[mapguide-commits] r7001 - trunk/Tools/Maestro/Localization
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Tue Sep 11 10:12:30 PDT 2012
Author: jng
Date: 2012-09-11 10:12:28 -0700 (Tue, 11 Sep 2012)
New Revision: 7001
Added:
   trunk/Tools/Maestro/Localization/Duplicati.Library.Utility.dll
   trunk/Tools/Maestro/Localization/LocalizationTool.exe.config
Removed:
   trunk/Tools/Maestro/Localization/ConvertResX.exe
   trunk/Tools/Maestro/Localization/Duplicati.Library.Core.dll
   trunk/Tools/Maestro/Localization/Translate.xml
   trunk/Tools/Maestro/Localization/configuration.xml
#2110: Update the Localization tool to the trunk version used by the Duplicati project (http://code.google.com/p/duplicati), with a custom patch (https://code.google.com/p/duplicati/issues/detail?id=701) to properly localize .net Framework 4.0 applications.
Deleted: trunk/Tools/Maestro/Localization/ConvertResX.exe
(Binary files differ)
Deleted: trunk/Tools/Maestro/Localization/Duplicati.Library.Core.dll
Added: trunk/Tools/Maestro/Localization/Duplicati.Library.Utility.dll
Property changes on: trunk/Tools/Maestro/Localization/Duplicati.Library.Utility.dll
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Modified: trunk/Tools/Maestro/Localization/LocalizationTool.exe
Added: trunk/Tools/Maestro/Localization/LocalizationTool.exe.config
--- trunk/Tools/Maestro/Localization/LocalizationTool.exe.config	                        (rev 0)
+++ trunk/Tools/Maestro/Localization/LocalizationTool.exe.config	2012-09-11 17:12:28 UTC (rev 7001)
@@ -0,0 +1,5 @@
+<?xml version="1.0"?>
+<configuration>
+    <configSections>
+    </configSections>
+<startup><supportedRuntime version="v4.0" sku=".NETFramework,Version=v4.0"/></startup></configuration>
Deleted: trunk/Tools/Maestro/Localization/Translate.xml
--- trunk/Tools/Maestro/Localization/Translate.xml	2012-09-11 14:00:59 UTC (rev 7000)
+++ trunk/Tools/Maestro/Localization/Translate.xml	2012-09-11 17:12:28 UTC (rev 7001)
@@ -1,715 +0,0 @@
-<root>
-<translate
-	from="OSGeo.MapGuide.Maestro.FusionEditor.ApplicationDefinitionEditor.containerEditor"
-	to="OSGeo.MapGuide.Maestro.FusionEditor.ContainerEditor"
-<translate
-	from="OSGeo.MapGuide.Maestro.FusionEditor.ApplicationDefinitionEditor.widgetEntry"
-	to="OSGeo.MapGuide.Maestro.FusionEditor.WidgetEntry"
-<translate
-	from="OSGeo.MapGuide.Maestro.FusionEditor.ApplicationDefinitionEditor.flyoutEntry"
-	to="OSGeo.MapGuide.Maestro.FusionEditor.FlyoutEditor"
-<translate
-	from="OSGeo.MapGuide.Maestro.FusionEditor.EditWidgets.widgetEditor"
-	to="OSGeo.MapGuide.Maestro.FusionEditor.WidgetEditor"
-<translate
-	from="OSGeo.MapGuide.Maestro.FusionEditor.EditWidgets.widgetEditorUI"
-	to="OSGeo.MapGuide.Maestro.FusionEditor.WidgetEditorUI"
-<translate
-	from="OSGeo.MapGuide.Maestro.FusionEditor.EditWidgets.BufferPanel"
-	to="OSGeo.MapGuide.Maestro.FusionEditor.CustomizedEditors.BufferPanel"
-<translate
-	from="OSGeo.MapGuide.Maestro.FusionEditor.EditWidgets.Buffer"
-	to="OSGeo.MapGuide.Maestro.FusionEditor.CustomizedEditors.Buffer"
-<translate
-	from="OSGeo.MapGuide.Maestro.FusionEditor.EditWidgets.ActivityIndicator"
-	to="OSGeo.MapGuide.Maestro.FusionEditor.CustomizedEditors.ActivityIndicator"
-<translate
-	from="OSGeo.MapGuide.Maestro.FusionEditor.EditWidgets.About"
-	to="OSGeo.MapGuide.Maestro.FusionEditor.CustomizedEditors.About"
-<translate
-	from="OSGeo.MapGuide.Maestro.FusionEditor.EditWidgets.CursorPosition"
-	to="OSGeo.MapGuide.Maestro.FusionEditor.CustomizedEditors.CursorPosition"
-<translate
-	from="OSGeo.MapGuide.Maestro.FusionEditor.EditWidgets.EditableScale"
-	to="OSGeo.MapGuide.Maestro.FusionEditor.CustomizedEditors.EditableScale"
-<translate
-	from="OSGeo.MapGuide.Maestro.FusionEditor.EditWidgets.ExtentHistory"
-	to="OSGeo.MapGuide.Maestro.FusionEditor.CustomizedEditors.ExtentHistory"
-<translate
-	from="OSGeo.MapGuide.Maestro.FusionEditor.EditWidgets.Help"
-	to="OSGeo.MapGuide.Maestro.FusionEditor.CustomizedEditors.Help"
-<translate
-	from="OSGeo.MapGuide.Maestro.FusionEditor.EditWidgets.InvokeScript"
-	to="OSGeo.MapGuide.Maestro.FusionEditor.CustomizedEditors.InvokeScript"
-<translate
-	from="OSGeo.MapGuide.Maestro.FusionEditor.EditWidgets.Legend"
-	to="OSGeo.MapGuide.Maestro.FusionEditor.CustomizedEditors.Legend"
-<translate
-	from="OSGeo.MapGuide.Maestro.FusionEditor.EditWidgets.MapMenu"
-	to="OSGeo.MapGuide.Maestro.FusionEditor.CustomizedEditors.MapMenu"
