[mapguide-commits] r7829 - sandbox/jng/webtier_upgrade_v2/MgDev/Oem/LinuxApt
svn_mapguide at osgeo.org
Sat Aug 31 08:21:17 PDT 2013
Author: jng
Date: 2013-08-31 08:21:17 -0700 (Sat, 31 Aug 2013)
New Revision: 7829
Added:
sandbox/jng/webtier_upgrade_v2/MgDev/Oem/LinuxApt/apr-1.4.8.tar.bz2
sandbox/jng/webtier_upgrade_v2/MgDev/Oem/LinuxApt/apr-util-1.5.2.tar.bz2
sandbox/jng/webtier_upgrade_v2/MgDev/Oem/LinuxApt/build_apt.sh
Fix build_apt.sh
Added: sandbox/jng/webtier_upgrade_v2/MgDev/Oem/LinuxApt/apr-1.4.8.tar.bz2
(Binary files differ)
Property changes on: sandbox/jng/webtier_upgrade_v2/MgDev/Oem/LinuxApt/apr-1.4.8.tar.bz2
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Added: sandbox/jng/webtier_upgrade_v2/MgDev/Oem/LinuxApt/apr-util-1.5.2.tar.bz2
Property changes on: sandbox/jng/webtier_upgrade_v2/MgDev/Oem/LinuxApt/apr-util-1.5.2.tar.bz2
Modified: sandbox/jng/webtier_upgrade_v2/MgDev/Oem/LinuxApt/build_apt.sh
--- sandbox/jng/webtier_upgrade_v2/MgDev/Oem/LinuxApt/build_apt.sh 2013-08-30 17:10:48 UTC (rev 7828)
+++ sandbox/jng/webtier_upgrade_v2/MgDev/Oem/LinuxApt/build_apt.sh 2013-08-31 15:21:17 UTC (rev 7829)
@@ -17,6 +17,9 @@
PORT=8008
TOMCAT=0
+TOMCAT_PORT=8009
+START_HTTPD=0
+START_TOMCAT=0
while [ $# -gt 0 ]; do # Until you run out of parameters . . .
case "$1" in
@@ -24,6 +27,10 @@
PORT="$2"
shift
+ -tomcat-port|--tomcat-port)
+ TOMCAT_PORT="$2"
+ shift
-prefix|--prefix)
INSTALLDIR="$2"
shift
@@ -32,13 +39,25 @@
TOMCAT=1
shift
+ -start-tomcat|--start-tomcat)
+ START_TOMCAT=1
+ shift
+ -start-httpd|--start-httpd)
+ START_HTTPD=1
+ shift
-help|--help)
echo "Usage: $0 (options)"
echo "Options:"
echo " --port [Apache port number]"
echo " --prefix [installation directory]"
+ echo " --start-httpd Automatically start httpd once compiled"
echo " --with-tomcat Configure and install Tomcat"
+ echo " --tomcat-port [Tomcat port number]"
+ echo " --start-tomcat Automatically start tomcat once configured"
echo " --help Display usage"
+ exit 0
esac
shift # Check next set of parameters.
@@ -54,7 +73,7 @@
echo
echo "Apache will be configured to run on port $PORT."
if [ "$TOMCAT" = "1" ]; then
- echo "Tomcat will be configured to run on port $PORT."
+ echo "Tomcat will be configured to run on port $TOMCAT_PORT."
