[mapguide-commits] r7943 - trunk/MgDev/Desktop/MapViewer
svn_mapguide at osgeo.org
Sun Dec 1 08:53:51 PST 2013
Author: jng
Date: 2013-12-01 08:53:51 -0800 (Sun, 01 Dec 2013)
New Revision: 7943
trunk/MgDev/Desktop/MapViewer/MgLegend.cs
trunk/MgDev/Desktop/MapViewer/MgLegendControlPresenter.cs
mg-desktop viewer legend fixes:
- Fix ThemeCompressionLimit property not taking in given value
- Fix incorrect display of layers with multiple styles and/or composite styles
Modified: trunk/MgDev/Desktop/MapViewer/MgLegend.cs
--- trunk/MgDev/Desktop/MapViewer/MgLegend.cs 2013-11-29 15:20:24 UTC (rev 7942)
+++ trunk/MgDev/Desktop/MapViewer/MgLegend.cs 2013-12-01 16:53:51 UTC (rev 7943)
@@ -344,7 +344,7 @@
get { return _themeCompressionLimit; }
set
- if (value != _themeCompressionLimit)
+ if (value == _themeCompressionLimit)
return;
_themeCompressionLimit = value;
Modified: trunk/MgDev/Desktop/MapViewer/MgLegendControlPresenter.cs
--- trunk/MgDev/Desktop/MapViewer/MgLegendControlPresenter.cs 2013-11-29 15:20:24 UTC (rev 7942)
+++ trunk/MgDev/Desktop/MapViewer/MgLegendControlPresenter.cs 2013-12-01 16:53:51 UTC (rev 7943)
@@ -85,6 +85,12 @@
return true;
+ class RuleData
+ public int GeomType;
+ public XmlNodeList RuleNodes;
private TreeNode CreateLayerNode(MgLayerBase layer)
var node = new TreeNode();
@@ -113,7 +119,7 @@
node.Tag = layerMeta;
node.ToolTipText = string.Format(Strings.DrawingLayerTooltip, Environment.NewLine, layer.Name, layer.FeatureSourceId);
- else
+ else //Vector or Grid layer
var ldfId = layer.LayerDefinition;
if (_layers.ContainsKey(layer.GetObjectId()))
@@ -130,9 +136,13 @@
+ const int LAYER_VECTOR = 0;
+ const int LAYER_RASTER = 1;
+ const int LAYER_DWF = 2;
XmlDocument doc = new XmlDocument();
doc.LoadXml(layerMeta.LayerDefinitionContent);
- int type = 0;
+ int type = LAYER_VECTOR;
XmlNodeList scaleRanges = doc.GetElementsByTagName("VectorScaleRange"); //NOXLATE
if (scaleRanges.Count == 0)
@@ -142,16 +152,17 @@
scaleRanges = doc.GetElementsByTagName("DrawingLayerDefinition"); //NOXLATE
return null;
- type = 2;
+ type = LAYER_DWF;
else
- type = 1;
+ type = LAYER_RASTER;
String[] typeStyles = new String[] { "PointTypeStyle", "LineTypeStyle", "AreaTypeStyle", "CompositeTypeStyle" }; //NOXLATE
String[] ruleNames = new String[] { "PointRule", "LineRule", "AreaRule", "CompositeRule" }; //NOXLATE
node.ToolTipText = string.Format(Strings.DefaultLayerTooltip, Environment.NewLine, layer.Name, layer.FeatureSourceId, layer.FeatureClassName);
+ //Do this if not cached already from a previous run
if (!layerMeta.HasTheme() || !layerMeta.HasDefaultIcons())
for (int sc = 0; sc < scaleRanges.Count; sc++)
@@ -167,95 +178,165 @@
if (maxElt.Count > 0)
maxScale = maxElt[0].ChildNodes[0].Value;
- if (type != 0)
+ if (type != LAYER_VECTOR)
break;
- for (int geomType = 0; geomType < typeStyles.Length; geomType++)
+ bool bComposite = false;
+ //Check TS count. Give precedence to composite type styles
+ List<XmlNode> typeStyleCol = new List<XmlNode>();
+ XmlNodeList styleNodes = scaleRange.GetElementsByTagName(typeStyles[3]);
+ List<RuleData> rules = new List<RuleData>();