-<translate
-	from="OSGeo.MapGuide.Maestro.FusionEditor.EditWidgets.Measure"
-	to="OSGeo.MapGuide.Maestro.FusionEditor.CustomizedEditors.Measure"
-<translate
-	from="OSGeo.MapGuide.Maestro.FusionEditor.EditWidgets.OverviewMap"
-	to="OSGeo.MapGuide.Maestro.FusionEditor.CustomizedEditors.OverviewMap"
-<translate
-	from="OSGeo.MapGuide.Maestro.FusionEditor.EditWidgets.Print"
-	to="OSGeo.MapGuide.Maestro.FusionEditor.CustomizedEditors.Print"
-<translate
-	from="OSGeo.MapGuide.Maestro.FusionEditor.EditWidgets.SaveMap"
-	to="OSGeo.MapGuide.Maestro.FusionEditor.CustomizedEditors.SaveMap"
-<translate
-	from="OSGeo.MapGuide.Maestro.FusionEditor.EditWidgets.Select"
-	to="OSGeo.MapGuide.Maestro.FusionEditor.CustomizedEditors.Select"
-<translate
-	from="OSGeo.MapGuide.Maestro.FusionEditor.EditWidgets.SelectPolygon"
-	to="OSGeo.MapGuide.Maestro.FusionEditor.CustomizedEditors.SelectPolygon"
-<translate
-	from="OSGeo.MapGuide.Maestro.FusionEditor.EditWidgets.SelectRadius"
-	to="OSGeo.MapGuide.Maestro.FusionEditor.CustomizedEditors.SelectRadius"
-<translate
-	from="OSGeo.MapGuide.Maestro.FusionEditor.EditWidgets.SelectWithin"
-	to="OSGeo.MapGuide.Maestro.FusionEditor.CustomizedEditors.SelectWithin"
-<translate
-	from="OSGeo.MapGuide.Maestro.FusionEditor.EditWidgets.TaskPane"
-	to="OSGeo.MapGuide.Maestro.FusionEditor.CustomizedEditors.TaskPane"
-<translate
-	from="OSGeo.MapGuide.Maestro.FusionEditor.EditWidgets.ViewOptions"
-	to="OSGeo.MapGuide.Maestro.FusionEditor.CustomizedEditors.ViewOptions"
-<translate
-	from="OSGeo.MapGuide.Maestro.FusionEditor.EditWidgets.ViewSize"
-	to="OSGeo.MapGuide.Maestro.FusionEditor.CustomizedEditors.ViewSize"
-<translate
-	from="OSGeo.MapGuide.Maestro.FusionEditor.EditWidgets.Zoom"
-	to="OSGeo.MapGuide.Maestro.FusionEditor.CustomizedEditors.Zoom"
-<translate
-	from="OSGeo.MapGuide.Maestro.FusionEditor.EditWidgets.ZoomOnClick"
-	to="OSGeo.MapGuide.Maestro.FusionEditor.CustomizedEditors.ZoomOnClick"
-<translate
-	from="OSGeo.MapGuide.Maestro.FusionEditor.EditWidgets.ZoomToSelection"
-	to="OSGeo.MapGuide.Maestro.FusionEditor.CustomizedEditors.ZoomToSelection"
-<translate
-	from="OSGeo.MapGuide.Maestro.FormLogin"
-	to="OSGeo.MapGuide.Maestro.LoginForm.FormLogin"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.MapEditor.ctlLayerProperties"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.MapLayerProperties"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.MapEditor.ctlGroupProperties"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.MapLayerGroupProperties"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.LayoutEditor.commandEditor.basicCommand"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.LayoutControls.BasicCommand"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.LayoutEditor.commandEditor.flyoutItem"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.LayoutControls.FlyoutItem"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.LayoutEditor.commandEditor.searchCommand"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.LayoutControls.SearchCommand"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.LayoutEditor.commandEditor.invokeURL"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.LayoutControls.InvokeURL"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.LayoutEditor.commandEditor.targetedCommand"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.LayoutControls.TargetedCommand"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.LayoutEditor.commandEditor.printCommand"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.LayoutControls.PrintCommand"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.LayoutEditor.commandEditor.helpCommand"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.LayoutControls.HelpCommand"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.LayoutEditor.commandEditor.invokeScript"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.LayoutControls.InvokeScript"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.LayoutEditor.commandEditor"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.LayoutControls.CommandEditor"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.LayerEditor.vectorLayer"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.LayerEditorControls.VectorLayer"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.LayerEditor.rasterLayer"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