[mapguide-commits] r7041 - in trunk/Tools/Maestro: Maestro.Editors Maestro.Editors/LayerDefinition/Vector/Scales Maestro.Editors/LayerDefinition/Vector/StyleEditors Maestro.Editors/Properties Maestro.Editors/Resources OSGeo.MapGuide.MaestroAPI OSGeo.MapGuide.MaestroAPI/ObjectModels
svn_mapguide at osgeo.org
Fri Sep 21 07:45:34 PDT 2012
Author: jng
Date: 2012-09-21 07:45:33 -0700 (Fri, 21 Sep 2012)
New Revision: 7041
Added:
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/ExplodeThemeDialog.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/ExplodeThemeDialog.cs
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/ExplodeThemeDialog.resx
trunk/Tools/Maestro/Maestro.Editors/Resources/arrow-split.png
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/ConditionListButtons.cs
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/ConditionListButtons.designer.cs
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/ConditionListButtons.resx
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/StyleEditors/LineFeatureStyleEditor.cs
trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj
trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx
trunk/Tools/Maestro/Maestro.Editors/Strings.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/Strings.resx
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/LayerInterfaces.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/VectorLayerDefinitionImpl.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs
#2127: Add support for "exploding" themes into individual filtered layers. Each layer filter is derived from the filter defined in the respective rule from the exploded theme. This also required some additions and hierarchical modifications to the Layer Definition interfaces.
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/ConditionListButtons.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/ConditionListButtons.cs 2012-09-19 17:49:04 UTC (rev 7040)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/ConditionListButtons.cs 2012-09-21 14:45:33 UTC (rev 7041)
@@ -30,6 +30,7 @@
using OSGeo.MapGuide.ObjectModels;
using Maestro.Editors.LayerDefinition.Vector.Thematics;
using Maestro.Editors.LayerDefinition.Vector.StyleEditors;
+using Maestro.Shared.UI;
namespace Maestro.Editors.LayerDefinition.Vector.Scales
@@ -120,7 +121,8 @@
var cm2 = m_comp as ICompositeTypeStyle2;
//Check if we're working with a 1.3.0 schema
- ShowInLegend.Enabled = (ar2 != null || pt2 != null || ln2 != null || cm2 != null);
+ ShowInLegend.Enabled = (ar2 != null || pt2 != null || ln2 != null || cm2 != null);
+ btnExplodeTheme.Enabled = (m_comp == null);
public void AddRule()
@@ -301,5 +303,41 @@
m_owner.FlagDirty();
+ private void btnExplodeTheme_Click(object sender, EventArgs e)
+ var ed = m_owner.EditorService;
+ var layer = ed.GetEditedResource() as ILayerDefinition;
+ var style = m_point as IVectorStyle ?? m_line as IVectorStyle ?? m_area as IVectorStyle;
+ var diag = new ExplodeThemeDialog(ed, m_parent, style, layer);
+ if (diag.ShowDialog() == DialogResult.OK)
+ var options = new ExplodeThemeOptions()
+ ActiveStyle = style,
+ FolderId = diag.CreateInFolder,
+ Layer = layer,
+ LayerNameFormat = diag.LayerNameFormat,
+ LayerPrefix = diag.LayerPrefix,
+ Range = m_parent
+ var progress = new ProgressDialog();
+ var worker = new BackgroundWorker();
+ worker.WorkerReportsProgress = true;
+ progress.RunOperationAsync(null, ExplodeThemeWorker, options);
+ private static object ExplodeThemeWorker(BackgroundWorker worker, DoWorkEventArgs e, params object[] args)
+ var options = (ExplodeThemeOptions)args[0];
+ LengthyOperationProgressCallBack cb = (s, cbArgs) =>
+ worker.ReportProgress(cbArgs.Progress, cbArgs.StatusMessage);
+ Utility.ExplodeThemeIntoFilteredLayers(options, cb);
+ return true;
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/ConditionListButtons.designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/ConditionListButtons.designer.cs 2012-09-19 17:49:04 UTC (rev 7040)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/ConditionListButtons.designer.cs 2012-09-21 14:45:33 UTC (rev 7041)
@@ -40,6 +40,7 @@
this.MoveRuleDownButton = new System.Windows.Forms.Button();
this.MoveRuleUpButton = new System.Windows.Forms.Button();
this.panel1 = new System.Windows.Forms.Panel();
+ this.btnExplodeTheme = new System.Windows.Forms.Button();
this.ShowInLegend = new System.Windows.Forms.CheckBox();
this.toolTips = new System.Windows.Forms.ToolTip(this.components);
this.panel1.SuspendLayout();
@@ -50,8 +51,6 @@
resources.ApplyResources(this.conditionList, "conditionList");
this.conditionList.BorderStyle = System.Windows.Forms.BorderStyle.Fixed3D;
this.conditionList.Name = "conditionList";
- this.conditionList.Owner = null;
- this.conditionList.SelectedItem = null;
this.conditionList.ItemChanged += new System.EventHandler(this.conditionList_ItemChanged);
// label1
@@ -115,6 +114,7 @@
// panel1
+ this.panel1.Controls.Add(this.btnExplodeTheme);
this.panel1.Controls.Add(this.ShowInLegend);
this.panel1.Controls.Add(this.MoveRuleUpButton);
this.panel1.Controls.Add(this.MoveRuleDownButton);
@@ -127,6 +127,15 @@
resources.ApplyResources(this.panel1, "panel1");
this.panel1.Name = "panel1";
+ // btnExplodeTheme
+ this.btnExplodeTheme.Image = global::Maestro.Editors.Properties.Resources.arrow_split;
+ resources.ApplyResources(this.btnExplodeTheme, "btnExplodeTheme");
+ this.btnExplodeTheme.Name = "btnExplodeTheme";
+ this.toolTips.SetToolTip(this.btnExplodeTheme, resources.GetString("btnExplodeTheme.ToolTip"));
+ this.btnExplodeTheme.UseVisualStyleBackColor = true;
+ this.btnExplodeTheme.Click += new System.EventHandler(this.btnExplodeTheme_Click);
// ShowInLegend
resources.ApplyResources(this.ShowInLegend, "ShowInLegend");
@@ -164,5 +173,6 @@
private System.Windows.Forms.Panel panel1;
private System.Windows.Forms.CheckBox ShowInLegend;
private System.Windows.Forms.ToolTip toolTips;
+ private System.Windows.Forms.Button btnExplodeTheme;
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/ConditionListButtons.resx
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/ConditionListButtons.resx 2012-09-19 17:49:04 UTC (rev 7040)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/ConditionListButtons.resx 2012-09-21 14:45:33 UTC (rev 7041)
@@ -112,20 +112,20 @@
<value>2.0</value>
</resheader>
<resheader name="reader">
- <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</resheader>
<resheader name="writer">
- <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</resheader>
- <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
<data name="conditionList.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
<value>Top, Bottom, Left</value>
</data>
- <assembly alias="mscorlib" name="mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <assembly alias="mscorlib" name="mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
<data name="conditionList.AutoScroll" type="System.Boolean, mscorlib">
<value>True</value>
</data>
- <assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+ <assembly alias="System.Drawing" name="System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
<data name="conditionList.Location" type="System.Drawing.Point, System.Drawing">
<value>0, 24</value>
</data>
@@ -139,7 +139,7 @@
<value>conditionList</value>
</data>
<data name=">>conditionList.Type" xml:space="preserve">
- <value>Maestro.Editors.LayerDefinition.Vector.Scales.ConditionList, Maestro.Editors, Version=3.0.0.5728, Culture=neutral, PublicKeyToken=null</value>
+ <value>Maestro.Editors.LayerDefinition.Vector.Scales.ConditionList, Maestro.Editors, Version=5.0.0.6640, Culture=neutral, PublicKeyToken=f526c48929fda856</value>
</data>
<data name=">>conditionList.Parent" xml:space="preserve">
<value>$this</value>
@@ -166,13 +166,13 @@
<value>label1</value>
</data>
<data name=">>label1.Type" xml:space="preserve">
- <value>System.Windows.Forms.Label, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.Label, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>label1.Parent" xml:space="preserve">
<value>panel1</value>
</data>
<data name=">>label1.ZOrder" xml:space="preserve">
- <value>8</value>
+ <value>9</value>
</data>
<data name="label3.AutoSize" type="System.Boolean, mscorlib">
<value>True</value>
@@ -193,13 +193,13 @@
<value>label3</value>
</data>
<data name=">>label3.Type" xml:space="preserve">
</data>
<data name=">>label3.Parent" xml:space="preserve">
</data>
<data name=">>label3.ZOrder" xml:space="preserve">
- <value>7</value>
+ <value>8</value>
</data>
<data name="label4.AutoSize" type="System.Boolean, mscorlib">
<value>True</value>
@@ -220,17 +220,14 @@
<value>label4</value>
</data>
<data name=">>label4.Type" xml:space="preserve">
</data>
<data name=">>label4.Parent" xml:space="preserve">
</data>
<data name=">>label4.ZOrder" xml:space="preserve">
- <value>6</value>
+ <value>7</value>
</data>
- <metadata name="toolTips.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>17, 17</value>
- </metadata>
<data name="AddRuleButton.Location" type="System.Drawing.Point, System.Drawing">
<value>0, 0</value>
</data>
@@ -240,6 +237,9 @@
<data name="AddRuleButton.TabIndex" type="System.Int32, mscorlib">
<value>4</value>
</data>
+ <metadata name="toolTips.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>17, 17</value>
+ </metadata>
<data name="AddRuleButton.ToolTip" xml:space="preserve">
<value>Add a new rule</value>
</data>
@@ -247,19 +247,19 @@
<value>AddRuleButton</value>
</data>
<data name=">>AddRuleButton.Type" xml:space="preserve">
- <value>System.Windows.Forms.Button, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.Button, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>AddRuleButton.Parent" xml:space="preserve">
</data>
<data name=">>AddRuleButton.ZOrder" xml:space="preserve">
- <value>5</value>
+ <value>6</value>
</data>
<data name="CopyRuleButton.Enabled" type="System.Boolean, mscorlib">
<value>False</value>
</data>
<data name="CopyRuleButton.Location" type="System.Drawing.Point, System.Drawing">
- <value>138, 0</value>
+ <value>144, 0</value>
</data>
<data name="CopyRuleButton.Size" type="System.Drawing.Size, System.Drawing">
<value>32, 24</value>
@@ -274,13 +274,13 @@
<value>CopyRuleButton</value>
</data>
<data name=">>CopyRuleButton.Type" xml:space="preserve">
</data>
<data name=">>CopyRuleButton.Parent" xml:space="preserve">
</data>
<data name=">>CopyRuleButton.ZOrder" xml:space="preserve">
- <value>4</value>
+ <value>5</value>
</data>
<data name="CreateThemeButton.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
@@ -299,7 +299,7 @@
</value>
</data>
<data name="CreateThemeButton.Location" type="System.Drawing.Point, System.Drawing">
- <value>106, 0</value>
+ <value>80, 0</value>
</data>
<data name="CreateThemeButton.Size" type="System.Drawing.Size, System.Drawing">
@@ -314,13 +314,13 @@
<value>CreateThemeButton</value>
</data>
<data name=">>CreateThemeButton.Type" xml:space="preserve">
</data>
<data name=">>CreateThemeButton.Parent" xml:space="preserve">
</data>
<data name=">>CreateThemeButton.ZOrder" xml:space="preserve">
- <value>3</value>
+ <value>4</value>
</data>
<data name="MoveRuleDownButton.Enabled" type="System.Boolean, mscorlib">
@@ -341,13 +341,13 @@
<value>MoveRuleDownButton</value>
</data>
<data name=">>MoveRuleDownButton.Type" xml:space="preserve">
</data>
<data name=">>MoveRuleDownButton.Parent" xml:space="preserve">
</data>
<data name=">>MoveRuleDownButton.ZOrder" xml:space="preserve">
- <value>2</value>
+ <value>3</value>
</data>
<data name="MoveRuleUpButton.Enabled" type="System.Boolean, mscorlib">
@@ -368,19 +368,46 @@
<value>MoveRuleUpButton</value>
</data>
<data name=">>MoveRuleUpButton.Type" xml:space="preserve">
</data>
<data name=">>MoveRuleUpButton.Parent" xml:space="preserve">
</data>
<data name=">>MoveRuleUpButton.ZOrder" xml:space="preserve">
- <value>1</value>
+ <value>2</value>
</data>
+ <data name="btnExplodeTheme.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ <value>NoControl</value>
+ </data>
+ <data name="btnExplodeTheme.Location" type="System.Drawing.Point, System.Drawing">
+ <value>112, 0</value>
+ </data>
+ <data name="btnExplodeTheme.Size" type="System.Drawing.Size, System.Drawing">
+ <value>32, 24</value>
+ </data>
+ <data name="btnExplodeTheme.TabIndex" type="System.Int32, mscorlib">
+ <value>10</value>
+ </data>
+ <data name="btnExplodeTheme.ToolTip" xml:space="preserve">
+ <value>Explode this theme</value>
+ </data>
+ <data name=">>btnExplodeTheme.Name" xml:space="preserve">
+ <value>btnExplodeTheme</value>
+ </data>
+ <data name=">>btnExplodeTheme.Type" xml:space="preserve">
+ </data>
+ <data name=">>btnExplodeTheme.Parent" xml:space="preserve">
+ <value>panel1</value>
+ </data>
+ <data name=">>btnExplodeTheme.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
<data name="ShowInLegend.AutoSize" type="System.Boolean, mscorlib">
<value>True</value>
</data>
<data name="ShowInLegend.Location" type="System.Drawing.Point, System.Drawing">
- <value>176, 6</value>
+ <value>194, 7</value>
</data>
<data name="ShowInLegend.Size" type="System.Drawing.Size, System.Drawing">
<value>104, 17</value>
@@ -391,9 +418,6 @@
<data name="ShowInLegend.Text" xml:space="preserve">
<value>Show In Legend</value>
</data>
- </metadata>
<data name="ShowInLegend.ToolTip" xml:space="preserve">
<value>Check to show in legend (only avalible in LayerDefinition 1.3.0 and above). This can toggle legend visibility without removing your defined style rules</value>
</data>
@@ -401,13 +425,13 @@
<value>ShowInLegend</value>
</data>
<data name=">>ShowInLegend.Type" xml:space="preserve">
- <value>System.Windows.Forms.CheckBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.CheckBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>ShowInLegend.Parent" xml:space="preserve">
</data>
<data name=">>ShowInLegend.ZOrder" xml:space="preserve">
- <value>0</value>
+ <value>1</value>
</data>
<data name="panel1.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
<value>Top</value>
@@ -425,7 +449,7 @@
</data>
<data name=">>panel1.Type" xml:space="preserve">
- <value>System.Windows.Forms.Panel, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.Panel, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>panel1.Parent" xml:space="preserve">
@@ -433,7 +457,7 @@
<data name=">>panel1.ZOrder" xml:space="preserve">
<value>1</value>
</data>
- <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+ <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
<value>True</value>
</metadata>
<data name="$this.Size" type="System.Drawing.Size, System.Drawing">
@@ -443,12 +467,12 @@
<value>toolTips</value>
</data>
<data name=">>toolTips.Type" xml:space="preserve">
- <value>System.Windows.Forms.ToolTip, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.ToolTip, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>$this.Name" xml:space="preserve">
<value>ConditionListButtons</value>
</data>
<data name=">>$this.Type" xml:space="preserve">
- <value>System.Windows.Forms.UserControl, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.UserControl, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
</root>
\ No newline at end of file
Added: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/ExplodeThemeDialog.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/ExplodeThemeDialog.Designer.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/ExplodeThemeDialog.Designer.cs 2012-09-21 14:45:33 UTC (rev 7041)
@@ -0,0 +1,183 @@
+namespace Maestro.Editors.LayerDefinition.Vector.Scales
+ partial class ExplodeThemeDialog
+ /// <summary>
+ /// Required designer variable.
+ /// </summary>
+ private System.ComponentModel.IContainer components = null;
+ /// <summary>
+ /// Clean up any resources being used.
+ /// </summary>
+ /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+ protected override void Dispose(bool disposing)
+ if (disposing && (components != null))
+ components.Dispose();
+ base.Dispose(disposing);
+ #region Windows Form Designer generated code
+ /// <summary>
+ /// Required method for Designer support - do not modify
+ /// the contents of this method with the code editor.
+ /// </summary>
+ private void InitializeComponent()
+ System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(ExplodeThemeDialog));
+ this.label1 = new System.Windows.Forms.Label();
+ this.label2 = new System.Windows.Forms.Label();
+ this.txtFolder = new System.Windows.Forms.TextBox();
+ this.btnBrowse = new System.Windows.Forms.Button();
+ this.label3 = new System.Windows.Forms.Label();
+ this.txtLayersCreate = new System.Windows.Forms.TextBox();
+ this.label4 = new System.Windows.Forms.Label();
+ this.txtLayerNameFormat = new System.Windows.Forms.TextBox();
+ this.label5 = new System.Windows.Forms.Label();
+ this.lstLayerNameExamples = new System.Windows.Forms.ListBox();
+ this.label6 = new System.Windows.Forms.Label();
+ this.btnCreate = new System.Windows.Forms.Button();
+ this.btnCancel = new System.Windows.Forms.Button();
+ this.txtLayerPrefix = new System.Windows.Forms.TextBox();
+ this.label7 = new System.Windows.Forms.Label();
+ this.SuspendLayout();
+ // label1
+ resources.ApplyResources(this.label1, "label1");
+ this.label1.Name = "label1";
+ // label2
+ resources.ApplyResources(this.label2, "label2");
+ this.label2.Name = "label2";
+ // txtFolder
+ resources.ApplyResources(this.txtFolder, "txtFolder");
+ this.txtFolder.Name = "txtFolder";
+ this.txtFolder.ReadOnly = true;
+ this.txtFolder.TextChanged += new System.EventHandler(this.txtFolder_TextChanged);
+ // btnBrowse
+ resources.ApplyResources(this.btnBrowse, "btnBrowse");
+ this.btnBrowse.Name = "btnBrowse";
+ this.btnBrowse.UseVisualStyleBackColor = true;
+ this.btnBrowse.Click += new System.EventHandler(this.btnBrowse_Click);
+ // label3
+ resources.ApplyResources(this.label3, "label3");
+ this.label3.Name = "label3";
+ // txtLayersCreate
+ resources.ApplyResources(this.txtLayersCreate, "txtLayersCreate");
+ this.txtLayersCreate.Name = "txtLayersCreate";
+ this.txtLayersCreate.ReadOnly = true;
+ // label4
+ resources.ApplyResources(this.label4, "label4");
+ this.label4.Name = "label4";
+ // txtLayerNameFormat
+ resources.ApplyResources(this.txtLayerNameFormat, "txtLayerNameFormat");
+ this.txtLayerNameFormat.Name = "txtLayerNameFormat";
+ this.txtLayerNameFormat.TextChanged += new System.EventHandler(this.txtLayerNameFormat_TextChanged);
+ // label5
+ resources.ApplyResources(this.label5, "label5");
+ this.label5.Name = "label5";
+ // lstLayerNameExamples
+ resources.ApplyResources(this.lstLayerNameExamples, "lstLayerNameExamples");
+ this.lstLayerNameExamples.FormattingEnabled = true;
+ this.lstLayerNameExamples.Name = "lstLayerNameExamples";
+ // label6
+ resources.ApplyResources(this.label6, "label6");
+ this.label6.Name = "label6";
+ // btnCreate
+ resources.ApplyResources(this.btnCreate, "btnCreate");
+ this.btnCreate.Name = "btnCreate";
+ this.btnCreate.UseVisualStyleBackColor = true;
+ this.btnCreate.Click += new System.EventHandler(this.btnCreate_Click);
+ // btnCancel
+ resources.ApplyResources(this.btnCancel, "btnCancel");
+ this.btnCancel.DialogResult = System.Windows.Forms.DialogResult.Cancel;
+ this.btnCancel.Name = "btnCancel";
+ this.btnCancel.UseVisualStyleBackColor = true;
+ this.btnCancel.Click += new System.EventHandler(this.btnCancel_Click);
+ // txtLayerPrefix
+ resources.ApplyResources(this.txtLayerPrefix, "txtLayerPrefix");
+ this.txtLayerPrefix.Name = "txtLayerPrefix";
+ this.txtLayerPrefix.TextChanged += new System.EventHandler(this.txtLayerPrefix_TextChanged);
+ // label7
+ resources.ApplyResources(this.label7, "label7");
+ this.label7.Name = "label7";
+ // ExplodeThemeDialog
+ this.AcceptButton = this.btnCreate;
+ this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.None;
+ this.CancelButton = this.btnCancel;
+ resources.ApplyResources(this, "$this");
+ this.ControlBox = false;
+ this.Controls.Add(this.txtLayerPrefix);
+ this.Controls.Add(this.label7);
+ this.Controls.Add(this.btnCancel);
+ this.Controls.Add(this.btnCreate);
+ this.Controls.Add(this.label6);
+ this.Controls.Add(this.lstLayerNameExamples);
+ this.Controls.Add(this.label5);
+ this.Controls.Add(this.txtLayerNameFormat);
+ this.Controls.Add(this.label4);
+ this.Controls.Add(this.txtLayersCreate);
+ this.Controls.Add(this.label3);
+ this.Controls.Add(this.btnBrowse);
+ this.Controls.Add(this.txtFolder);
+ this.Controls.Add(this.label2);
+ this.Controls.Add(this.label1);
+ this.Name = "ExplodeThemeDialog";
+ this.ResumeLayout(false);
+ this.PerformLayout();
+ #endregion
+ private System.Windows.Forms.Label label1;
+ private System.Windows.Forms.Label label2;
+ private System.Windows.Forms.TextBox txtFolder;
+ private System.Windows.Forms.Button btnBrowse;
+ private System.Windows.Forms.Label label3;
+ private System.Windows.Forms.TextBox txtLayersCreate;
+ private System.Windows.Forms.Label label4;
+ private System.Windows.Forms.TextBox txtLayerNameFormat;
+ private System.Windows.Forms.Label label5;
+ private System.Windows.Forms.ListBox lstLayerNameExamples;
+ private System.Windows.Forms.Label label6;
+ private System.Windows.Forms.Button btnCreate;
+ private System.Windows.Forms.Button btnCancel;
+ private System.Windows.Forms.TextBox txtLayerPrefix;
+ private System.Windows.Forms.Label label7;
Added: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/ExplodeThemeDialog.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/ExplodeThemeDialog.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/ExplodeThemeDialog.cs 2012-09-21 14:45:33 UTC (rev 7041)
@@ -0,0 +1,159 @@
+#region Disclaimer / License
+// Copyright (C) 2012, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using Maestro.Editors.Generic;
+using OSGeo.MapGuide.MaestroAPI;
+using OSGeo.MapGuide.MaestroAPI.Resource;
+using OSGeo.MapGuide.ObjectModels.LayerDefinition;
+using System;
+using System.Collections.Generic;
+using System.ComponentModel;
+using System.Data;
+using System.Drawing;
+using System.Globalization;
+using System.Linq;
+using System.Text;
+using System.Windows.Forms;
+ internal partial class ExplodeThemeDialog : Form
+ private ExplodeThemeDialog()
+ InitializeComponent();
+ private IVectorScaleRange _parentRange;
+ private IVectorStyle _style;
+ private ILayerDefinition _parentLayer;
+ private IEditorService _editor;
+ public ExplodeThemeDialog(IEditorService editor, IVectorScaleRange parentRange, IVectorStyle style, ILayerDefinition parentLayer)
+ : this()
+ if (style.StyleType == StyleType.Composite)
+ throw new NotSupportedException(Strings.ErrorExplodingCompositeStyleNotSupported);
+ _editor = editor;
+ _style = style;
+ _parentRange = parentRange;
+ _parentLayer = parentLayer;
+ txtLayersCreate.Text = style.RuleCount.ToString(CultureInfo.InvariantCulture);
+ txtLayerNameFormat.Text = "{0} - {1} - {2}"; //NOXLATE
+ EvaluateStates();
+ if (!_editor.IsNew)
+ txtLayerPrefix.Text = ResourceIdentifier.GetName(_editor.ResourceID);
+ else
+ txtLayerPrefix.Text = "Theme"; //NOXLATE
+ public string CreateInFolder
+ get { return txtFolder.Text; }
+ public string LayerNameFormat
+ get { return txtLayerNameFormat.Text; }
+ public string LayerPrefix
+ get { return txtLayerPrefix.Text; }
+ private void btnBrowse_Click(object sender, EventArgs e)
+ using (var picker = new ResourcePicker(_editor.ResourceService, ResourcePickerMode.OpenFolder))
+ if (picker.ShowDialog() == System.Windows.Forms.DialogResult.OK)
+ txtFolder.Text = picker.ResourceID;
+ private void btnCancel_Click(object sender, EventArgs e)
+ this.DialogResult = System.Windows.Forms.DialogResult.Cancel;
+ private void btnCreate_Click(object sender, EventArgs e)
+ this.DialogResult = System.Windows.Forms.DialogResult.OK;
+ private bool EvaluateStates()
+ btnCreate.Enabled = IsValidToPreview() && ResourceIdentifier.IsFolderResource(txtFolder.Text);
+ return btnCreate.Enabled;
+ private bool IsValidToPreview()
+ return !string.IsNullOrEmpty(txtLayerPrefix.Text) && txtLayerNameFormat.Text.Contains("{0}") && txtLayerNameFormat.Text.Contains("{1}") && txtLayerNameFormat.Text.Contains("{2}"); //NOXLATE
+ private void txtLayerNameFormat_TextChanged(object sender, EventArgs e)
+ GeneratePreviews();
+ private void GeneratePreviews()
+ lstLayerNameExamples.Items.Clear();
+ if (IsValidToPreview())
+ string layerPrefix = txtLayerPrefix.Text;
+ int rules = Math.Min(3, _style.RuleCount);
+ string scaleRange = Utility.GetScaleRangeStr(_parentRange);
+ for (int i = 0; i < rules; i++)
+ var rule = _style.GetRuleAt(i);
+ string name = Utility.GenerateLayerName(txtLayerNameFormat.Text, layerPrefix, scaleRange, i, rule);
+ lstLayerNameExamples.Items.Add(name);
+ EvaluateStates();
+ else
+ lstLayerNameExamples.Items.Add(Strings.InvalidLayerNameFormat);
+ EvaluateStates();
+ private void txtFolder_TextChanged(object sender, EventArgs e)
+ EvaluateStates();
+ private void txtLayerPrefix_TextChanged(object sender, EventArgs e)
+ EvaluateStates();
Added: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/ExplodeThemeDialog.resx
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/ExplodeThemeDialog.resx (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/ExplodeThemeDialog.resx 2012-09-21 14:45:33 UTC (rev 7041)
@@ -0,0 +1,530 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+ Microsoft ResX Schema
+ Version 2.0
+ The primary goals of this format is to allow a simple XML format
+ that is mostly human readable. The generation and parsing of the
+ various data types are done through the TypeConverter classes
+ associated with the data types.
+ Example:
+ ... ado.net/XML headers & schema ...
+ <resheader name="resmimetype">text/microsoft-resx</resheader>
+ <resheader name="version">2.0</resheader>
+ <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+ <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+ <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+ <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+ <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>[base64 mime encoded serialized .NET Framework object]</value>
+ </data>
+ <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+ <comment>This is a comment</comment>
+ </data>
+ There are any number of "resheader" rows that contain simple
+ name/value pairs.
+ Each data row contains a name, and value. The row also contains a
+ type or mimetype. Type corresponds to a .NET class that support
+ text/value conversion through the TypeConverter architecture.
+ Classes that don't support this are serialized and stored with the
+ mimetype set.
+ The mimetype is used for serialized objects, and tells the
+ ResXResourceReader how to depersist the object. This is currently not
+ extensible. For a given mimetype the value must be set accordingly:
+ Note - application/x-microsoft.net.object.binary.base64 is the format
+ that the ResXResourceWriter will generate, however the reader can
+ read any of the formats listed below.
+ mimetype: application/x-microsoft.net.object.binary.base64
+ value : The object must be serialized with
+ : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+ : and then encoded with base64 encoding.
+ mimetype: application/x-microsoft.net.object.soap.base64
+ : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+ mimetype: application/x-microsoft.net.object.bytearray.base64
+ value : The object must be serialized into a byte array
+ : using a System.ComponentModel.TypeConverter
+ <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+ <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+ <xsd:element name="root" msdata:IsDataSet="true">
+ <xsd:complexType>
+ <xsd:choice maxOccurs="unbounded">
+ <xsd:element name="metadata">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" />
+ </xsd:sequence>
+ <xsd:attribute name="name" use="required" type="xsd:string" />
+ <xsd:attribute name="type" type="xsd:string" />
+ <xsd:attribute name="mimetype" type="xsd:string" />
+ <xsd:attribute ref="xml:space" />
+ </xsd:complexType>
+ </xsd:element>
+ <xsd:element name="assembly">
+ <xsd:complexType>
+ <xsd:attribute name="alias" type="xsd:string" />
+ <xsd:attribute name="name" type="xsd:string" />
+ </xsd:element>
+ <xsd:element name="data">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+ <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+ <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+ <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+ </xsd:element>
+ <xsd:element name="resheader">
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" />
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ <value>text/microsoft-resx</value>
+ </resheader>
+ <value>2.0</value>
+ </resheader>
+ </resheader>
+ </resheader>
+ <data name="label1.Location" type="System.Drawing.Point, System.Drawing">
+ <value>12, 9</value>
+ </data>
+ <data name="label1.Size" type="System.Drawing.Size, System.Drawing">
+ <value>522, 60</value>
+ </data>
+ <data name="label1.TabIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ <data name="label1.Text" xml:space="preserve">
+ <value>Exploding this theme will create a filtered sub-layer for each rule in this theme, filtered on the filter of the respective rule.
+WARNING: This will overwrite any layers of the same name in the folder you choose!
+</value>
+ </data>
+ <data name=">>label1.Name" xml:space="preserve">
+ <value>label1</value>
+ </data>
+ <data name=">>label1.Type" xml:space="preserve">
+ </data>
+ <data name=">>label1.Parent" xml:space="preserve">
+ <value>$this</value>
+ </data>
+ <data name=">>label1.ZOrder" xml:space="preserve">
+ <value>14</value>
+ </data>
+ <data name="label2.AutoSize" type="System.Boolean, mscorlib">
+ <value>True</value>
+ </data>
+ <data name="label2.Location" type="System.Drawing.Point, System.Drawing">
+ <value>12, 114</value>
+ </data>
+ <data name="label2.Size" type="System.Drawing.Size, System.Drawing">
+ <value>178, 13</value>
+ </data>
+ <data name="label2.TabIndex" type="System.Int32, mscorlib">
+ <value>1</value>
+ </data>
+ <data name="label2.Text" xml:space="preserve">
+ <value>Create Layer Definitions in this folder</value>
+ </data>
+ <data name=">>label2.Name" xml:space="preserve">
+ <value>label2</value>
+ </data>
+ <data name=">>label2.Type" xml:space="preserve">
+ </data>
+ <data name=">>label2.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label2.ZOrder" xml:space="preserve">
+ <value>13</value>
+ </data>
+ <data name="txtFolder.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Top, Left, Right</value>
+ </data>
+ <data name="txtFolder.Location" type="System.Drawing.Point, System.Drawing">
+ <value>202, 111</value>
+ </data>
+ <data name="txtFolder.Size" type="System.Drawing.Size, System.Drawing">
+ <value>299, 20</value>
+ </data>
+ <data name="txtFolder.TabIndex" type="System.Int32, mscorlib">
+ <value>2</value>
+ </data>
+ <data name=">>txtFolder.Name" xml:space="preserve">
+ <value>txtFolder</value>
+ </data>
+ <data name=">>txtFolder.Type" xml:space="preserve">
+ <value>System.Windows.Forms.TextBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>txtFolder.Parent" xml:space="preserve">
+ </data>
+ <data name=">>txtFolder.ZOrder" xml:space="preserve">
+ <value>12</value>
+ </data>
+ <data name="btnBrowse.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Top, Right</value>
+ </data>
+ <data name="btnBrowse.Location" type="System.Drawing.Point, System.Drawing">
+ <value>507, 109</value>
+ </data>
+ <data name="btnBrowse.Size" type="System.Drawing.Size, System.Drawing">
+ <value>27, 23</value>
+ </data>
+ <data name="btnBrowse.TabIndex" type="System.Int32, mscorlib">
+ <value>3</value>
+ </data>
+ <data name="btnBrowse.Text" xml:space="preserve">
+ <value>...</value>
+ </data>
+ <data name=">>btnBrowse.Name" xml:space="preserve">
+ <value>btnBrowse</value>
+ </data>
+ <data name=">>btnBrowse.Type" xml:space="preserve">
+ </data>
+ <data name=">>btnBrowse.Parent" xml:space="preserve">
+ </data>
+ <data name=">>btnBrowse.ZOrder" xml:space="preserve">
+ <value>11</value>
+ </data>
+ <data name="label3.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="label3.Location" type="System.Drawing.Point, System.Drawing">
+ <value>12, 85</value>
+ </data>
+ <data name="label3.Size" type="System.Drawing.Size, System.Drawing">
+ <value>131, 13</value>
+ </data>
+ <data name="label3.TabIndex" type="System.Int32, mscorlib">
+ <value>4</value>
+ </data>
+ <data name="label3.Text" xml:space="preserve">
+ <value>Number of layers to create</value>
+ </data>
+ <data name=">>label3.Name" xml:space="preserve">
+ <value>label3</value>
+ </data>
+ <data name=">>label3.Type" xml:space="preserve">
+ </data>
+ <data name=">>label3.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label3.ZOrder" xml:space="preserve">
+ <value>10</value>
+ </data>
+ <data name="txtLayersCreate.Location" type="System.Drawing.Point, System.Drawing">
+ <value>202, 82</value>
+ </data>
+ <data name="txtLayersCreate.Size" type="System.Drawing.Size, System.Drawing">
+ <value>35, 20</value>
+ </data>
+ <data name="txtLayersCreate.TabIndex" type="System.Int32, mscorlib">
+ <value>5</value>
+ </data>
+ <data name=">>txtLayersCreate.Name" xml:space="preserve">
+ <value>txtLayersCreate</value>
+ </data>
+ <data name=">>txtLayersCreate.Type" xml:space="preserve">
+ </data>
+ <data name=">>txtLayersCreate.Parent" xml:space="preserve">
+ </data>
+ <data name=">>txtLayersCreate.ZOrder" xml:space="preserve">
+ <value>9</value>
+ </data>
+ <data name="label4.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="label4.Location" type="System.Drawing.Point, System.Drawing">
+ <value>12, 167</value>
+ </data>
+ <data name="label4.Size" type="System.Drawing.Size, System.Drawing">
+ <value>99, 13</value>
+ </data>
+ <data name="label4.TabIndex" type="System.Int32, mscorlib">
+ <value>6</value>
+ </data>
+ <data name="label4.Text" xml:space="preserve">
+ <value>Layer Name Format</value>
+ </data>
+ <data name=">>label4.Name" xml:space="preserve">
+ <value>label4</value>
+ </data>
+ <data name=">>label4.Type" xml:space="preserve">
+ </data>
+ <data name=">>label4.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label4.ZOrder" xml:space="preserve">
+ <value>8</value>
+ </data>
+ <data name="txtLayerNameFormat.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ </data>
+ <data name="txtLayerNameFormat.Location" type="System.Drawing.Point, System.Drawing">
+ <value>202, 164</value>
+ </data>
+ <data name="txtLayerNameFormat.Size" type="System.Drawing.Size, System.Drawing">
+ <value>332, 20</value>
+ </data>
+ <data name="txtLayerNameFormat.TabIndex" type="System.Int32, mscorlib">
+ <value>7</value>
+ </data>
+ <data name=">>txtLayerNameFormat.Name" xml:space="preserve">
+ <value>txtLayerNameFormat</value>
+ </data>
+ <data name=">>txtLayerNameFormat.Type" xml:space="preserve">
+ </data>
+ <data name=">>txtLayerNameFormat.Parent" xml:space="preserve">
+ </data>
+ <data name=">>txtLayerNameFormat.ZOrder" xml:space="preserve">
+ <value>7</value>
+ </data>
+ <data name="label5.Location" type="System.Drawing.Point, System.Drawing">
+ <value>202, 187</value>
+ </data>
+ <data name="label5.Size" type="System.Drawing.Size, System.Drawing">
+ <value>299, 42</value>
+ </data>
+ <data name="label5.TabIndex" type="System.Int32, mscorlib">
+ <value>8</value>
+ </data>
+ <data name="label5.Text" xml:space="preserve">
+ <value>{0} - Layer Name
+{1} - Scale Range
+{2} - Legend Label</value>
+ </data>
+ <data name=">>label5.Name" xml:space="preserve">
+ <value>label5</value>
+ </data>
+ <data name=">>label5.Type" xml:space="preserve">
+ </data>
+ <data name=">>label5.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label5.ZOrder" xml:space="preserve">
+ <value>6</value>
+ </data>
+ <data name="lstLayerNameExamples.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Top, Bottom, Left, Right</value>
+ </data>
+ <data name="lstLayerNameExamples.Location" type="System.Drawing.Point, System.Drawing">
+ <value>202, 239</value>
+ </data>
+ <data name="lstLayerNameExamples.Size" type="System.Drawing.Size, System.Drawing">
+ <value>332, 95</value>
+ </data>
+ <data name="lstLayerNameExamples.TabIndex" type="System.Int32, mscorlib">
+ <value>9</value>
+ </data>
+ <data name=">>lstLayerNameExamples.Name" xml:space="preserve">
+ <value>lstLayerNameExamples</value>
+ </data>
+ <data name=">>lstLayerNameExamples.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ListBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>lstLayerNameExamples.Parent" xml:space="preserve">
+ </data>
+ <data name=">>lstLayerNameExamples.ZOrder" xml:space="preserve">
+ <value>5</value>
+ </data>
+ <data name="label6.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="label6.Location" type="System.Drawing.Point, System.Drawing">
+ <value>12, 239</value>
+ </data>
+ <data name="label6.Size" type="System.Drawing.Size, System.Drawing">
+ <value>174, 13</value>
+ </data>
+ <data name="label6.TabIndex" type="System.Int32, mscorlib">
+ <value>10</value>
+ </data>
+ <data name="label6.Text" xml:space="preserve">
+ <value>Examples of generated layer names</value>
+ </data>
+ <data name=">>label6.Name" xml:space="preserve">
+ <value>label6</value>
+ </data>
+ <data name=">>label6.Type" xml:space="preserve">
+ </data>
+ <data name=">>label6.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label6.ZOrder" xml:space="preserve">
+ <value>4</value>
+ </data>
+ <data name="btnCreate.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Bottom, Right</value>
+ </data>
+ <data name="btnCreate.Enabled" type="System.Boolean, mscorlib">
+ <value>False</value>
+ </data>
+ <data name="btnCreate.Location" type="System.Drawing.Point, System.Drawing">
+ <value>378, 355</value>
+ </data>
+ <data name="btnCreate.Size" type="System.Drawing.Size, System.Drawing">
+ <value>75, 23</value>
+ </data>
+ <data name="btnCreate.TabIndex" type="System.Int32, mscorlib">
+ <value>11</value>
+ </data>
+ <data name="btnCreate.Text" xml:space="preserve">
+ <value>Create</value>
+ </data>
+ <data name=">>btnCreate.Name" xml:space="preserve">
+ <value>btnCreate</value>
+ </data>
+ <data name=">>btnCreate.Type" xml:space="preserve">
+ </data>
+ <data name=">>btnCreate.Parent" xml:space="preserve">