+ if (styleNodes.Count > 0)
- ThemeCategory themeCat = new ThemeCategory()
+ foreach (XmlNode n in styleNodes)
- MinScale = minScale,
- MaxScale = maxScale,
- GeometryType = geomType
- if (layerMeta.CategoryExists(themeCat))
- continue;
- int catIndex = 0;
- XmlNodeList typeStyle = scaleRange.GetElementsByTagName(typeStyles[geomType]);
- for (int st = 0; st < typeStyle.Count; st++)
// We will check if this typestyle is going to be shown in the legend
- XmlNodeList showInLegend = ((XmlElement)typeStyle[st]).GetElementsByTagName("ShowInLegend"); //NOXLATE
+ XmlNodeList showInLegend = ((XmlElement)n).GetElementsByTagName("ShowInLegend"); //NOXLATE
if (showInLegend.Count > 0)
if (!bool.Parse(showInLegend[0].ChildNodes[0].Value))
continue; // This typestyle does not need to be shown in the legend
- XmlNodeList rules = ((XmlElement)typeStyle[st]).GetElementsByTagName(ruleNames[geomType]);
- if (rules.Count > 1)
+ typeStyleCol.Add(n);
+ var ruleData = new RuleData();
+ ruleData.GeomType = 3;
+ ruleData.RuleNodes = ((XmlElement)n).GetElementsByTagName(ruleNames[3]);
+ if (ruleData.RuleNodes.Count > 0)
+ rules.Add(ruleData);
+ bComposite = true;
+ else
+ for (int t = 0; t < 3; t++)
+ styleNodes = scaleRange.GetElementsByTagName(typeStyles[t]);
- layerMeta.SetDefaultIcon(themeCat, Properties.Resources.lc_theme);
- node.ToolTipText = string.Format(Strings.ThemedLayerTooltip, Environment.NewLine, layer.Name, layer.FeatureSourceId, layer.FeatureClassName, rules.Count);
+ // We will check if this typestyle is going to be shown in the legend
+ if (showInLegend.Count > 0)
+ if (!bool.Parse(showInLegend[0].ChildNodes[0].Value))
+ continue; // This typestyle does not need to be shown in the legend
- if (_legend.ThemeCompressionLimit > 0 && rules.Count > _legend.ThemeCompressionLimit)
+ ruleData.GeomType = t;
+ ruleData.RuleNodes = ((XmlElement)n).GetElementsByTagName(ruleNames[t]);
+ //No type styles. Skip
+ if (typeStyleCol.Count == 0)
+ continue;
+ //Determine if this is themed or not
+ int nTotalRules = 0;
+ foreach(RuleData r in rules)
+ nTotalRules += r.RuleNodes.Count;
+ bool bThemed = nTotalRules > 1;
+ if (bThemed)
+ int catIndex = 0;
+ for (int i = 0; i < rules.Count; i++)
+ RuleData theRule = rules[i];
+ ThemeCategory themeCat = new ThemeCategory()
+ MinScale = minScale,
+ MaxScale = maxScale,
+ GeometryType = theRule.GeomType
+ //Non-composite styles must be processed once
+ if (layerMeta.CategoryExists(themeCat) && theRule.GeomType != 3)
+ continue;
+ layerMeta.SetDefaultIcon(themeCat, Properties.Resources.lc_theme);
+ node.ToolTipText = string.Format(Strings.ThemedLayerTooltip, Environment.NewLine, layer.Name, layer.FeatureSourceId, layer.FeatureClassName, nTotalRules);
+ if (_legend.ThemeCompressionLimit > 0 && theRule.RuleNodes.Count > _legend.ThemeCompressionLimit)
+ AddThemeRuleNode(layerMeta, themeCat, node, theRule.GeomType, catIndex, theRule.RuleNodes, 0);
+ node.Nodes.Add(CreateCompressedThemeNode(layerMeta, themeCat, theRule.RuleNodes.Count - 2));
+ AddThemeRuleNode(layerMeta, themeCat, node, theRule.GeomType, (catIndex + (theRule.RuleNodes.Count - 1)), theRule.RuleNodes, theRule.RuleNodes.Count - 1);
