[mapguide-commits] r7744 - sandbox/jng/stylization_refactor/Common/Stylization
svn_mapguide at osgeo.org
Wed Aug 7 09:29:49 PDT 2013
Author: jng
Date: 2013-08-07 09:29:48 -0700 (Wed, 07 Aug 2013)
New Revision: 7744
sandbox/jng/stylization_refactor/Common/Stylization/DefaultStylizer.cpp
sandbox/jng/stylization_refactor/Common/Stylization/DefaultStylizer.h
sandbox/jng/stylization_refactor/Common/Stylization/FdoEvaluator.h
sandbox/jng/stylization_refactor/Common/Stylization/GeometryAdapter.cpp
sandbox/jng/stylization_refactor/Common/Stylization/GeometryAdapter.h
sandbox/jng/stylization_refactor/Common/Stylization/SE_Evaluator.h
sandbox/jng/stylization_refactor/Common/Stylization/Stylizer.h
This submission includes the following changes:
- Remove FdoExpression/FdoFilter cache cleanup code from GeometryAdapter
- Update signature of Stylizer::SetGeometryAdapter to use LineBuffer::GeometryType instead of FdoGeometryType (the enum values are the same)
- Remove unused GetRulesFilter method from DefaultStylizer
Modified: sandbox/jng/stylization_refactor/Common/Stylization/DefaultStylizer.cpp
--- sandbox/jng/stylization_refactor/Common/Stylization/DefaultStylizer.cpp 2013-08-07 15:57:40 UTC (rev 7743)
+++ sandbox/jng/stylization_refactor/Common/Stylization/DefaultStylizer.cpp 2013-08-07 16:29:48 UTC (rev 7744)
@@ -466,7 +466,7 @@
// WARNING: given pointer to the new stylizer will be destroyed
// by the stylizer (in its destructor)
-void DefaultStylizer::SetGeometryAdapter(FdoGeometryType type, GeometryAdapter* stylizer)
+void DefaultStylizer::SetGeometryAdapter(LineBuffer::GeometryType type, GeometryAdapter* stylizer)
GeometryAdapter* old = (GeometryAdapter*)m_hGeomStylizers[type];
delete old;
@@ -552,84 +552,4 @@
MdfModel::VectorScaleRange* scaleRange = Stylizer::FindScaleRange(*scaleRanges, mapScale);
return (NULL != scaleRange);
-FdoFilter* DefaultStylizer::GetRulesFilter(MdfModel::VectorLayerDefinition* layer,
- double mapScale)
- // look through the scale ranges to find a valid one
- MdfModel::VectorScaleRangeCollection* scaleRanges = layer->GetScaleRanges();
- MdfModel::VectorScaleRange* scaleRange = Stylizer::FindScaleRange(*scaleRanges, mapScale);
- // no range -- fast return, the layer is invisible at this scale
- if (NULL == scaleRange)
- return NULL;
- // extract all the composite styles once
- MdfModel::FeatureTypeStyleCollection* ftsc = scaleRange->GetFeatureTypeStyles();
- std::vector<CompositeTypeStyle*> compTypeStyles;
- for (int i=0; i<ftsc->GetCount(); ++i)
- MdfModel::FeatureTypeStyle* fts = ftsc->GetAt(i);
- if (FeatureTypeStyleVisitor::DetermineFeatureTypeStyle(fts) == FeatureTypeStyleVisitor::ftsComposite)
- compTypeStyles.push_back((CompositeTypeStyle*)fts);
- size_t numTypeStyles = compTypeStyles.size();
- _ASSERT(numTypeStyles > 0);
- if (numTypeStyles == 0)
- return NULL;
- // Build a filter by combining the filters for each rule
- MdfString filterstr;
- for (size_t i=0; i<numTypeStyles; ++i)
- CompositeTypeStyle* style = compTypeStyles.at(i);
- RuleCollection* rulecoll = style->GetRules();
- int nRules = rulecoll->GetCount();
- for (int j = nRules-1; j >= 0; --j)
- CompositeRule* r = static_cast<CompositeRule*>(rulecoll->GetAt(j));
- const MdfString& temp = r->GetFilter();
- // If any of the rules is the default rule, return an empty filter because the
- // default rule will match all features, even those not matched by other rules.