+ </data>
+ <data name=">>btnCreate.ZOrder" xml:space="preserve">
+ <value>3</value>
+ </data>
+ <data name="btnCancel.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ </data>
+ <data name="btnCancel.Location" type="System.Drawing.Point, System.Drawing">
+ <value>459, 355</value>
+ </data>
+ <data name="btnCancel.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="btnCancel.TabIndex" type="System.Int32, mscorlib">
+ <value>12</value>
+ </data>
+ <data name="btnCancel.Text" xml:space="preserve">
+ <value>Cancel</value>
+ </data>
+ <data name=">>btnCancel.Name" xml:space="preserve">
+ <value>btnCancel</value>
+ </data>
+ <data name=">>btnCancel.Type" xml:space="preserve">
+ </data>
+ <data name=">>btnCancel.Parent" xml:space="preserve">
+ </data>
+ <data name=">>btnCancel.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
+ <data name="txtLayerPrefix.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ </data>
+ <data name="txtLayerPrefix.Location" type="System.Drawing.Point, System.Drawing">
+ <value>202, 138</value>
+ </data>
+ <data name="txtLayerPrefix.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="txtLayerPrefix.TabIndex" type="System.Int32, mscorlib">
+ <value>14</value>
+ </data>
+ <data name=">>txtLayerPrefix.Name" xml:space="preserve">
+ <value>txtLayerPrefix</value>
+ </data>
+ <data name=">>txtLayerPrefix.Type" xml:space="preserve">
+ </data>
+ <data name=">>txtLayerPrefix.Parent" xml:space="preserve">
+ </data>
+ <data name=">>txtLayerPrefix.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name="label7.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="label7.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ </data>
+ <data name="label7.Location" type="System.Drawing.Point, System.Drawing">
+ <value>12, 141</value>
+ </data>
+ <data name="label7.Size" type="System.Drawing.Size, System.Drawing">
+ <value>93, 13</value>
+ </data>
+ <data name="label7.TabIndex" type="System.Int32, mscorlib">
+ <value>13</value>
+ </data>
+ <data name="label7.Text" xml:space="preserve">
+ <value>Layer Name Prefix</value>
+ </data>
+ <data name=">>label7.Name" xml:space="preserve">
+ <value>label7</value>
+ </data>
+ <data name=">>label7.Type" xml:space="preserve">
+ </data>
+ <data name=">>label7.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label7.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ </metadata>
+ <data name="$this.ClientSize" type="System.Drawing.Size, System.Drawing">
+ <value>549, 390</value>
+ </data>
+ <data name="$this.Text" xml:space="preserve">
+ <value>Explode Theme</value>
+ </data>
+ <data name=">>$this.Name" xml:space="preserve">
+ <value>ExplodeThemeDialog</value>
+ </data>
+ <data name=">>$this.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Form, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+</root>
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/StyleEditors/LineFeatureStyleEditor.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/StyleEditors/LineFeatureStyleEditor.cs 2012-09-19 17:49:04 UTC (rev 7040)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/StyleEditors/LineFeatureStyleEditor.cs 2012-09-21 14:45:33 UTC (rev 7041)
@@ -645,11 +645,6 @@
private void compositeLines_CheckedChanged(object sender, System.EventArgs e)
- if (compositePanel.Visible && !compositeLines.Checked)
- this.AutoScrollMinSize = new Size(this.AutoScrollMinSize.Width, this.AutoScrollMinSize.Height - compositePanel.Height);
- else if (!compositePanel.Visible && compositeLines.Checked)
- this.AutoScrollMinSize = new Size(this.AutoScrollMinSize.Width, this.AutoScrollMinSize.Height + compositePanel.Height);
compositePanel.Visible = compositeLines.Checked;
if (m_inUpdate)
Modified: trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj
--- trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj 2012-09-19 17:49:04 UTC (rev 7040)
+++ trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj 2012-09-21 14:45:33 UTC (rev 7041)
@@ -771,6 +771,12 @@
<Compile Include="LayerDefinition\Vector\Scales\EditorTemplateForm.designer.cs">
<DependentUpon>EditorTemplateForm.cs</DependentUpon>
</Compile>
+ <Compile Include="LayerDefinition\Vector\Scales\ExplodeThemeDialog.cs">
+ <SubType>Form</SubType>
+ </Compile>
+ <Compile Include="LayerDefinition\Vector\Scales\ExplodeThemeDialog.Designer.cs">
+ <DependentUpon>ExplodeThemeDialog.cs</DependentUpon>
+ </Compile>
<Compile Include="LayerDefinition\Vector\Scales\ItemStyle.cs">
<SubType>UserControl</SubType>
</Compile>
@@ -1664,6 +1670,9 @@
<EmbeddedResource Include="LayerDefinition\Vector\Scales\EditorTemplateForm.resx">
</EmbeddedResource>
+ <EmbeddedResource Include="LayerDefinition\Vector\Scales\ExplodeThemeDialog.resx">
+ </EmbeddedResource>
<EmbeddedResource Include="LayerDefinition\Vector\Scales\ItemStyle.resx">
<DependentUpon>ItemStyle.cs</DependentUpon>
</EmbeddedResource>
@@ -2413,6 +2422,7 @@
<Content Include="OdbcDriverMap.xml">
<CopyToOutputDirectory>Always</CopyToOutputDirectory>
</Content>
+ <None Include="Resources\arrow-split.png" />
<None Include="Resources\folder-horizontal-open.png" />
<None Include="Resources\water.png" />
<None Include="Resources\magnifier-left.png" />
Modified: trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs 2012-09-19 17:49:04 UTC (rev 7040)
+++ trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs 2012-09-21 14:45:33 UTC (rev 7041)
@@ -213,6 +213,16 @@
/// <summary>
/// Looks up a localized resource of type System.Drawing.Bitmap.
/// </summary>
+ internal static System.Drawing.Bitmap arrow_split {
+ get {
+ object obj = ResourceManager.GetObject("arrow-split", resourceCulture);
+ return ((System.Drawing.Bitmap)(obj));
+ /// <summary>
+ /// Looks up a localized resource of type System.Drawing.Bitmap.
+ /// </summary>
internal static System.Drawing.Bitmap block {
get {
object obj = ResourceManager.GetObject("block", resourceCulture);
Modified: trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx
--- trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx 2012-09-19 17:49:04 UTC (rev 7040)
+++ trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx 2012-09-21 14:45:33 UTC (rev 7041)
@@ -118,11 +118,27 @@
</resheader>
- <data name="icon_print_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_help_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIIAAJmZmdra2rS2uLe5u7W1vbq6uv///wAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQB
- BwAGACwAAAAAEAAQAAAIYgANCBQAoKBBAAUEKhQIIIDDhwEKJFxooCFEhwUiUrR4MaNGhRcfShwpcMDB
- ggMuAmAYkqPDlQRbCoAIwKTLlwgfFsR58KXOmyp/hqT586TRokAN6rTZEsDMggJKGh1A0UBAADs=
+ R0lGODlhEAAQAIezAPLy8o2cqvj4+JKfq8LK0pWirvf395mlsf///8bT36m1wbO+yay4xPHw76q2waKv
+ vKe1wo+cqK+7xvT5+5yotLTAy+rz+LK+yOfr7qWxvJqpt/r8/d/k6Ku3w8fS3pSirrC9ybC8yODq84qT
+ oaezvvn8/bG8yc7V26CsuLa/yJOgrN3i5/L09ff4+Ke1xNzh5cPP25als93j6JWir6y7yfj7/JqnsrzF
+ zu71+fP2+NXb4d7o8crV4JGfrLbCzbC8x8PQ3Pb8/L/GzLG6w8HK0rfDzpGdqZShrsnV4J2qtZ6qtZyo
+ s5SgrLC9ysHIztPg7MHK1dvm8b/L17fAyb7J1L7K1Ky5xtjc4Kizvaa0wcXR3bfF0IyXpY6cqYybp/r9
+ /aSwvLbBzIyZp6u5x6q4xp6ruK25xLvG0ery+Ku3wouVo8XO1qi0wIuUosnV4Z2ruJKhr7bDz7bDzrbC
+ zsrQ1uLq86q0vezz+Jentq+3wbW+x/T3+bTC0J2pttLW2tvg5Z+ruZyntMzX4bTBzbvH0qexuqayvsbR
+ 3J+suM/U2cXS3bfE0IyXpuDk6ay1vtXZ3vX3+brG0bS/yq26x5uotcLN2IuWo7S8xtLY3c3Y4uHl6rzI
+ 1LW9xPX19Jqns5uns622v+ft8+fs8tnk76e0wbC7yJGeqp6qtsvW4Oz1+IuTo/T7+4+dqs/T2MfU4aGu
+ urO8xbzI06Cvvv///wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAACzACwAAAAAEAAQAAAI/wBnzerUQoDBgwIMKGwgEJKrBIqA
+ 8KFBxsWYSRAgEJgFwA2STB7i6NAkY4WkLD/MwCEAIIEgHrFY1EGDQ8SGGw8clEkBQAuqRRxGhXpxQtST
+ PSjAeJoCAMahOTm+YJCFJ9GOCVj6zNADQEolQlDWVDAR40qUGkoo9bgEYFMVKnJAhHjz6M4qOqwodBkC
+ YEukMz4WPMBkYUIrRp9siMkDYFCRMAsYZCiRyo8qCgcKcAEFoEmFCxIUvPrTKNCHzCosOQJgpZSENCQA
+ weKU5EiBAaZG2AFAikEHNoiWIAjiRA0TIxEGFAKgQYEDQ6cOIEAgpM2ACF4GbCQSoLv37wO0CwpsAKC8
+ +fPlBQYEADs=
</value>
</data>
<data name="blueprints" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -141,124 +157,155 @@
Ab7ReT9BDLTyAAAAAElFTkSuQmCC
</value>
</data>
- <data name="application-import" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_clearselect_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABx0lEQVQ4T6XUPWgaYRgH8Afc
- LIJjySiCOOrkopOCDoKKDiV0jW0phVJoh1BwcXdyUgRxEAQHEYyIuly0EZJKk+LgpPj9gYKC4te/7yMI
- BQ0Y8sKPO47//+55D+4IAL0Gud3uPY/HoxLeCVdn4qyKXC7XwWWpVHqq1+uo1Wp4fPyDh4d73N39wu1t
- CZJUFscKyuXfqFT+4uZGehLdS3I4HAcfc7kcstksMpkM0uk0UqkUkskkEokE4vE4YrEYotEoIpEIQqEQ
- ZDLZFY9+4BXv4kVLdL1ktVrJ6XSyD9vtVoxXQT6fR7vdxmazeRZnuUMmk4ksFgvZ7fZPq9VqPzYvSZLQ
- 6/WwXC5P4ix3yGg0esRNvjLeJ+v3++AnVKtVjEYjzOfzI4vFAjab7TPpdLofpza+Xq/BodlshslkcoSv
- m83mL6RWq9+rVKqfLBAIgLVaLfCIxWIRjUYDw+HwyHQ6BU9Nosg3IYPB8G08HsPv92O32yEcDu+30Ol0
- TuIsd0ir1ZJer2ffB4MBgsEgfD4fCoUCms3mszjLHdJoNAfXPGq32z0LZ0X3muRy+Z5CofAqlUr/S3CH
- /ltycf5WuDgTZ9+86lPm38A/lieNoGpgVUMAAAAASUVORK5CYII=
+ R0lGODlhEAAQAIZRAICAgMDAwPn5+fz8/Oru8OPhzubr7e3x8vHw5tPIoObY1b6/w9XYz8XJyOjn0bu2
+ p6OmqLe2qcPDyefm0Obl0PH09dfa09XV1bu+wePp6/Dr1tTGxdvd4PXp59/h5d7e3tXV2eDdzOPcwcW7
+ l7Sun8S6l7y+v8DP09/Gwsa/qtzf4fDs2czOzP39/dLIoaOqqr2/wPj4+tnc39XZ0eXjz/j5+bSmpLyo
+ o5WVldrd3+Xkz9XOz7GvsLiwsM7Pz/7+/unk0NDJp/Dr2ZqbmNbY0Orq07nNy5OZmNzf4sXHydzf49TJ
+ oM3Ny9O2sr+1lenu79ne3////wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQB
+ AABRACwAAAAAEAAQAAAInwCjCBxIcKAKIggCRFHIcOFAGQw0iChIEcmMFS6CKATAkaPDHBaEJCiRQiCA
+ Ig4oABCohAWQJSMeMNk4QUeBlRg8xIjghMQHASZpFAgBgAOIH1BODLnQwmFHABB2KGhg5IWPARQFSuiA
+ 4sYRGFgFKozSccGGJjZMAC0IoMKBJzh49EhSo+DGAwQMrBybFUDeDCuzOiTrcbDgwwQbKs4aEAA7
</value>
</data>
- <data name="layer--plus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="table--arrow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACHUlEQVQ4T6XSXUhTcRjH8Qel
- QrwJDZWlUhBR2ZzpbV7UZQRGIERhrRdXahhS1lVedRFEKdVyg1XUaiCczVmbL80CG2svzgtHuMxUTp7T
- 2nbmNs2yq9P/d1xkXtigwYf/nvF8z84ZI1mW6X9QzTUXlDN1zPEsYRcNUfXVV3DEP5UYiKV/BqPp5cB6
- sINdNGhpX/sQNERTy6N8fMmVDeyiQUtVVwbhZCT5wzsb/TaUDeyiQUuaywOgFRPfPZ8ii/3ZwC4atKRu
- c8JpduvusLDgWG2cT9k8H6SnrtDXB46xL129AeEW+KYSFjRoqeLSSzg7E10aCfHpPhibSXIsMlr9wh3O
- N3db4f3DHY4/Q4OW9rS+gMaPkcU3LLS9nYibewPiXc4rdHE+RadyYl75rNMdlixo0NKui3Y4PyEsDA+H
- ok/Yt963+v5yj82K/Y6G90VWTezQ6zM8GrS0s9kGTcHpeafNLxiY7gy8Xz13F/doYufm2+UyriaJpvCG
- lmjHBQ5aPJOS3R4QTb+xxzAB5lruRLjYXBmH+rhOLrNUJ3MN23gyFRhpe2MPtLJf1tkXFB8rRjNnZi55
- qJYORI7Ka5F+c5A2leymrafMuucj04PsL9r/blJyrHWY04rlhqoU7P1cK6v0lencm6U8Necbib0K8tV1
- Bwvr9W1bjpmuryeno1RUzVbIOR2qOTRocYE8pohR/VPTxkek2zBOOFeavF/hwGWQJJEHwAAAAABJRU5E
- rkJggg==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACLUlEQVQ4T52ST0iTYRzHn0vB
+ qK4h3YQu4aEOFmMYmQ461ASTdRDyojRzltFbzFZrik2DIKJDdik6dAg6BHXokIo61prOVzfX2GROUZes
+ xXRs7/64d/v2/F7aG4MdxAe+vL/fC58vH573ZUa73cBz44AxsA6bzYQDHmJZu9XaW+YFei/QOl9Gy1wJ
+ Fz0yLrj3cN6VR5MzC92sBO10GuemUjg7uYvGiR0QQyxrs1j65HJZKXiahFLgSMh48ruoFNhjWdg2M0qB
+ dT2FweiOUkAMseyyIJgLpZJq0CNKcPgTGFmKY1jcxpA3hsfzW3jk2YDVvY4H39cw6IqCGGLZpYGBWzlZ
+ Vg1G/X+wx3eKKxhU52mfT50nFhZADLFMbzbfzhSLqgEVeFZW4A6FsBSNwhkIYHZ5GV7+bmpxEZOiCCpQ
+ GM6yZpPpTqpQqDKQ+E4hg8pMBpWZCoghljV1d99N5vM1DcTVVdVgLhyuMiCGWKbt6hISuVyVQYrvFDKo
+ zGRA8+hMEs+/BUEMsayxs/N+PJutaeCNRFSDH/xO6A6uvoso+Rjgn5Oz7IzRaPklSVUGSb5TyODh5zUY
+ 34Rx5ZVfeVLGY0AHf57uf/GBnTIYrFuZTE0DKmh95sbLTaDvJ3Dd9z9CCDh572uM1el0w3F+oxvpdM30
+ v/eh2TFTFa2L/7FjTtS1C5+Ypr7+5pGGhrH95ti119uUoy09X4hl/Gh4jvOc2E8Ot42/PaQf6f3HaP4C
+ dRjFo//0njYAAAAASUVORK5CYII=
</value>
</data>
- <data name="scissors-blue" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_panright" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACRUlEQVQ4T6VSS2gTURS9mSyD
- QRGtRlOxkM+gdcAQiIImMQYbE2tIqqVmJUHcWPCDkj4k/q2gYBcuahYuhIpWorgQsSqEqhUpmE1WQQrR
- QsBo1m7M8543HQ0ibhw43LnnN2+GISkl/Q8ok8lQNpvdxzBSqRRFo1EKBoPk9/vJ7XariR08dPjgRw4P
- VmQ+nxdAMpk0/lUA3fIipwpweTweUa1WZS6XE5FIxPjbCcBDhw9+5H4V8L3h9XpFrVaTfDQRCASM7lfA
- Dh46fPD/WYDd8Pl8ol6vy0QiIdho4BtgYgcP3Qr/LvDtJ9KzRKs3qRJ+smg0GjIcDguXyzWEiR28CsMH
- P+fMVxi8Q5S5R3RgmihyHkWGruui2WzKeDw+U6lUJHbwSocPfs51Fzho6EGacYkxSeFiuW/30flWqyWd
- gzfnKTVZVrypp7nA0V3goPTdse3F17NnyovfxmfanWsv2vJ46Y2077nexj0AHjp88HOBwzzB3tLBUOHl
- O5g8R6Y+2AduvLr87Iu0x8YrjAlMtTPfM1Kau/r8q4QfObMgNnGrO3z28Sep7bwwq4UvDmu7rpCavIO3
- SsSjz9+RMwtC556y2IFYfLIotdDYW22bGNG2HCbbxhhhqp35wsMFVXL6/scfyJkFm0dv7zg21cQpbFtP
- vbd5hw/ZnL3mL7p0YVc864XphQ78yJkFy9xR6h8tMeaod+AkM/34uxkbGOsY6xl9DJ31E8oHP+esX9nF
- ooW1fN/DWMlYznAuYQXPVYw1XV4XCn4Cnzlvq0a0CiQAAAAASUVORK5CYII=
+ R0lGODlhEAAQAIeDAJhpZZpqZiJNeNikptelprG+zCBPfSJNdyJOfVJvjMybl9Kgn7ShnSNOeCJPea2f
+ nq6entWjojVkl6CBgB9NfjVjlB5OftOnqDJejp1xbp9wbM6cnbWEgbaGhKh3eJBkYbeKh9CdnM2jpMeU
+ kcCNirqIi9qoqZ5ybdOfodSmptenpbuKhriHg6uWkyNQeq59fNakpciYljZklaB1dCtXhTFhkC1Zid2m
+ qdilpJlxbah2cyBPe////9ioqLCRjtCdmrKiotuop8OWkaZ0c3+hvdmhpMyZlipZhkFiirWgnd2prcGP
+ jvXm6TNfjcmdmtShoMKPjoKVs9KanbmTkrqIiaiOjVFwjNulpZJnZqNwcpd0dE9wkGF8mNimpdimp7GR
+ kvfk6MeVlKyfqcSSkd6rqDVjk9KeoqGEgbyWk5emu36SscSUkjFfj8WUkDdlltOaoDJeirqurqOPjiBM
+ eax/f9Ghn8aUkyBOf9yorNympKJybtKeoMOTkcuYlShYh6R/fpx6eL6KjL6LigAAAAAAAAAAAAAAAAAA
+ ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAACDACwAAAAAEAAQAAAIwQAHCRxIcGCCAgUTHjjQQIAAF4Ps
+ eAkwpUrCQQcHidAh5AoAMjPiXBw0oUeAEQMAKPkD4eIZOgQArMEBAI+TLxdzcMgToM2ADjdS+Lj4IUwX
+ Fj/e7DFxgcFFDSpgbAiBoggBNAU9xKiTZYmUBWaeRAgihmASLEYUvCghaEwfPmDSWCEIBNAKKCBIUAnE
+ JEoZP1sKthiS4YQeHmqOVKhBA0nCB3K0EDFwp4kEDBZGDuKCAMEcG27gaB7EhsIOBwZkBAQAOw==
</value>
</data>
- <data name="folder--minus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_measure_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB3klEQVQ4T43SS0hUYRjG8Wfd
- SlwEZbTOiBZJy6A2bdyUmzZhWRAIrSIiccpmmkZtYMqYUvNCMjJOacZAihhjF7qpUwZFRIYilcygTqdp
- vIyXeXpf8TuLmA4e+PEe+N7/x1kcjNYBKl6HCuHepArTYaQWhofzUTLd60x2pPGYDsM+GF7+7mFutsuR
- 7kjjNR1ee2H41lL3uZrsdKQ70vhMh5dXYdSvzoS5Mt3hSHekqTcdnrth+FcSIWa/tznSHWn8psNQDYxA
- 9mc7FyabHC0nOihNYOgyEBN4csnWsDjVwsx48L+yP9o58cxFaRpEyaBLLhiotgUXJhqZ/nIzLz37FqsS
- F7mWy1G6oLZ4dADoq1rXmPl6i9Ynf156Nvawkjr/LC1R97VDl+jZCUQv4G76c4BzH2rz0rP4gzPUOW1Z
- 1H0BhIFmuSQeKcBs/+4d7Cvevu5F2X7OvPPYrI/X+TZ8ijrHk0n2nkebAJokXiwv578iu7YxOVJj+yVf
- 9ip0gjoPDefYfQ73BCA/YvMVueRaAVJ3iosYlFB1H9nHxBuXLfXey1jLMerc259h6Cwi1WVygTxbxNbb
- p/HYGvNxbtSdl55Fb5RSp+6ePIijGy0K5WVP5WG0+o/j6Wborjai8C+upHqE/vhN6AAAAABJRU5ErkJg
- gg==
+ R0lGODlhEAAQAIMPAKufkcu/pqqomunkwKKdkdXIq5Whrtbh5YyZpZy+1J6Zj42Zp5y/1I2appy+1f//
+ /yH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAAPACwAAAAAEAAQAAAIWAAfCBxIsKDBgwgTDkyQYMGDAwce
+ RoT4gOECBwwQPDBgYGNHjg8wIhjZQCFJhShTqhRYgEDLly5jwhwggKbNmjhvBlAQoCdPnz139gRAtKjR
+ owBWKl06MCAAOw==
</value>
</data>
- <data name="icon_zoomrect" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_panup" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIZoAAE1Z6e2z3BJJeqxd8Xa71tgZMfb8KjR49Dh8trn9LjH19nm86i7zufu9brT7Zu2
- 0NDg8dHh8tjm8qu0vOzw9Mza6PT3+aSttoOGiGRrcoSAf15cWuLr9a22v97m7Z+fn7e/x1xbXcbb75mi
- rM7X383U2cjIx3h3d9fb3+Xq73yQo4SHi7S3u67L53ahzKq8z5u83uLs9a6yt+Do8W50epyzy7bBzeTr
- 8cvY5cPT49ri6unv9LvU7b7L2EdKTauoqHyPokpMTMjQ2OHr9FhYWbCurbC/z398e5GRkqC50q/N6tbe
- 56TF52RgX4SFiJDO1oiOlGxtb+rv82BocJy20KWqsXV5fsrc7tDh8aCnr6jG5DAvLq7C1efs8auvs+Dq
- 9JSVl+vw9YWUo77H0Tg3N5qbnaamp4aKjQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
- AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQB
- AABoACwAAAAAEAAQAAAIuADRABhIsGDBAAIDKFzIUCEAhA/RSJxIMaFANEU0NDnyo6JFNB9YjOlhowoS
- ExQjlhHiocuOGRWMrEgZwIwMKUssNPgi4YoYMBMfnihBQceNIQsgEKgRImiADSnC4MiRIAIBB1rIOI2C
- okGMBAhEHFBCxcdBKF44LMBi4MATJipoNAThhAQCAzxguEgyZYLHLBhGcGnxAEiGAh4ldjhDZEsQKxcK
- CBiQGI2CFwokMhAwuXLFzZ3RBAQAOw==
+ ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAACDACwAAAAAEAAQAAAIxAAHCRxIcKCLgggHFhBQQKAdLwGm
+ VEGYQECCQSJ0CLkCgMyMOAUbCJzQI8CIAQCU/IFA8IDAM3QIAFiDAwAeJ18GuhSYg0OeAG0GdLiRwkfC
+ D2G6sPjxZo+JCwwSalABY0MIFEUIoCnoIUadLEukLDDzJEIQMQSTYDGi4EUJQWP68AGTxgpBIIBWQAFB
+ gkogJlHK+NlSsMWQDCf08FBzpEINGkgQPpCjhYiBO00kYLCQUCAXBAjm2HADp7NANhR2ODAgIyAAOw==
</value>
</data>
- <data name="plus-circle" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="sum" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACY0lEQVQ4T6WPX0hTcRTHT3eW
- C93W3dTVlbLdoQbTejCMKDP/lJBs+CewJBnUY3vsvSACDXrpoYfCyig1IxekQWRei4WTscK2NbQ9bLt7
- GMzXe9nL5XR+V9u1KHroBx/4/s453+/v/AAR4X/QzfDEAfCsCmCaeF4twEx1gJgkQlswHdB7bIbNkkf3
- /hbgNb+slY6EO2Vfyq8My1e1i4Tvu185vNwhl1OPArx/C/Bag66ob92vDqxfQd83P7Yv9+kw3b92GXvX
- RlTL7MEoBXh/3WDCIZRPCVJv8pLa8+UCnv08hMc/nKPlNg/TrMZ6Z74Oqbsm90lAHuMLD+2BJqlN7oqc
- x7ZPPp2Wd92lAKZ/1jtWBrD+basM5DEC7vNTpyP9SutiDzbPn9JpmD2GhUIBs9ksVo3Xo/2BW6fmUSO6
- Xx1VgDxGwL09oc7IoOZ5fRKLxSJmMhlMJBKYTCYxlUphOp3GXC6H+Xwe+cci1s40aUAeI+CuLdQe7tPE
- YAvG43GMxWJ/NG9sbCA/KaJz9pAG5DEC7linPO9PKPY5N/LT4iZPxdLLTJfqc6SDLgXIYwSMWQKOaVGu
- XmpAfpEGGPOisTbpUp16uyecMpDHCLhVKZhu2yTnUqNqD9MWYTIsiPqf9bVJ6zXCtlCncmMWCchjBNys
- ALhe4S0btUb5kEu1r1LIKhnebME0Yft4QDWNWqJsFshjBACdOhPA4E4vd80smccdsjW0X+HjLo3BNKux
- HpvRZ+lsDyiju5PwgLCjC7q5GzDMvYARLqTDNKuxHkAzsZco2x7AUaGSqCGEf8AeYrMcC/gB3xr3gK0n
- sEUAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAAtElEQVQ4T2P4//8/AyWYIs0g
+ iweZAYyMjAxA3AjEa3BgkByKq1E4UAM4gXQPEK8HYh2oGMhgEBskRtAAkGKQIROAeAsQ6yEZokusASBD
+ uIB4ChDvBGJ9JENwu4ABCqCKDYD0fiCeATUMZCgYI6cbVA7CACOgwqNAPBemGSQFZIPECRpgAlR0BogX
+ gzTDXAWkYeJ4DeAEKlwPxA9x4A1AcS58XgAZIAzEUjiwKF4DyMlUA58XALSICQGuLQH3AAAAAElFTkSu
+ QmCC
</value>
</data>
- <data name="sql" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="map--arrow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABE0lEQVQ4T82Tv2rCUBjFb+ji
- IF1KKfgATtJBtFOW6gOIi2hBEAJm8QncpHXxBRwEB0cVRHBx0Uknh76CD+AzpOeEc+EmSJd06IUf5/tz
- vi83hJgoikwWMg3zwf9gged5PliDqdRAX8Cn8jm0CXhGqtHfAobmDWiDkmLWxmACnkBd9VcOOH7G8YId
- CNTsSFnrKn6Q58Pp2The8A72oCYDa8ztgnSe6MXX0DWPUuaMe85CN0/0aLbXHyA+aYjad16BufW5cZkL
- LsaYCjRkrKEZdIE6v0ZD9ap69ISa4ay5grM0gBbAG9iq9g0dqr5UjTNkxQU58AieZeICy5eWF1M9ejnD
- 2V9PHt0DuAH/rjPLn/gnP9MPy8pUmKBE2kMAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAC5ElEQVQ4T53STUzTZwDH8ecy
+ E52e57yZnRaiWRZdCPHgYdHDhtMwdkA0MQ0UeauA0A55UQSRYJEgL4KCQIq2EMGmCgEE5K0DLGwoXUFR
+ wLYgEtm0BSQi3z1PYrKYeDA+yef2+/6T////iNDMzGAp8jME/5qRIURIerqWzziqk4Q4lJoatS4fUNeX
+ RtNQDn1jxTgn63BMtmF6OEb2oAdDj5eEVi9xNi/RjV7UXnWSEAf0+ui19XWudabQPmlk0FPOkKucxZVO
+ /vZNYJ7zk2H3ctYJaQ6ItnpRe9VJQvyUlBSz+u4d5a0J3Hado/NpIa0jRp77brGwbGfgnxny70+R9whO
+ P4BYmxu1V50kxH6dLm5lbY1iWwwVbYnU3kvFOpxL12ghD8ZrGZxoxuxykWWfJqVrBl3LDGqvOkmIH2Ni
+ 4v1v33LxZhRmxymsY2cxdZ/iD/dlphYtvFzuoMPZgWXuNcYn6yS2T6P2qpOE2KvVnni1uorxeiQmu576
+ kXSutidz98lFhmcrmX3VxLCrQb7KNJXuVQxdU6i96iQh9mg0iYtv3lBQpaWmO5m6QQOld3TcGT/Pvaki
+ nC9qcYxV4vY7aF2Y53TPY9RedZIQgUePJi2srFBYGk1+dQQXzBGUNMdR1nyCqrsG6nuzsDtLcTysoW20
+ hWONT2ka96E6SYhdYWHJ88vLFBfGYbIaqOk4yQVLBJbhNKzObPlrC2jsz8Hz701eLPXwS/UEh80efkip
+ uPF9QpkQ34WG6meXlijJ12GpT6f2dgrnTRpMA3oa/sxAc93GvqJuDl4ZIOSqg59Lhyjzws4z/Z4dOX+F
+ i2+Dg1M9fj8lefFcyo/HeCmKvEoNeXUajA1agrJtFLnlBZIX6cjo/5LG4Zvfex1ia1DQmXn5VZ/5fB8V
+ axplb073BwL7YWvEjdmvY1vCxcbt249/GRCQ+6m2/HZ5TtkUGFa8efdhoc4m6Stp26fYcKCs6ot9uZHv
+ O/EfeeONT9E6bWgAAAAASUVORK5CYII=
</value>
</data>
- <data name="table" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="folder-horizontal-open" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\folder-horizontal-open.png;System.Drawing.Bitmap, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
+ <data name="application-import" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABzUlEQVQ4T52RzUtiUQDF71ba
- R7RrGW5aVIQUNVPQYjCIwU2LNg3ZjMwUSViPzGKmmf6oiigcs+zZF5FSFn3iGJbo8yOfnrnnwXskuMkL
- B8598Dv8uE+4AgGnzGSDcYrPfr8bDR6yYlRRpqpyYCgCDO5X8XGvgg9hHf2hV/QFi+jdycOxraFnK4vu
- zQy6Nl7Quf4MMmTFiM/3Ta9WjYG1NIyB1ZSOX//KxkDgPg//bc4YUK4zmE88GwNkyIpPXq+nVKlYBl9U
- DavHKfw8TGJFfcRy5B5L+3dYDN9ACV1j4e8V5oMJkCErhqenvxd03TL4ffyEV3lngmdnVt86OrL6+sEB
- yJAVQx7Pj1y5bBlwIByPI3R+jsNEAjunp9g+OUFEftuMRrGhquCAwUhWDLjdM5lSqcZAk3eGBmangdk5
- QIas6J2YmE0Xi3UN1MtLy2AvFqsxIENW9IyPe1OFQo1BRt4ZGpidBmanARmyonNsbC6Zz9c1iFxcWAa7
- 8k3evgEZsqLD5fI9aFqNQVreGRqYnQZmpwEZsqLd6VTucrm6Bhww/wIH3hqQIStaHI6VpHzRm2z2XSFD
- Vtja2r422e1/GglZIY9Nplmm9Z0hY/sP0fXQjui6fQYAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABx0lEQVQ4T6XUPWgaYRgH8Afc
+ LIJjySiCOOrkopOCDoKKDiV0jW0phVJoh1BwcXdyUgRxEAQHEYyIuly0EZJKk+LgpPj9gYKC4te/7yMI
+ BQ0Y8sKPO47//+55D+4IAL0Gud3uPY/HoxLeCVdn4qyKXC7XwWWpVHqq1+uo1Wp4fPyDh4d73N39wu1t
+ CZJUFscKyuXfqFT+4uZGehLdS3I4HAcfc7kcstksMpkM0uk0UqkUkskkEokE4vE4YrEYotEoIpEIQqEQ
+ ZDLZFY9+4BXv4kVLdL1ktVrJ6XSyD9vtVoxXQT6fR7vdxmazeRZnuUMmk4ksFgvZ7fZPq9VqPzYvSZLQ
+ 6/WwXC5P4ix3yGg0esRNvjLeJ+v3++AnVKtVjEYjzOfzI4vFAjab7TPpdLofpza+Xq/BodlshslkcoSv
+ m83mL6RWq9+rVKqfLBAIgLVaLfCIxWIRjUYDw+HwyHQ6BU9Nosg3IYPB8G08HsPv92O32yEcDu+30Ol0
+ TuIsd0ir1ZJer2ffB4MBgsEgfD4fCoUCms3mszjLHdJoNAfXPGq32z0LZ0X3muRy+Z5CofAqlUr/S3CH
+ /ltycf5WuDgTZ9+86lPm38A/lieNoGpgVUMAAAAASUVORK5CYII=
</value>
</data>
+ <data name="function" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABIElEQVQ4T6WTsU4CQRRFdwnE
+ EIkxKBL5BkKjDRQWFljQEwq0pCI2FFT8ABV+gB0dxMrEBAsTowmVxs5f8CvWc/GtWcdZDWGSk3nvvnl3
+ Zmd3gyiKgk0IwjD00UafG4q967Sxr3BMww2cQtXitQx6NM1gL23nWE87wYQFV/81q+4ajBHvHGqJvGum
+ ZdO6vhPUKd6DZj33hc0d03UvU2j6TqCGS1hAyXmEBvmD8X2hvhNcs0i4t95CewK9oVQD7foIA8dA38HS
+ OPvL4ITiC2gONJiHpilW7dwMFH+9hcQYEb9B2bQ+83uiHufSWtKTBnXyZ7j9Yfk7KSCJ1YgNPojFKxzB
+ PhRhF3ZgG/KwBTnIQgbC2KBCcgg6+sHaBpv8yur9BCINtCQt9llRAAAAAElFTkSuQmCC
+</value>
+ </data>
+ <data name="icon_maptip_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ R0lGODlhEAAQAIUqAO3u8e7v8vHz9cTDyPHz9O3v8fr7+9HQ1eTl6NPT1ujp6+Dh5enr7/f3+PP09dDQ
+ 1Pb3+O/w8sC/xfLz9fj4+evs7/f4+evr7PX19+7v8ePk5+/x89TU187P0/n5+u7w8tvb3sPDx/P09vv7
+ /Ors7/Dx8/X29+vt8Pj5+bW0uv///wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAAqACwAAAAAEAAQ
+ AAAIqQBVgAiRoqDBgyFACBwwouEIDw4tOBww0AGJiycyamTAgIQDghcxasxYIWRBjRIOFlygsSCAlwUy
+ LEjRIWMBADcLBvgQYKeGFA8+CBUaoGCJoxsiIEhx4KjTEgUJCBBAoMTSpiWkSi0ooquICVePehVREIOJ
+ syYUpEiAFm3BBm3VskULoUFBFHjxXkjBIS9eCilCePDgt/BgDwkHGCjs14ABigIJqkSoMCAAOw==
+</value>
+ </data>
<data name="layers-stack-arrange-back" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
@@ -278,205 +325,222 @@
aMIAAAAASUVORK5CYII=
</value>
</data>
- <data name="sql-join" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="database--plus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACXklEQVQ4T6WTW0jTYRjGPwy6
- CHLZKsjALhYVkkhJtJvqoiN0EUGSXaQX0oIEc4oNR+ga2kRUxJ106lquaOps03by72GosZzhVonWdJuu
- nZxa2WhBV+t7ZEL3G/z4Xp73+b27+pNkMknSIS0Zf0zyq6zkdPUIOfOYYRUIRrmUm5S7qfccfcH/GRdd
- OHB3DuRcr5+81+cIKgIbf2wb8b+u0U8xzQ3J9COAGRl26KBLD+TsHGBdEdtLFoK/9N82ExOr6wnGE42P
- FLW+E84HtqwAMzLs0EEXDj3AInl883nt1IpiZT0x6l37baWlsWf6z9KesWU1MoAZGXboIIMDl+SWDxd9
- CcVNiyn8sYT9Wp1N5Pb/NI7Px7reOEMtFlek86LQXGtyRaQvpwMNg85Qs8Oz2QuXnCgz8OjVyY+rWwbw
- NRxnjvF0NVZXVKlkvHXA4o4qOPd1Naa5SIeC8dYqRrYzFVzCeTBQPOf/YXR6v+ut7rVu42xYya0yiPsd
- AWWbeUkEMCMbeB+UbWeWJdHgTFAOlxwtfX213bSoGvoQ7m4e9og7GF8TTzbVJuydlclsy40AMzLsmoY8
- T+U2b6NI526FS46UaNmnyvorX9h90pa3HolYvyDSTPg6z1YMSNTj3h6AGRl26KCb+7CPD5fszb9Fsi4L
- Th7nvaoWaJzt6gmfUj8T1DT0u1WcUm09wIzsOd2hgy4cuPjtohzYnZ1XwLokKGbflley73Q9YRcqKzIv
- lBcCOvOR7ac7dNCFk3JJBh32pIJs+h6mHKTso2SmyKLvodQOHchwMtL/mNL5lOH+A5i6WIwCDkE+AAAA
- AElFTkSuQmCC
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACQUlEQVQ4T5WST2iSYRzHn5qK
+ Hhq1oMLLoINsbC4wki6CXUZ/NsHES0SnGhTrFJIDDy47OnaoLd6pzbk5nU77N6evUzcyK927IQt0NMrt
+ jd7I/hBdOn573rEO5qL5wIeHh9/v+4Xny5eYzWayQy+9+/aIuLut+yMmBoOhr1qtolKpoFQqYW3tDdLp
+ V5ibyyGVWkU+v4Fy+TME4Rfo7g2j0UhEagwEQUCxWKTCNFg2icnJCFzuMKYDCSTYApa5d9jifzZgMBXB
+ GDXwB+cRT75GgdvAJv+jEYNZMJ4ZTAVjmE++RJ5bR4X/9k+Dk/39/c9cLhcYhsHw8DBsNhusVivsdjuc
+ TifEmcViidMMtLtm8HeIqUwOT+YXEU/nkC0Usbb+HpvC171/wecP48G4H95QFE8XMsitFLHBf2zAYDqE
+ 0fFJjIfCeJxawIuVFbzl+QYMAiGMeCfwMDyDR6kEeuOX0RHTQTnUllUPaEn7bU1ND/4bYqvvBK5+t0Di
+ PVomE4cJ8bQQYjKZtunp6alrYmopi0g8gQvRS1AFTqF95jTMX/ogHz22RcUccbcwRKvVku7ubqLX66/V
+ NpGFLxjEPZ8HrWNdOPPpYh1k5CBHxKNSqYharb6+u4EbOuYsjo92QTWmQSevg/TuIZ44mzky1MyIegXl
+ iFKpvFXXg6XnmE3MIboYA7ucQdt9DZSVDjRZD3wQNTtaQpMgnQqF4qZcLh+USqWDEolE5A7FQd8OmUzm
+ oDNH03nZ6r4rMmH/OSkraigtvwEKQSNnrT8HPgAAAABJRU5ErkJggg==
</value>
</data>
- <data name="control" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="printer" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABeklEQVQ4T2P4//8/AyUYRbP9
- 3BcMDvNezgTiGJtZTxkspj5gMO67yaDXfolBo/4UVotQBEGagPgMFMeQbABIAxCfmfn0/38QbTHlfgxJ
- LgApBuIzHVd+/5/++P9/ENu490YM0V4AKQTiM/Wnv//P2vbx/4Q7f/+D+LptF2OICgOQIiA+U3Xs6//E
- tS//hy++/7/hzMf/IDH1upMx2GILJRCVyg8xAPGZtC1P/7tMOvffeeJZMM7f8/w/SJygATJ5OxmA+EzA
- uif/TWbeBOOE3a/+g8Rk83cRdoFY2kYGID5jufn9f9klr/577f30H8QXT98UAzKcoAsE4lcxAPEZxR2/
- /5vs//0fxBZMWB0DMlg0qJuwAdwRixmA+Izq/v//QTRP5JIYHvd6BlZJHQYQIOgCFi1/BraguWdAmNWu
- LIZZTBOsEQYIGgBUyMFkVbyIySi5BMg2AGINIFYAYgkgZifGABagQjEgloJqEgHSAkDMA8QsBA0gJ1sD
- AE2BbRvnALnyAAAAAElFTkSuQmCC
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACYklEQVQ4T42SX0hTYRjGX1To
+ omIggdDVLvJi5o0IJjrI5ZgtNuG4KVsodtPZGSNScirHzY2mTIQSDPVK8MKBN6JSyVTUGAkTuqyLBInU
+ iQRZ+OdChz5978nBxJTew+/84/c853zwkbO7mzLUh0J2gXwJdxzBIEldXecgfpmF51c6jdTBATb29/F9
+ b09jJpGAcDyCwgsFkqpSFsrvoyNs7O7i684Ovmxv43MqhdjsLHiEp1hbW/UmRSGmzuMhcjgcVCfLVNvR
+ wXj3j4/xQ3w1u+TN+DgyFFqtAQE9qK/XstrJ6XSSo6mJbG1tvgNR8PPw8EIJ/wkvhx12tcxZQY54sAs8
+ eXl5r/x+P66CHXY5IwpySJKkW6qqhnbEmhVFQSQSQTAYvEAgEEA4HNacra0tdHZ2hjhLNpvNMDg4OLa2
+ tgaXy4X29nbIsozm5mZIUh2qq82orDSirOwerNZHmjM3t4yent4xzlJNTU3V5OTk8urqKsxmswh7YLFY
+ YTRWieD9c5jNDzVnZmYBAwPDy5wlk8nkSiaT60tLSygpKUFDQ6OQ7P/EYqnVHFkcExPv1zlLFRUVz+Lx
+ OGKxGPR6PZzOJ7DbH18KO6Ojo5iamgJnqbS01J9IfMT0dBw+33P09w+jr28I0ehwFiPi/i9ebysWFj5p
+ cJYMBoO6uLiC+fkVuN3u/yJTwFnS6XQt+fn5vUxubm5fSmyY6mgKr9+mMPTuAypfuHG3UYXRO4Jvm5tg
+ J+NzlsTcFNxmCsrLX2qbPmtOTk/BpE9OkBZXdjL+WZY7iK4VFNCN4uKn14uKolfBDruZ+QOvqgI74xfB
+ qAAAAABJRU5ErkJggg==
</value>
</data>
- <data name="icon_selectwithin_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_measure" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIUsAOjs8K+6x5ScqICAgLSun+zs1uPhzs3Q0ujn0ebr7ebl0O3x8uru8O7u2OLj0aet
- svj48Onu79rbzd3ezre8u/7+/vHx4cTHy/H09efm0LW6usXIxOXjz7e8vrC2verq0/b27LG2t+Pp6+Xk
- z+7u2qKpsvv79+DdzPDv3fPz5LzBxtjazf///wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
- AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAAsACwAAAAAEAAQ
- AAAIlQBZCBxIsCCLAAgTKlyIEIDDhxAhNhxAcYCAiA8nfkCgQMBFjBMzjDAgoMJHiQEADOBg4IQAExAE
- EJhJAMDEigJApEAhgGPNhhAFWCBRoIAAAz9TqqQooEEBCSEeyLSZcgCGBREEOKBglCZVlQsYJBDQQcCK
- DQcyVhUrogSACxoKeFDrsOJDARNOAsV4QIAKtQwDIwwIADs=
+ R0lGODlhEAAQAIQSAHFCCr2NKldCE9ajLmddJf7nWp3M3BJEd005EQGM5AGK4wGN4QEzZgGK5QE1ZwI0
+ ZQE0awE1Zf///wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBF
+ Mi4wAwEBAAAh+QQBAAASACwAAAAAEAAQAAAIWgAlCBxIsKDBgwgTDlSQAIIEAwYeRoQogSGEBgsiSDhw
+ YGNHjhIwRnjAwIFCkiYVqlzJUsIAAS9jwpwpswABmzhv6swZAEGAnz6B/uz5E4DRo0iTAmjJtOnAgAA7
</value>
</data>
- <data name="icon_zoomout" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_refreshmap_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIZ6AG1LJgE0ZkV2qN7s9bK8xuqvdtfk7LOcjH+AgLrK25i1019fX6OmqdDc41lZWV1d
- XcnV4XF3fJrU5Xp6emVlZbHE2Y6QkY+Rk7DE2ZGkuLvJ2MjV4VlZWmZmZlpbW8PP3XmTsLHN3rGai5ux
- yYWFhajN32NobG5vcOz0+a+vr6ewuYGYstzq9LW8weXx993r9WSHraDP4VxcXJ641IeHh3uFj5qzzn6a
- uF9hY6rK3YepxarA19bk7ouLi5230rnAxdLe56m80ZKYodjm8M3a5nplTnt7e3Jyctfl7/z9/dLg6tPh
- 65m108HP3aurq5vO4mlpabvM3M7b58fHx1xdXoCAgG5ubometKy/zoeNkkZJTGdrb1tcXczZ5cfU4MvL
- y7GxsXFxcae+12NjZJOluLHJ25yvwcva5lJrhePv9ZKov9He6aHE28PQ3WJjZGRkZKC61WNjY2mGp21+
- kaS2x3d4eH5/gHyWsaW911dXVwAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQB
- AAB6ACwAAAAAEAAQAAAIxgD1CPwyQUYeB1DACFy4kAYFBg0GGPiB4AhDgSTqGBgw4MWQJVIuVGE45Y2B
- JChYIFFCZMMHOykWGmEwwEUaHmu6eGmSQEWYhQsiChhKVACGIAsWOhhwJoDTpwHEwHmw8AEQLHQgtIkS
- IgeeGSPiLLTSwkwGDQnKlIjxRIGQHgudICBzRU2FHWwk6LAx5mKHCCtA3PDBRAEaNxZEXDxhYo4cGHdq
- UNFSpMCBi1lweODAZYseAgAAWL5I+nPo0aUZghad+uLqgAA7
-</value>
- </data>
- <data name="icon_home" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- R0lGODlhEAAQAIZZAFJ5osvLxjZHVTdPa6C9zcOlRMjl9pa65GqZz3CLpPb4+f///329mg2RUJy1yE91
- n9jb52B+l0ZSayApMSw/UV6LvjZRbsDQ4GmtmY3F6ujs8j9cfOfcvmOSx2+cz2uYyomou1Foe02Mg6eo
- w3Wdy5ahrI634Y203OXp7m+QtYSt2jyScFeBr9K1f16Mv+3x9eXl4rOMMN7p+jNLZlmGuo2cq+Ho8Iiw
- 23qk1mGelW+lndnh7IGPm2uaz157k9a0MGWJs12KvKWlo1+Mvqy7yR4iJUdXYzRObT6UctTf6xgoOFVv
- huLLgOny/XiXuKKALLTI19rY05mmtHGBkaO50fP0+E51n6S1xU98rP///wAAAAAAAAAAAAAAAAAAAAAA
+ R0lGODlhEAAQAIYAAAAAAP////38/f7+//39/vz8/evr7Nzd4M7P0s3O0bGzuOvs7n6Ej32DjnyCjH6E
+ js3Q1c3P0szO0ers77K4wLG3v6+1vYaasLC3v6+2vq61vK+2vczQ1Ors7unr7fb3+N7f4Kqtrpienqes
+ rKisrKqtramsrN3f38TGxvT19d/g4Kesq6isq6qtrMPGxcTGxdzf3c7Sz7a9t0J2QlqAWneNd3uOe4KU
+ gpSllJmomaOyo6WzpdHi0dHh0cXUxdbk1snWyd3p3dvn26avpqOso97p3tHc0a22rdPd0+Ls4uXu5cTK
+ xMHHwenr6f7+/v39/fz8/O7u7v///wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
- AABZACwAAAAAEAAQAAAI3QCzCBQY4AGVFwViSBjIMEtBEg82jPghIUBDhwgOHOhBI6KECBYHBkBgQIWH
- DgBcWFFiBCRBkjcqHEBQAcCMGlMogBxp4IRMAEMAHJGyQMYVChR8GDBhAAeCIAAslFiwoIkGAQInADgA
- 4AOAATwWZMAy4KrABBYmcB0QAkWGJwUG7MCaJYEBCwMmLIGywEmBKAMu0E2gAEALDg4UVElRoEjgwToc
- JEiQ2AaQAkweZyHAoMGKHCASJ2FRoIAAARgIZIHAuQESEQqICBggBMZmhqw7C2jAIPVF3ASCXwwIADs=
+ AABSACwAAAAAEAAQAAAI8AAxZKiwAYPBCgYvSFm4EEOBhyYKEIBSAAMEhQwxPHlSwIQAjhULcMAoxUIE
+ BBFKJEiAAAEGBgweMLRQAAGBFQQeFjjQoYPMhRUiSIgwooAAJwNSDBhgIGPOAiEkDlhio6oMhhkKqECx
+ 4gWIADYCiLVBA2gBFwRIEEAxNYcSJTaQ5JCSgQQLEytYtIgypImRJDaMGKGhoQCKAi2guBhwI8gOGzJ2
+ FKmBgcCJFyNcgHByQ4gOJjZ0CKlBocDGERudHAECJGwTIDRKd/AgYsKCDzBw+Aj7A8cMDA4aPAjuQIGB
+ GETC8uhhg6Fz5zOq2pgREAA7
</value>
</data>
- <data name="icon_invokeurl" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="database_share" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIU/AP///0typRExZG+wPtbn963D3maPxcyZALfH3FWHSGupO3ugdqq+r5iymaDfUY/S
- S1iORF6fN56xxmKWSj14K5jYTqqRCT95LHy6Ql6PT5Gzh4fKSIPCRY/RS2akOShXQp/eUZ7dUIrOSYLH
- R1V8IHvBRFmPRInISH+og0mCPpfYTp3cUJPVTIDGRojHR1eNRIPDRYjGR0dzh5vbT6DeUHCzP7jOsU+E
- SVuQRZvbUHGzQIbLSJPVTZq0sWWkOQAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAA/ACwAAAAAEAAQ
- AAAIugB//JAQoKDBgwUlCAxgoKHDhgAMRBSwEKHFABR/BCDAsaNHjhk3AhhJsmSBjDJQZLiQQYOFAzAP
- ADj5o0EKBQNWnFAwwYZJAQxwYBgAYIADBxgmvJR5coECGkSLhgChQAPJkwlizIhaNIcLEjBnCqBQQQXX
- ohUuXBWQgAMPrh1YwLhRoG5THw+ibhDxwMMHAYABMzAxgGiLETsGvOiBoHHjmhAi6ChRIwKEBgIzZ2aw
- IAGFBAsYaM4cEAA7
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACqklEQVQ4T5WSa0iTURjHz6oP
+ Db8EpfghDLpRKH5RhBXJGIE52VzNVaybEGibFZZ9UNIuGDgIxRRzF3NL1FDx0tzm5iWdl3nZ61Rkajd1
+ inOogRJlkPDvvAMTh4Ed+MF5Xt73d97n/xwik8lIACJap+wC9j0S+DERi8UpS0tLmJ6ehtvtBsOMwmzu
+ hdU6hL6+SfrMi4WFnxCJREqJRLKzwOv1wuVyob29HSaTBbqyWhgqjGg29WJg8CNmPav/K6iBvqIJRnM3
+ +ocmMOP5tiXg8xO2tUFbiFIoFM1arRZqtRoqlQqZmZnIzs7270tLS5GRkdFCW4jxtxASEhMoCMhgBKYW
+ O0y2HnQ5hjHi/ozZheWtPyAkfJuEDTEwA62+GrrKGtRbrOh2Mvjkmd8uYCWbo9xJoNFXQVv1DnUtZnQ5
+ BzE1N/NvQXLiuV1lIBQKYxISEghd4cMsUqk0lcUgP2gbe6OEU6uEqyEfTocdzbYONLbaYOu3Y2DChSnv
+ V/D5/FSBQEBIenoRJJKH2NjYgNFoBL7U+Pk9WYn51jy0qpJQnnsbakMxqqz1aGM6MT43gcjIyLQs4WFC
+ 4uPTwONdh8/nQ3V1NdZdOqz1Ff3lB6PBVH0WGp/Go+r1Ixhr82EpkKNQxHV0JO9Tkujoy4iISPRfXY1G
+ g+8DJRgtT4O94BraVDKMGe5h+cNL/KLit/fPgCm7g1V6AFs3yffqSFycAlFRMiwuLiI0NPT5K2nw+GDJ
+ jRXP+ydgNCmw5Eqgv8uDNjUanflyzBtz1nvyLrgbFMe69Bf3XKEhnlhjCQoKyuNyuQ/OhpGbj2NJXeGl
+ Q+OOwqsrPksuNmHr4qTgkRcCTsn5oxye+BSHnQIJo5ymRFCOU05SoqjoFit6xifMJjmxpDb2CKH3lxyg
+ 7Kdw/gAsOxzv+3rD2AAAAABJRU5ErkJggg==
</value>
</data>
- <data name="icon_back" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_selectpolygon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIUmABQ1Z7S/z3GFo5TY9aXb8YO37oC06oa78oCz6Ya68Y3B96HF64q+9YW58Im99Xer
- 4d7s+6TH7t3r+tvp+H2x54Gz6Xeq4Hyv5Xqu5KvP9ajN85fM7eDu/oK27Z/D6KrO9H+y6YG17Hyv5t/t
- /XOm3KbK8P///wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
- AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAAmACwAAAAAEAAQ
- AAAIeQBNCBxIsKBBEwIOHhQAQGFBARwaOhQoYIQCiQ4FQHDAAICAjyAZUpTQIMGBDB80lIiwwMMGAAEA
- TDDQoYDNEAYoYLBAYgBMEwAIgEBQYYDRo0Z/xiRwQQSAp1ChBhC49AHMAFizYh249OdEEzG9fo059SvV
- smYnBgQAOw==
+ R0lGODlhEAAQAIMLAM2qrs8YGBU2aKi0ws2OkfLyl851eMbMjqiToKOuhs6QkwAAAAAAAAAAAAAAAAAA
+ ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAALACwAAAAAEAAQAAAIbwAXCFxgIIDBgwcHCixIAIDDhwAC
+ KGQIEaLEhQEaVnRI4CLFjQA6GhCYcaMABBFHkgQp4CQAhQFYHhAwACbLAjNrrjRZACfNnQ8bCujps2bM
+ oBKHJmjZcgFCgwoWCFg6oKpOhQNbXsWK9SfXr2ADAgA7
</value>
</data>
- <data name="exclamation" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="images_stack" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACDklEQVQ4T6XTz2vTYBgH8OcN
- is6LqAM7cXpxwlAsHnSIiF6ml/0FIlgRhUEOO2g30JPgPCi402C4grP+3rSz/qqpWKtlunXQt7GzrO1W
- Bk2wdLWDukJdx+P7hKVka0HQwIc8ffL9Jj0kgIjwP4COi6cZTL6ssVnshlfQvCpDHQIDvXXLFL6gxR1c
- i5/lNNd5gHFDmHjBaoS9rDni2+qpLI6UK4tPyxHfFg/t6mXhq4fVGB9lV7IzXcml/C1cyt/EbEpO0q5e
- FsaesVW+PGd27t+t/F4YXHY6nUjKhf5lrjQrdG1tHj4PMyspNML6cukerZjpRlmWDcXMZcwmZY2uibxk
- 7UDwMav69IS1R9/vD/36cQMX0p3ocDgMNBe1q8iVlhBlrB348ICZGgKPJHcu3V0ozHaKJ55Du92ONpsN
- Y+FTqE6cxNhkR4EyotNg9uDdEDP43eyMGmjj+bkuTE11oMpPoHhFDFF+3BBT23HszS5OWbMHvruMNPrv
- b/DqyfOlROwYxr8dMcxnrxnM33SeihwqKe51XupQF165GLx2sUuRwIHE3PRRnP1+sMr8B9YdzWF/U4I6
- 1IXRAbbHd29jUE8crujT+9DKvMHafSbeWnk7tD5IXXh4G1zqx536/Ewr5lJ7hZaq0s8eJNadOUcD23Xq
- wmAv9N+5DuP/grr0MUrCJmGb0CTs+AvKNK50pD9EZQJEPplB2AAAAABJRU5ErkJggg==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACAElEQVQ4T6WRXUiTURjHz03o
+ lK0EE1SwL9JCvJj4dZF14S5sMEVJB13YRYiitpjKbt7cuhGxZJDlLoKapkwqxUVRM9YkEwTPhR8QTENE
+ /ID0ItLEhrp/5znqcFim+MKf83J4nv/v/fEyAOw4YSVWK7vR0LD3NIi7ikPGEFZQYrOxIkWpFF+E4H9C
+ MzS7j1ysKK5+zvH86bV/5pUzA5vBIAwWS5UsOCr5hVOH31tbuG4211CBdN4l6x9wFLRwFNs5DA85bj7m
+ uOXguNfN0ebxS7KrS49fGxvQVVebjuTc+WlEkjvaC/EjEMDV8nIzIw9qHe2N/UtOh+5o5uXAsCQ3N2Vh
+ eX0dOWVldYw8qHWs7yz875Mw+WE7Ux/PYHrgPL55z2HSkyTJLq9Pku+atFhcW0O60Whh5EGtt3VX4LRl
+ YO7zJcwPXsbyRDYCK0b8nNFhYShVkq2vvZLscLuxJIpS9HqFkQe15iYmoiAtFfY76ehpyYR/uFT86Uas
+ fDdhdjBbkmvb+yX5Yn6+75RW26hOTq5g5EGtbnuUSDTePlLjXasGX1wxWPiagHFPHHzPToaRL+TlNTPG
+ EkRUjDyo9UltZChtdSo476sw9EaN3tYoOOoj95FPaDRiXzzkQT7zq6sHhmbCyNvrjJEH+RwmNBsi7xaI
+ M0IkfseJvA6Kas+efP0DD+tcAk1PV7wAAAAASUVORK5CYII=
</value>
</data>
- <data name="icon_restorecenter" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_selectradius" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIZdAEJyohU2aKTFzsfc4bLO1eHt7+729rDN1d7r7b/X3drp68nd4ur09Nno6uTw8Xuf
- veXw8dno69ro67HN1efy8+nz9KrJ0YqpxbbR2KbGz+/2973V3K7L03+hv/P5+cLZ3tfm6bPP1qnI0dfn
- 6qjH0dbm6rPO1cDY3c/h5r3V27fS2bHO1avK0eHt7uHu73yfvnOZuMvf46vK0rXR2Ov09NPk6Mzg47jS
- 2YCiwNLk53+iv8jd4nOauejx84enw8/h5a3L07nT2nygvs/g5Nfn6cDY3u719rnS2XCYt8PZ3rTP1q/M
- 1LnT2ejy88Ta4ODt7rLO1m+Yt7zV24enxMXa4K/N1H6hv/P5+N7s7tXk6LbR17rT2s7g5QAAAAAAAAAA
+ R0lGODlhEAAQAIQZAM2vsxU2aKi0ws2TlvLyl86Ym82Xm85ucM5hY85sbs81Ns9GR82rr8bMjs8cHM5c
+ Xs8xMaOuhqiXpKiAjc5YWs8bG6lYZM6Bg889PgAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBF
+ Mi4wAwEBAAAh+QQBAAAZACwAAAAAEAAQAAAIjAAzCCyAQIEDCBQKCFy48MCCBAMYDEiA4QBDgQceGADA
+ kaOBBxYXFliwsWNHAwsUCkSQwKTLCwgWQhjgEkAACQAGQFjogEHNADcZVFiogKbLAA0CTFCwkOVPAkkt
+ iCR5lADUAAIaajQZwOrVrBgfRhzQNQJQoAwJGlQQwKyAt2AvCgQaVy5DrHbz2g0IADs=
+</value>
+ </data>
+ <data name="icon_selectradius_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ R0lGODlhEAAQAIQYAM3Lz5+svc3FycTM09bcyM3EyM26v86ssM6wtM26vs23u83KzsvSxs6mqs22us6r
+ r8LKxMTFzM6ussS1vMS/xs6mqc2/w821uQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBF
+ Mi4wAwEBAAAh+QQBAAAYACwAAAAAEAAQAAAIiwAxCBSg4ECDBxcECFy40ACCBAUWFEggwQBDgQYcCADA
+ kaMABxYXCkCwsWPHkQoFKkhgsqUFBQsfFGgJIEAEAAUeLGywgGYAmwsqLDwws2UABgEoHFi40icBpBNE
+ kjRK4GmAAQ01mgxQ1SpWjA8jFuAK4edPhgQNHghQdoDbrxcF/oQbl+HVunjrBgQAOw==
+</value>
+ </data>
+ <data name="icon_plotdwf_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ R0lGODlhEAAQAIecAP7+/rW6x9PW48TD1uHg6ba6x////8HBxMTFyMC/wrK+y/r6+v39/cTD173JyMLG
+ 0fT09/P09d3d5qGprPX3+MPFxtXW2dLT1vj4+JOjqcXFxujo6OLk5+Dl58TFyba7x8fIy7a6xuDi4+Li
+ 4drb3cHG0Onp6cLP29vb3u7w8ODg6LG2utjc4IeSk+Tx6dTr5dLV4urq6palqp2ho6ezwL69vrTBz8TD
+ 1ebu9rvI1Lq+vKSvvdzm89XY3r+/wtLV2PX3+dTX3tHQ3Ymbj+Lk6b/KxOvt8PD1+bS5xvz9/aGvvPX3
+ 98LOzLa6yJ+suuvr66CsurzKyM7Q0OHf6NHT1uzu8sTGyb3KyMrKztLX5M3L2b2+wdbY3O3u8sTGyODg
+ 6cbIyNrb4Le9v8rLzrq+y5GunKvMuNna3eHi5fDx8qayu7u7vpShq/Py9fX19ZKop8LU2Jmps+nq67TN
+ x5eosPn6++/1+bO/zKCsu/T398XR36Goqp+rutbX2r/AwdHe6tPW5O3v787M2sfL1fz8/K22v/X199ze
+ 4t3c5rW6xr/Dz/n5+c7Q0cnKzdze5MTGyoaSiJenndPW4o+ul+Df6MDAxL3BzcHDxcvX1Jyws8XD142g
+ lv///wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
- AABdACwAAAAAEAAQAAAI0gABCBxIsGAXAAwMaDDAAAKCESgGJFBxAMBBAwEuXAlAoUCDAAtwBCBgEYCG
- CwGmBKhQQEEAHQGEmChpxIOPABxdRMD54gjJgzRw4nSApYTQABNKQmhSoYeDJxJy2KCyYUaVkggKFGiB
- QEKWIQOKBAkBpCSRBgoigKjBZceHFFoOyCj542iMAUmOiig5YEEHnE5ObMDJw0KGkgmsBHgQQMoWDAFg
- BEAioOSNxUwCYFByIICFKAEqH1xBgACUCUs4sCCRQYDrkgVjD+xCu7bt27QDAgA7
+ ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAACcACwAAAAAEAAQAAAI8QA5CRwoEJODKHcUMElBcOCCQA5c
+ 2OFx4k0GDAMNCRkw4MqLIzj+5NgEaQUnQVoGAACwqMMcM3D0KJDRYganBitXMoBQZFKZTDTwsNlz8wkA
+ AwAYAOAQaQgdJTvUiBGoKacBFQR0TIhTyIYTNwNvACBA4EsYDzU08IEih2AASlO4gNjiBwaYNX0GEioR
+ 4MClClIESKKQ5wKZgQWojAEkQoCAJUDONDoQADGAQxayAEBBAkGCEAESDQzAAkAVNF6sPEIgIc0GLKN7
+ dEnwIwAjRBGSmBBgaSCRD0Yq+QjQpE4MRUHaNFzwAEkBTiMGOWrIKSAAOw==
</value>
</data>
- <data name="MgCooker" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="gear--exclamation" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAJcEhZcwAADsEAAA7BAbiRa+0AAAHrSURBVDhPhZLtS1NhGMb9T/rQx6ACyUVDyQjDaKAGQYOB
- Ew2K9ilifrA+LDAMablFb1IM03DbMXMwj4O15VZ5iPly2Go0yzCzF0iwr4OdX3seOxK1owcunofzPPfv
- vq77nLo6i2d44j0Xb8elgk90rO7VfN80dB13coLmyUFalCMcHjvJ+fBnHkdLu4Psty5wKhZgz9022tUw
- 9oiHpuQy+1IG7umNnQGdfkV2bA4fq3ZtpCP+EI9u4NAM6mMJDkaDuPoj1pCGgUt/LDfiSYV4sFzGm6/g
- zBkcGOtj/4gTm/+cNeBqvIBttIeexDDqlwqhjxX6ixVcc1/lHITawn5rwBVlVRa0x4ZoVc7i1V5JBx3p
- nIwk4wU6rQG+e3m8ehlnMrodxaGOc+K1gS21waHRMzh6B3cepHDRrf2UHe3jp2mZXaf+hcHeRBnxeXf9
- H4L3Z3HfnOJoyMVxtUSD+ovW55t03SnguzZNOp2xhiws6GjaPJPPXnLDn8Hnn6NvIMvl3qcEApHq2Rsp
- SxcCUHj7QUrsTaAo0vUSi0vv5JklxCwUl0Wxuf4NE3vLGCuf1rdtii7Z7JZlASoWV1G6uslEpsjlFmvH
- WFv7wcxM6j8JZ9++bzL/aISV/Ja7mnNYqmY07YouQubg/l1NwG/XLb2y/7oFegAAAABJRU5ErkJggg==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACv0lEQVQ4T6WQbUhTYRTHn9sm
+ IhbolwWlEqaYTEO2SGcfFiu1ph/UbZ8MxC+9EEUQjQwTkkyioMIFpWIpawVGoUyDTTfTeVfe5e5eTJfT
+ llxfNoiSWIUUp+dsLhT61oUf53DO///n3IcAAPkfYma1Wk2qqqpITU0Nqa2tjVWtVqugnNpAsXmHWvQg
+ WwKqq6tLqfAMrbuxrq+vQzQahc0z1PwzoLKy8pBer78biUSgoaHhChWdXV5eAgR7nOEONajdckFFRQWh
+ nAuFQsBxk7C0JIDZbJ4TBAEQ7IPBYGyHGtRueOK/oFAoiFKpzNBoNM0eDw8874aFhXlYXPwUA3uc4Q41
+ qEVPcXFxPKCkpERJBxeRnp7HQb/fBybTk5mCgoL7CPY4w11Ch56/ATKZTO9ycWC328DpZMHr9UJh4f42
+ kUhEEOw9zuvAWVQwYb0MqEUPJX6BVCptdDgcYLVaAavP9x6KimQtDMMQRC6TtrpHNfA10gsTQ8fAMW4D
+ 9FDiAbm5uWU5OTlNSHu74aPb7YeBgWG3XH7wKvLCpPcHPefhV7QP3ljKhZMnJEb0UOIBWVlZJDMzc49M
+ Jr/Nsi4YGRmHQECA1dUfsLLyDdz2OviyfAd0Oh2EF5p/2kwik6OPEVPiARKJBGlhWR76+y0wNuYCg6Ez
