[mapguide-commits] r7021 - in branches/2.4/MgDev/Desktop: MapViewer MapViewer.Desktop
svn_mapguide at osgeo.org
Mon Sep 17 07:29:22 PDT 2012
Author: jng
Date: 2012-09-17 07:29:22 -0700 (Mon, 17 Sep 2012)
New Revision: 7021
branches/2.4/MgDev/Desktop/MapViewer.Desktop/MapViewer.Desktop.Net40.csproj
branches/2.4/MgDev/Desktop/MapViewer/BaseInteractionComponents.cs
branches/2.4/MgDev/Desktop/MapViewer/MapViewer.Net40.csproj
branches/2.4/MgDev/Desktop/MapViewer/MgDefaultToolbar.cs
branches/2.4/MgDev/Desktop/MapViewer/MgLegendControlPresenter.cs
branches/2.4/MgDev/Desktop/MapViewer/MgMapViewer.cs
branches/2.4/MgDev/Desktop/MapViewer/MgQueryControlImpl.cs
branches/2.4/MgDev/Desktop/MapViewer/Util.cs
#2118: Update VS2010 projects and unify/fix the WKT utility methods.
Modified: branches/2.4/MgDev/Desktop/MapViewer/BaseInteractionComponents.cs
--- branches/2.4/MgDev/Desktop/MapViewer/BaseInteractionComponents.cs 2012-09-17 13:56:57 UTC (rev 7020)
+++ branches/2.4/MgDev/Desktop/MapViewer/BaseInteractionComponents.cs 2012-09-17 14:29:22 UTC (rev 7021)
@@ -3,6 +3,7 @@
using System.Text;
using System.ComponentModel;
using System.Windows.Forms;
+using System.Globalization;
namespace OSGeo.MapGuide.Viewer
@@ -329,10 +330,7 @@
- static string MakeWktCircle(double x, double y, double r)
- return "CURVEPOLYGON ((" + (x - r) + " " + y + " (CIRCULARARCSEGMENT (" + x + " " + (y - r) + ", " + (x + r) + " " + y + "), CIRCULARARCSEGMENT (" + x + " " + (y + r) + ", " + (x - r) + " " + y + "))))"; //NOXLATE
public override void Invoke()
@@ -342,7 +340,7 @@
if (_wktRw == null)
_wktRw = new MgWktReaderWriter();
- MgGeometry geom = _wktRw.Read(MakeWktCircle(x, y, r));
+ MgGeometry geom = _wktRw.Read(Util.MakeWktCircle(x, y, r));
viewer.SelectByGeometry(geom);
Modified: branches/2.4/MgDev/Desktop/MapViewer/MapViewer.Net40.csproj
--- branches/2.4/MgDev/Desktop/MapViewer/MapViewer.Net40.csproj 2012-09-17 13:56:57 UTC (rev 7020)
+++ branches/2.4/MgDev/Desktop/MapViewer/MapViewer.Net40.csproj 2012-09-17 14:29:22 UTC (rev 7021)
@@ -219,6 +219,7 @@
<DesignTime>True</DesignTime>
<DependentUpon>Resources.resx</DependentUpon>
</Compile>
+ <Compile Include="Strings.Designer.cs" />
<Compile Include="Tasks\MgTaskPaneStub.cs">
<SubType>UserControl</SubType>
</Compile>
@@ -270,6 +271,7 @@
<Generator>ResXFileCodeGenerator</Generator>
<LastGenOutput>Resources.Designer.cs</LastGenOutput>
</EmbeddedResource>
+ <EmbeddedResource Include="Strings.resx" />
<EmbeddedResource Include="Tasks\MgTaskPaneStub.resx">
<DependentUpon>MgTaskPaneStub.cs</DependentUpon>
</EmbeddedResource>
Modified: branches/2.4/MgDev/Desktop/MapViewer/MgDefaultToolbar.cs
--- branches/2.4/MgDev/Desktop/MapViewer/MgDefaultToolbar.cs 2012-09-17 13:56:57 UTC (rev 7020)
+++ branches/2.4/MgDev/Desktop/MapViewer/MgDefaultToolbar.cs 2012-09-17 14:29:22 UTC (rev 7021)
@@ -258,7 +258,7 @@
