[mapguide-commits] r7945 - in branches/2.5/MgDev/Desktop: MapViewer MgDesktop MgDesktop/Services/Rendering UnitTest
svn_mapguide at osgeo.org
Sun Dec 1 09:39:38 PST 2013
Author: jng
Date: 2013-12-01 09:39:38 -0800 (Sun, 01 Dec 2013)
New Revision: 7945
branches/2.5/MgDev/Desktop/MapViewer/MgLegend.cs
branches/2.5/MgDev/Desktop/MapViewer/MgLegendControlPresenter.cs
branches/2.5/MgDev/Desktop/MgDesktop/Services/Rendering/LegendPlotUtil.cpp
branches/2.5/MgDev/Desktop/MgDesktop/Services/Rendering/LegendPlotUtil.h
branches/2.5/MgDev/Desktop/MgDesktop/Services/Rendering/icons.h
branches/2.5/MgDev/Desktop/MgDesktop/changelog.txt
branches/2.5/MgDev/Desktop/UnitTest/TestRenderingService.cpp
branches/2.5/MgDev/Desktop/UnitTest/TestRenderingService.h
mg-desktop: Merge r7935, r7936, r7943 and r7944 from trunk
Modified: branches/2.5/MgDev/Desktop/MapViewer/MgLegend.cs
--- branches/2.5/MgDev/Desktop/MapViewer/MgLegend.cs 2013-12-01 16:54:17 UTC (rev 7944)
+++ branches/2.5/MgDev/Desktop/MapViewer/MgLegend.cs 2013-12-01 17:39:38 UTC (rev 7945)
@@ -344,7 +344,7 @@
get { return _themeCompressionLimit; }
set
- if (value != _themeCompressionLimit)
+ if (value == _themeCompressionLimit)
return;
_themeCompressionLimit = value;
Modified: branches/2.5/MgDev/Desktop/MapViewer/MgLegendControlPresenter.cs
--- branches/2.5/MgDev/Desktop/MapViewer/MgLegendControlPresenter.cs 2013-12-01 16:54:17 UTC (rev 7944)
+++ branches/2.5/MgDev/Desktop/MapViewer/MgLegendControlPresenter.cs 2013-12-01 17:39:38 UTC (rev 7945)
@@ -85,6 +85,12 @@
return true;
+ class RuleData
+ public int GeomType;
+ public XmlNodeList RuleNodes;
private TreeNode CreateLayerNode(MgLayerBase layer)
var node = new TreeNode();
@@ -113,7 +119,7 @@
node.Tag = layerMeta;
node.ToolTipText = string.Format(Strings.DrawingLayerTooltip, Environment.NewLine, layer.Name, layer.FeatureSourceId);
- else
+ else //Vector or Grid layer
var ldfId = layer.LayerDefinition;
if (_layers.ContainsKey(layer.GetObjectId()))
@@ -130,9 +136,13 @@
+ const int LAYER_VECTOR = 0;
+ const int LAYER_RASTER = 1;
+ const int LAYER_DWF = 2;
XmlDocument doc = new XmlDocument();
doc.LoadXml(layerMeta.LayerDefinitionContent);
- int type = 0;
+ int type = LAYER_VECTOR;
XmlNodeList scaleRanges = doc.GetElementsByTagName("VectorScaleRange"); //NOXLATE
if (scaleRanges.Count == 0)
@@ -142,16 +152,17 @@
scaleRanges = doc.GetElementsByTagName("DrawingLayerDefinition"); //NOXLATE
return null;
- type = 2;
+ type = LAYER_DWF;
else
- type = 1;
+ type = LAYER_RASTER;
String[] typeStyles = new String[] { "PointTypeStyle", "LineTypeStyle", "AreaTypeStyle", "CompositeTypeStyle" }; //NOXLATE
String[] ruleNames = new String[] { "PointRule", "LineRule", "AreaRule", "CompositeRule" }; //NOXLATE
node.ToolTipText = string.Format(Strings.DefaultLayerTooltip, Environment.NewLine, layer.Name, layer.FeatureSourceId, layer.FeatureClassName);
+ //Do this if not cached already from a previous run
if (!layerMeta.HasTheme() || !layerMeta.HasDefaultIcons())
for (int sc = 0; sc < scaleRanges.Count; sc++)
@@ -167,95 +178,165 @@
if (maxElt.Count > 0)
maxScale = maxElt[0].ChildNodes[0].Value;
- if (type != 0)
+ if (type != LAYER_VECTOR)
break;
- for (int geomType = 0; geomType < typeStyles.Length; geomType++)
+ bool bComposite = false;
+ //Check TS count. Give precedence to composite type styles
+ List<XmlNode> typeStyleCol = new List<XmlNode>();
+ XmlNodeList styleNodes = scaleRange.GetElementsByTagName(typeStyles[3]);
+ List<RuleData> rules = new List<RuleData>();
+ if (styleNodes.Count > 0)
- ThemeCategory themeCat = new ThemeCategory()
+ foreach (XmlNode n in styleNodes)
- MinScale = minScale,
- MaxScale = maxScale,
- GeometryType = geomType
- if (layerMeta.CategoryExists(themeCat))
- continue;
- int catIndex = 0;
- XmlNodeList typeStyle = scaleRange.GetElementsByTagName(typeStyles[geomType]);
- for (int st = 0; st < typeStyle.Count; st++)
// We will check if this typestyle is going to be shown in the legend
- XmlNodeList showInLegend = ((XmlElement)typeStyle[st]).GetElementsByTagName("ShowInLegend"); //NOXLATE
+ XmlNodeList showInLegend = ((XmlElement)n).GetElementsByTagName("ShowInLegend"); //NOXLATE
if (showInLegend.Count > 0)
if (!bool.Parse(showInLegend[0].ChildNodes[0].Value))
continue; // This typestyle does not need to be shown in the legend
- XmlNodeList rules = ((XmlElement)typeStyle[st]).GetElementsByTagName(ruleNames[geomType]);
- if (rules.Count > 1)
+ typeStyleCol.Add(n);
+ var ruleData = new RuleData();
+ ruleData.GeomType = 3;
+ ruleData.RuleNodes = ((XmlElement)n).GetElementsByTagName(ruleNames[3]);
+ if (ruleData.RuleNodes.Count > 0)
+ rules.Add(ruleData);
+ bComposite = true;
+ else
+ for (int t = 0; t < 3; t++)
+ styleNodes = scaleRange.GetElementsByTagName(typeStyles[t]);
- layerMeta.SetDefaultIcon(themeCat, Properties.Resources.lc_theme);
- node.ToolTipText = string.Format(Strings.ThemedLayerTooltip, Environment.NewLine, layer.Name, layer.FeatureSourceId, layer.FeatureClassName, rules.Count);
+ // We will check if this typestyle is going to be shown in the legend
+ if (showInLegend.Count > 0)
+ if (!bool.Parse(showInLegend[0].ChildNodes[0].Value))
+ continue; // This typestyle does not need to be shown in the legend
- if (_legend.ThemeCompressionLimit > 0 && rules.Count > _legend.ThemeCompressionLimit)
+ ruleData.GeomType = t;
+ ruleData.RuleNodes = ((XmlElement)n).GetElementsByTagName(ruleNames[t]);
+ //No type styles. Skip
+ if (typeStyleCol.Count == 0)
+ continue;
+ //Determine if this is themed or not
+ int nTotalRules = 0;
+ foreach(RuleData r in rules)
+ nTotalRules += r.RuleNodes.Count;
+ bool bThemed = nTotalRules > 1;
+ if (bThemed)
+ int catIndex = 0;
+ for (int i = 0; i < rules.Count; i++)
+ RuleData theRule = rules[i];
+ ThemeCategory themeCat = new ThemeCategory()
+ MinScale = minScale,
+ MaxScale = maxScale,
+ GeometryType = theRule.GeomType
+ //Non-composite styles must be processed once
+ if (layerMeta.CategoryExists(themeCat) && theRule.GeomType != 3)
+ continue;
+ layerMeta.SetDefaultIcon(themeCat, Properties.Resources.lc_theme);
