[mapguide-commits] r7713 - in trunk/MgDev: Server/src/PostBuild Server/src/UnitTesting UnitTest/TestData/MappingService
svn_mapguide at osgeo.org
Fri Aug 2 00:32:30 PDT 2013
Author: jng
Date: 2013-08-02 00:32:30 -0700 (Fri, 02 Aug 2013)
New Revision: 7713
Added:
trunk/MgDev/UnitTest/TestData/MappingService/UT_Sheboygan_833.mdf
trunk/MgDev/Server/src/PostBuild/PostBuild.mak
trunk/MgDev/Server/src/UnitTesting/TestMisc.cpp
trunk/MgDev/Server/src/UnitTesting/TestMisc.h
#833: Add failing unit test
Modified: trunk/MgDev/Server/src/PostBuild/PostBuild.mak
--- trunk/MgDev/Server/src/PostBuild/PostBuild.mak 2013-08-02 06:36:23 UTC (rev 7712)
+++ trunk/MgDev/Server/src/PostBuild/PostBuild.mak 2013-08-02 07:32:30 UTC (rev 7713)
@@ -182,6 +182,7 @@
..\..\bin\UnitTestFiles\UT_SheboyganWithWatermark.mdf \
..\..\bin\UnitTestFiles\UT_PoweredByMapGuide.wdf \
..\..\bin\UnitTestFiles\UT_Sheboygan.mdf \
+ ..\..\bin\UnitTestFiles\UT_Sheboygan_833.mdf \
..\..\bin\UnitTestFiles\UT_HydrographicPolygons.sdf \
..\..\bin\UnitTestFiles\UT_HydrographicPolygons.fs \
..\..\bin\UnitTestFiles\UT_HydrographicPolygons.ldf \
@@ -442,6 +443,7 @@
@@ -702,6 +704,7 @@
@@ -962,6 +965,7 @@
@@ -1095,6 +1099,7 @@
if EXIST ..\..\bin\UnitTestFiles\UT_SheboyganWithWatermark.mdf del /F ..\..\bin\UnitTestFiles\UT_SheboyganWithWatermark.mdf
if EXIST ..\..\bin\UnitTestFiles\UT_PoweredByMapGuide.wdf del /F ..\..\bin\UnitTestFiles\UT_PoweredByMapGuide.wdf
if EXIST ..\..\bin\UnitTestFiles\UT_Sheboygan.mdf del /F ..\..\bin\UnitTestFiles\UT_Sheboygan.mdf
+ if EXIST ..\..\bin\UnitTestFiles\UT_Sheboygan_833.mdf del /F ..\..\bin\UnitTestFiles\UT_Sheboygan_833.mdf
if EXIST ..\..\bin\UnitTestFiles\UT_HydrographicPolygons.sdf del /F ..\..\bin\UnitTestFiles\UT_HydrographicPolygons.sdf
if EXIST ..\..\bin\UnitTestFiles\UT_HydrographicPolygons.fs del /F ..\..\bin\UnitTestFiles\UT_HydrographicPolygons.fs
if EXIST ..\..\bin\UnitTestFiles\UT_HydrographicPolygons.ldf del /F ..\..\bin\UnitTestFiles\UT_HydrographicPolygons.ldf
@@ -1223,6 +1228,7 @@
@@ -1351,6 +1357,7 @@
@@ -1477,6 +1484,7 @@
@@ -1730,6 +1738,7 @@
@@ -1989,6 +1998,7 @@
@@ -2248,6 +2258,7 @@
@@ -2507,6 +2518,7 @@
@@ -2639,6 +2651,7 @@
@@ -2766,6 +2779,7 @@
@@ -2893,6 +2907,7 @@
@@ -3018,6 +3033,7 @@
@@ -3115,6 +3131,7 @@
"..\..\..\UnitTest\TestData\MappingService\UT_SheboyganWithWatermark.mdf" :
"..\..\..\UnitTest\TestData\MappingService\UT_PoweredByMapGuide.wdf" :
"..\..\..\UnitTest\TestData\MappingService\UT_Sheboygan.mdf" :
+"..\..\..\UnitTest\TestData\MappingService\UT_Sheboygan_833.mdf" :
"..\..\..\UnitTest\TestData\MappingService\UT_HydrographicPolygons.sdf" :
"..\..\..\UnitTest\TestData\MappingService\UT_HydrographicPolygons.fs" :
"..\..\..\UnitTest\TestData\MappingService\UT_HydrographicPolygons.ldf" :
@@ -3294,6 +3311,10 @@
if NOT EXIST ..\..\bin\UnitTestFiles\nul mkdir ..\..\bin\UnitTestFiles
