[mapguide-commits] r7459 - sandbox/jng/extra_stylization_funcs/Common/MapGuideCommon/Resources
svn_mapguide at osgeo.org
Wed Apr 17 09:14:50 PDT 2013
Author: jng
Date: 2013-04-17 09:14:50 -0700 (Wed, 17 Apr 2013)
New Revision: 7459
sandbox/jng/extra_stylization_funcs/Common/MapGuideCommon/Resources/mapguide_en.res
String bundle update
Modified: sandbox/jng/extra_stylization_funcs/Common/MapGuideCommon/Resources/mapguide_en.res
--- sandbox/jng/extra_stylization_funcs/Common/MapGuideCommon/Resources/mapguide_en.res 2013-04-17 15:40:19 UTC (rev 7458)
+++ sandbox/jng/extra_stylization_funcs/Common/MapGuideCommon/Resources/mapguide_en.res 2013-04-17 16:14:50 UTC (rev 7459)
@@ -439,17 +439,26 @@
MgFunctionDECAP_StringValueDescription = String to format
MgFunctionFEATURECLASS_Description = Returns the active feature class name
MgFunctionFEATUREID_Description = Returns the active feature Id
+MgFunctionFEATURESOURCE_Description = Returns the Feature Source resource id where the current feature originates from
+MgFunctionHTMLCOLOR_Description = HTML Color generation function
+MgFunctionHTMLCOLOR_RValueDescription = Red value
+MgFunctionHTMLCOLOR_GValueDescription = Green value
+MgFunctionHTMLCOLOR_BValueDescription = Blue value
MgFunctionIF_Description = If evaluator for style theming
MgFunctionIF_ConditionDescription = Boolean expression (filter) encapsulated in a string
MgFunctionIF_TrueValueDescription = Returned if condition is true
MgFunctionIF_FalseValueDescription = Returned if condition is false
MgFunctionLAYERID_Description = Returns the active layer Id
+MgFunctionLAYERDEFINITION_Description = Returns the Layer Definition resource id used for stylizing the current feature
MgFunctionLOOKUP_Description = Lookup table for style theming
MgFunctionLOOKUP_ExpressionDescription = Key expression
MgFunctionLOOKUP_DefaultValueDescription = Default value returned if expression does not evaluate to any of the keys
MgFunctionLOOKUP_IndexDescription = Lookup index that can be matched by the key expression
MgFunctionLOOKUP_ValueDescription = Value that is returned when the key expression matches the associated index
+MgFunctionMAPCENTERX_Description = Returns the X coordinate of the view center of the currently rendered map
+MgFunctionMAPCENTERY_Description = Returns the Y coordinate of the view center of the currently rendered map
MgFunctionMAPNAME_Description = Returns the active map name
+MgFunctionMAPSCALE_Description = Returns the scale of the currently rendered map
MgFunctionRANGE_Description = Range table for style theming
MgFunctionRANGE_ExpressionDescription = Key expression
MgFunctionRANGE_DefaultValueDescription = Default value returned if expression does not fall into any of the ranges
More information about the mapguide-commits