.LayerEditorControls.RasterLayer"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditorArcSDE"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.ArcSDE.FeatureSourceEditorArcSDE"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditorGdal"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.Gdal.FeatureSourceEditorGdal"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditorKingMSSql"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.King.MSSql.FeatureSourceEditorKingMSSql"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditorKingOracle"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.King.Oracle.FeatureSourceEditorKingOracle"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditorMSSQLSpatial"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.MSQLSpatial.FeatureSourceEditorMSSQLSpatial"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditorMySQL"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.MySQL.FeatureSourceEditorMySQL"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditorODBC"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.ODBC.FeatureSourceEditorODBC"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditorOGR"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.OGR.FeatureSourceEditorOGR"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditorPostGIS"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.PostGIS.FeatureSourceEditorPostGIS"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditorSHP"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.SHP.FeatureSourceEditorSHP"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditorSDF"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.SDF.FeatureSourceEditorSDF"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditorWFS"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.WFS.FeatureSourceEditorWFS"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.Gdal.FeatureSourceEditorGdal.simple"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.Gdal.Simple"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.Gdal.FeatureSourceEditorGdal.composite"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.Gdal.Composite"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditorGeneric.resourceDataEditor"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.ResourceDataEditor"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.SelectDataProvider.OKButton"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.SelectDataProvider.OKBtn"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.SelectDataProvider.CancelButton"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.SelectDataProvider.CancelBtn"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.ODBC.FeatureSourceEditorODBC.dsn"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.ODBC.DSN"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.ODBC.FeatureSourceEditorODBC.managed"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.ODBC.Managed"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.ODBC.FeatureSourceEditorODBC.unmanaged"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.ODBC.Unmanaged"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.ODBC.wizard.msSQL"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.ODBC.Wizards.MsSQL"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.ODBC.FeatureSourceEditorODBC.wizard"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.ODBC.Wizard"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.ODBC.Managed.managedFileControl"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.ManagedFileControl"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.ODBC.Wizard.mySQL"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.ODBC.Wizards.MySQL"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.ODBC.Wizard.postgreSQL"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.ODBC.Wizards.PostgreSQL"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.ODBC.Wizard.informix"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.ODBC.Wizards.Informix"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.ODBC.Wizard.oracle"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.ODBC.Wizards.Oracle"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.ODBC.Wizard.oracleMS"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.ODBC.Wizards.OracleMS"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