- if (temp.empty())
- return NULL;
- else
- if (filterstr.empty())
- filterstr.append(L"("); // start filter
- else
- filterstr.append(L" OR ");
- filterstr.append(temp.c_str());
- filterstr.append(L")");
- // Output filter
- FdoFilter* filter = NULL;
- if (!filterstr.empty())
- filterstr.append(L")"); // close filter
- try
- filter = FdoFilter::Parse(filterstr.c_str());
- catch (FdoException* e)
- e->Release();
- return filter;
\ No newline at end of file
Modified: sandbox/jng/stylization_refactor/Common/Stylization/DefaultStylizer.h
--- sandbox/jng/stylization_refactor/Common/Stylization/DefaultStylizer.h 2013-08-07 15:57:40 UTC (rev 7743)
+++ sandbox/jng/stylization_refactor/Common/Stylization/DefaultStylizer.h 2013-08-07 16:29:48 UTC (rev 7744)
@@ -66,13 +66,11 @@
int saveWidth,
int saveHeight);
- STYLIZATION_API virtual void SetGeometryAdapter(FdoGeometryType type, GeometryAdapter* stylizer);
+ STYLIZATION_API virtual void SetGeometryAdapter(LineBuffer::GeometryType type, GeometryAdapter* stylizer);
STYLIZATION_API virtual bool HasValidScaleRange(MdfModel::VectorLayerDefinition* layer,
double mapScale);
- STYLIZATION_API virtual FdoFilter* GetRulesFilter(MdfModel::VectorLayerDefinition* layer,
- double mapScale);
private:
int StylizeVLHelper(MdfModel::VectorLayerDefinition* layer,
MdfModel::VectorScaleRange* scaleRange,
Modified: sandbox/jng/stylization_refactor/Common/Stylization/FdoEvaluator.h
--- sandbox/jng/stylization_refactor/Common/Stylization/FdoEvaluator.h 2013-08-07 15:57:40 UTC (rev 7743)
+++ sandbox/jng/stylization_refactor/Common/Stylization/FdoEvaluator.h 2013-08-07 16:29:48 UTC (rev 7744)
@@ -24,6 +24,10 @@
#include "Renderer.h"
#include <map>
+// Provides services for evaluating FDO expressions and filters
class FdoEvaluator : public SE_Evaluator
public:
@@ -41,6 +45,13 @@
void ProcessStylizerException(FdoException* exception, int line, wchar_t* file);
FdoPtr<FdoExpressionEngine> m_exec;
+ // BOGUS:
+ // TODO: we use pointer to the MDF strings for caching --
+ // this may be risky but all caching in the stylizer is
+ // based on the MDF pointer staying the same throughout the
+ // stylization process
// FdoFilter cache
std::map<const void*, FdoFilter*> m_hFilterCache;
// FdoExpression cache
Modified: sandbox/jng/stylization_refactor/Common/Stylization/GeometryAdapter.cpp
--- sandbox/jng/stylization_refactor/Common/Stylization/GeometryAdapter.cpp 2013-08-07 15:57:40 UTC (rev 7743)
+++ sandbox/jng/stylization_refactor/Common/Stylization/GeometryAdapter.cpp 2013-08-07 16:29:48 UTC (rev 7744)
@@ -35,25 +35,7 @@
GeometryAdapter::~GeometryAdapter()
- // free up cached fdo filters
- for (std::map<const void*, FdoFilter*>::iterator iter = m_hFilterCache.begin();
- iter != m_hFilterCache.end(); ++iter)
- if (iter->second)
- iter->second->Release();
- m_hFilterCache.clear();
- // free up cached fdo expressions
- for (std::map<const void*, FdoExpression*>::iterator iter = m_hExpressionCache.begin();
- iter != m_hExpressionCache.end(); ++iter)
- if (iter->second)
- m_hExpressionCache.clear();
Modified: sandbox/jng/stylization_refactor/Common/Stylization/GeometryAdapter.h
--- sandbox/jng/stylization_refactor/Common/Stylization/GeometryAdapter.h 2013-08-07 15:57:40 UTC (rev 7743)
+++ sandbox/jng/stylization_refactor/Common/Stylization/GeometryAdapter.h 2013-08-07 16:29:48 UTC (rev 7744)
@@ -90,18 +90,6 @@
SE_Evaluator* m_eval;
LineBufferPool* m_lbPool;
- // BOGUS:
- // TODO: we use pointer to the MDF strings for caching --
- // this may be risky but all caching in the stylizer is
- // based on the MDF pointer staying the same throughout the
- // stylization process
- // FdoFilter cache
- std::map<const void*, FdoFilter*> m_hFilterCache;
- // FdoExpression cache
- std::map<const void*, FdoExpression*> m_hExpressionCache;
#endif
Modified: sandbox/jng/stylization_refactor/Common/Stylization/SE_Evaluator.h
--- sandbox/jng/stylization_refactor/Common/Stylization/SE_Evaluator.h 2013-08-07 15:57:40 UTC (rev 7743)
+++ sandbox/jng/stylization_refactor/Common/Stylization/SE_Evaluator.h 2013-08-07 16:29:48 UTC (rev 7744)
@@ -21,6 +21,10 @@
#include "Stylization.h"
#include "RendererStyles.h"
+// Provides services for evaluating expressions and filters
class SE_Evaluator
public:
Modified: sandbox/jng/stylization_refactor/Common/Stylization/Stylizer.h
--- sandbox/jng/stylization_refactor/Common/Stylization/Stylizer.h 2013-08-07 15:57:40 UTC (rev 7743)
+++ sandbox/jng/stylization_refactor/Common/Stylization/Stylizer.h 2013-08-07 16:29:48 UTC (rev 7744)
@@ -88,7 +88,7 @@
///<summary>
/// Allows a user to set a custom stylization object for a given geometry type.
///</summary>
- virtual void SetGeometryAdapter(FdoGeometryType type, GeometryAdapter* stylizer) = 0;
+ virtual void SetGeometryAdapter(LineBuffer::GeometryType type, GeometryAdapter* stylizer) = 0;
STYLIZATION_API static MdfModel::VectorScaleRange* FindScaleRange(MdfModel::VectorScaleRangeCollection& src, double mapScale);
STYLIZATION_API static MdfModel::GridScaleRange* FindScaleRange(MdfModel::GridScaleRangeCollection& src, double mapScale);
More information about the mapguide-commits