+ node.ToolTipText = string.Format(Strings.ThemedLayerTooltip, Environment.NewLine, layer.Name, layer.FeatureSourceId, layer.FeatureClassName, nTotalRules);
+ if (_legend.ThemeCompressionLimit > 0 && theRule.RuleNodes.Count > _legend.ThemeCompressionLimit)
+ AddThemeRuleNode(layerMeta, themeCat, node, theRule.GeomType, catIndex, theRule.RuleNodes, 0);
+ node.Nodes.Add(CreateCompressedThemeNode(layerMeta, themeCat, theRule.RuleNodes.Count - 2));
+ AddThemeRuleNode(layerMeta, themeCat, node, theRule.GeomType, (catIndex + (theRule.RuleNodes.Count - 1)), theRule.RuleNodes, theRule.RuleNodes.Count - 1);
+ else
+ for (int r = 0; r < theRule.RuleNodes.Count; r++)
- AddThemeRuleNode(layerMeta, themeCat, node, geomType, 0, rules, 0);
- node.Nodes.Add(CreateCompressedThemeNode(layerMeta, themeCat, rules.Count - 2));
- AddThemeRuleNode(layerMeta, themeCat, node, geomType, rules.Count - 1, rules, rules.Count - 1);
+ AddThemeRuleNode(layerMeta, themeCat, node, theRule.GeomType, (catIndex + r), theRule.RuleNodes, r);
- else
- for (int r = 0; r < rules.Count; r++)
- AddThemeRuleNode(layerMeta, themeCat, node, geomType, catIndex++, rules, r);
- else
+ //Only bump catIndex if composite, as category indexes for composite styles are handled differently
+ if (bComposite)
+ catIndex += theRule.RuleNodes.Count;
+ else
+ Trace.Assert(rules.Count == 1);
+ Trace.Assert(rules[0].RuleNodes.Count == 1);
+ RuleData theRule = rules[0];
+ if (layerMeta.CategoryExists(themeCat))
+ continue;
+ if (LayerNodeMetadata.ScaleIsApplicable(_map.ViewScale, themeCat))
+ if (!layerMeta.HasDefaultIconsAt(_map.ViewScale))
- if (LayerNodeMetadata.ScaleIsApplicable(_map.ViewScale, themeCat))
+ try
- if (!layerMeta.HasDefaultIconsAt(_map.ViewScale))
+ MgByteReader layerIcon = _provider.GenerateLegendImage(layer.LayerDefinition,
+ _map.ViewScale,
+ 16,
+ 16,
+ "PNG", //NOXLATE
+ (theRule.GeomType+1),
+ -1);
+ legendCallCount++;
+ if (layerIcon != null)
try
- MgByteReader layerIcon = _provider.GenerateLegendImage(layer.LayerDefinition,
- _map.ViewScale,
- 16,
- 16,
- "PNG", //NOXLATE
- -1,
- -1);
- legendCallCount++;
- if (layerIcon != null)
+ byte[] b = new byte[layerIcon.GetLength()];
+ layerIcon.Read(b, b.Length);
+ using (var ms = new MemoryStream(b))
- try
- byte[] b = new byte[layerIcon.GetLength()];
- layerIcon.Read(b, b.Length);
- using (var ms = new MemoryStream(b))
- layerMeta.SetDefaultIcon(themeCat, Image.FromStream(ms));
- node.ToolTipText = string.Format(Strings.DefaultLayerTooltip, Environment.NewLine, layer.Name, layer.FeatureSourceId, layer.FeatureClassName);
- finally
- layerIcon.Dispose();
+ layerMeta.SetDefaultIcon(themeCat, Image.FromStream(ms));
+ node.ToolTipText = string.Format(Strings.DefaultLayerTooltip, Environment.NewLine, layer.Name, layer.FeatureSourceId, layer.FeatureClassName);
- else
- layerMeta.SetDefaultIcon(themeCat, Properties.Resources.lc_broken);
- catch
+ finally
+ layerIcon.Dispose();
+ else
+ layerMeta.SetDefaultIcon(themeCat, Properties.Resources.lc_broken);
+ catch
@@ -271,9 +352,9 @@
return node;
- private void AddThemeRuleNode(LayerNodeMetadata layerMeta, ThemeCategory themeCat, TreeNode node, int geomType, int catIndex, XmlNodeList rules, int r)
+ private void AddThemeRuleNode(LayerNodeMetadata layerMeta, ThemeCategory themeCat, TreeNode node, int geomType, int catIndex, XmlNodeList rules, int ruleOffset)
- XmlElement rule = (XmlElement)rules[r];
+ XmlElement rule = (XmlElement)rules[ruleOffset];
XmlNodeList label = rule.GetElementsByTagName("LegendLabel"); //NOXLATE
XmlNodeList filter = rule.GetElementsByTagName("Filter"); //NOXLATE
Modified: branches/2.5/MgDev/Desktop/MgDesktop/Services/Rendering/LegendPlotUtil.cpp
--- branches/2.5/MgDev/Desktop/MgDesktop/Services/Rendering/LegendPlotUtil.cpp 2013-12-01 16:54:17 UTC (rev 7944)
+++ branches/2.5/MgDev/Desktop/MgDesktop/Services/Rendering/LegendPlotUtil.cpp 2013-12-01 17:39:38 UTC (rev 7945)
@@ -80,6 +80,9 @@
RS_LineStroke lineStroke;
dr.ProcessPolyline(&lb, lineStroke);
+ //Pad left at the top-level
+ legendOffsetX += (defaultLegendMargin * convertUnits);
//And then do the content.
BuildLegendContent(map, dMapScale, legendSpec, legendOffsetX, legendOffsetY, dr, convertUnits);
@@ -93,6 +96,10 @@
textDef.halign() = RS_HAlignment_Left;
textDef.valign() = RS_VAlignment_Base;
+ //for convenience compute legend bitmap size in plot units (inches, mm, pixels, whatever)
+ double dIconWidth = ((double)bitmapPixelWidth / bitmapDpi)*convertUnits;
+ double dIconHeight = ((double)bitmapPixelHeight / bitmapDpi)*convertUnits;
// Get the layer info
double x = legendOffsetX + legendSpec->GetMarginLeft();
double y = legendOffsetY + legendSpec->GetPaperHeight() - legendSpec->GetMarginTop() - legendFontHeightMeters*M_TO_IN*convertUnits;
@@ -101,63 +108,54 @@
//for icon and label from the bottom up
y -= legendSpacing * convertUnits;
+ // Compile the necessary information needed to avoid repeated linear searches for this information
+ LayerGroupChildMap groupChildren;
+ VisibleLayerCountMap visibleLayers;
+ CompileInformation(map, visibleLayers, groupChildren);
// Add legend entries for layers that do not belong to a group
- ProcessLayersForLegend(map, scale, NULL, x, y, textDef, dr, legendSpec, legendOffsetY, convertUnits);
+ ProcessLayersForLegend(map, scale, NULL, x, y, textDef, dr, legendSpec, legendOffsetY, convertUnits, visibleLayers, groupChildren);
- // do layer groups
- Ptr<MgLayerGroupCollection> mggroups = map->GetLayerGroups();
+void MgdLegendPlotUtil::CompileInformation(MgdMap* map, VisibleLayerCountMap& visibleLayers, LayerGroupChildMap& groupChildren)
Ptr<MgLayerCollection> layers = map->GetLayers();
+ Ptr<MgLayerGroupCollection> groups = map->GetLayerGroups();
- // iterate over groups and draw each group's layers
- for (int k = 0; k < mggroups->GetCount(); k++)
+ for (INT32 i = 0; i < layers->GetCount(); i++)
- Ptr<MgLayerGroup> mggroup = mggroups->GetItem(k);
+ Ptr<MgLayerBase> layer = layers->GetItem(i);
+ if (!layer->IsVisible()) //Not visible
+ continue;
- // Count number of visible layers in this group.
