[mapguide-commits] r7794 -	trunk/MgDev/Doc/samples/ol2samples/selection
    svn_mapguide at osgeo.org
    Wed Aug 21 08:40:33 PDT 2013
Author: jng
Date: 2013-08-21 08:40:32 -0700 (Wed, 21 Aug 2013)
New Revision: 7794
Added:
   trunk/MgDev/Doc/samples/ol2samples/selection/index.html
#2344: Add OpenLayers selection sample. This uses v2.6 CREATERUNTIMEMAP and QUERYMAPFEATURES operations to allow for an OpenLayers MapGuide viewer with interaction and inspection of selected features without any .net/Java/PHP glue code required on the Web Tier.
Added: trunk/MgDev/Doc/samples/ol2samples/selection/index.html
--- trunk/MgDev/Doc/samples/ol2samples/selection/index.html	                        (rev 0)
+++ trunk/MgDev/Doc/samples/ol2samples/selection/index.html	2013-08-21 15:40:32 UTC (rev 7794)
@@ -0,0 +1,354 @@
+<html>
+    <head>
+        <title>Basic Sheboygan un-tiled map example with selection</title>
+        <link rel="stylesheet" href="../assets/theme/default/style.css" />
+        <style type="text/css">
+            body { font-family: Verdana; font-size: 0.9em; }
+            #error { color: red; }
+            #wrap { width: 1150; }
+            #map { width: 650; height: 500; float: right; }
+            #details { width: 250; height: 500; overflow: auto; display: block-inline; float: left; }
+            #selInfo { width: 250; height: 500; overflow: auto; display: block-inline; float: right; }
+            #rootList { list-style-type: none; margin-left: -20px; }
+            #rootList li { list-style-type: none; }
+            #selInfoTree { list-style-type: none; margin-left: -20px; }
+            #selInfoTree li { list-style-type: none; margin-left: -20px; }
+            #selMessage { color: red; font-weight: bolder; }
+            .olControlMousePosition { background: #ffff66; font-size: 0.6em !important; padding: 2px; }
+        </style>
+        <script type="text/javascript" src="../assets/jquery-1.10.2.min.js"></script>
+        <script type="text/javascript" src="../assets/OpenLayers.js"></script>
+        <script type="text/javascript" src="../assets/legend.js"></script>
+        <script type="text/javascript">
+        //This sample is assumed to be hosted at http://servername/mapguide/ol2samples/untiled/index.html
+        var mapAgentUrl = "../../mapagent/mapagent.fcgi";
+        //Various features you can include in the CREATERUNTIMEMAP response.
+        var REQ_NONE = 0;                   //Nothing. This the default.
+        var REQ_LAYER_STRUCTURE = 1;        //Information about layers and groups (required for the mask values below to have any effect)
+        var REQ_LAYER_ICONS = 2;            //Icons for each layer (has no effect if REQ_LAYER_STRUCTURE is not in the bitmask)
+        var REQ_LAYER_FEATURE_SOURCE = 4;   //Feature Source information for each layer (has no effect if REQ_LAYER_STRUCTURE is not in the bitmask)
+        var gMimeType = null;
+        var map = null;
+        var mgLayer = null;
+        var selLayer = null;
+        var selRectControl = null;
+        var sessionId = null;
+        var mapName = null;
+        var legend = null;
+        var ptBuffer = 2;
+        var bSelecting = false;
+        var navControl = null;
+        var zoomControl = null;
+        var wktFormat = null;
+        $(document).ready(function() {
+            OpenLayers.Control.DragPan.prototype.enableKinetic = false;
+            //Have a play with the bitmask values to see the differences in JSON payload size
+            //and to see how our legend control gracefully handles such situations
+            //createMap(REQ_NONE);
+            //createMap(REQ_LAYER_STRUCTURE);
+            createMap(REQ_LAYER_STRUCTURE | REQ_LAYER_FEATURE_SOURCE | REQ_LAYER_ICONS);
+        function createMap(reqFeatures) {
+            $.getJSON(mapAgentUrl, {
+                "OPERATION": "CREATERUNTIMEMAP",
+                "VERSION": "2.6.0",
+                "MAPDEFINITION": "Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition",
+                "USERNAME": "Anonymous", //Or you can use "SESSION": "<my session id>"
+                "REQUESTEDFEATURES": reqFeatures,
+                //Optional parameters you can specify and/or experiment with
+                //"ICONFORMAT": "GIF",    //Uncomment to override desired image format (default: PNG)
+                //"ICONWIDTH": 32,         //Uncomment to override desired icon width (default: 16)
+                //"ICONHEIGHT": 32,        //Uncomment to override desired icon height (default: 16)
+                //"ICONSPERSCALERANGE": 3, //Uncomment to observe theme compression for themes exceeding this number of rules (default: 25)
+                //"TARGETMAPNAME": "MyRuntimeMapForOpenLayers", //Uncomment if you require a specific map name be given (default: inferred from Map Definition)
+                "FORMAT": "application/json"
+            }, function(data, textStatus, jqXHR) {
+                loadMap(data);
+            }).error(function(jqXHR, textStatus, errorThrown) {
+                $("#error").html(jqXHR.responseText);
+        function loadMap(rtMapInfo) {
+            var extent = new OpenLayers.Bounds(
+                parseFloat(rtMapInfo.RuntimeMap.Extents[0].LowerLeftCoordinate[0].X[0]),
+                parseFloat(rtMapInfo.RuntimeMap.Extents[0].LowerLeftCoordinate[0].Y[0]),
+                parseFloat(rtMapInfo.RuntimeMap.Extents[0].UpperRightCoordinate[0].X[0]),
+                parseFloat(rtMapInfo.RuntimeMap.Extents[0].UpperRightCoordinate[0].Y[0]));
+            wktFormat = new OpenLayers.Format.WKT();
+            navControl = new OpenLayers.Control.Navigation();
+            zoomControl = new OpenLayers.Control.ZoomBox({alwaysZoom:true});
+            OpenLayers.Control.CustomNavToolbar = OpenLayers.Class(OpenLayers.Control.Panel, {
+                 * Constructor: OpenLayers.Control.NavToolbar
+                 * Add our two mousedefaults controls.