if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_Sheboygan.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_Sheboygan.mdf" ..\..\bin\UnitTestFiles\
+..\..\bin\UnitTestFiles\UT_Sheboygan_833.mdf : "..\..\..\UnitTest\TestData\MappingService\UT_Sheboygan_833.mdf"
+ if NOT EXIST ..\..\bin\UnitTestFiles\nul mkdir ..\..\bin\UnitTestFiles
+ if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_Sheboygan_833.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_Sheboygan_833.mdf" ..\..\bin\UnitTestFiles\
..\..\bin\UnitTestFiles\UT_HydrographicPolygons.sdf : "..\..\..\UnitTest\TestData\MappingService\UT_HydrographicPolygons.sdf"
if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_HydrographicPolygons.sdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_HydrographicPolygons.sdf" ..\..\bin\UnitTestFiles\
Modified: trunk/MgDev/Server/src/UnitTesting/TestMisc.cpp
--- trunk/MgDev/Server/src/UnitTesting/TestMisc.cpp 2013-08-02 06:36:23 UTC (rev 7712)
+++ trunk/MgDev/Server/src/UnitTesting/TestMisc.cpp 2013-08-02 07:32:30 UTC (rev 7713)
@@ -103,6 +103,11 @@
Ptr<MgByteReader> mdfrdr = mdfsrc->GetReader();
m_svcResource->SetResource(mapres, mdfrdr, NULL);
+ Ptr<MgResourceIdentifier> mapres2 = new MgResourceIdentifier(L"Library://UnitTests/Maps/Sheboygan_833.MapDefinition");
+ Ptr<MgByteSource> mdfsrc2 = new MgByteSource(L"../UnitTestFiles/UT_Sheboygan_833.mdf", false);
+ Ptr<MgByteReader> mdfrdr2 = mdfsrc2->GetReader();
+ m_svcResource->SetResource(mapres2, mdfrdr2, NULL);
//publish the layer definitions
Ptr<MgResourceIdentifier> ldfres1 = new MgResourceIdentifier(L"Library://UnitTests/Layers/HydrographicPolygons.LayerDefinition");
Ptr<MgByteSource> ldfsrc1 = new MgByteSource(L"../UnitTestFiles/UT_HydrographicPolygons.ldf", false);
@@ -194,6 +199,9 @@
Ptr<MgResourceIdentifier> mapres = new MgResourceIdentifier(L"Library://UnitTests/Maps/Sheboygan.MapDefinition");
m_svcResource->DeleteResource(mapres);
+ m_svcResource->DeleteResource(mapres2);
//delete the layer definitions
m_svcResource->DeleteResource(ldfres1);
@@ -484,6 +492,36 @@
+void TestMisc::TestCase_833()
+ try
+ Ptr<MgResourceIdentifier> mapRes1 = new MgResourceIdentifier(L"Library://UnitTests/Maps/Sheboygan_833.MapDefinition");
+ Ptr<MgMap> map1 = new MgMap(m_siteConnection);
+ map1->Create(mapRes1, L"UnitTestSheboygan1");
+ Ptr<MgLayerGroupCollection> groups = map1->GetLayerGroups();
+ Ptr<MgLayerCollection> layers = map1->GetLayers();
+ //These are the ones initially hidden from the legend
+ Ptr<MgLayerGroup> group = groups->GetItem(L"Municipal");
+ Ptr<MgLayerBase> layer = layers->GetItem(L"HydrographicPolygons");
+ CPPUNIT_ASSERT(!group->GetLegendLabel().empty());
+ CPPUNIT_ASSERT(!layer->GetLegendLabel().empty());
+ catch (MgException* e)
+ STRING message = e->GetDetails(TEST_LOCALE);
+ SAFE_RELEASE(e);
+ CPPUNIT_FAIL(MG_WCHAR_TO_CHAR(message.c_str()));
+ catch (...)