+ NDnphwl7B0zZtb/XhCYgVL4yexoGjXuF0WfMEfvTjYD09HRCOa5SlRk5bhby8vLvpaWltbKsD2wvdTA7
+ Vfd9xlcOg+ZL4OUPwzu2dG3YyDyw9NIHwgvwE4vFJCUlRZ2amtqWnJycjZXnzOB8dRRCARXMT8tjF2Cd
+ nz4Ar5/vcA51M6WJADFd7qTQZyVyJCkpqf7aBZGHH82OhufyIfxhH0Q/N8YqEnBmhPsfMl2JgG3UtJ0i
+ oexK0NlKOiiuzXTdIFx3G3n76CZhe28Rwx+y4Aflu5kbswAAAABJRU5ErkJggg==
</value>
</data>
- <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
- <data name="magnifier-left" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\magnifier-left.png;System.Drawing.Bitmap, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
- </data>
- <data name="icon_measure" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="application--minus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIQSAHFCCr2NKldCE9ajLmddJf7nWp3M3BJEd005EQGM5AGK4wGN4QEzZgGK5QE1ZwI0
- ZQE0awE1Zf///wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBF
- Mi4wAwEBAAAh+QQBAAASACwAAAAAEAAQAAAIWgAlCBxIsKDBgwgTDlSQAIIEAwYeRoQogSGEBgsiSDhw
- YGNHjhIwRnjAwIFCkiYVqlzJUsIAAS9jwpwpswABmzhv6swZAEGAnz6B/uz5E4DRo0iTAmjJtOnAgAA7
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABbklEQVQ4T6XUsUsCYRzG8ZdT
+ BwdBl4ZGFycRnJycXBwEFYTiwFErIgihpamhqX9BRBBMEOTgSEShKfVCowSlBCchDxRRUDgR5en9jRUG
+ b77wgZf33i+878EdA8D2wWKxmJM75hKCqHGyaDQqNxqN7mAwQL//gV6vh07nDe12G5qmgT9DvU6e+fwF
+ zWYHrdY7KpWnLrUsHA6f1mo1VKtVvlhBuVyGqqpQFAWlUgnFYhGFQgH5fB65XA7ZbBaZTAbpdBomkylB
+ V0jyd/CvQS2LRCIn2+0Wm81GCDXUslAodLZer7FarYRQQy0LBoPnhmFguVwKoYZaFggELhaLBWazmRBq
+ qGV+v/9yPp9jMpkIoYZa5vP5UtPpFKPRSAg11DKv13s1Ho8xHA53epRlqG73Nw8eD24cDo25XK5rOr6u
+ 6zvd881GPP7LncXyyWw2W9Jut9/+RTabX1OSpP90JEkK48PKHXCHgqix7vUp02/gC8LYywg0EW0TAAAA
+ AElFTkSuQmCC
</value>
</data>
- <data name="databases-relation" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="drive-upload" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACD0lEQVQ4T42SvW8ScRzGb+B9
- 0oSBl8EAIWGAOLIhgyMkLCxOJgaNbwlDBzGVsz3BPwAxosH42qiHl1LbhuRsKJQ3y3bm0pqI9dQj7VWM
- k+vj3UktR7DyS57ll3ue3+f73JeIx+PEFDorf3NzkqYxE5FI5LwkSej1euB5HrXaJlZWWlhf5zB1QL/f
- R7fbBcuyePFyEQ+KJZSYNTVgIpp8r2CrDygE4wH3izRohgUxjsRxXyGKvxCNRi/FYjFCOW63O5RIJN4U
- CgXk83mQJIlUKgWKokCMIzWaPD4LP9UAn8+n+E9mb2dpTQcb71BerYKtdQ4DDpA2Whx2hIEaoJipbIb+
- /mMAzQivGNx79BwLi0sgxpFyuRySyWTF6/WemcvconcH+0iTZFUTQDO4+/gJnpWZYQcjSF1uGzuiBDJD
- 0d/29zBLpqsej+fc0R2MIK21O/ggfIEg7eJ6+kZVp9OdCoVCCU0HjTaYSgXL9bfDDkaQ2HYTW8InXEvP
- qman00n4/f6LmhFKr3HnaREPlxb+3UEwGDxttVoJk8lE2O32GS1BC6XKMsr1yrCDEaTG+01six8RDocv
- uFwu5TeeMJvNV4xG45xMdCBKr9dTBoOB+rMHI0irHRacwCMQCFy22WxKwDFZdlmOiVI3sXGIVOea4MUt
- OByOGdlwXF3Fo84Q6y+SPPO8xWKZl7GvKlv8P/9vysUMoJZl8vEAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACS0lEQVQ4T42OX2iScRSGD3QR
+ C4QwiBH9WV3U0qLIiyyoNuyiG1FBRwwsRqtR4BZFuQXNbiRydNMgmEFrxC5WBJbZZvbH0pVuXwyJFBW1
+ DWpaQYsIzVGn3yv7bGOw+n08cL5znvdwiObeirpdtKGlj3b2xEnbm6V9Nz5SQ/+n/QA1epjBgVt9qw60
+ 0roj12nzxQjVXxr/u8D94ZAIShVELS+AAxcZZCs/MvKC3dcyCEi9ud98NfmLUaOHC+QFcmbRgh2udxCl
+ nsQsd4Z/cEfgOzvGi4weZksu2OIYgyBdfvuTnbES2/yf2TKQ4uP3p7jlXpYxgzP/atpkf1ll4/kXfXXn
+ gpJMx5NpNt6M8/wenPmZBQuESOvPPKW1pwNUe8o3ah0pFBtvZ4uo0cMMzoIFe45dIbC31UXbbYO0xjZC
+ K4/eAbcO+r9F6u9+iYi6Hz3M4MCVc2QwGCqYTCayWCykazpJNU0DoH1rYNalfFB2oUYPMzhw5dyiBRAa
+ zW20zOBuqH3MxuU+NqJGD7OlFijMZnOzoO0fNIsLFNUL9Ho9zWENhUKpWCzG0WiEg8FnPDz8iL1er+Ch
+ wC94zkNDvpTwrXKONBoN6XQ60F4ul7lUKvHMzFfO56d5cvI9ZzIZQVYwxZKU4GQyz3CRQbby1Go1abXa
+ s4VCgT0eDzudTnY4urmrq5PtdtAtcPIJ8UUiCYaLjPxqRLFapVJdEOfm0uk0JxJxnph4I+TXHA6HBaOC
+ KAcCr9jtHszBRUaALCkF2xQKxWGlUun8H+Aig+wfdPytZLAK/bMAAAAASUVORK5CYII=
</value>
</data>
- <data name="arrow-return-180" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="arrow-270" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAClUlEQVQ4T6XSe0hTcRQH8IPm
- Y1ZWPnK2yqt/NMpHPqMkUaNCqn8iMYSbZGFhSMtCS6RBD4VmDxqVjCywP9QwLa5GPkK9PVDHtVrlkx6z
- 1WbhH5kSE7d7OnduK8T6p8GHc36/e8733j8GiAj/A1JvjTmk3f6qI8I/6OkZR9Q0z6TcNENy5ScAqXES
- rhkRL4+I87pE9+VvbdYCfsqytXqMp510R8CmG6MugvaDiJoBm9uFfhu6lL+eQbV+Gku7rVjS+3Myreoz
- T7sMbNC+d9ElXX0n/E2q7qMhp+mbqfjplF3VPom5zeNmmlW7A+gAiVdGIFbT7yD1f4q/OKiIqxjQZN+z
- mApavmNhx4SVzhwo1b2w9owAUedfOvqocy9Yoos82we05A6Jo9DosleKpIo3hpyGUcxrtiDt6EF+5CGs
- VLVBxEke1pzuYSlEcAKmqAtWFT52iDj1RHquiCnrM+yoM+Kuu0akud8B4cVdLIUIWqMdpRp2osO9LAUw
- RZ0KutdsrBw0RdeYcXPdFyududkvONrK0lcIpUM2zOqeRqmfK7yEN0RdHzIp70/Y5fU/MLJy2EwzagjJ
- b84gQq5BRK8HM7iuw4479SJu6xEx5bmIibzdcRfWZkP/Jhv6cTO4unZ8Uq5q5enlDAQcaMggwnY9/ac5
- xCWPEBXtiKFE3oa4nAS1Iga2iBjcOGWVa4ctgflNfODBxvTgwxzAsv314L+vjl3M1gpJz2YXpX4eerrj
- iJrmGXopLEzMBpDFZoFPTCb47b3DyrKqBWUnolR9t5SCd/Seefmsz4S5P0+6kC1IPnbIa3eVIKHzCqdQ
- qiEkiCwli4gv8SIeriBvagJImEdCnsoj+XgN9QlO8VRjiJIwRO4MklH1/AWgVvXWOcn9vQAAAABJRU5E
- rkJggg==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB6UlEQVQ4T6WPT0hUYRTFPyYH
+ QkkJMpgBNSYEiRY2SiAyFvhnUy0Cy4GeQpS6UDeaiQ4oucqVQiKOWIumRdMgWlHSX7UYXXhdCLpSU2FM
+ Z1NYDI4gc7p3cOS9N86qD35c7jnnO+97CoD6H+KXrzzdMXD1WdjLkA6vOZP4aLzANbJlhgY3gP6VGJ6s
+ A+yTOWMoKBnaVCaob/kAnrkoHi8dgD0yZwwFF3oXVPHAih56tBBFy4c/6JnfA3uk9yVvKMhr+6ryPUFV
+ 2LeUgDxzETS8+YWu2QhYp4QnOcknFZxrn1LnO78raWeofWYXNb51NL4NQXbRxZdcygIxHR0zKr8rSHfH
+ 1lAxQKj1r0J20cU/tiC39YuXW0mPO/ADZYOLuOVfg9mTvOEX7M2Tmq3pPTUHd3F9YhvXxn/C9WIThSOr
+ KPVtoDIQQsWrEKrfhSE5yRsKWFTZ9RPamfvjdPvbX+T6wkmUT/6G+JKTfFIBmyqrzq9l1r6ksul9ZAYi
+ R1z6GIXo4ksuqeDU5Tsq3elWGVXdKsPt09JrnlPBVAyW1zE4Pscgu+jiW20XlRzDC+LK4bGcLVBproea
+ 9eYo2T8BMmUXXX+OK7ByIIdxMkUW570HlhvDJFP2Qxw8T6Z6wQk2shgbY0/BadbT9AX/ADWhA8f0EOn9
+ AAAAAElFTkSuQmCC
</value>
</data>
- <data name="icon_zoomnext_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_panleft_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIZqAK2km+XXyefi3uvv85ScqJWdqPb3+OXn6cHCwq6vsJqirpWdqsPJ0Li9w+fs8cTJ
- 0JKapqOrtN3g45Wcqu/y9dPU1sjIyJ6ksNHT1dvg5dHU1/X2+Kurq73BybGztbe5usPExbO1tr69vdPa
- 4O7x9NLS0t3k69TT05OcqZubm6ertpWdqbu7u9PV17q1sLm/yK2trP///8zQ1MLHzM7R1ZObpsTGx6mv
- t9ni6qCosvX297Cvr/Hz9ejr7qOqtMbJzaSkpKSkpcnKyvL197W2tufp6ru8vdXb4ZaWlujt8ezt7tfd
- 4s7T2Le9wqiuuNvf4+Hk55afrMnLz8LDxPP09dfZ3ejq7Ofn6J2ksOjs787Q0pScqcLHy8C/v62trdbX
- 2MfKzdfY2aqwuO7w8tPZ38zNzejt8pWcqdfZ27m+xAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ R0lGODlhEAAQAIZuAJumsOTY2MS5uK+2vcW5uJumstrOzsi9vOHV1eHU1ZunsuXZ2dve4d7S0aaxvuTX
+ 2ObZ2aaxvePY2NnNzODU0+HT1Ofb2sTJ0c7Jyfjz9J+rttvPztrPzpumsdbS0pqmsdfR0dbS0aSvupum
+ s9zPz9/T08/ExMzFxNbKydfOzdXJyqOuutjMy9zQz8fP1tvPz97R0dLLytfLysG2ttPQ08vEw6Ouucq9
+ vs/Dw6eyvuLW1eXX1+TY1+DW1sa8u+LV1vj09dTQ0NPHx8i/v9fKy+PX1pynsc3BwaSvu+fZ2tTIx+PX
+ 18m9vJqlsNLMzMK4t8zAv9zQ0P///9TR0KGsuObY2Mu/v6CrtqSwu6mxu8m/vubZ2pqmst7T0tXKydXJ
+ yc/Jyca9vcbL0si8u7e9xK+3v5+rt8zDw9PHxtjPztrX1+fa28/S2NTMzAAAAAAAAAAAAAAAAAAAAAAA
- AABqACwAAAAAEAAQAAAIqADVqNEAhkaXHSJOCFy48IaKCyhyQJFQwQJDgVIalDnwYgEWHlmeTLnYpEQY
- HTGc1GBAIskPIQwfsChiYAwTCAoGOCDj5SIMKgZ6LIlSYEuEKykuElGyQYyCCWdWVBkR5KKNL0MopCFA
- wAeOGR8uqkFgZYCZDgUOHPGARiwGBFoymJDBJUQCsQtBcEACxEiLBAACCMArFkDgwYQZGhacWHHgxopd
- QL4YEAA7
+ AABuACwAAAAAEAAQAAAIvwDdCBxI0A2DAQUTCjQCoGFDNy8CEEgBpuDBgT2gcIAgwIIWNQrd1FhAgMQD
+ AWvOBFF4wkQAAQZ4CNjSpY1CH2iqENjwQEgSCTEUzmgRQAmFCgkWSAihcEyAJSUo/NgRIE3BI1EQ3JhQ
+ AUECHUUg0CAI4kmDBjhUyDAAw0AGNggHehiCYoIXFl+IABETwUyZgk6sHDjARMoFDRGwXMmScAqGMC4U
+ jBDhYAWXkG7IFCjQhEoOG5jdICnwoYMCBwEBADs=
</value>
</data>
- <data name="icon_pandown" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_panleft" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
@@ -491,24 +555,12 @@
- ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAACDACwAAAAAEAAQAAAIwgAHCRxIkOCBgggNCrTjJcCUKgkH
- NRgkQoeQKwDIzIhTMIGABBN6BBgxAICSPxAIFhBQ4AwdAgDW4ACAx8kXgi4E5uCQJ0CbAR1upPCR8EOY
- Lix+vNlj4gKDhBpUwNgQAkURAmgKeohRJ8sSKQvMPIkQRAzBJFiMKHhRQtCYPnzApLFCEAigFVBAkKAS
- iEmUMn62FGwxJMMJPTzUHKlQgwYShA/kaCFi4E4TCRgsRBzEBQGCOTbcwNk8iA2FHQ4MyAgIADs=
+ ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAACDACwAAAAAEAAQAAAIwQAHCRxIcFCBBAUTCnQhQECDAwcG
+ 2fESYEqVggcHitAh5AoAMjPiKBw0oUeAEQMAKPkDQeEZOgQArMEBAI+TLwpzcMgToM2ADjdS+FD4IUwX
+ Fj/e7DFxgYFCDSpgbAiBoggBNAU9xKiTZYmUBWaeRAgihmASLEYUvCghaEwfPmDSWCEIBNAKKCBIUAnE
</value>
</data>
- <data name="icon_maptip" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- R0lGODlhEAAQAIU/APT19/Dx89HV3PX292tpdYuKld3g5N3g5by9xdnc4c7S2dXY3snO1sbHzJGQmdXY
- 37K1v+Dj5/P09Nba393h5dTX3czN0PP09dfb4M7S2uLk6Nrd4tHW3ImJlGFgbezu8bi7w93h5NTZ3urr
- 7oWGke3u8eXn6svQ2O/x8+rr7enr7c3S2ZSTnMzQ1+3v8dHW2+Hj6Nnd4t7g5c7T2tPX3eHk6NXZ36al
- rGpodMvQ19nc4s3S2ubo6+3v8EZDUv///yH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAA/ACwAAAAAEAAQ
- AAAIvAB/3MDho6DBgzhuCCQwoOEAFAAifog4gMDACDky7tjIkQGDHBEIZtTIcWOLExkLztixwsPBghAy
- KFBQUIBNGhUg+CCxkYOAFwIKPrCxYIENED462FhqQ8SDgjES6MAwAYGPAjqyStVRMMQBCgY2WMWqw8AB
- swVrqK0hY2zWGjBqaChogoddHg18OLh7t+AIvnn33lWRomCPw4ct+GCB2EWPEj5wBAiAuPLhyQESEpBg
- ufIFCRYFEnyJUGFAADs=
-</value>
- </data>
<data name="tick" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
@@ -525,202 +577,147 @@
QmCC
</value>
</data>
- <data name="icon_panright" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_zoomrect_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIeDAJhpZZpqZiJNeNikptelprG+zCBPfSJNdyJOfVJvjMybl9Kgn7ShnSNOeCJPea2f
- nq6entWjojVkl6CBgB9NfjVjlB5OftOnqDJejp1xbp9wbM6cnbWEgbaGhKh3eJBkYbeKh9CdnM2jpMeU
- kcCNirqIi9qoqZ5ybdOfodSmptenpbuKhriHg6uWkyNQeq59fNakpciYljZklaB1dCtXhTFhkC1Zid2m
- qdilpJlxbah2cyBPe////9ioqLCRjtCdmrKiotuop8OWkaZ0c3+hvdmhpMyZlipZhkFiirWgnd2prcGP
- jvXm6TNfjcmdmtShoMKPjoKVs9KanbmTkrqIiaiOjVFwjNulpZJnZqNwcpd0dE9wkGF8mNimpdimp7GR
- kvfk6MeVlKyfqcSSkd6rqDVjk9KeoqGEgbyWk5emu36SscSUkjFfj8WUkDdlltOaoDJeirqurqOPjiBM
- eax/f9Ghn8aUkyBOf9yorNympKJybtKeoMOTkcuYlShYh6R/fpx6eL6KjL6LigAAAAAAAAAAAAAAAAAA
+ R0lGODlhEAAQAIZWAI2aptjb4q2km+vv8+/y9efs8eXXyfX29/b3+PX2+PL199Pa4Nrl6a6vsMHCwujt
+ 8ujr7uHk5+Pp76SkpLu7u/T19ufp6qSkpfH09vP09fr7+9fY2aurq8LHzO7x9Ozt7tbX2NPU1sC/v8nK
+ ypubm+Xn6c/Pz9LS0t3g49ri6cLHy/Dy9N3k6/Hz9dXd5czNzcjIyL69vdvg5cPExbO1ttDf4ejq7Nni
+ 6paWltrb3Nvf4+js787Q0uXp7ezw9NTT08bJzfP19ujt8bu8vfL09uzu8LGzteLp79PZ38TGx62tre7w
+ 8t7l7MLDxK2trODj5be5usXQ2tXb4bCvr9bW1rW2tgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
- AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
- ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAACDACwAAAAAEAAQAAAIwQAHCRxIcGCCAgUTHjjQQIAAF4Ps
- eAkwpUrCQQcHidAh5AoAMjPiXBw0oUeAEQMAKPkD4eIZOgQArMEBAI+TLxdzcMgToM2ADjdS+Lj4IUwX
- Fj/e7DFxgcFFDSpgbAiBoggBNAU9xKiTZYmUBWaeRAgihmASLEYUvCghaEwfPmDSWCEIBNAKKCBIUAnE
- JEoZP1sKthiS4YQeHmqOVKhBA0nCB3K0EDFwp4kEDBZGDuKCAMEcG27gaB7EhsIOBwZkBAQAOw==
+ AABWACwAAAAAEAAQAAAIqwCtABhIsGDBAAIDKFzIUCEAhA+tSJxIMaFAK1RETInxo6JFKyZyPImAIgSM
+ ihFflFhR4UCLHTqaUHx4YsOBIhoSYPAgBMiIiQ8pWECwJAgRAgMKIFECNICTDAgg9CDgo8CRFCSaVvmQ
+ QAHSAgyYLLhwMAkIrwMeMKhxowOUhlYc2EgrwUUUKUY8SnTAQwaLBSpoNNArcQYHHBOGWGkgwABhjwIa
+ P64Y2bGVgAA7
</value>
</data>
- <data name="icon_tasks" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_zoomin_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIYAAAAAAP////39/vv8/gkiTxAwYzhfl2CW0qG30Pf6/fb5/Pn7/fj6/Ozz+ery+PH2
- +vX5/OXv9uzz+O/1+djo8trp8tzq897r8+Tv9uPu9efx9+z0+fP4+9bn8djo8d7s9OLu9eXw9urz+Ony
- 9+jx9u71+dXn8Nfo8d3s9Nzr89vq8uDt9OTw9uPv9enz+Ofx9uz0+PH3+vX5+9nq8tjp8eLv9efy9+Xw
- 9erz9+nz9/D3+u/2+fP4+u72+fn8/ff7/Pz+/vv9/f7//v///wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ R0lGODlhEAAQAIUhALK8xpKYoa+vr7Gxsaurq9jY2LnAxcfHx7W8waq1wOns79bW1rOcjNDc4+Tk5PHz
+ 9am80YGYsuzs7MzOz/n5+dfk7PHx8cLK0tPh68fU4ImetOz0+cjV4dLe56Omqfz9/cvLywAAAAAAAAAA
- AABDACwAAAAAEAAQAAAIuQCHCBxIsKBAAwgTKlR48ICBFxBfGDhAkSKBgwUMINiIoIDHjxeHGAhgQEAQ
- HwxkcNBhYEOOkAaEGBiwsIcBBy9gAjHg44cCDjFKwDCggQVMmgkUwhBhIAIImAsMyODxYEIDFzYM1FgB
- k4EBHgtDGFjxASYEAw92wMjxAkMLAyhUwORgwCbCGyBWGLBQAeYDAzBwkAiR94OBCh5gTliokMYJmBJG
- aIiQYcWFFDModDABk4Dnz6A/DwkIADs=
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAAhACwAAAAAEAAQ
+ AAAIrgBDCAxhgIDBAQUGKgxxYMACCQ8sOECAYCFDBAoeAAgAQIGEAwYWDrDwgQKACB0VOAg5EMGCDRQ0
+ Bkig0sGCigIFSACQAMBGCD4BdBAwkMADDQECREi6NEADojkV8PQZAEJPAE9bFmgwoUICjhUwNABxYOAC
+ AwsmcPiJIUOBASIRXDgAgWOBBAIOTBA5wIDfCwYEeEBo8YAAAQQEwA3BgEFCi5AJOIYceTLlhZIDAgA7
</value>
</data>
- <data name="icon_refreshmap_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_zoomnext_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIYAAAAAAP////38/f7+//39/vz8/evr7Nzd4M7P0s3O0bGzuOvs7n6Ej32DjnyCjH6E
- js3Q1c3P0szO0ers77K4wLG3v6+1vYaasLC3v6+2vq61vK+2vczQ1Ors7unr7fb3+N7f4Kqtrpienqes
- rKisrKqtramsrN3f38TGxvT19d/g4Kesq6isq6qtrMPGxcTGxdzf3c7Sz7a9t0J2QlqAWneNd3uOe4KU
- gpSllJmomaOyo6WzpdHi0dHh0cXUxdbk1snWyd3p3dvn26avpqOso97p3tHc0a22rdPd0+Ls4uXu5cTK
- xMHHwenr6f7+/v39/fz8/O7u7v///wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ R0lGODlhEAAQAIZqAK2km+XXyefi3uvv85ScqJWdqPb3+OXn6cHCwq6vsJqirpWdqsPJ0Li9w+fs8cTJ
+ 0JKapqOrtN3g45Wcqu/y9dPU1sjIyJ6ksNHT1dvg5dHU1/X2+Kurq73BybGztbe5usPExbO1tr69vdPa
+ 4O7x9NLS0t3k69TT05OcqZubm6ertpWdqbu7u9PV17q1sLm/yK2trP///8zQ1MLHzM7R1ZObpsTGx6mv
+ t9ni6qCosvX297Cvr/Hz9ejr7qOqtMbJzaSkpKSkpcnKyvL197W2tufp6ru8vdXb4ZaWlujt8ezt7tfd
+ 4s7T2Le9wqiuuNvf4+Hk55afrMnLz8LDxPP09dfZ3ejq7Ofn6J2ksOjs787Q0pScqcLHy8C/v62trdbX
+ 2MfKzdfY2aqwuO7w8tPZ38zNzejt8pWcqdfZ27m+xAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
- AABSACwAAAAAEAAQAAAI8AAxZKiwAYPBCgYvSFm4EEOBhyYKEIBSAAMEhQwxPHlSwIQAjhULcMAoxUIE
- BBFKJEiAAAEGBgweMLRQAAGBFQQeFjjQoYPMhRUiSIgwooAAJwNSDBhgIGPOAiEkDlhio6oMhhkKqECx
- 4gWIADYCiLVBA2gBFwRIEEAxNYcSJTaQ5JCSgQQLEytYtIgypImRJDaMGKGhoQCKAi2guBhwI8gOGzJ2
- FKmBgcCJFyNcgHByQ4gOJjZ0CKlBocDGERudHAECJGwTIDRKd/AgYsKCDzBw+Aj7A8cMDA4aPAjuQIGB
- GETC8uhhg6Fz5zOq2pgREAA7
+ AABqACwAAAAAEAAQAAAIqADVqNEAhkaXHSJOCFy48IaKCyhyQJFQwQJDgVIalDnwYgEWHlmeTLnYpEQY
+ HTGc1GBAIskPIQwfsChiYAwTCAoGOCDj5SIMKgZ6LIlSYEuEKykuElGyQYyCCWdWVBkR5KKNL0MopCFA
+ wAeOGR8uqkFgZYCZDgUOHPGARiwGBFoymJDBJUQCsQtBcEACxEiLBAACCMArFkDgwYQZGhacWHHgxopd
+ QL4YEAA7
</value>
</data>
- <data name="sort-number" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_help" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABuElEQVQ4T42TTUsCYRSFJwMJ
- QWoXCFKEtAhqE/4EN4E7V+nGELUsAyUcUdC9W8Ef4cKtG3+BuJGgtQiCX/iFIn7d7rk5Mg4JCg/nfe89
- 58yIqKiqqiSTyT3S6bSSyWQcTBCKu9GDHBEpyoEChEJsICjjOFiQSCRuuOSZCenZbDa0Xq8JatzBj5y8
- QTwe97Zare/VakV6lsslaRh38CMnBdFo9HWxWNB8Pj8a+JGTgnA4/IbwdDqlUqlEhUJBznoqlYrMoZjD
- j5wU+P3+yGw2o/F4LORyud3ZONN28CMnBV6v930ymdBgMBBSqZRovV7fnYvFopy1HfzISYHH4/kYjUbU
- 6/WESCSyO2szaLVapVgsJjv4kZMCt9sdxRPb7TZls1ny+XyiuGvk83kKBAJULpdlBj9yUuByuT77/T7x
- T3M08CMnBU6n86VWq/10u13qdDo7ms0maejn8MGPnBTY7fZbm80WZL70DIdDajQaBDXu4EdOCviiWCyW
- Pcxm8x2j4rtCcTd6rFbr359p+zGxnjNXzD3zaDKZnhgVijvzwFwzF8wpcvqCE76fbZeXrLZ/wBxh+PBA
- KfgFcqFa2BgtJlQAAAAASUVORK5CYII=
+ R0lGODlhEAAQAIfIAOXl5QA5cw4/cnaYt/////Hy8UJyoUl4pjVtoQs8bhRGeDVqn+Xi3hBPjkBwnhJH
+ elF/q/Dx8FWHtVaFtWCPvVd5nxRIePDw8AApYCdWhEdskRFCc16CptHt/0+DtgA5a53K9wU5bFaJuTRq
+ n0p4qUp6qVqItiBZjWeXwkVzorbK3FF+rPPy8Q9CdwAhYCRUiBhVjTZllW+gzzlqlrDV+0luk3Wo3Xyt
+ 2TpqmTxrnFOBq26h05WswEBwnE1wl3Om1ZKtxc3p/+P2/zFsqOP4/43B802HvwdDfj5qkjx4sXONqG+W
+ wBBBc7LI3j5tm3KVt5aovPP7/xtMffT//yJUg2eMryRTf4Cs1xFNham7zEBvoGSTwFl+omGRw3ik0WeU
+ wFJ2m09/qej//3Wn2rLE1fPz8hxMfRxMfAAkXB5QhShZixJFdwU9ciVWjSVXh7nM4FiGsypbjISv2VZ7
+ n1iGsQw+b+fv+liNu7fJ3VyApQ1CclSDrwQ8cEF1qXSn1DJik2GNuVGBr8jp/63D1Tx0rHiRrB1Pfe/w
+ 7z90qHao2aSzx8rX5SFRgvD9/5+30B9PgeT9/z1lioiy2/P08itflO3r6CFQgqHQ+3CeyQAkXWiZySxd
+ kOXj3lWJuwAuZhtQgrLF2QU5a3ut3oKu2DRkkgAuaYqiu+Pv97PV+c7z/yRfmyRXjMfl/wAza+78/3yf
+ wO/y80l7rkRrkOTr78Xa8Ut5p0d6rythlTxrmwpBduXv+Z2uv6zT+Fx7mQAnYPT08kt6q3em1iRVg5qx
+ yGCNvBBIesPe9jl0rP///wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAADIACwAAAAAEAAQAAAI/wCRIasEq0CBMr8msSgQ4cIhTgLt
+ 2BjjZ4eRJMeGEOqDAMEAZABE3ZAUTISjN01A6RhRK8WRAQASybmyZRYqVh1oRKlyq8eqPAB+jOqkAoQx
+ MkBoFdEV588nDgBkeJlwasoiVQ148BKC5MUDLgA0YaKw5NUeYFiyXHKVIU2uCgC6oPgiIVaJE4qCQDLF
+ hgofMADuEAMEZwWlYYKIQCn1yFArHwA8mKADwQCpRql2uWBkRoGnGgBsBQpzANemQXgsFZOyhgkGDQAQ
+ kTjgYEabOb2EtbAgoA4aWQAWGNCCQ40VAmIK+dqQIJSASABg5HASw80ZAgSUZNIT4oOAj08CiA8fT17A
+ d4EMAKhfz169wIAAOw==
</value>
</data>
- <data name="icon_zoomnext" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="arrow-090" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIZ4AHBJJai7zuqxd9nFs1tgZLjH1xc5Zs/a5CtGdezw9Bg5bypGdWV7khY1bKu0vNjm
- 8oOGiKqxwcfb8GBocEFagpKfshI0ZKa80cza6JGRkoSHi622v2d7k8LQ3aSttmh8lre/x67L567C1a6y
- t36QrjhUe5y20ODo8auvsz9SfSJAcoSFiBIzacvY5YSAfzAvLjg3N2xtb3V5fnCCov///6amp3h3d5Sp
- vhg4Z+rv82RgXzBQeaCnr5qbnV5cWpmirEdhgdDh8hc2bEdKTevw9cXa76m1w+Xq79Dg8crc7oaKjRU1
- aLC/z56quGRrcr7L2KTF52Z+oVxbXcjQ2OLr9RY3aoiOlEpMTIWUoxgzaqC50tri6s3U2YBqV9nm8yJE
- cZiktMfS2Ofu9RMzYlhYWc/O1KuoqJyzy7bBzXqSsH98e6q8z9fb3xU3ZzhWfG50enyPoomXpJSVl6Wq
- sY6XqM7X30ZegHyQowAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQB
- AAB4ACwAAAAAEAAQAAAItADx4GkSB4wLHWrMCFy40E4KBCx2PEEzJwNDgXQ49JgSpcGCExiYaLjIoMaI
- HDQojEnzIAkWOQxJ2OCSYMsNCyqQFDkjhaERH0eItLigwEAVN2VgXIzBRgyQL0Ky4IhgYshFKyioePnQ
- ZkkJKHfeXASxok4QCTMMhNEywcFFPDwg/BARogIcJwTeCtyghMyLKzI8EAAgYMDbAwXWFDiAJwAAwob1
- MnQMWfLkxwIsX+6ieXKHgAA7
-</value>
- </data>
- <data name="database_share" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACqklEQVQ4T5WSa0iTURjHz6oP
- Db8EpfghDLpRKH5RhBXJGIE52VzNVaybEGibFZZ9UNIuGDgIxRRzF3NL1FDx0tzm5iWdl3nZ61Rkajd1
- inOogRJlkPDvvAMTh4Ed+MF5Xt73d97n/xwik8lIACJap+wC9j0S+DERi8UpS0tLmJ6ehtvtBsOMwmzu
- hdU6hL6+SfrMi4WFnxCJREqJRLKzwOv1wuVyob29HSaTBbqyWhgqjGg29WJg8CNmPav/K6iBvqIJRnM3
- +ocmMOP5tiXg8xO2tUFbiFIoFM1arRZqtRoqlQqZmZnIzs7270tLS5GRkdFCW4jxtxASEhMoCMhgBKYW
- O0y2HnQ5hjHi/ozZheWtPyAkfJuEDTEwA62+GrrKGtRbrOh2Mvjkmd8uYCWbo9xJoNFXQVv1DnUtZnQ5
- BzE1N/NvQXLiuV1lIBQKYxISEghd4cMsUqk0lcUgP2gbe6OEU6uEqyEfTocdzbYONLbaYOu3Y2DChSnv
- V/D5/FSBQEBIenoRJJKH2NjYgNFoBL7U+Pk9WYn51jy0qpJQnnsbakMxqqz1aGM6MT43gcjIyLQs4WFC
- 4uPTwONdh8/nQ3V1NdZdOqz1Ff3lB6PBVH0WGp/Go+r1Ixhr82EpkKNQxHV0JO9Tkujoy4iISPRfXY1G
- g+8DJRgtT4O94BraVDKMGe5h+cNL/KLit/fPgCm7g1V6AFs3yffqSFycAlFRMiwuLiI0NPT5K2nw+GDJ
- jRXP+ydgNCmw5Eqgv8uDNjUanflyzBtz1nvyLrgbFMe69Bf3XKEhnlhjCQoKyuNyuQ/OhpGbj2NJXeGl
- Q+OOwqsrPksuNmHr4qTgkRcCTsn5oxye+BSHnQIJo5ymRFCOU05SoqjoFit6xifMJjmxpDb2CKH3lxyg
- 7Kdw/gAsOxzv+3rD2AAAAABJRU5ErkJggg==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB1klEQVQ4T6WQTyjkYRzG32ax
+ WlK7xvhzsNnNxko7RYkiBzkoBwfZWtMmm4ucJIuTPeHCblgkB8q/SRPbYvewbStcvnsQ7QEzWOYgcVAT
+ iXn2faZ+mjEzqH3r09v3eZ73eX/vTwFQ/4Pv8MsPv5W1c0Pl9myp/P49VTjkVsUjh9Ua4c6ZOn3mmDcu
+ DVfAQzLoBrhrqu9f0LfLsHzeB9pWz9H/F+Ccr/W7v6B7kyHp2/Oi4dvpNR+dV6Ceq/2wT3jVsU5TPrmu
+ UDd3EkTXnwvQZy7oH2S2C0Xp3rpE64oHLcse1C8co2psB28mXKh17OKt3YnmpSMwx3zAT3zRtjKY3ros
+ /tTMOFHSI7BNbeOmx3xAgQ6o5++XfDxr/qWeNv6Q13YXinrXUDnlBGfqRob5kAVpTT9Vcv08kbIZN6xD
+ 2yidPgBn6vRZErJA36LM7xwGkjd7gtSxQ+Q4jqF1MTzmggriC2tVtLVSxdkmDST96xni7B6kfdG7bVIM
+ LyIpS3EFPMGn6PXAkqkeVY0SsSx6YZr14smCF5yp0zdWyAKapoQMFVkxLJbvQOw88HgR4Ezdf4UqeKgD
+ TOWYChrHTeUDco2eqWuyNTHhnhChDbMm5RYStRflX/AP4Mv/7H+tMgIAAAAASUVORK5CYII=
</value>
</data>
- <data name="image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="globe--minus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACAElEQVQ4T6XTT0iTYRzA8efk
- Jbp0EOpQFy9drIMXVyhaEbWsjBUxTCmQOf8wojcYMWcmZKM/tsoKCXSXVtiqJdlaRmVeKjH7Y5pKUNvK
- zD+DuS3X5rfnWaeObi98eZ8Xns/z4zm8AhDZlBVWg8X+pqYymSnDysQ+m61GnpTRo6zYY7WaU0tL6M7B
- 5vNQchG2XYbiNii6ALuugbETKl1w8iF0D4F7EJRRVug1rS6RSmG+BZY7YJebLj2HEw+g5dG/tVPW3Aue
- YZj8Be9DoIyyYrvF0hBPJmnpGeD2YAj/KDz+JJPv4SD45PqehD0f4MUEjPyAr3OgjLJiS22tJZJIUNx8
- mB2OOpz+Pt7JCWrjhJw2Pk36OzAPX2YgGIa5KCijrCiqrj46v7jI6kObWF+vR2er4JTHRWf/M3wfJxn6
- NsvoVJSAhGkck9P/gDLKisKqqmMz8Tirdh8gt9zIWuMRNtZrFGqNbLWfYa/jChXtXZhdHqx3n9D+coTe
- sTDKKCsKjMbjU7EYBaYOdA1dlGhu9HYvB88+xdTxGmv3GI6+ENffhLn5+TfeYAqfvFraSCs2GAzW7wsL
- /x2ws/E+hlY/lc4BzDfeornHsXuDtPpnaeuPcvVVEmWUFetKS+0/5X0CkciyUkZZsSIvr2Zlfv7pTFJW
- yCdHlitbs8yUycn6b/wLvnCph/venGUAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAADSklEQVQ4T4WRbUxTVxzGD+1M
+ JGYuMSFmiyMOQQuaiDUqGwsRGG+aoCRkKpHOlymKi2SZQkKmbAxtKC8FtUoDErRQFalhzhpe3PaBqZRC
+ G7RNKavWKbRAJZQi2lXWZ/9zxU9+8Ca/PPee//M859x7mejYfSYqMjLxL38zsfyfhWLF6FfiCpeCaCO6
+ 51UhrPM5+bif57JKvmXCjVBQal9OQ/Wmhqdm+V/PPVqrz3/T7gsOTM/5WxwvPSlal5nPue9tAc++KSg0
+ LP+oxNxe8NtT13XbFPp9c2ixTqPeNIV7E37YAoDtX6DaOOniPu4XckJBnj5UlN/VWND+yF3e40aX208F
+ QbRYpqCz+9Az7kefdw59s8C9F8DpHpeb+4Vcnp6xkN3atJjiDus314Zx6KYTl+wvUPrHCE78PoIrQzP4
+ cxI4qXdAQ+s3xoC2Z68Rdfy2ledCcjRUkHXhjOyiaSq90YaUpiFs0wxhR6sDubrHONzuxO6mB8g8a4By
+ MIBiatune4Ic8vMcwRhLK+/4Xj8WSFRZsFY5gLg6C+LrLUhosOJLlRkynQtFd//Dd92zSFCaEFthxJY6
+ U4DnCCpI/NkQV3InmNw4iqhTBkgqBxBdaUJMlQnRCiOkChMSamzI1s3i02OdkFZReWVvkOcIKtj8U2e8
+ whj4rLQXkfJ+RFFg1TwS0qiyXmyscSC1ZRbhBZ3YqgOyNOMBniOoIPnUudVFHd6V5Q8gqXiINdUWxCot
+ kNZaBWKrBrGp1oG1ZYOIV48hrQ1IVj3y8hxBBelVGUtyNcPrySQlvlA9RpLaibQGJ9IvPkFqvROJFxzY
+ cNqMr29DYNnhG8OrN+ZnZEemUkHm+VC2Xd0sOdnnSVK7kdk0jl3aCexp9WD/dY+g8qRcqMLXoEGynjT6
+ dc2isEltiMikZUzN2I7LjO1sjvggt7VLKrd4ZFe9ONLuww+3ZlConxFUGbkOr2Syd6hjrJ+OQNfSGHqV
+ sgi299fmZYV37dvqR735uunA8Vsvg1yPxO98dTRshf/o4o8nfxQveEifrp9TJpyAMTERRkSzD5fGsc8P
+ HmCy1kZ2sKOb5XUZBOXPfJ3PGaPdWFg45fg/4JeIWDRf8gnp++CbcT/Psf8BxLcXab+EC34AAAAASUVO
+ RK5CYII=
</value>
</data>
- <data name="layers-stack-arrange" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="ui_menu" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACuElEQVQ4T4WQb0gTYRzHnze9
- it5ERC/KIOkvUpggRC8qKggiiqQXWWH+CSvMtNIoonrRP6LAwoSiCYqmc61tOp2bzm06N4fTuXm67c7d
- ttttt+223ea2eiFxPY8xuUTs4MPdc8/n+/vec6D4YhMoejgkJA+uz0NK/wNy8kDVq9g/Aw43ai7osKjc
- x2Y13mhmcC3QHnKQKxyw3AxftnxSLzjeyF3GtfjQj+tVtrCMjGTUhQ3qa8sDLr/wg1zz5EIc80az0QUm
- HVyNJ5wJjbti1Ltelw4PpZWH7qvKQOVLtgQOISH8etQ3xZZ6dIkIDgc/E2Njc4FU38F7A+Wg9AlFKsaS
- XK4Zo1IcbP4FG7I5CCb9Uz7K/a5+TS/BIPWo026w+5KKgjplJTh3F+PReZRTIbPDn6KNLpadJrms1ZNY
- FOIOLmaRC4PUgzabwerhZAdqe2+AY+VGHp1HZqFNMEjpsEjEQiQyZjyeEjJLpTLIhUN9tSKrHu5J99XI
- q0FhyQCPziMe95ssRJxSzzCR0Xk2PeSIcCobk1BOMfG+qVB8zBlLIdfkjntvfrboR52sdPct6W2w54wU
- fZaiXU8aDfOst8voDykmg8nvE3RMyAgWTSIXOmRFs9kA7z/yqyU1YNcpCfwsTvZxwG2AQfyr1hP4ZvQv
- SsyBZA/C9Jfh2UgaubCZrhNN2kTDhHL79Y4qkH9agaZ2Pxc7tNIJmmgdIZ0tgwTdrMIZIRIzFUNuu84z
- t6O8U7nlUkvdpuKyIrD/rJYfnAl3PO22a1q1HlJsChBd4xS+GvhPKOSuNAOwDQCwEf5EK6+xh8Xve51t
- jzumdY1tVlODALRGfNG4Z5Gba96weSfMw+vIFYJs6mZYtT3c0z/NdK0F2kMOcmEkf7k5dxWcFF09XhH0
- nagM8+uBnL1H396Bua0rYfjwB5D4p3X4gwOzAAAAAElFTkSuQmCC
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABG0lEQVQ4T53OvYqDQBDA8anS
+ iO0VV+YVxCCxt7OyEbnC6hK4T0E4swiGIFgIQQiE+Bq+kVXQRCFIuujcTp7AdeBfbPGbHdhutybvfWIm
+ hGG4wolDFjabzWoYBjydTtj3/ejIkAXf99cEH4+HUGTIgqZp6zzPnxccj0c8HA6YZRnu93tM0xSTJME4
+ jnG322EURcjPRsYYBkGAy+WSwWKxeC6gEV3AP2egKMrkC1RVZeC67sf9fseu64QiQxYcx/m83W7oeR5e
+ r9fRkSELlmV90aNtW6HIkAXTNL+LosApkQXDMH6apsG6roUiQxZ0Xf+tqgpt28ayLEdHhizM53P/crng
+ +XwWigxZkCTpTZblvymRBT4z3gvvVTAys38hdsO4G3bw/gAAAABJRU5ErkJggg==
</value>
</data>
- <data name="server" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="sql-join-left" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABaUlEQVQ4T42SMWvCUBRGr+LU
- jqVQujh1dtDFxSVDBhFB9DdokCAigpNDBscundw7+A8cRDAEFKQiySAYXESy+Ceu95Z3H0IerYGTId+5
- ZwogIjSbzV9arVaNaP9DTXy+BX41Gg2hc71eMUkSI7yR2xFfB+r1Oiicy+WCcRwb4Y08R3wdqFaroOj6
- vo/r9doIb+R1xdcB27ZB4Z7PZzydTkZ4I88VXwcsywJF73g84n6/N8IbeT3xdaBSqYCiP5/PcbFYGOGN
- vL74OlAul0ExOBwOGIahEd7IG4ivA6VSCRTD3W6HQRCkmE6nyBt5Q/F1oFAogGK03W5xtVqliKIIeSNv
- JL4O5PN5UIw3mw0ul0sjvJE3Fl8HstksKGb0G+NfkDcTXwcymQzkcjnmy3VddBwnRfGniLyxwy7f6ADQ
- Q9UPGj4nkwl6nmeEN3bY5Zv7wAsV2zR8PwK5Hbp/vQ880Yc34v1B2H3mwA1XqPmpzb5U7wAAAABJRU5E
- rkJggg==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAADAUlEQVQ4T6WT+0uTURyHXwz6
+ IUgzu1lQUJIilqhBWQRqZlZkaqvUnMIMiw00NS94WUt0DtFlqVPUzOmc2hyjubmL13mZl3LL6dTNrXev
+ c+/mZumWBklg5639Bx54+By+53ye89OBdnd3ob2wpzL2MBT1Qg3FFyAQocTq85S63gyAATtYplBtzMii
+ rzFBuX33AfHOvBKYI3UNyJZA/lmi/4K4fDj2SRFiLmqwmhv5mzru8NZKGcumTCw2zCWQDRtM0dqYzfFb
+ gdh+ibvkRkZkiQwPBKf/CSKJSp976SpzJduq7xhwLLH7HQttUruaUKHntYg25+kd1pXoTJVjVPV90mDd
+ lq6sbw+qjfbum8VDyUDgBl1NHG4m0ZbM7X2OBZbUPg8Ei3mNxsESFjqOzTBItEULkaqAgaBfZ9kSwdbt
+ vrYRmHEhQ3gd8oviw5VsVNsi3lRhAIEmoXSxp0mwoXzLXR8rY1v7ChuQzwE4waZAgVazRpFS7tRqhVyz
+ 3uqbxo+DvCI4O0zxxnKTcEOJ0SqxL9zNn+VVfrTJCt6jfAwae03mdYvzRzCD1jOkOjJDonvVqzQ3eJN4
+ qdDZcC5cxlxdquf/mAGlsfJOm+wBZU5IZVtkeU2mHozsmm/T3nd4ds6EsaZKqKVU9Wop3Elj7blnnCTI
+ +7a4ObFAhZZ3WkdzGkyCog9myfM3y/0ZDHiooBkVYeCylStR6aPaeqm+vPyT5nWtWEejdCrpZ1I6IqCL
+ 0XKfQNyUJY2OKPMaTaKsemNPcSs6EkOeFYEcT6cb5i49mvxZwdF2FXerKZU9mjLmkL7al9iVcSq57TDk
+ 6ZsK+d5ojb2G11jwZAR5yTBNU9stEyQ6/CWMqNYG4xccmdWLA92TxpYPg/q63Japd+dT27Pdw3O9D/rH
+ QNjaBzhy3AsXcRkn54QQTEhoinknlIAaguMVnBMhZJLHw7oMj8eNhR642ky3sJyk/Z5+QVjH2YVcwOaA
+ c3ASpCfgKOAQwNWJO8hjzjPsDlbGOi57/0x7+cpY9y8yIme1LfwcuAAAAABJRU5ErkJggg==
</value>
</data>
- <data name="icon_selectradius_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="application--arrow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIQYAM3Lz5+svc3FycTM09bcyM3EyM26v86ssM6wtM26vs23u83KzsvSxs6mqs22us6r
- r8LKxMTFzM6ussS1vMS/xs6mqc2/w821uQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBF
- Mi4wAwEBAAAh+QQBAAAYACwAAAAAEAAQAAAIiwAxCBSg4ECDBxcECFy40ACCBAUWFEggwQBDgQYcCADA
- kaMABxYXCkCwsWPHkQoFKkhgsqUFBQsfFGgJIEAEAAUeLGywgGYAmwsqLDwws2UABgEoHFi40icBpBNE
- kjRK4GmAAQ01mgxQ1SpWjA8jFuAK4edPhgQNHghQdoDbrxcF/oQbl+HVunjrBgQAOw==
-</value>
- </data>
- <data name="icon_clearselect" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- R0lGODlhEAAQAIZXAAEBAYSChPn6+b2/vvrond3Th9bm63CrvN7Vh6+8mOCnnLK8mnJ+jOzNYuTfi627
- nIeZk3l+jvX28+LaiamMOSE7NSwuLMfd47SVnNDi6O7sj2ZdZIBoKdfn67TA0O/swv3///vKwd+zDV+y
- qu3Zh395RpiimK26xaiouLC9xcjd5JRCL7m/0sytJvP19vL09qyuq4GCmd/s7/Lv+s/i6HV+hHk/Odet
- EXqChdjMhURNV/vok+nljbuRAamDAfz8+6+9os3h5zU7L/n6+ujjjJ6iorS8yOLdisDZ4J+dlnpaWa3B
- xY53O/nonIiSmbO/yrqAfbTAy914aNuvDUBeXLePAclWRv///wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
- AABXACwAAAAAEAAQAAAIoACvCBxIcOCTBR8CXFHIcOHAEwl2NChIMcqDJjdaKATAkaPDFEAITKlCQSAA
- DTwcABDowQQJET2YJNlI5AiClQxYzCjhg8MACSYnFMgBwAgKEEsOCIHxw2FHADowKIAwgkoRARQFxggh
- ZUUFHEMGKrzSMQIUKzZquKAIQIaBIBY2KHHyouDGDjQurBybFUAGFUhWZnVI1iPhwYgJNlycNSAAOw==
-</value>
- </data>
- <data name="icon_zoomselect_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- R0lGODlhEAAQAIZYAMDAwICAgK2km+vv8+/y9fb3+Ofs8fL19/X29/X2+K6vsNPa4MHCwtrl6ejt8sLH
- y9ri6eLp78jIyMzNzbu8vejr7paWltrb3LW2tru7u9bX2PH09tPZ38/Pz+zw9PP19tHT1dfY2c7Q0uXj
- z9PU1ufp6q2trcXQ2ufm0MC/v/Hz9d3k6+/v7/L09qSkpL69vdvg5dDf4ejq7MbJzaSkpePp78nKyuzt
- 7rO1tuXn6ejt8fP09dbW1tni6q2trO7w8sPExcTGx+js77Cvr/Dy9Pr7+93g48LHzKurq+rq0+7x9Jub
- m/T19uXp7dXd5cLDxNXb4eHk59LS0re5urGzteDj5d7l7Nvf4wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
- AABYACwAAAAAEAAQAAAIrwABYBFIcCCWgwgTJuSRYsgLhQIDSMTS4UKVKEZISFAYIAmLCTmIMEGgQsiV
- JwcjopASAkGBIgk2KNExwwbCACMylCjw40MLAgMMcDBhUKKPHQUqNCHgwUAECEsUYriR4ABQAw2sLKBh
- EEuAIBqsDnDQIEaPI1NuHmQgY2wNJyegUEnp9SAIBiJgrFjwAIeChAESAkFiwQUFLAoEdJUYWOFBAYod
- S8YioKDlyZgdBwQAOw==
-</value>
- </data>
- <data name="minus-circle" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACC0lEQVQ4T6WSP2gTYRjGP5JA
- EyhNc0M8SotbAxU7pNDsNRA6hLQIpXiVzi0d3RVEaAUXBwexYgT7T9EKcfHfWQlSJJfmUFAhZOgJRocM
- yh1ZjtfnCXq0pY2DgR+8933v87v3u3xKRNT/0AnfV0o9ABtgU6mBLaWWwBoo/4H1EvfYw15mmD0qyD+O
- xcxaJuP8mJtzfy0u+j8XFvzvhuHujY873IMgf5Ig/7S/32oahvdtfl4cwzgE177Oznrb8bgFQf7QBEWO
- Fo2a+zMz3pfpaflUKBzL56kpqRcK3npPj8lMcIS7ON+7dNqxJyfl/cREV/ZyOXk1MuIwEwhuK7X+IZdz
- zUxG/vI8nZbtVErWBgflXjIpdzStA+tSKuUyEwhu4Wvj7f6LsTFpt9vSaDSkWq2KbdtSr9el2WxKq9Xq
- UEwk5NHQkM9MILiJByub9Z8ND0utVpNKpXJsmIItCJ7ous9MILiBcd6MjroljLiBhm6UKNA0l5lAsMKL
- k0zu7+B8r9HwL4qxmMNMILiGv+R6OGzu6Lq3iyl2ITmJl/G4txIKmcwEgqu4lpdxOZYjEausaZ4NiQ3J
- Ud4ivBwOW+xlJhCgVqfBeWxcgn01GnXKfX3ux0TCJ6y5xj32sJe/g4IInk+BMwNKncsqdeWCUg8v4ksT
- 1lzjHnrOAh1EDgpCWOgFSYC+rvBF7A1R8BuYvt7nXvKiFAAAAABJRU5ErkJggg==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABpElEQVQ4T6XQTUgCQRjG8QEh
+ iBK8VNAxAukWHsKTJy8Wkit56ItOfRJRBF2iLtE5kCAiEUMSwRJBENGOaYb2sdCSgZeMlBRRUFBEeZo3
+ ggoK3HrhB7uz/IfZYQDYfzCLxdLHjXNzMlHTx8xm82Q0Gr1PpVJ4fExCkiSI4h0SiQRisRj4N0Qi5Io/
+ X+PyUkQ8/oBg8OKeWmYymRbD4TBCoRBfDCIQCMDv98Pn88Hr9cLj8cDtdsPlcsHpdMLhcMBut8Nms0Gh
+ UMzRL8zzO/jTUMsEQVhoNptoNBqyUEMtMxqNS/V6HbVaTRZqqGUGg2G5Wq2iUqnIQg21TK/Xr5TLZRSL
+ RVmooZbpdLq1UqmEfD7fkp3zV5zd5kANtUyr1a4XCgVkMpmWTJ48gZzevIJaptFoNnK5HNLp9I82PEmY
+ D6VvDl6AsaMHDE5su5lard6k42ez2R8N78VhfQaWJGBa/LSeBPpX/S9MqVTOq1Sq3d90jWzd9swcZ7/S
+ RgB6Vw2N7zM+7Vw319sK5YRTJJ2CdfajpT1aG8XAKGsTbIfcVIfJ+h69AbnIrwah7HLvAAAAAElFTkSu
+ QmCC
</value>
</data>
<data name="document_task" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -738,111 +735,170 @@
A+jKfnCib2Agtm9o6O7/wLN06O4ALt15PeGOvdAAAAAASUVORK5CYII=
</value>
</data>
- <data name="icon_popupscrollup" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_pan" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIcAAAAAAIAAAACAAICAAAAAgIAAgACAgICAgMDAwP8AAAD/AP//AAAA//8A/wD/////
- /wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
- AAAAAAAAAAAAAAAAAAAAAAAAMwAAZgAAmQAAzAAA/wAzAAAzMwAzZgAzmQAzzAAz/wBmAABmMwBmZgBm
- mQBmzABm/wCZAACZMwCZZgCZmQCZzACZ/wDMAADMMwDMZgDMmQDMzADM/wD/AAD/MwD/ZgD/mQD/zAD/
- /zMAADMAMzMAZjMAmTMAzDMA/zMzADMzMzMzZjMzmTMzzDMz/zNmADNmMzNmZjNmmTNmzDNm/zOZADOZ
- MzOZZjOZmTOZzDOZ/zPMADPMMzPMZjPMmTPMzDPM/zP/ADP/MzP/ZjP/mTP/zDP//2YAAGYAM2YAZmYA
- mWYAzGYA/2YzAGYzM2YzZmYzmWYzzGYz/2ZmAGZmM2ZmZmZmmWZmzGZm/2aZAGaZM2aZZmaZmWaZzGaZ
- /2bMAGbMM2bMZmbMmWbMzGbM/2b/AGb/M2b/Zmb/mWb/zGb//5kAAJkAM5kAZpkAmZkAzJkA/5kzAJkz
- M5kzZpkzmZkzzJkz/5lmAJlmM5lmZplmmZlmzJlm/5mZAJmZM5mZZpmZmZmZzJmZ/5nMAJnMM5nMZpnM
- mZnMzJnM/5n/AJn/M5n/Zpn/mZn/zJn//8wAAMwAM8wAZswAmcwAzMwA/8wzAMwzM8wzZswzmcwzzMwz
- /8xmAMxmM8xmZsxmmcxmzMxm/8yZAMyZM8yZZsyZmcyZzMyZ/8zMAMzMM8zMZszMmczMzMzM/8z/AMz/
- M8z/Zsz/mcz/zMz///8AAP8AM/8AZv8Amf8AzP8A//8zAP8zM/8zZv8zmf8zzP8z//9mAP9mM/9mZv9m
- mf9mzP9m//+ZAP+ZM/+ZZv+Zmf+ZzP+Z///MAP/MM//MZv/Mmf/MzP/M////AP//M///Zv//mf//zP//
- /yH/C05FVFNDQVBFMi4wAwEBAAAh+QQAAAAAACwAAAAAEAAQAAAILwAfCBxIsKDBgwgTKvzxQ+FAhgwd
- QoSYcOLEgxYtFsyY8SHHjh8/OhxJsqRJkwEBADs=
+ R0lGODlhEAAQAIUAAAAAALe7woCEiVNYYTtBSuHi5Keqr2hsc9HT1uzt7pSYnHB3g8fJyrG0t////19k
+ a97e342QlURKUqCjp7/Bw290en+Diaqvt5Sbp1lZWUxMTZCUnMzMzKOosri7vNbX13F1e+Xm55KWmWZq
+ cZyfolRUVL3AxIaKj660u76/wKastd7e5s/R08PFxnR5f5SUpdbW3sXOzn6FkpmcoKKlqJScrbS4v5SU
+ lIWLlf///wAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBBwA5ACwAAAAAEAAQ
+ AAAIyABzCBxIUCCAgggHZgCQIWHBhgcbJmhxAoQLBR4+5ADAsSOAAxVEFKCgYAaICQxKbMzR8IGDECwg
+ JHAAwQEIFhoYCnzQQqYDDgUcyHAwgcJBgQcEeGAQVAYLBwwckOAwMEQEAgZaPOUgMwGECg0IfiBw4cOH
+ EAnSJkgxQGCCEQ8GEPDAVW2CEG1zzJiRlkaFFi1g2M0r4YAIDyYSB7BRIK0BAgNTWCAwA8UFFR06INhA
+ gEVBFgRwYBi9YQEBjQhBS5BAoDUEggEBADs=
</value>
</data>
- <data name="icon_plotdwf_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="tick-circle-frame" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIecAP7+/rW6x9PW48TD1uHg6ba6x////8HBxMTFyMC/wrK+y/r6+v39/cTD173JyMLG
- 0fT09/P09d3d5qGprPX3+MPFxtXW2dLT1vj4+JOjqcXFxujo6OLk5+Dl58TFyba7x8fIy7a6xuDi4+Li
- 4drb3cHG0Onp6cLP29vb3u7w8ODg6LG2utjc4IeSk+Tx6dTr5dLV4urq6palqp2ho6ezwL69vrTBz8TD
- 1ebu9rvI1Lq+vKSvvdzm89XY3r+/wtLV2PX3+dTX3tHQ3Ymbj+Lk6b/KxOvt8PD1+bS5xvz9/aGvvPX3
- 98LOzLa6yJ+suuvr66CsurzKyM7Q0OHf6NHT1uzu8sTGyb3KyMrKztLX5M3L2b2+wdbY3O3u8sTGyODg
- 6cbIyNrb4Le9v8rLzrq+y5GunKvMuNna3eHi5fDx8qayu7u7vpShq/Py9fX19ZKop8LU2Jmps+nq67TN
- x5eosPn6++/1+bO/zKCsu/T398XR36Goqp+rutbX2r/AwdHe6tPW5O3v787M2sfL1fz8/K22v/X199ze
- 4t3c5rW6xr/Dz/n5+c7Q0cnKzdze5MTGyoaSiJenndPW4o+ul+Df6MDAxL3BzcHDxcvX1Jyws8XD142g
- lv///wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
- ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAACcACwAAAAAEAAQAAAI8QA5CRwoEJODKHcUMElBcOCCQA5c
- 2OFx4k0GDAMNCRkw4MqLIzj+5NgEaQUnQVoGAACwqMMcM3D0KJDRYganBitXMoBQZFKZTDTwsNlz8wkA
- AwAYAOAQaQgdJTvUiBGoKacBFQR0TIhTyIYTNwNvACBA4EsYDzU08IEih2AASlO4gNjiBwaYNX0GEioR
- 4MClClIESKKQ5wKZgQWojAEkQoCAJUDONDoQADGAQxayAEBBAkGCEAESDQzAAkAVNF6sPEIgIc0GLKN7
- dEnwIwAjRBGSmBBgaSCRD0Yq+QjQpE4MRUHaNFzwAEkBTiMGOWrIKSAAOw==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAC5UlEQVQ4T12Q60uTYRiHHzIZ
+ HlssW6Em62BQikPE0cyJg6W20h0cgc2gxMAYfVACFbEDJkIRnb4IrukyM1kuJhqK6NJEreHUPDWXEydK
+ +g/47dd7Pw1jPXC93Nz377rf531ZSUkJ0+l0zGAwMKPRyEpLSxNMJpNKgE5FCKpVNKMMZckhlz9CC0TC
+ MLempqZ2ampqfmdnB1tbWxyqJycn56urq2spIywQ/b9ApNfrr9pstg4S2mbtuDNxDznDWg7V1NvcDMJq
+ tXZQVlgg4jcoLi4m8oSBPRAIQDdyA+pvRph+3cb1oIVT6q9E/rSBz/z+VbS2ttrJIZdptVqpxWJpWF8P
+ oHioDJfnymDwVUD7wxyG/uctXJq5xjMrKyuoqqpqIJcVFhaqR0dHFp6Pv4bq61UUCQvyJnVhZA1rQOfd
+ 715ccBfh2ZeX6OtzLZDLNBqNma5l7q9EgfCG9H4VskcKIB/Mx5nebCR1pmNjYwPBYBDb29s451LyrMfz
+ HeQytVpt8Xq9yPiYA43HhL29PSS+T4O4QwbxGxnW1tb4Avq5YqsMiT1pPDs+Pg5ymUqluuvxeJD2QQFH
+ wIXFxUXs7u4i/m1KmBxvT0FsdzKOOE7zrNvtBrlMqVTe9HpnYXKU4+RQJl/g8/nC5LiuE4j+lMg53Cvj
+ Wbd7DOQyhUJR0NPjWH78+SlSHOchdoRfO7YnGaLBY/tIu0+haeAJbDb7MrksKyvruF5vbJ6ZWcDFTg0k
+ Lhlincn8m6OdiTg4lrDPIWcSz0xPz0Kn0zeTy+RyOcvIyChsbHzkmJtbhaJNhbj2o4gclCBi4i9Ux7Yn
+ 8JnX60NDw0MHOeQyqVTKZDJZVGpqqrmu7oFzaWkTLQMvcMVqgLhJwqGaektLQdTV3XdSlhxy6RwQiBaJ
+ REkSiaRcqcx91dXl8vt8u8LP/Af1aEYZIZtMTshlEUIhEUgVyIyMjFRHRUVVxsTE1Au0hKinHs0oI3A2
+ 5ET8AeUdBAROQKmSAAAAAElFTkSuQmCC
</value>
</data>
- <data name="icon_restorecenter_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="control-stop-square" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIUtAKq7y5+svcbS2MPQ1tTc4MvW29DZ3sTR17nH0tDZ3crV2tLa38fT2dHa3snU2tPb
- 387X3MzW29Xd4MjU2dbd4dXc4MXS18nV2sfT2LjH0sXS2NLa3rzJ1LbF0cjT2dfd4c/Y3c3X3NTb4LbF
- 0LvJ1LXF0M7Y3c/Z3dLb38bT2MzX3LrH07vJ0wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
- AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAAtACwAAAAAEAAQ
- AAAIxAABCBxIsGALAAQkUJBA4EGDBBAKXGAgAMBBCQE4fAhAYEGCABFWBKh4kAKHACQ4LjAQAEFLkgAq
- fGARgCMKli09wKxQs6bDEz1HWgTwgAABEQ82GDARooADBhqGNliwYEMDAyAiKpiQwsLQBAkMGEgAIkQE
- BQ4wCDgwFEJQFQUUBGV7sEAElwHiOqjZ4cCAoRdcZgjgYAKDAB0CjPh70EOADBMCMFAb4ECJAIwBCNi8
- WYOFA34HiB5asPTAFqhTq16NOiAAOw==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABcUlEQVQ4T8XTO0hCYRjG8Q8M
+ 6YKE2RC1VRANQVNDQi65RVC0hDQEBS2F4FBQSy2BQxdrUOg6mDWEBJZJUdBSw1cEZYNh2AUywgiHEBSf
+ 3ldQ+ChJcGj4cc6B/3nOtxwBQBSjqJf5w5mBjtWoMK29uYgsgIv77KkzN0bXC5PLEWD+Pq2YC6WR5XgA
+ uONeGWhzhAWR9rsUJs8Tec3eJMEd98pAqz0oiJy5SmA0EM8Z8cUwuPuKgZ0nWDwRWI/fwR33ykDztBRE
+ Tl18YXgvhn73I7qctzAvXqJzQeZYPCFwx70yUD9+Joi0nn7A7AzCtHT9q153CNxxrwzUjQUEkT2+KFpW
+ wnmZtp/BHffKQPWQVxDZ7o+jxhPLq8n7Ce64VwZ0li1BZONRClpvMq8qXxLcca8MlPatCyIbTgBDANAf
+ ApV+QEcqDoByUrZPz3TlTmuaUAeEEBqN0bah6XbJPxltm9SXKCfgAaIntQUw/Bj417/xG49phw+gF0Mn
+ AAAAAElFTkSuQmCC
</value>
</data>
- <data name="icon_selectwithin" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_zoomnext" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIUwAMnY6Ud1qBU2aAEBAYBoKfLyl+Tfi97Vh+nljZeirOLaicjd5Pf3vPX2s+Ldimp9
- hv7+/vr62lZsif397ENccrvDjs3h54qYhWZ7etjMhdXZkt3Th+jjjMfd48nPjvX0qvPznGp/evn50Nbm
- 6zVReNfn67/GjfPzou7sj9/s73CBl150eMDZ4M/i6NDi6IGPoP///wAAAAAAAAAAAAAAAAAAAAAAAAAA
- AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAAwACwAAAAAEAAQ
- AAAIlgBhCBxIsCCMAAgTKlyIEIDDhxAhNhxAcYCAiA8nokBgQMBFjBM5ODggAMJHiQEADFCwIYOACREE
- EJhJAMDEigJEMPgggGPNhhAFNDhRoICAAz9TqqQoAEQBEysoyLSZckCKERYEaAhhlCZVlSVadBDwQECF
- CwkyVnWxgAUJAC8wFJCg1mHFhwI8nASKMYEAFWoZCkYYEAA7
+ R0lGODlhEAAQAIZ4AHBJJai7zuqxd9nFs1tgZLjH1xc5Zs/a5CtGdezw9Bg5bypGdWV7khY1bKu0vNjm
+ 8oOGiKqxwcfb8GBocEFagpKfshI0ZKa80cza6JGRkoSHi622v2d7k8LQ3aSttmh8lre/x67L567C1a6y
+ t36QrjhUe5y20ODo8auvsz9SfSJAcoSFiBIzacvY5YSAfzAvLjg3N2xtb3V5fnCCov///6amp3h3d5Sp
+ vhg4Z+rv82RgXzBQeaCnr5qbnV5cWpmirEdhgdDh8hc2bEdKTevw9cXa76m1w+Xq79Dg8crc7oaKjRU1
+ aLC/z56quGRrcr7L2KTF52Z+oVxbXcjQ2OLr9RY3aoiOlEpMTIWUoxgzaqC50tri6s3U2YBqV9nm8yJE
+ cZiktMfS2Ofu9RMzYlhYWc/O1KuoqJyzy7bBzXqSsH98e6q8z9fb3xU3ZzhWfG50enyPoomXpJSVl6Wq
+ sY6XqM7X30ZegHyQowAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQB
+ AAB4ACwAAAAAEAAQAAAItADx4GkSB4wLHWrMCFy40E4KBCx2PEEzJwNDgXQ49JgSpcGCExiYaLjIoMaI
+ HDQojEnzIAkWOQxJ2OCSYMsNCyqQFDkjhaERH0eItLigwEAVN2VgXIzBRgyQL0Ky4IhgYshFKyioePnQ
+ ZkkJKHfeXASxok4QCTMMhNEywcFFPDwg/BARogIcJwTeCtyghMyLKzI8EAAgYMDbAwXWFDiAJwAAwob1
+ MnQMWfLkxwIsX+6ieXKHgAA7
</value>
</data>
- <data name="ui-separator" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="application--plus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAAKklEQVQ4T2P4//8/AyWYIs0g
- i0cNoEYYMDExVVCCR2OBGrFASUYaHHkBAGwz1S9OnHZ7AAAAAElFTkSuQmCC
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABq0lEQVQ4T6XQz0vacRzH8Tda
+ gwjD7dAhdvLiYS3Bk7H1pcCLB0EFD8ODEKFzW8EY26EgunToTwhEBJkIMnEI4vSq5tBoQrIFwkCYX1BM
+ QUER5dXn3Y9TlH3bGx68P9/vlyd8v18CQP+DnE6nTngjeBTiRkcOh8OVz+dPq9Uqzs7+oFKpoFz+hVKp
+ hEKhAPEMuRz7Kc7HODoqo1j8jVQqe8ot2Ww2XyaTQTqdFjdTSCaTSCQSiMfjiMViiEajiEQiCIfDCIVC
+ CAaDCAQC8Pv9UKvVHv4Er/gHjxpuyW63vx2PxxiNRopwwy1ZrdZ3w+EQg8FAEW64JYvF8qHf76PX6ynC
+ DbdkNpu3ut0u2u22ItxwS5Ikfex0Omg2mxO5s+9hSK6CNzfckslk+tRqtVCv1yda+i5h4/wzeHPDLRmN
+ xi+NRgO1Wu1Orh8evIy+vuRsXp0N3yQ83X5eIL1ev8OvL8vynQxfX2FNdtwyffDsH2k0Gq9Wq92/z9T6
+ 3Ilqd05mi7UV3JxV7tk4iZkR5oWFifZmywt/X4DEvm64feAsTxFtPjkk33TpcvO1mAsmbJya11eQ2wAA
+ AABJRU5ErkJggg==
</value>
</data>
- <data name="map--plus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_clearselect" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
+ R0lGODlhEAAQAIZXAAEBAYSChPn6+b2/vvrond3Th9bm63CrvN7Vh6+8mOCnnLK8mnJ+jOzNYuTfi627
+ nIeZk3l+jvX28+LaiamMOSE7NSwuLMfd47SVnNDi6O7sj2ZdZIBoKdfn67TA0O/swv3///vKwd+zDV+y
+ qu3Zh395RpiimK26xaiouLC9xcjd5JRCL7m/0sytJvP19vL09qyuq4GCmd/s7/Lv+s/i6HV+hHk/Odet
+ EXqChdjMhURNV/vok+nljbuRAamDAfz8+6+9os3h5zU7L/n6+ujjjJ6iorS8yOLdisDZ4J+dlnpaWa3B
+ xY53O/nonIiSmbO/yrqAfbTAy914aNuvDUBeXLePAclWRv///wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQB
+ AABXACwAAAAAEAAQAAAIoACvCBxIcOCTBR8CXFHIcOHAEwl2NChIMcqDJjdaKATAkaPDFEAITKlCQSAA
+ DTwcABDowQQJET2YJNlI5AiClQxYzCjhg8MACSYnFMgBwAgKEEsOCIHxw2FHADowKIAwgkoRARQFxggh
+ ZUUFHEMGKrzSMQIUKzZquKAIQIaBIBY2KHHyouDGDjQurBybFUAGFUhWZnVI1iPhwYgJNlycNSAAOw==
+</value>
+ </data>
+ <data name="table" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAC6klEQVQ4T53Rf0zUdRzH8fdq
- 1srNWv2R6eZy8x9Hg9babKRTNmd/FG5l9Idbru2Cw8PjBII7EfAHKjI8ZcJR14DidjQOhniB2ImAml2C
- h07lPH+gB3IHIpMyTpCJPP186s/Wan63xz7/vJ7f7fv9SMqOHclK2jNI/qyoSGRDYaGRZ3h0p4h8kp+f
- PqdeUH+2gJbevZztryQ4UE9g4ATuK/3s6YlgOxMlyxfF3BrFdCSK3utOEVlvtZpm5+b4viuPjgE7PREn
- vSEnE9NdXJ28TsNojCJ/lOIgFATA5I2i97pTRD7KycmYefIEpy+LttA+um6X47tg5+7kUcan/Jz7fYiy
- 82FKb8DOy7CldRi9150i8qHFYp6enaWyNYPvTmTjOpWPt6+E7kvlXL7moud6Ow2hELv9g+R1D2E5PoTe
- 604RWZuRkRl7/JhDzek0BLbj7S/GfXo7vw1/S3jCw/2pTjqDnXhG/8R+a47sjkH0XneKyBqjceuDmRns
- P6bh9ltpvFBIdUcuJ28dom+khpEHLfSFmtSnDFIzPIOtO4ze604RWWkwZE88esTBWiN1p3Op77FRdczC
- sWv7ORU+TPCei0B/DcOxAL7xMXaeuYne604ReX/Tppzx6WnKq0yU/ZDKgYZUHO1mvmnfSu1JG42/7MYf
- rCJwpY6PfZ+z5GgiX/ZmoTtF5L2NG3PHpqaoLDfj9tqo6/yaA55UPH0FeIN71NUe5Mive4n80UxC2wq+
- mshVZxK6W1ywQuSdlBTryMOHOMoseBoLcbXlsd9twH3OStPFInW1JSQ1riSuOZ6ElndJGU8jvmU18xxv
- RqT6NacsT07Oj8RiOEozqSjLxF6RTmmNgdJ6A/YmIxU/mXmrehlJo5/+gzheDcjCxMRdY+qv3pmc/Fdf
- /LyF+LoP/vL2nVUkuFbxfPHrI2Jf4JSXli7dPD8uruT/eG7bK6OLwnHoU3ey7kXRz8vKG8qi/7T5hVpJ
- m3dJTOr8u5Onl817ThS42NsAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABzUlEQVQ4T52RzUtiUQDF71ba
