[mapguide-commits] r7786 - in trunk/MgDev: Common/MapGuideCommon/Resources Web/src/HttpHandler
svn_mapguide at osgeo.org
Tue Aug 20 08:33:39 PDT 2013
Author: jng
Date: 2013-08-20 08:33:39 -0700 (Tue, 20 Aug 2013)
New Revision: 7786
trunk/MgDev/Common/MapGuideCommon/Resources/mapguide_en.res
trunk/MgDev/Web/src/HttpHandler/HttpSelectFeatures.cpp
trunk/MgDev/Web/src/HttpHandler/HttpSelectFeaturesSpatially.cpp
trunk/MgDev/Web/src/HttpHandler/HttpWfsGetFeature.cpp
trunk/MgDev/Web/src/HttpHandler/OgcWfsServer.cpp
trunk/MgDev/Web/src/HttpHandler/ResponseStream.h
#2342: Fix the broken test cases
- SELECTFEATURE/SELECTAGGREGATES
- Default to text/xml if no format specified (PHP test runner doesn't specify FORMAT for some tests and is expecting a non-exception response)
- WFS GetFeature
- Throw exception on malformed WFS feature type names (ie. No ":" in the type name)
- Throw exception if WFS feature type name could not be resolved to a Feature Source ID
- Make MgGetWfsFeaturesResponseStream an actual stream inheriting from MgHttpResponseStream with an extra MgByteReader property (that a successful GetFeature request will set). This way, any exceptions written by MgOgcServer::ServiceExceptionReportResponse() will be captured. When it comes to sending back the actual result, the GetFeature response will be returned if it exists, otherwise whatever the MgOgcServer wrote will be returned.
Modified: trunk/MgDev/Common/MapGuideCommon/Resources/mapguide_en.res
--- trunk/MgDev/Common/MapGuideCommon/Resources/mapguide_en.res 2013-08-20 15:15:32 UTC (rev 7785)
+++ trunk/MgDev/Common/MapGuideCommon/Resources/mapguide_en.res 2013-08-20 15:33:39 UTC (rev 7786)
@@ -159,6 +159,7 @@
MgArgumentsMismatch = The arguments needed do not match the arguments provided.
MgArgumentOutOfRange = Argument out of range [%1, %2]: %3
MgClassWOIdentity = A class definition has no identity property.
+MgCannotResolveFeatureSourceFromWfsTypeName = Could not resolve the Feature Source from the given WFS Type Name: %1
MgCollectionEmpty = The collection cannot be empty.
MgCoordinateSystemNotReadyException = The object is not ready for this operation.
MgConfigurationPropertyLengthIsInvalid = The value of property %1 under section %2 is %3. Its length must be %4
Modified: trunk/MgDev/Web/src/HttpHandler/HttpSelectFeatures.cpp
--- trunk/MgDev/Web/src/HttpHandler/HttpSelectFeatures.cpp 2013-08-20 15:15:32 UTC (rev 7785)
+++ trunk/MgDev/Web/src/HttpHandler/HttpSelectFeatures.cpp 2013-08-20 15:33:39 UTC (rev 7786)
@@ -38,6 +38,10 @@
Ptr<MgHttpRequestParam> params = hRequest->GetRequestParam();
m_resId = params->GetParameterValue(MgHttpResourceStrings::reqFeatResourceId);
m_className = params->GetParameterValue(MgHttpResourceStrings::reqFeatClass);
+ //Default to xml if not specified
+ if (m_responseFormat.empty())
+ m_responseFormat = MgMimeType::Xml;
/// <summary>