- bool hasVisibleLayers = false;
- for (int l = 0; l < layers->GetCount(); l++)
- Ptr<MgLayerBase> layer = layers->GetItem(l);
- Ptr<MgLayerGroup> layerGroup = layer->GetGroup();
- if ((layer->IsVisible()) && (layerGroup.p == mggroup.p))
- hasVisibleLayers = true;
- break;
- if (!hasVisibleLayers)
+ Ptr<MgLayerGroup> parentGroup = layer->GetGroup();
+ if (NULL == parentGroup.p) //No parent
continue;
- if (mggroup == NULL)
- throw new MgNullReferenceException(L"MgdLegendPlotUtil.AddLegendElement", __LINE__, __WFILE__, NULL, L"", NULL);
- Ptr<MgLayerGroup> mgparent = mggroup->GetGroup();
+ STRING parentGroupName = parentGroup->GetName();
+ VisibleLayerCountMap::iterator vit = visibleLayers.find(parentGroupName);
+ if (vit == visibleLayers.end())
+ visibleLayers[parentGroupName] = 0;
+ visibleLayers[parentGroupName]++;
- double indent = 0;
- while (mgparent)
+ for (INT32 i = 0; i < groups->GetCount(); i++)
+ Ptr<MgLayerGroup> group = groups->GetItem(i);
+ Ptr<MgLayerGroup> parentGroup = group->GetGroup();
+ if (NULL != parentGroup.p)
- indent += PrintGroupIndent;
- mgparent = mgparent->GetGroup();
+ STRING groupName = group->GetName();
+ LayerGroupChildMap::iterator cit = groupChildren.find(parentGroupName);
+ if (cit == groupChildren.end())
+ groupChildren[parentGroupName] = LayerGroupList();
+ groupChildren[parentGroupName].push_back(groupName);
- x = legendOffsetX + (defaultLegendMargin + indent)*convertUnits;
- RS_LabelInfo info(x, y + legendTextVertAdjust*convertUnits, textDef);
- dr.ProcessLabelGroup(&info, 1, mggroup->GetLegendLabel(), RS_OverpostType_All, false, NULL, 0.0);
- y -= legendSpacing*convertUnits;
- if (y < legendSpec->GetMarginBottom())
- break;
- // Process the layers
- ProcessLayersForLegend(map, scale, mggroup, x, y, textDef, dr, legendSpec, legendOffsetY, convertUnits);
-void MgdLegendPlotUtil::ProcessLayersForLegend(MgdMap* map, double mapScale, MgLayerGroup* mggroup, double startX, double& startY, RS_TextDef textDef, Renderer& dr, MgdPlotSpecification* legendSpec, double legendOffsetY, double convertUnits)
+void MgdLegendPlotUtil::ProcessLayersForLegend(MgdMap* map, double mapScale, MgLayerGroup* mggroup, double startX, double& startY, RS_TextDef textDef, Renderer& dr, MgdPlotSpecification* legendSpec, double legendOffsetY, double convertUnits, VisibleLayerCountMap& visibleLayers, LayerGroupChildMap& groupChildren)
double x;
double &y = startY;
@@ -178,6 +176,29 @@
//bottom of the legend -- where we stop drawing
double bottomLimit = legendOffsetY + legendSpec->GetMarginBottom();
+ if (NULL != mggroup)
+ x = startX - initialMarginX;
+ // use group icon
+ RS_Bounds b2(x, y, x + dIconWidth, y + dIconHeight);
+ DrawPNG(&dr, (unsigned char*)LAYER_GROUP_ICON, sizeof(LAYER_GROUP_ICON), bitmapPixelWidth, bitmapPixelHeight, b2);
+ // Add the group legend label.
+ RS_LabelInfo info(x + dIconWidth + (defaultLegendMargin * convertUnits), y + legendTextVertAdjust*convertUnits, textDef);
+ dr.ProcessLabelGroup(&info, 1, mggroup->GetLegendLabel(), RS_OverpostType_All, false, NULL, 0.0);
+ // Indent for children
+ x += initialMarginX;
+ //move y cursor down one line
+ y -= verticalDelta;
+ if (y < bottomLimit)
+ return;
// build the list of layers that need to be processed
Ptr<MgStringCollection> layerIds = new MgStringCollection();
@@ -268,24 +289,70 @@
if (ftscol->GetCount() == 0)
continue;
- // if there are multiple feature type styles, using the first one
- MdfModel::FeatureTypeStyle* fts = ftscol->GetAt(0);
- MdfModel::RuleCollection* rules = fts->GetRules();
- int nRuleCount = rules->GetCount();
+ //Peek ahead to determine what we're dealing with
+ bool bThemed = false;
+ int nCompositeStyleCount = 0;
+ MdfModel::FeatureTypeStyle* singleFTS = NULL;
+ MdfModel::FeatureTypeStyle* singleCTS = NULL;
+ int nTotalFTSRules = 0;
+ int nTotalCTSRules = 0;
+ //Compile type/rule count to determine if this is a themed layer
+ for (int j = 0; j < ftscol->GetCount(); j++)
+ MdfModel::FeatureTypeStyle* fts = ftscol->GetAt(j);
+ if (!fts->IsShowInLegend())
+ continue;
+ MdfModel::RuleCollection* rules = fts->GetRules();
+ MdfModel::CompositeTypeStyle* cts = dynamic_cast<MdfModel::CompositeTypeStyle*>(fts);
+ //Composite Styles take precedence (it's what the stylizer does. So we're doing the same thing here).
+ //If a Composite Style exists, we're using it.