+ R7RrGW5aVIQUNVPQYjCIwU2LNg3ZjMwUSViPzGKmmf6oiigcs+zZF5FSFn3iGJbo8yOfnrnnwXskuMkL
+ B8598Dv8uE+4AgGnzGSDcYrPfr8bDR6yYlRRpqpyYCgCDO5X8XGvgg9hHf2hV/QFi+jdycOxraFnK4vu
+ zQy6Nl7Quf4MMmTFiM/3Ta9WjYG1NIyB1ZSOX//KxkDgPg//bc4YUK4zmE88GwNkyIpPXq+nVKlYBl9U
+ DavHKfw8TGJFfcRy5B5L+3dYDN9ACV1j4e8V5oMJkCErhqenvxd03TL4ffyEV3lngmdnVt86OrL6+sEB
+ yJAVQx7Pj1y5bBlwIByPI3R+jsNEAjunp9g+OUFEftuMRrGhquCAwUhWDLjdM5lSqcZAk3eGBmangdk5
+ QIas6J2YmE0Xi3UN1MtLy2AvFqsxIENW9IyPe1OFQo1BRt4ZGpidBmanARmyonNsbC6Zz9c1iFxcWAa7
+ 8k3evgEZsqLD5fI9aFqNQVreGRqYnQZmpwEZsqLd6VTucrm6Bhww/wIH3hqQIStaHI6VpHzRm2z2XSFD
+ Vtja2r422e1/GglZIY9Nplmm9Z0hY/sP0fXQjui6fQYAAAAASUVORK5CYII=
</value>
</data>
- <data name="icon_fitwindow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="gear--arrow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIZlAEJyokd1qBU2aPLyl/PzoPj4yvT0rJi2zPn9/O729/L4+PT1rLnS2eny8+fx87zV
- 26jB1bnT2vr62rHN1e/29/v86cLY3/f7+9Hj5vb2uq7L1N/r7q3L1OPu8PX6+vT1q7TQ2KrJ0qnC1Zm3
- zObx8/z86ev09Pj8+7/W3PH4+Pz76bbQ2LHO1bXP1+Xw8erz9O319cDY3cHY3vL5+PT5+brT2rTP18fd
- 4bbR2Nrp7KjH0OTv8arI0szg5LjS2dHi5vb3u9bl6d7r7b7W3OLt8Or09ejy8+z19fT6+qnB1bLO1afG
- 0PPzn8Ta36vJ0ubw8r3V3OTv8Pb6+tXl6f399q3K07rU2q7L08jd4rLN1cPa373W3Oz19tro66XFz/f8
- +/D398zf5MLY3rXQ1+v09QAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACfklEQVQ4T6WQXUhTcRjG/7Yt
+ GWbozexrI0qRUMPOwG11MbDEmov8uojQZFBIq66kgVERgogglG1hEJRSGdRNihG0TFA7ws6JnX2YmsuW
+ bTq8l8ibt/9zjpZCdNOBH+/L8z7PwzmHERH7H9Swy+Vibreb1dXVsfr6enU2NjY6OK3rODbf4EUGbCmo
+ ra09yo2X+NyLuba2Rqurq7RZg+evBTU1Ncd8Pt/dlZUV8ng817np8tJSmgB2aLjBA++WN6iurmacq8lk
+ kiQpROl0ikZGRuZTqRQB7IlEQr3BA+96RvsEh8PBnE7nvoaGhluRiEKKEqaFhS+0uPhNBTs03OCBFxmb
+ zaYV2O12JxfawMBAfyIej9Hg4LOZ0tLS+wA7NNw2fMj8LhAEwSfLEo2NvaepKZGi0SiVlR3u0ul0DGCH
+ hhs88CLD0d6gpKSkfXJykoLBIGHGYp+ovFzoyMrKYgA7tM0eZDhaQVFRUVVhYeEN4PcHvobDcRoefhe2
+ WituAuzQcKu49lw60nz7JTIcrcBisTCz2bxfEKw9oijT6OgEzc2lKJP5oYIdGm72bilj6/0cs/kXmviH
+ aQUmkwl0iKJCQ0NvaXxcpkDgYTIUipP3sULHe6Sfbn+ETt75SKcDUepLE/GwXNapNKkF+fn54FRlZdVT
+ SZql4uJDvXl5eZ2iGKMT3VN07zuRd5qoOfKHtlmig+0TslqAR6/XM6PR6MrJyenKzs4+gDkzs0wX+0Jk
+ ahlYLmh9FVPnhRfz9g9Eu7yv5d1X3mhvgDyngMN/K7MCg8HQwou6AfYNPfds/3TuuSeRnU2D53mJ9g/4
+ s42zg2Pi7PkX2888eGRw93rWM+wXiN3yhzE1UjYAAAAASUVORK5CYII=
+</value>
+ </data>
+ <data name="icon_zoomselect" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ R0lGODlhEAAQAIZvAISChAEBAXBJJai7zsfb8Nrn9M/a5Nnm81tgZNDh8sXa77jH16jR4+fu9dDh8brT
+ 7erv89jm8uzw9ODq9Ku0vNHh8mRrcvT3+aStttri6oOGiJqbncrc7oaKjZ+fn9Di6JSVl67C1a6yt5u2
+ 0F5cWsjd5IiOlM3U2Tg3N398ezAvLujjjKCnr5u83uXq73V5fnh3d+nv9OLaid/s76/N6pyzy9fn65mi
+ rLCurXahzJDO1tfb3+Do8dDg8UdKTb7L2EpMTFhYWZy20K22v6jG5KWqsaq8z+7sj7C/z6amp6C50uLr
+ 9evw9aTF52RgX250esjQ2ISAf2xtb7S3u+Tr8WBocMPT43yQo7vU7cbb7+Hr9JGRkt7m7YSFiL7H0cza
+ 6IWUo7bBzeqxd6uvs6uoqOLs9c7X31xbXbe/x+fs8evv84SHi8vY5XyPoq7L5wAAAAAAAAAAAAAAAAAA
- AABlACwAAAAAEAAQAAAI0QABCBxIsGAZAAgQnJAyAwyXBk+ICOkSBMBBBBc8KKAAI4DHjxgsAviCZOOR
- BgEWEBgwQEAPkTQUJDBhxIWIAAZWCrghMkUCMg52JAlQIMMCJgK0iExQxEEUCAEqSCgg4IMAFCJfeIRa
- gooKASMECKghkgROohIqCDggZogVHCI7BCCwAAjVAxa2RFihROSGAAMIGFgrA0qEMVk0iMwBOPDgBwxA
- sODgROSUAGIzM2gx4UoIHSJ/hMHSJMYDHzYmVOGxxIvIgrAHlplNu7bt2QEBADs=
+ AABvACwAAAAAEAAQAAAIwgABvBFIcOCbgwgTJsQRxUkKMgkFBpj4xsMULz/CFNmiMMCRNxugcEkTg8cX
+ JGsOSlyRRAQENRcaTIjAAQwIhAFkwDghIQMVLQd6KKhxxuBEEi6YsLFSoIKCB0RQKJSyo0GZAgmyMKAh
+ xIfBNwFMjFlywAEBBjqaXHmCcwaaLmYSEMDSIoeSKhSM2njDQsONEG5GtLGAIGGADyXeDOkQRAWQFxgQ
+ CBAjECxFAwuMLDDwZoAAAQpDI/RcsHToAaJTvwkIADs=
</value>
</data>
+ <data name="icon_search_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ R0lGODlhEAAQAIYAAAAAAP///+np6q+xtc3O0JeboqKlqqSnrKOmq5OXncXJz5SZn7q/xaOnrKSqsMLH
+ zOLn7Ont8e3w8/n6+/j5+vf4+fb3+OLj5NfY2Zieo52jqLS7wOLo7PH09pKan9rf4unu8ebr7quzt9rg
+ 4/D09unt7/P19qCnqvT3+PP29+rt7pqipPD09e7y8+nt7ufr7MrS07W8vOLn55Sgn5qlpK62tcrS0c/W
+ 1dvh4Obr6pKfnO7y8aSuq7/JxtXc2p+qprfBvbW/u73Gws3U0cHKxaa0rKe1rMbPyZ6uo6q3rpSmmJCj
+ k5Ollqe1qaq3rKOxpISYhYOXhIeaiJSllZ23nZu1m5ixmJKqkoSahICVgH6Tfpu0m5aulo6ljo2kjYmf
+ iYGWgYKWgoCUgHuOe6O4o6C1oJ+0n52xnZiomLrJurO/s8rUysfRx8XOxcnRycjPyMTLxOLo4uLn4uHm
+ 4eDl4OHl4ePm4+Ll4uHk4eDj4N7h3vv8+/r7+vv7+////wAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQB
+ AAB+ACwAAAAAEAAQAAAI6gD9CBRAYECCBAMICBDIUCCGAydiBAHyQAMCDA39YMjAw0kTGSVCwKCxAOPA
+ Az/QoDniQkKEEUVEGFjoh8CKKU92oOggAQQEI0o8EBA4oAaOHChSkHDJgQkUHQMEJhAy5EULFhMoVDCR
+ J8+dC1I/3CDiQwIFKmjTph2gwIYWMUksVEkTZ0+cNFWqbCHgoEcYLWPsWJGzhswaOVYSC2jAAAmUKHq4
+ 9CnDxUwfLpg1FtiwRAqeK3XYnGEz54pphwg8zFDRRQ2dPnT4uPHShSHBARe+6Nb9Zk+bLxkFYhlOHM4e
+ LMH9gFm+PAvzgAA7
+</value>
+ </data>
+ <data name="databases-relation" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACD0lEQVQ4T42SvW8ScRzGb+B9
+ 0oSBl8EAIWGAOLIhgyMkLCxOJgaNbwlDBzGVsz3BPwAxosH42qiHl1LbhuRsKJQ3y3bm0pqI9dQj7VWM
+ k+vj3UktR7DyS57ll3ue3+f73JeIx+PEFDorf3NzkqYxE5FI5LwkSej1euB5HrXaJlZWWlhf5zB1QL/f
+ R7fbBcuyePFyEQ+KJZSYNTVgIpp8r2CrDygE4wH3izRohgUxjsRxXyGKvxCNRi/FYjFCOW63O5RIJN4U
+ CgXk83mQJIlUKgWKokCMIzWaPD4LP9UAn8+n+E9mb2dpTQcb71BerYKtdQ4DDpA2Whx2hIEaoJipbIb+
+ /mMAzQivGNx79BwLi0sgxpFyuRySyWTF6/WemcvconcH+0iTZFUTQDO4+/gJnpWZYQcjSF1uGzuiBDJD
+ 0d/29zBLpqsej+fc0R2MIK21O/ggfIEg7eJ6+kZVp9OdCoVCCU0HjTaYSgXL9bfDDkaQ2HYTW8InXEvP
+ qman00n4/f6LmhFKr3HnaREPlxb+3UEwGDxttVoJk8lE2O32GS1BC6XKMsr1yrCDEaTG+01six8RDocv
+ uFwu5TeeMJvNV4xG45xMdCBKr9dTBoOB+rMHI0irHRacwCMQCFy22WxKwDFZdlmOiVI3sXGIVOea4MUt
+ OByOGdlwXF3Fo84Q6y+SPPO8xWKZl7GvKlv8P/9vysUMoJZl8vEAAAAASUVORK5CYII=
+</value>
+ </data>
<data name="icon_plotdwf" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
R0lGODlhEAAQAIe1AP///Vpuov7//f7//////7643ltsoVltoUt+spij2f7+/JGVoZKUo01/s11toLOx
@@ -865,155 +921,143 @@
PNiyiMHAADJGBVpyAIyEGowqtKoz0NOfD1xiHRCjKswPV0MazgiyykCtJKUwNawVEAA7
</value>
</data>
- <data name="arrow-090" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_zoomprev_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB1klEQVQ4T6WQTyjkYRzG32ax
- WlK7xvhzsNnNxko7RYkiBzkoBwfZWtMmm4ucJIuTPeHCblgkB8q/SRPbYvewbStcvnsQ7QEzWOYgcVAT
- iXn2faZ+mjEzqH3r09v3eZ73eX/vTwFQ/4Pv8MsPv5W1c0Pl9myp/P49VTjkVsUjh9Ua4c6ZOn3mmDcu
- DVfAQzLoBrhrqu9f0LfLsHzeB9pWz9H/F+Ccr/W7v6B7kyHp2/Oi4dvpNR+dV6Ceq/2wT3jVsU5TPrmu
- UDd3EkTXnwvQZy7oH2S2C0Xp3rpE64oHLcse1C8co2psB28mXKh17OKt3YnmpSMwx3zAT3zRtjKY3ros
- /tTMOFHSI7BNbeOmx3xAgQ6o5++XfDxr/qWeNv6Q13YXinrXUDnlBGfqRob5kAVpTT9Vcv08kbIZN6xD
- 2yidPgBn6vRZErJA36LM7xwGkjd7gtSxQ+Q4jqF1MTzmggriC2tVtLVSxdkmDST96xni7B6kfdG7bVIM
- LyIpS3EFPMGn6PXAkqkeVY0SsSx6YZr14smCF5yp0zdWyAKapoQMFVkxLJbvQOw88HgR4Ezdf4UqeKgD
- TOWYChrHTeUDco2eqWuyNTHhnhChDbMm5RYStRflX/AP4Mv/7H+tMgIAAAAASUVORK5CYII=
+ R0lGODlhEAAQAIZpAK2km+XXyfX29+Xn6ZWdqJScqNPa4JqirsHCwq6vsLm+xNfY2dfZ29vg5cTGx6Oq
+ tMbJzZObpq2trJWcqqSkpcPJ0J2ksODj5ZKapszNzc/Pz87Q0vL197u8vezt7rW2tru7u7GztaiuuLe5
+ upWcqZScqefp6u/y9ZWdqb69veLp78LHy9ni6tfd4snLz5aWltbW1tbX2NLS0pafrMC/v9fZ3c7T2MzQ
+ 1K2trfr7+8PExcLHzMXQ2vX2+MTJ0Ofn6N3g45WdqqSkpOHk5+fs8aurq+jt8fT19tTT0+jq7JOcqbm/
+ yLe9wrq1sOvv86CosqertsfKzb3Byc7R1fP09Z6ksLi9w6qwuP///5ubm9Xb4bCvr8nKytHU19rb3Pb3
+ +KOrtPDy9Nri6amvt8LDxPP19rO1ttPZ3+7w8gAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AABpACwAAAAAEAAQAAAIqgDTCIRBY0sKJFOidBHIUKAGLxeGAHmipAqUMQ3TZBgQ5ogAC0GWkEljxQVD
+ GQsEYMlRIYIIIxC4pGHCEISJL2jKHMBgg8gZHGl8MJRA5QeYEgRmtFAhJkvGDx561EBBYsKBKwYoZHQQ
+ g8OJBwUKKGCxY0TGNAiSOBlAQAoPLSEYnEW7ocENAyvMJJgrUEeRF0I6pEkAIADfswAKH86Y2PBiho0f
+ Q24iOWNAADs=
</value>
</data>
- <data name="application--minus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="sql-join" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABbklEQVQ4T6XUsUsCYRzG8ZdT
- BwdBl4ZGFycRnJycXBwEFYTiwFErIgihpamhqX9BRBBMEOTgSEShKfVCowSlBCchDxRRUDgR5en9jRUG
- b77wgZf33i+878EdA8D2wWKxmJM75hKCqHGyaDQqNxqN7mAwQL//gV6vh07nDe12G5qmgT9DvU6e+fwF
- zWYHrdY7KpWnLrUsHA6f1mo1VKtVvlhBuVyGqqpQFAWlUgnFYhGFQgH5fB65XA7ZbBaZTAbpdBomkylB
- V0jyd/CvQS2LRCIn2+0Wm81GCDXUslAodLZer7FarYRQQy0LBoPnhmFguVwKoYZaFggELhaLBWazmRBq
- qGV+v/9yPp9jMpkIoYZa5vP5UtPpFKPRSAg11DKv13s1Ho8xHA53epRlqG73Nw8eD24cDo25XK5rOr6u
- 6zvd881GPP7LncXyyWw2W9Jut9/+RTabX1OSpP90JEkK48PKHXCHgqix7vUp02/gC8LYywg0EW0TAAAA
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACXklEQVQ4T6WTW0jTYRjGPwy6
+ CHLZKsjALhYVkkhJtJvqoiN0EUGSXaQX0oIEc4oNR+ga2kRUxJ106lquaOps03by72GosZzhVonWdJuu
+ nZxa2WhBV+t7ZEL3G/z4Xp73+b27+pNkMknSIS0Zf0zyq6zkdPUIOfOYYRUIRrmUm5S7qfccfcH/GRdd
+ OHB3DuRcr5+81+cIKgIbf2wb8b+u0U8xzQ3J9COAGRl26KBLD+TsHGBdEdtLFoK/9N82ExOr6wnGE42P
+ FLW+E84HtqwAMzLs0EEXDj3AInl883nt1IpiZT0x6l37baWlsWf6z9KesWU1MoAZGXboIIMDl+SWDxd9
+ CcVNiyn8sYT9Wp1N5Pb/NI7Px7reOEMtFlek86LQXGtyRaQvpwMNg85Qs8Oz2QuXnCgz8OjVyY+rWwbw
+ NRxnjvF0NVZXVKlkvHXA4o4qOPd1Naa5SIeC8dYqRrYzFVzCeTBQPOf/YXR6v+ut7rVu42xYya0yiPsd
+ AWWbeUkEMCMbeB+UbWeWJdHgTFAOlxwtfX213bSoGvoQ7m4e9og7GF8TTzbVJuydlclsy40AMzLsmoY8
+ T+U2b6NI526FS46UaNmnyvorX9h90pa3HolYvyDSTPg6z1YMSNTj3h6AGRl26KCb+7CPD5fszb9Fsi4L
+ Th7nvaoWaJzt6gmfUj8T1DT0u1WcUm09wIzsOd2hgy4cuPjtohzYnZ1XwLokKGbflley73Q9YRcqKzIv
+ lBcCOvOR7ac7dNCFk3JJBh32pIJs+h6mHKTso2SmyKLvodQOHchwMtL/mNL5lOH+A5i6WIwCDkE+AAAA
AElFTkSuQmCC
</value>
</data>
- <data name="icon_maptip_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="property" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIUqAO3u8e7v8vHz9cTDyPHz9O3v8fr7+9HQ1eTl6NPT1ujp6+Dh5enr7/f3+PP09dDQ
- 1Pb3+O/w8sC/xfLz9fj4+evs7/f4+evr7PX19+7v8ePk5+/x89TU187P0/n5+u7w8tvb3sPDx/P09vv7
- /Ors7/Dx8/X29+vt8Pj5+bW0uv///wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
- AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAAqACwAAAAAEAAQ
- AAAIqQBVgAiRoqDBgyFACBwwouEIDw4tOBww0AGJiycyamTAgIQDghcxasxYIWRBjRIOFlygsSCAlwUy
- LEjRIWMBADcLBvgQYKeGFA8+CBUaoGCJoxsiIEhx4KjTEgUJCBBAoMTSpiWkSi0ooquICVePehVREIOJ
- syYUpEiAFm3BBm3VskULoUFBFHjxXkjBIS9eCilCePDgt/BgDwkHGCjs14ABigIJqkSoMCAAOw==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACXUlEQVQ4T5WQUUiTURTHj7bH
+ BF8C6XGEwnoIpg/rIcEY2QhlW86USMjKUoa1LIO0h8AoRRSVolFWkFmuaUaBzW1awkZue+hh1pgJMWiL
+ rbGFC4fM/t1zSfEhaF34cb5zv//vfPe7ZDKZiHGfVEjmmhXV882K/n/BuTdNCpIyc76hinhDMJILPcHK
+ i24ERtuAzxPgPubuQ/zdAFLeEWQCVnBu5oTiyNYAHmI+VkXWhpLaqcYdo/77rch9GoPzlknWxHw/lsYs
+ WJm8iq8zPfgues7xAKWgUdDCXKqrGJy6WBHKfhiVctozLCv3sdmbCE904sv0NSw9OB1/fLTwGRmNxuNe
+ rze4vLwM78t7cPfV4+f723ho3o+Eqxe2K1pZeQjX0HjHr1fd2uRAdcHckK6gifR6favT6YTD4cDdU/vw
+ Y2EQY5YDuHO5Dr31SnwTx+UhXKe6DmP4jAaH9hTaeg7SbjFEXuJZ/FlhzzQemTXgyuvjwiSsLeWIvr4u
+ h7iejiAQCIAdvjNL7V4ig8FwbmNjA7lc7q8E3z6XQ2bHh+Dz+eD3+8GOgF2impqatvX1dZTblMhms+Df
+ 4a8Eg0GEw2G5tx3OsiNgl0in05nX1taQyWTygrPsCNgl0mq17aurq1iwtCOVSsHlcsHj8Wyx2W9WzrIj
+ YJeosrLSkk6nkUgk8oKz7AjYJdJoNB3JZBItViAajcLtdsNut8u6/XlxcVG+5yw7AlKpVERqtbozHo8j
+ EonkBWfZKS0tJbnKysq6+PixWCwvOMuOUHcJdlJRUVFbcXHxjf9BOBeELM5PJb8B18GBdzrX/msAAAAA
+ SUVORK5CYII=
</value>
</data>
- <data name="database--plus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="application-export" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACQUlEQVQ4T5WST2iSYRzHn5qK
- Hhq1oMLLoINsbC4wki6CXUZ/NsHES0SnGhTrFJIDDy47OnaoLd6pzbk5nU77N6evUzcyK927IQt0NMrt
- jd7I/hBdOn573rEO5qL5wIeHh9/v+4Xny5eYzWayQy+9+/aIuLut+yMmBoOhr1qtolKpoFQqYW3tDdLp
- V5ibyyGVWkU+v4Fy+TME4Rfo7g2j0UhEagwEQUCxWKTCNFg2icnJCFzuMKYDCSTYApa5d9jifzZgMBXB
- GDXwB+cRT75GgdvAJv+jEYNZMJ4ZTAVjmE++RJ5bR4X/9k+Dk/39/c9cLhcYhsHw8DBsNhusVivsdjuc
- TifEmcViidMMtLtm8HeIqUwOT+YXEU/nkC0Usbb+HpvC171/wecP48G4H95QFE8XMsitFLHBf2zAYDqE
- 0fFJjIfCeJxawIuVFbzl+QYMAiGMeCfwMDyDR6kEeuOX0RHTQTnUllUPaEn7bU1ND/4bYqvvBK5+t0Di
- PVomE4cJ8bQQYjKZtunp6alrYmopi0g8gQvRS1AFTqF95jTMX/ogHz22RcUccbcwRKvVku7ubqLX66/V
- NpGFLxjEPZ8HrWNdOPPpYh1k5CBHxKNSqYharb6+u4EbOuYsjo92QTWmQSevg/TuIZ44mzky1MyIegXl
- iFKpvFXXg6XnmE3MIboYA7ucQdt9DZSVDjRZD3wQNTtaQpMgnQqF4qZcLh+USqWDEolE5A7FQd8OmUzm
- oDNH03nZ6r4rMmH/OSkraigtvwEKQSNnrT8HPgAAAABJRU5ErkJggg==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABzklEQVQ4T6WTO2hiURCGB+0M
+ go0YtrwKaqlphKCVhQ/EB1qE9Ek2CYElsFvErRZ7KytBEAtBsFDBqK2P5MpmIckiaCGIKCqi+MAHyuyZ
+ W66Fhgx85zTzDWd+OICI8BnA5/NxjDPGxYFQL+f1eoEAj8dzXi6X3xuNBtZqNXx7e8WXl9/4/PyEpVIZ
+ i8UKu3msVP4gz//Fx8fiOzkMcgFcLtfXQqGAuVwOs9ksZjIZTKVSmEwmMZFIYDwex1gshtFoFCORCIbD
+ YRSLxRcikQgIWuGSZfChIodBLoDb7b7abre42Wz2wvM85vN5ZE+/cjqdYLFYABwOx/V6vcblcrkXWo3K
+ brff2Gw2nclkArBarbeLxQJns9kO/X4f6/U6C7Ek5EJ59Ho9YQiTvxmNxhMwm8130+kUR6PRDpPJBOfz
+ Oa5WK6Q1/y+dTvcDaNJ4PMbBYLBDs9nEarWK6XRaSD8YDGK73RbmcBz3U6VSGcBgMNwPh0PsdDp7CQQC
+ giyXy38pFIpTNgRAr9d/p11brdZeQqEQ+v1+1Gg0D0qlErRaLYBarX6g53e73YOgXnIY5AJIpdJLmUwW
+ +AjkSCQSIKjoPGZ8ORDqPRJMqs98ZXL/Ad8QklT8D+CBAAAAAElFTkSuQmCC
</value>
</data>
- <data name="icon_pan" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_buffer" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIUAAAAAALe7woCEiVNYYTtBSuHi5Keqr2hsc9HT1uzt7pSYnHB3g8fJyrG0t////19k
- a97e342QlURKUqCjp7/Bw290en+Diaqvt5Sbp1lZWUxMTZCUnMzMzKOosri7vNbX13F1e+Xm55KWmWZq
- cZyfolRUVL3AxIaKj660u76/wKastd7e5s/R08PFxnR5f5SUpdbW3sXOzn6FkpmcoKKlqJScrbS4v5SU
- lIWLlf///wAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBBwA5ACwAAAAAEAAQ
- AAAIyABzCBxIUCCAgggHZgCQIWHBhgcbJmhxAoQLBR4+5ADAsSOAAxVEFKCgYAaICQxKbMzR8IGDECwg
- JHAAwQEIFhoYCnzQQqYDDgUcyHAwgcJBgQcEeGAQVAYLBwwckOAwMEQEAgZaPOUgMwGECg0IfiBw4cOH
- EAnSJkgxQGCCEQ8GEPDAVW2CEG1zzJiRlkaFFi1g2M0r4YAIDyYSB7BRIK0BAgNTWCAwA8UFFR06INhA
- gEVBFgRwYBi9YQEBjQhBS5BAoDUEggEBADs=
+ R0lGODlhEAAQAIQAAEZCU1KTygpgs6jS54Sv2XuSpTJ6wL/e65jI40mOyObv92Wfz7LX6Iy+3hlquKXM
+ 4rjb6leVykqUxY2bqK7V6JzK5Gih0FuazVCSybzd6sTh66TQ5mme0f///wAAAAAAACH/C05FVFNDQVBF
+ Mi4wAwEBAAAh+QQBBwAdACwAAAAAEAAQAAAIoQA7KODgwAABBR0SKlxIIAKCBhEEKFRAwIBBhAYaFACw
+ IYHEDgIiNIDIoUNGACgHeBSQYACAAhUcdCBwwWXKAThRAmhgQCBLCjopAEVJ4QIBhQIwDNUJgAIGAQiR
+ MmDAlMHThQkFTNVp9eNCAQEg6IQQwGtCBWAz6MxQFuvMBQd0Hojo1uQDnRro1jXwYAKAvGaxErAA4YGF
+ wFgHFjxYN2FAADs=
</value>
</data>
- <data name="icon_pandown_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="arrow-return-180" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIZuAJumsOTY2MS5uK+2vcW5uJumstrOzsi9vOHV1eHU1ZunsuXZ2dve4d7S0aaxvuTX
- 2ObZ2aaxvePY2NnNzODU0+HT1Ofb2sTJ0c7Jyfjz9J+rttvPztrPzpumsdbS0pqmsdfR0dbS0aSvupum
- s9zPz9/T08/ExMzFxNbKydfOzdXJyqOuutjMy9zQz8fP1tvPz97R0dLLytfLysG2ttPQ08vEw6Ouucq9
- vs/Dw6eyvuLW1eXX1+TY1+DW1sa8u+LV1vj09dTQ0NPHx8i/v9fKy+PX1pynsc3BwaSvu+fZ2tTIx+PX
- 18m9vJqlsNLMzMK4t8zAv9zQ0P///9TR0KGsuObY2Mu/v6CrtqSwu6mxu8m/vubZ2pqmst7T0tXKydXJ
- yc/Jyca9vcbL0si8u7e9xK+3v5+rt8zDw9PHxtjPztrX1+fa28/S2NTMzAAAAAAAAAAAAAAAAAAAAAAA
- AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQB
- AABuACwAAAAAEAAQAAAIwQDdCBxIkCCAgggNCnwRgEAKMAndHOwBhQMEARa0qCk4AMCAGgsIkHggYM2Z
- IAQZAGBwwkQAAQZ4CNjSpQ1BIwJ9oKlCYMMDIUkkxEg4o0UAJRQqJFggIUTCMQGWlKDwY0eANAWPREFw
- Y0IFBAl0FIFAgyCIJw0a4FAhwwAMAxnYDCDoYQiKCV5YfCECREwEM2UKOrFy4AATKRc0RMByJQvCKRjC
- uFAwQoSDFVwiuiFToEATKjlsaHaDpMCHDgocBAQAOw==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAClUlEQVQ4T6XSe0hTcRQH8IPm
+ Y1ZWPnK2yqt/NMpHPqMkUaNCqn8iMYSbZGFhSMtCS6RBD4VmDxqVjCywP9QwLa5GPkK9PVDHtVrlkx6z
+ 1WbhH5kSE7d7OnduK8T6p8GHc36/e8733j8GiAj/A1JvjTmk3f6qI8I/6OkZR9Q0z6TcNENy5ScAqXES
+ rhkRL4+I87pE9+VvbdYCfsqytXqMp510R8CmG6MugvaDiJoBm9uFfhu6lL+eQbV+Gku7rVjS+3Myreoz
+ T7sMbNC+d9ElXX0n/E2q7qMhp+mbqfjplF3VPom5zeNmmlW7A+gAiVdGIFbT7yD1f4q/OKiIqxjQZN+z
+ mApavmNhx4SVzhwo1b2w9owAUedfOvqocy9Yoos82we05A6Jo9DosleKpIo3hpyGUcxrtiDt6EF+5CGs
+ VLVBxEke1pzuYSlEcAKmqAtWFT52iDj1RHquiCnrM+yoM+Kuu0akud8B4cVdLIUIWqMdpRp2osO9LAUw
+ RZ0KutdsrBw0RdeYcXPdFyududkvONrK0lcIpUM2zOqeRqmfK7yEN0RdHzIp70/Y5fU/MLJy2EwzagjJ
+ b84gQq5BRK8HM7iuw4479SJu6xEx5bmIibzdcRfWZkP/Jhv6cTO4unZ8Uq5q5enlDAQcaMggwnY9/ac5
+ xCWPEBXtiKFE3oa4nAS1Iga2iBjcOGWVa4ctgflNfODBxvTgwxzAsv314L+vjl3M1gpJz2YXpX4eerrj
+ iJrmGXopLEzMBpDFZoFPTCb47b3DyrKqBWUnolR9t5SCd/Seefmsz4S5P0+6kC1IPnbIa3eVIKHzCqdQ
+ qiEkiCwli4gv8SIeriBvagJImEdCnsoj+XgN9QlO8VRjiJIwRO4MklH1/AWgVvXWOcn9vQAAAABJRU5E
+ rkJggg==
</value>
</data>
- <data name="icon_selectpolygon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="exclamation" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIMLAM2qrs8YGBU2aKi0ws2OkfLyl851eMbMjqiToKOuhs6QkwAAAAAAAAAAAAAAAAAA
- ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAALACwAAAAAEAAQAAAIbwAXCFxgIIDBgwcHCixIAIDDhwAC
- KGQIEaLEhQEaVnRI4CLFjQA6GhCYcaMABBFHkgQp4CQAhQFYHhAwACbLAjNrrjRZACfNnQ8bCujps2bM
- oBKHJmjZcgFCgwoWCFg6oKpOhQNbXsWK9SfXr2ADAgA7
-</value>
- </data>
- <data name="edit-indent" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABjElEQVQ4T5XTS0sCURQH8OOm
- rVmL1E0UGhRWJqGGBUapQZE9NpWQSBBtg4i2EkF9iXa10srHFJHUWNGDgmhTqyjaRASt293+Z3AmXyM0
- 8PPO3Hse98oMCSHIYDCwOCQgWbCHcR8OIAVpyIIEW5zDucpPocC/x/IC3LlWV+oNrClcQ6vkHFzR3wEH
- qMHquLj5TaqFjS+Kxj/+CjQ7Y8Ts7iVlIbb+KSNI6OH1kgL983li3rlTCi8/MXH+8KOL1zlO+w/cMzkC
- 4RhP+z2zOeqLnMn8rIfXuaFWwB5KELyB4PvO8BG1j6YrdIxlyTl1yM2UHWsFbMEUgWgdTvjtoQyKZWR+
- Lsfz9pBEXRPH1DN9UrwDCUkStY1I1D15w6qen+cL60qctoNGW4RYvdlLjuAutvcqD0TfRTmedwR2yNjk
- Ib5030ST1UctrpUKJotPSVSv8gIy3sQ8XMAlXME13MId3MMjkp/hpeYO9L6NkvbFR8C9EUnbNbomEWMt
- sGBsgDrtCFwAzEVBanC1saTAL88kUjz8yRfZAAAAAElFTkSuQmCC
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACDklEQVQ4T6XTz2vTYBgH8OcN
+ is6LqAM7cXpxwlAsHnSIiF6ml/0FIlgRhUEOO2g30JPgPCi402C4grP+3rSz/qqpWKtlunXQt7GzrO1W
+ Bk2wdLWDukJdx+P7hKVka0HQwIc8ffL9Jj0kgIjwP4COi6cZTL6ssVnshlfQvCpDHQIDvXXLFL6gxR1c
+ i5/lNNd5gHFDmHjBaoS9rDni2+qpLI6UK4tPyxHfFg/t6mXhq4fVGB9lV7IzXcml/C1cyt/EbEpO0q5e
+ FsaesVW+PGd27t+t/F4YXHY6nUjKhf5lrjQrdG1tHj4PMyspNML6cukerZjpRlmWDcXMZcwmZY2uibxk
+ 7UDwMav69IS1R9/vD/36cQMX0p3ocDgMNBe1q8iVlhBlrB348ICZGgKPJHcu3V0ozHaKJ55Du92ONpsN
+ Y+FTqE6cxNhkR4EyotNg9uDdEDP43eyMGmjj+bkuTE11oMpPoHhFDFF+3BBT23HszS5OWbMHvruMNPrv
+ b/DqyfOlROwYxr8dMcxnrxnM33SeihwqKe51XupQF165GLx2sUuRwIHE3PRRnP1+sMr8B9YdzWF/U4I6
+ 1IXRAbbHd29jUE8crujT+9DKvMHafSbeWnk7tD5IXXh4G1zqx536/Ewr5lJ7hZaq0s8eJNadOUcD23Xq
+ wmAv9N+5DuP/grr0MUrCJmGb0CTs+AvKNK50pD9EZQJEPplB2AAAAABJRU5ErkJggg==
</value>
</data>
- <data name="arrow-circle-135" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="document--pencil" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAC1UlEQVQ4T6WSfSxVcRjHf93K
- HxSNCKNkSGSpKyOMpfVi3aympVvRIhZXhWV3RSuypZmYl1WrvC1RrveX0UVKpXZ0N1Ot3MQurisvYbc7
- pp6e56j+sP5o62yfne/zfJ/f93d+5xwGAOx/YNuylDyeeQPM5/YQ8707ssrvnkaEpCPtCIeUIBL0LGmG
- ZmkNbbw4wNY/Xy2NkE+VpHTPKbKUP6YQQK2NbJlW+ReoFRgg+ntAbr/FzvzB0Oy+75mpirm6ZG72HTKF
- AIE9QA92FQ51e+b2i/48gTDjA3O78VHPK/eTf1bvfExix0zm2ebJmn2Fqma3zN52hEOtjJVP6pI6ZgBn
- wDuvT4FrLPkjuKb1EBZHyof2S1snYiKr1FlYX9ty/W0AhROoxdjjous0OpyB0Gq1CmsJH+CU3EXYS5o0
- QadlgxLvjB6pc8qbrZuuKtjGKxwfQJtgT7wj571SUjUE8W1jWlzzgA9wSHzJHC6+sEl4Mu4bcv+zn/2F
- 50Jb6VNmc76NrYtvZdaxcuaEQRuSOhl6XESFCnAWSPMBNLA2ruUWDnOLoT75VuceM2uE/BMYEN2kAdJ8
- gEV0A8GFNIzCoUo1T4R8HKhnKWk8Zh5Vz1aHVzKLqHqxe9prZWDZIASVDWjRXzgCmQi3t3oM3IqH4WDj
- BFCN5BiflDGj0IfMJKxCTL3AymGdV+kICNO7VFgvvETD46UE5103DXuaZ8CudAJIu6R0KKlPkN5dM6pz
- Lv8KHrVTYBwuUxiFlC18Rv3DRQQX8GwW6O7aqAO7Wh041OvAXT7LQ9q84husr9GBYZis2yC4WLTyaMnC
- rywwdWTLD9zhfpGqF1zc5pL+SrVZ9kVr3jgP+jXzsKJAozW41KlCT7HMJ0EkMHNkdPEBeFkJtscXCYSn
- 4lALl5g5+Qs8zlwWBGQ/EohudvGQxh55OOOEmCJLfwcYYmGCrEEs/wFabIAIKOAngC8O+qdBFeoAAAAA
- SUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACMklEQVQ4T4WSTWgTURDHZ4/V
+ Ww4KhRwCjWgIegjFrVLbSq1djaKYQg/10ENMQxs0JRhSbRu8iBc9eBLUXuJFlFCsi7YiGL/wXrURTGgw
+ aZRQbb423+PMtg+CtPHBD5bH/H/Mmx1wzMwAMzQ7e4a49B86LkxPw/mpKTgXCMD+7m4AvtjCVajV8He5
+ jL+KRUzm85jI5XA1m9WZj0SQ6lyEWQhYotu2GMtVKpih4NrGBsYzGYym0/g5lcLlZBIfqSryodoxwsxh
+ XXDW7xe48yRYLxS2ldwNhVBgVpTrBDBg9/kE48VqFf9Q+ztJuBN+DmXGRQ4GvV7BhEYzyGpaSwkLKDPB
+ uVtdXQAnPB6Bp0SCfKnUUsKDpYxn0WiET5IEcNztFlyu1OtYpDm0kvDfuWK334lJUviDJPXCMadT4K2S
+ oERzaCVZjsXQ2d+vYjCI85L0Bo6Mjgoma40GlukZO0ni8Zf4OBxGjeY00N5+ew5gAA6PjAh8dRJwF9tJ
+ EqtLGHk2iFoqgAc6O18YDIaD94GObXhYcLVBi1Ijwb+SZOIVvl1Q9PCTh314+uLReyabDVxWK0BHTw8c
+ cjgYP29ag7polqR/vMZ3C6c2ww968Vt0EbmWM5zVj1GWYZ+iXNN3tUmy/vMrvn++GX5K4ZUvKvKycS1n
+ xGmjjz17ZfmGEOgS4qMaRMxHMTzXh9+jS8h7UqYOuZYzBGfBQFjbTKbJ3RbLzWboHodO7lqxyMZQ8z3X
+ coazfwEpq4JeDHDvFwAAAABJRU5ErkJggg==
</value>
</data>
- <data name="icon_select" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_zoomrect" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIZdAOvsxmuAjjRRfpOhtpOitjRQeDVQejtTfDZUdzBMejtXf///1/385///74OTl3WE
- mu7w81Zhdv384KCuwG+EmZWjtPz72/7+3ISQoeLlyFptkPj5vs3Q1ImYsOPl0ktgg3CBnP/95mp9if//
- 4NfZ3P//zYKTjKWviv3919/inpuovOTo59DU27e6weTn4P//7KGyxzVRfjVQezJNdlRqgoCQl7/Gzm6C
- n9fd15adp+PmzNfe0P//97C6y2d7ltXb45mppoqZra2yt+rs7v///5mjuOLjrdLauuzvqmN5jjVSdf//
- 9NfavlltiGp/nGB1h9nenmBviLq9wrS4vjRQdzNQelhujqGwnOXp7M/V2KWvwfv60+Ln2v///wAAAAAA
+ R0lGODlhEAAQAIZoAAE1Z6e2z3BJJeqxd8Xa71tgZMfb8KjR49Dh8trn9LjH19nm86i7zufu9brT7Zu2
+ 0NDg8dHh8tjm8qu0vOzw9Mza6PT3+aSttoOGiGRrcoSAf15cWuLr9a22v97m7Z+fn7e/x1xbXcbb75mi
+ rM7X383U2cjIx3h3d9fb3+Xq73yQo4SHi7S3u67L53ahzKq8z5u83uLs9a6yt+Do8W50epyzy7bBzeTr
+ 8cvY5cPT49ri6unv9LvU7b7L2EdKTauoqHyPokpMTMjQ2OHr9FhYWbCurbC/z398e5GRkqC50q/N6tbe
+ 56TF52RgX4SFiJDO1oiOlGxtb+rv82BocJy20KWqsXV5fsrc7tDh8aCnr6jG5DAvLq7C1efs8auvs+Dq
+ 9JSVl+vw9YWUo77H0Tg3N5qbnaamp4aKjQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
- AABdACwAAAAAEAAQAAAIjAC7CBxIsCDBBDcMKuyioMeEhQVjQPihAuJAAViIZAlisYuMFUt44BhgsYqL
- Bgxe7CAA0QCXEBIsjMhQYSEVDxdQbGFyBEgHhQV0LABQgsaBD1EUIgBQ48kGBw+ESFGoJIAVH1eMaBiy
- cAaIKRgoIDFRZKENEl1YRDgBpQmHjjmSpBDRomMXGE60FAwIADs=
+ AABoACwAAAAAEAAQAAAIuADRABhIsGDBAAIDKFzIUCEAhA/RSJxIMaFANEU0NDnyo6JFNB9YjOlhowoS
+ ExQjlhHiocuOGRWMrEgZwIwMKUssNPgi4YoYMBMfnihBQceNIQsgEKgRImiADSnC4MiRIAIBB1rIOI2C
+ okGMBAhEHFBCxcdBKF44LMBi4MATJipoNAThhAQCAzxguEgyZYLHLBhGcGnxAEiGAh4ldjhDZEsQKxcK
+ CBiQGI2CFwokMhAwuXLFzZ3RBAQAOw==
</value>
</data>
- <data name="ruler1" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB3UlEQVQ4T2PYn8jCsD+JheFA
- EksGEHdDcQZIbG0EM0gcJw3SywAiQIqAdM/fm8v+/7qy8D+IjU8jzGCwAfsSWTJBGpaFMF98sLnh/9dT
- 0//vTWQ5AxJbE8E8Bx8N0suwPZZlyu9ri/9fnej+/8fFef8/n5gKZ9/fWAcWw0aD9ID0MgBtmf92f8//
- baUm/+9tqP3/8eik/6dbrP4/29aMF4P0gPQyzAtgap7lx7QRyLn/9fSM/+8P9YMk7oPECGGQXgagIjCe
- 5MY0787aqv8gkzdHM88AiU30ZMSLQWoYloYwM2yIAuPZIOe/2tP5H8QGic30xW8I2IBOeyYYXnhzZdn/
- FzvbwH4DYlD4MMzAYwjYgJVhzDC8COR8UOABxRYhiTNM98HuErABjZaMMLz0+tKi/0+AaWFZKNNSIGaA
- YS0xRgZ0oCrMyOCrDhRfHMwEwytfAZ3/CBiVQLGVMHFNUUzNKIaJsTEwVBgxgvDqK4vy/z9YV/1/rj/T
- eiBm0CCkGWYSyDkTPBn3vAa64NmWxv8gNkiMWCAPVGiUasywsM2Z4TgIA9nzgGLKQCwHxBJALAzEfEDM
- CcSsQAwMPQQQADIloRikWAyIRYBYCIj5gZgHiLmAmB2qmRlIw50HAIdyTYaOb/frAAAAAElFTkSuQmCC
-</value>
- </data>
<data name="folder--plus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
@@ -1029,103 +1073,6 @@
+Udxwfacx7rDy2ZKjDmTjj30QE3VVmoRDdP+AgqRc9vLR4PDAAAAAElFTkSuQmCC
</value>
</data>
- <data name="application--arrow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABpElEQVQ4T6XQTUgCQRjG8QEh
- iBK8VNAxAukWHsKTJy8Wkit56ItOfRJRBF2iLtE5kCAiEUMSwRJBENGOaYb2sdCSgZeMlBRRUFBEeZo3
- ggoK3HrhB7uz/IfZYQDYfzCLxdLHjXNzMlHTx8xm82Q0Gr1PpVJ4fExCkiSI4h0SiQRisRj4N0Qi5Io/
- X+PyUkQ8/oBg8OKeWmYymRbD4TBCoRBfDCIQCMDv98Pn88Hr9cLj8cDtdsPlcsHpdMLhcMBut8Nms0Gh
- UMzRL8zzO/jTUMsEQVhoNptoNBqyUEMtMxqNS/V6HbVaTRZqqGUGg2G5Wq2iUqnIQg21TK/Xr5TLZRSL
- RVmooZbpdLq1UqmEfD7fkp3zV5zd5kANtUyr1a4XCgVkMpmWTJ48gZzevIJaptFoNnK5HNLp9I82PEmY
- D6VvDl6AsaMHDE5su5lard6k42ez2R8N78VhfQaWJGBa/LSeBPpX/S9MqVTOq1Sq3d90jWzd9swcZ7/S
- RgB6Vw2N7zM+7Vw319sK5YRTJJ2CdfajpT1aG8XAKGsTbIfcVIfJ+h69AbnIrwah7HLvAAAAAElFTkSu
- QmCC
-</value>
- </data>
- <data name="marker" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABlklEQVQ4T4WSP0iCURTF75Og
- oWwp+gNurQ0tzq6igyBokkOUhAkqiOZQkyCCW0stQkUukkMUjbUEQpRRS1s0BI6SGoqVdrvH/KQanh/8
- ON85977jg09iZjKoKEXCpBATDoVCX+GRD3aNM38CWZgT9usOx20nm23wzg5D4ZFj/vsH8f6/INFwue45
- leKvZHIAPHIpSGgLXpTKd9Lpt24iwYVAgFe93p7CI8dcW/CkVLGbyXQ7sRgvOZ1st9t7Co8cc23Bo1IH
- rXi8+hmNcs7jYYfN1lN45JhrC+6UCj5brXcfcuX3cHgAPHLMtQUlpaZKJtNpbWOj3g6F2AAeOebagiv5
- zhdKrZbn58vtSIRb6+sMhUeOubbgnIiEsTOik4rbXW2urTEUHjnm2oKiLIBjouVLi+WhKZ8QCm/MtAV5
- OdzHfERUaqysMFQyM/LtYTeQOW0KuR+u634/Q+GR49HeoL9DMXnZI7qp+XwMhTeeYQUmWRwXpnfl4Kv8
- laHiZ4UJYWRYwYgszQgLQaItHIaKXxQswuj/gm+HNTFEuMVJpAAAAABJRU5ErkJggg==
-</value>
- </data>
- <data name="globe--arrow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAADYklEQVQ4T32QfUxTZxTGX1td
- ZgyaLDHoMg1+sAFzkxSVKqYR/IBtBjRZ5nS0cy6KVhNiQIgmfiGFUKgojEFTIGABJ9qNKXUFnPsDUUpp
- a6VNqVTrFy1YCVDEdBX77NxK4h8mu8kv573nPM/znnsZL/sO4+UaGP/MAOMXPv6QLx/cxC92y4krRMd0
- lYf63Jx0nD7kI94euIA8RwQNlfHVT8yFt154m2w+/1WHL2gcn/I3Ol95Nze5zdyc070fkKOPmHfS3JJ5
- 7Yn7sn0Uvb4pNNrGoTKN4vZzP+wBwP4vcNYw4uZ0PNK/2yBDO5snba/NbHngKer0oN3jp4AgGq2j0Dh8
- 6Bz2o2dsCj2TwO2XQEGn28PpeZwvQ8vYjPSm5JhjOtuPl+5j/1UX6h0vkXfzGY7//QwX+yfwzwhwQuuE
- mvq/DwFXnr5G5JHrNs43Y5eaArZXlklqTKMptXZsrutHmrofO5qdEGse4kCLC+l195BarkepJYBjlLZH
- 8wi7SM/5CMZYcpHusHYokFhhxcpSI4RVViSorBBV27C+wgyJxo3crjc41DEJUakJscUGfF1lCnA+ggIS
- T+uFJ28EN9YOIlKmR1SJEdElJsQoTIiWGyCQmyA6Z8e3mkksym6DQEHhJd1BzkdQwIZTbQlyQ2BJXjeW
- F/YikgyfTRNFNTK/G2vOObGlcRKLM9vwjQbYrh4OcD6CAjbKfvk8Vzf2adE9RBX3YcVZK2JLrRCct4WI
- VVgQf96JlfkWJCiHkKQeh6h8YILzERSQovjqI7H6fhyJBMS6iodIUrqQXO1CSs0jbFG5kFjpxOoCM767
- DohUbsQp7P6IrBtnwjP+oIDUX2ezbcqGqBM93iSlB6l1w9jZ9By7m734+bIXieUDiFfYsaqIfi6d44r7
- XlcOAl8WWExfyO6mM7bjAmPfNyydKW5uFxRavZLfxnCwxYes1gnkaCcQJzOi7CkgtQFiyzuy+oFlRzt7
- aQV6wmPoU/KXsp/+bPgkp8uRphock2rGA0daXwWFMuObZdk3pxYc1PnnH2gdCZdq+4RdwAKptnfhob9o
- A8b4xHwimoWFC9nafXuZpLmW7dN1sIx2fahy71yf5mE7661hPzTcnSu+KKGQ0P08Ys50yMdU/5cP0qpq
- Zm0t2z3tY/8BOAMvdn6kKfgAAAAASUVORK5CYII=
-</value>
- </data>
- <data name="document-copy" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB70lEQVQ4T42SPUubYRSGz+Kg
- IphFqCAFY4YiWboIUkyLhZjQWhULWVwcNJUgRqpECWazP6DkF9S2UkTqoAjBqnF3dOtQBC1YNOb7+/Tc
- Dz3yECvkgQteeN735lz3eWlybY3exmKvhZkH6JuIRmlsZQXvGUYnh8nf30aurhYiXArBXLXK18Ui/87n
- +TyT4V/pNO8kk4w7wWUHaOCg10MmWXiXLZf5TzbLF6kU/7y64rPLS/68t8c4uBdcOoEGvIlEiF4tLYG5
- XKXCN7mcCUmcnvLXoyNejcfveBEMfv+neKdkAkbCYRAqiMJtoWBCtk9OuBklE/AyFALzJQnISgcI2Rb3
- ZpRMwPPZWbBQrtU4Lz0gZOv4mG0l7eXjxgYrLp8vKhA9m54Gi9V6nYvSA0K2Dg/ZVmosFxuCNvRpYGoK
- vK9JQEU0EPLt4IBtJS1XJzmXoqENfXoaCIDluqyrKhoI2Uwk2FbScnUS/CvQhj65x8dBBPuuyxQI+bK/
- z7aSlquT3JRKDG3oU6vDQT0eT8z8MQgRPu3usq2k5eokaekJ2tDHedzudIY73O4PSp/X+8NW0nJ1EqwY
- 2tDH6RQeCd3KE79/3VbScnWSvBQN7d6hIRPQeDoblaCDTlAstlOSZ7wjHzr+F3BPydbTZ2jLx71/Ad5i
- gsnRJ2HiAAAAAElFTkSuQmCC
-</value>
- </data>
- <data name="document--plus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACEklEQVQ4T4WSS0hUYRSAD5NF
- gyA5mFJRMOBEmJSPRYM43SyChh70mAEXEkw+B73KyNjglBpCtKlNUSAlQdimTQQh2HI2bmbRohatJGtm
- xAYf834fz7nM2ahzu/BtLv/33f8/9wfH9DQwzpmZm8TAf2i8NzUFd/x+uD05CWdsNgB+UWYwWSjgZjaL
- 66kUhhIJXI3H8XcspvElEEBaN0hYJMARrVZmKJ7LYZTEyPY2rkSj+GttDX+Gw/gjFMKPi4vID60dIiws
- a4FbPp/gTlBgI5ncN/JqYQEFi93+mAAGbni9wnAqn8ct2n6lCO+Ej0POsHhwzeMRRtI0g1g6rRvhADkj
- 4sFVVRXUDAUSmYxuhAdLjioeXHa7hbFcsYgpmoNehP8OOWPiwcX+fsGTp0CG5qAXWacjkuMRDzpcLmG8
- UCphlo5RKXJ/eRRblq5g3ctzy+ZZBU496QC40NMjeIsU4F1UirR87cK+jQk8NH/ij+H9UYB5E0B7d7fw
- sEQXpUCB3ZEHAfry50uEgs5/A3jwzbG/JAfhnWkOGhUFzjscjI9vWol2sTvS+knBrsjdPcDrI0Hg56TV
- Cqft9kfaXd0n0rukYusHm0bzqg2rntaF4HlNEF7UzLFvJOobrNZZCWgRgmfCg+Uj8S9ue9uJx1fO4gF/
- bZidsgs0CWg2ms3j1U1Nz/SoctZ+N7iMEcP1w9/YIUw7Q/B728HeTjIAAAAASUVORK5CYII=
-</value>
- </data>
- <data name="sql-join-right" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAC50lEQVQ4T2P4//8/AyWYIs0g
- ixn0i7czGJbuZDAq28VnXL7bAoj9gTgSRHvUXghMbnu9MKXtzX0g/gWl5yW1vNKIrH7I4FdwFW6AnEfL
- wdiVxx5Pe/j6247Xn36eW7j95ZGougfvY5oeXG5f8vr82gNfHs3e9OFO7axXz6NrHz6PqLofBDOA37Vp
- f/zVxx/XPHrzdd+DV193Hb709kRA0aVPfctfPVqw/cOVpJ676xfv+nh12Z5P15bv/XSjd9mru775l557
- ZJ3XYNAt3Gq7+ND9afdffd1958WX7UAD9mS1nbuf3XH9xdLdn66BcMuSZ0crZj/eBzTg+pJdH6+AxLI7
- bjy3ijkwj0Erb1PE9SeftlyD4nsvv+43Ct3ysWvJ0+sT17450r7s1e6eVa8OhTVf29S98vW+pkUvtwHF
- djXPf3xBx2/TfQb17PVpQJsPXnjwYT0I33j6aZeK++o/ncteHqqe+2wTCPesen3Au+ri+p6Vrw/CxDqX
- vzyi4rb6F4Ny+uq4s/febTh55+2a7edfzNlw6ul0de/1H0un3DtVMefpZhBuW/biYHDD5a1Am/fDxEqn
- 3j+p5LL2PoN88nK3SVuuzdp4+umcnk03m2bsutvll3/4Vkjp+UfV855tB+HCaff3Z/Tf3lM7//nOsllP
- N4PEQksvPFD33DGPQTp+sZBO9qqihfvvTu7dfLO9ac3Vhp7Vt1aahJ34nN/34HLTomdHA+subgfSh4pn
- PAa5aHte38PzRiEnn+sFHNNg4NUPZBB0KVdXS1taWr7g5KR5++5OX3Pi8YKiydf3WsZe++SUdfVWdt/9
- M21LXxwvnfb0VGzdw4fWsTdfaDkvCpLUSmMAAWYgFmGT1DHmdyqLEw6ZWiQcPrtGOHR6oYRDXZZlxLnV
- DknPHjgmP//lkPT0oXnIsdXiKiFuID1QvQxMQAYXVEAKSEsCsSgQCwAxHxQLAmkxqBxIDUgzSA8T5ZmJ
- kqwM0gsAucRqK8NQIioAAAAASUVORK5CYII=
-</value>
- </data>
<data name="icon_refreshmap" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
R0lGODlhEAAQAIYAAAAAAP////vz//79//fy//fz/vfz//38//bz//j2//b0/vf2/ff2//T0//T0/vb2
@@ -1142,23 +1089,22 @@
DR1KcCjhQQQWLmjLkPGysTpDrtgDAgA7
</value>
</data>
- <data name="icon_search_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_home_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIYAAAAAAP///+np6q+xtc3O0JeboqKlqqSnrKOmq5OXncXJz5SZn7q/xaOnrKSqsMLH
- zOLn7Ont8e3w8/n6+/j5+vf4+fb3+OLj5NfY2Zieo52jqLS7wOLo7PH09pKan9rf4unu8ebr7quzt9rg
- 4/D09unt7/P19qCnqvT3+PP29+rt7pqipPD09e7y8+nt7ufr7MrS07W8vOLn55Sgn5qlpK62tcrS0c/W
- 1dvh4Obr6pKfnO7y8aSuq7/JxtXc2p+qprfBvbW/u73Gws3U0cHKxaa0rKe1rMbPyZ6uo6q3rpSmmJCj
- k5Ollqe1qaq3rKOxpISYhYOXhIeaiJSllZ23nZu1m5ixmJKqkoSahICVgH6Tfpu0m5aulo6ljo2kjYmf
- iYGWgYKWgoCUgHuOe6O4o6C1oJ+0n52xnZiomLrJurO/s8rUysfRx8XOxcnRycjPyMTLxOLo4uLn4uHm
- 4eDl4OHl4ePm4+Ll4uHk4eDj4N7h3vv8+/r7+vv7+////wAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQB
- AAB+ACwAAAAAEAAQAAAI6gD9CBRAYECCBAMICBDIUCCGAydiBAHyQAMCDA39YMjAw0kTGSVCwKCxAOPA
- Az/QoDniQkKEEUVEGFjoh8CKKU92oOggAQQEI0o8EBA4oAaOHChSkHDJgQkUHQMEJhAy5EULFhMoVDCR
- J8+dC1I/3CDiQwIFKmjTph2gwIYWMUksVEkTZ0+cNFWqbCHgoEcYLWPsWJGzhswaOVYSC2jAAAmUKHq4
- 9CnDxUwfLpg1FtiwRAqeK3XYnGEz54pphwg8zFDRRQ2dPnT4uPHShSHBARe+6Nb9Zk+bLxkFYhlOHM4e
- LMH9gFm+PAvzgAA7
+ R0lGODlhEAAQAIZYAOTk47K8xp6iptXc4KGnrtHJsdTd58HN2r3Eyunw9P////r7+9LZ3Za3p7rF0rG6
+ xcbWzZGTlaGor7a+xKeqsOPn6+3u8Zqfo7zNyKattdHf6PT19rzAxPb4+9fc4rvG0tnd4PLz9fn5+sG5
+ pNbW3dDb5d3Wyc3X4sPGydHR0dDZ47fGxLK9yb7Lyb3I1qi9tdXZ3Y+Tl8rR1sHM2si+p8/S1cHM2MPL
+ 07jD0KaqrbzFz+7w8p+lq7C2vPP09evr6q2yt+3q48DI0bbBzKm+tvf4+czW4Y+QkbC6xKCmrsXP2tXN
+ rPH0+LW8wq69u7rF0c3Q0srN0ePey/Hx8N3i5uzv8sfR3sPO2////wAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AABYACwAAAAAEAAQAAAI3QCxCBQI4IGHIgVoUBjIEEtBJQ8ykFhCAUBDhwcMGJiBIyKFCRYHAjiQwMgV
+ FwEcIImRAyRBkiccGDjgIACPKBwugByZQIXMAB8CJKmhgAmMCxeaJCiRwMqBJwEkQFGgoMMGAQIjBDAQ
+ wEYAAigUaGBB4KpABBIicCUAxIeGEQUI7MCKBUECCQQi9KCi4EaBHwQq0EWwIICJIAwWiBBS4EjgwS0Y
+ IECQOISOAlIeYxkAocGLFTISVxlSoIAAARgGYLHAuQERJwtACCCQYspmhqw7C2gAIfVF3AOCXwwIADs=
</value>
</data>
- <data name="icon_popupscrolldown" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_popupscrollup_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
@@ -1173,89 +1119,41 @@
- /yH/C05FVFNDQVBFMi4wAwEBAAAh+QQAAAAAACwAAAAAEAAQAAAIMQAfCBxIsKDBgwgTKlzIUOCPhxAj
- SvzxYKJFig4vQiyoESNHiwknLozY8GHDkygbBgQAOw==
+ /yH/C05FVFNDQVBFMi4wAwEBAAAh+QQAAAAAACwAAAAAEAAQAAAILwAfCBxIsKDBgwgTKkSAQOFAhgwd
+ QoSYcOLEgxYtFsyY8SHHjh8/OhxJsqRJkwEBADs=
</value>
</data>
- <data name="icon_forward_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="script--arrow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIQcALa4vIaKkNbe4tjZ29vc3uTn6ufq7ejr7uXo6+Hk58PK0M7V28zT2cHIzs3T2svR
- 2MbN08bM08rQ18jP1cLIz+bp7MTK0cfN1MXL0sPJ0M/R0+Ll6P///wAAAAAAAAAAACH/C05FVFNDQVBF
- Mi4wAwEBAAAh+QQBAAAcACwAAAAAEAAQAAAIdAA5CBxIsKDBgQAOKgQQQKFBAAgaOkRYQIBEgQAyatRY
- AIJFhAdCGjBQAUGBAhEsfOQAwMCCBQ4YPJAw4QIGBQ0+thTAsydPBRQsaiAQoKhRoxsyWBxAQOCAp1AH
- AEiwtKnDqQGYTmSZ1epEAFq3cggrVmFAADs=
-</value>
- </data>
- <data name="folder_horizontal" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABLUlEQVQ4T6XUvUoDQRSG4a/K
- JVh4EXsPVl6FVQrBykJEQZEkrIn/GBSMEIQIoogiFinEFIKgxoiCiGBABTG66MrihpC47B7nExt1txhT
- PMWZM285AxFBO1BOI1IlA0NJRDDYMo4rqSh+EIjbbErNcaRqWdJ1EohRrMv3/TiOTJjibkvgbP7AM+ts
- 4svvHWfu2eIwhYxvr4v3VPjDVxdrZVNu94dCscVBAlOetSqth3yoD7UL472uCVuUxjDbelyRxt2SFjZs
- sTeCbOM+J+5NVgsbtigOY7FeXRDnakYLG7bYHUTu/XpO7Iu0FjZssTWAvHM5KS+VpBY2bLHRj8Lb+bg8
- H49qYcMWy73YcdRgnya1sGGLvm7MT/eg9B9s1WtATOlQOjWxibX1lPkNfAJSiLGOr2CqXQAAAABJRU5E
- rkJggg==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACA0lEQVQ4T43TT0iTYRzA8d/o
+ DylIsEOUOyS85qGZhxXULsGG0kCrQ60uG3aIZ7iNZIZ/VuhFbSQIug5dUrpK4KGIIII0iQi3WtFCR6XD
+ 3jne+Ta3uSG67dfvCZ7q9ODhA+/h9+X9Pc/LCx39/cBdCgbh6tCQlbC9ujI4WP8n5i4ODFhfLi4+q1Sr
+ WK5UpPKl0satyck79NLjcCEQEFihXMZMoSCV29nB8OzsY0dPTyN/MZzv6hKYurWFy+m0FJ+hhtn8fmjt
+ 7gY409kpsGQ+j19UVYrPUMNEByedToGt0fpfUykpPkMNEx00tLcL7Cett0RHkOEz1DDRwRG7XWDrxSJ+
+ 0zQpPkMNEx3UWa0Cy5RKmNR1KT5DDRMdHLRYBPZrextTm5tSw3M6Kp7x6Yab98HkHgYwNDcLnjx94w26
+ JBn3jIqnxz4mzz744WoJfQaApibBV9zdxRyt+L+7T1fQObX817XpBD5UESmOnBqNuQBMJgBF4QJaLofp
+ bBY1OkaGnnXapiMcxfAaojeO6P70z+0lRCW4EAEwGnlsvuzzPXkVjeJ8LIbv4nH8kEhgfHUVPY/eo21k
+ Du2j89h67w22hRbw3FvEo97nkWP+Fy4wGI1ms8Mxoel6tko/khQinvDOFOquT32vtfd56AIOgaGmpmWf
+ ooT26oCt9/V+y40+iunscPg3qfGIS2EPRjUAAAAASUVORK5CYII=
</value>
</data>
- <data name="icon_zoomprev" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="magnifier" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIZ7AHBJJai7zuqxd9nFsxc5ZrjH11tgZOnv9CpGdRc2bGV7kpu20IiOlKm1w6u0vKqx
- wSJEcd7m7UdhgaTF59ri6hgzakFagqC50tfb3xU3Z5yzy1xbXXyQo6q8z7bBza6ytz9Sfc/O1IaKjYSA
- f2RgX+fs8a7C1Y6XqImXpLrT7WRrchIzaYWUo5qbneLr9Tg3N77L2PT3+auoqOzw9Kamp6jG5JSpvsrc
- 7s/a5MXa75SVl7e/x250esfS2L7H0UdKTZmirJKfsuXq75y20ISHi2BocNnm8+rv82xtb6a80auvs0Ze
- gBMzYmZ+odDh8n6QrjhWfM3U2ThUe+Tr8bS3uxY3ajAvLnV5fn98e3ahzJ6quEpMTDBQeZ+fn3CCohg4
- Z15cWlhYWWd7kxg5b8LQ3aSttoSFiMjQ2P///+fu9SJAcnyPooOGiBY1bM7X37Cura22v5iktBU1aIBq
- V3qSsCtGdWh8lnh3d6CnrxI0ZM7OzgAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQB
- AAB7ACwAAAAAEAAQAAAIvAD3CHwzggQWGXFQaBHIUGAXKj5geOCyog6IJQ33tDgTocQBBG2aENkj5gRD
- Gh+OoIlBh4mFGyx07FHA8E6UGRSmqMljI4eGDXueMAQjJASUKgTGJElR48WeBgyRYEjz4EuFBBAkDPmR
- kYESF0akyMlgZwIHHhl3mHHjpAcBL1kuFHGQcQ8eNkBMBFmwRoUBPXX3wBERxsqWK2UMABAwIHCBDgVw
- 7AkAYHHjwA0pW8acubIAzp3ngM5MZk9AADs=
-</value>
- </data>
- <data name="icon_invokescript" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- R0lGODlhEAAQAIU6AEtypf///9bn92+wPq3D3hExZKq+r3ugdmupO1WHSD14K7fH3Jiymb7M37HMxlmP
- RFeLTVyTSVuQRY/SS6DfUZjYTl6fN1iORJ6xxny6Qn+og4jHR5vbTzJpMpvbUIjGR3Gad4/RS4nISHvB
- RIrOSXCzP5/eUaDeUJ7dUJPVTYfKSIbLSIDGRnWPsoLHR2WkOT95LD11Pp3cUJPVTIPCRZ6+rIPDRWak
- OZfYTnGzQAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAA6ACwAAAAAEAAQ
- AAAIuAB1CNSBAYDBgwgxDNRhsEGAhxADNACwEMBEARgzYqQ4EEAAhCA5CvRIoKRJAgUWGjgQAwYEDQ4y
- ohzIQAKCATJEIIhQA+NMHQYkZBgQYAAFChkixPx5AMEJokVRmECgQcDPBB84QC3qYQMEqyl1KKiAY2vR
- CgoItAibgEaKrSFm2OhQoMACgQdeTICqgsSEGyAW3BVo4MEAoixcrBjwwMBCgQwuWMgxooSFCwweD1yZ
- QEGCA441BwQAOw==
-</value>
- </data>
- <data name="drive-upload" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACS0lEQVQ4T42OX2iScRSGD3QR
- C4QwiBH9WV3U0qLIiyyoNuyiG1FBRwwsRqtR4BZFuQXNbiRydNMgmEFrxC5WBJbZZvbH0pVuXwyJFBW1
- DWpaQYsIzVGn3yv7bGOw+n08cL5znvdwiObeirpdtKGlj3b2xEnbm6V9Nz5SQ/+n/QA1epjBgVt9qw60
- 0roj12nzxQjVXxr/u8D94ZAIShVELS+AAxcZZCs/MvKC3dcyCEi9ud98NfmLUaOHC+QFcmbRgh2udxCl
- nsQsd4Z/cEfgOzvGi4weZksu2OIYgyBdfvuTnbES2/yf2TKQ4uP3p7jlXpYxgzP/atpkf1ll4/kXfXXn
- gpJMx5NpNt6M8/wenPmZBQuESOvPPKW1pwNUe8o3ah0pFBtvZ4uo0cMMzoIFe45dIbC31UXbbYO0xjZC
- K4/eAbcO+r9F6u9+iYi6Hz3M4MCVc2QwGCqYTCayWCykazpJNU0DoH1rYNalfFB2oUYPMzhw5dyiBRAa
- zW20zOBuqH3MxuU+NqJGD7OlFijMZnOzoO0fNIsLFNUL9Ho9zWENhUKpWCzG0WiEg8FnPDz8iL1er+Ch
- wC94zkNDvpTwrXKONBoN6XQ60F4ul7lUKvHMzFfO56d5cvI9ZzIZQVYwxZKU4GQyz3CRQbby1Go1abXa
- s4VCgT0eDzudTnY4urmrq5PtdtAtcPIJ8UUiCYaLjPxqRLFapVJdEOfm0uk0JxJxnph4I+TXHA6HBaOC
- KAcCr9jtHszBRUaALCkF2xQKxWGlUun8H+Aig+wfdPytZLAK/bMAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACPklEQVQ4T2Pw8/NjwIYDAwMZ
+ QkJCBENDQx2AOAqIU6G0A0gcJA/Sh1UzSAKoQDEuITlpyuKN3UevPlt//9WX4zcfv926aM22PpA4SB5s
+ gI+PDwb29fUVjIqNT1l38OrCIzdeH3r05tvZJ2+/nQNhEHvHiZtLomMTUkDqGDw9PbFh54nz1/btvvTi
+ wNXHH0/ANMPoa08+nZi+ZMNEoF5nBmdnrDhh2+kHa0AG4MIHLz/ZBNSbwGBnZ4cN5++78nIfTDO6C0D8
+ E7ffHgXqzWewsLDAhlP3nH+4EWQANs0gsVM3nu8A6k1lMDQ0xIY9J89dMX3/1VeH77/8ehrdEGBAnpu3
+ bO1coF5PBicnJwYHBwewN2xtbRlsbGwYzM3NVVzc3KuPXLy37+azzygGPHv//eLlm/d3WNvYlqipqYlg
+ GGBtbS0PNKR47dr1/zU0tdsnTp+79PGLd0fefv557emr90fnLVi8UkNDs1ZQUFBLTk6OAcUAoEYtNzf3
+ mh079vwXFRVrZmFh0QLiMCCuBOJ2KA3ii/Hx8TGgGAB0vkVgYHDbkSNn/isqKvUAFakCMQMuzMXFxcDB
+ wcEA8793QkLKhIsX7/7X0zOYBtRkzMzMzMDIyMjAxMSEgRmQAcgZwEAruXXr1X97e+d5QM0uII2kAA5R
+ UVEXERGRFqDmbKBGfSDWAWINIFYBYnkglgZiMSAWBGIeIAa6nYEViJlAFrFAJaWAtCQQS0D5IkBaCIgF
+ gJgPiLmBmBOI2aB6mIE0IwDSnmBluZcHuwAAAABJRU5ErkJggg==
</value>
</data>
- <data name="icon_zoomprev_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- R0lGODlhEAAQAIZpAK2km+XXyfX29+Xn6ZWdqJScqNPa4JqirsHCwq6vsLm+xNfY2dfZ29vg5cTGx6Oq
- tMbJzZObpq2trJWcqqSkpcPJ0J2ksODj5ZKapszNzc/Pz87Q0vL197u8vezt7rW2tru7u7GztaiuuLe5
- upWcqZScqefp6u/y9ZWdqb69veLp78LHy9ni6tfd4snLz5aWltbW1tbX2NLS0pafrMC/v9fZ3c7T2MzQ
- 1K2trfr7+8PExcLHzMXQ2vX2+MTJ0Ofn6N3g45WdqqSkpOHk5+fs8aurq+jt8fT19tTT0+jq7JOcqbm/
- yLe9wrq1sOvv86CosqertsfKzb3Byc7R1fP09Z6ksLi9w6qwuP///5ubm9Xb4bCvr8nKytHU19rb3Pb3
- +KOrtPDy9Nri6amvt8LDxPP19rO1ttPZ3+7w8gAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
- AABpACwAAAAAEAAQAAAIqgDTCIRBY0sKJFOidBHIUKAGLxeGAHmipAqUMQ3TZBgQ5ogAC0GWkEljxQVD
- GQsEYMlRIYIIIxC4pGHCEISJL2jKHMBgg8gZHGl8MJRA5QeYEgRmtFAhJkvGDx561EBBYsKBKwYoZHQQ
- g8OJBwUKKGCxY0TGNAiSOBlAQAoPLSEYnEW7ocENAyvMJJgrUEeRF0I6pEkAIADfswAKH86Y2PBiho0f
- Q24iOWNAADs=
-</value>
- </data>
<data name="icon_forward" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
R0lGODlhEAAQAIUmAHGFoxQ1Z5TY9bS/z7nD0r7Y8sPd97nT7bjS7IG16sHb9cPe+IO57nCk2YK27HWp
@@ -1267,17 +1165,19 @@
sgoDAgA7
</value>
</data>
- <data name="layer-shape-curve" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="arrow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABlklEQVQ4T6WS2y/CYRjHH4uN
- ZbRSU8sqM1FSsdEF5sKFzYXIoTJuwozKMcw9rurSDS64YWbOZ/+C/ynf5+33tn5lDvPbPr/v8x6e7/u8
- B+rceu8CcUUJmscZTZPW6qHiTx9Mk2HykLLZLFHH5lsCwQcr4Hae9rUnalt5IPfyvcAxtk/G7gipDPyp
- 1wBIKkpQgUwuNGATV/KOmhYuyTx9kquAJ/s2XsJABzhWJX9l0Jq4JUYYeNefmUHg4lU9q4+iXE6UyC3I
- ClQGnARsYALJWjn51wa8IoOEPjAKAyvQIO4BKdZvKygY1CD2gTCIgW2+HValzf0+HKJGtYVCd7lHPmlM
- 6gU7rGiXQxvAOOhvid8QIw7RFIiK+5VGnKwYiEm8WkG72rl0PQUczYtXOQP58YtjM34oDCdKA3toT8Sc
- BLwgWGJQ8l6LOqosbvGAgAHMNc5fqCv4yYDHa/0hssXOBuyz57uscgtlGNOAClAJtKAG6IAe1AETqAdm
- y8xphm9HUbHunwwMI5nhuvDRgTFyPCQq4N9/+ATdd0wu3kGkzgAAAABJRU5ErkJggg==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB6UlEQVQ4T2P4//8/AyUYrFmv
+ /RKDfsdlOLaf+4IBhh3mvZwJxDE2s54yWEx9wGDcdxOsXqP+FFgvVgOMe28wgDRA8RkgDcIxRBsAco1R
+ z3WwjUB8ZsaT//9BtMWU+zFEuQDmHcOuqyAnn+m8+uf/lAf//oPYQNfFYHhBt+3iTKDgGVy48eyP/0X7
+ vvzvvfnnP0gNUH0MShgAOUBbfv2vPfntf82Jb/+rj38F46pjX/9XHv36v2DPp/8ZW96DcfP5H/9B6tXr
+ TsbAA1Gp/NAZkIa0Te/gOGHdq//BSx7+95x947/LtMv/HSdfAGMQO2PHi/8gPXADZPJ2nmk8+/1/2aEv
+ /wsPfP4fvePdf88NL/67rnv+33nts/+mSx//15z3EIx9t77+D1Ivm78L4QLx9E0zxdI2nsGFVbd+/8+3
+ +ut/o13f/4PUANXHAA1BpAOgIINIynoMLJy8jkEgftUZoZ3//8vt+f8fxBZMWB0DUo9iALdxJAOXUQQG
+ 5o5YzADEZyR2/f8Ponkil8TwuNczsErqMIAAPAzAPCyASVSDgS1o7hkQZrUri2EW00RRhWwAE1CGD4hl
+ gFgLiI1hmMmqeBmTUXIJlK8NpGWBmB+ImZENYAQKsEMNEQXSUjiwGFQzB5BmghtASXYGADrJ+mn64PZ5
+ AAAAAElFTkSuQmCC
</value>
</data>