Modified: trunk/MgDev/Web/src/HttpHandler/HttpSelectFeaturesSpatially.cpp
--- trunk/MgDev/Web/src/HttpHandler/HttpSelectFeaturesSpatially.cpp 2013-08-20 15:15:32 UTC (rev 7785)
+++ trunk/MgDev/Web/src/HttpHandler/HttpSelectFeaturesSpatially.cpp 2013-08-20 15:33:39 UTC (rev 7786)
@@ -48,6 +48,10 @@
m_operation = atoi(MgUtil::WideCharToMultiByte(spatialOp).c_str());
m_geometry = params->GetParameterValue(MgHttpResourceStrings::reqFeatGeometry);
/// <summary>
Modified: trunk/MgDev/Web/src/HttpHandler/HttpWfsGetFeature.cpp
--- trunk/MgDev/Web/src/HttpHandler/HttpWfsGetFeature.cpp 2013-08-20 15:15:32 UTC (rev 7785)
+++ trunk/MgDev/Web/src/HttpHandler/HttpWfsGetFeature.cpp 2013-08-20 15:33:39 UTC (rev 7786)
@@ -23,6 +23,9 @@
#include "OgcFramework.h"
#include "OgcWfsServer.h"
+extern CPSZ kpszQueryStringTypeName;
+extern CPSZ kpszExceptionMessageMalformedRequestedType;
// MgException* or derivative //
// | MgOgcWfsException::kpsz... //
@@ -34,7 +37,7 @@
ogc_server.ServiceExceptionReportResponse( \
MgOgcWfsException(MgOgcWfsException::ogc_exception_code, \
sReport.c_str() )); \
- Ptr<MgByteReader> capabilities = responseStream.GetReader(); \
+ Ptr<MgByteReader> capabilities = responseStream.Stream().GetReader(); \
hResult->SetResultObject(capabilities, capabilities->GetMimeType()); \
e->Release(); \
@@ -49,7 +52,7 @@
MgOgcWfsException(MgOgcWfsException::kpszInternalError, \
_("Unexpected exception was thrown. No additional details available.")));\
@@ -130,16 +133,27 @@
try
wfsServer.ProcessRequest(this);
+ //We have the GetFeature response
+ if (responseStream.HasReader())
+ // Obtain the response byte reader
+ Ptr<MgByteReader> responseReader = responseStream.GetReader();
- // Obtain the response byte reader
- Ptr<MgByteReader> responseReader = responseStream.GetReader();
+ Ptr<MgHttpHeader> respHeader = hResponse.GetHeader();
+ //This is the "hint" to chunk the MgByteReader content
+ respHeader->AddHeader(MgHttpResourceStrings::hrhnTransfer_Encoding, MgHttpResourceStrings::hrhnChunked);
- Ptr<MgHttpHeader> respHeader = hResponse.GetHeader();
- //This is the "hint" to chunk the MgByteReader content
- respHeader->AddHeader(MgHttpResourceStrings::hrhnTransfer_Encoding, MgHttpResourceStrings::hrhnChunked);
+ // Set the result
+ hResult->SetResultObject(responseReader, responseReader->GetMimeType());
+ else //Write out whatever the MgOgcWfsServer has written
+ // Slurp the results.
+ Ptr<MgByteReader> response = responseStream.Stream().GetReader();
- // Set the result
- hResult->SetResultObject(responseReader, responseReader->GetMimeType());
+ // Set the result
+ hResult->SetResultObject(response, response->GetMimeType());
CATCH_MGEXCEPTION_HANDLE_AS_OGC_WFS(MgException,kpszInternalError,wfsServer)
@@ -292,7 +306,19 @@
// This *is* already the WFS GetFeature response. There is nothing to post-process through the XML templates!