+ if (NULL != cts)
+ //For a single type scale range, this will only be set once. Otherwise it could
+ //be set many times over (for each style type we encounter), but this is okay
+ //because we won't be using this pointer anyway for multi-type layers
+ singleCTS = fts;
+ nTotalCTSRules += rules->GetCount();
+ nCompositeStyleCount++;
+ else
+ singleFTS = fts;
+ nTotalFTSRules += rules->GetCount();
+ //It's a themed layer if we found more than one rule of that type
+ bThemed = (nTotalFTSRules > 1);
+ //Found a composite style, re-evaluate against composite rule count
+ if (nCompositeStyleCount > 0)
+ bThemed = (nTotalCTSRules > 1);
//add the layer icon, if any
x = startX;
- if (nRuleCount > 1)
+ if (bThemed)
//in case of themed layer, use standard theme icon
DrawPNG(&dr, (unsigned char*)THEMED_LAYER_ICON, sizeof(THEMED_LAYER_ICON), bitmapPixelWidth, bitmapPixelHeight, b2);
else
+ assert(NULL != singleFTS || NULL != singleCTS); //Should've been set by peek-ahead from above
+ MdfModel::FeatureTypeStyle* theFTS = NULL;
+ //Composite TS takes precedence
+ if (NULL != singleCTS)
+ theFTS = singleCTS;
+ else if (NULL != singleFTS)
+ theFTS = singleFTS;
//otherwise pick the icon from the only rule
- Ptr<MgByteReader> layerIcon = MgdMappingUtil::DrawFTS(m_svcResource, fts, bitmapPixelWidth, bitmapPixelHeight, 0);
+ Ptr<MgByteReader> layerIcon = MgdMappingUtil::DrawFTS(m_svcResource, theFTS, bitmapPixelWidth, bitmapPixelHeight, 0);
if (layerIcon.p)
@@ -303,38 +370,56 @@
RS_LabelInfo info(x, y + verticalTextAdjust, textDef);
dr.ProcessLabelGroup(&info, 1, mapLayer->GetLegendLabel(), RS_OverpostType_All, false, NULL, 0.0);
+ //layer is themed : draw the theme icons under the layer title
+ if (bThemed)
//theme icons draw slightly indented
x = startX + initialMarginX;
- //layer is themed : draw the theme icons under the layer title
- for (int i = 0; i < nRuleCount; i++)
- MdfModel::Rule* rule = rules->GetAt(i);
+ //Skip items not marked for display
+ continue;
- //move y cursor down one line
- y -= verticalDelta;
+ //If we found one or more composite styles, then they take precedence. So skip all non-composite ones
+ if (nCompositeStyleCount > 0 && NULL == cts)
+ continue;
- if (y < bottomLimit)
- break;
- //draw the icon for the current theming rule
- Ptr<MgByteReader> rdr = MgdMappingUtil::DrawFTS(m_svcResource, fts, bitmapPixelWidth, bitmapPixelHeight, i);
- if (rdr != NULL)
+ for (int k = 0; k < rules->GetCount(); k++)
- MgByteSink sink(rdr);
- Ptr<MgByte> bytes = sink.ToBuffer();
+ MdfModel::Rule* rule = rules->GetAt(k);
- RS_Bounds b2(x, y, x + dIconWidth, y + dIconHeight);
- DrawPNG(&dr, bytes->Bytes(), bytes->GetLength(), bitmapPixelWidth, bitmapPixelHeight, b2);
+ break;
+ //draw the icon for the current theming rule
+ Ptr<MgByteReader> rdr = MgdMappingUtil::DrawFTS(m_svcResource, fts, bitmapPixelWidth, bitmapPixelHeight, k);
+ if (rdr != NULL)
+ MgByteSink sink(rdr);
+ Ptr<MgByte> bytes = sink.ToBuffer();
+ DrawPNG(&dr, bytes->Bytes(), bytes->GetLength(), bitmapPixelWidth, bitmapPixelHeight, b2);
+ //draw the label after the icon, but also allow
+ //some blank space for better clarity
+ RS_LabelInfo info(x + dIconWidth + initialMarginX, y + verticalTextAdjust, textDef);
+ dr.ProcessLabelGroup(&info, 1, rule->GetLegendLabel(), RS_OverpostType_All, false, NULL, 0.0);
- //draw the label after the icon, but also allow
- //some blank space for better clarity
- RS_LabelInfo info(x + dIconWidth + initialMarginX, y + verticalTextAdjust, textDef);
- dr.ProcessLabelGroup(&info, 1, rule->GetLegendLabel(), RS_OverpostType_All, false, NULL, 0.0);
+ break;
@@ -382,6 +467,29 @@
break;
+ //Process child groups of this legend
+ for (int i = 0; i < groups->GetCount(); i++)
+ if (!group->GetDisplayInLegend())
+ continue;
+ Ptr<MgLayerGroup> groupParent = group->GetGroup();
+ if (groupParent.p == mggroup)
+ //If this group has no visible layers, skip it
+ if (!HasVisibleLayers(group->GetName(), visibleLayers, groupChildren))
+ continue;
+ ProcessLayersForLegend(map, mapScale, group, startX + initialMarginX, y, textDef, dr, legendSpec, legendOffsetY, convertUnits, visibleLayers, groupChildren);
+ break;
@@ -1280,6 +1388,28 @@
dr.EndLayout();
+bool MgdLegendPlotUtil::HasVisibleLayers(CREFSTRING groupName, VisibleLayerCountMap& visibleLayers, LayerGroupChildMap& groupChildren)
+ INT32 total = 0;
+ VisibleLayerCountMap::iterator vit = visibleLayers.find(groupName);
+ if (vit != visibleLayers.end())
+ if (vit->second > 0)
+ return true;
+ LayerGroupChildMap::iterator cit = groupChildren.find(groupName);
+ if (cit != groupChildren.end())
+ for (LayerGroupList::iterator lit = cit->second.begin(); lit != cit->second.end(); lit++)
+ if (HasVisibleLayers(*lit, visibleLayers, groupChildren))
+ return true;
+ return false;
// Compute the legend size and the offset position on the page
Modified: branches/2.5/MgDev/Desktop/MgDesktop/Services/Rendering/LegendPlotUtil.h
--- branches/2.5/MgDev/Desktop/MgDesktop/Services/Rendering/LegendPlotUtil.h 2013-12-01 16:54:17 UTC (rev 7944)
+++ branches/2.5/MgDev/Desktop/MgDesktop/Services/Rendering/LegendPlotUtil.h 2013-12-01 17:39:38 UTC (rev 7945)
@@ -3,6 +3,10 @@
class EPlotRenderer;
+typedef std::vector<STRING> LayerGroupList;
+typedef std::map<STRING, LayerGroupList> LayerGroupChildMap;
+typedef std::map<STRING, int> VisibleLayerCountMap;
class MG_DESKTOP_API MgdLegendPlotUtil
public:
@@ -25,12 +29,14 @@
//Eventually the scale bar and north arrow ones need to be cleaned up also in order
//to use them in the AJAX viewer
void AddLegendElement(double dMapScale, Renderer& dr, MgdMap* map, MgdPlotSpecification* plotSpec, double legendOffsetX, double legendOffsetY);