fi
@@ -117,43 +136,52 @@
# Apache build procedure
-# Notes: none
+# Notes: Be sure to install pcre-devel (on CentOS) or an
+# equivalent library in other Linux distributions
-echo Apache Httpd build started
+echo "Apache Httpd build started"
tar -jxf httpd-2.4.6.tar.bz2
+if [ ! -d "httpd-2.4.6/srclib/apr" ]; then
+ tar -jxf apr-1.4.8.tar.bz2
+ mv apr-1.4.8 httpd-2.4.6/srclib/apr
+fi
+if [ ! -d "httpd-2.4.6/srclib/aprutil" ]; then
+ tar -jxf apr-util-1.5.2.tar.bz2
+ mv apr-util-1.5.2 httpd-2.4.6/srclib/apr-util
+fi
pushd httpd-2.4.6
./configure --prefix=$INSTALLWEB/apache2 --enable-mods-shared=all \
---enable-ldap --with-ldap --enable-authnz-ldap --with-included-apr --with-port=$PORT
+--with-included-apr --with-port=$PORT
check_apache_build
make
check_apache_build
popd
-echo Apache Httpd build completed
+echo "Apache Httpd build completed"
# Apache shutdown procedure
# Notes: none
-echo Checking for existing Apache install
+echo "Checking for existing Apache install"
if [ -d $INSTALLWEB/apache2/bin ]; then
- echo Attempting to shutdown Apache
+ echo "Attempting to shutdown Apache"
pushd $INSTALLWEB/apache2/bin
./apachectl stop
popd
- echo Attempting to remove old Apache and Php
+ echo "Attempting to remove old Apache and Php"
pushd $INSTALLWEB
rm -rf apache2
rm -rf php
popd
- echo Completed uninstall of Apache and Php
+ echo "Completed uninstall of Apache and Php"
fi
# Apache install procedure
# Notes: none
-echo Apache install started
-pushd httpd-2.2.21
+echo "Apache install started"
+pushd httpd-2.4.6
make install
check_apache_install
popd
@@ -167,7 +195,7 @@
rm httpd.conf.mgorig_
popd
-echo Apache install completed
+echo "Apache install completed"
pushd $INSTALLWEB/apache2/conf
cat > mapguide.conf <<END-OF-CONFIGURATION
@@ -196,8 +224,9 @@
# Php build procedure
# Notes: none
-echo Php build started
-pushd ../php
+echo "Php build started"
+tar -jxf php-5.5.3.tar.bz2
+pushd php-5.5.3
./configure --prefix=$INSTALLWEB/php --with-apxs2=$INSTALLWEB/apache2/bin/apxs --with-openssl \
--with-curl --enable-xml --enable-wddx --enable-shared \
--enable-safe-mode --with-zlib --enable-zip --enable-mbstring=all --with-xsl=/usr/lib --with-gd --with-png --with-jpeg --with-freetype
@@ -205,25 +234,25 @@
make
check_php_build
popd
-echo Php build completed
+echo "Php build completed"
# Php install procedure
# Notes: none
-echo Php install started
-pushd ../php
+echo "Php install started"
+pushd php-5.5.3
make install
check_php_install
popd
-echo Php install completed
+echo "Php install completed"
# Tomcat connector build/install procedure
# Notes: none
-echo Tomcat connector build/install started
+echo "Tomcat connector build/install started"
tar -zxf tomcat-connectors-1.2.37-src.tar.gz
pushd tomcat-connectors-1.2.37-src/native
@@ -234,7 +263,7 @@
make install
check_tomcat_install
popd
-echo Tomcat connector build/install completed
+echo "Tomcat connector build/install completed"
fi
@@ -242,14 +271,14 @@
# Notes: none
-echo Tomcat install started
+echo "Tomcat install started"
tar -zxf apache-tomcat-7.0.42.tar.gz -C $INSTALLWEB
pushd $INSTALLWEB
mv apache-tomcat-7.0.42 tomcat
popd
-echo Tomcat install completed
+echo "Tomcat install completed"
fi
@@ -257,7 +286,7 @@
# Notes: none
-echo Apache configuration started
+echo "Apache configuration started"
# Prep httpd.conf to read mapguide configuration
@@ -336,7 +365,7 @@
# Notes: none
-echo Tomcat configuration started
+echo "Tomcat configuration started"
cat >> mapguide.conf <<END-OF-CONFIGURATION
@@ -372,7 +401,7 @@
# Set properties for worker1 (ajp13)
worker.worker1.type=ajp13
worker.worker1.host=localhost
-worker.worker1.port=8009
+worker.worker1.port=$TOMCAT_PORT
worker.worker1.lbfactor=50
worker.worker1.cachesize=10
worker.worker1.cache_timeout=600
@@ -429,7 +458,7 @@
chmod 755 startup.sh
popd
-echo Tomcat configuration completed
+echo "Tomcat configuration completed"
fi
@@ -452,7 +481,9 @@
echo "Adding test pages"
-mkdir $INSTALLWEB/www
+if [ ! -d "$INSTALLWEB/www" ]; then
+ mkdir $INSTALLWEB/www
+fi
cat >> $INSTALLWEB/www/index.html <<ENDOFINDEX
<html>
<body>
@@ -470,7 +501,7 @@
echo "Installation complete."
+if [ "$START_HTTPD" = "1" ]; then
# Start Apache
# Notes: none
@@ -480,17 +511,17 @@
./apachectl start
popd
echo "Apache is now online."
+fi
# Tomcat startup procedure
# Notes: none
-if [ "$TOMCAT" = "1" ]; then
-echo Tomcat startup
+if [ "$TOMCAT" = "1" -a "$START_TOMCAT" = "1" ]; then
+echo "Tomcat startup"
pushd $INSTALLWEB/tomcat/bin
./startup.sh
popd
-echo Tomcat startup completed
+echo "Tomcat startup completed"
fi
More information about the mapguide-commits