<data name="cross" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -1293,80 +1193,89 @@
yd/5G8s+qAWdGU8YAAAAAElFTkSuQmCC
</value>
</data>
- <data name="icon_zoomselect" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="layer-shape-curve" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIZvAISChAEBAXBJJai7zsfb8Nrn9M/a5Nnm81tgZNDh8sXa77jH16jR4+fu9dDh8brT
- 7erv89jm8uzw9ODq9Ku0vNHh8mRrcvT3+aStttri6oOGiJqbncrc7oaKjZ+fn9Di6JSVl67C1a6yt5u2
- 0F5cWsjd5IiOlM3U2Tg3N398ezAvLujjjKCnr5u83uXq73V5fnh3d+nv9OLaid/s76/N6pyzy9fn65mi
- rLCurXahzJDO1tfb3+Do8dDg8UdKTb7L2EpMTFhYWZy20K22v6jG5KWqsaq8z+7sj7C/z6amp6C50uLr
- 9evw9aTF52RgX250esjQ2ISAf2xtb7S3u+Tr8WBocMPT43yQo7vU7cbb7+Hr9JGRkt7m7YSFiL7H0cza
- 6IWUo7bBzeqxd6uvs6uoqOLs9c7X31xbXbe/x+fs8evv84SHi8vY5XyPoq7L5wAAAAAAAAAAAAAAAAAA
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABlklEQVQ4T6WS2y/CYRjHH4uN
+ ZbRSU8sqM1FSsdEF5sKFzYXIoTJuwozKMcw9rurSDS64YWbOZ/+C/ynf5+33tn5lDvPbPr/v8x6e7/u8
+ B+rceu8CcUUJmscZTZPW6qHiTx9Mk2HykLLZLFHH5lsCwQcr4Hae9rUnalt5IPfyvcAxtk/G7gipDPyp
+ 1wBIKkpQgUwuNGATV/KOmhYuyTx9kquAJ/s2XsJABzhWJX9l0Jq4JUYYeNefmUHg4lU9q4+iXE6UyC3I
+ ClQGnARsYALJWjn51wa8IoOEPjAKAyvQIO4BKdZvKygY1CD2gTCIgW2+HValzf0+HKJGtYVCd7lHPmlM
+ 6gU7rGiXQxvAOOhvid8QIw7RFIiK+5VGnKwYiEm8WkG72rl0PQUczYtXOQP58YtjM34oDCdKA3toT8Sc
+ BLwgWGJQ8l6LOqosbvGAgAHMNc5fqCv4yYDHa/0hssXOBuyz57uscgtlGNOAClAJtKAG6IAe1AETqAdm
+ y8xphm9HUbHunwwMI5nhuvDRgTFyPCQq4N9/+ATdd0wu3kGkzgAAAABJRU5ErkJggg==
+</value>
+ </data>
+ <data name="icon_printablepage_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ R0lGODlhEAAQAIZsAO7y9pKaptzi6LC5xtra4P39/f///6qrsqmqsdbX26+xuN/j6O/v8qurs9HT3ff4
+ +f7+/qmrsr6/xvj4+bi4vaqrs8TFzqyrs7q9wb/CyL2+w+zs7bW2vO3v8dLT3rW2vcHEzLu7wOrs7cPG
+ zfP09crM0/X298/R2sTGyre2vP39/qystNva3sbGycbHy7q9wuLk6fr6+8bJ0eHj6LGxt6mrsejp7Pv7
+ +8/Q0bu9w7i4vry8wtrc4N3g5s/Q0vT198PDy729wtvc4e3t77CxuNzd4vz8/M/R27q9xb6+xvb3+L7A
+ w7S0vuDg5ayut/Lz9NXV1ubn7N7g5czMz+Tl59vc38DBxMXGydTW3M7R27Cvt7i5v/z8+87O0fn5+vLz
+ 9fr7+6yttLi5wMHCx8PEzaiqsdXV2Ozs8aqqscTFyNfX29LT1////wAAAAAAAAAAAAAAAAAAAAAAAAAA
- AABvACwAAAAAEAAQAAAIwgABvBFIcOCbgwgTJsQRxUkKMgkFBpj4xsMULz/CFNmiMMCRNxugcEkTg8cX
- JGsOSlyRRAQENRcaTIjAAQwIhAFkwDghIQMVLQd6KKhxxuBEEi6YsLFSoIKCB0RQKJSyo0GZAgmyMKAh
- xIfBNwFMjFlywAEBBjqaXHmCcwaaLmYSEMDSIoeSKhSM2njDQsONEG5GtLGAIGGADyXeDOkQRAWQFxgQ
- CBAjECxFAwuMLDDwZoAAAQpDI/RcsHToAaJTvwkIADs=
+ AABsACwAAAAAEAAQAAAI1gDZCBQ4oKDBggMTshlgoGHDAQACKPSxREcQABgBQBQgkQ0OK1OGFDBzJeNG
+ jim6bDBQ4EaBHSYDyAwAhQOEAmC8KKHSIqOAnxI1oIgxwcQXAiEyYuQo8MMEAlAJMBHzwmfHMVATaFVQ
+ BMaWpRIjjACSAIkCBSWSFKhCAwDHBj24SMigAAuDMz86sNDiNsAKB1JUSHjygAeGAzkQpAGK4IiDKCRA
+ 1EDgYYYIIjMDlMlygoEMJ00gGCnw4AKFBajZNDgQoQKCMEJsuDhgQY1ChWgOkFmjMCAAOw==
</value>
</data>
- <data name="arrow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="cross-circle-frame" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB6UlEQVQ4T2P4//8/AyUYrFmv
- /RKDfsdlOLaf+4IBhh3mvZwJxDE2s54yWEx9wGDcdxOsXqP+FFgvVgOMe28wgDRA8RkgDcIxRBsAco1R
- z3WwjUB8ZsaT//9BtMWU+zFEuQDmHcOuqyAnn+m8+uf/lAf//oPYQNfFYHhBt+3iTKDgGVy48eyP/0X7
- vvzvvfnnP0gNUH0MShgAOUBbfv2vPfntf82Jb/+rj38F46pjX/9XHv36v2DPp/8ZW96DcfP5H/9B6tXr
- TsbAA1Gp/NAZkIa0Te/gOGHdq//BSx7+95x947/LtMv/HSdfAGMQO2PHi/8gPXADZPJ2nmk8+/1/2aEv
- /wsPfP4fvePdf88NL/67rnv+33nts/+mSx//15z3EIx9t77+D1Ivm78L4QLx9E0zxdI2nsGFVbd+/8+3
- +ut/o13f/4PUANXHAA1BpAOgIINIynoMLJy8jkEgftUZoZ3//8vt+f8fxBZMWB0DUo9iALdxJAOXUQQG
- 5o5YzADEZyR2/f8Ponkil8TwuNczsErqMIAAPAzAPCyASVSDgS1o7hkQZrUri2EW00RRhWwAE1CGD4hl
- gFgLiI1hmMmqeBmTUXIJlK8NpGWBmB+ImZENYAQKsEMNEQXSUjiwGFQzB5BmghtASXYGADrJ+mn64PZ5
- AAAAAElFTkSuQmCC
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACw0lEQVQ4T22SXUhTYRjHXxI5
+ LG+UmWNSiAoLvFBJRZhswZHZUNyHU7tRU7ILZXThbpwM+7gQL6OMWiLTE4gfS01DJDJnq6a1dtxaR3Nz
+ ExVZBl504+XT+7wcQaMHfjsPz/P/vTsvHGI2m4nFYiENDQ3EZrORxsbGS01NTXoK1m0Z7PW4wwxm0UGX
+ /cgHcHSpczgcvWtra5GjoyM4PDxkYB8IBCI9PT29mKEHcP8ewFmt1nqPxzOGwveJCfjscMAyzzOwj9DZ
+ wcE+jIyMjGGWHsCxNzCZTMh1uhCSySSsdnSAaDTCL/r8093NSLW3Q6imhu3i8Ri43W4BHXRJXV2dym63
+ u3Z3k/CurRV+2myAlWhuPgfOfphMLLO1tQVdXV0udInRaORXVt5HPw6/gC/V1Uw+rW8GAyBny6/Tgd/9
+ HBYW5qPoEoPB0IKvtdjZCZLZDNOFhSx/cnICqVQKEokExGIx2NnZgeGsLFgsLmbZYPAroEt4nreLogiv
+ KiogUlsLSzQwqlRCKBSCcDgMkiTRe8fBQ2WBMpOXx7J+vx/QJXq9/m4wGITJsjJYr6qCmexs8NLgWXlv
+ b4/NkNdqNcv6fD5Al2i12g5R3ICZtluwWlQES/+RT78F3L1RqVjW5/sA6JLKysobU1PezbePn8JcQcG5
+ f56jAoIf0vHxMWM6NxeWHg2BxyNsokvKy8vVVqttIBSKwqTJAkJODrvzIhU3ZLBHWaDXw8z6+gZYLNYB
+ dElpaSkpKSkx9vc/9IbDMXhZWw9DmZnwiUpRGexxhjtR3AaX64EXHXSJSqUi+fn5Co1G0+J03p+VpANY
+ fjYKws1WGFTnMrDHmSTtg9N5bxaz6KCLdYFykeO4y0qlslWr1T0ZH5+Pb2//hrPgDHeYodkr6MguSaON
+ kqKhXEtPT+cVCsWdjIyMPsqgTB/OcIcZylXZSfsLjyUbBUyIGBQAAAAASUVORK5CYII=
</value>
</data>
- <data name="document--minus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_restorecenter_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB20lEQVQ4T42SO0hbYRTHz2jo
- 5qBZOgiJgwgl6dAgqCAIBlQqRnBQQTDGoEFuCAbfIkK3Lg5GXLUdOrVD3IVujjo4lYpRkeAj7/fxfy45
- i4+rH/zg3sv3/3HOuYd8a2skjKyvD4DpN3AMr67S0NISfV1cpMHxTiL5UCeQrVT4rljkm1yOE5kMn6fT
- /D+VMvl9dMS4FwBOFYjEtNWZSZdKnETw6uGB/yWTfHZ9zaeXl3ySSPBBPM5ycHcGOCVsCgajUSWYgeA2
- m31Rsr2/z4rT610BJFB/JKLM5splvkf5r0mkEmkHmVnNUZ9hKHN5zCCVz1tKRIDMnOaoNxRSQgUIMoWC
- pUQGi0xIc9QTDCrzpWqVc5iDlUT+DjLzmqMuv18xyhAUMAcryQ1aRMbQHHVMTirhSq3GRbRhJZE9QSYs
- OcPlIvoyNqZEqhBIFVaSFFpEJvLdbqefhPN5dFRZqGFRKhA8lfydmuK4y2Vy6Hbzns12gfDxD6JdcnR3
- 0yefT4jKptVQxVPJL4TyExPPiEEiRdBHj4davd5lc1dfkPzx+3kHEiEGFhoaEhsIb0kFODbQ1OzxbKrA
- lACZiQxWWpJfLHtSxLvclUw9S414aLe1tIQ/tLV9ew9yVzKg8REGvINQesvmrAAAAABJRU5ErkJggg==
+ R0lGODlhEAAQAIUtAKq7y5+svcbS2MPQ1tTc4MvW29DZ3sTR17nH0tDZ3crV2tLa38fT2dHa3snU2tPb
+ 387X3MzW29Xd4MjU2dbd4dXc4MXS18nV2sfT2LjH0sXS2NLa3rzJ1LbF0cjT2dfd4c/Y3c3X3NTb4LbF
+ 0LvJ1LXF0M7Y3c/Z3dLb38bT2MzX3LrH07vJ0wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAAtACwAAAAAEAAQ
+ AAAIxAABCBxIsGALAAQkUJBA4EGDBBAKXGAgAMBBCQE4fAhAYEGCABFWBKh4kAKHACQ4LjAQAEFLkgAq
+ fGARgCMKli09wKxQs6bDEz1HWgTwgAABEQ82GDARooADBhqGNliwYEMDAyAiKpiQwsLQBAkMGEgAIkQE
+ BQ4wCDgwFEJQFQUUBGV7sEAElwHiOqjZ4cCAoRdcZgjgYAKDAB0CjPh70EOADBMCMFAb4ECJAIwBCNi8
+ WYOFA34HiB5asPTAFqhTq16NOiAAOw==
</value>
</data>
- <data name="drive-download" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="water" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\water.png;System.Drawing.Bitmap, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
+ <data name="block" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACTklEQVQ4T42OXWhSYRjHH4KK
- iBNkX9AHWx9QeaQuDpTsZgu7CsRJGjIcqyAFiY0xhm7RFqxTdLPoqtjCm+jCPsCwUhtL86O0nRo2zZy5
- tXWR3qztYuUkfHqfsSOOsdWRHzz+n9//4YV6ZwFWQXB+xwYxUW5ge2E1D47d/FTh+K0xqLs7LWO79/XP
- 9Y7AvMgym5yTU92B2s5AhQOOEBy9NgJCf4Z4fCe1kLJ6ZlJsfkQZ7cip7qw4cKg7CoevxoDv+yj1vZ/D
- M4NfkGbKaLfmgf32N7eZ4FtCsoVmUHV/Atl/Sc7JWfaCvW2vQGZPq9988Eoo1Z4o4SVpAQXfPG5zzWH9
- 8C80RH9jjSOYJKe6UylTuPuyFxQXn5p3tfuT2pEybveWcd2zMqqCZdzR5kvSjpxlB060iECcPH8Djlic
- sPXCE9hsemDeYnUn66KItcOInMWdpIx25JAr90Cn0y2i1+vBaDTCaZMN9p3rh/WNg+aNLa6xDQyaKaMd
- OeTKvRUHSCBOnbUA39hZQ9As52sd4AwGQxPD+g+a2Au4ygu0Wi0s0RwOh8cTiQTG4zEMBl+j1/sSPR4P
- 4znDzwigy/VinPnNcg8EQQCNRkO0lkolLBaLODv7E/P5Hzg19Q1zuRxjgjGNkpTGTCaP5FKHuosfz/Og
- Vqs7CoUCut1uFEURe3t7sKvLgXY70cMQ0cJ+sVgayaWO/G1iw06lUtnNnjuZzWYxnf6Mo6MfmPwOI5EI
- I8qI49DQWxwYeDhJLnUY1AUFQ8VxnEmhUIj/A7nUoe5fouy03kA6Jw4AAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB80lEQVQ4T4WSUUhTURjH//fV
+ hwgiRBnSi8xxG0qlBZZtajK0xir30MCQYI/51AQzFEXSUQ8JiiAqiGLMh0HhQ4U1aNBDHoiIZbYpRKWE
+ DaHe/Tzf8d7rdu/ACz8+/ud83++ce7nQWrqhjb0/Ip4OavH0VgmCRX1yjogAbSRlZ7Xh5c7/zrV9MuEs
+ +1btvUrQ7euCNvC6kJz/1S6dX9604Cx7cra+wxukADyr8kLrfWGSvbKyQ3XPv1twlvvZgh7o45EjgZK4
+ dGg9CWbjUvIHnV34asGZ1419+GZ0hJdRLFCSSg+06Pz6uUSO3HOfLTjzugS+aY8atgTvgIBEmETqQts8
+ 4F1ct1CCyFTGN+W2hi3BGyC53XE9vx/rJWbhXh+FQ/2Kmmt39iq6DtEfXP3dmYAoIKA+4oo8/V99G/3B
+ GQfDtyDGRCsl8tEi4l/8+dAikkqQlIK/3ib6CZeDR0GIxx+baXLjJnE14dw+A6EES1Lwq7qBsqhwEGuH
+ GP7QROOZG8TVhHPrhCGYk4Itl5cyOO3gfhvEYLqRnn4KEFcTzpefGIJJKchV1dK3U9UOon6I/tRFdXWu
+ JpwvDBmCu8DsQykpxe1GiL639TS61lL0Cpz1mCGQ/0+ZpFxSacN9ohlLJ8MQpZB7s+ojHvPYpWbmA8tY
+ cADrXMqIVYe9mAAAAABJRU5ErkJggg==
</value>
</data>
- <data name="document--pencil" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_forward_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACMklEQVQ4T4WSTWgTURDHZ4/V
- Ww4KhRwCjWgIegjFrVLbSq1djaKYQg/10ENMQxs0JRhSbRu8iBc9eBLUXuJFlFCsi7YiGL/wXrURTGgw
- aZRQbb423+PMtg+CtPHBD5bH/H/Mmx1wzMwAMzQ7e4a49B86LkxPw/mpKTgXCMD+7m4AvtjCVajV8He5
- jL+KRUzm85jI5XA1m9WZj0SQ6lyEWQhYotu2GMtVKpih4NrGBsYzGYym0/g5lcLlZBIfqSryodoxwsxh
- XXDW7xe48yRYLxS2ldwNhVBgVpTrBDBg9/kE48VqFf9Q+ztJuBN+DmXGRQ4GvV7BhEYzyGpaSwkLKDPB
- uVtdXQAnPB6Bp0SCfKnUUsKDpYxn0WiET5IEcNztFlyu1OtYpDm0kvDfuWK334lJUviDJPXCMadT4K2S
- oERzaCVZjsXQ2d+vYjCI85L0Bo6Mjgoma40GlukZO0ni8Zf4OBxGjeY00N5+ew5gAA6PjAh8dRJwF9tJ
- EqtLGHk2iFoqgAc6O18YDIaD94GObXhYcLVBi1Ijwb+SZOIVvl1Q9PCTh314+uLReyabDVxWK0BHTw8c
- cjgYP29ag7polqR/vMZ3C6c2ww968Vt0EbmWM5zVj1GWYZ+iXNN3tUmy/vMrvn++GX5K4ZUvKvKycS1n
- xGmjjz17ZfmGEOgS4qMaRMxHMTzXh9+jS8h7UqYOuZYzBGfBQFjbTKbJ3RbLzWboHodO7lqxyMZQ8z3X
- coazfwEpq4JeDHDvFwAAAABJRU5ErkJggg==
+ R0lGODlhEAAQAIQcALa4vIaKkNbe4tjZ29vc3uTn6ufq7ejr7uXo6+Hk58PK0M7V28zT2cHIzs3T2svR
+ 2MbN08bM08rQ18jP1cLIz+bp7MTK0cfN1MXL0sPJ0M/R0+Ll6P///wAAAAAAAAAAACH/C05FVFNDQVBF
+ Mi4wAwEBAAAh+QQBAAAcACwAAAAAEAAQAAAIdAA5CBxIsKDBgQAOKgQQQKFBAAgaOkRYQIBEgQAyatRY
+ AIJFhAdCGjBQAUGBAhEsfOQAwMCCBQ4YPJAw4QIGBQ0+thTAsydPBRQsaiAQoKhRoxsyWBxAQOCAp1AH
+ AEiwtKnDqQGYTmSZ1epEAFq3cggrVmFAADs=
</value>
</data>
<data name="applications_stack" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -1382,23 +1291,50 @@
S3EAAAAASUVORK5CYII=
</value>
</data>
- <data name="table--arrow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_ctxarrow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
+ R0lGODlhBAAIAIcAAAAAAIAAAACAAICAAAAAgIAAgACAgICAgMDAwP8AAAD/AP//AAAA//8A/wD/////
+ /wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAMwAAZgAAmQAAzAAA/wAzAAAzMwAzZgAzmQAzzAAz/wBmAABmMwBmZgBm
+ mQBmzABm/wCZAACZMwCZZgCZmQCZzACZ/wDMAADMMwDMZgDMmQDMzADM/wD/AAD/MwD/ZgD/mQD/zAD/
+ /zMAADMAMzMAZjMAmTMAzDMA/zMzADMzMzMzZjMzmTMzzDMz/zNmADNmMzNmZjNmmTNmzDNm/zOZADOZ
+ MzOZZjOZmTOZzDOZ/zPMADPMMzPMZjPMmTPMzDPM/zP/ADP/MzP/ZjP/mTP/zDP//2YAAGYAM2YAZmYA
+ mWYAzGYA/2YzAGYzM2YzZmYzmWYzzGYz/2ZmAGZmM2ZmZmZmmWZmzGZm/2aZAGaZM2aZZmaZmWaZzGaZ
+ /2bMAGbMM2bMZmbMmWbMzGbM/2b/AGb/M2b/Zmb/mWb/zGb//5kAAJkAM5kAZpkAmZkAzJkA/5kzAJkz
+ M5kzZpkzmZkzzJkz/5lmAJlmM5lmZplmmZlmzJlm/5mZAJmZM5mZZpmZmZmZzJmZ/5nMAJnMM5nMZpnM
+ mZnMzJnM/5n/AJn/M5n/Zpn/mZn/zJn//8wAAMwAM8wAZswAmcwAzMwA/8wzAMwzM8wzZswzmcwzzMwz
+ /8xmAMxmM8xmZsxmmcxmzMxm/8yZAMyZM8yZZsyZmcyZzMyZ/8zMAMzMM8zMZszMmczMzMzM/8z/AMz/
+ M8z/Zsz/mcz/zMz///8AAP8AM/8AZv8Amf8AzP8A//8zAP8zM/8zZv8zmf8zzP8z//9mAP9mM/9mZv9m
+ mf9mzP9m//+ZAP+ZM/+ZZv+Zmf+ZzP+Z///MAP/MM//MZv/Mmf/MzP/M////AP//M///Zv//mf//zP//
+ /yH/C05FVFNDQVBFMi4wAwEBAAAh+QQAAAAAACwAAAAABAAIAAAIFAABPBgIQOCDggIRKlR40KDBBwEB
+ ADs=
+</value>
+ </data>
+ <data name="icon_selectpolygon_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ R0lGODlhEAAQAIMLAM3Jzs6lqZ+svcTM083Cx828wdbcyMvSxsTEy8LKxM3DxwAAAAAAAAAAAAAAAAAA
+ ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAALACwAAAAAEAAQAAAIbwAXCFxQIIDBgwcHCixIAIDDhwAC
+ KGQIEaLEhQEaVnRI4CLFjQA6FhCYcaMABBFHkgQp4CQAhQFYHhAwACZLAzNrrjRpACfNnQ8bCujps2bM
+ oBKHJmjZcgFCgwoWCFg6oKpOhQNbXsWK9SfXr2ADAgA7
+</value>
+ </data>
+ <data name="layer--plus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACLUlEQVQ4T52ST0iTYRzHn0vB
- qK4h3YQu4aEOFmMYmQ461ASTdRDyojRzltFbzFZrik2DIKJDdik6dAg6BHXokIo61prOVzfX2GROUZes
- xXRs7/64d/v2/F7aG4MdxAe+vL/fC58vH573ZUa73cBz44AxsA6bzYQDHmJZu9XaW+YFei/QOl9Gy1wJ
- Fz0yLrj3cN6VR5MzC92sBO10GuemUjg7uYvGiR0QQyxrs1j65HJZKXiahFLgSMh48ruoFNhjWdg2M0qB
- dT2FweiOUkAMseyyIJgLpZJq0CNKcPgTGFmKY1jcxpA3hsfzW3jk2YDVvY4H39cw6IqCGGLZpYGBWzlZ
- Vg1G/X+wx3eKKxhU52mfT50nFhZADLFMbzbfzhSLqgEVeFZW4A6FsBSNwhkIYHZ5GV7+bmpxEZOiCCpQ
- GM6yZpPpTqpQqDKQ+E4hg8pMBpWZCoghljV1d99N5vM1DcTVVdVgLhyuMiCGWKbt6hISuVyVQYrvFDKo
- zGRA8+hMEs+/BUEMsayxs/N+PJutaeCNRFSDH/xO6A6uvoso+Rjgn5Oz7IzRaPklSVUGSb5TyODh5zUY
- 34Rx5ZVfeVLGY0AHf57uf/GBnTIYrFuZTE0DKmh95sbLTaDvJ3Dd9z9CCDh572uM1el0w3F+oxvpdM30
- v/eh2TFTFa2L/7FjTtS1C5+Ypr7+5pGGhrH95ti119uUoy09X4hl/Gh4jvOc2E8Ot42/PaQf6f3HaP4C
- dRjFo//0njYAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACHUlEQVQ4T6XSXUhTcRjH8Qel
+ QrwJDZWlUhBR2ZzpbV7UZQRGIERhrRdXahhS1lVedRFEKdVyg1XUaiCczVmbL80CG2svzgtHuMxUTp7T
+ 2nbmNs2yq9P/d1xkXtigwYf/nvF8z84ZI1mW6X9QzTUXlDN1zPEsYRcNUfXVV3DEP5UYiKV/BqPp5cB6
+ sINdNGhpX/sQNERTy6N8fMmVDeyiQUtVVwbhZCT5wzsb/TaUDeyiQUuaywOgFRPfPZ8ii/3ZwC4atKRu
+ c8JpduvusLDgWG2cT9k8H6SnrtDXB46xL129AeEW+KYSFjRoqeLSSzg7E10aCfHpPhibSXIsMlr9wh3O
+ N3db4f3DHY4/Q4OW9rS+gMaPkcU3LLS9nYibewPiXc4rdHE+RadyYl75rNMdlixo0NKui3Y4PyEsDA+H
+ ok/Yt963+v5yj82K/Y6G90VWTezQ6zM8GrS0s9kGTcHpeafNLxiY7gy8Xz13F/doYufm2+UyriaJpvCG
+ lmjHBQ5aPJOS3R4QTb+xxzAB5lruRLjYXBmH+rhOLrNUJ3MN23gyFRhpe2MPtLJf1tkXFB8rRjNnZi55
+ qJYORI7Ka5F+c5A2leymrafMuucj04PsL9r/blJyrHWY04rlhqoU7P1cK6v0lencm6U8Necbib0K8tV1
+ Bwvr9W1bjpmuryeno1RUzVbIOR2qOTRocYE8pohR/VPTxkek2zBOOFeavF/hwGWQJJEHwAAAAABJRU5E
+ rkJggg==
</value>
</data>
- <data name="icon_copy_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_copy" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
R0lGODlhEAAQAIeMAEF1pURzq0Rzqezx9URzp0JyokJxp0F1p0J0p0B0pkN1pkZwoEZ2pERvokd2runz
9eDo6sHZ3ebw8ev19ufy+D5xqPv69vr4+0Z3otDi5J/Byvv7+d3p6fD28j93qENwqfj8/fn9/EFzqObu
@@ -1413,32 +1349,216 @@
- ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAACMACwAAAAAEAAQAAAInwAZCRxIsCAjQ4ISKhSEUFBBQRsu
- uLDg4sWLK1cSEjTkIqKFDlKuQIAgiORAQRYaKkTI0iEjQRc4UqRoUaTGgyk3eHwR0qZJQS5gRgQZciRD
- hS4MobjxAqRIJxASSU0Y1MIFoiOdSJ0q6IWhDRY7ABG51Y2bli6kSLGSVetWl117QnCiFUYiMong8nwq
- FQYMN3byCjya0A9hwzcNKmYUEAA7
+ ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAACMACwAAAAAEAAQAAAI3AAZCRxIsCAjBwASAGiAAQGLAyQY
+ FBQQYoOMDg8gcMgQoYINgjNuWHgxYYSKFiZKLKBxYmANFAgVMnQIkUEBgQouULSIUSNHjwJFgAg5suTJ
+ lCtbenDxkseALExi1GmChtChMQUIDMiZpweQQkJw/EjyxJASPAYoCJVyxUmiOVr2YKlihg6iFBKWWsmR
+ BgoZMFv8BNEgCNCKD1rlwIGxRseSN3G8fOESQGDaGDDcDApzh0qfIhoCKRKI184QPmLK/PERhY2aRWcE
+ HibSZsqOLgH0HBEQAIkRg8AHBgQAOw==
</value>
</data>
- <data name="globe--pencil" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAADRElEQVQ4T4WPe0iTURjGz7ag
- IqIIKrALFV1MC8UoZ3bRNLcuaEV0I82otIwaUSldNdOG84bV1Llp5dTKS3nJ0HWjLMvMSbWhW7ZVeMm+
- wjkr15A9nfMl0X8d+PF+57zP72EjwmPPiTCumYjOvyMi+cdRIkVXsCi1W0Epp9wbngr+ne4XHMoj+Z6e
- fhaB4HajQBBA/hYkmmbQEpWv5lOr/OlXrsRod1Sb7K6W/iFHccdPbnVJdyvbL4xRBsjE4tNISECVQPD4
- T0Fs04xx8a2VsppP3WVtfXhlH0KxsR9qfR8avzjQ5gTafgE5j6o4r72KN4ODgwhxc8u4QkgIEUbXjhbG
- 6Apkle97Uhp6oOtx0AIXig19qDDZ0dDrwEvbEBo/PsHdmvUY7D6BSSt26sdPc1+iIfQIdpZIPE7WGXfd
- NGN/tRXXTN+R+LATZx504nr7AB59A7JqbqK8TMrL6txA+MmSLMwT7NDSgo05FyPy9X3SgjasvtqOMG07
- tpZ2ILzCggOVVsRpC3EpexkvZ2QuR3ReIXbQPPMo9CdIUuqO1H52BioN8MpsgTjXAH+1ASs0Rqy/WI3c
- /GBeVmSsRGiyEt6pzVibq3cyj0ILAs81iePvu4IKujAnuQnuaS2Yn6aHR7oe4aeigO8mxJ/3RaSmBtOO
- 1cMnnZanvXAxj0ILAhLq/RXNzpmJLzBb/gpzFHrMG4ZusSkyGBL5LYQU/8B0WT3WVQAbtb1O5lFoJCj5
- smdcnW1uyhu4p77FggwDvDMN8Mky8ninv4ZvVge8kl7DX/UZknIgSPnexjwKLZCmr5kQrjUvoiEfylKl
- BatUVkg0VkjzPyBEbUVgTgcWX2jFlrvgmXrglpl5RJJKC0KzR5MNqiL3sy+5VaoehF7txfaSL4gs5bCn
- jOMnu0uzzDjcCATnmTmW573QbFqwtZCQbUWzRoSX6nzkBi7ihg0HK+04emcAsbUD/GT37ZpObL5u4UZG
- lulYnvcY/JnsQf9K0iyyu6poauwzU5i6yxZT0e88fueni012n3K0wcT2fI7l/zki+j2RMp+MnSwmflH7
- SERpAYmqu0eidU38ZHf2zvaEMJvlmccfIWXM8KMbnf+DySzPPPIbH8MN9etvR7oAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACAElEQVQ4T6XTT0iTYRzA8efk
+ Jbp0EOpQFy9drIMXVyhaEbWsjBUxTCmQOf8wojcYMWcmZKM/tsoKCXSXVtiqJdlaRmVeKjH7Y5pKUNvK
+ zD+DuS3X5rfnWaeObi98eZ8Xns/z4zm8AhDZlBVWg8X+pqYymSnDysQ+m61GnpTRo6zYY7WaU0tL6M7B
+ 5vNQchG2XYbiNii6ALuugbETKl1w8iF0D4F7EJRRVug1rS6RSmG+BZY7YJebLj2HEw+g5dG/tVPW3Aue
+ YZj8Be9DoIyyYrvF0hBPJmnpGeD2YAj/KDz+JJPv4SD45PqehD0f4MUEjPyAr3OgjLJiS22tJZJIUNx8
+ mB2OOpz+Pt7JCWrjhJw2Pk36OzAPX2YgGIa5KCijrCiqrj46v7jI6kObWF+vR2er4JTHRWf/M3wfJxn6
+ NsvoVJSAhGkck9P/gDLKisKqqmMz8Tirdh8gt9zIWuMRNtZrFGqNbLWfYa/jChXtXZhdHqx3n9D+coTe
+ sTDKKCsKjMbjU7EYBaYOdA1dlGhu9HYvB88+xdTxGmv3GI6+ENffhLn5+TfeYAqfvFraSCs2GAzW7wsL
+ /x2ws/E+hlY/lc4BzDfeornHsXuDtPpnaeuPcvVVEmWUFetKS+0/5X0CkciyUkZZsSIvr2Zlfv7pTFJW
+ yCdHlitbs8yUycn6b/wLvnCph/venGUAAAAASUVORK5CYII=
</value>
</data>
+ <data name="document--plus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACEklEQVQ4T4WSS0hUYRSAD5NF
+ gyA5mFJRMOBEmJSPRYM43SyChh70mAEXEkw+B73KyNjglBpCtKlNUSAlQdimTQQh2HI2bmbRohatJGtm
+ xAYf834fz7nM2ahzu/BtLv/33f8/9wfH9DQwzpmZm8TAf2i8NzUFd/x+uD05CWdsNgB+UWYwWSjgZjaL
+ 66kUhhIJXI3H8XcspvElEEBaN0hYJMARrVZmKJ7LYZTEyPY2rkSj+GttDX+Gw/gjFMKPi4vID60dIiws
+ a4FbPp/gTlBgI5ncN/JqYQEFi93+mAAGbni9wnAqn8ct2n6lCO+Ej0POsHhwzeMRRtI0g1g6rRvhADkj
+ 4sFVVRXUDAUSmYxuhAdLjioeXHa7hbFcsYgpmoNehP8OOWPiwcX+fsGTp0CG5qAXWacjkuMRDzpcLmG8
+ UCphlo5RKXJ/eRRblq5g3ctzy+ZZBU496QC40NMjeIsU4F1UirR87cK+jQk8NH/ij+H9UYB5E0B7d7fw
+ sEQXpUCB3ZEHAfry50uEgs5/A3jwzbG/JAfhnWkOGhUFzjscjI9vWol2sTvS+knBrsjdPcDrI0Hg56TV
+ Cqft9kfaXd0n0rukYusHm0bzqg2rntaF4HlNEF7UzLFvJOobrNZZCWgRgmfCg+Uj8S9ue9uJx1fO4gF/
+ bZidsgs0CWg2ms3j1U1Nz/SoctZ+N7iMEcP1w9/YIUw7Q/B728HeTjIAAAAASUVORK5CYII=
+</value>
+ </data>
+ <data name="folder--minus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB3klEQVQ4T43SS0hUYRjG8Wfd
+ SlwEZbTOiBZJy6A2bdyUmzZhWRAIrSIiccpmmkZtYMqYUvNCMjJOacZAihhjF7qpUwZFRIYilcygTqdp
+ vIyXeXpf8TuLmA4e+PEe+N7/x1kcjNYBKl6HCuHepArTYaQWhofzUTLd60x2pPGYDsM+GF7+7mFutsuR
+ 7kjjNR1ee2H41lL3uZrsdKQ70vhMh5dXYdSvzoS5Mt3hSHekqTcdnrth+FcSIWa/tznSHWn8psNQDYxA
+ 9mc7FyabHC0nOihNYOgyEBN4csnWsDjVwsx48L+yP9o58cxFaRpEyaBLLhiotgUXJhqZ/nIzLz37FqsS
+ F7mWy1G6oLZ4dADoq1rXmPl6i9Ynf156Nvawkjr/LC1R97VDl+jZCUQv4G76c4BzH2rz0rP4gzPUOW1Z
+ 1H0BhIFmuSQeKcBs/+4d7Cvevu5F2X7OvPPYrI/X+TZ8ijrHk0n2nkebAJokXiwv578iu7YxOVJj+yVf
+ 9ip0gjoPDefYfQ73BCA/YvMVueRaAVJ3iosYlFB1H9nHxBuXLfXey1jLMerc259h6Cwi1WVygTxbxNbb
+ p/HYGvNxbtSdl55Fb5RSp+6ePIijGy0K5WVP5WG0+o/j6Wborjai8C+upHqE/vhN6AAAAABJRU5ErkJg
+ gg==
+</value>
+ </data>
+ <data name="ui-separator" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAAKklEQVQ4T2P4//8/AyWYIs0g
+ i0cNoEYYMDExVVCCR2OBGrFASUYaHHkBAGwz1S9OnHZ7AAAAAElFTkSuQmCC
+</value>
+ </data>
+ <data name="gear--pencil" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACkElEQVQ4T6WPUUjTURTG799N
+ zNnD9GGJpcRQJOZMNtCtGTPNxG0POn3oLUYPUREEwcCsMCmEiMpcTxW6UiNWgTYLNNNs/MVttOlGJi1b
+ son4nA58Od3vvyUTeuvCj3P4zne+ey8jIvY/SMsWi4XZbDbW3t7O7Ha7VDs7O42ccxmM2TN4sQP2BLS1
+ tR3jxvO8HkTd2dmhra0tytbg+WeA1Wo1OZ3OB5ubm+RwOK5y08X19SQB9NAwgwfePS9oaWlhnEvxeJwC
+ AT8lkwnyer3fE4kEAfSxWEyawQNvZif9BaPRyMxm86GOjo4bi4thCodDtLr6g9bWfkmgh4YZPPBiZ0EQ
+ 0gEGg8HMhSvA7R6KRaMRGh0dWa6qqnoE0EPD7K8PO7sBOp3OGQwGaGbmI83Pi7S0tERabXWfTCZjAD00
+ zOD5MjRIMwpFVBSEBukFGo2my+fz0dTUFKFGIl+ppkbXK/AnAvTQMPN4POTu7ibq6aExQfgkBVRUVDSX
+ l5dfAwMDrp+hUJTGxz+E9Pra6wC9pHlubptMJm8qlaKmkpJXg4ydkgLKyspYaWnpYZ1Of1cUgzQ9/ZlW
+ VhK0sZGSQD/93kXvRo5Tar2L1Gr1vaKiouonjB8EqFQq0CuKYRobm6S5uSC5XI/jfn+UwMSbO9sTw/XS
+ sru/lmprlM94ADutUKQDCgsLQWtjY/NwIPCNKiuP9CuVytuiGKHZyafk6pHHsPz8oYFO1he/hjezkw7A
+ kcvlLD8/31JQUNCXl5enRg0t+GjyZZN08/0uYb7u6L4X8MC7ezIBUA5wNBw9yM3NPeNolfno9wrdupyz
+ fKKOXcjMtLwW404pJBOQw9v9HBWnJAs6axXe2hsEW5aGi+DFDvsDd0bcBZIplukAAAAASUVORK5CYII=
+</value>
+ </data>
+ <data name="icon_zoomselect_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ R0lGODlhEAAQAIZYAMDAwICAgK2km+vv8+/y9fb3+Ofs8fL19/X29/X2+K6vsNPa4MHCwtrl6ejt8sLH
+ y9ri6eLp78jIyMzNzbu8vejr7paWltrb3LW2tru7u9bX2PH09tPZ38/Pz+zw9PP19tHT1dfY2c7Q0uXj
+ z9PU1ufp6q2trcXQ2ufm0MC/v/Hz9d3k6+/v7/L09qSkpL69vdvg5dDf4ejq7MbJzaSkpePp78nKyuzt
+ 7rO1tuXn6ejt8fP09dbW1tni6q2trO7w8sPExcTGx+js77Cvr/Dy9Pr7+93g48LHzKurq+rq0+7x9Jub
+ m/T19uXp7dXd5cLDxNXb4eHk59LS0re5urGzteDj5d7l7Nvf4wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQB
+ AABYACwAAAAAEAAQAAAIrwABYBFIcCCWgwgTJuSRYsgLhQIDSMTS4UKVKEZISFAYIAmLCTmIMEGgQsiV
+ JwcjopASAkGBIgk2KNExwwbCACMylCjw40MLAgMMcDBhUKKPHQUqNCHgwUAECEsUYriR4ABQAw2sLKBh
+ EEuAIBqsDnDQIEaPI1NuHmQgY2wNJyegUEnp9SAIBiJgrFjwAIeChAESAkFiwQUFLAoEdJUYWOFBAYod
+ S8YioKDlyZgdBwQAOw==
+</value>
+ </data>
+ <data name="plus-circle" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACY0lEQVQ4T6WPX0hTcRTHT3eW
+ C93W3dTVlbLdoQbTejCMKDP/lJBs+CewJBnUY3vsvSACDXrpoYfCyig1IxekQWRei4WTscK2NbQ9bLt7
+ GMzXe9nL5XR+V9u1KHroBx/4/s453+/v/AAR4X/QzfDEAfCsCmCaeF4twEx1gJgkQlswHdB7bIbNkkf3
+ /hbgNb+slY6EO2Vfyq8My1e1i4Tvu185vNwhl1OPArx/C/Bag66ob92vDqxfQd83P7Yv9+kw3b92GXvX
+ RlTL7MEoBXh/3WDCIZRPCVJv8pLa8+UCnv08hMc/nKPlNg/TrMZ6Z74Oqbsm90lAHuMLD+2BJqlN7oqc
+ x7ZPPp2Wd92lAKZ/1jtWBrD+basM5DEC7vNTpyP9SutiDzbPn9JpmD2GhUIBs9ksVo3Xo/2BW6fmUSO6
+ Xx1VgDxGwL09oc7IoOZ5fRKLxSJmMhlMJBKYTCYxlUphOp3GXC6H+Xwe+cci1s40aUAeI+CuLdQe7tPE
+ YAvG43GMxWJ/NG9sbCA/KaJz9pAG5DEC7linPO9PKPY5N/LT4iZPxdLLTJfqc6SDLgXIYwSMWQKOaVGu
+ XmpAfpEGGPOisTbpUp16uyecMpDHCLhVKZhu2yTnUqNqD9MWYTIsiPqf9bVJ6zXCtlCncmMWCchjBNys
+ ALhe4S0btUb5kEu1r1LIKhnebME0Yft4QDWNWqJsFshjBACdOhPA4E4vd80smccdsjW0X+HjLo3BNKux
+ HpvRZ+lsDyiju5PwgLCjC7q5GzDMvYARLqTDNKuxHkAzsZco2x7AUaGSqCGEf8AeYrMcC/gB3xr3gK0n
+ sEUAAAAASUVORK5CYII=
+</value>
+ </data>
+ <data name="icon_search" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ R0lGODlhEAAQAIcAAAAAAP///4CLnpWeriI3WjRJazVKbDRJajVKazdMbcHGziI8ZC1Ne0hadq+3wyA8
+ XyZDZEVzpVmDs1WBrTxtnNvu/ydNbo7I+aLV/6TW/43J95rQ+4O32rLg/9nt++Dy/xxGYC9VbabY97Ph
+ /dHo9+X1/zRriH/A4L/q/8Dq/8Ps/ylTZLrW4srx/73p98/1/6/h6Wayup7W3Kzf5EyDhiZnYEJ9dmm1
+ q63h2h1jWFKmlXK7q4DEtcHu5BtiUY/OvjRyXUeWeVKegi1sU225mESVbFSpeCiLUCeKTanLtRyBOC6O
+ SWCxeBF3JqvQsg1yHRB1ICmKNy6OPAVoDCSFLKbKqQRlCQRkCBJ1GBZ5GxZ5HKXJp6THpgNiBgNhBQCq
+ AAClAACkAACdAACUAACLAACKAACAAAB/AAB1AABrAABiAABhAABWAAFdAgJeAw+jDw+bDw+aDw+RDzi5
+ ODi4ODicOF/CX1+2X2azZmGqYWasZmGkYaDdoKDaoKDUoKDToKDQoKPCo/D68PD58O/37/D38PP58///
+ ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAACHACwAAAAAEAAQAAAI6gAPCVQgoAEBAg0EKBDIUOCABCFo
+ FAkywQKCAQ0PDYAAREoUGSI2xKjxAOPABEO0ZGECowOGE0hMHFh4SMAKLFR6vFAxIoOGI01ACBDYwMYP
+ HC9apHB5AYoVHw0EEhBCZIYLFCU+VCCxhUsSB1I57DDCo8OHL2jTpm0g4UYbN0s8gKHDRxCfOWDAhBHA
+ QIeXNmyciOlj542dPmISKzAQQcmVLoHGDIIzJs6gMZg1LqDwZEoVMn/uyLnjp4xphwVA5GBhpg6gQoAI
+ 4TljhiHBBg7Q6Natx1AeNBkFphlOfI+hNMEPqVm+fA3zgAA7
+</value>
+ </data>
+ <data name="icon_popupscrolldown" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ R0lGODlhEAAQAIcAAAAAAIAAAACAAICAAAAAgIAAgACAgICAgMDAwP8AAAD/AP//AAAA//8A/wD/////
+ /yH/C05FVFNDQVBFMi4wAwEBAAAh+QQAAAAAACwAAAAAEAAQAAAIMQAfCBxIsKDBgwgTKlzIUOCPhxAj
+ SvzxYKJFig4vQiyoESNHiwknLozY8GHDkygbBgQAOw==
+</value>
+ </data>
+ <data name="scissors-blue" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACRUlEQVQ4T6VSS2gTURS9mSyD
+ QRGtRlOxkM+gdcAQiIImMQYbE2tIqqVmJUHcWPCDkj4k/q2gYBcuahYuhIpWorgQsSqEqhUpmE1WQQrR
+ QsBo1m7M8543HQ0ibhw43LnnN2+GISkl/Q8ok8lQNpvdxzBSqRRFo1EKBoPk9/vJ7XariR08dPjgRw4P
+ VmQ+nxdAMpk0/lUA3fIipwpweTweUa1WZS6XE5FIxPjbCcBDhw9+5H4V8L3h9XpFrVaTfDQRCASM7lfA
+ Dh46fPD/WYDd8Pl8ol6vy0QiIdho4BtgYgcP3Qr/LvDtJ9KzRKs3qRJ+smg0GjIcDguXyzWEiR28CsMH
+ P+fMVxi8Q5S5R3RgmihyHkWGruui2WzKeDw+U6lUJHbwSocPfs51Fzho6EGacYkxSeFiuW/30flWqyWd
+ gzfnKTVZVrypp7nA0V3goPTdse3F17NnyovfxmfanWsv2vJ46Y2077nexj0AHjp88HOBwzzB3tLBUOHl
+ O5g8R6Y+2AduvLr87Iu0x8YrjAlMtTPfM1Kau/r8q4QfObMgNnGrO3z28Sep7bwwq4UvDmu7rpCavIO3
+ SsSjz9+RMwtC556y2IFYfLIotdDYW22bGNG2HCbbxhhhqp35wsMFVXL6/scfyJkFm0dv7zg21cQpbFtP
+ vbd5hw/ZnL3mL7p0YVc864XphQ78yJkFy9xR6h8tMeaod+AkM/34uxkbGOsY6xl9DJ31E8oHP+esX9nF
+ ooW1fN/DWMlYznAuYQXPVYw1XV4XCn4Cnzlvq0a0CiQAAAAASUVORK5CYII=
+</value>
+ </data>
+ <data name="sql-join-right" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAC50lEQVQ4T2P4//8/AyWYIs0g
+ ixn0i7czGJbuZDAq28VnXL7bAoj9gTgSRHvUXghMbnu9MKXtzX0g/gWl5yW1vNKIrH7I4FdwFW6AnEfL
+ wdiVxx5Pe/j6247Xn36eW7j95ZGougfvY5oeXG5f8vr82gNfHs3e9OFO7axXz6NrHz6PqLofBDOA37Vp
+ f/zVxx/XPHrzdd+DV193Hb709kRA0aVPfctfPVqw/cOVpJ676xfv+nh12Z5P15bv/XSjd9mru775l557
+ ZJ3XYNAt3Gq7+ND9afdffd1958WX7UAD9mS1nbuf3XH9xdLdn66BcMuSZ0crZj/eBzTg+pJdH6+AxLI7
+ bjy3ijkwj0Erb1PE9SeftlyD4nsvv+43Ct3ysWvJ0+sT17450r7s1e6eVa8OhTVf29S98vW+pkUvtwHF
+ djXPf3xBx2/TfQb17PVpQJsPXnjwYT0I33j6aZeK++o/ncteHqqe+2wTCPesen3Au+ri+p6Vrw/CxDqX
+ vzyi4rb6F4Ny+uq4s/febTh55+2a7edfzNlw6ul0de/1H0un3DtVMefpZhBuW/biYHDD5a1Am/fDxEqn
+ 3j+p5LL2PoN88nK3SVuuzdp4+umcnk03m2bsutvll3/4Vkjp+UfV855tB+HCaff3Z/Tf3lM7//nOsllP
+ N4PEQksvPFD33DGPQTp+sZBO9qqihfvvTu7dfLO9ac3Vhp7Vt1aahJ34nN/34HLTomdHA+subgfSh4pn
+ PAa5aHte38PzRiEnn+sFHNNg4NUPZBB0KVdXS1taWr7g5KR5++5OX3Pi8YKiydf3WsZe++SUdfVWdt/9
+ M21LXxwvnfb0VGzdw4fWsTdfaDkvCpLUSmMAAWYgFmGT1DHmdyqLEw6ZWiQcPrtGOHR6oYRDXZZlxLnV
+ DknPHjgmP//lkPT0oXnIsdXiKiFuID1QvQxMQAYXVEAKSEsCsSgQCwAxHxQLAmkxqBxIDUgzSA8T5ZmJ
+ kqwM0gsAucRqK8NQIioAAAAASUVORK5CYII=
+</value>
+ </data>
+ <data name="cross-script" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACFElEQVQ4T6WTT0iTcRjHn3D6
+ 5nJbr+2dZo3Ci0KE6EC9rpNEl52yS4HFhKyItJIKCwnBlVYUFh0a2b95yYJRHdYunYJJZBZEeogxhJAu
+ ecnSt88zt5cF0WWDz37P832e5/v7A6/Yti3lUNawbpw3SIjIlEgXZArcfII2CXfhHjwE+nZRH4JnEHUM
+ tAiZ3wMD9nJf39pMe3tO8/slBg9ERhNVVe/QXz8S2QsbHIM4jRBlp8zbjo7ct54eO9vdvTIdCHziBKEp
+ rzeebm5eoJ6kb4duiEH+9Pk/NdBj3qF5QiQGmZlw+PvnSGT1ZVNTNt3SkkV7jlm99v7PQK7TMIbROCap
+ 1tYfqVBo5XZ19Ry5XANdlb9OcAmhyLCINcIjJRoaFpONjT/HDWM27vd/HausnKUmF2CwgHOFonCewpDI
+ jceWlUsHg6sxw5i7KHIY7ektt3ue9cW5fxmcRFROi/ROeDzzmbo6e9Lny51FYkh06AzGMZfrI+tIP/mp
+ 0kc8RnKc1z3Bvd9b1q83prlMnMTUVGM9oQ6gDcMresM641whSgJX4253bqG21h6sqPjQy0NG0Iu/ToKj
+ 632XYfSIiMsxqKdwiN2/mObadE3NEvGVrSXDpWHbem9/l0ibY4C2ncLBA5jsF0kFRPag7QRC8YEHNoMF
+ 24IinbtF9pUaeCn4QTdWdFAHNsFGMAqr5tprwhbHoJzP+Q95lHpGrVHH8wAAAABJRU5ErkJggg==
+</value>
+ </data>
+ <data name="sql" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABE0lEQVQ4T82Tv2rCUBjFb+ji
+ IF1KKfgATtJBtFOW6gOIi2hBEAJm8QncpHXxBRwEB0cVRHBx0Uknh76CD+AzpOeEc+EmSJd06IUf5/tz
+ vi83hJgoikwWMg3zwf9gged5PliDqdRAX8Cn8jm0CXhGqtHfAobmDWiDkmLWxmACnkBd9VcOOH7G8YId
+ CNTsSFnrKn6Q58Pp2The8A72oCYDa8ztgnSe6MXX0DWPUuaMe85CN0/0aLbXHyA+aYjad16BufW5cZkL
+ LsaYCjRkrKEZdIE6v0ZD9ap69ISa4ay5grM0gBbAG9iq9g0dqr5UjTNkxQU58AieZeICy5eWF1M9ejnD
+ 2V9PHt0DuAH/rjPLn/gnP9MPy8pUmKBE2kMAAAAASUVORK5CYII=
+</value>
+ </data>
<data name="gear" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
@@ -1455,60 +1575,70 @@
QmCC
</value>
</data>
- <data name="water" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\water.png;System.Drawing.Bitmap, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
- </data>
- <data name="icon_fitwindow_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_maptip" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIUzAKq7y6u8zZ+svdbd4dfcztje4tbcyNfcy9Pb39Tc4NXc4MbS2MTR19ne3cTP2MjU
- 2djd1cDM1srV2sfT2MfT2cnU2tfe4dXd4cnV2sjT2dDZ3svW28/Y3dfd0cXS2M3X3NTb4M7Y3Nje2dLa
- 38XR19Ha3sXS19ne4NfcytLa3srV28PQ18PQ1sDN1szW29Pb4Nfd4dfczcrW2wAAAAAAAAAAAAAAAAAA
- AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAAzACwAAAAAEAAQ
- AAAIuwABCBxIsOAMAAUSWhgwQEECBCNKaOAA4KBChgoCaNwYoiLChQ0TBCBwwIABAR88whhwwSECByNL
- CtjgkaUCEC8DQOhAAIUAGR4vJMAJs4EICAJiCMDgUWSAoicaCGghQMADjy9G6hQhNYIEDA8oeEQQ4ACB
- DkgjqABLYYHHFAEMmBXgtcKDCQs8eNQQVy4BARUytPXAwCOHAFUTZ8BrgkHhgyE+uNggITBeEgxWsPBY
- sPPAGaBDix4NOiAAOw==
+ R0lGODlhEAAQAIU/APT19/Dx89HV3PX292tpdYuKld3g5N3g5by9xdnc4c7S2dXY3snO1sbHzJGQmdXY
+ 37K1v+Dj5/P09Nba393h5dTX3czN0PP09dfb4M7S2uLk6Nrd4tHW3ImJlGFgbezu8bi7w93h5NTZ3urr
+ 7oWGke3u8eXn6svQ2O/x8+rr7enr7c3S2ZSTnMzQ1+3v8dHW2+Hj6Nnd4t7g5c7T2tPX3eHk6NXZ36al
+ rGpodMvQ19nc4s3S2ubo6+3v8EZDUv///yH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAA/ACwAAAAAEAAQ
+ AAAIvAB/3MDho6DBgzhuCCQwoOEAFAAifog4gMDACDky7tjIkQGDHBEIZtTIcWOLExkLztixwsPBghAy
+ KFBQUIBNGhUg+CCxkYOAFwIKPrCxYIENED462FhqQ8SDgjES6MAwAYGPAjqyStVRMMQBCgY2WMWqw8AB
+ swVrqK0hY2zWGjBqaChogoddHg18OLh7t+AIvnn33lWRomCPw4ct+GCB2EWPEj5wBAiAuPLhyQESEpBg
+ ufIFCRYFEnyJUGFAADs=
</value>
</data>
- <data name="icon_null" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="minus-circle" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIECANji87HH6f///wAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAACACwAAAAAEAAQ
- AAAIRAAFCBxIsKDBgwYDKFzIUCHBAAAiSpwY4OHEiwAqDoSIUaJGgRw7ZrQocuTGkiZBovwoIGRHli4x
- wlz5sKFNhDhzHgwIADs=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACC0lEQVQ4T6WSP2gTYRjGP5JA
+ EyhNc0M8SotbAxU7pNDsNRA6hLQIpXiVzi0d3RVEaAUXBwexYgT7T9EKcfHfWQlSJJfmUFAhZOgJRocM
+ yh1ZjtfnCXq0pY2DgR+8933v87v3u3xKRNT/0AnfV0o9ABtgU6mBLaWWwBoo/4H1EvfYw15mmD0qyD+O
+ xcxaJuP8mJtzfy0u+j8XFvzvhuHujY873IMgf5Ig/7S/32oahvdtfl4cwzgE177Oznrb8bgFQf7QBEWO
+ Fo2a+zMz3pfpaflUKBzL56kpqRcK3npPj8lMcIS7ON+7dNqxJyfl/cREV/ZyOXk1MuIwEwhuK7X+IZdz
+ zUxG/vI8nZbtVErWBgflXjIpdzStA+tSKuUyEwhu4Wvj7f6LsTFpt9vSaDSkWq2KbdtSr9el2WxKq9Xq
+ UEwk5NHQkM9MILiJByub9Z8ND0utVpNKpXJsmIItCJ7ous9MILiBcd6MjroljLiBhm6UKNA0l5lAsMKL
+ k0zu7+B8r9HwL4qxmMNMILiGv+R6OGzu6Lq3iyl2ITmJl/G4txIKmcwEgqu4lpdxOZYjEausaZ4NiQ3J
+ Ud4ivBwOW+xlJhCgVqfBeWxcgn01GnXKfX3ux0TCJ6y5xj32sJe/g4IInk+BMwNKncsqdeWCUg8v4ksT
+ 1lzjHnrOAh1EDgpCWOgFSYC+rvBF7A1R8BuYvt7nXvKiFAAAAABJRU5ErkJggg==
</value>
</data>
- <data name="magnifier" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="globe--plus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACPklEQVQ4T2Pw8/NjwIYDAwMZ
- QkJCBENDQx2AOAqIU6G0A0gcJA/Sh1UzSAKoQDEuITlpyuKN3UevPlt//9WX4zcfv926aM22PpA4SB5s
- gI+PDwb29fUVjIqNT1l38OrCIzdeH3r05tvZJ2+/nQNhEHvHiZtLomMTUkDqGDw9PbFh54nz1/btvvTi
- wNXHH0/ANMPoa08+nZi+ZMNEoF5nBmdnrDhh2+kHa0AG4MIHLz/ZBNSbwGBnZ4cN5++78nIfTDO6C0D8
- E7ffHgXqzWewsLDAhlP3nH+4EWQANs0gsVM3nu8A6k1lMDQ0xIY9J89dMX3/1VeH77/8ehrdEGBAnpu3
- bO1coF5PBicnJwYHBwewN2xtbRlsbGwYzM3NVVzc3KuPXLy37+azzygGPHv//eLlm/d3WNvYlqipqYlg
- GGBtbS0PNKR47dr1/zU0tdsnTp+79PGLd0fefv557emr90fnLVi8UkNDs1ZQUFBLTk6OAcUAoEYtNzf3
- mh079vwXFRVrZmFh0QLiMCCuBOJ2KA3ii/Hx8TGgGAB0vkVgYHDbkSNn/isqKvUAFakCMQMuzMXFxcDB
- wcEA8793QkLKhIsX7/7X0zOYBtRkzMzMzMDIyMjAxMSEgRmQAcgZwEAruXXr1X97e+d5QM0uII2kAA5R
- UVEXERGRFqDmbKBGfSDWAWINIFYBYnkglgZiMSAWBGIeIAa6nYEViJlAFrFAJaWAtCQQS0D5IkBaCIgF
- gJgPiLmBmBOI2aB6mIE0IwDSnmBluZcHuwAAAABJRU5ErkJggg==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAADV0lEQVQ4T3WPf1DTdRzG327K
+ 5WnY4RWnZ51pU0AvuXUlanJNVDDvILs8y5MpWaDmxWkCd96pSQgxmGBGOgc7ajBtuo7MdfxQ+wM1xmAT
+ 227MpjOSTVwEDLG1cI/vz+KuP7y+d697Pt/353me7/tLkn0/k6TIStLPfiVp2W9PSVX9q6UVPhVzjmmb
+ UFV0Lu7ZJ/zRHPPvQRQUu+fypWZpbZ+97MofAYMzGDrvDka6R8ZDjZ6HgTUGn13cC9+TBYWWuTMO2Zvy
+ f+jznXUNoSs4jkbnCLS2IVy7H4IrDLj+Bo5aB33CJ2H/fxvkmadKdrXq8ptu+cvb/Wj1h7gggkbHEEzu
+ INoHQugcHkfnGHDtAVDa7vMLv0Tk8sxEk7YY0pP2Nzu3fnsTO8578bX7AYov38WBS3dxuncUPw0CB80e
+ 6Hn+3T3g3O//QFbwo1PkJm3Wc8GGE18o62xDGToX1tT3Ikvfi01GD7JNt7GzyYst9TeQedyCqp4w9nPb
+ +6Y72Mx+kWOIKL28eY/5XlhR48CSqm6knHRghdaB1FonXq+xQ2nyoejqI+xuG0NqlQ3JFVa8edIWFjmG
+ CxSHLSmHLkbSdP2QHbEgobIbiZU2JKltSFRZIVfZkFrtwjumMTy/rwVyNZdXdkREjuGCNz5tWaGyhl8s
+ 7sBLZV2QcWDhBAmsspIOvFbtwdrGMbyQ34L1JmCDfiAscgwXpB35clFR8/CC8htIqPgFi486kFzlgPyY
+ M0qyugdLj3mwpKQHM7U5iDWuxizdtpDIMVyQoV4Xl62/+Qqb5MzymttYpfEivdaLjLo7WKv1QnHCg1dL
+ 7Yg7k4YP/ixAzKnkECk/Xkd7s7gg86up9JamIeFgZ2CVxo/M+gG8Z7iPbcYAtp8NRHV+/Q7M0C5HvEGB
+ jYFc0HHZINXNtFFtnIZo0zdE7zbMm5xtbJWXOQLKM8P4qCmITy6MotA8GtXntCuh8L/9BFTzTBevwE98
+ Ev9KyTzK+b5hTuFVd5a2f3iXaSRccOFhROic6py/pnz+cohKZYOL+1aCKmO7oqhjeQMiKfMsk0hPx6fQ
+ stwPSWnUUW5zG+W1WqIq3sX8wHTXbO8i0OHp12n+ZCmXRL8vYaZNlMxm/X92xugob8p12h2jncjRY8Vf
+ HJIr03vAAAAAAElFTkSuQmCC
</value>
</data>
- <data name="arrow-curve" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_zoomout_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACE0lEQVQ4T2P4//8/AyWYIs0g
- ixlUKo+AsVrNcQbt5nMMBl1XGQx7rsOx3dwXDCBsP+/lTCD2sJ75hMFs0l2wOs3GM4QNMJlwmwGkCYjP
- gPGMxx4kGQByjXHfTZCtZ6Y+/PcfRJtNvOOB0wX6nVdMgZK9QLwNiE8D8RkYrj/943/39d//QXygOg90
- L3ABBSptJ129nL3nzZu6099+Np//+b/x7I//dae+/68+/u1/4d5P/zO2vP9ff/r7f6DaMxoNpz0Y5Iv2
- MiiU7GdQKj9U6Tnr+t2aE9/+lB789j9j+/v/Yaue/Pecd+u/84yr/x2mXARj5+lX/nvMufk/fcfr/0A9
- Zxgks7cxSOXuMDVoOnq57PDnPxl7vvz32fbhv+2G12Bsvf71f4t1r/6brnn1X2v5y/8Ki57/t9709r90
- 3s4zMvm7PBhEUtaDcG/k8ruvw9c//WjYd+6BUs3B65L5Oy6Kpm88C5Q7A8fb/v6X2fn3P4gvmrrBA2gI
- AwNv9DIQ3qaYt/kskO7lj13hDsQaQCwIxCxCSWsZBBNWg9ScEdrx/z+I5otZ7sHv3czALq3HwMAspsHA
- ETL/DJt9RRWbbhADNgBTA1XnwSyuiaJMmNm6eDFQxBgLNgCK6QCxOlDNImaD2HAgWxiIeYGYHYiZQSZx
- AbE4EEthwRJAMTEgFgFiAahGkHqQZhYgZqI8M1GSlUF6AcIC84BckOgRAAAAAElFTkSuQmCC
+ R0lGODlhEAAQAIZpAJySh3aFlJ6tvO7z9eDPvpubm+ru8LKysqGhoZ2dncvFwOLm6Z+fn+ru8dbc4t/j
+ 56ioqNvf5KOjo+bp68rT3Kqqqp6ensnKyufr7tDX38rQ2MPIzre3t62trfL29+7y9brBybjAyMPJzsDK
+ 0trf48XL0s3Q0sDBxO3x9Lu8vLy9va62wLm5uf39/ebp7aWlpc3Nzautrs/Pz9Pe49HY39bd4qyyt5+m
+ rtLY3K+vr8nP1NHX3bOzs9PZ4Nvg5czU3K24w83V3crS2uXp7OTo7JycnNDe47e+x+Hl6Ovv8rm7vL7F
+ y6Kkpefq7dff5M/a4M7d48vT3M7W3ujs75+goOTo6/b4+aWmp5qamtXX2NDQ0MrDv7O2uc3S15GSk9Td
+ 47rCy7CwsM3e49fZ2qKiora2tqiim/H09t7i5gAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AABpACwAAAAAEAAQAAAIwADTCEyTIwGWAi+0DFyYhoOECxMGGBhzoALDNGU6GBgw4EOSKS5U8GBIxkAL
+ KygaYBiy4MEBGQPDXBjg4YzKKkjQRDBhUSCDiAKCChXgYAeDgQUGEAnAtGkAGlIsDLTQBEeXlj6cfMkQ
+ RAOCgRCy6NhAIkKNGUagUDjBYiCMAyKWlHDQ44mYEUK+LpQQA8QRMD+iULiBIMUWhhCY2FgBJASXBF7M
+ EFDAUAmVIgUSXBEIAMDki6A7fwbNUDTpi50DAgA7
</value>
</data>
- <data name="icon_panup_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_pandown_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
R0lGODlhEAAQAIZuAJumsOTY2MS5uK+2vcW5uJumstrOzsi9vOHV1eHU1ZunsuXZ2dve4d7S0aaxvuTX
2ObZ2aaxvePY2NnNzODU0+HT1Ofb2sTJ0c7Jyfjz9J+rttvPztrPzpumsdbS0pqmsdfR0dbS0aSvupum
@@ -1517,27 +1647,111 @@
18m9vJqlsNLMzMK4t8zAv9zQ0P///9TR0KGsuObY2Mu/v6CrtqSwu6mxu8m/vubZ2pqmst7T0tXKydXJ
yc/Jyca9vcbL0si8u7e9xK+3v5+rt8zDw9PHxtjPztrX1+fa28/S2NTMzAAAAAAAAAAAAAAAAAAAAAAA
- AABuACwAAAAAEAAQAAAIxADdCBxIcKCRgggHMgDAQOCLAARSgEE4AMAANz2gcIAgwIIWNQUBCKyxgACJ
- BwLWnAlCUKSbEyYCCDDAQ8CWLm0GunTjA00VAhseCEkiIUbCGS0CKKFQIcECCSESjgmwpASFHzsCpCl4
- JAqCGxMqIEigowgEGgRBPGnQAIcKGQZgGMjA5uJAD0NQTPDC4gsRIGIimClT0ImVAweYSLmgIQKWK1kQ
- TsEQxoWCESIcrOCSUCCZAgWaUMlho7NAJAU+dFDgICAAOw==
+ AABuACwAAAAAEAAQAAAIwQDdCBxIkCCAgggNCnwRgEAKMAndHOwBhQMEARa0qCk4AMCAGgsIkHggYM2Z
+ IAQZAGBwwkQAAQZ4CNjSpQ1BIwJ9oKlCYMMDIUkkxEg4o0UAJRQqJFggIUTCMQGWlKDwY0eANAWPREFw
+ Y0IFBAl0FIFAgyCIJw0a4FAhwwAMAxnYDCDoYQiKCV5YfCECREwEM2UKOrFy4AATKRc0RMByJQvCKRjC
+ uFAwQoSDFVwiuiFToEATKjlsaHaDpMCHDgocBAQAOw==
</value>
</data>
- <data name="script--arrow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_restorecenter" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
+ R0lGODlhEAAQAIZdAEJyohU2aKTFzsfc4bLO1eHt7+729rDN1d7r7b/X3drp68nd4ur09Nno6uTw8Xuf
+ veXw8dno69ro67HN1efy8+nz9KrJ0YqpxbbR2KbGz+/2973V3K7L03+hv/P5+cLZ3tfm6bPP1qnI0dfn
+ 6qjH0dbm6rPO1cDY3c/h5r3V27fS2bHO1avK0eHt7uHu73yfvnOZuMvf46vK0rXR2Ov09NPk6Mzg47jS
+ 2YCiwNLk53+iv8jd4nOauejx84enw8/h5a3L07nT2nygvs/g5Nfn6cDY3u719rnS2XCYt8PZ3rTP1q/M
+ 1LnT2ejy88Ta4ODt7rLO1m+Yt7zV24enxMXa4K/N1H6hv/P5+N7s7tXk6LbR17rT2s7g5QAAAAAAAAAA
+ AABdACwAAAAAEAAQAAAI0gABCBxIsGAXAAwMaDDAAAKCESgGJFBxAMBBAwEuXAlAoUCDAAtwBCBgEYCG
+ CwGmBKhQQEEAHQGEmChpxIOPABxdRMD54gjJgzRw4nSApYTQABNKQmhSoYeDJxJy2KCyYUaVkggKFGiB
+ QEKWIQOKBAkBpCSRBgoigKjBZceHFFoOyCj542iMAUmOiig5YEEHnE5ObMDJw0KGkgmsBHgQQMoWDAFg
+ BEAioOSNxUwCYFByIICFKAEqH1xBgACUCUs4sCCRQYDrkgVjD+xCu7bt27QDAgA7
+</value>
+ </data>
+ <data name="server" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACA0lEQVQ4T43TT0iTYRzA8d/o
- DylIsEOUOyS85qGZhxXULsGG0kCrQ60uG3aIZ7iNZIZ/VuhFbSQIug5dUrpK4KGIIII0iQi3WtFCR6XD
- 3jne+Ta3uSG67dfvCZ7q9ODhA+/h9+X9Pc/LCx39/cBdCgbh6tCQlbC9ujI4WP8n5i4ODFhfLi4+q1Sr
- WK5UpPKl0satyck79NLjcCEQEFihXMZMoSCV29nB8OzsY0dPTyN/MZzv6hKYurWFy+m0FJ+hhtn8fmjt
- 7gY409kpsGQ+j19UVYrPUMNEByedToGt0fpfUykpPkMNEx00tLcL7Cett0RHkOEz1DDRwRG7XWDrxSJ+
- 0zQpPkMNEx3UWa0Cy5RKmNR1KT5DDRMdHLRYBPZrextTm5tSw3M6Kp7x6Yab98HkHgYwNDcLnjx94w26
- JBn3jIqnxz4mzz744WoJfQaApibBV9zdxRyt+L+7T1fQObX817XpBD5UESmOnBqNuQBMJgBF4QJaLofp
- bBY1OkaGnnXapiMcxfAaojeO6P70z+0lRCW4EAEwGnlsvuzzPXkVjeJ8LIbv4nH8kEhgfHUVPY/eo21k
- Du2j89h67w22hRbw3FvEo97nkWP+Fy4wGI1ms8Mxoel6tko/khQinvDOFOquT32vtfd56AIOgaGmpmWf
- ooT26oCt9/V+y40+iunscPg3qfGIS2EPRjUAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABaUlEQVQ4T42SMWvCUBRGr+LU
+ jqVQujh1dtDFxSVDBhFB9DdokCAigpNDBscundw7+A8cRDAEFKQiySAYXESy+Ceu95Z3H0IerYGTId+5
+ ZwogIjSbzV9arVaNaP9DTXy+BX41Gg2hc71eMUkSI7yR2xFfB+r1Oiicy+WCcRwb4Y08R3wdqFaroOj6
+ vo/r9doIb+R1xdcB27ZB4Z7PZzydTkZ4I88VXwcsywJF73g84n6/N8IbeT3xdaBSqYCiP5/PcbFYGOGN
+ vL74OlAul0ExOBwOGIahEd7IG4ivA6VSCRTD3W6HQRCkmE6nyBt5Q/F1oFAogGK03W5xtVqliKIIeSNv
+ JL4O5PN5UIw3mw0ul0sjvJE3Fl8HstksKGb0G+NfkDcTXwcymQzkcjnmy3VddBwnRfGniLyxwy7f6ADQ
+ Q9UPGj4nkwl6nmeEN3bY5Zv7wAsV2zR8PwK5Hbp/vQ880Yc34v1B2H3mwA1XqPmpzb5U7wAAAABJRU5E
+ rkJggg==
</value>
</data>
+ <data name="icon_buffer_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ R0lGODlhEAAQAIQAAIyJk6y5xWibx7PN4423x/D1+cXHx3Ghy6PC3ZW9x4Gr0LXHx57Bx5S1xb3Hx7a/
+ xqDCx////wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBF
+ Mi4wAwEBAAAh+QQBBwARACwAAAAAEAAQAAAIiQAjFEBwQMGAAhESKlw4IIGDBQkEKCwwQIFBhAoWBABg
+ gIDECAISLICIIEJGACg7ChBAwACAAA4ORGjoMqWBmygBLFAgkGVNjj8NJBig0GfOnCoRFsWJ1OPChAKY
+ cmzwcWHIoBGfFriKNOvTAQywVl2oQOxThWUfcPR6diaEmxDGnh1Y8GDbhAEBADs=
+</value>
+ </data>
+ <data name="grid" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAApklEQVQ4T6WTMQrCQBBFZ0+Q
+ NljkrjYpU3oKEUFQhBQpAjZewAt4jXX+kpG/3V8S+PAW/r6dKWI5Z9sTSykhR8+5IeiXh0Nw2UQ4y8yC
+ KwlkZsHNBZFRYHSrFe40gcw8wZMEMrNgdkFkEhjdaoWFJpCZJ1hJIDMLXi6InARGt1rhTRPIXCbYvs+f
+ zGQOweCXH55vQ9AfQtD5ofccGoJ+VwR7fmXc/QGbydmsomqW4QAAAABJRU5ErkJggg==
+</value>
+ </data>
+ <data name="ruler" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB3UlEQVQ4T2PYn8jCsD+JheFA
+ EksGEHdDcQZIbG0EM0gcJw3SywAiQIqAdM/fm8v+/7qy8D+IjU8jzGCwAfsSWTJBGpaFMF98sLnh/9dT
+ 0//vTWQ5AxJbE8E8Bx8N0suwPZZlyu9ri/9fnej+/8fFef8/n5gKZ9/fWAcWw0aD9ID0MgBtmf92f8//
+ baUm/+9tqP3/8eik/6dbrP4/29aMF4P0gPQyzAtgap7lx7QRyLn/9fSM/+8P9YMk7oPECGGQXgagIjCe
+ 5MY0787aqv8gkzdHM88AiU30ZMSLQWoYloYwM2yIAuPZIOe/2tP5H8QGic30xW8I2IBOeyYYXnhzZdn/
+ FzvbwH4DYlD4MMzAYwjYgJVhzDC8COR8UOABxRYhiTNM98HuErABjZaMMLz0+tKi/0+AaWFZKNNSIGaA
+ YS0xRgZ0oCrMyOCrDhRfHMwEwytfAZ3/CBiVQLGVMHFNUUzNKIaJsTEwVBgxgvDqK4vy/z9YV/1/rj/T
+ eiBm0CCkGWYSyDkTPBn3vAa64NmWxv8gNkiMWCAPVGiUasywsM2Z4TgIA9nzgGLKQCwHxBJALAzEfEDM
+ CcSsQAwMPQQQADIloRikWAyIRYBYCIj5gZgHiLmAmB2qmRlIw50HAIdyTYaOb/frAAAAAElFTkSuQmCC
+</value>
+ </data>
+ <data name="icon_print" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ R0lGODlhEAAQAIMAADw8PNjY2GZmZvf396/Azu/v7+jo6P///3Nzczw/ROHh4WptcHZ4fGtzc////wAA
+ ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBBwAOACwAAAAAEAAQAAAIjgAdCEQAoKBBAAgEKhQI4IDDhwcQ
+ JFzoAICCixgVIIhI0WLGixs5KgwwoKTJAhJTCmSQoKVLBAMMyDQAQGACiA4TxJxZU8BNnAkElCxQAADL
+ nxBbbiQKQOcAly5L3mSagKjVqwVulmwaoKvXr1oHNIVKtuWBrS4PEFhL4EDarUdxuk2wIEDBiUehMqDo
+ ICAAOw==
+</value>
+ </data>
+ <data name="icon_zoom" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ R0lGODlhEAAQAIZsAAE1Z3BJJai7zuqxd9nFs1tgZNnm88fb8MXa78/a5LjH1+fu9dDh8trn9KjR43yP
+ orrT7erv8+Dq9ISAf622v2Rrcmxtb6Sttqq8z2BocJ+fn4aKjcvY5ZqbnYSHi9jm8pGRkpSVl7S3u83U
+ 2f///4SFiHV5fq6yt6Cnr77L2K7L54SdtXh3d1xbXcjQ2Ozw9GRgX5yzy7CurcLQ3efs8eLs9UpMTODo