- void ProcessLayersForLegend(MgdMap* map, double mapScale, MgLayerGroup* mggroup, double startX, double& startY, RS_TextDef textDef, Renderer& dr, MgdPlotSpecification* plotSpec, double legendOffsetY, double convertUnits);
+ void ProcessLayersForLegend(MgdMap* map, double mapScale, MgLayerGroup* mggroup, double startX, double& startY, RS_TextDef textDef, Renderer& dr, MgdPlotSpecification* plotSpec, double legendOffsetY, double convertUnits, VisibleLayerCountMap& visibleLayers, LayerGroupChildMap& groupChildren);
void BuildLegendContent(MgdMap* map, double scale, MgdPlotSpecification* legendSpec, double legendOffsetX, double legendOffsetY, Renderer& dr, double convertUnits);
void ExtentFromMapCenter(MgdMap* map, double metersPerUnit, RS_Bounds& b);
+ void CompileInformation(MgdMap* map, VisibleLayerCountMap& visibleLayers, LayerGroupChildMap& groupChildren);
private:
+ static bool HasVisibleLayers(CREFSTRING groupName, VisibleLayerCountMap& visibleLayers, LayerGroupChildMap& groupChildren);
MgResourceService* m_svcResource;
RS_String m_legendFontName;
@@ -90,8 +96,8 @@
const double legendSpacing = bitmapPixelHeight / bitmapDpi + 0.005;
const double defaultLegendMargin = 0.1; // inch
-const double legendFontHeightMeters = 0.002;
-const double legendTextVertAdjust = 0.07; // inch
+const double legendFontHeightMeters = 0.003;
+const double legendTextVertAdjust = 0.06; // inch
const double PrintLegendWidth = 2.0;
const double PrintLegendPadding = 0.1;
Modified: branches/2.5/MgDev/Desktop/MgDesktop/Services/Rendering/icons.h
--- branches/2.5/MgDev/Desktop/MgDesktop/Services/Rendering/icons.h 2013-12-01 16:54:17 UTC (rev 7944)
+++ branches/2.5/MgDev/Desktop/MgDesktop/Services/Rendering/icons.h 2013-12-01 17:39:38 UTC (rev 7945)
@@ -125,4 +125,26 @@
0x82
+//lc_group.png
+const unsigned char LAYER_GROUP_ICON[] = {
+0x89, 0x50, 0x4e, 0x47, 0x0d, 0x0a, 0x1a, 0x0a, 0x00, 0x00, 0x00, 0x0d, 0x49, 0x48, 0x44, 0x52,
+0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x10, 0x08, 0x06, 0x00, 0x00, 0x00, 0x1f, 0xf3, 0xff,
+0x61, 0x00, 0x00, 0x00, 0x01, 0x73, 0x52, 0x47, 0x42, 0x00, 0xae, 0xce, 0x1c, 0xe9, 0x00, 0x00,
+0x00, 0x04, 0x67, 0x41, 0x4d, 0x41, 0x00, 0x00, 0xb1, 0x8f, 0x0b, 0xfc, 0x61, 0x05, 0x00, 0x00,
+0x00, 0x09, 0x70, 0x48, 0x59, 0x73, 0x00, 0x00, 0x0e, 0xc3, 0x00, 0x00, 0x0e, 0xc3, 0x01, 0xc7,
+0x6f, 0xa8, 0x64, 0x00, 0x00, 0x00, 0x1a, 0x74, 0x45, 0x58, 0x74, 0x53, 0x6f, 0x66, 0x74, 0x77,
+0x61, 0x72, 0x65, 0x00, 0x50, 0x61, 0x69, 0x6e, 0x74, 0x2e, 0x4e, 0x45, 0x54, 0x20, 0x76, 0x33,
+0x2e, 0x35, 0x2e, 0x31, 0x30, 0x30, 0xf4, 0x72, 0xa1, 0x00, 0x00, 0x00, 0x84, 0x49, 0x44, 0x41,
+0x54, 0x38, 0x4f, 0x63, 0xf8, 0xff, 0xff, 0x3f, 0x45, 0x18, 0xab, 0x20, 0x29, 0x18, 0x4c, 0x1c,
+0x5c, 0xd3, 0xf2, 0xbf, 0x39, 0x92, 0x13, 0x03, 0x83, 0xc4, 0x91, 0x15, 0x63, 0xc3, 0x60, 0x02,
+0xa4, 0xf8, 0xff, 0xdb, 0x5e, 0x0c, 0x8c, 0x6e, 0x20, 0x32, 0x86, 0x19, 0x8e, 0x6a, 0xc0, 0x75,
+0x4b, 0x54, 0xfc, 0xa6, 0x03, 0xc3, 0x50, 0x10, 0xbe, 0xb4, 0x25, 0xe2, 0x7f, 0xa2, 0x21, 0x0b,
+0x61, 0x03, 0x90, 0x6d, 0xc4, 0x86, 0x31, 0x0c, 0xc0, 0x50, 0x80, 0x66, 0x20, 0x0c, 0x5f, 0xde,
+0x62, 0x89, 0xdd, 0x05, 0xe8, 0x9a, 0x40, 0x0a, 0xb1, 0xe1, 0x1d, 0xb3, 0x35, 0xf0, 0x1b, 0x80,
+0x4d, 0x13, 0x32, 0x1e, 0xee, 0x06, 0xc0, 0x14, 0x10, 0xc2, 0x28, 0x06, 0x80, 0x52, 0x15, 0x48,
+0x80, 0x14, 0xbc, 0x61, 0x46, 0x23, 0xc2, 0x00, 0x4a, 0x30, 0x56, 0x41, 0xe2, 0xf1, 0x7f, 0x06,
+0x00, 0x36, 0x20, 0xae, 0xaf, 0x57, 0x56, 0xf5, 0x08, 0x00, 0x00, 0x00, 0x00, 0x49, 0x45, 0x4e,
+0x44, 0xae, 0x42, 0x60, 0x82
#endif
Modified: branches/2.5/MgDev/Desktop/MgDesktop/changelog.txt
--- branches/2.5/MgDev/Desktop/MgDesktop/changelog.txt 2013-12-01 16:54:17 UTC (rev 7944)
+++ branches/2.5/MgDev/Desktop/MgDesktop/changelog.txt 2013-12-01 17:39:38 UTC (rev 7945)
@@ -1,5 +1,18 @@
API Changelog:
+ - Fix: Port legend image rendering fixes from MapGuide
+ - Fix: No-op UPDATEREPOSITORY operations in a package manifest. Packages containing such operations can now be loaded without errors
+Viewer Changelog:
+ - New Generic Redlining component
+ - Fix: Incorrect display of layers with multiple styles and/or composite styles in legend.
+2.5.1.7768 (16 Aug 2013)
+API Changelog:
- Fix: MgdResourceService::SetResource not properly flushing out in-memory cached content
- Fix: Guard against duplicate extended feature classes
Modified: branches/2.5/MgDev/Desktop/UnitTest/TestRenderingService.cpp
--- branches/2.5/MgDev/Desktop/UnitTest/TestRenderingService.cpp 2013-12-01 16:54:17 UTC (rev 7944)
+++ branches/2.5/MgDev/Desktop/UnitTest/TestRenderingService.cpp 2013-12-01 17:39:38 UTC (rev 7945)
@@ -321,6 +321,38 @@
Ptr<MgByteReader> dataReader7 = dataSource7->GetReader();
m_svcResource->SetResourceData(fsres6, L"UT_VotingDistricts.sdf", L"File", dataReader7);
+ // Data for exercising legend rendering
+ Ptr<MgResourceIdentifier> ldfres14 = new MgResourceIdentifier(L"Library://UnitTests/Layers/MultiFTS.LayerDefinition");
+ Ptr<MgByteSource> ldfsrc14 = new MgByteSource(L"../UnitTestFiles/UT_MultiFTS.ldf", false);
+ Ptr<MgByteReader> ldfrdr14 = ldfsrc14->GetReader();
+ m_svcResource->SetResource(ldfres14, ldfrdr14, NULL);
+ Ptr<MgResourceIdentifier> ldfres15 = new MgResourceIdentifier(L"Library://UnitTests/Layers/MultiCTS.LayerDefinition");
+ Ptr<MgByteSource> ldfsrc15 = new MgByteSource(L"../UnitTestFiles/UT_MultiCTS.ldf", false);
+ Ptr<MgByteReader> ldfrdr15 = ldfsrc15->GetReader();
+ m_svcResource->SetResource(ldfres15, ldfrdr15, NULL);
+ Ptr<MgResourceIdentifier> ldfres16 = new MgResourceIdentifier(L"Library://UnitTests/Layers/MultiFTSWithTheme.LayerDefinition");
+ Ptr<MgByteSource> ldfsrc16 = new MgByteSource(L"../UnitTestFiles/UT_MultiFTSWithTheme.ldf", false);
+ Ptr<MgByteReader> ldfrdr16 = ldfsrc16->GetReader();
+ m_svcResource->SetResource(ldfres16, ldfrdr16, NULL);
+ Ptr<MgResourceIdentifier> ldfres17 = new MgResourceIdentifier(L"Library://UnitTests/Layers/MultiCTSWithTheme.LayerDefinition");