+                 * Parameters:
+                 * options - {Object} An optional object whose properties will be used
+                 *     to extend the control.
+                initialize: function(options) {
+                    OpenLayers.Control.Panel.prototype.initialize.apply(this, [options]);
+                    this.addControls([
+                      navControl,
+                      //Here it come
+                      zoomControl
+                    // To make the custom navtoolbar use the regular navtoolbar style
+                    this.displayClass = 'olControlNavToolbar'
+                 * Method: draw
+                 * calls the default draw, and then activates mouse defaults.
+                draw: function() {
+                    var div = OpenLayers.Control.Panel.prototype.draw.apply(this, arguments);
+                    this.defaultControl = this.controls[0];
+                    return div;
+            var mapOptions = {
+                theme: null,
+                maxExtent: extent,
+                maxResolution: 'auto',
+                controls: [
+                    new OpenLayers.Control.Navigation(),
+                    new OpenLayers.Control.Attribution(),
+                    new OpenLayers.Control.Zoom(),
+                    new OpenLayers.Control.ScaleLine(),
+                    new OpenLayers.Control.MousePosition(),
+                    new OpenLayers.Control.CustomNavToolbar({alwaysZoom:true})
+            if (rtMapInfo.RuntimeMap.CoordinateSystem[0].EpsgCode[0].length > 0) {
+                mapOptions.projection = "EPSG:" + rtMapInfo.RuntimeMap.CoordinateSystem[0].EpsgCode[0];
+            var options = {
+                isBaseLayer: true,
+                transitionEffect: "resize",
+                buffer: 1,
+                useOverlay: true,
+                useAsyncOverlay: true,
+                singleTile: true
+            var selOptions = {
+                isBaseLayer: false,
+                buffer: 1,
+                useOverlay: true,
+                singleTile: true
+            mapName = rtMapInfo.RuntimeMap.Name[0];
+            sessionId = rtMapInfo.RuntimeMap.SessionId[0];
+            var params = {
+                mapname: mapName,
+                session: sessionId,
+                behavior: 2
+            var selParams = {
+                mapname: mapName,
+                selectioncolor: '0xFF000000',
+                behavior: 5
+            //Adjust the scale assumptions for MapGuide layers
+            //Tiled layers MUST use a DPI value of 96, untiled layers can use a
+            //different DPI value which will be passed to the server as a parameter.
+            //Tiled and untiled layers must adjust the OL INCHES_PER_UNIT values
+            //for any degree-based projections.
+            //You'll still need to do these adjustments manually, but CREATERUNTIMEMAP
+            //now provides the necessary meters-per-unit value for you to do this.