+ 8XahzMbb78rc7s7X39ri6uHr9HyQo6/N6uLr9eXq79Dh8dHh8jAvLrvU7X98e5DO1pmirDg3N97m7auo
+ qKamp5u83sjIx6TF54iOlKu0vJy20IWUo67C1aC50unv9Mza6EdKTV5cWr7H0bC/z4OGiKWqsdDg8YBq
+ V+vw9bbBzauvs7e/x1hYWdfb36jG5OTr8W50evT3+Zu20MPT4wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AABsACwAAAAAEAAQAAAIuQDZCJQxAYaRJQITAkjIRoMILSnCdAHhRGHCDi6U0LBy48oWD2wAiBTJ5EQE
+ EmkWSPigY0oIgQvZsBjxgseZHga8IIjRAqbALEHAcFjTYAgCCGaSMGRjocyCGg0Y5HDwQwqWFSMBQBED
+ xICQAw6OPPGBZumYEjsYHCjSBEeVDFGWskHBBQkVFWoeVCggVyCFDWSI2DBxoUCAAQTkJlCAQUECNgIC
+ HE7cl2HkyZUtSx6QWfOXzpZnsAkIADs=
+</value>
+ </data>
+ <data name="icon_zoomout" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ R0lGODlhEAAQAIZ6AG1LJgE0ZkV2qN7s9bK8xuqvdtfk7LOcjH+AgLrK25i1019fX6OmqdDc41lZWV1d
+ XcnV4XF3fJrU5Xp6emVlZbHE2Y6QkY+Rk7DE2ZGkuLvJ2MjV4VlZWmZmZlpbW8PP3XmTsLHN3rGai5ux
+ yYWFhajN32NobG5vcOz0+a+vr6ewuYGYstzq9LW8weXx993r9WSHraDP4VxcXJ641IeHh3uFj5qzzn6a
+ uF9hY6rK3YepxarA19bk7ouLi5230rnAxdLe56m80ZKYodjm8M3a5nplTnt7e3Jyctfl7/z9/dLg6tPh
+ 65m108HP3aurq5vO4mlpabvM3M7b58fHx1xdXoCAgG5ubometKy/zoeNkkZJTGdrb1tcXczZ5cfU4MvL
+ y7GxsXFxcae+12NjZJOluLHJ25yvwcva5lJrhePv9ZKov9He6aHE28PQ3WJjZGRkZKC61WNjY2mGp21+
+ kaS2x3d4eH5/gHyWsaW911dXVwAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQB
+ AAB6ACwAAAAAEAAQAAAIxgD1CPwyQUYeB1DACFy4kAYFBg0GGPiB4AhDgSTqGBgw4MWQJVIuVGE45Y2B
+ JChYIFFCZMMHOykWGmEwwEUaHmu6eGmSQEWYhQsiChhKVACGIAsWOhhwJoDTpwHEwHmw8AEQLHQgtIkS
+ IgeeGSPiLLTSwkwGDQnKlIjxRIGQHgudICBzRU2FHWwk6LAx5mKHCCtA3PDBRAEaNxZEXDxhYo4cGHdq
+ UNFSpMCBi1lweODAZYseAgAAWL5I+nPo0aUZghad+uLqgAA7
+</value>
+ </data>
<data name="question" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
@@ -1555,21 +1769,64 @@
BRw2EpGNiOwf0IdolyPBL48SEnGn6e/kAAAAAElFTkSuQmCC
</value>
</data>
- <data name="arrow-270" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_popupscrollup" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB6UlEQVQ4T6WPT0hUYRTFPyYH
- QkkJMpgBNSYEiRY2SiAyFvhnUy0Cy4GeQpS6UDeaiQ4oucqVQiKOWIumRdMgWlHSX7UYXXhdCLpSU2FM
- Z1NYDI4gc7p3cOS9N86qD35c7jnnO+97CoD6H+KXrzzdMXD1WdjLkA6vOZP4aLzANbJlhgY3gP6VGJ6s
- A+yTOWMoKBnaVCaob/kAnrkoHi8dgD0yZwwFF3oXVPHAih56tBBFy4c/6JnfA3uk9yVvKMhr+6ryPUFV
- 2LeUgDxzETS8+YWu2QhYp4QnOcknFZxrn1LnO78raWeofWYXNb51NL4NQXbRxZdcygIxHR0zKr8rSHfH
- 1lAxQKj1r0J20cU/tiC39YuXW0mPO/ADZYOLuOVfg9mTvOEX7M2Tmq3pPTUHd3F9YhvXxn/C9WIThSOr
- KPVtoDIQQsWrEKrfhSE5yRsKWFTZ9RPamfvjdPvbX+T6wkmUT/6G+JKTfFIBmyqrzq9l1r6ksul9ZAYi
- R1z6GIXo4ksuqeDU5Tsq3elWGVXdKsPt09JrnlPBVAyW1zE4Pscgu+jiW20XlRzDC+LK4bGcLVBproea
- 9eYo2T8BMmUXXX+OK7ByIIdxMkUW570HlhvDJFP2Qxw8T6Z6wQk2shgbY0/BadbT9AX/ADWhA8f0EOn9
- AAAAAElFTkSuQmCC
+ /yH/C05FVFNDQVBFMi4wAwEBAAAh+QQAAAAAACwAAAAAEAAQAAAILwAfCBxIsKDBgwgTKvzxQ+FAhgwd
</value>
</data>
+ <data name="icon_viewoptions" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ R0lGODlhEAAQAIYAAAAAAP////7+//39/vv8/gkiTxAwYzhfl4KSqYGRqHuNpnyOp32Pp3+QqICRqLfC
+ 0WCW0q++zqy8za29zbHAz7TC0LPBz/n7/fj6/Ory+PH2+vX5/ODs9OXv9uzz+PD2+u/1+djo8tvq89rp
+ 8tzq897r8+Tv9uPu9efx9+z0+fP4+9bn8djo8d7s9OLu9eXw9uny9+jx9u71+dXn8Nfo8d3s9Nzr89vq
+ 8t7s8+Dt9OTw9uPv9efx9uz0+PH3+vX5+9nq8tjp8eLv9dvr8unz9/D3+vP4+u72+fn8/ff7/Pz+/vv9
+ /f3+/qbQrqfQrnS0fKzSsXS1e3W1e6zTsHe2fHm3fXu5fgB3AP7//v///wAAAAAAAAAAAAAAAAAAAAAA
+ AABZACwAAAAAEAAQAAAIywCzCBxIsGCWAwgTKlyIEILDhxAhFjhgoKLFixcnBhAwYAkSDD9UiCwiIwWR
+ iViYEECS5IeRDzCPpMjAY6ISj1OuqPAho2ePDCh0TCRwBcqVKj4QJFjqoEEHFxMvWDmqAcSDClgtUBCS
+ YyLIKiR7EEFB9sWJHC0mblChwckVIjxMyN2Ro8aNiSquNLkSBQWDBYAV4CAxYqIGKlekxHgRYYJjCSJG
+ sJgIoscTFB1OcKjBeciIIDQmeoCB+WwJG6iBhFgxY2KB17Bjyw4IADs=
+</value>
+ </data>
+ <data name="icon_back_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ R0lGODlhEAAQAIQfAIaKkNjZ27a4vNbe4szS2dvh5M7U29LY39DW3c3T2vP198nP1s/V3MbM09Xb39vf
+ 5PDy9PL09t3h5tjc4cbN097i58jO1dTa4crQ19re48TK0dbb3/Lz9d3i5svR2P///yH/C05FVFNDQVBF
+ Mi4wAwEBAAAh+QQBAAAfACwAAAAAEAAQAAAIeAA/CBxIsKDBDwIOHhQAQGFBAQoaOhQI8YJEhwIiHDgA
+ QIDHjwwpcmCAAEGFDhIeZJiwwQGAAAAgEEhgoGYCAhgsNNAw4OUHAAU8ECAwoKjRoj5hFliwAIDTp08D
+ CFRK4WWAq1ivDlTqc+IHmF29wpTqdSrZshMDAgA7
+</value>
+ </data>
+ <data name="icon_zoomprev" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ R0lGODlhEAAQAIZ7AHBJJai7zuqxd9nFsxc5ZrjH11tgZOnv9CpGdRc2bGV7kpu20IiOlKm1w6u0vKqx
+ wSJEcd7m7UdhgaTF59ri6hgzakFagqC50tfb3xU3Z5yzy1xbXXyQo6q8z7bBza6ytz9Sfc/O1IaKjYSA
+ f2RgX+fs8a7C1Y6XqImXpLrT7WRrchIzaYWUo5qbneLr9Tg3N77L2PT3+auoqOzw9Kamp6jG5JSpvsrc
+ 7s/a5MXa75SVl7e/x250esfS2L7H0UdKTZmirJKfsuXq75y20ISHi2BocNnm8+rv82xtb6a80auvs0Ze
+ gBMzYmZ+odDh8n6QrjhWfM3U2ThUe+Tr8bS3uxY3ajAvLnV5fn98e3ahzJ6quEpMTDBQeZ+fn3CCohg4
+ Z15cWlhYWWd7kxg5b8LQ3aSttoSFiMjQ2P///+fu9SJAcnyPooOGiBY1bM7X37Cura22v5iktBU1aIBq
+ V3qSsCtGdWh8lnh3d6CnrxI0ZM7OzgAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQB
+ AAB7ACwAAAAAEAAQAAAIvAD3CHwzggQWGXFQaBHIUGAXKj5geOCyog6IJQ33tDgTocQBBG2aENkj5gRD
+ Gh+OoIlBh4mFGyx07FHA8E6UGRSmqMljI4eGDXueMAQjJASUKgTGJElR48WeBgyRYEjz4EuFBBAkDPmR
+ kYESF0akyMlgZwIHHhl3mHHjpAcBL1kuFHGQcQ8eNkBMBFmwRoUBPXX3wBERxsqWK2UMABAwIHCBDgVw
+ 7AkAYHHjwA0pW8acubIAzp3ngM5MZk9AADs=
+</value>
+ </data>
<data name="arrow-curve-180-left" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
@@ -1585,34 +1842,121 @@
XgFkNsgAZqghHECaG4j5gVgIiEWBWByIJYFYCgsWoDwzUZKVQXoB+7/02cSOHsEAAAAASUVORK5CYII=
</value>
</data>
- <data name="icon_print" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="layer" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIMAADw8PNjY2GZmZvf396/Azu/v7+jo6P///3Nzczw/ROHh4WptcHZ4fGtzc////wAA
- ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBBwAOACwAAAAAEAAQAAAIjgAdCEQAoKBBAAgEKhQI4IDDhwcQ
- JFzoAICCixgVIIhI0WLGixs5KgwwoKTJAhJTCmSQoKVLBAMMyDQAQGACiA4TxJxZU8BNnAkElCxQAADL
- nxBbbiQKQOcAly5L3mSagKjVqwVulmwaoKvXr1oHNIVKtuWBrS4PEFhL4EDarUdxuk2wIEDBiUehMqDo
- ICAAOw==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABwElEQVQ4T6XS6ytDcRzH8e8z
+ yTMkUUpJLsntP/AP8ERJuSV3kdwe+QvkkrtaybXUMcPmNilmdjEP7IHNZbScmWNnmLtH8/sclvFAR1av
+ zvme832fXRr5/X76D8pu10Ick8sUyoRdNERZbeuQZzrxrlz73iyC79X8G+xgFw1aymxdgyLh7nXP6XnS
+ yoFdNGgpo2UVit23L4Zz4XFNDuyiQUvpzStQ6vI+60/dD8tyYBcNWkpr0kAZ++g6G3+vDnbgvFPq7eKE
+ 1no1pN6/7J03851gPPHOoEFLqY1LUH4mPG1Znb4F2D+75Vg0OmfiuznjRZfE8EVn80yhQUspDYtQcex+
+ 2GShcvvQMzlvdvVxBr6XM0p6pCPmj2s9Ops4gwYtJdWroOqQv9/YsArj7F0H5ozf9LM5QLrHHjCLBi0l
+ 1iqhxuK40ShN/Agz/AnnwTOuS7PO7uHQoKWEag7q9EeiSmV2KQLY11AA5p/nO3ZRhQYtxVfMQgP7ZTUL
+ FteYZO/zGJiDj+wedtGgpZDoZIotmayc3nKssr/o8u6RqP4NdrCLBi1e4WFpuTkR+YNNkQWKDjmwiwYt
+ HhDKRDExf4Qm9B0h5nPvHST9+wAAAABJRU5ErkJggg==
</value>
</data>
- <data name="sql-join-left" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_select" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
+ R0lGODlhEAAQAIZdAOvsxmuAjjRRfpOhtpOitjRQeDVQejtTfDZUdzBMejtXf///1/385///74OTl3WE
+ mu7w81Zhdv384KCuwG+EmZWjtPz72/7+3ISQoeLlyFptkPj5vs3Q1ImYsOPl0ktgg3CBnP/95mp9if//
+ 4NfZ3P//zYKTjKWviv3919/inpuovOTo59DU27e6weTn4P//7KGyxzVRfjVQezJNdlRqgoCQl7/Gzm6C
+ n9fd15adp+PmzNfe0P//97C6y2d7ltXb45mppoqZra2yt+rs7v///5mjuOLjrdLauuzvqmN5jjVSdf//
+ 9NfavlltiGp/nGB1h9nenmBviLq9wrS4vjRQdzNQelhujqGwnOXp7M/V2KWvwfv60+Ln2v///wAAAAAA
+ AABdACwAAAAAEAAQAAAIjAC7CBxIsCDBBDcMKuyioMeEhQVjQPihAuJAAViIZAlisYuMFUt44BhgsYqL
+ Bgxe7CAA0QCXEBIsjMhQYSEVDxdQbGFyBEgHhQV0LABQgsaBD1EUIgBQ48kGBw+ESFGoJIAVH1eMaBiy
+ cAaIKRgoIDFRZKENEl1YRDgBpQmHjjmSpBDRomMXGE60FAwIADs=
+</value>
+ </data>
+ <data name="icon_back" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ R0lGODlhEAAQAIUmABQ1Z7S/z3GFo5TY9aXb8YO37oC06oa78oCz6Ya68Y3B96HF64q+9YW58Im99Xer
+ 4d7s+6TH7t3r+tvp+H2x54Gz6Xeq4Hyv5Xqu5KvP9ajN85fM7eDu/oK27Z/D6KrO9H+y6YG17Hyv5t/t
+ /XOm3KbK8P///wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAAmACwAAAAAEAAQ
+ AAAIeQBNCBxIsKBBEwIOHhQAQGFBARwaOhQoYIQCiQ4FQHDAAICAjyAZUpTQIMGBDB80lIiwwMMGAAEA
+ TDDQoYDNEAYoYLBAYgBMEwAIgEBQYYDRo0Z/xiRwQQSAp1ChBhC49AHMAFizYh249OdEEzG9fo059SvV
+ smYnBgQAOw==
+</value>
+ </data>
+ <data name="document-copy" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAADAUlEQVQ4T6WT+0uTURyHXwz6
- IUgzu1lQUJIilqhBWQRqZlZkaqvUnMIMiw00NS94WUt0DtFlqVPUzOmc2hyjubmL13mZl3LL6dTNrXev
- c+/mZumWBklg5639Bx54+By+53ye89OBdnd3ob2wpzL2MBT1Qg3FFyAQocTq85S63gyAATtYplBtzMii
- rzFBuX33AfHOvBKYI3UNyJZA/lmi/4K4fDj2SRFiLmqwmhv5mzru8NZKGcumTCw2zCWQDRtM0dqYzfFb
- gdh+ibvkRkZkiQwPBKf/CSKJSp976SpzJduq7xhwLLH7HQttUruaUKHntYg25+kd1pXoTJVjVPV90mDd
- lq6sbw+qjfbum8VDyUDgBl1NHG4m0ZbM7X2OBZbUPg8Ei3mNxsESFjqOzTBItEULkaqAgaBfZ9kSwdbt
- vrYRmHEhQ3gd8oviw5VsVNsi3lRhAIEmoXSxp0mwoXzLXR8rY1v7ChuQzwE4waZAgVazRpFS7tRqhVyz
- 3uqbxo+DvCI4O0zxxnKTcEOJ0SqxL9zNn+VVfrTJCt6jfAwae03mdYvzRzCD1jOkOjJDonvVqzQ3eJN4
- qdDZcC5cxlxdquf/mAGlsfJOm+wBZU5IZVtkeU2mHozsmm/T3nd4ds6EsaZKqKVU9Wop3Elj7blnnCTI
- +7a4ObFAhZZ3WkdzGkyCog9myfM3y/0ZDHiooBkVYeCylStR6aPaeqm+vPyT5nWtWEejdCrpZ1I6IqCL
- 0XKfQNyUJY2OKPMaTaKsemNPcSs6EkOeFYEcT6cb5i49mvxZwdF2FXerKZU9mjLmkL7al9iVcSq57TDk
- 6ZsK+d5ojb2G11jwZAR5yTBNU9stEyQ6/CWMqNYG4xccmdWLA92TxpYPg/q63Japd+dT27Pdw3O9D/rH
- QNjaBzhy3AsXcRkn54QQTEhoinknlIAaguMVnBMhZJLHw7oMj8eNhR642ky3sJyk/Z5+QVjH2YVcwOaA
- c3ASpCfgKOAQwNWJO8hjzjPsDlbGOi57/0x7+cpY9y8yIme1LfwcuAAAAABJRU5ErkJggg==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB70lEQVQ4T42SPUubYRSGz+Kg
+ IphFqCAFY4YiWboIUkyLhZjQWhULWVwcNJUgRqpECWazP6DkF9S2UkTqoAjBqnF3dOtQBC1YNOb7+/Tc
+ Dz3yECvkgQteeN735lz3eWlybY3exmKvhZkH6JuIRmlsZQXvGUYnh8nf30aurhYiXArBXLXK18Ui/87n
+ +TyT4V/pNO8kk4w7wWUHaOCg10MmWXiXLZf5TzbLF6kU/7y64rPLS/68t8c4uBdcOoEGvIlEiF4tLYG5
+ XKXCN7mcCUmcnvLXoyNejcfveBEMfv+neKdkAkbCYRAqiMJtoWBCtk9OuBklE/AyFALzJQnISgcI2Rb3
+ ZpRMwPPZWbBQrtU4Lz0gZOv4mG0l7eXjxgYrLp8vKhA9m54Gi9V6nYvSA0K2Dg/ZVmosFxuCNvRpYGoK
+ vK9JQEU0EPLt4IBtJS1XJzmXoqENfXoaCIDluqyrKhoI2Uwk2FbScnUS/CvQhj65x8dBBPuuyxQI+bK/
+ z7aSlquT3JRKDG3oU6vDQT0eT8z8MQgRPu3usq2k5eokaekJ2tDHedzudIY73O4PSp/X+8NW0nJ1EqwY
+ 2tDH6RQeCd3KE79/3VbScnWSvBQN7d6hIRPQeDoblaCDTlAstlOSZ7wjHzr+F3BPydbTZ2jLx71/Ad5i
+ gsnRJ2HiAAAAAElFTkSuQmCC
</value>
</data>
+ <data name="icon_invokescript_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ R0lGODlhEAAQAIUzAKy7zNrf48/Z4bXLssXQ2p6rvMTOzrjHwLDDtLTJsa/Btb3Ttam9rcfR2sDLycLX
+ t8nS277UtrnNs7DCtK/CtrHEtcbS1LPIscHWt8DVtrHHsMHL1LrQtLnJw7bMsrbFwLbMs8DWtrfDz7rR
+ tL/VtrvStbzRtKa5r7jPtLzRtam8ssHXt7zQtMHOzrrPtMDWt7vRtbzStam9rgAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAAzACwAAAAAEAAQ
+ AAAItwBnCJyxAYDBgwg3DJxhEEKAhxADQACwEMBEARgzYqQ4EEAAhCA5CvRIoKRJAgUWGjigQgaFDhYy
+ ohzoAEGCARhSJKjQAuPMGQYQSBgQYMCDBxIqxPx5IMEDokUxrEjQQcBPBSxCQC36wgQFqylnMMhAYmvR
+ DAwIiAirwEWErQsicDhRoEADgQcuLIAKI8aCCx8a3BUYdABRDiNKDEBgYKFABxM0gEDhQcMEB44HrlTA
+ QMGBxpkDAgA7
+</value>
+ </data>
+ <data name="map--minus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACt0lEQVQ4T52ROU8TUACA32bQ
+ H6BxI+qgJqjEwRgHBhMHxcQoCwNLxSJYiiC0QcALRQIFIodURYW0hoKglSuAnGIVbL2g1gMFpAWRiCKF
+ QkA+34txMg76ki9v+b53iohTp8IlR/6D8EMZGUIcTE/X8h9DdRIhDqSmxizLBaw9adzpO0/PQBHuQSvO
+ wRYs/QNk9noxdvs43uxDV+cjttaH8lUnEWK/wRC7tLzMjfYUWgdN9HrN9HnMTAXaeTXzhspxPxkOH+fc
+ kOaEWLsP5atOIsTepKS4hR8/MDcfp95zgfYPBTQ/NfFp5i6Tcw4efx0h58kQ2W/h9Es4VjeK8lUnEWKP
+ Xq8LLC1RVBfHlZZEKjpTsbuy6HhRwMvXFfS+aaTS4+GsY5iUjhH0TSMoX3USIXbHxcX7FxfJr4mh0nkS
+ +8A5LF0neTRaytCUjS9zbbS527CNf8f0fpnE1mGUrzqJEGFabcL0wgKmW0ewOAxUPU3nWmsy99/n4xor
+ Y2z6Di5PtbzKMGWjCxg7hlC+6iRC7NJoEqfm58m7rqW8Kxlrr5GSBj0Nry/SOXQJ9+cKnANljPqdNE9O
+ cLr7HcpXnUSIHVFRSZOBAAUlseTcjCa3MpriRh2XGxO4ft9I1YOzONwlOPvLaXnRROGj5yhfdRIhtkdG
+ Jk/MzVFUoMNiN1LedoJcWzQ2Vxp2d6b82jxqH57H+62Gz7Pd1LraUb7q4kNChNgaEWEYm52lOEePrSqd
+ ivoULlo0WB4bqH6WIb82C+u+UO5uCaZ+23pqNq2T8zauBgV5bwlhFhvDw1O9fj/F2fEU5sRjKowhu0xD
+ tlWDqVpL4T0d5g1rCERF/UGpEE6xZufOMxPyVT/OzPyV24cPUyR3/U1xaCgnVqwYy1QnCAoOPrpq8+as
+ f0V1YeLXWClZLVn7DyhfdeInSrd8PdhgSYgAAAAASUVORK5CYII=
+</value>
+ </data>
+ <data name="icon_popupscrolldown_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ /yH/C05FVFNDQVBFMi4wAwEBAAAh+QQAAAAAACwAAAAAEAAQAAAIMQAfCBxIsKDBgwgTKlzIUCCChxAj
+ SkTwYKJFig4vQiyoESNHiwknLozY8GHDkygbBgQAOw==
+</value>
+ </data>
+ <data name="folder_horizontal" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABLUlEQVQ4T6XUvUoDQRSG4a/K
+ JVh4EXsPVl6FVQrBykJEQZEkrIn/GBSMEIQIoogiFinEFIKgxoiCiGBABTG66MrihpC47B7nExt1txhT
+ PMWZM285AxFBO1BOI1IlA0NJRDDYMo4rqSh+EIjbbErNcaRqWdJ1EohRrMv3/TiOTJjibkvgbP7AM+ts
+ 4svvHWfu2eIwhYxvr4v3VPjDVxdrZVNu94dCscVBAlOetSqth3yoD7UL472uCVuUxjDbelyRxt2SFjZs
+ sTeCbOM+J+5NVgsbtigOY7FeXRDnakYLG7bYHUTu/XpO7Iu0FjZssTWAvHM5KS+VpBY2bLHRj8Lb+bg8
+ H49qYcMWy73YcdRgnya1sGGLvm7MT/eg9B9s1WtATOlQOjWxibX1lPkNfAJSiLGOr2CqXQAAAABJRU5E
+ rkJggg==
+</value>
+ </data>
<data name="icon_select_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
R0lGODlhEAAQAIZYAM3Q1fn58aKpsqKps/Dw56GosrzBxsLGyK6xtujp68jM0fT19bS4vuvs7KWstvn5
@@ -1627,123 +1971,245 @@
AgYTKwZIyICycEMDLAkQlKDwxEdHHTyQVLjQEQsQCFMKBgQAOw==
</value>
</data>
- <data name="sum" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_invokeurl_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAAtElEQVQ4T2P4//8/AyWYIs0g
- iweZAYyMjAxA3AjEa3BgkByKq1E4UAM4gXQPEK8HYh2oGMhgEBskRtAAkGKQIROAeAsQ6yEZokusASBD
- uIB4ChDvBGJ9JENwu4ABCqCKDYD0fiCeATUMZCgYI6cbVA7CACOgwqNAPBemGSQFZIPECRpgAlR0BogX
- gzTDXAWkYeJ4DeAEKlwPxA9x4A1AcS58XgAZIAzEUjiwKF4DyMlUA58XALSICQGuLQH3AAAAAElFTkSu
- QmCC
+ R0lGODlhEAAQAIU4ANrf46y7zJ6rvLXLss/Z4cXQ2rPD1M3Fo8fR2rjHwK/BtbTJsb3TtcLXt8TOzsDL
+ ycTDpbrQtL7UtrnNs7DCtMHWt6m9rqm9rcHL1LHDtrDDtLPIsb7MxMDVtrLEtbHHsLbMs6u8xK/CtK++
+ q6y/ssDWtrrPtLjPtLrRtLzRtLvStb/VtqS1s7nJw8jSz63AtbzQtMDWt7bMsrvRtcHXt7zStcDMz7zR
+ tQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAA4ACwAAAAAEAAQ
+ AAAIuQBx4MAQoKDBgwUxCAxgoKHDhgAMRBSwEKHFABRxBCDAsaNHjhk3AhhJsmSBjCFaZLCQgQOEAzAP
+ ADiJ4wGJBQMq3FjgwYVJihomDAAwoEGDCR5eyjyZYEGDoUQr0FjAgeRJBTBKQCUaI8UImDMFXOiwYivR
+ DhasClBgQsJWBhIivChAl+kGBlBn1GCwgYWAv38daBgwNAIKFQNE2EDAmHFNCh9AnJDxgcIDgZgxO0ig
+ 4IKCBA4yYw4IADs=
</value>
</data>
- <data name="application-search-result" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_viewoptions_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
+ R0lGODlhEAAQAIUAAAAAAP////39/vv7/Pr6+/n5+vj4+fb299DR1M/Q0+bn6eXm6OPk5n6Ejs3P0oyT
+ nM7T2bG3vs/R087Q0vf4+fb3+PX29/T19vP09ebn6OXm5+Tl5uPl5vb4+PT29v3+/vz9/fr7+/n6+vj5
+ +ff4+Pb3987Uz8/W0M7Vz4qgitHX0dDW0OLm4uTn5P7+/v39/fz8/Pv7+////wAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAAyACwAAAAAEAAQ
+ AAAItgBlCBxIsKCMCAgTKlyIEILDhxAhNojwoKLFixcnBgjgwsWHFzBCwhgQIkQBjR0/hhzAsqSIERNT
+ tkgxsmQIAi9hRnCRYuaKAQgkCJWQYASJiQJUpPgZQ0GGpws0kOgwEeTPmwVGaB1BoUOFiSBGskiR1YDZ
+ rhUsTISRYiyKERPiTnBQwoKHiQNOpHg7YgOHvwzsXpgYg4AJrRQqKE7r4cLgCASycu1wwILlxhcwTGzA
+ ubPnzwEBADs=
+</value>
+ </data>
+ <data name="icon_print_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ R0lGODlhEAAQAIIAAJmZmdra2rS2uLe5u7W1vbq6uv///wAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQB
+ BwAGACwAAAAAEAAQAAAIYgANCBQAoKBBAAUEKhQIIIDDhwEKJFxooCFEhwUiUrR4MaNGhRcfShwpcMDB
+ ggMuAmAYkqPDlQRbCoAIwKTLlwgfFsR58KXOmyp/hqT586TRokAN6rTZEsDMggJKGh1A0UBAADs=
+</value>
+ </data>
+ <data name="icon_fitwindow_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ R0lGODlhEAAQAIUzAKq7y6u8zZ+svdbd4dfcztje4tbcyNfcy9Pb39Tc4NXc4MbS2MTR19ne3cTP2MjU
+ 2djd1cDM1srV2sfT2MfT2cnU2tfe4dXd4cnV2sjT2dDZ3svW28/Y3dfd0cXS2M3X3NTb4M7Y3Nje2dLa
+ 38XR19Ha3sXS19ne4NfcytLa3srV28PQ18PQ1sDN1szW29Pb4Nfd4dfczcrW2wAAAAAAAAAAAAAAAAAA
+ AAAIuwABCBxIsOAMAAUSWhgwQEECBCNKaOAA4KBChgoCaNwYoiLChQ0TBCBwwIABAR88whhwwSECByNL
+ CtjgkaUCEC8DQOhAAIUAGR4vJMAJs4EICAJiCMDgUWSAoicaCGghQMADjy9G6hQhNYIEDA8oeEQQ4ACB
+ DkgjqABLYYHHFAEMmBXgtcKDCQs8eNQQVy4BARUytPXAwCOHAFUTZ8BrgkHhgyE+uNggITBeEgxWsPBY
+ sPPAGaBDix4NOiAAOw==
+</value>
+ </data>
+ <data name="icon_tasks" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ R0lGODlhEAAQAIYAAAAAAP////39/vv8/gkiTxAwYzhfl2CW0qG30Pf6/fb5/Pn7/fj6/Ozz+ery+PH2
+ +vX5/OXv9uzz+O/1+djo8trp8tzq897r8+Tv9uPu9efx9+z0+fP4+9bn8djo8d7s9OLu9eXw9urz+Ony
+ 9+jx9u71+dXn8Nfo8d3s9Nzr89vq8uDt9OTw9uPv9enz+Ofx9uz0+PH3+vX5+9nq8tjp8eLv9efy9+Xw
+ 9erz9+nz9/D3+u/2+fP4+u72+fn8/ff7/Pz+/vv9/f7//v///wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AABDACwAAAAAEAAQAAAIuQCHCBxIsKBAAwgTKlR48ICBFxBfGDhAkSKBgwUMINiIoIDHjxeHGAhgQEAQ
+ HwxkcNBhYEOOkAaEGBiwsIcBBy9gAjHg44cCDjFKwDCggQVMmgkUwhBhIAIImAsMyODxYEIDFzYM1FgB
+ k4EBHgtDGFjxASYEAw92wMjxAkMLAyhUwORgwCbCGyBWGLBQAeYDAzBwkAiR94OBCh5gTliokMYJmBJG
+ aIiQYcWFFDModDABk4Dnz6A/DwkIADs=
+</value>
+ </data>
+ <data name="icon_panright_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ R0lGODlhEAAQAIZuAJumsOTY2MS5uK+2vcW5uJumstrOzsi9vOHV1eHU1ZunsuXZ2dve4d7S0aaxvuTX
+ 2ObZ2aaxvePY2NnNzODU0+HT1Ofb2sTJ0c7Jyfjz9J+rttvPztrPzpumsdbS0pqmsdfR0dbS0aSvupum
+ s9zPz9/T08/ExMzFxNbKydfOzdXJyqOuutjMy9zQz8fP1tvPz97R0dLLytfLysG2ttPQ08vEw6Ouucq9
+ vs/Dw6eyvuLW1eXX1+TY1+DW1sa8u+LV1vj09dTQ0NPHx8i/v9fKy+PX1pynsc3BwaSvu+fZ2tTIx+PX
+ 18m9vJqlsNLMzMK4t8zAv9zQ0P///9TR0KGsuObY2Mu/v6CrtqSwu6mxu8m/vubZ2pqmst7T0tXKydXJ
+ yc/Jyca9vcbL0si8u7e9xK+3v5+rt8zDw9PHxtjPztrX1+fa28/S2NTMzAAAAAAAAAAAAAAAAAAAAAAA
+ AABuACwAAAAAEAAQAAAIvwDdCBxIcOAABgUTAli40IibFwEIpACT0M1BNz2gcIAgwIIWNRXd1FhAgMQD
+ AWvOBKl4wkQAAQZ4CNjSpU1FH2iqENjwQEgSCTEqzmgRQAmFCgkWSAhRcUyAJSUo/NgRIE3BI1EQ3JhQ
+ AUECHUUg0CAI4kmDBjhUyDAAw0AGNgMIehiCYoIXFl+IABETwUyZgk6sHDjARMoFDRGwXMmScAqGMC4U
+ jBDhYAWXkG7IFCjQhEoOG5jdICnwoYMCBwEBADs=
+</value>
+ </data>
+ <data name="control" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACjUlEQVQ4T5XST0iacRgH8J/W
- IBFGtEteOtRBL7u4SycbImRYw8IGrR3Nav9gDrbDTpHBW5c22A6NatHB0TKSFbWSTpqtJmOyUMM2h2j+
- yVI0fE2MZ8/zshdcu2wvfPDnw+/5vs9Pf8xkMjFRb29vM+pDln9A+5pZT09PtX6v17sfDochEAiA3+8H
- n+8z7OzsgMfjhe3tT+D1foHd3X1YX/fsY28/MxqN1YZdLhdsbGzA2toarK6ugtPphKWlJVhYWAC73Q7z
- 8/MwNzcHMzMzUFNTY2E4RrVB+I8HewdZd3d3taFCoQDpdBpOTk7g7OwMyuUyVCqVv1xcXAD2DjGDwSDo
- 7OxkXV1d9w4PDyGbzQLP84JisSgolUp/oGDaz9rb2wV6vb7FarWOpVKpc5vNtqVSqV4RWmcymfN8Pi9M
- JKLwjo6OB0yn04lMPp/vG8dxm7fuWLi9YGxxLxRbNN4dHKcaHQmDhOkIHRV7HzGNRiO6j28vtrW1Tbx1
- Be3vPNEV4nCHHVSj3yUajcLx8bEgl8sB9j5mra2toofJZLKI5xp1eL6/D8Tym2Tra2yFavF4HEKhEBwd
- HQloIux9wtRqtagPL0xgampqeYR7OfIjkf34M5lzTbx4baPawcGBcLFoCkITYe9TplAoWGNjI9FMT097
- IpEIPzs767BYLM8IrYPBIO92u4H+oUQiIaBjKJXK56y2tpbhjVKbzebl09NTmJyc3MXbGMaReUJrrVb7
- pr6+fuyyhoYGMwXcxGYnNQ8MDDjxuw4No9HfaH29rq5OIpfLWTUMZBTAUTOGfMBJbkilUnaZRCJh4oN7
- mEwmE4KEACz0Y8g4ft7GTSrUgpqQAl1DV5EMXUFSMYhCKOAXo8sWCvVAT3EAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABeklEQVQ4T2P4//8/AyUYRbP9
+ 3BcMDvNezgTiGJtZTxkspj5gMO67yaDXfolBo/4UVotQBEGagPgMFMeQbABIAxCfmfn0/38QbTHlfgxJ
+ LgApBuIzHVd+/5/++P9/ENu490YM0V4AKQTiM/Wnv//P2vbx/4Q7f/+D+LptF2OICgOQIiA+U3Xs6//E
+ tS//hy++/7/hzMf/IDH1upMx2GILJRCVyg8xAPGZtC1P/7tMOvffeeJZMM7f8/w/SJygATJ5OxmA+EzA
+ uif/TWbeBOOE3a/+g8Rk83cRdoFY2kYGID5jufn9f9klr/577f30H8QXT98UAzKcoAsE4lcxAPEZxR2/
+ /5vs//0fxBZMWB0DMlg0qJuwAdwRixmA+Izq/v//QTRP5JIYHvd6BlZJHQYQIOgCFi1/BraguWdAmNWu
+ LIZZTBOsEQYIGgBUyMFkVbyIySi5BMg2AGINIFYAYgkgZifGABagQjEgloJqEgHSAkDMA8QsBA0gJ1sD
+ AE2BbRvnALnyAAAAAElFTkSuQmCC
</value>
</data>
- <data name="grid" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="gear--plus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAApklEQVQ4T6WTMQrCQBBFZ0+Q
- NljkrjYpU3oKEUFQhBQpAjZewAt4jXX+kpG/3V8S+PAW/r6dKWI5Z9sTSykhR8+5IeiXh0Nw2UQ4y8yC
- KwlkZsHNBZFRYHSrFe40gcw8wZMEMrNgdkFkEhjdaoWFJpCZJ1hJIDMLXi6InARGt1rhTRPIXCbYvs+f
- zGQOweCXH55vQ9AfQtD5ofccGoJ+VwR7fmXc/QGbydmsomqW4QAAAABJRU5ErkJggg==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACeklEQVQ4T6WQUUhTURzGz9zm
+ GNMxJSasHFEbKzZDNmhbESNLRnMPc9pzDCKR6ikaFC1EKBEsCvWhslBovtSL4lNmgskV3IVtbrikpWts
+ Tgx6k9CXf+e7d4VGPXXhx/nz/b/v29lhRMT+BykcCARYMBhknZ2dLBwOS2d3d7eX01PFu38HLzLgQEEo
+ FDrDjb38PIxzb2+PdnZ2aL8Gz18LOjo6zkaj0Sfb29sUiUTuctP1zc0yAczQsIMH3gM38Pv9jHOzUChQ
+ IrFM5XKJZmZmPpdKJQKY8/m8tIMH3mpG/gter5f5fL4jXV1d99PpFKVSSVpf/0LF4lcJzNCwgwdeZNxu
+ t1zg8Xh8XLgFJibG89lshiYn4zmHwzEKMEPD7pcPmd8FTqczKooJmp//QEtLAq2srFBLy6kBpVLJAGZo
+ 2MEDLzIc+QZ2u/3O4uIizc7OEs5MZpVaW539CoWCAczQ9nuQ4cgFVqu13WKx3APDwyMbyWSWpqffJ12u
+ 0zGAGdqFt6Fd1fOmcn3MlECGIxeYzWbW3Nx81Ol0DQmCSHNzH2ltrURbWz8kMEM78cZLV7/fJsX4oYy2
+ z8jYy0a5wGg0gn5BSNHU1DtaWBBpZORFYXk5S+BiPLxri7vJMuGiy9+ukfJx4yYPi2ys8ZlU0NDQAC61
+ tbW/TiQ+kc128qnBYHggCBkCNQ8NlfOVMP0JGzWIUgE+lUrFtFptQKfTDWg0mmM4c7kKf9AiqSL1ScWg
+ PqOI6SuO4jliQ3pR4pFevgHynCYOf1bmAmq1+govGgSYJT2mWzVt2In11aXZcf6LQ3r5DfhXw6nj8Jdh
+ pn/SW/uK9ajT7EbtWDXDfgLZQt8vMfwSKAAAAABJRU5ErkJggg==
</value>
</data>
- <data name="ui_menu" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="globe--arrow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABG0lEQVQ4T53OvYqDQBDA8anS
- iO0VV+YVxCCxt7OyEbnC6hK4T0E4swiGIFgIQQiE+Bq+kVXQRCFIuujcTp7AdeBfbPGbHdhutybvfWIm
- hGG4wolDFjabzWoYBjydTtj3/ejIkAXf99cEH4+HUGTIgqZp6zzPnxccj0c8HA6YZRnu93tM0xSTJME4
- jnG322EURcjPRsYYBkGAy+WSwWKxeC6gEV3AP2egKMrkC1RVZeC67sf9fseu64QiQxYcx/m83W7oeR5e
- r9fRkSELlmV90aNtW6HIkAXTNL+LosApkQXDMH6apsG6roUiQxZ0Xf+tqgpt28ayLEdHhizM53P/crng
- +XwWigxZkCTpTZblvymRBT4z3gvvVTAys38hdsO4G3bw/gAAAABJRU5ErkJggg==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAADYklEQVQ4T32QfUxTZxTGX1td
+ ZgyaLDHoMg1+sAFzkxSVKqYR/IBtBjRZ5nS0cy6KVhNiQIgmfiGFUKgojEFTIGABJ9qNKXUFnPsDUUpp
+ a6VNqVTrFy1YCVDEdBX77NxK4h8mu8kv573nPM/znnsZL/sO4+UaGP/MAOMXPv6QLx/cxC92y4krRMd0
+ lYf63Jx0nD7kI94euIA8RwQNlfHVT8yFt154m2w+/1WHL2gcn/I3Ol95Nze5zdyc070fkKOPmHfS3JJ5
+ 7Yn7sn0Uvb4pNNrGoTKN4vZzP+wBwP4vcNYw4uZ0PNK/2yBDO5snba/NbHngKer0oN3jp4AgGq2j0Dh8
+ 6Bz2o2dsCj2TwO2XQEGn28PpeZwvQ8vYjPSm5JhjOtuPl+5j/1UX6h0vkXfzGY7//QwX+yfwzwhwQuuE
+ mvq/DwFXnr5G5JHrNs43Y5eaArZXlklqTKMptXZsrutHmrofO5qdEGse4kCLC+l195BarkepJYBjlLZH
+ 8wi7SM/5CMZYcpHusHYokFhhxcpSI4RVViSorBBV27C+wgyJxo3crjc41DEJUakJscUGfF1lCnA+ggIS
+ T+uFJ28EN9YOIlKmR1SJEdElJsQoTIiWGyCQmyA6Z8e3mkksym6DQEHhJd1BzkdQwIZTbQlyQ2BJXjeW
+ F/YikgyfTRNFNTK/G2vOObGlcRKLM9vwjQbYrh4OcD6CAjbKfvk8Vzf2adE9RBX3YcVZK2JLrRCct4WI
+ VVgQf96JlfkWJCiHkKQeh6h8YILzERSQovjqI7H6fhyJBMS6iodIUrqQXO1CSs0jbFG5kFjpxOoCM767
+ DohUbsQp7P6IrBtnwjP+oIDUX2ezbcqGqBM93iSlB6l1w9jZ9By7m734+bIXieUDiFfYsaqIfi6d44r7
+ XlcOAl8WWExfyO6mM7bjAmPfNyydKW5uFxRavZLfxnCwxYes1gnkaCcQJzOi7CkgtQFiyzuy+oFlRzt7
+ aQV6wmPoU/KXsp/+bPgkp8uRphock2rGA0daXwWFMuObZdk3pxYc1PnnH2gdCZdq+4RdwAKptnfhob9o
+ A8b4xHwimoWFC9nafXuZpLmW7dN1sIx2fahy71yf5mE7661hPzTcnSu+KKGQ0P08Ys50yMdU/5cP0qpq
+ Zm0t2z3tY/8BOAMvdn6kKfgAAAAASUVORK5CYII=
</value>
</data>
- <data name="layer--minus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="MgCooker" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB+ElEQVQ4T6XSzU/TcBzH8e/N
- TA8QNcSIAZGHiISgGP8BLx7Bg8GYOEQCKBAIAeHk1QtRiI8QlviALiwpY8jGgyMkuIw9MA7sQEEE09g6
- azu3ggie5u9TR5w7kBqWvNJ+u++765ZRIpGg/aDzXW7IYSqYawZhFw1Reec7qAysRie+ab9CsrYT3At2
- sIsGLZ27MwXX5fjOvKBsuY3ALhq0dLZjEsyR2Lbvk/xjygjsokFLZe0TcEOK/vR+jGyOG4FdNGiptM0F
- NezRPby44Uy1KMTt3mX1lTv89alz4UvvSFDsBv9q1IoGLZW0jkHturw1Gxa0UVhYj3Es6h8OiA84/+f7
- Ot9fHl55jQYtnWl5C3UfIpszLLS/X1IGR4LSQ84n9nJ+XY9+xPznWo+HV61o0NLpZgc0LIkb09Nh+SX7
- 1MfD/n88YvMu/T12AxsatFTUaIfbobXvLntA7GOeJeE8dcZ1ffYsKxyahgtVRAW3OGjyrqgOR1Cy7GJf
- wwKYbZcq+aHsXMXG4MidzI8NHMwUrET9lFdngxb2y7pGQ9Jz3XzymJwHTuSq22ZzIl0fUYgOHCum7OrB
- +jeza5PsLzo+t6I60724XCV15xXEdacKtXs5+VqXKUO4iSdgr8OHSisuHrnypO3oVctdI7CLBi1uYGKy
- mOP/CY3pN4OVZi86RL5AAAAAAElFTkSuQmCC
+ YQUAAAAJcEhZcwAADsEAAA7BAbiRa+0AAAHrSURBVDhPhZLtS1NhGMb9T/rQx6ACyUVDyQjDaKAGQYOB
+ Ew2K9ilifrA+LDAMablFb1IM03DbMXMwj4O15VZ5iPly2Go0yzCzF0iwr4OdX3seOxK1owcunofzPPfv
+ vq77nLo6i2d44j0Xb8elgk90rO7VfN80dB13coLmyUFalCMcHjvJ+fBnHkdLu4Psty5wKhZgz9022tUw
+ 9oiHpuQy+1IG7umNnQGdfkV2bA4fq3ZtpCP+EI9u4NAM6mMJDkaDuPoj1pCGgUt/LDfiSYV4sFzGm6/g
+ zBkcGOtj/4gTm/+cNeBqvIBttIeexDDqlwqhjxX6ixVcc1/lHITawn5rwBVlVRa0x4ZoVc7i1V5JBx3p
+ nIwk4wU6rQG+e3m8ehlnMrodxaGOc+K1gS21waHRMzh6B3cepHDRrf2UHe3jp2mZXaf+hcHeRBnxeXf9
+ H4L3Z3HfnOJoyMVxtUSD+ovW55t03SnguzZNOp2xhiws6GjaPJPPXnLDn8Hnn6NvIMvl3qcEApHq2Rsp
+ SxcCUHj7QUrsTaAo0vUSi0vv5JklxCwUl0Wxuf4NE3vLGCuf1rdtii7Z7JZlASoWV1G6uslEpsjlFmvH
+ WFv7wcxM6j8JZ9++bzL/aISV/Ja7mnNYqmY07YouQubg/l1NwG/XLb2y/7oFegAAAABJRU5ErkJggg==
</value>
</data>
- <data name="icon_selectpolygon_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_pandown" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIMLAM3Jzs6lqZ+svcTM083Cx828wdbcyMvSxsTEy8LKxM3DxwAAAAAAAAAAAAAAAAAA
- ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAALACwAAAAAEAAQAAAIbwAXCFxQIIDBgwcHCixIAIDDhwAC
- KGQIEaLEhQEaVnRI4CLFjQA6FhCYcaMABBFHkgQp4CQAhQFYHhAwACZLAzNrrjRpACfNnQ8bCujps2bM
- oBKHJmjZcgFCgwoWCFg6oKpOhQNbXsWK9SfXr2ADAgA7
+ R0lGODlhEAAQAIeDAJhpZZpqZiJNeNikptelprG+zCBPfSJNdyJOfVJvjMybl9Kgn7ShnSNOeCJPea2f
+ nq6entWjojVkl6CBgB9NfjVjlB5OftOnqDJejp1xbp9wbM6cnbWEgbaGhKh3eJBkYbeKh9CdnM2jpMeU
+ kcCNirqIi9qoqZ5ybdOfodSmptenpbuKhriHg6uWkyNQeq59fNakpciYljZklaB1dCtXhTFhkC1Zid2m
+ qdilpJlxbah2cyBPe////9ioqLCRjtCdmrKiotuop8OWkaZ0c3+hvdmhpMyZlipZhkFiirWgnd2prcGP
+ jvXm6TNfjcmdmtShoMKPjoKVs9KanbmTkrqIiaiOjVFwjNulpZJnZqNwcpd0dE9wkGF8mNimpdimp7GR
+ kvfk6MeVlKyfqcSSkd6rqDVjk9KeoqGEgbyWk5emu36SscSUkjFfj8WUkDdlltOaoDJeirqurqOPjiBM
+ eax/f9Ghn8aUkyBOf9yorNympKJybtKeoMOTkcuYlShYh6R/fpx6eL6KjL6LigAAAAAAAAAAAAAAAAAA
+ ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAACDACwAAAAAEAAQAAAIwgAHCRxIkOCBgggNCrTjJcCUKgkH
+ NRgkQoeQKwDIzIhTMIGABBN6BBgxAICSPxAIFhBQ4AwdAgDW4ACAx8kXgi4E5uCQJ0CbAR1upPCR8EOY
+ Lix+vNlj4gKDhBpUwNgQAkURAmgKeohRJ8sSKQvMPIkQRAzBJFiMKHhRQtCYPnzApLFCEAigFVBAkKAS
+ iEmUMn62FGwxJMMJPTzUHKlQgwYShA/kaCFi4E4TCRgsRBzEBQGCOTbcwNk8iA2FHQ4MyAgIADs=
</value>
</data>
- <data name="function" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_tasks_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
+ R0lGODlhEAAQAIQAAAAAAP////39/vz8/fv7/Pr6+/n5+vj4+fb2936EjuDi5YyTnM7T2bG3vvf4+fb3
+ +PX29/T19vP09fb4+PT29v3+/vz9/fr7+/n6+vj5+ff4+P7+/v39/fz8/Pv7+////yH/C05FVFNDQVBF
+ Mi4wAwEBAAAh+QQBAAAfACwAAAAAEAAQAAAIogA/CBxIsKDABggTKlR4kEGDDBAzNGBAkWKCgwsaKNio
+ YIHHjxc/NAjQYMOGChw6dCDQ4IKBkCNLLrzQAEMGmBsaoByw8kKBhzcP5uSgsACGhxpgCmigkoCHCzYb
+ aJgAk2iHhRInPIBpoYHTAgYyHHDQ4AEEmFdpIjwwtQEECjBZGoU49UEDChFgelioMELeg2AhOpiA4K1f
+ CTATKF7MePGHgAA7
+</value>
+ </data>
+ <data name="icon_fitwindow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ R0lGODlhEAAQAIZlAEJyokd1qBU2aPLyl/PzoPj4yvT0rJi2zPn9/O729/L4+PT1rLnS2eny8+fx87zV
+ 26jB1bnT2vr62rHN1e/29/v86cLY3/f7+9Hj5vb2uq7L1N/r7q3L1OPu8PX6+vT1q7TQ2KrJ0qnC1Zm3
+ zObx8/z86ev09Pj8+7/W3PH4+Pz76bbQ2LHO1bXP1+Xw8erz9O319cDY3cHY3vL5+PT5+brT2rTP18fd
+ 4bbR2Nrp7KjH0OTv8arI0szg5LjS2dHi5vb3u9bl6d7r7b7W3OLt8Or09ejy8+z19fT6+qnB1bLO1afG
+ 0PPzn8Ta36vJ0ubw8r3V3OTv8Pb6+tXl6f399q3K07rU2q7L08jd4rLN1cPa373W3Oz19tro66XFz/f8
+ +/D398zf5MLY3rXQ1+v09QAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AABlACwAAAAAEAAQAAAI0QABCBxIsGAZAAgQnJAyAwyXBk+ICOkSBMBBBBc8KKAAI4DHjxgsAviCZOOR
+ BgEWEBgwQEAPkTQUJDBhxIWIAAZWCrghMkUCMg52JAlQIMMCJgK0iExQxEEUCAEqSCgg4IMAFCJfeIRa
+ gooKASMECKghkgROohIqCDggZogVHCI7BCCwAAjVAxa2RFihROSGAAMIGFgrA0qEMVk0iMwBOPDgBwxA
+ sODgROSUAGIzM2gx4UoIHSJ/hMHSJMYDHzYmVOGxxIvIgrAHlplNu7bt2QEBADs=
+</value>
+ </data>
+ <data name="ruler1" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABIElEQVQ4T6WTsU4CQRRFdwnE
- EIkxKBL5BkKjDRQWFljQEwq0pCI2FFT8ABV+gB0dxMrEBAsTowmVxs5f8CvWc/GtWcdZDWGSk3nvvnl3
- Zmd3gyiKgk0IwjD00UafG4q967Sxr3BMww2cQtXitQx6NM1gL23nWE87wYQFV/81q+4ajBHvHGqJvGum
- ZdO6vhPUKd6DZj33hc0d03UvU2j6TqCGS1hAyXmEBvmD8X2hvhNcs0i4t95CewK9oVQD7foIA8dA38HS
- OPvL4ITiC2gONJiHpilW7dwMFH+9hcQYEb9B2bQ+83uiHufSWtKTBnXyZ7j9Yfk7KSCJ1YgNPojFKxzB
- PhRhF3ZgG/KwBTnIQgbC2KBCcgg6+sHaBpv8yur9BCINtCQt9llRAAAAAElFTkSuQmCC
</value>
</data>
- <data name="icon_printablepage" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="arrow-curve" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIZ+ANbn9xExZEtypa3D3q+xyP///6irvlVgfLfH3E5Sb+/w9vz8/fb2+WBedoGPsO7x
- 9pifyZygqWNohGluipiYpPDy9rW91Kusvm1rgd7e6r3D2X2CpuXq8Ors8r/F24qLnfr5/2lviJKexoCC
- oe7z93h/jm1ngn2HpW55jE1Sb/37/FFWdEtQbk9Qb9nZ4dvd6naBm0xTb/f5+k1VfPv9/HeDpfLy936B
- j2xuhnFzh1ldeoSLnYaIlc7Q3YyVsvb3+kpRbVFRc9TZ34yMmJ2iqP78/ZSdxHV6l2Rqgbu90v3//rS+
- 1+zu8/z79+Tn7tjf6ZWdwk9QbH2CmP///tXW6rG2yoiMl3V7kHd4jExSbHZ0i9rZ3mBiirO4zPv7/MjL
- 1LC3yktQbVFQcG15jpqZp295kU1UcObq87SxwqGrxICDqJeeyExRbpmdyllYd8fO4aqrr05Rcmx5mOTn
- 70xTcPz++3V4mLS4xHV4llBQcvz7+amotktSbqGktf///wAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQB
- AAB+ACwAAAAAEAAQAAAI1gD9CBQooKDBggMT+hFQoGFDAQACKIxQAgcWABgBQBwg0Q+RGxRcFNljJeNG
- jibIbCmwQIYKLSYDyAwAB8kULz9sMPkyJOOAnxKv7GBQocMcAjkyYuQoUIICAlAJcJkwxmdHKVANaD3Q
- xUOIpRLpnBhhQM6BAz7s1LnTAADHFkua4IFxIE0GKmeeoHHjNkCQNRZAHHFCAgyKBGXY8AAaxgiENxxq
- ZOHTRoMQHTMDABEB5YWDGUmU6KHxQAwGBKj95EkRIw6LFVV6fEig5oJChVHMbOijMCAAOw==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACE0lEQVQ4T2P4//8/AyWYIs0g
+ ixlUKo+AsVrNcQbt5nMMBl1XGQx7rsOx3dwXDCBsP+/lTCD2sJ75hMFs0l2wOs3GM4QNMJlwmwGkCYjP
+ gPGMxx4kGQByjXHfTZCtZ6Y+/PcfRJtNvOOB0wX6nVdMgZK9QLwNiE8D8RkYrj/943/39d//QXygOg90
+ L3ABBSptJ129nL3nzZu6099+Np//+b/x7I//dae+/68+/u1/4d5P/zO2vP9ff/r7f6DaMxoNpz0Y5Iv2
+ MiiU7GdQKj9U6Tnr+t2aE9/+lB789j9j+/v/Yaue/Pecd+u/84yr/x2mXARj5+lX/nvMufk/fcfr/0A9
+ Zxgks7cxSOXuMDVoOnq57PDnPxl7vvz32fbhv+2G12Bsvf71f4t1r/6brnn1X2v5y/8Ki57/t9709r90
+ 3s4zMvm7PBhEUtaDcG/k8ruvw9c//WjYd+6BUs3B65L5Oy6Kpm88C5Q7A8fb/v6X2fn3P4gvmrrBA2gI
+ AwNv9DIQ3qaYt/kskO7lj13hDsQaQCwIxCxCSWsZBBNWg9ScEdrx/z+I5otZ7sHv3czALq3HwMAspsHA
+ ETL/DJt9RRWbbhADNgBTA1XnwSyuiaJMmNm6eDFQxBgLNgCK6QCxOlDNImaD2HAgWxiIeYGYHYiZQSZx
+ AbE4EEthwRJAMTEgFgFiAahGkHqQZhYgZqI8M1GSlUF6AcIC84BckOgRAAAAAElFTkSuQmCC
</value>
</data>
- <data name="icon_selectradius" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_invokeurl" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIQZAM2vsxU2aKi0ws2TlvLyl86Ym82Xm85ucM5hY85sbs81Ns9GR82rr8bMjs8cHM5c
- Xs8xMaOuhqiXpKiAjc5YWs8bG6lYZM6Bg889PgAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBF
- Mi4wAwEBAAAh+QQBAAAZACwAAAAAEAAQAAAIjAAzCCyAQIEDCBQKCFy48MCCBAMYDEiA4QBDgQceGADA
- kaOBBxYXFliwsWNHAwsUCkSQwKTLCwgWQhjgEkAACQAGQFjogEHNADcZVFiogKbLAA0CTFCwkOVPAkkt
- iCR5lADUAAIaajQZwOrVrBgfRhzQNQJQoAwJGlQQwKyAt2AvCgQaVy5DrHbz2g0IADs=
+ R0lGODlhEAAQAIU/AP///0typRExZG+wPtbn963D3maPxcyZALfH3FWHSGupO3ugdqq+r5iymaDfUY/S
+ S1iORF6fN56xxmKWSj14K5jYTqqRCT95LHy6Ql6PT5Gzh4fKSIPCRY/RS2akOShXQp/eUZ7dUIrOSYLH
+ R1V8IHvBRFmPRInISH+og0mCPpfYTp3cUJPVTIDGRojHR1eNRIPDRYjGR0dzh5vbT6DeUHCzP7jOsU+E
+ SVuQRZvbUHGzQIbLSJPVTZq0sWWkOQAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAA/ACwAAAAAEAAQ
+ AAAIugB//JAQoKDBgwUlCAxgoKHDhgAMRBSwEKHFABR/BCDAsaNHjhk3AhhJsmSBjDJQZLiQQYOFAzAP
+ ADj5o0EKBQNWnFAwwYZJAQxwYBgAYIADBxgmvJR5coECGkSLhgChQAPJkwlizIhaNIcLEjBnCqBQQQXX
+ ohUuXBWQgAMPrh1YwLhRoG5THw+ibhDxwMMHAYABMzAxgGiLETsGvOiBoHHjmhAi6ChRIwKEBgIzZ2aw
+ IAGFBAsYaM4cEAA7
</value>
</data>
- <data name="ui_splitter_horizontal" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="edit-indent" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABD0lEQVQ4T62TsWqEQBCGxwTS
- JFZpEq0sAj6ARUrtbFLlBWzkIHCkFwtfJV1eTUVEBBER5+bfc8WzusNb+JiZ3f3/HWWXmJn2sEuMg/cb
- pGlKWZYt+L5P8zAlHgREwvx6H3Sqg61BFEXa4CiJhjB/lYHehBM1a6HOlw6SJPmS4nAr0KlPiOP4RxKe
- ponHceRhGLjve+66jtu25aZpuK5rrqqKi6LgPM+5LEuedURhGH4HQfB7K9CpDkRInudd4Lou2ba9gHq7
- B7rFwLIs/edVNAwD/K24WDdNkxzHORusxoPkz8K78CHiT+EfEbXwJrwIj1qzNTBk4Wm+OK+zAK1BiBpi
- rOMgNe5zlfe8xLt0cALSyt8vnqRT9gAAAABJRU5ErkJggg==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABjElEQVQ4T5XTS0sCURQH8OOm
+ rVmL1E0UGhRWJqGGBUapQZE9NpWQSBBtg4i2EkF9iXa10srHFJHUWNGDgmhTqyjaRASt293+Z3AmXyM0
+ 8PPO3Hse98oMCSHIYDCwOCQgWbCHcR8OIAVpyIIEW5zDucpPocC/x/IC3LlWV+oNrClcQ6vkHFzR3wEH
+ qMHquLj5TaqFjS+Kxj/+CjQ7Y8Ts7iVlIbb+KSNI6OH1kgL983li3rlTCi8/MXH+8KOL1zlO+w/cMzkC
+ 4RhP+z2zOeqLnMn8rIfXuaFWwB5KELyB4PvO8BG1j6YrdIxlyTl1yM2UHWsFbMEUgWgdTvjtoQyKZWR+
+ Lsfz9pBEXRPH1DN9UrwDCUkStY1I1D15w6qen+cL60qctoNGW4RYvdlLjuAutvcqD0TfRTmedwR2yNjk
+ Ib5030ST1UctrpUKJotPSVSv8gIy3sQ8XMAlXME13MId3MMjkp/hpeYO9L6NkvbFR8C9EUnbNbomEWMt
+ sGBsgDrtCFwAzEVBanC1saTAL88kUjz8yRfZAAAAAElFTkSuQmCC
</value>
</data>
- <data name="icon_panleft_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_panup_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
@@ -1752,82 +2218,68 @@
- AABuACwAAAAAEAAQAAAIvwDdCBxI0A2DAQUTCjQCoGFDNy8CEEgBpuDBgT2gcIAgwIIWNQrd1FhAgMQD
- AWvOBFF4wkQAAQZ4CNjSpY1CH2iqENjwQEgSCTEUzmgRQAmFCgkWSAihcEyAJSUo/NgRIE3BI1EQ3JhQ
- AUECHUUg0CAI4kmDBjhUyDAAw0AGNggHehiCYoIXFl+IABETwUyZgk6sHDjARMoFDRGwXMmScAqGMC4U
- jBDhYAWXkG7IFCjQhEoOG5jdICnwoYMCBwEBADs=
+ AABuACwAAAAAEAAQAAAIxADdCBxIcKCRgggHMgDAQOCLAARSgEE4AMAANz2gcIAgwIIWNQUBCKyxgACJ
+ BwLWnAlCUKSbEyYCCDDAQ8CWLm0GunTjA00VAhseCEkiIUbCGS0CKKFQIcECCSESjgmwpASFHzsCpCl4
+ JAqCGxMqIEigowgEGgRBPGnQAIcKGQZgGMjA5uJAD0NQTPDC4gsRIGIimClT0ImVAweYSLmgIQKWK1kQ
+ TsEQxoWCESIcrOCSUCCZAgWaUMlho7NAJAU+dFDgICAAOw==
</value>
</data>
- <data name="gear--exclamation" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_selectwithin" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACv0lEQVQ4T6WQbUhTYRTHn9sm
- IhbolwWlEqaYTEO2SGcfFiu1ph/UbZ8MxC+9EEUQjQwTkkyioMIFpWIpawVGoUyDTTfTeVfe5e5eTJfT
- llxfNoiSWIUUp+dsLhT61oUf53DO///n3IcAAPkfYma1Wk2qqqpITU0Nqa2tjVWtVqugnNpAsXmHWvQg
- WwKqq6tLqfAMrbuxrq+vQzQahc0z1PwzoLKy8pBer78biUSgoaHhChWdXV5eAgR7nOEONajdckFFRQWh
- nAuFQsBxk7C0JIDZbJ4TBAEQ7IPBYGyHGtRueOK/oFAoiFKpzNBoNM0eDw8874aFhXlYXPwUA3uc4Q41
- qEVPcXFxPKCkpERJBxeRnp7HQb/fBybTk5mCgoL7CPY4w11Ch56/ATKZTO9ycWC328DpZMHr9UJh4f42
- kUhEEOw9zuvAWVQwYb0MqEUPJX6BVCptdDgcYLVaAavP9x6KimQtDMMQRC6TtrpHNfA10gsTQ8fAMW4D
- 9FDiAbm5uWU5OTlNSHu74aPb7YeBgWG3XH7wKvLCpPcHPefhV7QP3ljKhZMnJEb0UOIBWVlZJDMzc49M
- Jr/Nsi4YGRmHQECA1dUfsLLyDdz2OviyfAd0Oh2EF5p/2kwik6OPEVPiARKJBGlhWR76+y0wNuYCg6Ez
- NDnphwl7B0zZtb/XhCYgVL4yexoGjXuF0WfMEfvTjYD09HRCOa5SlRk5bhby8vLvpaWltbKsD2wvdTA7
- Vfd9xlcOg+ZL4OUPwzu2dG3YyDyw9NIHwgvwE4vFJCUlRZ2amtqWnJycjZXnzOB8dRRCARXMT8tjF2Cd
- nz4Ar5/vcA51M6WJADFd7qTQZyVyJCkpqf7aBZGHH82OhufyIfxhH0Q/N8YqEnBmhPsfMl2JgG3UtJ0i
- oexK0NlKOiiuzXTdIFx3G3n76CZhe28Rwx+y4Aflu5kbswAAAABJRU5ErkJggg==
+ R0lGODlhEAAQAIUwAMnY6Ud1qBU2aAEBAYBoKfLyl+Tfi97Vh+nljZeirOLaicjd5Pf3vPX2s+Ldimp9
+ hv7+/vr62lZsif397ENccrvDjs3h54qYhWZ7etjMhdXZkt3Th+jjjMfd48nPjvX0qvPznGp/evn50Nbm
+ 6zVReNfn67/GjfPzou7sj9/s73CBl150eMDZ4M/i6NDi6IGPoP///wAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAAwACwAAAAAEAAQ
+ AAAIlgBhCBxIsCCMAAgTKlyIEIDDhxAhNhxAcYCAiA8nokBgQMBFjBM5ODggAMJHiQEADFCwIYOACREE
+ EJhJAMDEigJEMPgggGPNhhAFNDhRoICAAz9TqqQoAEQBEysoyLSZckCKERYEaAhhlCZVlSVadBDwQECF
+ CwkyVnWxgAUJAC8wFJCg1mHFhwI8nASKMYEAFWoZCkYYEAA7
</value>
</data>
- <data name="icon_search" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_printablepage" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIcAAAAAAP///4CLnpWeriI3WjRJazVKbDRJajVKazdMbcHGziI8ZC1Ne0hadq+3wyA8
- XyZDZEVzpVmDs1WBrTxtnNvu/ydNbo7I+aLV/6TW/43J95rQ+4O32rLg/9nt++Dy/xxGYC9VbabY97Ph
- /dHo9+X1/zRriH/A4L/q/8Dq/8Ps/ylTZLrW4srx/73p98/1/6/h6Wayup7W3Kzf5EyDhiZnYEJ9dmm1
- q63h2h1jWFKmlXK7q4DEtcHu5BtiUY/OvjRyXUeWeVKegi1sU225mESVbFSpeCiLUCeKTanLtRyBOC6O
- SWCxeBF3JqvQsg1yHRB1ICmKNy6OPAVoDCSFLKbKqQRlCQRkCBJ1GBZ5GxZ5HKXJp6THpgNiBgNhBQCq
- AAClAACkAACdAACUAACLAACKAACAAAB/AAB1AABrAABiAABhAABWAAFdAgJeAw+jDw+bDw+aDw+RDzi5
- ODi4ODicOF/CX1+2X2azZmGqYWasZmGkYaDdoKDaoKDUoKDToKDQoKPCo/D68PD58O/37/D38PP58///
- /wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
- AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
- ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAACHACwAAAAAEAAQAAAI6gAPCVQgoAEBAg0EKBDIUOCABCFo
- FAkywQKCAQ0PDYAAREoUGSI2xKjxAOPABEO0ZGECowOGE0hMHFh4SMAKLFR6vFAxIoOGI01ACBDYwMYP
- HC9apHB5AYoVHw0EEhBCZIYLFCU+VCCxhUsSB1I57DDCo8OHL2jTpm0g4UYbN0s8gKHDRxCfOWDAhBHA
- QIeXNmyciOlj542dPmISKzAQQcmVLoHGDIIzJs6gMZg1LqDwZEoVMn/uyLnjp4xphwVA5GBhpg6gQoAI
- 4TljhiHBBg7Q6Natx1AeNBkFphlOfI+hNMEPqVm+fA3zgAA7
+ R0lGODlhEAAQAIZ+ANbn9xExZEtypa3D3q+xyP///6irvlVgfLfH3E5Sb+/w9vz8/fb2+WBedoGPsO7x
+ 9pifyZygqWNohGluipiYpPDy9rW91Kusvm1rgd7e6r3D2X2CpuXq8Ors8r/F24qLnfr5/2lviJKexoCC
+ oe7z93h/jm1ngn2HpW55jE1Sb/37/FFWdEtQbk9Qb9nZ4dvd6naBm0xTb/f5+k1VfPv9/HeDpfLy936B
+ j2xuhnFzh1ldeoSLnYaIlc7Q3YyVsvb3+kpRbVFRc9TZ34yMmJ2iqP78/ZSdxHV6l2Rqgbu90v3//rS+
+ 1+zu8/z79+Tn7tjf6ZWdwk9QbH2CmP///tXW6rG2yoiMl3V7kHd4jExSbHZ0i9rZ3mBiirO4zPv7/MjL
+ 1LC3yktQbVFQcG15jpqZp295kU1UcObq87SxwqGrxICDqJeeyExRbpmdyllYd8fO4aqrr05Rcmx5mOTn
+ 70xTcPz++3V4mLS4xHV4llBQcvz7+amotktSbqGktf///wAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQB
+ AAB+ACwAAAAAEAAQAAAI1gD9CBQooKDBggMT+hFQoGFDAQACKIxQAgcWABgBQBwg0Q+RGxRcFNljJeNG
+ jibIbCmwQIYKLSYDyAwAB8kULz9sMPkyJOOAnxKv7GBQocMcAjkyYuQoUIICAlAJcJkwxmdHKVANaD3Q
+ xUOIpRLpnBhhQM6BAz7s1LnTAADHFkua4IFxIE0GKmeeoHHjNkCQNRZAHHFCAgyKBGXY8AAaxgiENxxq
+ ZOHTRoMQHTMDABEB5YWDGUmU6KHxQAwGBKj95EkRIw6LFVV6fEig5oJChVHMbOijMCAAOw==
</value>
</data>
- <data name="icon_zoom_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="map--plus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIZfAHaFlJ2Sh9HW3Ojt8uDPvuPp79Tg5fP19uzw9O3x9OLo7t3l7PP1956foLa2t52d
- nZ2dnM/R0tPU1ZKSk6SmqPX2987P0NHT1vDz9eDl6b29veTn6dzg5KqsreTo7KKkpsbZ26enqNba3e/y
- 9b+/wJubm7zEy4eHh7rH09Lc5tbY2tfg6M/OzvHz9sXHysvMzsrKypKTk9vd4LGwsKymoP///4KCgra8
- wvDy87q7vdTZ3cvO0MvT28XFxeDj5a2trczT2+zw8+jp6uPl5tTd5uTo683V3Le4ucjKzLa8wcLDw7q/
- w/T2983X4evt76GgoOTq7/n6+u/x9K2vsNjh6dTa4LSzs8vR2fHz9ba3uO3v8c/S1PH09szLy/L09QAA
- AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQB
- AABfACwAAAAAEAAQAAAIqwC/CGRh5cmMLgITAkj4pYcEGRxEvNDAcKFAJT60eDkgxYOOLF8AiBQJI8KB
- GlEYjAgCZQkJgRZ/DKngBAsGBAMUXHkAUyAEHEyKZEiQcwGREwy/hBDCgAvRAgaoAJlgYiSAHBZa4IQK
- IsWNDklVONgwoMCCJiiMfNiS9AsSBy6qrOCRhEKDtgIvHClhI8aUHQ0CEMDbVkAAwYSTGkacOOHiwY0F
- GqYR2bHAgAA7
+ iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAC6klEQVQ4T53Rf0zUdRzH8fdq
+ 1srNWv2R6eZy8x9Hg9babKRTNmd/FG5l9Idbru2Cw8PjBII7EfAHKjI8ZcJR14DidjQOhniB2ImAml2C
+ h07lPH+gB3IHIpMyTpCJPP186s/Wan63xz7/vJ7f7fv9SMqOHclK2jNI/qyoSGRDYaGRZ3h0p4h8kp+f
+ PqdeUH+2gJbevZztryQ4UE9g4ATuK/3s6YlgOxMlyxfF3BrFdCSK3utOEVlvtZpm5+b4viuPjgE7PREn
+ vSEnE9NdXJ28TsNojCJ/lOIgFATA5I2i97pTRD7KycmYefIEpy+LttA+um6X47tg5+7kUcan/Jz7fYiy
+ 82FKb8DOy7CldRi9150i8qHFYp6enaWyNYPvTmTjOpWPt6+E7kvlXL7moud6Ow2hELv9g+R1D2E5PoTe
+ 604RWZuRkRl7/JhDzek0BLbj7S/GfXo7vw1/S3jCw/2pTjqDnXhG/8R+a47sjkH0XneKyBqjceuDmRns
+ P6bh9ltpvFBIdUcuJ28dom+khpEHLfSFmtSnDFIzPIOtO4ze604RWWkwZE88esTBWiN1p3Op77FRdczC
+ sWv7ORU+TPCei0B/DcOxAL7xMXaeuYne604ReX/Tppzx6WnKq0yU/ZDKgYZUHO1mvmnfSu1JG42/7MYf
+ rCJwpY6PfZ+z5GgiX/ZmoTtF5L2NG3PHpqaoLDfj9tqo6/yaA55UPH0FeIN71NUe5Mive4n80UxC2wq+
+ mshVZxK6W1ywQuSdlBTryMOHOMoseBoLcbXlsd9twH3OStPFInW1JSQ1riSuOZ6ElndJGU8jvmU18xxv
+ RqT6NacsT07Oj8RiOEozqSjLxF6RTmmNgdJ6A/YmIxU/mXmrehlJo5/+gzheDcjCxMRdY+qv3pmc/Fdf
+ /LyF+LoP/vL2nVUkuFbxfPHrI2Jf4JSXli7dPD8uruT/eG7bK6OLwnHoU3ey7kXRz8vKG8qi/7T5hVpJ
+ m3dJTOr8u5Onl817ThS42NsAAAAASUVORK5CYII=
</value>
</data>
- <data name="application_browser" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="marker" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACiklEQVQ4T6WUXUiTURiAT3rl
- heBNXQTdCGF2E+1qUIwkiwwsleyHfonUrAhCMTAKE7xINCORgnSslqYNZSmJusrQnH9zttraVkNJdLOt
- uaWbzrH19H1eBF2aLzycc97D8/KeA+cIQGwEkZ+fnypxSqJwnchOqsjLyzttNBqtLpcLp9OBzWbDYvmI
- yWRiZGQEaY+hIZlRaT7B8LCF8XE7PT0frLIrcnJyig0GA319fVKyh+7ubrq6utDr9XR0dKDT6WhtbaWl