+ Ptr<MgByteSource> ldfsrc17 = new MgByteSource(L"../UnitTestFiles/UT_MultiCTSWithTheme.ldf", false);
+ Ptr<MgByteReader> ldfrdr17 = ldfsrc17->GetReader();
+ m_svcResource->SetResource(ldfres17, ldfrdr17, NULL);
+ Ptr<MgResourceIdentifier> ldfres18 = new MgResourceIdentifier(L"Library://UnitTests/Layers/MultiFTSSingleCTS.LayerDefinition");
+ Ptr<MgByteSource> ldfsrc18 = new MgByteSource(L"../UnitTestFiles/UT_MultiFTSSingleCTS.ldf", false);
+ Ptr<MgByteReader> ldfrdr18 = ldfsrc18->GetReader();
+ m_svcResource->SetResource(ldfres18, ldfrdr18, NULL);
+ Ptr<MgResourceIdentifier> ldfres19 = new MgResourceIdentifier(L"Library://UnitTests/Layers/SingleFTSMultiCTS.LayerDefinition");
+ Ptr<MgByteSource> ldfsrc19 = new MgByteSource(L"../UnitTestFiles/UT_SingleFTSMultiCTS.ldf", false);
+ Ptr<MgByteReader> ldfrdr19 = ldfsrc19->GetReader();
+ m_svcResource->SetResource(ldfres19, ldfrdr19, NULL);
catch (MgException* e)
@@ -440,6 +472,19 @@
m_svcResource->DeleteResource(fsres6);
Ptr<MgResourceIdentifier> fsres7 = new MgResourceIdentifier(L"Library://UnitTests/Data/VotingDistricts.FeatureSource");
m_svcResource->DeleteResource(fsres7);
+ m_svcResource->DeleteResource(ldfres14);
+ m_svcResource->DeleteResource(ldfres15);
+ m_svcResource->DeleteResource(ldfres16);
+ m_svcResource->DeleteResource(ldfres17);
+ m_svcResource->DeleteResource(ldfres18);
+ m_svcResource->DeleteResource(ldfres19);
catch(MgFileIoException* e)
@@ -627,34 +672,58 @@
Ptr<MgLayerGroupCollection> layerGroups = map->GetLayerGroups();
- Ptr<MgResourceIdentifier> resId = new MgResourceIdentifier(L"Library://UnitTests/Layers/Parcels.LayerDefinition");
+ Ptr<MgResourceIdentifier> resId = new MgResourceIdentifier(L"Library://UnitTests/Layers/HydrographicPolygons.LayerDefinition");
+ Ptr<MgResourceIdentifier> ldfRail = new MgResourceIdentifier(L"Library://UnitTests/Layers/Rail.LayerDefinition");
- Ptr<MgLayerGroup> group = new MgLayerGroup(L"Can't see me");
- group->SetLegendLabel(L"Can't see me");
+ Ptr<MgLayerGroup> group = new MgLayerGroup(L"Test Group");
+ group->SetLegendLabel(L"Test Group");
group->SetDisplayInLegend(true);
layerGroups->Add(group);
+ Ptr<MgLayerGroup> group1 = new MgLayerGroup(L"Nest top level");
+ group1->SetLegendLabel(L"Nest top level");
+ group1->SetDisplayInLegend(true);
+ layerGroups->Add(group1);
+ Ptr<MgLayerGroup> group2 = new MgLayerGroup(L"Nest child");
+ group2->SetLegendLabel(L"Nest child (Nest top level)");
+ group2->SetDisplayInLegend(true);
+ group2->SetGroup(group1);
+ layerGroups->Add(group2);
+ Ptr<MgLayerGroup> group3 = new MgLayerGroup(L"Not visible in legend");
+ group3->SetLegendLabel(L"Not visible in legend");
+ group3->SetDisplayInLegend(false);
+ layerGroups->Add(group3);
Ptr<MgdLayer> layer = new MgdLayer(resId, m_svcResource);
- layer->SetName(L"MyParcels");
- layer->SetLegendLabel(L"Parcels");
+ layer->SetName(L"HydroPolygons");
+ layer->SetLegendLabel(L"HydroPolygons (Test Group)");
layer->SetGroup(group);
layer->SetDisplayInLegend(true);
+ Ptr<MgdLayer> layer2 = new MgdLayer(ldfRail, m_svcResource);
+ layer2->SetName(L"RailUnderNestedGroup");
+ layer2->SetLegendLabel(L"Rail (Nest Child)");
+ layer2->SetGroup(group2);
+ layer2->SetDisplayInLegend(true);
layers->Add(layer);
+ layers->Add(layer2);
//Re-draw at 75k. Layer group should not be there because it has no visible layers
map->SetViewScale(75000.0);
- Ptr<MgByteReader> rdr3 = m_svcRendering->RenderMapLegend(map, 200, 400, bgc, imageFormat);
- rdr3->ToFile(GetPath(L"../UnitTestFiles/RenderLegend75kWithEmptyLayerGroup", imageFormat, extension));
+ Ptr<MgByteReader> rdr3 = m_svcRendering->RenderMapLegend(map, 200, 400, bgc, imageFormat);
+ rdr3->ToFile(GetPath(L"../UnitTestFiles/RenderLegend75kWithEmptyLayerGroup", imageFormat, extension));
//Re-draw at 14000. Layer group should still not be there because it has no visible layers
map->SetViewScale(14000.0);
- Ptr<MgByteReader> rdr4 = m_svcRendering->RenderMapLegend(map, 200, 400, bgc, imageFormat);
+ Ptr<MgByteReader> rdr4 = m_svcRendering->RenderMapLegend(map, 200, 400, bgc, imageFormat);
rdr4->ToFile(GetPath(L"../UnitTestFiles/RenderLegend14kWithEmptyLayerGroup", imageFormat, extension));
//Re-draw at 12000. Layer group should now be there because its child layer (Parcels) should be visible
map->SetViewScale(12000.0);
- Ptr<MgByteReader> rdr5 = m_svcRendering->RenderMapLegend(map, 200, 400, bgc, imageFormat);
+ Ptr<MgByteReader> rdr5 = m_svcRendering->RenderMapLegend(map, 200, 400, bgc, imageFormat);
rdr5->ToFile(GetPath(L"../UnitTestFiles/RenderLegend12kWithLayerGroup", imageFormat, extension));
@@ -669,6 +738,263 @@
+void TestRenderingService::TestCase_RenderLegendEmptyGroups(CREFSTRING imageFormat, CREFSTRING extension)
+ try
+ // make a runtime map
+ Ptr<MgdMap> map = CreateTestMap();
+ map->SetViewScale(75000.0);
+ Ptr<MgColor> bgc = new MgColor(255, 255, 255, 255);
+ // Set up the following structure
+ // EmptyGroup1
+ // EmptyGroup2
+ // EmptyGroup3
+ // None of these should be visible when we render the legend
+ Ptr<MgLayerGroup> group1 = new MgLayerGroup(L"EmptyGroup1");
+ group1->SetLegendLabel(L"EmptyGroup1");
+ Ptr<MgLayerGroup> group2 = new MgLayerGroup(L"EmptyGroup2");
+ group2->SetLegendLabel(L"EmptyGroup2");
+ Ptr<MgLayerGroup> group3 = new MgLayerGroup(L"EmptyGroup3");
+ group3->SetLegendLabel(L"EmptyGroup3");
+ group3->SetDisplayInLegend(true);
+ groups->Add(group1);
+ groups->Add(group2);
+ groups->Add(group3);
+ group3->SetGroup(group2);
+ map->Save();
+ // Call the API
+ rdr3->ToFile(GetPath(L"../UnitTestFiles/RenderLegendEmptyGroups", imageFormat, extension));
+ catch (MgException* e)
+ STRING message = e->GetDetails(TEST_LOCALE);
+ SAFE_RELEASE(e);
+ CPPUNIT_FAIL(MG_WCHAR_TO_CHAR(message.c_str()));
+ catch (...)