+            var metersPerUnit = parseFloat(rtMapInfo.RuntimeMap.CoordinateSystem[0].MetersPerUnit[0]);
+            var inPerUnit = OpenLayers.INCHES_PER_UNIT.m * metersPerUnit;
+            OpenLayers.INCHES_PER_UNIT["dd"] = inPerUnit;
+            OpenLayers.INCHES_PER_UNIT["degrees"] = inPerUnit;
+            OpenLayers.DOTS_PER_INCH = 96;
+            map = new OpenLayers.Map('map', mapOptions );
+            mgLayer = new OpenLayers.Layer.MapGuide( "MapGuide (from CREATERUNTIMEMAP)", mapAgentUrl, params, options );
+            selLayer = new OpenLayers.Layer.MapGuide( "MapGuide Selection Overlay", mapAgentUrl, selParams, options );
+            map.addLayer(mgLayer);
+            map.addLayer(selLayer);
+            var boxLayer = new OpenLayers.Layer.Vector("Selection Rectangles");
+            map.addLayer(boxLayer);
+            selRectControl = new OpenLayers.Control.DrawFeature(boxLayer,
+                OpenLayers.Handler.RegularPolygon, {
+                    handlerOptions: {
+                        sides: 4,
+                        irregular: true
+            boxLayer.events.register("beforefeatureadded", this, onSelBoxAdded);
+            map.addControl(selRectControl);
+            map.zoomToMaxExtent();
+            legend = new Legend({
+                legendSelector: "#rootList",
+                stdIconRoot: "../../stdicons",
+                runtimeMap: rtMapInfo,
+                map: map,
+                mgLayerOL: mgLayer
+            legend.update();
+            $("div.olMap").css("background-color", "#" + rtMapInfo.RuntimeMap.BackgroundColor[0].substring(2));
+            $(".olMapViewport").append($("<img class='selOverlay' />"));
+            map.events.register("click", this, onMapClick);
+            startKeepAlive();
+        function doSelect() {
+            setSelectionState(true);
+            navControl.deactivate();
+            zoomControl.deactivate();
+        function onSelBoxAdded(e) {
+            sendSelectionQuery(e.feature.geometry.getBounds());
+            return false;
+        function getImageUri(mimeType, imgBase64) {
+            return "data:" + mimeType + ";base64," + imgBase64;
+        function onMapClick(e) {
+            if (bSelecting) {
+                var llPt = map.getLonLatFromViewPortPx({ x: e.xy.x - ptBuffer, y: e.xy.y - ptBuffer });
+                var urPt = map.getLonLatFromViewPortPx({ x: e.xy.x + ptBuffer, y: e.xy.y + ptBuffer });
+                var box = new OpenLayers.Bounds();
+                box.extend(llPt);
+                box.extend(urPt);
+                sendSelectionQuery(box);
+                navControl.activate();
+        function sendSelectionQuery(bounds) {
+            var reqQueryFeatures = 1; //Attributes
+            var wkt = wktFormat.extractGeometry(bounds.toGeometry());
+                "OPERATION": "QUERYMAPFEATURES",
+                "PERSIST": "1",
+                "MAPNAME": mapName,
+                "SESSION": sessionId,
+                "GEOMETRY": wkt,
+                "SELECTIONVARIANT": "INTERSECTS",
+                "SELECTIONCOLOR": "0xFF000000",
+                "SELECTIONFORMAT": "PNG8",
+                "MAXFEATURES": "-1",
+                "REQUESTDATA": reqQueryFeatures,
+                processQueryResult(data);
+                selLayer.setVisibility(true);
+                selLayer.redraw(true);
+        function setSelectionState(sel) {
+            bSelecting = sel;
+            if (bSelecting) {
+                selRectControl.activate();
+                $("#selMessage").html("Selection mode active. Click or drag a selection rectangle on the map");
+            } else {
+                selRectControl.deactivate();
+                $("#selMessage").html("");
+        function processQueryResult(json) {
+            if (json.FeatureInformation) {
+                var fi = json.FeatureInformation;
+                setSelectionState(false);
+                var total = 0;
+                var html = "<ul>";
+                if (fi.SelectedFeatures) {
+                    var selection = fi.SelectedFeatures[0];
+                    for (var i = 0; i < selection.SelectedLayer.length; i++) {
+                        var selLayer = selection.SelectedLayer[i];
+                        total += selLayer.Feature.length;
+                        var layerHtml = "<li><p>" + selLayer["@name"] + " (" + selLayer.Feature.length + " features)</p><ul>";
+                        for (var j = 0; j < selLayer.Feature.length; j++) {
+                            var feat = selLayer.Feature[j];
+                            layerHtml += "<li><p>Feature</p><ul>";
+                            for (var p = 0; p < feat.Property.length; p++) {
+                                var prop = feat.Property[p];
+                                layerHtml += "<li><strong>" + prop.Name[0] + "</strong>: " + (prop.Value ? prop.Value[0] : "(null)") + "</li>";
+                            layerHtml += "</ul></li>";
+                        html += layerHtml;
+                html += "</ul>";
+                $("#selCount").html(total);
+                if (total > 0)
+                    $("#selInfoTree").html(html);
+                else
+                    $("#selInfoTree").html("");
+        function startKeepAlive() {
+            var keepAlive = function() {
+                $.get(mapAgentUrl, {
+                    "OPERATION": "GETSESSIONTIMEOUT",
+                    "VERSION": "1.0.0",
+                }, function(data, textStatus, jxXHR) {
+                    $("#mgSession").html("MapGuide session ID: " + sessionId + " (last checked at: " + (new Date()) + ")");
+                    setTimeout(keepAlive, parseInt(data) * 1000);
+            keepAlive();
+        </script>
+    </head>
+    <body>
+        <p>This example demonstrates selection via QUERYMAPFEATURES. The map is created with CREATERUNTIMEMAP</p>
+        <div id="error">
+        </div>
+        <button onclick="doSelect()">Select</button><span id="selMessage"></span>
+        <div id="wrap">
+            <div id="details">
+                <strong>Layer and Groups</strong>
+                <ul id="rootList">
+                </ul>
+            </div>
+            <div id="selInfo">
+                <strong>Selection Info</strong>
+                <div id="selInfoTree">
+                </div>
+            </div>
+            <div id="map">
+            </div>
+        </div>
+        <p><span id="selCount">0</span> features selected</p>
+    </body>
+</html>
\ No newline at end of file
More information about the mapguide-commits