+ throw;
void TestMisc::TestCase_1304()
try
Modified: trunk/MgDev/Server/src/UnitTesting/TestMisc.h
--- trunk/MgDev/Server/src/UnitTesting/TestMisc.h 2013-08-02 06:36:23 UTC (rev 7712)
+++ trunk/MgDev/Server/src/UnitTesting/TestMisc.h 2013-08-02 07:32:30 UTC (rev 7713)
@@ -27,6 +27,7 @@
CPPUNIT_TEST(TestCase_CommonExceptionMessages);
CPPUNIT_TEST(TestCase_611);
+ CPPUNIT_TEST(TestCase_833);
CPPUNIT_TEST(TestCase_1304);
CPPUNIT_TEST(TestCase_MapLayerCollections);
@@ -44,6 +45,7 @@
void TestCase_CommonExceptionMessages();
void TestCase_611();
+ void TestCase_833();
void TestCase_1304();
void TestCase_MapLayerCollections();
Added: trunk/MgDev/UnitTest/TestData/MappingService/UT_Sheboygan_833.mdf
--- trunk/MgDev/UnitTest/TestData/MappingService/UT_Sheboygan_833.mdf (rev 0)
+++ trunk/MgDev/UnitTest/TestData/MappingService/UT_Sheboygan_833.mdf 2013-08-02 07:32:30 UTC (rev 7713)
@@ -0,0 +1,50 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<MapDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="MapDefinition-1.0.0.xsd">
+ <Name>New Map</Name>
+ <CoordinateSystem>GEOGCS["WGS84 Lat/Long's, Degrees, -180 ==> +180",DATUM["D_WGS_1984",SPHEROID["World_Geodetic_System_of_1984",6378137,298.257222932867]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]]</CoordinateSystem>
+ <Extents>
+ <MinX>-87.770746109180749</MinX>
+ <MaxX>-87.6957605384125</MaxX>
+ <MinY>43.686899685828813</MinY>
+ <MaxY>43.805498742206247</MaxY>
+ </Extents>
+ <BackgroundColor>FFFFFFFF</BackgroundColor>
+ <MapLayer>
+ <Name>Rail</Name>
+ <ResourceId>Library://UnitTests/Layers/Rail.LayerDefinition</ResourceId>
+ <Selectable>true</Selectable>
+ <ShowInLegend>true</ShowInLegend>
+ <LegendLabel>Rail</LegendLabel>
+ <ExpandInLegend>true</ExpandInLegend>
+ <Visible>true</Visible>
+ <Group />
+ </MapLayer>
+ <MapLayer>
+ <Name>HydrographicPolygons</Name>
+ <ResourceId>Library://UnitTests/Layers/HydrographicPolygons.LayerDefinition</ResourceId>
+ <ShowInLegend>false</ShowInLegend>
+ <LegendLabel>HydrographicPolygons</LegendLabel>
+ <Group>Municipal</Group>
+ </MapLayer>
+ <MapLayer>
+ <Name>Parcels</Name>
+ <ResourceId>Library://UnitTests/Layers/Parcels.LayerDefinition</ResourceId>
+ <LegendLabel>Parcels</LegendLabel>
+ </MapLayer>
+ <MapLayerGroup>
+ <Name>Municipal</Name>
+ <LegendLabel>Municipal</LegendLabel>
+ <Group />
+ </MapLayerGroup>
+</MapDefinition>
More information about the mapguide-commits