+ throw;
+void TestRenderingService::TestCase_RenderLegendMultiFTS(CREFSTRING imageFormat, CREFSTRING extension)
+ try
+ // Insert our test layer
+ Ptr<MgResourceIdentifier> layerDef = new MgResourceIdentifier(L"Library://UnitTests/Layers/MultiFTS.LayerDefinition");
+ Ptr<MgdLayer> layer = new MgdLayer(layerDef, m_svcResource);
+ layer->SetLegendLabel(layerDef->GetName());
+ Ptr<MgLayerCollection> layers = map->GetLayers();
+ layers->Insert(0, layer);
+ map->Save();
+ // call the API using scales of 75000 and 12000
+ Ptr<MgByteReader> rdr1 = m_svcRendering->RenderMapLegend(map, 200, 400, bgc, imageFormat);
+ rdr1->ToFile(GetPath(L"../UnitTestFiles/RenderLegendMultiFTS", imageFormat, extension));
+ SAFE_RELEASE(e);
+ catch (...)
+ throw;
+void TestRenderingService::TestCase_RenderLegendMultiCTS(CREFSTRING imageFormat, CREFSTRING extension)
+ try
+ Ptr<MgResourceIdentifier> layerDef = new MgResourceIdentifier(L"Library://UnitTests/Layers/MultiCTS.LayerDefinition");
+ map->Save();
+ rdr1->ToFile(GetPath(L"../UnitTestFiles/RenderLegendMultiCTS", imageFormat, extension));
+ SAFE_RELEASE(e);
+ catch (...)
+ throw;
+void TestRenderingService::TestCase_RenderLegendMultiFTSWithTheme(CREFSTRING imageFormat, CREFSTRING extension)
+ try
+ Ptr<MgResourceIdentifier> layerDef = new MgResourceIdentifier(L"Library://UnitTests/Layers/MultiFTSWithTheme.LayerDefinition");
+ map->Save();
+ rdr1->ToFile(GetPath(L"../UnitTestFiles/RenderLegendMultiFTSWithTheme", imageFormat, extension));
+ SAFE_RELEASE(e);
+ catch (...)
+ throw;
+void TestRenderingService::TestCase_RenderLegendMultiCTSWithTheme(CREFSTRING imageFormat, CREFSTRING extension)
+ try
+ Ptr<MgResourceIdentifier> layerDef = new MgResourceIdentifier(L"Library://UnitTests/Layers/MultiCTSWithTheme.LayerDefinition");
+ map->Save();
+ rdr1->ToFile(GetPath(L"../UnitTestFiles/RenderLegendMultiCTSWithTheme", imageFormat, extension));
+ SAFE_RELEASE(e);
+ catch (...)
+ throw;
+void TestRenderingService::TestCase_RenderLegendMultiFTSSingleCTS(CREFSTRING imageFormat, CREFSTRING extension)
+ try
+ Ptr<MgResourceIdentifier> layerDef = new MgResourceIdentifier(L"Library://UnitTests/Layers/MultiFTSSingleCTS.LayerDefinition");
+ map->Save();
+ rdr1->ToFile(GetPath(L"../UnitTestFiles/RenderLegendMultiFTSSingleCTS", imageFormat, extension));
+ SAFE_RELEASE(e);
+ catch (...)
+ throw;
+void TestRenderingService::TestCase_RenderLegendSingleFTSMultiCTS(CREFSTRING imageFormat, CREFSTRING extension)
+ try
+ Ptr<MgResourceIdentifier> layerDef = new MgResourceIdentifier(L"Library://UnitTests/Layers/SingleFTSMultiCTS.LayerDefinition");
+ map->Save();
+ rdr1->ToFile(GetPath(L"../UnitTestFiles/RenderLegendSingleFTSMultiCTS", imageFormat, extension));
+ SAFE_RELEASE(e);
+ catch (...)
+ throw;
void TestRenderingService::TestCase_QueryFeatures()
try
Modified: branches/2.5/MgDev/Desktop/UnitTest/TestRenderingService.h
--- branches/2.5/MgDev/Desktop/UnitTest/TestRenderingService.h 2013-12-01 16:54:17 UTC (rev 7944)
+++ branches/2.5/MgDev/Desktop/UnitTest/TestRenderingService.h 2013-12-01 17:39:38 UTC (rev 7945)
@@ -40,6 +40,13 @@
CPPUNIT_TEST(TestCase_RenderMapPNG);
CPPUNIT_TEST(TestCase_RenderMapWithWatermarkPNG);
CPPUNIT_TEST(TestCase_RenderLegendPNG);
+ CPPUNIT_TEST(TestCase_RenderLegendEmptyGroupsPNG);
+ CPPUNIT_TEST(TestCase_RenderLegendMultiFTSPNG);
+ CPPUNIT_TEST(TestCase_RenderLegendMultiCTSPNG);
+ CPPUNIT_TEST(TestCase_RenderLegendMultiFTSWithThemePNG);
+ CPPUNIT_TEST(TestCase_RenderLegendMultiCTSWithThemePNG);
+ CPPUNIT_TEST(TestCase_RenderLegendMultiFTSSingleCTSPNG);
+ CPPUNIT_TEST(TestCase_RenderLegendSingleFTSMultiCTSPNG);
CPPUNIT_TEST(TestCase_SymbologyPointsPNG8);
CPPUNIT_TEST(TestCase_SymbologyPointsParamPNG8);
@@ -56,6 +63,13 @@
CPPUNIT_TEST(TestCase_RenderMapPNG8);
CPPUNIT_TEST(TestCase_RenderMapWithWatermarkPNG8);
CPPUNIT_TEST(TestCase_RenderLegendPNG8);
+ CPPUNIT_TEST(TestCase_RenderLegendEmptyGroupsPNG8);
+ CPPUNIT_TEST(TestCase_RenderLegendMultiFTSPNG8);
+ CPPUNIT_TEST(TestCase_RenderLegendMultiCTSPNG8);
+ CPPUNIT_TEST(TestCase_RenderLegendMultiFTSWithThemePNG8);
+ CPPUNIT_TEST(TestCase_RenderLegendMultiCTSWithThemePNG8);
+ CPPUNIT_TEST(TestCase_RenderLegendMultiFTSSingleCTSPNG8);
+ CPPUNIT_TEST(TestCase_RenderLegendSingleFTSMultiCTSPNG8);
CPPUNIT_TEST(TestCase_SymbologyPointsGIF);
CPPUNIT_TEST(TestCase_SymbologyPointsParamGIF);
@@ -72,6 +86,13 @@
CPPUNIT_TEST(TestCase_RenderMapGIF);
CPPUNIT_TEST(TestCase_RenderMapWithWatermarkGIF);
CPPUNIT_TEST(TestCase_RenderLegendGIF);
+ CPPUNIT_TEST(TestCase_RenderLegendEmptyGroupsGIF);
+ CPPUNIT_TEST(TestCase_RenderLegendMultiFTSGIF);
+ CPPUNIT_TEST(TestCase_RenderLegendMultiCTSGIF);
+ CPPUNIT_TEST(TestCase_RenderLegendMultiFTSWithThemeGIF);
+ CPPUNIT_TEST(TestCase_RenderLegendMultiCTSWithThemeGIF);
+ CPPUNIT_TEST(TestCase_RenderLegendMultiFTSSingleCTSGIF);
+ CPPUNIT_TEST(TestCase_RenderLegendSingleFTSMultiCTSGIF);
CPPUNIT_TEST(TestCase_SymbologyPointsJPG);
CPPUNIT_TEST(TestCase_SymbologyPointsParamJPG);
@@ -88,6 +109,13 @@
CPPUNIT_TEST(TestCase_RenderMapJPG);
CPPUNIT_TEST(TestCase_RenderMapWithWatermarkJPG);
CPPUNIT_TEST(TestCase_RenderLegendJPG);
+ CPPUNIT_TEST(TestCase_RenderLegendEmptyGroupsJPG);
+ CPPUNIT_TEST(TestCase_RenderLegendMultiFTSJPG);
+ CPPUNIT_TEST(TestCase_RenderLegendMultiCTSJPG);