.OGR.FeatureSourceEditorOGR.custom"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.OGR.Custom"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.OGR.FeatureSourceEditorOGR.mySQL"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.OGR.MySQL"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.OGR.FeatureSourceEditorOGR.oracle"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.OGR.Oracle"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.OGR.FeatureSourceEditorOGR.odbc"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.OGR.ODBC"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.OGR.FeatureSourceEditorOGR.postGIS"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.OGR.PostGIS"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.OGR.FeatureSourceEditorOGR.managed.managedFileControl"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.OGR.FeatureSourceEditorOGR.unmanaged"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.OGR.Unmanaged"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.OGR.FeatureSourceEditorOGR.dods"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.OGR.DODS"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.OGR.FeatureSourceEditorOGR.arcSDE"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.OGR.ArcSDE"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.OGR.FeatureSourceEditorOGR.grass"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.OGR.Grass"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.OGR.FeatureSourceEditorOGR.ogdi"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.OGR.OGDI"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.OGR.FeatureSourceEditorOGR.informix"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.OGR.Informix"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.OGR.FeatureSourceEditorOGR.fme"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.OGR.FME"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.SDF.FeatureSourceEditorSDF.UnmanagedEditor"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.Filebased.Unmanaged"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.SDF.FeatureSourceEditorSDF.ManagedEditor.managedFileControl"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.SDF.FeatureSourceEditorSDF"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.Filebased.FilebasedFeatureSourceEditor"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.SHP.FeatureSourceEditorSHP.unmanaged"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.SHP.FeatureSourceEditorSHP.managed.managedFileControl"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.SHP.FeatureSourceEditorSHP"
-<translate
-	from="OSGeo.MapGuide.Maestro.FusionEditor.WidgetEditor.label4"
-	to="OSGeo.MapGuide.Maestro.FusionEditor.WidgetEditorUI.label4"
-<translate
-	from="OSGeo.MapGuide.Maestro.FusionEditor.WidgetEditor.label5"
-	to="OSGeo.MapGuide.Maestro.FusionEditor.WidgetEditorUI.label5"
-<translate
-	from="OSGeo.MapGuide.Maestro.FusionEditor.WidgetEditor.label6"
-	to="OSGeo.MapGuide.Maestro.FusionEditor.WidgetEditorUI.label6"
-<translate
-	from="OSGeo.MapGuide.Maestro.FusionEditor.WidgetEditor.label7"
-	to="OSGeo.MapGuide.Maestro.FusionEditor.WidgetEditorUI.label7"
-<translate
-	from="OSGeo.MapGuide.Maestro.FusionEditor.WidgetEditor.label8"
-	to="OSGeo.MapGuide.Maestro.FusionEditor.WidgetEditorUI.label8"
-<translate
-	from="OSGeo.MapGuide.Maestro.FusionEditor.WidgetEditor.DisabledCheck"
-	to="OSGeo.MapGuide.Maestro.FusionEditor.WidgetEditorUI.DisabledCheck"
-<translate
-	from="OSGeo.MapGuide.Maestro.PackageManager.PackageProgress"
-	to="OSGeo.MapGuide.MaestroAPI.PackageBuilder.PackageProgress"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditorBase.CoordinateSystemOverride"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.CoordinateSystemOverride"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditorGeneric.btnTest"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditorBase.btnTest"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditorGeneric.TestConnectionResult"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditorBase.TestConnectionResult"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.OGR.FeatureSourceEditorOGR.managed"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.ManageFileControl"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.Filebased.managed"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditorWMS"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.WMS.FeatureSourceEditorWMS"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.GeometryStyleEditors.AreaFeatureStyleEditor.fillStyleEditor"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.GeometryStyleEditors.FillStyleEditor"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.GeometryStyleEditors.AreaFeatureStyleEditor.lineStyleEditor"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.GeometryStyleEditors.LineStyleEditor"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.GeometryStyleEditors.LineFeatureStyleEditor.lineStyleEditor"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.GeometryStyleEditors.PointFeatureStyleEditor.fillStyleEditor"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.GeometryStyleEditors.PointFeatureStyleEditor.lineStyleEditor"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.LayerEditorControls.VectorLayer.schemaSelector"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.LayerEditorControls.SchemaSelector"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.LayerEditorControls.VectorLayer.groupBox2"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.LayerEditorControls.VectorLayer.groupViewerProperties"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.LayerEditorControls.VectorLayer.SelectAllButton.Text"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.LayerEditorControls.VectorLayer.SelectAllButton.ToolTipText"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.LayerEditorControls.VectorLayer.SelectNoneButton.Text"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.LayerEditorControls.VectorLayer.SelectNoneButton.ToolTipText"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.LayerEditorControls.VectorLayer.SelectInverseButton.Text"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.LayerEditorControls.VectorLayer.SelectInverseButton.ToolTipText"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.LayerEditorControls.RasterLayer.schemaSelector"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.LayerEditorControls.VectorLayer.scaleRangeList"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.LayerEditorControls.ScaleControls.ScaleRangeList"
-<translate
-	from="OSGeo.MapGuide.Maestro.BrowseResource"
-	to="OSGeo.MapGuide.Maestro.ResourceBrowser.BrowseResource"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.GeometryStyleEditors.LineFeatureStyleEditor.groupBox1"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.GeometryStyleEditors.LineFeatureStyleEditor.CompositeGroup"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.Filebased.FilebasedFeatureSourceEditor.managed"
-<translate
-	from="OSGeo.MapGuide.Maestro.PackageManager.PackageEditor.LoaderGroup.Text"
-	to="Reading package contents ..."
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.Filebased.FilebasedFeatureSourceEditor.SDFType"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.Filebased.FilebasedFeatureSourceEditor.LocationType"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.Filebased.Unmanaged.label2"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.SHP.FeatureSourceEditorSHP.label2"
-<translate
-	from="Unlimited"
-	to="infinite"
-<translate
-	from="Legendlabel"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.LayerEditorControls.ScaleControls.ConditionListButtons.ShowInLegend.Text"
-<translate
-	from="Featurestyle"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.LayerEditorControls.ScaleControls.ConditionListButtons.label3.Text"
-<translate
-	from="Labelstyle"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.LayerEditorControls.ScaleControls.ConditionListButtons.label4.Text"
-<translate
-<translate
-	from="There already exists a resource file with the name "{0}". Do you want to overwrite the existing file?"
-	to="There already exists a resource file with the name \"{0}\". Do you want to overwrite the existing file?"
-<translate
-	from="Download of resource "{0}" failed.\nReason: {1}\nHow do you want to continue?"
-	to="Download of file "{0}" failed.\nReason: {1}\nHow do you want to continue?"
-<translate
-	from="Delete of resource "{0}" failed.\nReason: {1}\nHow do you want to continue?"
-	to="Delete of resource \"{0}\" failed.\nReason: {1}\nHow do you want to continue?"
-<translate
-	from="The file "{0}" already exists. \nDo you want to overwrite?"
