[mapguide-commits] r7006 - branches/2.4/MgDev
svn_mapguide at osgeo.org
Wed Sep 12 09:18:18 PDT 2012
Author: jng
Date: 2012-09-12 09:18:17 -0700 (Wed, 12 Sep 2012)
New Revision: 7006
branches/2.4/MgDev/build.bat
branches/2.4/MgDev/build64.bat
branches/2.4/MgDev/setenvironment.bat
branches/2.4/MgDev/setenvironment64.bat
#2114: Build the .net intellisense files as part of the main build process
Modified: branches/2.4/MgDev/build.bat
--- branches/2.4/MgDev/build.bat 2012-09-12 14:51:41 UTC (rev 7005)
+++ branches/2.4/MgDev/build.bat 2012-09-12 16:18:17 UTC (rev 7006)
@@ -388,7 +388,8 @@
echo [install]: Copy dlls into .net samples
%XCOPY% "%MG_OUTPUT_WEB%\www\mapviewernet\bin\*.dll" "%MG_OUTPUT_WEB%\www\dotnetsamples\bin" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
%XCOPY% "%MG_OUTPUT_WEB%\www\mapviewernet\bin\*.dll" "%MG_OUTPUT_WEB%\www\dotnetviewersample\bin" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+echo [build]: .net intellisense files
+DoxyTransform.exe dotnet "%MG_DOC_XML%" "%MG_OUTPUT_WEB%\www\mapviewernet\bin"
goto quit
:error
Modified: branches/2.4/MgDev/build64.bat
--- branches/2.4/MgDev/build64.bat 2012-09-12 14:51:41 UTC (rev 7005)
+++ branches/2.4/MgDev/build64.bat 2012-09-12 16:18:17 UTC (rev 7006)
@@ -420,7 +420,8 @@
goto quit
:error
Modified: branches/2.4/MgDev/setenvironment.bat
--- branches/2.4/MgDev/setenvironment.bat 2012-09-12 14:51:41 UTC (rev 7005)
+++ branches/2.4/MgDev/setenvironment.bat 2012-09-12 16:18:17 UTC (rev 7006)
@@ -36,6 +36,7 @@
@echo off
SET MG_FUSION=%MG_OEM%\Fusion
SET MG_DOC=%MG_DEV%\Doc
+SET MG_DOC_XML=%MG_DOC%\mgopensource_xml
SET MG_DOC_OUTPUT=%MG_DOC%\MgOpensource_WebAPIReference
SET MG_DOC_DEVGUIDE_SAMPLES=%MG_DOC%\samples\
SET MG_BUILD_TEMP=%MG_DEV%\BuildTemp
@@ -55,13 +56,13 @@
rem running
rem ==================================================
-IF "%JAVA_HOME%" == "" SET JAVA_HOME=C:\Program Files\Java\jdk1.6.0_21
+IF "%JAVA_HOME%" == "" SET JAVA_HOME=C:\Program Files\Java\jdk1.6.0_31
IF "%DOXYGEN%" == "" SET DOXYGEN=%MG_DEV%\BuildTools\doxygen
-IF "%GNUWIN32%" == "" SET GNUWIN32=C:\Program Files\GnuWin32\bin
+IF "%GNUWIN32%" == "" SET GNUWIN32=C:\Program Files (x86)\GnuWin32\bin
IF "%SEVENZ%" == "" SET SEVENZ=%MG_DEV%\BuildTools\WebTools\7-Zip
-IF "%ANT_HOME%" == "" SET ANT_HOME=%MG_DEV%\BuildTools\apache-ant-1.7.1
+IF "%ANT_HOME%" == "" SET ANT_HOME=C:\apache-ant-1.8.3
-SET PATH=%PATH%;%DOXYGEN%;%GNUWIN32%;%SEVENZ%;%ANT_HOME%\bin
+SET PATH=%PATH%;%DOXYGEN%;%GNUWIN32%;%SEVENZ%;%ANT_HOME%\bin;%MG_DEV%\BuildTools\DoxyTransform
rem MSBuild Settings
Modified: branches/2.4/MgDev/setenvironment64.bat
--- branches/2.4/MgDev/setenvironment64.bat 2012-09-12 14:51:41 UTC (rev 7005)
+++ branches/2.4/MgDev/setenvironment64.bat 2012-09-12 16:18:17 UTC (rev 7006)
@@ -43,6 +43,7 @@
SET MG_UNIT_TEST=%MG_DEV%\UnitTest
@@ -64,13 +65,13 @@
rem running
-IF "%JAVA_HOME%" == "" SET JAVA_HOME=C:\Program Files\Java\jdk1.5.0_18
-IF "%DOXYGEN%" == "" SET DOXYGEN=%MG_DEV%\BuildTools\doxygen
+IF "%DOXYGEN%" == "" SET DOXYGEN=C:\Program Files\doxygen\bin
@@ -78,8 +79,8 @@
rem If the NUMBER_OF_PROCESSORS environment variable is wrong for any reason. Change this value.
rem Multi core builds seem to be broken
-rem SET CPU_CORES=%NUMBER_OF_PROCESSORS%
-SET CPU_CORES=1
+SET CPU_CORES=%NUMBER_OF_PROCESSORS%
+rem SET CPU_CORES=1
rem Uncomment the line below to enable msbuild logging
rem SET MSBUILD_LOG=/l:FileLogger,Microsoft.Build.Engine;logfile=Build.log;verbosity=diagnostic
More information about the mapguide-commits