- pQWtVotGo0GtVtPY2EhiYmKhfIQi6Q7+K2RX5ObmXo7H48RisX8Ir8YwTC1T1h8kX7/Awbafa6O8lvPL
- 0TiyK7Kzs69Eo1EikchfvnnDFHS6uaB3Uz/qp/XLIp3ORSYXY7z6vsLVXh+FXR5kV2RlZV1bWVkhFAqt
- YZ8LcPL5VyoMs+jsAUyS1Gz7xRNzAKM3gj0K9lVQfw6yufxdm8jMzLy+tLREIBBg3rfAuSYzd3qmuTfo
- oc8TkQr8ptkaoF3qYPBHhLFgjLEwGEOQeNfxXqhUqhvBYBCfz4fug5Ps+wOcb/vK5c5pnjpDVL6b5fbb
- WV44luj3w53XLrRSvmMeEkqNA0KpVJb4/X7cbjeXHvZSrLVwSG3ngMbBUa2DEy9dnG2folg/zRnNJ47U
- j1JniVIuVUso6BwSCoWizOv1MjMzw76SZ5R2z5PRYGVX3QTKx1b2PLGiarSxt2GSc+1ubg7FuWYIo6oz
- s+m4ekSkpaXdktv3eDwoCh6hrHjDfvUc26tG2VEzQXqNmZ21ZtKrx1FUm1E9sHOsPcy20l7E4dpxkZyc
- XJSSklIlIzIqTeti98UmIUWSxBaJretEdpI29JTlb+APrpaoVzbDpskAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABlklEQVQ4T4WSP0iCURTF75Og
+ oWwp+gNurQ0tzq6igyBokkOUhAkqiOZQkyCCW0stQkUukkMUjbUEQpRRS1s0BI6SGoqVdrvH/KQanh/8
+ ON85977jg09iZjKoKEXCpBATDoVCX+GRD3aNM38CWZgT9usOx20nm23wzg5D4ZFj/vsH8f6/INFwue45
+ leKvZHIAPHIpSGgLXpTKd9Lpt24iwYVAgFe93p7CI8dcW/CkVLGbyXQ7sRgvOZ1st9t7Co8cc23Bo1IH
+ rXi8+hmNcs7jYYfN1lN45JhrC+6UCj5brXcfcuX3cHgAPHLMtQUlpaZKJtNpbWOj3g6F2AAeOebagiv5
+ zhdKrZbn58vtSIRb6+sMhUeOubbgnIiEsTOik4rbXW2urTEUHjnm2oKiLIBjouVLi+WhKZ8QCm/MtAV5
+ OdzHfERUaqysMFQyM/LtYTeQOW0KuR+u634/Q+GR49HeoL9DMXnZI7qp+XwMhTeeYQUmWRwXpnfl4Kv8
+ laHiZ4UJYWRYwYgszQgLQaItHIaKXxQswuj/gm+HNTFEuMVJpAAAAABJRU5ErkJggg==
</value>
</data>
<data name="gear--minus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -1847,29 +2299,20 @@
TkSuQmCC
</value>
</data>
- <data name="icon_clearselect_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_null" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIZRAICAgMDAwPn5+fz8/Oru8OPhzubr7e3x8vHw5tPIoObY1b6/w9XYz8XJyOjn0bu2
- p6OmqLe2qcPDyefm0Obl0PH09dfa09XV1bu+wePp6/Dr1tTGxdvd4PXp59/h5d7e3tXV2eDdzOPcwcW7
- l7Sun8S6l7y+v8DP09/Gwsa/qtzf4fDs2czOzP39/dLIoaOqqr2/wPj4+tnc39XZ0eXjz/j5+bSmpLyo
- o5WVldrd3+Xkz9XOz7GvsLiwsM7Pz/7+/unk0NDJp/Dr2ZqbmNbY0Orq07nNy5OZmNzf4sXHydzf49TJ
- oM3Ny9O2sr+1lenu79ne3////wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
- AABRACwAAAAAEAAQAAAInwCjCBxIcKAKIggCRFHIcOFAGQw0iChIEcmMFS6CKATAkaPDHBaEJCiRQiCA
- Ig4oABCohAWQJSMeMNk4QUeBlRg8xIjghMQHASZpFAgBgAOIH1BODLnQwmFHABB2KGhg5IWPARQFSuiA
- 4sYRGFgFKozSccGGJjZMAC0IoMKBJzh49EhSo+DGAwQMrBybFUDeDCuzOiTrcbDgwwQbKs4aEAA7
+ R0lGODlhEAAQAIECANji87HH6f///wAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAACACwAAAAAEAAQ
+ AAAIRAAFCBxIsKDBgwYDKFzIUCHBAAAiSpwY4OHEiwAqDoSIUaJGgRw7ZrQocuTGkiZBovwoIGRHli4x
+ wlz5sKFNhDhzHgwIADs=
</value>
</data>
- <data name="icon_zoomin_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_pan_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIUhALK8xpKYoa+vr7Gxsaurq9jY2LnAxcfHx7W8waq1wOns79bW1rOcjNDc4+Tk5PHz
- 9am80YGYsuzs7MzOz/n5+dfk7PHx8cLK0tPh68fU4ImetOz0+cjV4dLe56Omqfz9/cvLywAAAAAAAAAA
- AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAAhACwAAAAAEAAQ
- AAAIrgBDCAxhgIDBAQUGKgxxYMACCQ8sOECAYCFDBAoeAAgAQIGEAwYWDrDwgQKACB0VOAg5EMGCDRQ0
- Bkig0sGCigIFSACQAMBGCD4BdBAwkMADDQECREi6NEADojkV8PQZAEJPAE9bFmgwoUICjhUwNABxYOAC
- AwsmcPiJIUOBASIRXDgAgWOBBAIOTBA5wIDfCwYEeEBo8YAAAQQEwA3BgEFCi5AJOIYceTLlhZIDAgA7
+ R0lGODlhEAAQAIQAAGtra7/Dy6Smq5KWm9bW1o2Rlri6veTl5q6wtPDx8czMzMPFx5mZmdzd3q6zuqir
+ r/f3+Lu9v52gpcbK0a+yttjZ262trcLGzre7w7u/xba4vP///wAAAAAAAAAAAAAAACH/C05FVFNDQVBF
+ Mi4wAwEBAAAh+QQBBwAbACwAAAAAEAAQAAAIlQA3CBxIUCCAgggHSgAgIWHBhgcbQmgQAQGFBRUObADA
+ sSOABwgWECCwYAEFBQcYbNzQUMDIly8REGDAUKBLmCMxEFBA4KDABwZg6nzJc2CCDAV44hwpk+CBAktf
+ NtwA4YEACVCjTi05UoHMpVMHPBAZdWSBgRU0FLjQVYHbBQU0Oi2QYcKECwEcxE34dMCAAoATEAwIADs=
</value>
</data>
<data name="disk" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -1886,24 +2329,92 @@
L1tJUV/SlAd3xCblH+s4aw2T/BzJAAAAAElFTkSuQmCC
</value>
</data>
- <data name="map--minus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="application_browser" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACt0lEQVQ4T52ROU8TUACA32bQ
- H6BxI+qgJqjEwRgHBhMHxcQoCwNLxSJYiiC0QcALRQIFIodURYW0hoKglSuAnGIVbL2g1gMFpAWRiCKF
- QkA+34txMg76ki9v+b53iohTp8IlR/6D8EMZGUIcTE/X8h9DdRIhDqSmxizLBaw9adzpO0/PQBHuQSvO
- wRYs/QNk9noxdvs43uxDV+cjttaH8lUnEWK/wRC7tLzMjfYUWgdN9HrN9HnMTAXaeTXzhspxPxkOH+fc
- kOaEWLsP5atOIsTepKS4hR8/MDcfp95zgfYPBTQ/NfFp5i6Tcw4efx0h58kQ2W/h9Es4VjeK8lUnEWKP
- Xq8LLC1RVBfHlZZEKjpTsbuy6HhRwMvXFfS+aaTS4+GsY5iUjhH0TSMoX3USIXbHxcX7FxfJr4mh0nkS
- +8A5LF0neTRaytCUjS9zbbS527CNf8f0fpnE1mGUrzqJEGFabcL0wgKmW0ewOAxUPU3nWmsy99/n4xor
- Y2z6Di5PtbzKMGWjCxg7hlC+6iRC7NJoEqfm58m7rqW8Kxlrr5GSBj0Nry/SOXQJ9+cKnANljPqdNE9O
- cLr7HcpXnUSIHVFRSZOBAAUlseTcjCa3MpriRh2XGxO4ft9I1YOzONwlOPvLaXnRROGj5yhfdRIhtkdG
- Jk/MzVFUoMNiN1LedoJcWzQ2Vxp2d6b82jxqH57H+62Gz7Pd1LraUb7q4kNChNgaEWEYm52lOEePrSqd
- ivoULlo0WB4bqH6WIb82C+u+UO5uCaZ+23pqNq2T8zauBgV5bwlhFhvDw1O9fj/F2fEU5sRjKowhu0xD
- tlWDqVpL4T0d5g1rCERF/UGpEE6xZufOMxPyVT/OzPyV24cPUyR3/U1xaCgnVqwYy1QnCAoOPrpq8+as
- f0V1YeLXWClZLVn7DyhfdeInSrd8PdhgSYgAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACiklEQVQ4T6WUXUiTURiAT3rl
+ heBNXQTdCGF2E+1qUIwkiwwsleyHfonUrAhCMTAKE7xINCORgnSslqYNZSmJusrQnH9zttraVkNJdLOt
+ uaWbzrH19H1eBF2aLzycc97D8/KeA+cIQGwEkZ+fnypxSqJwnchOqsjLyzttNBqtLpcLp9OBzWbDYvmI
+ yWRiZGQEaY+hIZlRaT7B8LCF8XE7PT0frLIrcnJyig0GA319fVKyh+7ubrq6utDr9XR0dKDT6WhtbaWl
+ pQWtVotGo0GtVtPY2EhiYmKhfIQi6Q7+K2RX5ObmXo7H48RisX8Ir8YwTC1T1h8kX7/Awbafa6O8lvPL
+ 0TiyK7Kzs69Eo1EikchfvnnDFHS6uaB3Uz/qp/XLIp3ORSYXY7z6vsLVXh+FXR5kV2RlZV1bWVkhFAqt
+ YZ8LcPL5VyoMs+jsAUyS1Gz7xRNzAKM3gj0K9lVQfw6yufxdm8jMzLy+tLREIBBg3rfAuSYzd3qmuTfo
+ oc8TkQr8ptkaoF3qYPBHhLFgjLEwGEOQeNfxXqhUqhvBYBCfz4fug5Ps+wOcb/vK5c5pnjpDVL6b5fbb
+ WV44luj3w53XLrRSvmMeEkqNA0KpVJb4/X7cbjeXHvZSrLVwSG3ngMbBUa2DEy9dnG2folg/zRnNJ47U
+ j1JniVIuVUso6BwSCoWizOv1MjMzw76SZ5R2z5PRYGVX3QTKx1b2PLGiarSxt2GSc+1ubg7FuWYIo6oz
+ s+m4ekSkpaXdktv3eDwoCh6hrHjDfvUc26tG2VEzQXqNmZ21ZtKrx1FUm1E9sHOsPcy20l7E4dpxkZyc
+ XJSSklIlIzIqTeti98UmIUWSxBaJretEdpI29JTlb+APrpaoVzbDpskAAAAASUVORK5CYII=
</value>
</data>
+ <data name="sort-number" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABuElEQVQ4T42TTUsCYRSFJwMJ
+ QWoXCFKEtAhqE/4EN4E7V+nGELUsAyUcUdC9W8Ef4cKtG3+BuJGgtQiCX/iFIn7d7rk5Mg4JCg/nfe89
+ 58yIqKiqqiSTyT3S6bSSyWQcTBCKu9GDHBEpyoEChEJsICjjOFiQSCRuuOSZCenZbDa0Xq8JatzBj5y8
+ QTwe97Zare/VakV6lsslaRh38CMnBdFo9HWxWNB8Pj8a+JGTgnA4/IbwdDqlUqlEhUJBznoqlYrMoZjD
+ j5wU+P3+yGw2o/F4LORyud3ZONN28CMnBV6v930ymdBgMBBSqZRovV7fnYvFopy1HfzISYHH4/kYjUbU
+ 6/WESCSyO2szaLVapVgsJjv4kZMCt9sdxRPb7TZls1ny+XyiuGvk83kKBAJULpdlBj9yUuByuT77/T7x
+ T3M08CMnBU6n86VWq/10u13qdDo7ms0maejn8MGPnBTY7fZbm80WZL70DIdDajQaBDXu4EdOCviiWCyW
+ Pcxm8x2j4rtCcTd6rFbr359p+zGxnjNXzD3zaDKZnhgVijvzwFwzF8wpcvqCE76fbZeXrLZ/wBxh+PBA
+ KfgFcqFa2BgtJlQAAAAASUVORK5CYII=
+</value>
+ </data>
+ <data name="globe--pencil" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAADRElEQVQ4T4WPe0iTURjGz7ag
+ IqIIKrALFV1MC8UoZ3bRNLcuaEV0I82otIwaUSldNdOG84bV1Llp5dTKS3nJ0HWjLMvMSbWhW7ZVeMm+
+ wjkr15A9nfMl0X8d+PF+57zP72EjwmPPiTCumYjOvyMi+cdRIkVXsCi1W0Epp9wbngr+ne4XHMoj+Z6e
+ fhaB4HajQBBA/hYkmmbQEpWv5lOr/OlXrsRod1Sb7K6W/iFHccdPbnVJdyvbL4xRBsjE4tNISECVQPD4
+ T0Fs04xx8a2VsppP3WVtfXhlH0KxsR9qfR8avzjQ5gTafgE5j6o4r72KN4ODgwhxc8u4QkgIEUbXjhbG
+ 6Apkle97Uhp6oOtx0AIXig19qDDZ0dDrwEvbEBo/PsHdmvUY7D6BSSt26sdPc1+iIfQIdpZIPE7WGXfd
+ NGN/tRXXTN+R+LATZx504nr7AB59A7JqbqK8TMrL6txA+MmSLMwT7NDSgo05FyPy9X3SgjasvtqOMG07
+ tpZ2ILzCggOVVsRpC3EpexkvZ2QuR3ReIXbQPPMo9CdIUuqO1H52BioN8MpsgTjXAH+1ASs0Rqy/WI3c
+ /GBeVmSsRGiyEt6pzVibq3cyj0ILAs81iePvu4IKujAnuQnuaS2Yn6aHR7oe4aeigO8mxJ/3RaSmBtOO
+ 1cMnnZanvXAxj0ILAhLq/RXNzpmJLzBb/gpzFHrMG4ZusSkyGBL5LYQU/8B0WT3WVQAbtb1O5lFoJCj5
+ smdcnW1uyhu4p77FggwDvDMN8Mky8ninv4ZvVge8kl7DX/UZknIgSPnexjwKLZCmr5kQrjUvoiEfylKl
+ BatUVkg0VkjzPyBEbUVgTgcWX2jFlrvgmXrglpl5RJJKC0KzR5MNqiL3sy+5VaoehF7txfaSL4gs5bCn
+ jOMnu0uzzDjcCATnmTmW573QbFqwtZCQbUWzRoSX6nzkBi7ihg0HK+04emcAsbUD/GT37ZpObL5u4UZG
+ lulYnvcY/JnsQf9K0iyyu6poauwzU5i6yxZT0e88fueni012n3K0wcT2fI7l/zki+j2RMp+MnSwmflH7
+ SERpAYmqu0eidU38ZHf2zvaEMJvlmccfIWXM8KMbnf+DySzPPPIbH8MN9etvR7oAAAAASUVORK5CYII=
+</value>
+ </data>
+ <data name="drive-download" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACTklEQVQ4T42OXWhSYRjHH4KK
+ iBNkX9AHWx9QeaQuDpTsZgu7CsRJGjIcqyAFiY0xhm7RFqxTdLPoqtjCm+jCPsCwUhtL86O0nRo2zZy5
+ tXWR3qztYuUkfHqfsSOOsdWRHzz+n9//4YV6ZwFWQXB+xwYxUW5ge2E1D47d/FTh+K0xqLs7LWO79/XP
+ 9Y7AvMgym5yTU92B2s5AhQOOEBy9NgJCf4Z4fCe1kLJ6ZlJsfkQZ7cip7qw4cKg7CoevxoDv+yj1vZ/D
+ M4NfkGbKaLfmgf32N7eZ4FtCsoVmUHV/Atl/Sc7JWfaCvW2vQGZPq9988Eoo1Z4o4SVpAQXfPG5zzWH9
+ 8C80RH9jjSOYJKe6UylTuPuyFxQXn5p3tfuT2pEybveWcd2zMqqCZdzR5kvSjpxlB060iECcPH8Djlic
+ sPXCE9hsemDeYnUn66KItcOInMWdpIx25JAr90Cn0y2i1+vBaDTCaZMN9p3rh/WNg+aNLa6xDQyaKaMd
+ OeTKvRUHSCBOnbUA39hZQ9As52sd4AwGQxPD+g+a2Au4ygu0Wi0s0RwOh8cTiQTG4zEMBl+j1/sSPR4P
+ 4znDzwigy/VinPnNcg8EQQCNRkO0lkolLBaLODv7E/P5Hzg19Q1zuRxjgjGNkpTGTCaP5FKHuosfz/Og
+ Vqs7CoUCut1uFEURe3t7sKvLgXY70cMQ0cJ+sVgayaWO/G1iw06lUtnNnjuZzWYxnf6Mo6MfmPwOI5EI
+ I8qI49DQWxwYeDhJLnUY1AUFQ8VxnEmhUIj/A7nUoe5fouy03kA6Jw4AAAAASUVORK5CYII=
+</value>
+ </data>
+ <data name="color" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAC3klEQVQ4T6XSa0hTYRgH8Cdd
+ yyCCBDWLWRARdsE+VhRllCH0LWEYFSZ2wTJ0kIhm0dzy0rIbCGGOXKkLNU1y3nNU1vCSudlxK0bBlpk5
+ 5Ciabu78e/TDTAj60Ic/L+dw/r/zPu85BID+JwvlisdEA8+IPuYTWRIpbOAQKe07g7X2cHmZXb6mzC7b
+ rh2kWGU/HQ8TSEM2qiUztS50lwI3KdZxLdQwWnamf+al0SO9Nfukjle+GUOTZzSppN8RmmMQqCD270AD
+ HXZUK1pmP1eJsD4BjFeBPBWg4jX3MVDajdl7VtGxvqrFRvWHl+zgSQ1FWntWm2Y8jybhLgYsXGxUA3od
+ oHsAaBqAy128fsGM+vukdZXF1ErmyMAIejOlCe4E15xUCkxmAK4iwKYHOqqBmhag/ANQ/BXIFDGX54ew
+ 3+0ykiUtABRaqP7TVOEvN7IwjuuYm+PyeDPg7AZ6HUDbGPwGLyZuAN94cx+Sp37pyFIfAM69JrvVXyJ1
+ 4RJsKIQLTzEJC/yzbkgj05juA4brAOE28C4d6Dzvl1LptT0AHOokZ7O/QKpEGhoZeMPAIAPD+IkfIjD0
+ nosMNDFgZEB/wi8doU5nAIhqpXbtRIq3iHdwh0cohwHNDHRjDL0MtDFQYQTu8wjaVODCwQnvRmptDwDL
+ Kih711CMmMFABnJRhEro0YNqBmom+AwH+Axr+Aw1QNIpIHrDkBhEddkBgNSkkJvkwlHxpDeFR1DxCGr0
+ QgcPdAxorPwVeYSkQmDfMdErW24SiB4qFoF0Iqok5coXEe4D41d8iahFCvpwkYGLDJxlIPE5sDd33Bei
+ eOEmqlYS3V38lblOFM1JD1bK9NGCoksl7h5t9sb7RqR4j0/a0zHqjcrqEmUxeoHkKi5vXags7oBIxtcR
+ nG20aUUcnd5yizQJZsrPdFJOvpMSNWbalnyLQjbH8TM7OGs5sj+BIL6xihPOWfePzL9o/tmgeeA3KbNy
+ RaQn6HMAAAAASUVORK5CYII=
+</value>
+ </data>
<data name="document" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
@@ -1918,122 +2429,77 @@
TkSuQmCC
</value>
</data>
- <data name="tick-circle-frame" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="funnel" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAC5UlEQVQ4T12Q60uTYRiHHzIZ
- HlssW6Em62BQikPE0cyJg6W20h0cgc2gxMAYfVACFbEDJkIRnb4IrukyM1kuJhqK6NJEreHUPDWXEydK
- +g/47dd7Pw1jPXC93Nz377rf531ZSUkJ0+l0zGAwMKPRyEpLSxNMJpNKgE5FCKpVNKMMZckhlz9CC0TC
- MLempqZ2ampqfmdnB1tbWxyqJycn56urq2spIywQ/b9ApNfrr9pstg4S2mbtuDNxDznDWg7V1NvcDMJq
- tXZQVlgg4jcoLi4m8oSBPRAIQDdyA+pvRph+3cb1oIVT6q9E/rSBz/z+VbS2ttrJIZdptVqpxWJpWF8P
- oHioDJfnymDwVUD7wxyG/uctXJq5xjMrKyuoqqpqIJcVFhaqR0dHFp6Pv4bq61UUCQvyJnVhZA1rQOfd
- 715ccBfh2ZeX6OtzLZDLNBqNma5l7q9EgfCG9H4VskcKIB/Mx5nebCR1pmNjYwPBYBDb29s451LyrMfz
- HeQytVpt8Xq9yPiYA43HhL29PSS+T4O4QwbxGxnW1tb4Avq5YqsMiT1pPDs+Pg5ymUqluuvxeJD2QQFH
- wIXFxUXs7u4i/m1KmBxvT0FsdzKOOE7zrNvtBrlMqVTe9HpnYXKU4+RQJl/g8/nC5LiuE4j+lMg53Cvj
- Wbd7DOQyhUJR0NPjWH78+SlSHOchdoRfO7YnGaLBY/tIu0+haeAJbDb7MrksKyvruF5vbJ6ZWcDFTg0k
- Lhlincn8m6OdiTg4lrDPIWcSz0xPz0Kn0zeTy+RyOcvIyChsbHzkmJtbhaJNhbj2o4gclCBi4i9Ux7Yn
- 8JnX60NDw0MHOeQyqVTKZDJZVGpqqrmu7oFzaWkTLQMvcMVqgLhJwqGaektLQdTV3XdSlhxy6RwQiBaJ
- REkSiaRcqcx91dXl8vt8u8LP/Af1aEYZIZtMTshlEUIhEUgVyIyMjFRHRUVVxsTE1Au0hKinHs0oI3A2
- 5ET8AeUdBAROQKmSAAAAAElFTkSuQmCC
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB9klEQVQ4T6WT30uaYRTHj7/w
+ FzLyQnFC4Mgh4hgs9B8QvJH0vxDqJhiDRYMuNsaoi6Cr3bSgaIHMNghrUhmZliwpMXCMGAoyJNzNbnf1
+ 3TkvzxtKNoJe+MDzvDznc85zzvsSALoPWnA6nZ6IRCIZm82WISJhinllNBrnnU7nvNfrfRsMBuei0ejL
+ eDw+zefTelJdkOn1euh2u2i1Wmg2mzg9Pcf2dgWFwjdUKt9xcfEL7fYfXF39BcdP3hBIBaVSCfl8Htls
+ FsvLH7CwsITFxfe8/ojNzR3s7x9DVTAoSCaTJIJOp4N6vY5iscjZv3LgJ6yt5Xld5Yp+4vLytyZIpVLX
+ fdMWsVhMBGPSg0ajgXK5jN3dPays5LCxUeDM5zg7a0P1IJRIJIYKiAVj0sRarYbDwxJWVz8jlztAtfoD
+ qolhroD+J+B4EsnUyUkV6+tfsLVVgZrCE66A7iIQyWMZo0xBjfEpV0C3Cvx+P3k8HjKbzRKsP9cCt9tN
+ Pp+PAoEAhUIhCofDgz3ojxomcLlcpONwOMhqtd5JMKuu8K4/WE8w8CH1V2AwGEjxQgR2u31OsvKEBgq9
+ VSCn+B8QnovAYrHMMDduOUxg4lMPGB/zkJk5OmrAZDLNqr28G2G0Tg8TSJpR5hkzzrxm3vB1Umov7x4x
+ 2l10wT8uhpNvS0oRDQAAAABJRU5ErkJggg==
</value>
</data>
- <data name="icon_printablepage_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="ui_splitter_horizontal" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIZsAO7y9pKaptzi6LC5xtra4P39/f///6qrsqmqsdbX26+xuN/j6O/v8qurs9HT3ff4
- +f7+/qmrsr6/xvj4+bi4vaqrs8TFzqyrs7q9wb/CyL2+w+zs7bW2vO3v8dLT3rW2vcHEzLu7wOrs7cPG
- zfP09crM0/X298/R2sTGyre2vP39/qystNva3sbGycbHy7q9wuLk6fr6+8bJ0eHj6LGxt6mrsejp7Pv7
- +8/Q0bu9w7i4vry8wtrc4N3g5s/Q0vT198PDy729wtvc4e3t77CxuNzd4vz8/M/R27q9xb6+xvb3+L7A
- w7S0vuDg5ayut/Lz9NXV1ubn7N7g5czMz+Tl59vc38DBxMXGydTW3M7R27Cvt7i5v/z8+87O0fn5+vLz
- 9fr7+6yttLi5wMHCx8PEzaiqsdXV2Ozs8aqqscTFyNfX29LT1////wAAAAAAAAAAAAAAAAAAAAAAAAAA
- AABsACwAAAAAEAAQAAAI1gDZCBQ4oKDBggMTshlgoGHDAQACKPSxREcQABgBQBQgkQ0OK1OGFDBzJeNG
- jim6bDBQ4EaBHSYDyAwAhQOEAmC8KKHSIqOAnxI1oIgxwcQXAiEyYuQo8MMEAlAJMBHzwmfHMVATaFVQ
- BMaWpRIjjACSAIkCBSWSFKhCAwDHBj24SMigAAuDMz86sNDiNsAKB1JUSHjygAeGAzkQpAGK4IiDKCRA
- 1EDgYYYIIjMDlMlygoEMJ00gGCnw4AKFBajZNDgQoQKCMEJsuDhgQY1ChWgOkFmjMCAAOw==
-</value>
- </data>
- <data name="layer" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABwElEQVQ4T6XS6ytDcRzH8e8z
- yTMkUUpJLsntP/AP8ERJuSV3kdwe+QvkkrtaybXUMcPmNilmdjEP7IHNZbScmWNnmLtH8/sclvFAR1av
- zvme832fXRr5/X76D8pu10Ick8sUyoRdNERZbeuQZzrxrlz73iyC79X8G+xgFw1aymxdgyLh7nXP6XnS
- yoFdNGgpo2UVit23L4Zz4XFNDuyiQUvpzStQ6vI+60/dD8tyYBcNWkpr0kAZ++g6G3+vDnbgvFPq7eKE
- 1no1pN6/7J03851gPPHOoEFLqY1LUH4mPG1Znb4F2D+75Vg0OmfiuznjRZfE8EVn80yhQUspDYtQcex+
- 2GShcvvQMzlvdvVxBr6XM0p6pCPmj2s9Ops4gwYtJdWroOqQv9/YsArj7F0H5ozf9LM5QLrHHjCLBi0l
- 1iqhxuK40ShN/Agz/AnnwTOuS7PO7uHQoKWEag7q9EeiSmV2KQLY11AA5p/nO3ZRhQYtxVfMQgP7ZTUL
- FteYZO/zGJiDj+wedtGgpZDoZIotmayc3nKssr/o8u6RqP4NdrCLBi1e4WFpuTkR+YNNkQWKDjmwiwYt
- HhDKRDExf4Qm9B0h5nPvHST9+wAAAABJRU5ErkJggg==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABD0lEQVQ4T62TsWqEQBCGxwTS
+ JFZpEq0sAj6ARUrtbFLlBWzkIHCkFwtfJV1eTUVEBBER5+bfc8WzusNb+JiZ3f3/HWWXmJn2sEuMg/cb
+ pGlKWZYt+L5P8zAlHgREwvx6H3Sqg61BFEXa4CiJhjB/lYHehBM1a6HOlw6SJPmS4nAr0KlPiOP4RxKe
+ ponHceRhGLjve+66jtu25aZpuK5rrqqKi6LgPM+5LEuedURhGH4HQfB7K9CpDkRInudd4Lou2ba9gHq7
+ B7rFwLIs/edVNAwD/K24WDdNkxzHORusxoPkz8K78CHiT+EfEbXwJrwIj1qzNTBk4Wm+OK+zAK1BiBpi
+ rOMgNe5zlfe8xLt0cALSyt8vnqRT9gAAAABJRU5ErkJggg==
</value>
</data>
- <data name="cross-circle-frame" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="arrow-circle-135" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACw0lEQVQ4T22SXUhTYRjHXxI5
- LG+UmWNSiAoLvFBJRZhswZHZUNyHU7tRU7ILZXThbpwM+7gQL6OMWiLTE4gfS01DJDJnq6a1dtxaR3Nz
- ExVZBl504+XT+7wcQaMHfjsPz/P/vTsvHGI2m4nFYiENDQ3EZrORxsbGS01NTXoK1m0Z7PW4wwxm0UGX
- /cgHcHSpczgcvWtra5GjoyM4PDxkYB8IBCI9PT29mKEHcP8ewFmt1nqPxzOGwveJCfjscMAyzzOwj9DZ
- wcE+jIyMjGGWHsCxNzCZTMh1uhCSySSsdnSAaDTCL/r8093NSLW3Q6imhu3i8Ri43W4BHXRJXV2dym63
- u3Z3k/CurRV+2myAlWhuPgfOfphMLLO1tQVdXV0udInRaORXVt5HPw6/gC/V1Uw+rW8GAyBny6/Tgd/9
- HBYW5qPoEoPB0IKvtdjZCZLZDNOFhSx/cnICqVQKEokExGIx2NnZgeGsLFgsLmbZYPAroEt4nreLogiv
- KiogUlsLSzQwqlRCKBSCcDgMkiTRe8fBQ2WBMpOXx7J+vx/QJXq9/m4wGITJsjJYr6qCmexs8NLgWXlv
- b4/NkNdqNcv6fD5Al2i12g5R3ICZtluwWlQES/+RT78F3L1RqVjW5/sA6JLKysobU1PezbePn8JcQcG5
- f56jAoIf0vHxMWM6NxeWHg2BxyNsokvKy8vVVqttIBSKwqTJAkJODrvzIhU3ZLBHWaDXw8z6+gZYLNYB
- dElpaSkpKSkx9vc/9IbDMXhZWw9DmZnwiUpRGexxhjtR3AaX64EXHXSJSqUi+fn5Co1G0+J03p+VpANY
- fjYKws1WGFTnMrDHmSTtg9N5bxaz6KCLdYFykeO4y0qlslWr1T0ZH5+Pb2//hrPgDHeYodkr6MguSaON
- kqKhXEtPT+cVCsWdjIyMPsqgTB/OcIcZylXZSfsLjyUbBUyIGBQAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAC1UlEQVQ4T6WSfSxVcRjHf93K
+ HxSNCKNkSGSpKyOMpfVi3aympVvRIhZXhWV3RSuypZmYl1WrvC1RrveX0UVKpXZ0N1Ot3MQurisvYbc7
+ pp6e56j+sP5o62yfne/zfJ/f93d+5xwGAOx/YNuylDyeeQPM5/YQ8707ssrvnkaEpCPtCIeUIBL0LGmG
+ ZmkNbbw4wNY/Xy2NkE+VpHTPKbKUP6YQQK2NbJlW+ReoFRgg+ntAbr/FzvzB0Oy+75mpirm6ZG72HTKF
+ AIE9QA92FQ51e+b2i/48gTDjA3O78VHPK/eTf1bvfExix0zm2ebJmn2Fqma3zN52hEOtjJVP6pI6ZgBn
+ wDuvT4FrLPkjuKb1EBZHyof2S1snYiKr1FlYX9ty/W0AhROoxdjjous0OpyB0Gq1CmsJH+CU3EXYS5o0
+ QadlgxLvjB6pc8qbrZuuKtjGKxwfQJtgT7wj571SUjUE8W1jWlzzgA9wSHzJHC6+sEl4Mu4bcv+zn/2F
+ 50Jb6VNmc76NrYtvZdaxcuaEQRuSOhl6XESFCnAWSPMBNLA2ruUWDnOLoT75VuceM2uE/BMYEN2kAdJ8
+ gEV0A8GFNIzCoUo1T4R8HKhnKWk8Zh5Vz1aHVzKLqHqxe9prZWDZIASVDWjRXzgCmQi3t3oM3IqH4WDj
+ BFCN5BiflDGj0IfMJKxCTL3AymGdV+kICNO7VFgvvETD46UE5103DXuaZ8CudAJIu6R0KKlPkN5dM6pz
+ Lv8KHrVTYBwuUxiFlC18Rv3DRQQX8GwW6O7aqAO7Wh041OvAXT7LQ9q84husr9GBYZis2yC4WLTyaMnC
+ rywwdWTLD9zhfpGqF1zc5pL+SrVZ9kVr3jgP+jXzsKJAozW41KlCT7HMJ0EkMHNkdPEBeFkJtscXCYSn
+ 4lALl5g5+Qs8zlwWBGQ/EohudvGQxh55OOOEmCJLfwcYYmGCrEEs/wFabIAIKOAngC8O+qdBFeoAAAAA
+ SUVORK5CYII=
</value>
</data>
- <data name="layers-stack" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_zoom_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACm0lEQVQ4T4WQ3UtTYRzHn5uu
- pC7CoouyCwmioiih/oLugroRKgi1F6QQGb0oQqHQTYFdJG1gpaBZOnVN3dqrbTu24xrOHffiXs7Zdjw7
- 287Ldvbizui25xEmxzHqgQ/n7ff9ffkc0DFoBw20weebkLv/Ac20NYbBlQHbLWdYXNrJ12y0KFuagb6h
- GTSrXLDXDF9q1JZE8M1SzN2M9ybKZSZ4fUqQrZdfWO/tL6g3bySkEC3WRIqXs40kBTmHxwrpUUPMSeaq
- xkvPzF1owYHm4fkwpbEmi2MmSlAybk/ytoDAkFw1O6IN/9pmK4aLT009+8715nC6UqI4+Q9sqNWhuGoN
- Nstqa4LbZnfTQ18DWGCnvHxBZXwAkAfyMW5mPUGmknHH8qI/Var5ksVdJbFstfZWH83BIPN8inD5kiX9
- uf6VRwB5IB+9N4P76RLrDAuil5JkD1moKAmly/LrxW0OLt3pn/C5PKSkO9u31AuQB/LR4gzupYqMleCE
- tUi+ag/wRTPBST/8nGTczEnuaL78ajaYW49LdO+4F1uL5nVnHuueAOSBfKZdNI5FRHrWnc4tb2TLut9s
- QYkjLJQHp4ksFsmn7n/wYPD6vb13oQ8gD+QzZopjMEh9/pliv7mZyoKHrcx72HKd1ZAgD34hRNicUU1u
- EBOrlPFk98xDgDzgtrkRbXBV582Qk45UVGMhM2pznFOyuM4Ubo9i9LQzETnV89XQ2qlRHb7a1QGQh2WL
- nxme27JPOpIp7TpLzeFpshF7UEgfaAbgBACgBSAPW4DXvjNEp4Zm/I6BKR/ejI+2eEjZfOjoaZiHB3l8
- ssVXrAF+Hv7x2Wagb2hmzxmA9r3m+jlyrbsD+Ry7M/HyX7R2qlUt529ch7nj+2F48xccaJZr1sn7YAAA
- AABJRU5ErkJggg==
+ R0lGODlhEAAQAIZfAHaFlJ2Sh9HW3Ojt8uDPvuPp79Tg5fP19uzw9O3x9OLo7t3l7PP1956foLa2t52d
+ nZ2dnM/R0tPU1ZKSk6SmqPX2987P0NHT1vDz9eDl6b29veTn6dzg5KqsreTo7KKkpsbZ26enqNba3e/y
+ 9b+/wJubm7zEy4eHh7rH09Lc5tbY2tfg6M/OzvHz9sXHysvMzsrKypKTk9vd4LGwsKymoP///4KCgra8
+ wvDy87q7vdTZ3cvO0MvT28XFxeDj5a2trczT2+zw8+jp6uPl5tTd5uTo683V3Le4ucjKzLa8wcLDw7q/
+ w/T2983X4evt76GgoOTq7/n6+u/x9K2vsNjh6dTa4LSzs8vR2fHz9ba3uO3v8c/S1PH09szLy/L09QAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQB
+ AABfACwAAAAAEAAQAAAIqwC/CGRh5cmMLgITAkj4pYcEGRxEvNDAcKFAJT60eDkgxYOOLF8AiBQJI8KB
+ GlEYjAgCZQkJgRZ/DKngBAsGBAMUXHkAUyAEHEyKZEiQcwGREwy/hBDCgAvRAgaoAJlgYiSAHBZa4IQK
+ IsWNDklVONgwoMCCJiiMfNiS9AsSBy6qrOCRhEKDtgIvHClhI8aUHQ0CEMDbVkAAwYSTGkacOOHiwY0F
+ GqYR2bHAgAA7
</value>
</data>
- <data name="images_stack" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_selectwithin_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACAElEQVQ4T6WRXUiTURjHz03o
- lK0EE1SwL9JCvJj4dZF14S5sMEVJB13YRYiitpjKbt7cuhGxZJDlLoKapkwqxUVRM9YkEwTPhR8QTENE
- /ID0ItLEhrp/5znqcFim+MKf83J4nv/v/fEyAOw4YSVWK7vR0LD3NIi7ikPGEFZQYrOxIkWpFF+E4H9C
- MzS7j1ysKK5+zvH86bV/5pUzA5vBIAwWS5UsOCr5hVOH31tbuG4211CBdN4l6x9wFLRwFNs5DA85bj7m
- uOXguNfN0ebxS7KrS49fGxvQVVebjuTc+WlEkjvaC/EjEMDV8nIzIw9qHe2N/UtOh+5o5uXAsCQ3N2Vh
- eX0dOWVldYw8qHWs7yz875Mw+WE7Ux/PYHrgPL55z2HSkyTJLq9Pku+atFhcW0O60Whh5EGtt3VX4LRl
- YO7zJcwPXsbyRDYCK0b8nNFhYShVkq2vvZLscLuxJIpS9HqFkQe15iYmoiAtFfY76ehpyYR/uFT86Uas
- fDdhdjBbkmvb+yX5Yn6+75RW26hOTq5g5EGtbnuUSDTePlLjXasGX1wxWPiagHFPHHzPToaRL+TlNTPG
- EkRUjDyo9UltZChtdSo476sw9EaN3tYoOOoj95FPaDRiXzzkQT7zq6sHhmbCyNvrjJEH+RwmNBsi7xaI
- M0IkfseJvA6Kas+efP0DD+tcAk1PV7wAAAAASUVORK5CYII=
+ R0lGODlhEAAQAIUsAOjs8K+6x5ScqICAgLSun+zs1uPhzs3Q0ujn0ebr7ebl0O3x8uru8O7u2OLj0aet
+ svj48Onu79rbzd3ezre8u/7+/vHx4cTHy/H09efm0LW6usXIxOXjz7e8vrC2verq0/b27LG2t+Pp6+Xk
+ z+7u2qKpsvv79+DdzPDv3fPz5LzBxtjazf///wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAAsACwAAAAAEAAQ
+ AAAIlQBZCBxIsCCLAAgTKlyIEIDDhxAhNhxAcYCAiA8nfkCgQMBFjBMzjDAgoMJHiQEADOBg4IQAExAE
+ EJhJAMDEigJApEAhgGPNhhAFWCBRoIAAAz9TqqQooEEBCSEeyLSZcgCGBREEOKBglCZVlQsYJBDQQcCK
+ DQcyVhUrogSACxoKeFDrsOJDARNOAsV4QIAKtQwDIwwIADs=
</value>
</data>
- <data name="sql-join-inner" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACZ0lEQVQ4T6WTW0jTYRjGPwy6
- CGrJKrDALooSSaQjdRERnQk6QAeN0gvFIiGZMRdouqRYjC1M3SZmZqnVTjh1Ot3MtTLdFLWRzrb+Oufc
- Wtsa22xBEKzvkQndb/Dje3ne5/fu6k/i8ThJhqRk/DHJvqsju7n9ZE+ZnrWXZzhIOU/JxXum0noO/J+h
- gy4cuCsH0k8/NN2QD7ulrsDvvkD0z0T7QGioUOCPAMzIsEMHXXogfeUA60S1MX/aHVEtBGOD8/6Y/tNU
- 2HytgolK1CEXwIwMO3TQhUMPsEgWp+dw6wen1OmPGRjfLx0tDZSIppwl4m++dkPUBjAjww4ddOHAJZl3
- unJmFqNaW4K5HzHjgVxdRNjmnXmqDg4JXvsN9xtdY/tzdGHthLeu7aPrkdqyKBq2B1/BJTuLO4roVdPn
- +XAH+OqJ6refUv4VKwKm8ufeLiBSBN4j0457G6R6plLaz1T1Tn5vhEu23VTmjc+FNBbmp0o36WvSjHpk
- GWc1EW69c/Rek6cbYEamHHHX1/Q4+DW9Dr7a7JbAJVsL3pys1doaO8c8TaIue3WDflZ4gTPiuML7slDe
- 7NUBzMiwE3baH0j6mMf8t5NP4JIt+a3sXcWK0pfG2Tpxt11QrZrmi1WM/NB16xJXsmgFmJEt72gH3czb
- cg5csjb7Ikk9zsvYUdTO5bVYapsHZ2Uqs7uFK2HeHSlYWAKYkb2gO3TQhQMXv1WUDavTsvaxjpXlsS9J
- StlXn1WwL8s4aUerbgHMyxndoYMunIRLUuiwJhFspm8aZSNlPWVdglT6bkrs0IEMJyX5jymZTxnuP42L
- XZ3g33aHAAAAAElFTkSuQmCC
-</value>
- </data>
<data name="edit" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
@@ -2047,91 +2513,18 @@
QmCC
</value>
</data>
- <data name="icon_buffer_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_invokescript" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIQAAIyJk6y5xWibx7PN4423x/D1+cXHx3Ghy6PC3ZW9x4Gr0LXHx57Bx5S1xb3Hx7a/
- xqDCx////wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBF
- Mi4wAwEBAAAh+QQBBwARACwAAAAAEAAQAAAIiQAjFEBwQMGAAhESKlw4IIGDBQkEKCwwQIFBhAoWBABg
- gIDECAISLICIIEJGACg7ChBAwACAAA4ORGjoMqWBmygBLFAgkGVNjj8NJBig0GfOnCoRFsWJ1OPChAKY
- cmzwcWHIoBGfFriKNOvTAQywVl2oQOxThWUfcPR6diaEmxDGnh1Y8GDbhAEBADs=
+ R0lGODlhEAAQAIU6AEtypf///9bn92+wPq3D3hExZKq+r3ugdmupO1WHSD14K7fH3Jiymb7M37HMxlmP
+ RFeLTVyTSVuQRY/SS6DfUZjYTl6fN1iORJ6xxny6Qn+og4jHR5vbTzJpMpvbUIjGR3Gad4/RS4nISHvB
+ RIrOSXCzP5/eUaDeUJ7dUJPVTYfKSIbLSIDGRnWPsoLHR2WkOT95LD11Pp3cUJPVTIPCRZ6+rIPDRWak
+ OZfYTnGzQAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAA6ACwAAAAAEAAQ
+ AAAIuAB1CNSBAYDBgwgxDNRhsEGAhxADNACwEMBEARgzYqQ4EEAAhCA5CvRIoKRJAgUWGjgQAwYEDQ4y
+ ohzIQAKCATJEIIhQA+NMHQYkZBgQYAAFChkixPx5AMEJokVRmECgQcDPBB84QC3qYQMEqyl1KKiAY2vR
+ CgoItAibgEaKrSFm2OhQoMACgQdeTICqgsSEGyAW3BVo4MEAoixcrBjwwMBCgQwuWMgxooSFCwweD1yZ
+ QEGCA441BwQAOw==
</value>
</data>
- <data name="icon_tasks_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- R0lGODlhEAAQAIQAAAAAAP////39/vz8/fv7/Pr6+/n5+vj4+fb2936EjuDi5YyTnM7T2bG3vvf4+fb3
- +PX29/T19vP09fb4+PT29v3+/vz9/fr7+/n6+vj5+ff4+P7+/v39/fz8/Pv7+////yH/C05FVFNDQVBF
- Mi4wAwEBAAAh+QQBAAAfACwAAAAAEAAQAAAIogA/CBxIsKDABggTKlR4kEGDDBAzNGBAkWKCgwsaKNio
- YIHHjxc/NAjQYMOGChw6dCDQ4IKBkCNLLrzQAEMGmBsaoByw8kKBhzcP5uSgsACGhxpgCmigkoCHCzYb
- aJgAk2iHhRInPIBpoYHTAgYyHHDQ4AEEmFdpIjwwtQEECjBZGoU49UEDChFgelioMELeg2AhOpiA4K1f
- CTATKF7MePGHgAA7
-</value>
- </data>
- <data name="printer" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACYklEQVQ4T42SX0hTYRjGX1To
- omIggdDVLvJi5o0IJjrI5ZgtNuG4KVsodtPZGSNScirHzY2mTIQSDPVK8MKBN6JSyVTUGAkTuqyLBInU
- iQRZ+OdChz5978nBxJTew+/84/c853zwkbO7mzLUh0J2gXwJdxzBIEldXecgfpmF51c6jdTBATb29/F9
- b09jJpGAcDyCwgsFkqpSFsrvoyNs7O7i684Ovmxv43MqhdjsLHiEp1hbW/UmRSGmzuMhcjgcVCfLVNvR
- wXj3j4/xQ3w1u+TN+DgyFFqtAQE9qK/XstrJ6XSSo6mJbG1tvgNR8PPw8EIJ/wkvhx12tcxZQY54sAs8
- eXl5r/x+P66CHXY5IwpySJKkW6qqhnbEmhVFQSQSQTAYvEAgEEA4HNacra0tdHZ2hjhLNpvNMDg4OLa2
- tgaXy4X29nbIsozm5mZIUh2qq82orDSirOwerNZHmjM3t4yent4xzlJNTU3V5OTk8urqKsxmswh7YLFY
- YTRWieD9c5jNDzVnZmYBAwPDy5wlk8nkSiaT60tLSygpKUFDQ6OQ7P/EYqnVHFkcExPv1zlLFRUVz+Lx
- OGKxGPR6PZzOJ7DbH18KO6Ojo5iamgJnqbS01J9IfMT0dBw+33P09w+jr28I0ehwFiPi/i9ebysWFj5p
- cJYMBoO6uLiC+fkVuN3u/yJTwFnS6XQt+fn5vUxubm5fSmyY6mgKr9+mMPTuAypfuHG3UYXRO4Jvm5tg
- J+NzlsTcFNxmCsrLX2qbPmtOTk/BpE9OkBZXdjL+WZY7iK4VFNCN4uKn14uKolfBDruZ+QOvqgI74xfB
- qAAAAABJRU5ErkJggg==
-</value>
- </data>
- <data name="icon_viewoptions" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- R0lGODlhEAAQAIYAAAAAAP////7+//39/vv8/gkiTxAwYzhfl4KSqYGRqHuNpnyOp32Pp3+QqICRqLfC
- 0WCW0q++zqy8za29zbHAz7TC0LPBz/n7/fj6/Ory+PH2+vX5/ODs9OXv9uzz+PD2+u/1+djo8tvq89rp
- 8tzq897r8+Tv9uPu9efx9+z0+fP4+9bn8djo8d7s9OLu9eXw9uny9+jx9u71+dXn8Nfo8d3s9Nzr89vq
- 8t7s8+Dt9OTw9uPv9efx9uz0+PH3+vX5+9nq8tjp8eLv9dvr8unz9/D3+vP4+u72+fn8/ff7/Pz+/vv9
- /f3+/qbQrqfQrnS0fKzSsXS1e3W1e6zTsHe2fHm3fXu5fgB3AP7//v///wAAAAAAAAAAAAAAAAAAAAAA
- AABZACwAAAAAEAAQAAAIywCzCBxIsGCWAwgTKlyIEILDhxAhFjhgoKLFixcnBhAwYAkSDD9UiCwiIwWR
- iViYEECS5IeRDzCPpMjAY6ISj1OuqPAho2ePDCh0TCRwBcqVKj4QJFjqoEEHFxMvWDmqAcSDClgtUBCS
- YyLIKiR7EEFB9sWJHC0mblChwckVIjxMyN2Ro8aNiSquNLkSBQWDBYAV4CAxYqIGKlekxHgRYYJjCSJG
- sJgIoscTFB1OcKjBeciIIDQmeoCB+WwJG6iBhFgxY2KB17Bjyw4IADs=
-</value>
- </data>
- <data name="color" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAC3klEQVQ4T6XSa0hTYRgH8Cdd
- yyCCBDWLWRARdsE+VhRllCH0LWEYFSZ2wTJ0kIhm0dzy0rIbCGGOXKkLNU1y3nNU1vCSudlxK0bBlpk5
- 5Ciabu78e/TDTAj60Ic/L+dw/r/zPu85BID+JwvlisdEA8+IPuYTWRIpbOAQKe07g7X2cHmZXb6mzC7b
- rh2kWGU/HQ8TSEM2qiUztS50lwI3KdZxLdQwWnamf+al0SO9Nfukjle+GUOTZzSppN8RmmMQqCD270AD
- HXZUK1pmP1eJsD4BjFeBPBWg4jX3MVDajdl7VtGxvqrFRvWHl+zgSQ1FWntWm2Y8jybhLgYsXGxUA3od
- oHsAaBqAy128fsGM+vukdZXF1ErmyMAIejOlCe4E15xUCkxmAK4iwKYHOqqBmhag/ANQ/BXIFDGX54ew
- 3+0ykiUtABRaqP7TVOEvN7IwjuuYm+PyeDPg7AZ6HUDbGPwGLyZuAN94cx+Sp37pyFIfAM69JrvVXyJ1
- 4RJsKIQLTzEJC/yzbkgj05juA4brAOE28C4d6Dzvl1LptT0AHOokZ7O/QKpEGhoZeMPAIAPD+IkfIjD0
- nosMNDFgZEB/wi8doU5nAIhqpXbtRIq3iHdwh0cohwHNDHRjDL0MtDFQYQTu8wjaVODCwQnvRmptDwDL
- Kih711CMmMFABnJRhEro0YNqBmom+AwH+Axr+Aw1QNIpIHrDkBhEddkBgNSkkJvkwlHxpDeFR1DxCGr0
- QgcPdAxorPwVeYSkQmDfMdErW24SiB4qFoF0Iqok5coXEe4D41d8iahFCvpwkYGLDJxlIPE5sDd33Bei
- eOEmqlYS3V38lblOFM1JD1bK9NGCoksl7h5t9sb7RqR4j0/a0zHqjcrqEmUxeoHkKi5vXags7oBIxtcR
- nG20aUUcnd5yizQJZsrPdFJOvpMSNWbalnyLQjbH8TM7OGs5sj+BIL6xihPOWfePzL9o/tmgeeA3KbNy
- RaQn6HMAAAAASUVORK5CYII=
-</value>
- </data>
- <data name="icon_zoomin" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- R0lGODlhEAAQAIZeAEV2qAE0Zm1LJt7s9eqvdrK8xtfk7LOcjF1dXdDc45i101lZWaOmqX+AgF9fX4ep
- xc7b57GxsY+Rk3JycnyWsWNjZK+vr1xcXMvLy19hY2mGp6urq2SHreXx96C61YGYsnFxcc3a5lpbW3p6
- enmTsGVlZcfU4GNjY2ZmZnt7e6DP4X5/gIuLi5Kov21+kXplTnF3fJOluFJrhfz9/Wlpaaewuam80brK
- 28PP3bGai5qzzsHP3ZvO4prU5WJjZImetJyvwbvJ2FtcXYCAgIeNkkZJTFlZWsfHx2RkZG5vcJGkuIWF
- hWdrb+Pv9dLe546QkZuxyYeHh8jV4WNobLnAxez0+dPh63d4eLW8wZKYoVdXV25ublxdXnuFjwAAAAAA
- AABeACwAAAAAEAAQAAAIsgC9CMQw4oKWBTQiCFy4MEoJBgkGGKDSYAJDgUuuGBgAIAAAKxAkDGF4BImB
- GVU6AgghBccKCwtTMBjQoYlKEztu1ACx0EECAEBVBrXhYOGCAQGSKlXqAcFCBE6CCgUK5cTCLViAKAmi
- UgUPBVlYLNzQIMaPFip7PNBR4SIKGB9IqFQgw8eTHBeTTHGhgQOFLlyKvCBw4CKRDCKMCGHipYAAAYQv
- Sm78OPJkho4hX76YOSAAOw==
-</value>
- </data>
<data name="clipboard-paste" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
@@ -2149,48 +2542,6 @@
CBL/g/dyjRT1G7y5F+bDPK+HAAAAAElFTkSuQmCC
</value>
</data>
- <data name="icon_panup" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- R0lGODlhEAAQAIeDAJhpZZpqZiJNeNikptelprG+zCBPfSJNdyJOfVJvjMybl9Kgn7ShnSNOeCJPea2f
- nq6entWjojVkl6CBgB9NfjVjlB5OftOnqDJejp1xbp9wbM6cnbWEgbaGhKh3eJBkYbeKh9CdnM2jpMeU
- kcCNirqIi9qoqZ5ybdOfodSmptenpbuKhriHg6uWkyNQeq59fNakpciYljZklaB1dCtXhTFhkC1Zid2m
- qdilpJlxbah2cyBPe////9ioqLCRjtCdmrKiotuop8OWkaZ0c3+hvdmhpMyZlipZhkFiirWgnd2prcGP
- jvXm6TNfjcmdmtShoMKPjoKVs9KanbmTkrqIiaiOjVFwjNulpZJnZqNwcpd0dE9wkGF8mNimpdimp7GR
- kvfk6MeVlKyfqcSSkd6rqDVjk9KeoqGEgbyWk5emu36SscSUkjFfj8WUkDdlltOaoDJeirqurqOPjiBM
- eax/f9Ghn8aUkyBOf9yorNympKJybtKeoMOTkcuYlShYh6R/fpx6eL6KjL6LigAAAAAAAAAAAAAAAAAA
- ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAACDACwAAAAAEAAQAAAIxAAHCRxIcKCLgggHFhBQQKAdLwGm
- VEGYQECCQSJ0CLkCgMyMOAUbCJzQI8CIAQCU/IFA8IDAM3QIAFiDAwAeJ18GuhSYg0OeAG0GdLiRwkfC
- D2G6sPjxZo+JCwwSalABY0MIFEUIoCnoIUadLEukLDDzJEIQMQSTYDGi4EUJQWP68AGTxgpBIIBWQAFB
- gkogJlHK+NlSsMWQDCf08FBzpEINGkgQPpCjhYiBO00kYLCQUCAXBAjm2HADp7NANhR2ODAgIyAAOw==
-</value>
- </data>
- <data name="globe--plus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAADV0lEQVQ4T3WPf1DTdRzG327K
- 5WnY4RWnZ51pU0AvuXUlanJNVDDvILs8y5MpWaDmxWkCd96pSQgxmGBGOgc7ajBtuo7MdfxQ+wM1xmAT
- 227MpjOSTVwEDLG1cI/vz+KuP7y+d697Pt/353me7/tLkn0/k6TIStLPfiVp2W9PSVX9q6UVPhVzjmmb
- UFV0Lu7ZJ/zRHPPvQRQUu+fypWZpbZ+97MofAYMzGDrvDka6R8ZDjZ6HgTUGn13cC9+TBYWWuTMO2Zvy
- f+jznXUNoSs4jkbnCLS2IVy7H4IrDLj+Bo5aB33CJ2H/fxvkmadKdrXq8ptu+cvb/Wj1h7gggkbHEEzu
- INoHQugcHkfnGHDtAVDa7vMLv0Tk8sxEk7YY0pP2Nzu3fnsTO8578bX7AYov38WBS3dxuncUPw0CB80e
- 6Hn+3T3g3O//QFbwo1PkJm3Wc8GGE18o62xDGToX1tT3Ikvfi01GD7JNt7GzyYst9TeQedyCqp4w9nPb
- +6Y72Mx+kWOIKL28eY/5XlhR48CSqm6knHRghdaB1FonXq+xQ2nyoejqI+xuG0NqlQ3JFVa8edIWFjmG
- CxSHLSmHLkbSdP2QHbEgobIbiZU2JKltSFRZIVfZkFrtwjumMTy/rwVyNZdXdkREjuGCNz5tWaGyhl8s
- 7sBLZV2QcWDhBAmsspIOvFbtwdrGMbyQ34L1JmCDfiAscgwXpB35clFR8/CC8htIqPgFi486kFzlgPyY
- M0qyugdLj3mwpKQHM7U5iDWuxizdtpDIMVyQoV4Xl62/+Qqb5MzymttYpfEivdaLjLo7WKv1QnHCg1dL
- 7Yg7k4YP/ixAzKnkECk/Xkd7s7gg86up9JamIeFgZ2CVxo/M+gG8Z7iPbcYAtp8NRHV+/Q7M0C5HvEGB
- jYFc0HHZINXNtFFtnIZo0zdE7zbMm5xtbJWXOQLKM8P4qCmITy6MotA8GtXntCuh8L/9BFTzTBevwE98
- Ev9KyTzK+b5hTuFVd5a2f3iXaSRccOFhROic6py/pnz+cohKZYOL+1aCKmO7oqhjeQMiKfMsk0hPx6fQ
- stwPSWnUUW5zG+W1WqIq3sX8wHTXbO8i0OHp12n+ZCmXRL8vYaZNlMxm/X92xugob8p12h2jncjRY8Vf
- HJIr03vAAAAAAElFTkSuQmCC
-</value>
- </data>
<data name="map" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
@@ -2209,171 +2560,11 @@
bwAAAABJRU5ErkJggg==
</value>
</data>
- <data name="ruler" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB3UlEQVQ4T2PYn8jCsD+JheFA
- EksGEHdDcQZIbG0EM0gcJw3SywAiQIqAdM/fm8v+/7qy8D+IjU8jzGCwAfsSWTJBGpaFMF98sLnh/9dT
- 0//vTWQ5AxJbE8E8Bx8N0suwPZZlyu9ri/9fnej+/8fFef8/n5gKZ9/fWAcWw0aD9ID0MgBtmf92f8//
- baUm/+9tqP3/8eik/6dbrP4/29aMF4P0gPQyzAtgap7lx7QRyLn/9fSM/+8P9YMk7oPECGGQXgagIjCe
- 5MY0787aqv8gkzdHM88AiU30ZMSLQWoYloYwM2yIAuPZIOe/2tP5H8QGic30xW8I2IBOeyYYXnhzZdn/
- FzvbwH4DYlD4MMzAYwjYgJVhzDC8COR8UOABxRYhiTNM98HuErABjZaMMLz0+tKi/0+AaWFZKNNSIGaA
- YS0xRgZ0oCrMyOCrDhRfHMwEwytfAZ3/CBiVQLGVMHFNUUzNKIaJsTEwVBgxgvDqK4vy/z9YV/1/rj/T
- eiBm0CCkGWYSyDkTPBn3vAa64NmWxv8gNkiMWCAPVGiUasywsM2Z4TgIA9nzgGLKQCwHxBJALAzEfEDM
- CcSsQAwMPQQQADIloRikWAyIRYBYCIj5gZgHiLmAmB2qmRlIw50HAIdyTYaOb/frAAAAAElFTkSuQmCC
-</value>
+ <data name="magnifier-left" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\magnifier-left.png;System.Drawing.Bitmap, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="application--plus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_copy_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABq0lEQVQ4T6XQz0vacRzH8Tda
- gwjD7dAhdvLiYS3Bk7H1pcCLB0EFD8ODEKFzW8EY26EgunToTwhEBJkIMnEI4vSq5tBoQrIFwkCYX1BM
- QUER5dXn3Y9TlH3bGx68P9/vlyd8v18CQP+DnE6nTngjeBTiRkcOh8OVz+dPq9Uqzs7+oFKpoFz+hVKp
- hEKhAPEMuRz7Kc7HODoqo1j8jVQqe8ot2Ww2XyaTQTqdFjdTSCaTSCQSiMfjiMViiEajiEQiCIfDCIVC
- CAaDCAQC8Pv9UKvVHv4Er/gHjxpuyW63vx2PxxiNRopwwy1ZrdZ3w+EQg8FAEW64JYvF8qHf76PX6ynC
- DbdkNpu3ut0u2u22ItxwS5Ikfex0Omg2mxO5s+9hSK6CNzfckslk+tRqtVCv1yda+i5h4/wzeHPDLRmN
- xi+NRgO1Wu1Orh8evIy+vuRsXp0N3yQ83X5eIL1ev8OvL8vynQxfX2FNdtwyffDsH2k0Gq9Wq92/z9T6
- 3Ilqd05mi7UV3JxV7tk4iZkR5oWFifZmywt/X4DEvm64feAsTxFtPjkk33TpcvO1mAsmbJya11eQ2wAA
- AABJRU5ErkJggg==
-</value>
- </data>
- <data name="icon_help_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- R0lGODlhEAAQAIezAPLy8o2cqvj4+JKfq8LK0pWirvf395mlsf///8bT36m1wbO+yay4xPHw76q2waKv
- vKe1wo+cqK+7xvT5+5yotLTAy+rz+LK+yOfr7qWxvJqpt/r8/d/k6Ku3w8fS3pSirrC9ybC8yODq84qT
- oaezvvn8/bG8yc7V26CsuLa/yJOgrN3i5/L09ff4+Ke1xNzh5cPP25als93j6JWir6y7yfj7/JqnsrzF
- zu71+fP2+NXb4d7o8crV4JGfrLbCzbC8x8PQ3Pb8/L/GzLG6w8HK0rfDzpGdqZShrsnV4J2qtZ6qtZyo
- s5SgrLC9ysHIztPg7MHK1dvm8b/L17fAyb7J1L7K1Ky5xtjc4Kizvaa0wcXR3bfF0IyXpY6cqYybp/r9
- /aSwvLbBzIyZp6u5x6q4xp6ruK25xLvG0ery+Ku3wouVo8XO1qi0wIuUosnV4Z2ruJKhr7bDz7bDzrbC
- zsrQ1uLq86q0vezz+Jentq+3wbW+x/T3+bTC0J2pttLW2tvg5Z+ruZyntMzX4bTBzbvH0qexuqayvsbR
- 3J+suM/U2cXS3bfE0IyXpuDk6ay1vtXZ3vX3+brG0bS/yq26x5uotcLN2IuWo7S8xtLY3c3Y4uHl6rzI
- 1LW9xPX19Jqns5uns622v+ft8+fs8tnk76e0wbC7yJGeqp6qtsvW4Oz1+IuTo/T7+4+dqs/T2MfU4aGu
- urO8xbzI06Cvvv///wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
- ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAACzACwAAAAAEAAQAAAI/wBnzerUQoDBgwIMKGwgEJKrBIqA
- 8KFBxsWYSRAgEJgFwA2STB7i6NAkY4WkLD/MwCEAIIEgHrFY1EGDQ8SGGw8clEkBQAuqRRxGhXpxQtST
- PSjAeJoCAMahOTm+YJCFJ9GOCVj6zNADQEolQlDWVDAR40qUGkoo9bgEYFMVKnJAhHjz6M4qOqwodBkC
- YEukMz4WPMBkYUIrRp9siMkDYFCRMAsYZCiRyo8qCgcKcAEFoEmFCxIUvPrTKNCHzCosOQJgpZSENCQA
- weKU5EiBAaZG2AFAikEHNoiWIAjiRA0TIxEGFAKgQYEDQ6cOIEAgpM2ACF4GbCQSoLv37wO0CwpsAKC8
- +fPlBQYEADs=
-</value>
- </data>
- <data name="gear--plus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACeklEQVQ4T6WQUUhTURzGz9zm
- GNMxJSasHFEbKzZDNmhbESNLRnMPc9pzDCKR6ikaFC1EKBEsCvWhslBovtSL4lNmgskV3IVtbrikpWts
- Tgx6k9CXf+e7d4VGPXXhx/nz/b/v29lhRMT+BykcCARYMBhknZ2dLBwOS2d3d7eX01PFu38HLzLgQEEo
- FDrDjb38PIxzb2+PdnZ2aL8Gz18LOjo6zkaj0Sfb29sUiUTuctP1zc0yAczQsIMH3gM38Pv9jHOzUChQ
- IrFM5XKJZmZmPpdKJQKY8/m8tIMH3mpG/gter5f5fL4jXV1d99PpFKVSSVpf/0LF4lcJzNCwgwdeZNxu
- t1zg8Xh8XLgFJibG89lshiYn4zmHwzEKMEPD7pcPmd8FTqczKooJmp//QEtLAq2srFBLy6kBpVLJAGZo
- 2MEDLzIc+QZ2u/3O4uIizc7OEs5MZpVaW539CoWCAczQ9nuQ4cgFVqu13WKx3APDwyMbyWSWpqffJ12u
- 0zGAGdqFt6Fd1fOmcn3MlECGIxeYzWbW3Nx81Ol0DQmCSHNzH2ltrURbWz8kMEM78cZLV7/fJsX4oYy2
- z8jYy0a5wGg0gn5BSNHU1DtaWBBpZORFYXk5S+BiPLxri7vJMuGiy9+ukfJx4yYPi2ys8ZlU0NDQAC61
- tbW/TiQ+kc128qnBYHggCBkCNQ8NlfOVMP0JGzWIUgE+lUrFtFptQKfTDWg0mmM4c7kKf9AiqSL1ScWg
- PqOI6SuO4jliQ3pR4pFevgHynCYOf1bmAmq1+govGgSYJT2mWzVt2In11aXZcf6LQ3r5DfhXw6nj8Jdh
- pn/SW/uK9ajT7EbtWDXDfgLZQt8vMfwSKAAAAABJRU5ErkJggg==
-</value>
- </data>
- <data name="icon_panleft" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAACDACwAAAAAEAAQAAAIwQAHCRxIcFCBBAUTCnQhQECDAwcG
- 2fESYEqVggcHitAh5AoAMjPiKBw0oUeAEQMAKPkDQeEZOgQArMEBAI+TLwpzcMgToM2ADjdS+FD4IUwX
- Fj/e7DFxgYFCDSpgbAiBoggBNAU9xKiTZYmUBWaeRAgihmASLEYUvCghaEwfPmDSWCEIBNAKKCBIUAnE
- JEoZP1sKthiS4YQeHmqOVKhBA0nCB3K0EDFwp4kEDBZGDuKCAMEcG27gaB7EhsIOBwZkBAQAOw==
-</value>
- </data>
- <data name="icon_measure_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- R0lGODlhEAAQAIMPAKufkcu/pqqomunkwKKdkdXIq5Whrtbh5YyZpZy+1J6Zj42Zp5y/1I2appy+1f//
- /yH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAAPACwAAAAAEAAQAAAIWAAfCBxIsKDBgwgTDkyQYMGDAwce
- RoT4gOECBwwQPDBgYGNHjg8wIhjZQCFJhShTqhRYgEDLly5jwhwggKbNmjhvBlAQoCdPnz139gRAtKjR
- owBWKl06MCAAOw==
-</value>
- </data>
- <data name="globe--minus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAADSklEQVQ4T4WRbUxTVxzGD+1M
- JGYuMSFmiyMOQQuaiDUqGwsRGG+aoCRkKpHOlymKi2SZQkKmbAxtKC8FtUoDErRQFalhzhpe3PaBqZRC
- G7RNKavWKbRAJZQi2lXWZ/9zxU9+8Ca/PPee//M859x7mejYfSYqMjLxL38zsfyfhWLF6FfiCpeCaCO6
- 51UhrPM5+bif57JKvmXCjVBQal9OQ/Wmhqdm+V/PPVqrz3/T7gsOTM/5WxwvPSlal5nPue9tAc++KSg0
- LP+oxNxe8NtT13XbFPp9c2ixTqPeNIV7E37YAoDtX6DaOOniPu4XckJBnj5UlN/VWND+yF3e40aX208F
- QbRYpqCz+9Az7kefdw59s8C9F8DpHpeb+4Vcnp6xkN3atJjiDus314Zx6KYTl+wvUPrHCE78PoIrQzP4
- cxI4qXdAQ+s3xoC2Z68Rdfy2ledCcjRUkHXhjOyiaSq90YaUpiFs0wxhR6sDubrHONzuxO6mB8g8a4By
- MIBiatune4Ic8vMcwRhLK+/4Xj8WSFRZsFY5gLg6C+LrLUhosOJLlRkynQtFd//Dd92zSFCaEFthxJY6
- U4DnCCpI/NkQV3InmNw4iqhTBkgqBxBdaUJMlQnRCiOkChMSamzI1s3i02OdkFZReWVvkOcIKtj8U2e8
- whj4rLQXkfJ+RFFg1TwS0qiyXmyscSC1ZRbhBZ3YqgOyNOMBniOoIPnUudVFHd6V5Q8gqXiINdUWxCot
- kNZaBWKrBrGp1oG1ZYOIV48hrQ1IVj3y8hxBBelVGUtyNcPrySQlvlA9RpLaibQGJ9IvPkFqvROJFxzY
- cNqMr29DYNnhG8OrN+ZnZEemUkHm+VC2Xd0sOdnnSVK7kdk0jl3aCexp9WD/dY+g8qRcqMLXoEGynjT6
- dc2isEltiMikZUzN2I7LjO1sjvggt7VLKrd4ZFe9ONLuww+3ZlConxFUGbkOr2Syd6hjrJ+OQNfSGHqV
- sgi299fmZYV37dvqR735uunA8Vsvg1yPxO98dTRshf/o4o8nfxQveEifrp9TJpyAMTERRkSzD5fGsc8P
- HmCy1kZ2sKOb5XUZBOXPfJ3PGaPdWFg45fg/4JeIWDRf8gnp++CbcT/Psf8BxLcXab+EC34AAAAASUVO
- RK5CYII=
-</value>
- </data>
- <data name="control-stop-square" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABcUlEQVQ4T8XTO0hCYRjG8Q8M
- 6YKE2RC1VRANQVNDQi65RVC0hDQEBS2F4FBQSy2BQxdrUOg6mDWEBJZJUdBSw1cEZYNh2AUywgiHEBSf
- 3ldQ+ChJcGj4cc6B/3nOtxwBQBSjqJf5w5mBjtWoMK29uYgsgIv77KkzN0bXC5PLEWD+Pq2YC6WR5XgA
- uONeGWhzhAWR9rsUJs8Tec3eJMEd98pAqz0oiJy5SmA0EM8Z8cUwuPuKgZ0nWDwRWI/fwR33ykDztBRE
- Tl18YXgvhn73I7qctzAvXqJzQeZYPCFwx70yUD9+Joi0nn7A7AzCtHT9q153CNxxrwzUjQUEkT2+KFpW
- wnmZtp/BHffKQPWQVxDZ7o+jxhPLq8n7Ce64VwZ0li1BZONRClpvMq8qXxLcca8MlPatCyIbTgBDANAf
- ApV+QEcqDoByUrZPz3TlTmuaUAeEEBqN0bah6XbJPxltm9SXKCfgAaIntQUw/Bj417/xG49phw+gF0Mn
- AAAAAElFTkSuQmCC
-</value>
- </data>
- <data name="funnel" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB9klEQVQ4T6WT30uaYRTHj7/w
- FzLyQnFC4Mgh4hgs9B8QvJH0vxDqJhiDRYMuNsaoi6Cr3bSgaIHMNghrUhmZliwpMXCMGAoyJNzNbnf1
- 3TkvzxtKNoJe+MDzvDznc85zzvsSALoPWnA6nZ6IRCIZm82WISJhinllNBrnnU7nvNfrfRsMBuei0ejL
- eDw+zefTelJdkOn1euh2u2i1Wmg2mzg9Pcf2dgWFwjdUKt9xcfEL7fYfXF39BcdP3hBIBaVSCfl8Htls
- FsvLH7CwsITFxfe8/ojNzR3s7x9DVTAoSCaTJIJOp4N6vY5iscjZv3LgJ6yt5Xld5Yp+4vLytyZIpVLX
- fdMWsVhMBGPSg0ajgXK5jN3dPays5LCxUeDM5zg7a0P1IJRIJIYKiAVj0sRarYbDwxJWVz8jlztAtfoD
- qolhroD+J+B4EsnUyUkV6+tfsLVVgZrCE66A7iIQyWMZo0xBjfEpV0C3Cvx+P3k8HjKbzRKsP9cCt9tN
- Pp+PAoEAhUIhCofDgz3ojxomcLlcpONwOMhqtd5JMKuu8K4/WE8w8CH1V2AwGEjxQgR2u31OsvKEBgq9
- VSCn+B8QnovAYrHMMDduOUxg4lMPGB/zkJk5OmrAZDLNqr28G2G0Tg8TSJpR5hkzzrxm3vB1Umov7x4x
- 2l10wT8uhpNvS0oRDQAAAABJRU5ErkJggg==
-</value>
- </data>
- <data name="gear--arrow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACfklEQVQ4T6WQXUhTcRjG/7Yt
- GWbozexrI0qRUMPOwG11MbDEmov8uojQZFBIq66kgVERgogglG1hEJRSGdRNihG0TFA7ws6JnX2YmsuW
- bTq8l8ibt/9zjpZCdNOBH+/L8z7PwzmHERH7H9Swy+Vibreb1dXVsfr6enU2NjY6OK3rODbf4EUGbCmo
- ra09yo2X+NyLuba2Rqurq7RZg+evBTU1Ncd8Pt/dlZUV8ng817np8tJSmgB2aLjBA++WN6iurmacq8lk
- kiQpROl0ikZGRuZTqRQB7IlEQr3BA+96RvsEh8PBnE7nvoaGhluRiEKKEqaFhS+0uPhNBTs03OCBFxmb
- zaYV2O12JxfawMBAfyIej9Hg4LOZ0tLS+wA7NNw2fMj8LhAEwSfLEo2NvaepKZGi0SiVlR3u0ul0DGCH
- hhs88CLD0d6gpKSkfXJykoLBIGHGYp+ovFzoyMrKYgA7tM0eZDhaQVFRUVVhYeEN4PcHvobDcRoefhe2
- WituAuzQcKu49lw60nz7JTIcrcBisTCz2bxfEKw9oijT6OgEzc2lKJP5oYIdGm72bilj6/0cs/kXmviH
- aQUmkwl0iKJCQ0NvaXxcpkDgYTIUipP3sULHe6Sfbn+ETt75SKcDUepLE/GwXNapNKkF+fn54FRlZdVT
- SZql4uJDvXl5eZ2iGKMT3VN07zuRd5qoOfKHtlmig+0TslqAR6/XM6PR6MrJyenKzs4+gDkzs0wX+0Jk
- ahlYLmh9FVPnhRfz9g9Eu7yv5d1X3mhvgDyngMN/K7MCg8HQwou6AfYNPfds/3TuuSeRnU2D53mJ9g/4
- s42zg2Pi7PkX2888eGRw93rWM+wXiN3yhzE1UjYAAAAASUVORK5CYII=
-</value>
- </data>
- <data name="icon_copy" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
R0lGODlhEAAQAIeMAEF1pURzq0Rzqezx9URzp0JyokJxp0F1p0J0p0B0pkN1pkZwoEZ2pERvokd2runz
9eDo6sHZ3ebw8ev19ufy+D5xqPv69vr4+0Z3otDi5J/Byvv7+d3p6fD28j93qENwqfj8/fn9/EFzqObu
8T90qL3U3MTb4z50o/r5/kBxqd3o6kVzpEVwp9Pk6/z1/PXz+NTh59nn6Pj3/UVyrb3N50J0qT9zo/r7
@@ -2387,332 +2578,94 @@
- ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAACMACwAAAAAEAAQAAAI3AAZCRxIsCAjBwASAGiAAQGLAyQY
- FBQQYoOMDg8gcMgQoYINgjNuWHgxYYSKFiZKLKBxYmANFAgVMnQIkUEBgQouULSIUSNHjwJFgAg5suTJ
- lCtbenDxkseALExi1GmChtChMQUIDMiZpweQQkJw/EjyxJASPAYoCJVyxUmiOVr2YKlihg6iFBKWWsmR
