProperties</value>
- </data>
- <data name=">>btnProperties.Type" xml:space="preserve">
- </data>
<data name=">>$this.Name" xml:space="preserve">
<value>ExpressionEditor</value>
</data>
<data name=">>$this.Type" xml:space="preserve">
- <value>System.Windows.Forms.Form, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.Form, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
</root>
\ No newline at end of file
Modified: branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI/Expression/ExpressionFeatureReader.cs
--- branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI/Expression/ExpressionFeatureReader.cs 2012-09-03 12:32:42 UTC (rev 6972)
+++ branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI/Expression/ExpressionFeatureReader.cs 2012-09-03 12:48:48 UTC (rev 6973)
@@ -98,6 +98,16 @@
return _reader.GetName(index);
+ public override Schema.PropertyValueType GetPropertyType(int index)
+ return _reader.GetPropertyType(index);
+ public override Schema.PropertyValueType GetPropertyType(string name)
+ return _reader.GetPropertyType(name);
public override ReaderType ReaderType
get { return _reader.ReaderType; }
Modified: branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI/Feature/FeatureBase.cs
--- branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI/Feature/FeatureBase.cs 2012-09-03 12:32:42 UTC (rev 6972)
+++ branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI/Feature/FeatureBase.cs 2012-09-03 12:48:48 UTC (rev 6973)
@@ -134,6 +134,36 @@
_pos = -1;
+ public override PropertyValueType GetPropertyType(int index)
+ var prop = this.ClassDefinition.Properties[index];
+ if (prop.Type == PropertyDefinitionType.Data)
+ return (PropertyValueType)((DataPropertyDefinition)prop).DataType;
+ else if (prop.Type == PropertyDefinitionType.Geometry)
+ return PropertyValueType.Geometry;
+ else if (prop.Type == PropertyDefinitionType.Raster)
+ return PropertyValueType.Raster;
+ else
+ throw new ArgumentException();
+ public override PropertyValueType GetPropertyType(string name)
+ var prop = this.ClassDefinition.FindProperty(name);
+ if (prop != null)
+ else
/// <summary>
/// Reads the next feature.
/// </summary>
Modified: branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI/Feature/ReaderBase.cs
--- branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI/Feature/ReaderBase.cs 2012-09-03 12:32:42 UTC (rev 6972)
+++ branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI/Feature/ReaderBase.cs 2012-09-03 12:48:48 UTC (rev 6973)
@@ -368,5 +368,19 @@
get { return this.Current[name]; }
+ /// <summary>
+ /// Gets the type of the property.
+ /// </summary>
+ /// <param name="name">The name.</param>
+ /// <returns></returns>
+ public abstract OSGeo.MapGuide.MaestroAPI.Schema.PropertyValueType GetPropertyType(string name);
+ /// <summary>
+ /// Gets the type of the property at the specified index.
+ /// </summary>
+ /// <param name="index">The index.</param>
+ public abstract OSGeo.MapGuide.MaestroAPI.Schema.PropertyValueType GetPropertyType(int index);
Modified: branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI.Http/XmlReaderBase.cs
--- branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI.Http/XmlReaderBase.cs 2012-09-03 12:32:42 UTC (rev 6972)
+++ branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI.Http/XmlReaderBase.cs 2012-09-03 12:48:48 UTC (rev 6973)
@@ -140,6 +140,16 @@
+ return _propertyMap[name].Type;
+ return _properties[index].Type;
public override Type GetFieldType(int i)
return ClrFdoTypeMap.GetClrType(_properties[i].Type);
Modified: branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeDataReader.cs
--- branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeDataReader.cs 2012-09-03 12:32:42 UTC (rev 6972)
+++ branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeDataReader.cs 2012-09-03 12:48:48 UTC (rev 6973)
@@ -80,6 +80,17 @@
get { return ReaderType.Data; }
+ var name = _reader.GetPropertyName(index);
+ return (PropertyValueType)_reader.GetPropertyType(name); //We can do this because the enum values map directly to MgPropertyType
public override string GetName(int index)
return _reader.GetPropertyName(index);
Modified: branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeFeatureReader.cs
--- branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeFeatureReader.cs 2012-09-03 12:32:42 UTC (rev 6972)
+++ branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeFeatureReader.cs 2012-09-03 12:48:48 UTC (rev 6973)
@@ -23,6 +23,7 @@
using OSGeo.MapGuide.MaestroAPI.Exceptions;
using OSGeo.MapGuide.MaestroAPI.Feature;
using GisSharpBlog.NetTopologySuite.IO;
+using OSGeo.MapGuide.MaestroAPI.Schema;
namespace OSGeo.MapGuide.MaestroAPI.Native
@@ -51,6 +52,17 @@
return null;
public override void Dispose()
Close();
Modified: branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeSqlReader.cs
--- branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeSqlReader.cs 2012-09-03 12:32:42 UTC (rev 6972)
+++ branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeSqlReader.cs 2012-09-03 12:48:48 UTC (rev 6973)
@@ -70,6 +70,17 @@
return null;
public override void Close()
_reader.Close();
More information about the mapguide-commits
