[mapguide-commits] r7452 - in trunk/MgDev: Common/Foundation/Exception Server/src/Services/Feature
svn_mapguide at osgeo.org
Sun Apr 7 23:05:25 PDT 2013
Author: jng
Date: 2013-04-07 23:05:24 -0700 (Sun, 07 Apr 2013)
New Revision: 7452
trunk/MgDev/Common/Foundation/Exception/Exception.cpp
trunk/MgDev/Server/src/Services/Feature/OpUpdateFeatures.cpp
#2218: Merge r7448 from 2.5 branch
#2251: Merge r7447 from 2.5 branch
Modified: trunk/MgDev/Common/Foundation/Exception/Exception.cpp
--- trunk/MgDev/Common/Foundation/Exception/Exception.cpp 2013-04-06 18:37:27 UTC (rev 7451)
+++ trunk/MgDev/Common/Foundation/Exception/Exception.cpp 2013-04-08 06:05:24 UTC (rev 7452)
@@ -534,6 +534,8 @@
m_details = GetExceptionMessage(locale);
m_details += L"\n";
m_details += FormatDetails(locale);
+ m_details += L"\n";
+ m_details += FormatStackTrace(locale);
MG_CATCH_AND_RELEASE()
Modified: trunk/MgDev/Server/src/Services/Feature/OpUpdateFeatures.cpp
--- trunk/MgDev/Server/src/Services/Feature/OpUpdateFeatures.cpp 2013-04-06 18:37:27 UTC (rev 7451)
+++ trunk/MgDev/Server/src/Services/Feature/OpUpdateFeatures.cpp 2013-04-08 06:05:24 UTC (rev 7452)
@@ -55,6 +55,7 @@
ACE_DEBUG((LM_DEBUG, ACE_TEXT(" (%t) MgOpUpdateFeatures::Execute()\n")));
STRING partialFailureMsg;
+ Ptr<MgPropertyCollection> rowsAffected;
MG_LOG_OPERATION_MESSAGE(L"UpdateFeatures");
MG_FEATURE_SERVICE_TRY()
@@ -89,7 +90,7 @@
Validate();
// Execute the operation
- Ptr<MgPropertyCollection> rowsAffected = m_service->UpdateFeatures(resource, commands, useTransaction);
+ rowsAffected = m_service->UpdateFeatures(resource, commands, useTransaction);
// #649: Exceptions are only thrown in transactional cases (which will never reach here). For non-transactional cases,
// we check for any MgStringProperty instances. These are "serialized" FDO exception messages indicating failure for that
@@ -138,13 +139,18 @@
// Failed operation
MG_LOG_OPERATION_MESSAGE_ADD_STRING(MgResources::Failure.c_str());
- // Only thrown exceptions are logged, so for this partial failure to be logged into Error.log it needs to be
- // wrapped in an MgException to be thrown at the end of this method
+ // Only thrown exceptions are logged, so for this partial failure to be logged into Error.log
+ // we have to log it here
if (mgException == NULL && !partialFailureMsg.empty())
- MgStringCollection args;
- args.Add(partialFailureMsg);
- mgException = new MgFeatureServiceException(L"MgOpUpdateFeatures.Execute", __LINE__, __WFILE__, NULL, L"MgFormatInnerExceptionMessage", &args);
+ //NOTE: Serialized MgFdoException already has the stack trace, so stub an empty string to
+ //satisfy the logging macro
+ STRING sTrace = L"";
+ MG_LOG_EXCEPTION_ENTRY(partialFailureMsg, sTrace);
+ //DO NOT THROW A NEW EXCEPTION! We must respect the original contract of the API as perceived by the
+ //calling web tier code. That is: Write out the original MgPropertyCollection
+ EndExecution(rowsAffected);
More information about the mapguide-commits
