[mapguide-commits] r6986 - branches/2.4/MgDev
svn_mapguide at osgeo.org
Fri Sep 7 09:59:40 PDT 2012
Author: jng
Date: 2012-09-07 09:59:40 -0700 (Fri, 07 Sep 2012)
New Revision: 6986
branches/2.4/MgDev/build_fusion.bat
Build the fusion API docs and include them in the output dir for installer packing
Modified: branches/2.4/MgDev/build_fusion.bat
--- branches/2.4/MgDev/build_fusion.bat 2012-09-07 06:30:22 UTC (rev 6985)
+++ branches/2.4/MgDev/build_fusion.bat 2012-09-07 16:59:40 UTC (rev 6986)
@@ -1,5 +1,9 @@
@echo off
echo [build]: Web Tier - fusion templates
%XCOPY% "%MG_OEM%\fusionMG" "%MG_OEM%\fusion_build" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
+echo [build]: Web Tier - Clean fusion
+call %ANT% clean -f "%MG_OEM%\fusion\build.xml"
+echo [build]: Web Tier - Build Fusion API docs
+call %ANT% docs -f "%MG_OEM%\fusion\build.xml"
call %ANT% deploy -Ddeploy.home="%MG_OEM%\fusion_build" -f "%MG_OEM%\fusion\build.xml"
\ No newline at end of file
More information about the mapguide-commits