-	to="The file \"{0}\" already exists. \nDo you want to overwrite?"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.Filebased.FilebasedFeatureSourceEditor.FilePathType"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.XmlEditorControl.ValidateButton.Text"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.XmlEditorControl.ValidateButton.ToolTipText"
-<translate
-	from="OSGeo.MapGuide.Maestro.FusionEditor.ApplicationDefinitionEditor.seperatorToolStripMenuItem.Text"
-	to="OSGeo.MapGuide.Maestro.FusionEditor.ApplicationDefinitionEditor.AddWidgetSeperatorMenu.Text"
-<translate
-	from="OSGeo.MapGuide.Maestro.FusionEditor.ApplicationDefinitionEditor.submenuToolStripMenuItem.Text"
-	to="OSGeo.MapGuide.Maestro.FusionEditor.ApplicationDefinitionEditor.AddWidgetSubmenuMenu.Text"
-<translate
-	from="OSGeo.MapGuide.Maestro.FusionEditor.ApplicationDefinitionEditor.widgetToolStripMenuItem.Text"
-	to="OSGeo.MapGuide.Maestro.FusionEditor.ApplicationDefinitionEditor.AddWidgetEntryMenu.Text"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceExtensions.EditExtensions.featureSourceExtension"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceExtensions.FeatureSourceExtension"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceExtensions.FeatureSourceExtension.join"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceExtensions.Join"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceExtensions.FeatureSourceExtension.extension"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceExtensions.Extension"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceExtensions.FeatureSourceExtension.key"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceExtensions.Key"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceExtensions.FeatureSourceExtension.calculated"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceExtensions.Calculated"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.Filebased.FilebasedFeatureSourceEditor.ManagedEditor.managedFileControl"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.LayerEditorControls.Scalecontrols.EditorTemplateForm"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.LayerEditorControls.ScaleControls.EditorTemplateForm"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.LayerEditorControls.ScaleControls.ConditionListButtons.AddRuleButton.ToolTipText"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.LayerEditorControls.ScaleControls.ConditionListButtons.AddRuleButton.ToolTip"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.LayerEditorControls.ScaleControls.ConditionListButtons.CreateThemeButton.ToolTipText"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.LayerEditorControls.ScaleControls.ConditionListButtons.CreateThemeButton.ToolTip"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FiniteDisplayScales.RemoveScaleButton.ToolTipText"
-	to="OSGeo.MapGuide.Maestro.ResourceEditors.FiniteDisplayScales.RemoveScaleButton.ToolTipText"
-<translate
-	from="OSGeo.MapGuide.Maestro.ResourceEditors.FilebasedFeatureSourceEditor.LocationType"
-<translate
-	from=""
-	to=""
-</root>
\ No newline at end of file
Modified: trunk/Tools/Maestro/Localization/configuration.xml
--- trunk/Tools/Maestro/Localization/configuration.xml	2012-09-11 14:00:59 UTC (rev 7000)
+++ trunk/Tools/Maestro/Localization/configuration.xml	2012-09-11 17:12:28 UTC (rev 7001)
@@ -1,20 +1,25 @@
 <root>
-	<configuration name="OSGeo.MapGuide">
+	<configuration name="Maestro">
 		<assembly name="Maestro" folder="Maestro" namespace="Maestro" />
 		<assembly name="Maestro.AddIn.ExtendedObjectModels" folder="Maestro.AddIn.ExtendedObjectModels" namespace="Maestro.AddIn.ExtendedObjectModels" />
+        <assembly name="Maestro.AddIn.Scripting" folder="Maestro.AddIn.Scripting" namespace="Maestro.AddIn.Scripting" />
+        <assembly name="Maestro.AddInManager" folder="Maestro.AddInManager" namespace="Maestro.AddInAddInManager" />
 		<assembly name="Maestro.Base" folder="Maestro.Base" namespace="Maestro.Base" />
 		<assembly name="Maestro.Editors" folder="Maestro.Editors" namespace="Maestro.Editors" />
 		<assembly name="Maestro.Login" folder="Maestro.Login" namespace="Maestro.Login" />
+        <assembly name="Maestro.MapViewer" folder="Maestro.MapViewer" namespace="Maestro.MapViewer" />
 		<assembly name="Maestro.Packaging" folder="Maestro.Packaging" namespace="Maestro.Packaging" />
 		<assembly name="Maestro.Shared.UI" folder="Maestro.Shared.UI" namespace="Maestro.Shared.UI" />
 		<assembly name="MaestroFsPreview" folder="MaestroFsPreview" namespace="MaestroFsPreview" />
 		<assembly name="MgCooker" folder="MgCooker" namespace="MgCooker" />
 		<assembly name="OSGeo.MapGuide.MaestroAPI" folder="OSGeo.MapGuide.MaestroAPI" namespace="OSGeo.MapGuide.MaestroAPI" />
+        <assembly name="RtMapInspector" folder="RtMapInspector" namespace="RtMapInspector" />
-		<!-- <keyfile>..\MaestroAPI\Maestroapi.key</keyfile> -->
+		<keyfile>..\Properties\Maestroapi.key</keyfile>
 		<versionassembly>..\out\Release\Maestro.exe</versionassembly>
 		<sourcefolder>..</sourcefolder>
 		<outputfolder>compiled</outputfolder>
 		<productname>Maestro</productname>
+        <frameworkVersion>4.0</frameworkVersion>
 	</configuration>
 </root>
More information about the mapguide-commits mailing list
