[mapguide-commits] r7051 - in branches/2.4/MgDev/Desktop/MgDesktop: . System
svn_mapguide at osgeo.org
Thu Sep 27 10:28:09 PDT 2012
Author: jng
Date: 2012-09-27 10:28:09 -0700 (Thu, 27 Sep 2012)
New Revision: 7051
branches/2.4/MgDev/Desktop/MgDesktop/Platform.ini
branches/2.4/MgDev/Desktop/MgDesktop/System/PlatformInit.cpp
mg-desktop: Port over support for the PreCacheMaps configuration property
Modified: branches/2.4/MgDev/Desktop/MgDesktop/Platform.ini
(Binary files differ)
Modified: branches/2.4/MgDev/Desktop/MgDesktop/System/PlatformInit.cpp
--- branches/2.4/MgDev/Desktop/MgDesktop/System/PlatformInit.cpp 2012-09-27 16:50:27 UTC (rev 7050)
+++ branches/2.4/MgDev/Desktop/MgDesktop/System/PlatformInit.cpp 2012-09-27 17:28:09 UTC (rev 7051)
@@ -132,14 +132,6 @@
#endif
- // NOTE: Altering the dictionary path via MgCoordinateSystemCatalog::SetDictionaryDir() does not
- // update the internal library status. Possible defect?
- if (csCatalog->GetLibraryStatus() != LibraryStatus::lsInitialized)
- throw new MgCoordinateSystemInitializationFailedException(L"MgdPlatform::Initialize", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemInitializationFailedException", NULL);
// Load the Fdo library
STRING fdoLibrary = fdoPath;
@@ -164,6 +156,43 @@
// Initialize Stylizer callback mechanism for non-fatal FDO exceptions
MgdMappingUtil::InitializeStylizerCallback();
+ // Precache the specified maps, which will prime any related caches
+ STRING preCacheMaps;
+ pConfiguration->GetStringValue(MgdConfigProperties::GeneralPropertiesSection, MgdConfigProperties::GeneralPropertyPreCacheMaps, preCacheMaps, MgdConfigProperties::DefaultGeneralPropertyPreCacheMaps);
+ // Check if there is actually anything to precache
+ if (!preCacheMaps.empty())
+ Ptr<MgStringCollection> preCacheMapsCollection;
+ preCacheMapsCollection = MgStringCollection::ParseCollection(preCacheMaps, L",");
+ if (preCacheMapsCollection->GetCount() > 0)
+ ACE_DEBUG((LM_INFO, ACE_TEXT("%W\n"), MgResources::PreCacheMapsStart.c_str()));
+ for(INT32 i = 0; i < preCacheMapsCollection->GetCount(); i++)
+ try
+ STRING mapRes = preCacheMapsCollection->GetItem(i);
+ ACE_DEBUG((LM_INFO, ACE_TEXT(" %W "), mapRes.c_str()));
+ Ptr<MgResourceIdentifier> mapResId = new MgResourceIdentifier(mapRes);
+ Ptr<MgdMap> map = new MgdMap(mapResId, L"PreCacheMap");
+ ACE_DEBUG((LM_INFO, ACE_TEXT("<%W>\n"), MgResources::Success.c_str()));
+ catch(MgException* e)
+ // Skip map entries that fail to be cached
+ STRING message = e->GetDetails();
+ SAFE_RELEASE(e);
+ ACE_DEBUG((LM_INFO, ACE_TEXT("<%W> %W\n"), MgResources::Failure.c_str(), message.c_str()));
+ ACE_DEBUG((LM_INFO, ACE_TEXT("\n")));
MG_LOG_TRACE_ENTRY(L"MgdPlatform::Initialize()");
sm_init = true;
More information about the mapguide-commits