_viewer.DigitizeCircle((x, y, r) =>
_viewer.SelectByGeometry(geom);
@@ -362,16 +362,6 @@
UpdateButtonCheckedState();
- static string MakeWktPolygon(double x1, double y1, double x2, double y2)
- return "POLYGON((" + x1 + " " + y1 + ", " + x2 + " " + y1 + ", " + x2 + " " + y2 + ", " + x1 + " " + y2 + ", " + x1 + " " + y1 + "))"; //NOXLATE
/// <summary>
Modified: branches/2.4/MgDev/Desktop/MapViewer/MgLegendControlPresenter.cs
--- branches/2.4/MgDev/Desktop/MapViewer/MgLegendControlPresenter.cs 2012-09-17 13:56:57 UTC (rev 7020)
+++ branches/2.4/MgDev/Desktop/MapViewer/MgLegendControlPresenter.cs 2012-09-17 14:29:22 UTC (rev 7021)
@@ -11,6 +11,7 @@
using System.Xml;
using System.IO;
using System.Diagnostics;
+ using System.Globalization;
interface ILegendView
@@ -992,10 +993,10 @@
if (bHasMin)
- double minVal = double.Parse(cat.MinScale);
+ double minVal = double.Parse(cat.MinScale, CultureInfo.InvariantCulture);
if (bHasMax) //bHasMin = true, bHasMax = true
- double maxVal = double.Parse(cat.MaxScale);
+ double maxVal = double.Parse(cat.MaxScale, CultureInfo.InvariantCulture);
if (scale >= minVal && scale < maxVal)
bApplicable = true;
@@ -1009,7 +1010,7 @@
if (bHasMax) //bHasMin = false, bHasMax = true
if (scale < maxVal)
bApplicable = true;
Modified: branches/2.4/MgDev/Desktop/MapViewer/MgMapViewer.cs
--- branches/2.4/MgDev/Desktop/MapViewer/MgMapViewer.cs 2012-09-17 13:56:57 UTC (rev 7020)
+++ branches/2.4/MgDev/Desktop/MapViewer/MgMapViewer.cs 2012-09-17 14:29:22 UTC (rev 7021)
@@ -12,6 +12,7 @@
using System.Xml;
using System.Collections.Specialized;
using System.Collections.ObjectModel;
@@ -144,7 +145,7 @@
if (_debugCenter == null)
_debugCenter = new MgPropertyCollection();
- var center = _wktRW.Read("POINT (" + _map.ViewCenter.Coordinate.X + " " + _map.ViewCenter.Coordinate.Y + ")"); //NOXLATE
+ var center = _wktRW.Read("POINT (" + _map.ViewCenter.Coordinate.X.ToString(CultureInfo.InvariantCulture) + " " + _map.ViewCenter.Coordinate.Y.ToString(CultureInfo.InvariantCulture) + ")"); //NOXLATE
var agf = _agfRW.Write(center);
if (!_debugCenter.Contains("Geometry")) //NOXLATE
@@ -2084,13 +2085,6 @@
- private static string MakeWktPolygon(double x1, double y1, double x2, double y2)
private int? _lastTooltipX;
private int? _lastTooltipY;
@@ -2535,7 +2529,7 @@
var dist = _mapMeasure.GetDistance(coord1, coord2);
- MgGeometry geom = _wktRW.Read(MakeWktPolygon(mapPt1.X, mapPt1.Y, mapPt2.X, mapPt2.Y));
+ MgGeometry geom = _wktRW.Read(Util.MakeWktPolygon(mapPt1.X, mapPt1.Y, mapPt2.X, mapPt2.Y));
SelectByGeometry(geom, 1);
Modified: branches/2.4/MgDev/Desktop/MapViewer/MgQueryControlImpl.cs
--- branches/2.4/MgDev/Desktop/MapViewer/MgQueryControlImpl.cs 2012-09-17 13:56:57 UTC (rev 7020)
+++ branches/2.4/MgDev/Desktop/MapViewer/MgQueryControlImpl.cs 2012-09-17 14:29:22 UTC (rev 7021)
@@ -73,11 +73,6 @@
private MgGeometry _filterGeometry;