- BgoZMFv8BNEgCNCKD1rlwIGxRseSN3G8fOESQGDaGDDcDApzh0qfIhoCKRKI184QPmLK/PERhY2aRWcE
- HibSZsqOLgH0HBEQAIkRg8AHBgQAOw==
+ ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAACMACwAAAAAEAAQAAAInwAZCRxIsCAjQ4ISKhSEUFBBQRsu
+ uLDg4sWLK1cSEjTkIqKFDlKuQIAgiORAQRYaKkTI0iEjQRc4UqRoUaTGgyk3eHwR0qZJQS5gRgQZciRD
+ hS4MobjxAqRIJxASSU0Y1MIFoiOdSJ0q6IWhDRY7ABG51Y2bli6kSLGSVetWl117QnCiFUYiMong8nwq
+ FQYMN3byCjya0A9hwzcNKmYUEAA7
</value>
</data>
- <data name="icon_home_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="layer--minus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIZYAOTk47K8xp6iptXc4KGnrtHJsdTd58HN2r3Eyunw9P////r7+9LZ3Za3p7rF0rG6
- xcbWzZGTlaGor7a+xKeqsOPn6+3u8Zqfo7zNyKattdHf6PT19rzAxPb4+9fc4rvG0tnd4PLz9fn5+sG5
- pNbW3dDb5d3Wyc3X4sPGydHR0dDZ47fGxLK9yb7Lyb3I1qi9tdXZ3Y+Tl8rR1sHM2si+p8/S1cHM2MPL
- 07jD0KaqrbzFz+7w8p+lq7C2vPP09evr6q2yt+3q48DI0bbBzKm+tvf4+czW4Y+QkbC6xKCmrsXP2tXN
- rPH0+LW8wq69u7rF0c3Q0srN0ePey/Hx8N3i5uzv8sfR3sPO2////wAAAAAAAAAAAAAAAAAAAAAAAAAA
- AABYACwAAAAAEAAQAAAI3QCxCBQI4IGHIgVoUBjIEEtBJQ8ykFhCAUBDhwcMGJiBIyKFCRYHAjiQwMgV
- FwEcIImRAyRBkiccGDjgIACPKBwugByZQIXMAB8CJKmhgAmMCxeaJCiRwMqBJwEkQFGgoMMGAQIjBDAQ
- wEYAAigUaGBB4KpABBIicCUAxIeGEQUI7MCKBUECCQQi9KCi4EaBHwQq0EWwIICJIAwWiBBS4EjgwS0Y
- IECQOISOAlIeYxkAocGLFTISVxlSoIAAARgGYLHAuQERJwtACCCQYspmhqw7C2gAIfVF3AOCXwwIADs=
-</value>
- </data>
- <data name="icon_ctxarrow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- R0lGODlhBAAIAIcAAAAAAIAAAACAAICAAAAAgIAAgACAgICAgMDAwP8AAAD/AP//AAAA//8A/wD/////
- AAAAAAAAAAAAAAAAAAAAAAAAMwAAZgAAmQAAzAAA/wAzAAAzMwAzZgAzmQAzzAAz/wBmAABmMwBmZgBm
- mQBmzABm/wCZAACZMwCZZgCZmQCZzACZ/wDMAADMMwDMZgDMmQDMzADM/wD/AAD/MwD/ZgD/mQD/zAD/
- /zMAADMAMzMAZjMAmTMAzDMA/zMzADMzMzMzZjMzmTMzzDMz/zNmADNmMzNmZjNmmTNmzDNm/zOZADOZ
- MzOZZjOZmTOZzDOZ/zPMADPMMzPMZjPMmTPMzDPM/zP/ADP/MzP/ZjP/mTP/zDP//2YAAGYAM2YAZmYA
- mWYAzGYA/2YzAGYzM2YzZmYzmWYzzGYz/2ZmAGZmM2ZmZmZmmWZmzGZm/2aZAGaZM2aZZmaZmWaZzGaZ
- /2bMAGbMM2bMZmbMmWbMzGbM/2b/AGb/M2b/Zmb/mWb/zGb//5kAAJkAM5kAZpkAmZkAzJkA/5kzAJkz
- M5kzZpkzmZkzzJkz/5lmAJlmM5lmZplmmZlmzJlm/5mZAJmZM5mZZpmZmZmZzJmZ/5nMAJnMM5nMZpnM
- mZnMzJnM/5n/AJn/M5n/Zpn/mZn/zJn//8wAAMwAM8wAZswAmcwAzMwA/8wzAMwzM8wzZswzmcwzzMwz
- /8xmAMxmM8xmZsxmmcxmzMxm/8yZAMyZM8yZZsyZmcyZzMyZ/8zMAMzMM8zMZszMmczMzMzM/8z/AMz/
- M8z/Zsz/mcz/zMz///8AAP8AM/8AZv8Amf8AzP8A//8zAP8zM/8zZv8zmf8zzP8z//9mAP9mM/9mZv9m
- mf9mzP9m//+ZAP+ZM/+ZZv+Zmf+ZzP+Z///MAP/MM//MZv/Mmf/MzP/M////AP//M///Zv//mf//zP//
- /yH/C05FVFNDQVBFMi4wAwEBAAAh+QQAAAAAACwAAAAABAAIAAAIFAABPBgIQOCDggIRKlR40KDBBwEB
- ADs=
-</value>
- </data>
- <data name="icon_zoomout_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- R0lGODlhEAAQAIZpAJySh3aFlJ6tvO7z9eDPvpubm+ru8LKysqGhoZ2dncvFwOLm6Z+fn+ru8dbc4t/j
- 56ioqNvf5KOjo+bp68rT3Kqqqp6ensnKyufr7tDX38rQ2MPIzre3t62trfL29+7y9brBybjAyMPJzsDK
- 0trf48XL0s3Q0sDBxO3x9Lu8vLy9va62wLm5uf39/ebp7aWlpc3Nzautrs/Pz9Pe49HY39bd4qyyt5+m
- rtLY3K+vr8nP1NHX3bOzs9PZ4Nvg5czU3K24w83V3crS2uXp7OTo7JycnNDe47e+x+Hl6Ovv8rm7vL7F
- y6Kkpefq7dff5M/a4M7d48vT3M7W3ujs75+goOTo6/b4+aWmp5qamtXX2NDQ0MrDv7O2uc3S15GSk9Td
- 47rCy7CwsM3e49fZ2qKiora2tqiim/H09t7i5gAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
- AABpACwAAAAAEAAQAAAIwADTCEyTIwGWAi+0DFyYhoOECxMGGBhzoALDNGU6GBgw4EOSKS5U8GBIxkAL
- KygaYBiy4MEBGQPDXBjg4YzKKkjQRDBhUSCDiAKCChXgYAeDgQUGEAnAtGkAGlIsDLTQBEeXlj6cfMkQ
- RAOCgRCy6NhAIkKNGUagUDjBYiCMAyKWlHDQ44mYEUK+LpQQA8QRMD+iULiBIMUWhhCY2FgBJASXBF7M
- EFDAUAmVIgUSXBEIAMDki6A7fwbNUDTpi50DAgA7
-</value>
- </data>
- <data name="icon_invokescript_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- R0lGODlhEAAQAIUzAKy7zNrf48/Z4bXLssXQ2p6rvMTOzrjHwLDDtLTJsa/Btb3Ttam9rcfR2sDLycLX
- t8nS277UtrnNs7DCtK/CtrHEtcbS1LPIscHWt8DVtrHHsMHL1LrQtLnJw7bMsrbFwLbMs8DWtrfDz7rR
- tL/VtrvStbzRtKa5r7jPtLzRtam8ssHXt7zQtMHOzrrPtMDWt7vRtbzStam9rgAAAAAAAAAAAAAAAAAA
- AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAAzACwAAAAAEAAQ
- AAAItwBnCJyxAYDBgwg3DJxhEEKAhxADQACwEMBEARgzYqQ4EEAAhCA5CvRIoKRJAgUWGjigQgaFDhYy
- ohzoAEGCARhSJKjQAuPMGQYQSBgQYMCDBxIqxPx5IMEDokUxrEjQQcBPBSxCQC36wgQFqylnMMhAYmvR
- DAwIiAirwEWErQsicDhRoEADgQcuLIAKI8aCCx8a3BUYdABRDiNKDEBgYKFABxM0gEDhQcMEB44HrlTA
- QMGBxpkDAgA7
-</value>
- </data>
- <data name="icon_back_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- R0lGODlhEAAQAIQfAIaKkNjZ27a4vNbe4szS2dvh5M7U29LY39DW3c3T2vP198nP1s/V3MbM09Xb39vf
- 5PDy9PL09t3h5tjc4cbN097i58jO1dTa4crQ19re48TK0dbb3/Lz9d3i5svR2P///yH/C05FVFNDQVBF
- Mi4wAwEBAAAh+QQBAAAfACwAAAAAEAAQAAAIeAA/CBxIsKDBDwIOHhQAQGFBAQoaOhQI8YJEhwIiHDgA
- QIDHjwwpcmCAAEGFDhIeZJiwwQGAAAAgEEhgoGYCAhgsNNAw4OUHAAU8ECAwoKjRoj5hFliwAIDTp08D
- CFRK4WWAq1ivDlTqc+IHmF29wpTqdSrZshMDAgA7
-</value>
- </data>
- <data name="icon_pan_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- R0lGODlhEAAQAIQAAGtra7/Dy6Smq5KWm9bW1o2Rlri6veTl5q6wtPDx8czMzMPFx5mZmdzd3q6zuqir
- r/f3+Lu9v52gpcbK0a+yttjZ262trcLGzre7w7u/xba4vP///wAAAAAAAAAAAAAAACH/C05FVFNDQVBF
- Mi4wAwEBAAAh+QQBBwAbACwAAAAAEAAQAAAIlQA3CBxIUCCAgggHSgAgIWHBhgcbQmgQAQGFBRUObADA
- sSOABwgWECCwYAEFBQcYbNzQUMDIly8REGDAUKBLmCMxEFBA4KDABwZg6nzJc2CCDAV44hwpk+CBAktf
- NtwA4YEACVCjTi05UoHMpVMHPBAZdWSBgRU0FLjQVYHbBQU0Oi2QYcKECwEcxE34dMCAAoATEAwIADs=
-</value>
- </data>
- <data name="icon_help" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- R0lGODlhEAAQAIfIAOXl5QA5cw4/cnaYt/////Hy8UJyoUl4pjVtoQs8bhRGeDVqn+Xi3hBPjkBwnhJH
- elF/q/Dx8FWHtVaFtWCPvVd5nxRIePDw8AApYCdWhEdskRFCc16CptHt/0+DtgA5a53K9wU5bFaJuTRq
- n0p4qUp6qVqItiBZjWeXwkVzorbK3FF+rPPy8Q9CdwAhYCRUiBhVjTZllW+gzzlqlrDV+0luk3Wo3Xyt
- 2TpqmTxrnFOBq26h05WswEBwnE1wl3Om1ZKtxc3p/+P2/zFsqOP4/43B802HvwdDfj5qkjx4sXONqG+W
- wBBBc7LI3j5tm3KVt5aovPP7/xtMffT//yJUg2eMryRTf4Cs1xFNham7zEBvoGSTwFl+omGRw3ik0WeU
- wFJ2m09/qej//3Wn2rLE1fPz8hxMfRxMfAAkXB5QhShZixJFdwU9ciVWjSVXh7nM4FiGsypbjISv2VZ7
- n1iGsQw+b+fv+liNu7fJ3VyApQ1CclSDrwQ8cEF1qXSn1DJik2GNuVGBr8jp/63D1Tx0rHiRrB1Pfe/w
- 7z90qHao2aSzx8rX5SFRgvD9/5+30B9PgeT9/z1lioiy2/P08itflO3r6CFQgqHQ+3CeyQAkXWiZySxd
- kOXj3lWJuwAuZhtQgrLF2QU5a3ut3oKu2DRkkgAuaYqiu+Pv97PV+c7z/yRfmyRXjMfl/wAza+78/3yf
- wO/y80l7rkRrkOTr78Xa8Ut5p0d6rythlTxrmwpBduXv+Z2uv6zT+Fx7mQAnYPT08kt6q3em1iRVg5qx
- yGCNvBBIesPe9jl0rP///wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
- ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAADIACwAAAAAEAAQAAAI/wCRIasEq0CBMr8msSgQ4cIhTgLt
- 2BjjZ4eRJMeGEOqDAMEAZABE3ZAUTISjN01A6RhRK8WRAQASybmyZRYqVh1oRKlyq8eqPAB+jOqkAoQx
- MkBoFdEV588nDgBkeJlwasoiVQ148BKC5MUDLgA0YaKw5NUeYFiyXHKVIU2uCgC6oPgiIVaJE4qCQDLF
- hgofMADuEAMEZwWlYYKIQCn1yFArHwA8mKADwQCpRql2uWBkRoGnGgBsBQpzANemQXgsFZOyhgkGDQAQ
- kTjgYEabOb2EtbAgoA4aWQAWGNCCQ40VAmIK+dqQIJSASABg5HASw80ZAgSUZNIT4oOAj08CiA8fT17A
- d4EMAKhfz169wIAAOw==
-</value>
- </data>
- <data name="icon_popupscrollup_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- R0lGODlhEAAQAIcAAAAAAIAAAACAAICAAAAAgIAAgACAgICAgMDAwP8AAAD/AP//AAAA//8A/wD/////
- /yH/C05FVFNDQVBFMi4wAwEBAAAh+QQAAAAAACwAAAAAEAAQAAAILwAfCBxIsKDBgwgTKkSAQOFAhgwd
- QoSYcOLEgxYtFsyY8SHHjh8/OhxJsqRJkwEBADs=
-</value>
- </data>
- <data name="icon_viewoptions_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- R0lGODlhEAAQAIUAAAAAAP////39/vv7/Pr6+/n5+vj4+fb299DR1M/Q0+bn6eXm6OPk5n6Ejs3P0oyT
- nM7T2bG3vs/R087Q0vf4+fb3+PX29/T19vP09ebn6OXm5+Tl5uPl5vb4+PT29v3+/vz9/fr7+/n6+vj5
- +ff4+Pb3987Uz8/W0M7Vz4qgitHX0dDW0OLm4uTn5P7+/v39/fz8/Pv7+////wAAAAAAAAAAAAAAAAAA
- AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAAyACwAAAAAEAAQ
- AAAItgBlCBxIsKCMCAgTKlyIEILDhxAhNojwoKLFixcnBgjgwsWHFzBCwhgQIkQBjR0/hhzAsqSIERNT
- tkgxsmQIAi9hRnCRYuaKAQgkCJWQYASJiQJUpPgZQ0GGpws0kOgwEeTPmwVGaB1BoUOFiSBGskiR1YDZ
- rhUsTISRYiyKERPiTnBQwoKHiQNOpHg7YgOHvwzsXpgYg4AJrRQqKE7r4cLgCASycu1wwILlxhcwTGzA
- ubPnzwEBADs=
-</value>
- </data>
- <data name="icon_popupscrolldown_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- /yH/C05FVFNDQVBFMi4wAwEBAAAh+QQAAAAAACwAAAAAEAAQAAAIMQAfCBxIsKDBgwgTKlzIUCCChxAj
- SkTwYKJFig4vQiyoESNHiwknLozY8GHDkygbBgQAOw==
-</value>
- </data>
- <data name="map--arrow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAC5ElEQVQ4T53STUzTZwDH8ecy
- E52e57yZnRaiWRZdCPHgYdHDhtMwdkA0MQ0UeauA0A55UQSRYJEgL4KCQIq2EMGmCgEE5K0DLGwoXUFR
- wLYgEtm0BSQi3z1PYrKYeDA+yef2+/6T////iNDMzGAp8jME/5qRIURIerqWzziqk4Q4lJoatS4fUNeX
- RtNQDn1jxTgn63BMtmF6OEb2oAdDj5eEVi9xNi/RjV7UXnWSEAf0+ui19XWudabQPmlk0FPOkKucxZVO
- /vZNYJ7zk2H3ctYJaQ6ItnpRe9VJQvyUlBSz+u4d5a0J3Hado/NpIa0jRp77brGwbGfgnxny70+R9whO
- P4BYmxu1V50kxH6dLm5lbY1iWwwVbYnU3kvFOpxL12ghD8ZrGZxoxuxykWWfJqVrBl3LDGqvOkmIH2Ni
- 4v1v33LxZhRmxymsY2cxdZ/iD/dlphYtvFzuoMPZgWXuNcYn6yS2T6P2qpOE2KvVnni1uorxeiQmu576
- kXSutidz98lFhmcrmX3VxLCrQb7KNJXuVQxdU6i96iQh9mg0iYtv3lBQpaWmO5m6QQOld3TcGT/Pvaki
- nC9qcYxV4vY7aF2Y53TPY9RedZIQgUePJi2srFBYGk1+dQQXzBGUNMdR1nyCqrsG6nuzsDtLcTysoW20
- hWONT2ka96E6SYhdYWHJ88vLFBfGYbIaqOk4yQVLBJbhNKzObPlrC2jsz8Hz701eLPXwS/UEh80efkip
- uPF9QpkQ34WG6meXlijJ12GpT6f2dgrnTRpMA3oa/sxAc93GvqJuDl4ZIOSqg59Lhyjzws4z/Z4dOX+F
- i2+Dg1M9fj8lefFcyo/HeCmKvEoNeXUajA1agrJtFLnlBZIX6cjo/5LG4Zvfex1ia1DQmXn5VZ/5fB8V
- axplb073BwL7YWvEjdmvY1vCxcbt249/GRCQ+6m2/HZ5TtkUGFa8efdhoc4m6Stp26fYcKCs6ot9uZHv
- O/EfeeONT9E6bWgAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB+ElEQVQ4T6XSzU/TcBzH8e/N
+ TA8QNcSIAZGHiISgGP8BLx7Bg8GYOEQCKBAIAeHk1QtRiI8QlviALiwpY8jGgyMkuIw9MA7sQEEE09g6
+ azu3ggie5u9TR5w7kBqWvNJ+u++765ZRIpGg/aDzXW7IYSqYawZhFw1Reec7qAysRie+ab9CsrYT3At2
+ sIsGLZ27MwXX5fjOvKBsuY3ALhq0dLZjEsyR2Lbvk/xjygjsokFLZe0TcEOK/vR+jGyOG4FdNGiptM0F
+ NezRPby44Uy1KMTt3mX1lTv89alz4UvvSFDsBv9q1IoGLZW0jkHturw1Gxa0UVhYj3Es6h8OiA84/+f7
+ Ot9fHl55jQYtnWl5C3UfIpszLLS/X1IGR4LSQ84n9nJ+XY9+xPznWo+HV61o0NLpZgc0LIkb09Nh+SX7
+ 1MfD/n88YvMu/T12AxsatFTUaIfbobXvLntA7GOeJeE8dcZ1ffYsKxyahgtVRAW3OGjyrqgOR1Cy7GJf
+ wwKYbZcq+aHsXMXG4MidzI8NHMwUrET9lFdngxb2y7pGQ9Jz3XzymJwHTuSq22ZzIl0fUYgOHCum7OrB
+ +jeza5PsLzo+t6I60724XCV15xXEdacKtXs5+VqXKUO4iSdgr8OHSisuHrnypO3oVctdI7CLBi1uYGKy
+ mOP/CY3pN4OVZi86RL5AAAAAAElFTkSuQmCC
</value>
</data>
- <data name="icon_zoom" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="sql-join-inner" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIZsAAE1Z3BJJai7zuqxd9nFs1tgZNnm88fb8MXa78/a5LjH1+fu9dDh8trn9KjR43yP
- orrT7erv8+Dq9ISAf622v2Rrcmxtb6Sttqq8z2BocJ+fn4aKjcvY5ZqbnYSHi9jm8pGRkpSVl7S3u83U
- 2f///4SFiHV5fq6yt6Cnr77L2K7L54SdtXh3d1xbXcjQ2Ozw9GRgX5yzy7CurcLQ3efs8eLs9UpMTODo
- 8XahzMbb78rc7s7X39ri6uHr9HyQo6/N6uLr9eXq79Dh8dHh8jAvLrvU7X98e5DO1pmirDg3N97m7auo
- qKamp5u83sjIx6TF54iOlKu0vJy20IWUo67C1aC50unv9Mza6EdKTV5cWr7H0bC/z4OGiKWqsdDg8YBq
- V+vw9bbBzauvs7e/x1hYWdfb36jG5OTr8W50evT3+Zu20MPT4wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
- AABsACwAAAAAEAAQAAAIuQDZCJQxAYaRJQITAkjIRoMILSnCdAHhRGHCDi6U0LBy48oWD2wAiBTJ5EQE
- EmkWSPigY0oIgQvZsBjxgseZHga8IIjRAqbALEHAcFjTYAgCCGaSMGRjocyCGg0Y5HDwQwqWFSMBQBED
- xICQAw6OPPGBZumYEjsYHCjSBEeVDFGWskHBBQkVFWoeVCggVyCFDWSI2DBxoUCAAQTkJlCAQUECNgIC
- HE7cl2HkyZUtSx6QWfOXzpZnsAkIADs=
-</value>
- </data>
- <data name="block" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB80lEQVQ4T4WSUUhTURjH//fV
- hwgiRBnSi8xxG0qlBZZtajK0xir30MCQYI/51AQzFEXSUQ8JiiAqiGLMh0HhQ4U1aNBDHoiIZbYpRKWE
- DaHe/Tzf8d7rdu/ACz8+/ud83++ce7nQWrqhjb0/Ip4OavH0VgmCRX1yjogAbSRlZ7Xh5c7/zrV9MuEs
- +1btvUrQ7euCNvC6kJz/1S6dX9604Cx7cra+wxukADyr8kLrfWGSvbKyQ3XPv1twlvvZgh7o45EjgZK4
- dGg9CWbjUvIHnV34asGZ1419+GZ0hJdRLFCSSg+06Pz6uUSO3HOfLTjzugS+aY8atgTvgIBEmETqQts8
- 4F1ct1CCyFTGN+W2hi3BGyC53XE9vx/rJWbhXh+FQ/2Kmmt39iq6DtEfXP3dmYAoIKA+4oo8/V99G/3B
- GQfDtyDGRCsl8tEi4l/8+dAikkqQlIK/3ib6CZeDR0GIxx+baXLjJnE14dw+A6EES1Lwq7qBsqhwEGuH
- GP7QROOZG8TVhHPrhCGYk4Itl5cyOO3gfhvEYLqRnn4KEFcTzpefGIJJKchV1dK3U9UOon6I/tRFdXWu
- JpwvDBmCu8DsQykpxe1GiL639TS61lL0Cpz1mCGQ/0+ZpFxSacN9ohlLJ8MQpZB7s+ojHvPYpWbmA8tY
- cADrXMqIVYe9mAAAAABJRU5ErkJggg==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACZ0lEQVQ4T6WTW0jTYRjGPwy6
+ CGrJKrDALooSSaQjdRERnQk6QAeN0gvFIiGZMRdouqRYjC1M3SZmZqnVTjh1Ot3MtTLdFLWRzrb+Oufc
+ Wtsa22xBEKzvkQndb/Dje3ne5/fu6k/i8ThJhqRk/DHJvqsju7n9ZE+ZnrWXZzhIOU/JxXum0noO/J+h
+ gy4cuCsH0k8/NN2QD7ulrsDvvkD0z0T7QGioUOCPAMzIsEMHXXogfeUA60S1MX/aHVEtBGOD8/6Y/tNU
+ 2HytgolK1CEXwIwMO3TQhUMPsEgWp+dw6wen1OmPGRjfLx0tDZSIppwl4m++dkPUBjAjww4ddOHAJZl3
+ unJmFqNaW4K5HzHjgVxdRNjmnXmqDg4JXvsN9xtdY/tzdGHthLeu7aPrkdqyKBq2B1/BJTuLO4roVdPn
+ +XAH+OqJ6refUv4VKwKm8ufeLiBSBN4j0457G6R6plLaz1T1Tn5vhEu23VTmjc+FNBbmp0o36WvSjHpk
+ GWc1EW69c/Rek6cbYEamHHHX1/Q4+DW9Dr7a7JbAJVsL3pys1doaO8c8TaIue3WDflZ4gTPiuML7slDe
+ 7NUBzMiwE3baH0j6mMf8t5NP4JIt+a3sXcWK0pfG2Tpxt11QrZrmi1WM/NB16xJXsmgFmJEt72gH3czb
+ cg5csjb7Ikk9zsvYUdTO5bVYapsHZ2Uqs7uFK2HeHSlYWAKYkb2gO3TQhQMXv1WUDavTsvaxjpXlsS9J
+ StlXn1WwL8s4aUerbgHMyxndoYMunIRLUuiwJhFspm8aZSNlPWVdglT6bkrs0IEMJyX5jymZTxnuP42L
+ XZ3g33aHAAAAAElFTkSuQmCC
</value>
</data>
- <data name="property" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_zoomin" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACXUlEQVQ4T5WQUUiTURTHj7bH
- BF8C6XGEwnoIpg/rIcEY2QhlW86USMjKUoa1LIO0h8AoRRSVolFWkFmuaUaBzW1awkZue+hh1pgJMWiL
- rbGFC4fM/t1zSfEhaF34cb5zv//vfPe7ZDKZiHGfVEjmmhXV882K/n/BuTdNCpIyc76hinhDMJILPcHK
- i24ERtuAzxPgPubuQ/zdAFLeEWQCVnBu5oTiyNYAHmI+VkXWhpLaqcYdo/77rch9GoPzlknWxHw/lsYs
- WJm8iq8zPfgues7xAKWgUdDCXKqrGJy6WBHKfhiVctozLCv3sdmbCE904sv0NSw9OB1/fLTwGRmNxuNe
- rze4vLwM78t7cPfV4+f723ho3o+Eqxe2K1pZeQjX0HjHr1fd2uRAdcHckK6gifR6favT6YTD4cDdU/vw
- Y2EQY5YDuHO5Dr31SnwTx+UhXKe6DmP4jAaH9hTaeg7SbjFEXuJZ/FlhzzQemTXgyuvjwiSsLeWIvr4u
- h7iejiAQCIAdvjNL7V4ig8FwbmNjA7lc7q8E3z6XQ2bHh+Dz+eD3+8GOgF2impqatvX1dZTblMhms+Df
- 4a8Eg0GEw2G5tx3OsiNgl0in05nX1taQyWTygrPsCNgl0mq17aurq1iwtCOVSsHlcsHj8Wyx2W9WzrIj
- YJeosrLSkk6nkUgk8oKz7AjYJdJoNB3JZBItViAajcLtdsNut8u6/XlxcVG+5yw7AlKpVERqtbozHo8j
- EonkBWfZKS0tJbnKysq6+PixWCwvOMuOUHcJdlJRUVFbcXHxjf9BOBeELM5PJb8B18GBdzrX/msAAAAA
- SUVORK5CYII=
-</value>
- </data>
- <data name="icon_panright_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- R0lGODlhEAAQAIZuAJumsOTY2MS5uK+2vcW5uJumstrOzsi9vOHV1eHU1ZunsuXZ2dve4d7S0aaxvuTX
- 2ObZ2aaxvePY2NnNzODU0+HT1Ofb2sTJ0c7Jyfjz9J+rttvPztrPzpumsdbS0pqmsdfR0dbS0aSvupum
- s9zPz9/T08/ExMzFxNbKydfOzdXJyqOuutjMy9zQz8fP1tvPz97R0dLLytfLysG2ttPQ08vEw6Ouucq9
- vs/Dw6eyvuLW1eXX1+TY1+DW1sa8u+LV1vj09dTQ0NPHx8i/v9fKy+PX1pynsc3BwaSvu+fZ2tTIx+PX
- 18m9vJqlsNLMzMK4t8zAv9zQ0P///9TR0KGsuObY2Mu/v6CrtqSwu6mxu8m/vubZ2pqmst7T0tXKydXJ
- yc/Jyca9vcbL0si8u7e9xK+3v5+rt8zDw9PHxtjPztrX1+fa28/S2NTMzAAAAAAAAAAAAAAAAAAAAAAA
+ R0lGODlhEAAQAIZeAEV2qAE0Zm1LJt7s9eqvdrK8xtfk7LOcjF1dXdDc45i101lZWaOmqX+AgF9fX4ep
+ xc7b57GxsY+Rk3JycnyWsWNjZK+vr1xcXMvLy19hY2mGp6urq2SHreXx96C61YGYsnFxcc3a5lpbW3p6
+ enmTsGVlZcfU4GNjY2ZmZnt7e6DP4X5/gIuLi5Kov21+kXplTnF3fJOluFJrhfz9/Wlpaaewuam80brK
+ 28PP3bGai5qzzsHP3ZvO4prU5WJjZImetJyvwbvJ2FtcXYCAgIeNkkZJTFlZWsfHx2RkZG5vcJGkuIWF
+ hWdrb+Pv9dLe546QkZuxyYeHh8jV4WNobLnAxez0+dPh63d4eLW8wZKYoVdXV25ublxdXnuFjwAAAAAA
- AABuACwAAAAAEAAQAAAIvwDdCBxIcOAABgUTAli40IibFwEIpACT0M1BNz2gcIAgwIIWNRXd1FhAgMQD
- AWvOBKl4wkQAAQZ4CNjSpU1FH2iqENjwQEgSCTEqzmgRQAmFCgkWSAhRcUyAJSUo/NgRIE3BI1EQ3JhQ
- AUECHUUg0CAI4kmDBjhUyDAAw0AGNgMIehiCYoIXFl+IABETwUyZgk6sHDjARMoFDRGwXMmScAqGMC4U
- jBDhYAWXkG7IFCjQhEoOG5jdICnwoYMCBwEBADs=
+ AABeACwAAAAAEAAQAAAIsgC9CMQw4oKWBTQiCFy4MEoJBgkGGKDSYAJDgUuuGBgAIAAAKxAkDGF4BImB
+ GVU6AgghBccKCwtTMBjQoYlKEztu1ACx0EECAEBVBrXhYOGCAQGSKlXqAcFCBE6CCgUK5cTCLViAKAmi
+ UgUPBVlYLNzQIMaPFip7PNBR4SIKGB9IqFQgw8eTHBeTTHGhgQOFLlyKvCBw4CKRDCKMCGHipYAAAYQv
+ Sm78OPJkho4hX76YOSAAOw==
</value>
</data>
- <data name="gear--pencil" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="application-search-result" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACkElEQVQ4T6WPUUjTURTG799N
- zNnD9GGJpcRQJOZMNtCtGTPNxG0POn3oLUYPUREEwcCsMCmEiMpcTxW6UiNWgTYLNNNs/MVttOlGJi1b
- son4nA58Od3vvyUTeuvCj3P4zne+ey8jIvY/SMsWi4XZbDbW3t7O7Ha7VDs7O42ccxmM2TN4sQP2BLS1
- tR3jxvO8HkTd2dmhra0tytbg+WeA1Wo1OZ3OB5ubm+RwOK5y08X19SQB9NAwgwfePS9oaWlhnEvxeJwC
- AT8lkwnyer3fE4kEAfSxWEyawQNvZif9BaPRyMxm86GOjo4bi4thCodDtLr6g9bWfkmgh4YZPPBiZ0EQ
- 0gEGg8HMhSvA7R6KRaMRGh0dWa6qqnoE0EPD7K8PO7sBOp3OGQwGaGbmI83Pi7S0tERabXWfTCZjAD00
- zOD5MjRIMwpFVBSEBukFGo2my+fz0dTUFKFGIl+ppkbXK/AnAvTQMPN4POTu7ibq6aExQfgkBVRUVDSX
- l5dfAwMDrp+hUJTGxz+E9Pra6wC9pHlubptMJm8qlaKmkpJXg4ydkgLKyspYaWnpYZ1Of1cUgzQ9/ZlW
- VhK0sZGSQD/93kXvRo5Tar2L1Gr1vaKiouonjB8EqFQq0CuKYRobm6S5uSC5XI/jfn+UwMSbO9sTw/XS
- sru/lmprlM94ADutUKQDCgsLQWtjY/NwIPCNKiuP9CuVytuiGKHZyafk6pHHsPz8oYFO1he/hjezkw7A
- kcvlLD8/31JQUNCXl5enRg0t+GjyZZN08/0uYb7u6L4X8MC7ezIBUA5wNBw9yM3NPeNolfno9wrdupyz
- fKKOXcjMtLwW404pJBOQw9v9HBWnJAs6axXe2hsEW5aGi+DFDvsDd0bcBZIplukAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACjUlEQVQ4T5XST0iacRgH8J/W
+ IBFGtEteOtRBL7u4SycbImRYw8IGrR3Nav9gDrbDTpHBW5c22A6NatHB0TKSFbWSTpqtJmOyUMM2h2j+
+ yVI0fE2MZ8/zshdcu2wvfPDnw+/5vs9Pf8xkMjFRb29vM+pDln9A+5pZT09PtX6v17sfDochEAiA3+8H
+ n+8z7OzsgMfjhe3tT+D1foHd3X1YX/fsY28/MxqN1YZdLhdsbGzA2toarK6ugtPphKWlJVhYWAC73Q7z
+ 8/MwNzcHMzMzUFNTY2E4RrVB+I8HewdZd3d3taFCoQDpdBpOTk7g7OwMyuUyVCqVv1xcXAD2DjGDwSDo
+ 7OxkXV1d9w4PDyGbzQLP84JisSgolUp/oGDaz9rb2wV6vb7FarWOpVKpc5vNtqVSqV4RWmcymfN8Pi9M
+ JKLwjo6OB0yn04lMPp/vG8dxm7fuWLi9YGxxLxRbNN4dHKcaHQmDhOkIHRV7HzGNRiO6j28vtrW1Tbx1
+ Be3vPNEV4nCHHVSj3yUajcLx8bEgl8sB9j5mra2toofJZLKI5xp1eL6/D8Tym2Tra2yFavF4HEKhEBwd
+ HQloIux9wtRqtagPL0xgampqeYR7OfIjkf34M5lzTbx4baPawcGBcLFoCkITYe9TplAoWGNjI9FMT097
+ IpEIPzs767BYLM8IrYPBIO92u4H+oUQiIaBjKJXK56y2tpbhjVKbzebl09NTmJyc3MXbGMaReUJrrVb7
+ pr6+fuyyhoYGMwXcxGYnNQ8MDDjxuw4No9HfaH29rq5OIpfLWTUMZBTAUTOGfMBJbkilUnaZRCJh4oN7
+ mEwmE4KEACz0Y8g4ft7GTSrUgpqQAl1DV5EMXUFSMYhCKOAXo8sWCvVAT3EAAAAASUVORK5CYII=
</value>
</data>
- <data name="icon_buffer" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="layers-stack" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIQAAEZCU1KTygpgs6jS54Sv2XuSpTJ6wL/e65jI40mOyObv92Wfz7LX6Iy+3hlquKXM
- 4rjb6leVykqUxY2bqK7V6JzK5Gih0FuazVCSybzd6sTh66TQ5mme0f///wAAAAAAACH/C05FVFNDQVBF
- Mi4wAwEBAAAh+QQBBwAdACwAAAAAEAAQAAAIoQA7KODgwAABBR0SKlxIIAKCBhEEKFRAwIBBhAYaFACw
- IYHEDgIiNIDIoUNGACgHeBSQYACAAhUcdCBwwWXKAThRAmhgQCBLCjopAEVJ4QIBhQIwDNUJgAIGAQiR
- MmDAlMHThQkFTNVp9eNCAQEg6IQQwGtCBWAz6MxQFuvMBQd0Hojo1uQDnRro1jXwYAKAvGaxErAA4YGF
- wFgHFjxYN2FAADs=
-</value>
- </data>
- <data name="cross-script" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACFElEQVQ4T6WTT0iTcRjHn3D6
- 5nJbr+2dZo3Ci0KE6EC9rpNEl52yS4HFhKyItJIKCwnBlVYUFh0a2b95yYJRHdYunYJJZBZEeogxhJAu
- ecnSt88zt5cF0WWDz37P832e5/v7A6/Yti3lUNawbpw3SIjIlEgXZArcfII2CXfhHjwE+nZRH4JnEHUM
- tAiZ3wMD9nJf39pMe3tO8/slBg9ERhNVVe/QXz8S2QsbHIM4jRBlp8zbjo7ct54eO9vdvTIdCHziBKEp
- rzeebm5eoJ6kb4duiEH+9Pk/NdBj3qF5QiQGmZlw+PvnSGT1ZVNTNt3SkkV7jlm99v7PQK7TMIbROCap
- 1tYfqVBo5XZ19Ry5XANdlb9OcAmhyLCINcIjJRoaFpONjT/HDWM27vd/HausnKUmF2CwgHOFonCewpDI
- jceWlUsHg6sxw5i7KHIY7ektt3ue9cW5fxmcRFROi/ROeDzzmbo6e9Lny51FYkh06AzGMZfrI+tIP/mp
- 0kc8RnKc1z3Bvd9b1q83prlMnMTUVGM9oQ6gDcMresM641whSgJX4253bqG21h6sqPjQy0NG0Iu/ToKj
- 632XYfSIiMsxqKdwiN2/mObadE3NEvGVrSXDpWHbem9/l0ibY4C2ncLBA5jsF0kFRPag7QRC8YEHNoMF
- 24IinbtF9pUaeCn4QTdWdFAHNsFGMAqr5tprwhbHoJzP+Q95lHpGrVHH8wAAAABJRU5ErkJggg==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACm0lEQVQ4T4WQ3UtTYRzHn5uu
+ pC7CoouyCwmioiih/oLugroRKgi1F6QQGb0oQqHQTYFdJG1gpaBZOnVN3dqrbTu24xrOHffiXs7Zdjw7
+ 287Ldvbizui25xEmxzHqgQ/n7ff9ffkc0DFoBw20weebkLv/Ac20NYbBlQHbLWdYXNrJ12y0KFuagb6h
+ GTSrXLDXDF9q1JZE8M1SzN2M9ybKZSZ4fUqQrZdfWO/tL6g3bySkEC3WRIqXs40kBTmHxwrpUUPMSeaq
+ xkvPzF1owYHm4fkwpbEmi2MmSlAybk/ytoDAkFw1O6IN/9pmK4aLT009+8715nC6UqI4+Q9sqNWhuGoN
+ Nstqa4LbZnfTQ18DWGCnvHxBZXwAkAfyMW5mPUGmknHH8qI/Var5ksVdJbFstfZWH83BIPN8inD5kiX9
+ uf6VRwB5IB+9N4P76RLrDAuil5JkD1moKAmly/LrxW0OLt3pn/C5PKSkO9u31AuQB/LR4gzupYqMleCE
+ tUi+ag/wRTPBST/8nGTczEnuaL78ajaYW49LdO+4F1uL5nVnHuueAOSBfKZdNI5FRHrWnc4tb2TLut9s
+ QYkjLJQHp4ksFsmn7n/wYPD6vb13oQ8gD+QzZopjMEh9/pliv7mZyoKHrcx72HKd1ZAgD34hRNicUU1u
+ EBOrlPFk98xDgDzgtrkRbXBV582Qk45UVGMhM2pznFOyuM4Ubo9i9LQzETnV89XQ2qlRHb7a1QGQh2WL
+ nxme27JPOpIp7TpLzeFpshF7UEgfaAbgBACgBSAPW4DXvjNEp4Zm/I6BKR/ejI+2eEjZfOjoaZiHB3l8
+ ssVXrAF+Hv7x2Wagb2hmzxmA9r3m+jlyrbsD+Ry7M/HyX7R2qlUt529ch7nj+2F48xccaJZr1sn7YAAA
+ AABJRU5ErkJggg==
</value>
</data>
- <data name="icon_zoomrect_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- R0lGODlhEAAQAIZWAI2aptjb4q2km+vv8+/y9efs8eXXyfX29/b3+PX2+PL199Pa4Nrl6a6vsMHCwujt
- 8ujr7uHk5+Pp76SkpLu7u/T19ufp6qSkpfH09vP09fr7+9fY2aurq8LHzO7x9Ozt7tbX2NPU1sC/v8nK
- ypubm+Xn6c/Pz9LS0t3g49ri6cLHy/Dy9N3k6/Hz9dXd5czNzcjIyL69vdvg5cPExbO1ttDf4ejq7Nni
- 6paWltrb3Nvf4+js787Q0uXp7ezw9NTT08bJzfP19ujt8bu8vfL09uzu8LGzteLp79PZ38TGx62tre7w
- 8t7l7MLDxK2trODj5be5usXQ2tXb4bCvr9bW1rW2tgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
- AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
- AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQB
- AABWACwAAAAAEAAQAAAIqwCtABhIsGDBAAIDKFzIUCEAhA+tSJxIMaFAK1RETInxo6JFKyZyPImAIgSM
- ihFflFhR4UCLHTqaUHx4YsOBIhoSYPAgBMiIiQ8pWECwJAgRAgMKIFECNICTDAgg9CDgo8CRFCSaVvmQ
- QAHSAgyYLLhwMAkIrwMeMKhxowOUhlYc2EgrwUUUKUY8SnTAQwaLBSpoNNArcQYHHBOGWGkgwABhjwIa
- P64Y2bGVgAA7
-</value>
- </data>
- <data name="application-export" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABzklEQVQ4T6WTO2hiURCGB+0M
- go0YtrwKaqlphKCVhQ/EB1qE9Ek2CYElsFvErRZ7KytBEAtBsFDBqK2P5MpmIckiaCGIKCqi+MAHyuyZ
- W66Fhgx85zTzDWd+OICI8BnA5/NxjDPGxYFQL+f1eoEAj8dzXi6X3xuNBtZqNXx7e8WXl9/4/PyEpVIZ
- i8UKu3msVP4gz//Fx8fiOzkMcgFcLtfXQqGAuVwOs9ksZjIZTKVSmEwmMZFIYDwex1gshtFoFCORCIbD
- YRSLxRcikQgIWuGSZfChIodBLoDb7b7abre42Wz2wvM85vN5ZE+/cjqdYLFYABwOx/V6vcblcrkXWo3K
- brff2Gw2nclkArBarbeLxQJns9kO/X4f6/U6C7Ek5EJ59Ho9YQiTvxmNxhMwm8130+kUR6PRDpPJBOfz
- Oa5WK6Q1/y+dTvcDaNJ4PMbBYLBDs9nEarWK6XRaSD8YDGK73RbmcBz3U6VSGcBgMNwPh0PsdDp7CQQC
- giyXy38pFIpTNgRAr9d/p11brdZeQqEQ+v1+1Gg0D0qlErRaLYBarX6g53e73YOgXnIY5AJIpdJLmUwW
- +AjkSCQSIKjoPGZ8ORDqPRJMqs98ZXL/Ad8QklT8D+CBAAAAAElFTkSuQmCC
-</value>
- </data>
- <data name="icon_invokeurl_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- R0lGODlhEAAQAIU4ANrf46y7zJ6rvLXLss/Z4cXQ2rPD1M3Fo8fR2rjHwK/BtbTJsb3TtcLXt8TOzsDL
- ycTDpbrQtL7UtrnNs7DCtMHWt6m9rqm9rcHL1LHDtrDDtLPIsb7MxMDVtrLEtbHHsLbMs6u8xK/CtK++
- q6y/ssDWtrrPtLjPtLrRtLzRtLvStb/VtqS1s7nJw8jSz63AtbzQtMDWt7bMsrvRtcHXt7zStcDMz7zR
- tQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAA4ACwAAAAAEAAQ
- AAAIuQBx4MAQoKDBgwUxCAxgoKHDhgAMRBSwEKHFABRxBCDAsaNHjhk3AhhJsmSBjCFaZLCQgQOEAzAP
- ADiJ4wGJBQMq3FjgwYVJihomDAAwoEGDCR5eyjyZYEGDoUQr0FjAgeRJBTBKQCUaI8UImDMFXOiwYivR
- DhasClBgQsJWBhIivChAl+kGBlBn1GCwgYWAv38daBgwNAIKFQNE2EDAmHFNCh9AnJDxgcIDgZgxO0ig
- 4IKCBA4yYw4IADs=
-</value>
- </data>
- <data name="folder-horizontal-open" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\folder-horizontal-open.png;System.Drawing.Bitmap, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
- </data>
<data name="ColorBrewer" xml:space="preserve">
<value>"ColorName","NumOfColors","Type","CritVal","ColorNum","ColorLetter","R","G","B","SchemeType"
"Accent",3,"qual",,1,"A",127,201,127,"Qualitative"
@@ -4429,4 +4382,54 @@
"5. Products derived from this software may not be called ""ColorBrewer"", nor may ""ColorBrewer"" appear in their name, without prior written permission of Cynthia Brewer.",,,,,,,,,
</value>
</data>
+ <data name="icon_home" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ R0lGODlhEAAQAIZZAFJ5osvLxjZHVTdPa6C9zcOlRMjl9pa65GqZz3CLpPb4+f///329mg2RUJy1yE91
+ n9jb52B+l0ZSayApMSw/UV6LvjZRbsDQ4GmtmY3F6ujs8j9cfOfcvmOSx2+cz2uYyomou1Foe02Mg6eo
+ w3Wdy5ahrI634Y203OXp7m+QtYSt2jyScFeBr9K1f16Mv+3x9eXl4rOMMN7p+jNLZlmGuo2cq+Ho8Iiw
+ 23qk1mGelW+lndnh7IGPm2uaz157k9a0MGWJs12KvKWlo1+Mvqy7yR4iJUdXYzRObT6UctTf6xgoOFVv
+ huLLgOny/XiXuKKALLTI19rY05mmtHGBkaO50fP0+E51n6S1xU98rP///wAAAAAAAAAAAAAAAAAAAAAA
+ AABZACwAAAAAEAAQAAAI3QCzCBQY4AGVFwViSBjIMEtBEg82jPghIUBDhwgOHOhBI6KECBYHBkBgQIWH
+ DgBcWFFiBCRBkjcqHEBQAcCMGlMogBxp4IRMAEMAHJGyQMYVChR8GDBhAAeCIAAslFiwoIkGAQInADgA
+ 4AOAATwWZMAy4KrABBYmcB0QAkWGJwUG7MCaJYEBCwMmLIGywEmBKAMu0E2gAEALDg4UVElRoEjgwToc
+ JEiQ2AaQAkweZyHAoMGKHCASJ2FRoIAAARgIZIHAuQESEQqICBggBMZmhqw7C2jAIPVF3ASCXwwIADs=
+</value>
+ </data>
+ <data name="document--minus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB20lEQVQ4T42SO0hbYRTHz2jo
+ 5qBZOgiJgwgl6dAgqCAIBlQqRnBQQTDGoEFuCAbfIkK3Lg5GXLUdOrVD3IVujjo4lYpRkeAj7/fxfy45
+ i4+rH/zg3sv3/3HOuYd8a2skjKyvD4DpN3AMr67S0NISfV1cpMHxTiL5UCeQrVT4rljkm1yOE5kMn6fT
+ /D+VMvl9dMS4FwBOFYjEtNWZSZdKnETw6uGB/yWTfHZ9zaeXl3ySSPBBPM5ycHcGOCVsCgajUSWYgeA2
+ m31Rsr2/z4rT610BJFB/JKLM5splvkf5r0mkEmkHmVnNUZ9hKHN5zCCVz1tKRIDMnOaoNxRSQgUIMoWC
+ pUQGi0xIc9QTDCrzpWqVc5iDlUT+DjLzmqMuv18xyhAUMAcryQ1aRMbQHHVMTirhSq3GRbRhJZE9QSYs
+ OcPlIvoyNqZEqhBIFVaSFFpEJvLdbqefhPN5dFRZqGFRKhA8lfydmuK4y2Vy6Hbzns12gfDxD6JdcnR3
+ 0yefT4jKptVQxVPJL4TyExPPiEEiRdBHj4davd5lc1dfkPzx+3kHEiEGFhoaEhsIb0kFODbQ1OzxbKrA
+ lACZiQxWWpJfLHtSxLvclUw9S414aLe1tIQ/tLV9ew9yVzKg8REGvINQesvmrAAAAABJRU5ErkJggg==
+</value>
+ </data>
+ <data name="layers-stack-arrange" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACuElEQVQ4T4WQb0gTYRzHnze9
+ it5ERC/KIOkvUpggRC8qKggiiqQXWWH+CSvMtNIoonrRP6LAwoSiCYqmc61tOp2bzm06N4fTuXm67c7d
+ ttttt+223ea2eiFxPY8xuUTs4MPdc8/n+/vec6D4YhMoejgkJA+uz0NK/wNy8kDVq9g/Aw43ai7osKjc
+ x2Y13mhmcC3QHnKQKxyw3AxftnxSLzjeyF3GtfjQj+tVtrCMjGTUhQ3qa8sDLr/wg1zz5EIc80az0QUm
+ HVyNJ5wJjbti1Ltelw4PpZWH7qvKQOVLtgQOISH8etQ3xZZ6dIkIDgc/E2Njc4FU38F7A+Wg9AlFKsaS
+ XK4Zo1IcbP4FG7I5CCb9Uz7K/a5+TS/BIPWo026w+5KKgjplJTh3F+PReZRTIbPDn6KNLpadJrms1ZNY
+ FOIOLmaRC4PUgzabwerhZAdqe2+AY+VGHp1HZqFNMEjpsEjEQiQyZjyeEjJLpTLIhUN9tSKrHu5J99XI
+ q0FhyQCPziMe95ssRJxSzzCR0Xk2PeSIcCobk1BOMfG+qVB8zBlLIdfkjntvfrboR52sdPct6W2w54wU
+ fZaiXU8aDfOst8voDykmg8nvE3RMyAgWTSIXOmRFs9kA7z/yqyU1YNcpCfwsTvZxwG2AQfyr1hP4ZvQv
+ SsyBZA/C9Jfh2UgaubCZrhNN2kTDhHL79Y4qkH9agaZ2Pxc7tNIJmmgdIZ0tgwTdrMIZIRIzFUNuu84z
+ t6O8U7nlUkvdpuKyIrD/rJYfnAl3PO22a1q1HlJsChBd4xS+GvhPKOSuNAOwDQCwEf5EK6+xh8Xve51t
+ jzumdY1tVlODALRGfNG4Z5Gba96weSfMw+vIFYJs6mZYtT3c0z/NdK0F2kMOcmEkf7k5dxWcFF09XhH0
+ nagM8+uBnL1H396Bua0rYfjwB5D4p3X4gwOzAAAAAElFTkSuQmCC
+</value>
+ </data>
+ <data name="arrow-split" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\arrow-split.png;System.Drawing.Bitmap, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
</root>
\ No newline at end of file
Added: trunk/Tools/Maestro/Maestro.Editors/Resources/arrow-split.png
(Binary files differ)
Property changes on: trunk/Tools/Maestro/Maestro.Editors/Resources/arrow-split.png
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Modified: trunk/Tools/Maestro/Maestro.Editors/Strings.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Strings.Designer.cs 2012-09-19 17:49:04 UTC (rev 7040)
+++ trunk/Tools/Maestro/Maestro.Editors/Strings.Designer.cs 2012-09-21 14:45:33 UTC (rev 7041)
@@ -466,6 +466,15 @@
/// <summary>
+ /// Looks up a localized string similar to Exploding Composite Styles is not currently supported.
+ /// </summary>
+ internal static string ErrorExplodingCompositeStyleNotSupported {
+ get {
+ return ResourceManager.GetString("ErrorExplodingCompositeStyleNotSupported", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Not a valid symbol library resource identifier: {0}.
/// </summary>
internal static string ErrorInvalidSymbolLibraryResourceId {
@@ -1193,6 +1202,15 @@
/// <summary>
+ /// Looks up a localized string similar to Invalid Layer Name Format. Name must have both {0} and {1} format markers.
+ /// </summary>
+ internal static string InvalidLayerNameFormat {
+ get {
+ return ResourceManager.GetString("InvalidLayerNameFormat", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Invalid record count in line {0}.
/// </summary>
internal static string InvalidRecordCountError {
Modified: trunk/Tools/Maestro/Maestro.Editors/Strings.resx
--- trunk/Tools/Maestro/Maestro.Editors/Strings.resx 2012-09-19 17:49:04 UTC (rev 7040)
+++ trunk/Tools/Maestro/Maestro.Editors/Strings.resx 2012-09-21 14:45:33 UTC (rev 7041)
@@ -1446,4 +1446,10 @@
<data name="FeatureNotImplemented" xml:space="preserve">
<value>This feature is not implemented yet</value>
</data>
+ <data name="ErrorExplodingCompositeStyleNotSupported" xml:space="preserve">
+ <value>Exploding Composite Styles is not currently supported</value>
+ </data>
+ <data name="InvalidLayerNameFormat" xml:space="preserve">
+ <value>Invalid Layer Name Format. Name must have both {0} and {1} format markers</value>
+ </data>
</root>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/LayerInterfaces.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/LayerInterfaces.cs 2012-09-19 17:49:04 UTC (rev 7040)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/LayerInterfaces.cs 2012-09-21 14:45:33 UTC (rev 7041)
@@ -760,7 +760,7 @@
/// <summary>
/// base interface for all style specifications
/// </summary>
- public interface IVectorStyle
+ public interface IVectorStyle : IRuleCollection
/// <summary>
/// Gets the type of this style specification
@@ -855,8 +855,39 @@
/// <summary>
/// Defines a collection of style rules
/// </summary>
+ public interface IRuleCollection
+ /// <summary>
+ /// Gets the index of the specified rule
+ /// </summary>
+ /// <param name="rule"></param>
+ /// <returns></returns>
+ IVectorRule GetRuleAt(int index);
+ /// <summary>
+ /// Gets the rule at the specified index
+ /// </summary>
+ /// <param name="index">The index.</param>
+ int IndexOfRule(IVectorRule rule);
+ /// <summary>
+ /// Moves the specified rule up the list
+ /// </summary>
+ /// <param name="rule">The rule.</param>
+ bool MoveUp(IVectorRule rule);
+ /// <summary>
+ /// Moves the specified rule down the list
+ /// </summary>
+ bool MoveDown(IVectorRule rule);
+ /// <summary>
+ /// Defines a collection of style rules
+ /// </summary>
/// <typeparam name="TRule">The type of the rule.</typeparam>
- public interface IRuleCollection<TRule>
+ public interface IRuleCollection<TRule> : IRuleCollection
/// <summary>
@@ -936,7 +967,13 @@
/// Gets or sets the filter for this rule
/// </summary>
string Filter { get; set; }
+ /// <summary>
+ /// Base interface for basic style rules for all geometric types
+ /// </summary>
+ public interface IBasicVectorRule : IVectorRule
/// <summary>
/// Gets or sets the the label
/// </summary>
@@ -946,7 +983,7 @@
/// <summary>
/// A style rule for the point geometry type
/// </summary>
- public interface IPointRule : IVectorRule
+ public interface IPointRule : IBasicVectorRule
/// <summary>
/// Gets or sets the symbolization settings for this point rule
@@ -957,9 +994,14 @@
/// <summary>
/// A style rule for the line geometry type
/// </summary>
- public interface ILineRule : IVectorRule
+ public interface ILineRule : IBasicVectorRule
/// <summary>
+ /// Gets the number of strokes in this line rule
+ /// </summary>
+ int StrokeCount { get; }
+ /// <summary>
/// Gets the symbolization settings for this line rule
/// </summary>
IEnumerable<IStroke> Strokes { get; }
@@ -986,7 +1028,7 @@
/// <summary>
/// A style rule for the area/polygon geometry type
/// </summary>
- public interface IAreaRule : IVectorRule
+ public interface IAreaRule : IBasicVectorRule
/// <summary>
/// Gets or sets the polygon stylization settings
@@ -1776,21 +1818,9 @@
/// <summary>
/// Represents a composite rule
/// </summary>
- public interface ICompositeRule
+ public interface ICompositeRule : IVectorRule
/// <summary>
- /// Gets or sets the legend label.
- /// </summary>
- /// <value>The legend label.</value>
- string LegendLabel { get; set; }
- /// <summary>
- /// Gets or sets the filter.
- /// </summary>
- /// <value>The filter.</value>
- string Filter { get; set; }
- /// <summary>
/// Gets or sets the composite symbolization.
/// </summary>
/// <value>The composite symbolization.</value>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/VectorLayerDefinitionImpl.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/VectorLayerDefinitionImpl.cs 2012-09-19 17:49:04 UTC (rev 7040)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/VectorLayerDefinitionImpl.cs 2012-09-21 14:45:33 UTC (rev 7041)
@@ -526,6 +526,41 @@
#endregion
+ #region IRuleCollection Members
+ IVectorRule IRuleCollection.GetRuleAt(int index)
+ return this.AreaRule[index];
+ public int IndexOfRule(IVectorRule rule)
+ var r = rule as AreaRuleType;
+ if (r != null)
+ return this.AreaRule.IndexOf(r);
+ return -1;
+ public bool MoveUp(IVectorRule rule)
+ if (r != null)
+ return CollectionUtil.MoveUp(this.AreaRule, r);
+ return false;
+ public bool MoveDown(IVectorRule rule)
+ if (r != null)
+ return CollectionUtil.MoveDown(this.AreaRule, r);
+ return false;
+ #endregion
internal static class CollectionUtil
@@ -579,7 +614,7 @@
[XmlIgnore]
- ITextSymbol IVectorRule.Label
+ ITextSymbol IBasicVectorRule.Label
get
@@ -677,13 +712,44 @@
#endregion
+ return this.PointRule[index];
+ var pr = rule as PointRuleType;
+ if (pr != null)
+ return this.PointRule.IndexOf(pr);
+ return -1;
+ if (pr != null)
+ return CollectionUtil.MoveUp(this.PointRule, pr);
+ return false;
+ if (pr != null)
+ return CollectionUtil.MoveDown(this.PointRule, pr);
+ return false;
+ #endregion
partial class PointRuleType : IPointRule
[XmlIgnore]
get
@@ -803,6 +869,37 @@
#endregion
+ return this.LineRule[index];
+ var lr = rule as LineRuleType;
+ if (lr != null)
+ return this.LineRule.IndexOf(lr);
+ return -1;
+ if (lr != null)
+ return CollectionUtil.MoveUp(this.LineRule, lr);
+ return false;
+ if (lr != null)
+ return CollectionUtil.MoveDown(this.LineRule, lr);
+ return false;
+ #endregion
partial class LineRuleType : ILineRule
@@ -819,6 +916,12 @@
+ [XmlIgnore]
+ int ILineRule.StrokeCount
+ get { return this.Items.Count; }
void ILineRule.SetStrokes(IEnumerable<IStroke> strokes)
Check.NotNull(strokes, "strokes"); //NOXLATE
@@ -846,7 +949,7 @@
[XmlIgnore]
get
@@ -2266,6 +2369,37 @@
#endregion
+ var cr = rule as CompositeRule;
+ if (cr != null)
+ return this.CompositeRule.IndexOf(cr);
+ return -1;
+ return this.CompositeRule[index];
+ if (cr != null)
+ return CollectionUtil.MoveUp(this.CompositeRule, cr);
+ return false;
+ if (cr != null)
+ return CollectionUtil.MoveDown(this.CompositeRule, cr);
+ return false;
+ #endregion
#endif
#endregion
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs 2012-09-19 17:49:04 UTC (rev 7040)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs 2012-09-21 14:45:33 UTC (rev 7041)
@@ -27,6 +27,10 @@
using OSGeo.MapGuide.ObjectModels;
using System.Xml;
using GeoAPI.Geometries;
+using OSGeo.MapGuide.ObjectModels.LayerDefinition;
+using System.Globalization;
+using OSGeo.MapGuide.MaestroAPI.Resource;
+using System.Text;
namespace OSGeo.MapGuide.MaestroAPI
@@ -834,5 +838,144 @@
return el["fdo:" + name]; //NOXLATE
return element;
+ public static void ExplodeThemeIntoFilteredLayers(ExplodeThemeOptions options, LengthyOperationProgressCallBack progress)
+ var conn = options.Layer.CurrentConnection;
+ var origLayerId = options.Layer.ResourceID;
+ string layerPrefix = options.LayerPrefix;
+ var origVl = (IVectorLayerDefinition)options.Layer.SubLayer;
+ var origRange = options.Range;
+ var origStyle = options.ActiveStyle;
+ int processed = 0;
+ for (int i = 0; i < origStyle.RuleCount; i++)
+ var currentRule = origStyle.GetRuleAt(i);
+ var newLayer = ObjectFactory.CreateDefaultLayer(conn, LayerType.Vector, options.Layer.ResourceVersion);
+ var vl = (IVectorLayerDefinition)newLayer.SubLayer;
+ vl.ResourceId = origVl.ResourceId;
+ vl.FeatureName = origVl.FeatureName;
+ vl.Geometry = origVl.Geometry;
+ //Set this layer's filter to be that of the current rule
+ vl.Filter = currentRule.Filter;
+ //A newly created Layer Definition will only have one scale range
+ var range = vl.GetScaleRangeAt(0);
+ range.MinScale = origRange.MinScale;
+ range.MaxScale = origRange.MaxScale;
+ //Composite styles aren't applicable, so remove them if they exist
+ var range2 = range as IVectorScaleRange2;
+ if (range2 != null)
+ range2.CompositeStyle = null;
+ //Invalidate geometry types not of the original style
+ switch (origStyle.StyleType)
+ case StyleType.Area:
+ range.LineStyle = null;
+ range.PointStyle = null;
+ IAreaRule ar = range.AreaStyle.GetRuleAt(0);
+ IAreaRule oar = (IAreaRule)currentRule;
+ if (oar.AreaSymbolization2D != null)
+ ar.AreaSymbolization2D = oar.AreaSymbolization2D.Clone();
+ if (oar.Label != null)
+ ar.Label = oar.Label.Clone();
+ break;
+ case StyleType.Line:
+ range.AreaStyle = null;
+ ILineRule lr = range.LineStyle.GetRuleAt(0);
+ ILineRule olr = (ILineRule)currentRule;
+ if (olr.StrokeCount > 0)
+ foreach (var stroke in olr.Strokes)
+ lr.AddStroke(stroke.Clone());
+ if (olr.Label != null)
+ lr.Label = olr.Label.Clone();
+ break;
+ case StyleType.Point:
+ IPointRule pr = range.PointStyle.GetRuleAt(0);
+ IPointRule opr = (IPointRule)currentRule;
+ if (opr.Label != null)
+ pr.Label = opr.Label.Clone();
+ if (opr.PointSymbolization2D != null)
+ pr.PointSymbolization2D = opr.PointSymbolization2D.Clone();
+ break;
+ string newResId = options.FolderId +
+ GenerateLayerName(options.LayerNameFormat, layerPrefix, GetScaleRangeStr(options.Range), i, currentRule) +
+ ".LayerDefinition";
+ conn.ResourceService.SaveResourceAs(newLayer, newResId);
+ processed++;
+ if (progress != null)
+ progress(null, new LengthyOperationProgressArgs(newResId, (processed / origStyle.RuleCount) * 100));
+ const string RESERVED_CHARS = "\\:*?\"<>|&'%=/";
+ public static string GenerateLayerName(string layerFormat, string layerName, string scaleRange, int i, IVectorRule rule)
+ StringBuilder sb = new StringBuilder(string.Format(layerFormat, layerName, scaleRange, string.IsNullOrEmpty(rule.LegendLabel) ? ("Rule" + i) : rule.LegendLabel)); //NOXLATE
+ foreach (char c in RESERVED_CHARS.ToCharArray())
+ sb.Replace(c, '_');
+ return sb.ToString().Trim();
+ public static string GetScaleRangeStr(IVectorScaleRange parentRange)
+ return string.Format("{0} to {1}", //NOXLATE
+ parentRange.MinScale.HasValue ? parentRange.MinScale.Value.ToString(CultureInfo.InvariantCulture) : "0", //NOXLATE
+ parentRange.MaxScale.HasValue ? parentRange.MaxScale.Value.ToString(CultureInfo.InvariantCulture) : "Infinity"); //NOXLATE
+ /// <summary>
+ /// Defines parameter for exploding a theme into filtered layers
+ /// </summary>
+ public class ExplodeThemeOptions
+ /// <summary>
+ /// The layer definition
+ /// </summary>
+ public ILayerDefinition Layer { get; set; }
+ /// <summary>
+ /// The active scale range
+ /// </summary>
+ public IVectorScaleRange Range { get; set; }
+ /// <summary>
+ /// The active style
+ /// </summary>
+ public IVectorStyle ActiveStyle { get; set; }
+ /// <summary>
+ /// The folder to create the layers in
+ /// </summary>
+ public string FolderId { get; set; }
+ /// <summary>
+ /// The layer name format string
+ /// </summary>
+ public string LayerNameFormat { get; set; }
+ /// <summary>
+ /// The layer prefix
+ /// </summary>
+ public string LayerPrefix { get; set; }
More information about the mapguide-commits
