[mapguide-commits] r7800 - trunk/MgDev/Doc/samples
svn_mapguide at osgeo.org
Thu Aug 22 09:35:39 PDT 2013
Author: jng
Date: 2013-08-22 09:35:39 -0700 (Thu, 22 Aug 2013)
New Revision: 7800
trunk/MgDev/Doc/samples/samples.html
#2343: Fix broken link on landing page
Modified: trunk/MgDev/Doc/samples/samples.html
--- trunk/MgDev/Doc/samples/samples.html 2013-08-22 12:06:35 UTC (rev 7799)
+++ trunk/MgDev/Doc/samples/samples.html 2013-08-22 16:35:39 UTC (rev 7800)
@@ -11,7 +11,7 @@
<li>MapGuide Web Extensions API</li>
<li>OpenLayers integration</li>
</ul>
- <p><strong>NOTE: You should download the <a href="http://download.osgeo.org/mapguide/releases/2.0.0/samples/Sheboygan.mgp">Sheboygan Dataset</a> and load this in via the <a href="../mapadmin/login.php">MapGuide Site Administrator</a> before running any of these samples</strong></p>
+ <p><strong>NOTE: You should download the <a href="http://download.osgeo.org/mapguide/releases/2.0.0/samples/Sheboygan.mgp">Sheboygan Dataset</a> and load this in via the <a href="mapadmin/login.php">MapGuide Site Administrator</a> before running any of these samples</strong></p>
<p><strong>NOTE: Some samples may not be available because you did not choose to enable this feature from the Windows installer. If you did not enable samples when installing MapGuide on Windows, none of these samples below will work</strong></p>
<p>Click on a link below to go to that particular sample</p>
<p>AJAX Viewer (.net)</p>
More information about the mapguide-commits