private void btnRectangle_Click(object sender, EventArgs e)
@@ -85,7 +80,7 @@
_viewer.DigitizeRectangle((llx, lly, urx, ury) =>
ClearFilterGeometry();
- _filterGeometry = _wktRw.Read(MakeWktPolygon(llx, lly, urx, ury));
+ _filterGeometry = _wktRw.Read(Util.MakeWktPolygon(llx, lly, urx, ury));
lblSpatialFilterGeomSet.Visible = true;
Modified: branches/2.4/MgDev/Desktop/MapViewer/Util.cs
--- branches/2.4/MgDev/Desktop/MapViewer/Util.cs 2012-09-17 13:56:57 UTC (rev 7020)
+++ branches/2.4/MgDev/Desktop/MapViewer/Util.cs 2012-09-17 14:29:22 UTC (rev 7021)
@@ -8,6 +8,20 @@
internal static class Util
+ public static string MakeWktCircle(double x, double y, double r)
+ return "CURVEPOLYGON ((" + (x - r).ToString(CultureInfo.InvariantCulture) + " " + y.ToString(CultureInfo.InvariantCulture) + " (CIRCULARARCSEGMENT (" + x.ToString(CultureInfo.InvariantCulture) + " " + (y - r).ToString(CultureInfo.InvariantCulture) + ", " + (x + r).ToString(CultureInfo.InvariantCulture) + " " + y.ToString(CultureInfo.InvariantCulture) + "), CIRCULARARCSEGMENT (" + x.ToString(CultureInfo.InvariantCulture) + " " + (y + r).ToString(CultureInfo.InvariantCulture) + ", " + (x - r).ToString(CultureInfo.InvariantCulture) + " " + y.ToString(CultureInfo.InvariantCulture) + "))))"; //NOXLATE
+ public static string MakeWktPolygon(double x1, double y1, double x2, double y2)
+ string x1str = x1.ToString(CultureInfo.InvariantCulture);
+ string y1str = y1.ToString(CultureInfo.InvariantCulture);
+ string x2str = x2.ToString(CultureInfo.InvariantCulture);
+ string y2str = y2.ToString(CultureInfo.InvariantCulture);
+ return "POLYGON((" + x1str + " " + y1str + ", " + x2str + " " + y1str + ", " + x2str + " " + y2str + ", " + x1str + " " + y2str + ", " + x1str + " " + y1str + "))"; //NOXLATE
public static string ToHtmlColor(Color color)
return String.Format("{0:X2}{1:X2}{2:X2}", color.R, color.G, color.B); //NOXLATE
Modified: branches/2.4/MgDev/Desktop/MapViewer.Desktop/MapViewer.Desktop.Net40.csproj
--- branches/2.4/MgDev/Desktop/MapViewer.Desktop/MapViewer.Desktop.Net40.csproj 2012-09-17 13:56:57 UTC (rev 7020)
+++ branches/2.4/MgDev/Desktop/MapViewer.Desktop/MapViewer.Desktop.Net40.csproj 2012-09-17 14:29:22 UTC (rev 7021)
@@ -80,6 +80,7 @@
<Compile Include="MgDesktopMapViewerProvider.cs" />
<Compile Include="MgdTransientMapState.cs" />
<Compile Include="Properties\AssemblyInfo.cs" />
</ItemGroup>
<ItemGroup>
<BootstrapperPackage Include="Microsoft.Net.Client.3.5">
@@ -104,6 +105,9 @@
<Name>MapViewer.Net40</Name>
</ProjectReference>
</ItemGroup>
+ <ItemGroup>
+ </ItemGroup>
<Import Project="$(MSBuildToolsPath)\Microsoft.CSharp.targets" />
<!-- To modify your build process, add your task inside one of the targets below and uncomment it.
Other similar extension points exist, see Microsoft.Common.targets.
More information about the mapguide-commits