+ else
+ for (int r = 0; r < theRule.RuleNodes.Count; r++)
- AddThemeRuleNode(layerMeta, themeCat, node, geomType, 0, rules, 0);
- node.Nodes.Add(CreateCompressedThemeNode(layerMeta, themeCat, rules.Count - 2));
- AddThemeRuleNode(layerMeta, themeCat, node, geomType, rules.Count - 1, rules, rules.Count - 1);
+ AddThemeRuleNode(layerMeta, themeCat, node, theRule.GeomType, (catIndex + r), theRule.RuleNodes, r);
- else
- for (int r = 0; r < rules.Count; r++)
- AddThemeRuleNode(layerMeta, themeCat, node, geomType, catIndex++, rules, r);
- else
+ //Only bump catIndex if composite, as category indexes for composite styles are handled differently
+ if (bComposite)
+ catIndex += theRule.RuleNodes.Count;
+ else
+ Trace.Assert(rules.Count == 1);
+ Trace.Assert(rules[0].RuleNodes.Count == 1);
+ RuleData theRule = rules[0];
+ if (layerMeta.CategoryExists(themeCat))
+ continue;
+ if (LayerNodeMetadata.ScaleIsApplicable(_map.ViewScale, themeCat))
+ if (!layerMeta.HasDefaultIconsAt(_map.ViewScale))
- if (LayerNodeMetadata.ScaleIsApplicable(_map.ViewScale, themeCat))
+ try
- if (!layerMeta.HasDefaultIconsAt(_map.ViewScale))
+ MgByteReader layerIcon = _provider.GenerateLegendImage(layer.LayerDefinition,
+ _map.ViewScale,
+ 16,
+ 16,
+ "PNG", //NOXLATE
+ (theRule.GeomType+1),
+ -1);
+ legendCallCount++;
+ if (layerIcon != null)
try
- MgByteReader layerIcon = _provider.GenerateLegendImage(layer.LayerDefinition,
- _map.ViewScale,
- 16,
- 16,
- "PNG", //NOXLATE
- -1,
- -1);
- legendCallCount++;
- if (layerIcon != null)
+ byte[] b = new byte[layerIcon.GetLength()];
+ layerIcon.Read(b, b.Length);
+ using (var ms = new MemoryStream(b))
- try
- byte[] b = new byte[layerIcon.GetLength()];
- layerIcon.Read(b, b.Length);
- using (var ms = new MemoryStream(b))
- layerMeta.SetDefaultIcon(themeCat, Image.FromStream(ms));
- node.ToolTipText = string.Format(Strings.DefaultLayerTooltip, Environment.NewLine, layer.Name, layer.FeatureSourceId, layer.FeatureClassName);
- finally
- layerIcon.Dispose();
+ layerMeta.SetDefaultIcon(themeCat, Image.FromStream(ms));
+ node.ToolTipText = string.Format(Strings.DefaultLayerTooltip, Environment.NewLine, layer.Name, layer.FeatureSourceId, layer.FeatureClassName);
- else
- layerMeta.SetDefaultIcon(themeCat, Properties.Resources.lc_broken);
- catch
+ finally
+ layerIcon.Dispose();
+ else
+ layerMeta.SetDefaultIcon(themeCat, Properties.Resources.lc_broken);
+ catch
@@ -271,9 +352,9 @@
return node;
- private void AddThemeRuleNode(LayerNodeMetadata layerMeta, ThemeCategory themeCat, TreeNode node, int geomType, int catIndex, XmlNodeList rules, int r)
+ private void AddThemeRuleNode(LayerNodeMetadata layerMeta, ThemeCategory themeCat, TreeNode node, int geomType, int catIndex, XmlNodeList rules, int ruleOffset)
- XmlElement rule = (XmlElement)rules[r];
+ XmlElement rule = (XmlElement)rules[ruleOffset];
XmlNodeList label = rule.GetElementsByTagName("LegendLabel"); //NOXLATE
XmlNodeList filter = rule.GetElementsByTagName("Filter"); //NOXLATE
More information about the mapguide-commits