+ else //Cannot resolve feature source from feature type name
+ MgStringCollection args;
+ args.Add(sFeatureType);
+ throw new MgInvalidArgumentException(L"MgHttpWfsGetFeature.AcquireResponseData", __LINE__, __WFILE__, NULL, L"MgCannotResolveFeatureSourceFromWfsTypeName", &args);
+ else //Feature type name is malformed. We expected the form <namespace>:<class_name>
+ wfsServer->ServiceExceptionReportResponse(MgOgcWfsException(MgOgcWfsException::kpszInvalidParameterValue,
+ kpszExceptionMessageMalformedRequestedType,
+ kpszQueryStringTypeName));
Modified: trunk/MgDev/Web/src/HttpHandler/OgcWfsServer.cpp
--- trunk/MgDev/Web/src/HttpHandler/OgcWfsServer.cpp 2013-08-20 15:15:32 UTC (rev 7785)
+++ trunk/MgDev/Web/src/HttpHandler/OgcWfsServer.cpp 2013-08-20 15:33:39 UTC (rev 7786)
@@ -40,6 +40,7 @@
CPSZ kpszQueryStringGetFeatureOutputFormatDefault_1_1_0 = _("Formats.GetFeature.default.1.1.0");
CPSZ kpszPiGetFeatureCollection = _("GetFeatureCollection");
CPSZ kpszPiGetFeatureCollectionDefaultFormat = _("&GetFeatureCollection.xml;");
+CPSZ kpszQueryStringTypeName = _("typename");
CPSZ kpszQueryStringAcceptVersions = _("acceptversions");
CPSZ kpszQueryStringSections = _("sections");
@@ -65,6 +66,7 @@
CPSZ kpszExceptionMessageWfsVersionNegotiationFailed = _("Requested version is unsupported in AcceptVersions"); //Localize
CPSZ kpszExceptionMessageWfsInvalidVersion = _("Version number specified must correspond to a version supported by the service."); // Localize
CPSZ kpszExceptionMessageWfsInvalidService = _("Invalid parameter value for SERVICE"); //Localize
+CPSZ kpszExceptionMessageMalformedRequestedType = _("Encountered malformed typeName in request"); //Localize
CPSZ kpszInternalErrorMissingGetFeatureRequestParams = _("Internal Error: Missing WFS GetFeature request parameters."); // Localize
Modified: trunk/MgDev/Web/src/HttpHandler/ResponseStream.h
--- trunk/MgDev/Web/src/HttpHandler/ResponseStream.h 2013-08-20 15:15:32 UTC (rev 7785)
+++ trunk/MgDev/Web/src/HttpHandler/ResponseStream.h 2013-08-20 15:33:39 UTC (rev 7786)
@@ -52,31 +52,6 @@
-// This is not a true stream. It's just a temporary MgByteReader
-// placeholder that passes the CStream type test allowing us to
-// pass this into a MgOgcWfsServer instance.
-class MgGetWfsFeaturesResponseStream : public CStream
-public:
- MgGetWfsFeaturesResponseStream()
- m_reader = NULL;
- ~MgGetWfsFeaturesResponseStream()
- m_reader = NULL;
- virtual void SetContentType(CPSZ pszContentTypeMime) { }
- virtual long Write(CPSZ pszBuffer,size_t uBytesToWrite,size_t* puBytesWritten) { return -1; }
- void SetReader(MgByteReader* reader) { m_reader = SAFE_ADDREF(reader); }
- MgByteReader* GetReader() { return SAFE_ADDREF(m_reader); }
-private:
- MgByteReader* m_reader;
class MgHttpResponseStream: public CStream
public:
@@ -86,6 +61,12 @@
m_pStream = new MgByteSource(m_pStore);
+ virtual ~MgHttpResponseStream()
+ m_pStream = NULL;
+ m_pStore = NULL;
m_pStream->SetMimeType(pszContentTypeMime);
@@ -121,9 +102,33 @@
return *m_pStream;
-private:
+protected:
Ptr<MgByte> m_pStore;
Ptr<MgByteSource> m_pStream;
+// This is a specialized response stream for GetFeature that allows us to attach
+// the MgFeatureService.GetWfsFeature() response directly (which the GetFeature operation will
+// check for), while still retaining the ability to have any exception responses written to it
+// by the MgOgcServer instance.
+class MgGetWfsFeaturesResponseStream : public MgHttpResponseStream
+public:
+ MgGetWfsFeaturesResponseStream() : MgHttpResponseStream()
+ m_reader = NULL;
+ virtual ~MgGetWfsFeaturesResponseStream()
+ SAFE_RELEASE(m_reader);
+ bool HasReader() { return NULL != m_reader; }
+ void SetReader(MgByteReader* reader) { m_reader = SAFE_ADDREF(reader); }
+ MgByteReader* GetReader() { return SAFE_ADDREF(m_reader); }
+private:
+ MgByteReader* m_reader;
#endif//_CgiResponseStream_h
More information about the mapguide-commits
