[mapguide-commits] r7441 - branches/2.5/MgDev/Desktop/MgDesktop
svn_mapguide at osgeo.org
Wed Apr 3 04:34:15 PDT 2013
Author: jng
Date: 2013-04-03 04:34:14 -0700 (Wed, 03 Apr 2013)
New Revision: 7441
branches/2.5/MgDev/Desktop/MgDesktop/changelog.txt
mg-desktop: changelog.txt update
Modified: branches/2.5/MgDev/Desktop/MgDesktop/changelog.txt
--- branches/2.5/MgDev/Desktop/MgDesktop/changelog.txt 2013-04-03 11:19:23 UTC (rev 7440)
+++ branches/2.5/MgDev/Desktop/MgDesktop/changelog.txt 2013-04-03 11:34:14 UTC (rev 7441)
@@ -1,5 +1,18 @@
+API Changelog:
+ - New experimental Java wrapper API using same SWIG configuration and enhancements introduced with MapGuide RFC 129
+ - New behavior flag (8 = RenderBaseLayers) for MgdRenderingService::RenderDynamicOverlay, allows base layers to be rendered to a map overlay image
Viewer Changelog:
+ - Base Layers now included by default for any map overlay images rendered. Eliminates the need to use the UseRenderMapIfTiledLayersExist or ConvertTiledGroupsToNonTiled viewer properties and allows for pre-rendering hooks to be used with Tiled Maps.
+ - New overload of SelectByGeometry() that allows for a custom selection callback to be specified. This bypasses the normal selection notification mechanisms.
+2.4.0.7152 (Oct 24 2012)
+Viewer Changelog:
- Query component now supports a LayerList property allowing the list of queryable layers in the UI to be restricted to what is in this list.
- AppLayout component definitions can have their labels overridden by specifying a <Label> element in the ComponentDefinition.
- AppLayout engine support for string array property values
More information about the mapguide-commits