+ CPPUNIT_TEST(TestCase_RenderLegendMultiFTSWithThemeJPG);
+ CPPUNIT_TEST(TestCase_RenderLegendMultiCTSWithThemeJPG);
+ CPPUNIT_TEST(TestCase_RenderLegendMultiFTSSingleCTSJPG);
+ CPPUNIT_TEST(TestCase_RenderLegendSingleFTSMultiCTSJPG);
CPPUNIT_TEST(TestCase_QueryFeatures);
@@ -105,12 +133,21 @@
void TestStart();
void TestEnd();
+ void TestCase_QueryFeatures();
//Parameterized versions that all format-specific tests call into
void TestCase_RenderDynamicOverlay(CREFSTRING imageFormat, CREFSTRING extension);
void TestCase_RenderDynamicOverlayTiledMap(CREFSTRING imageFormat, CREFSTRING extension);
void TestCase_RenderMap(CREFSTRING imageFormat, CREFSTRING extension);
void TestCase_RenderMapWithWatermark(CREFSTRING imageFormat, CREFSTRING extension);
void TestCase_RenderLegend(CREFSTRING imageFormat, CREFSTRING extension);
+ void TestCase_RenderLegendEmptyGroups(CREFSTRING imageFormat, CREFSTRING extension);
+ void TestCase_RenderLegendMultiFTS(CREFSTRING imageFormat, CREFSTRING extension);
+ void TestCase_RenderLegendMultiCTS(CREFSTRING imageFormat, CREFSTRING extension);
+ void TestCase_RenderLegendMultiFTSWithTheme(CREFSTRING imageFormat, CREFSTRING extension);
+ void TestCase_RenderLegendMultiCTSWithTheme(CREFSTRING imageFormat, CREFSTRING extension);
+ void TestCase_RenderLegendMultiFTSSingleCTS(CREFSTRING imageFormat, CREFSTRING extension);
+ void TestCase_RenderLegendSingleFTSMultiCTS(CREFSTRING imageFormat, CREFSTRING extension);
void TestCase_SymbologyPoints(CREFSTRING imageFormat, CREFSTRING extension);
void TestCase_SymbologyPointsParam(CREFSTRING imageFormat, CREFSTRING extension);
@@ -122,12 +159,13 @@
void TestCase_Annotation2(CREFSTRING imageFormat, CREFSTRING extension);
void TestCase_Annotation3(CREFSTRING imageFormat, CREFSTRING extension);
- //PNG output tests
- void TestCase_RenderDynamicOverlayPNG() { TestCase_RenderDynamicOverlay(L"PNG", L"png"); }
+ //PNG output tests
+ void TestCase_RenderDynamicOverlayPNG() { TestCase_RenderDynamicOverlay(L"PNG", L"png"); }
void TestCase_RenderDynamicOverlayTiledMapPNG() { TestCase_RenderDynamicOverlayTiledMap(L"PNG", L"png"); }
void TestCase_RenderMapPNG() { TestCase_RenderMap(L"PNG", L"png"); }
void TestCase_RenderMapWithWatermarkPNG() { TestCase_RenderMapWithWatermark(L"PNG", L"png"); }
void TestCase_RenderLegendPNG() { TestCase_RenderLegend(L"PNG", L"png"); }
+ void TestCase_RenderLegendEmptyGroupsPNG() { TestCase_RenderLegendEmptyGroups(L"PNG", L"png"); }
void TestCase_SymbologyPointsPNG() { TestCase_SymbologyPoints(L"PNG", L"png"); }
void TestCase_SymbologyPointsParamPNG() { TestCase_SymbologyPointsParam(L"PNG", L"png"); }
void TestCase_SymbologyLinesPNG() { TestCase_SymbologyLines(L"PNG", L"png"); }
@@ -136,13 +174,20 @@
void TestCase_Annotation1PNG() { TestCase_Annotation1(L"PNG", L"png"); }
void TestCase_Annotation2PNG() { TestCase_Annotation2(L"PNG", L"png"); }
void TestCase_Annotation3PNG() { TestCase_Annotation3(L"PNG", L"png"); }
+ void TestCase_RenderLegendMultiFTSPNG() { TestCase_RenderLegendMultiFTS(L"PNG", L"png"); }
+ void TestCase_RenderLegendMultiCTSPNG() { TestCase_RenderLegendMultiCTS(L"PNG", L"png"); }
+ void TestCase_RenderLegendMultiFTSWithThemePNG() { TestCase_RenderLegendMultiFTSWithTheme(L"PNG", L"png"); }
+ void TestCase_RenderLegendMultiCTSWithThemePNG() { TestCase_RenderLegendMultiCTSWithTheme(L"PNG", L"png"); }
+ void TestCase_RenderLegendMultiFTSSingleCTSPNG() { TestCase_RenderLegendMultiFTSSingleCTS(L"PNG", L"png"); }
+ void TestCase_RenderLegendSingleFTSMultiCTSPNG() { TestCase_RenderLegendSingleFTSMultiCTS(L"PNG", L"png"); }
- //PNG8 output tests
- void TestCase_RenderDynamicOverlayPNG8() { TestCase_RenderDynamicOverlay(L"PNG8", L"png"); }
+ //PNG8 output tests
+ void TestCase_RenderDynamicOverlayPNG8() { TestCase_RenderDynamicOverlay(L"PNG8", L"png"); }
void TestCase_RenderDynamicOverlayTiledMapPNG8() { TestCase_RenderDynamicOverlayTiledMap(L"PNG8", L"png"); }
void TestCase_RenderMapPNG8() { TestCase_RenderMap(L"PNG8", L"png"); }
void TestCase_RenderMapWithWatermarkPNG8() { TestCase_RenderMapWithWatermark(L"PNG8", L"png"); }
void TestCase_RenderLegendPNG8() { TestCase_RenderLegend(L"PNG8", L"png"); }
+ void TestCase_RenderLegendEmptyGroupsPNG8() { TestCase_RenderLegendEmptyGroups(L"PNG8", L"png"); }
void TestCase_SymbologyPointsPNG8() { TestCase_SymbologyPoints(L"PNG8", L"png"); }
void TestCase_SymbologyPointsParamPNG8() { TestCase_SymbologyPointsParam(L"PNG8", L"png"); }
void TestCase_SymbologyLinesPNG8() { TestCase_SymbologyLines(L"PNG8", L"png"); }
@@ -151,13 +196,20 @@
void TestCase_Annotation1PNG8() { TestCase_Annotation1(L"PNG8", L"png"); }
void TestCase_Annotation2PNG8() { TestCase_Annotation2(L"PNG8", L"png"); }
void TestCase_Annotation3PNG8() { TestCase_Annotation3(L"PNG8", L"png"); }
+ void TestCase_RenderLegendMultiFTSPNG8() { TestCase_RenderLegendMultiFTS(L"PNG8", L"png"); }
+ void TestCase_RenderLegendMultiCTSPNG8() { TestCase_RenderLegendMultiCTS(L"PNG8", L"png"); }
+ void TestCase_RenderLegendMultiFTSWithThemePNG8() { TestCase_RenderLegendMultiFTSWithTheme(L"PNG8", L"png"); }
+ void TestCase_RenderLegendMultiCTSWithThemePNG8() { TestCase_RenderLegendMultiCTSWithTheme(L"PNG8", L"png"); }
+ void TestCase_RenderLegendMultiFTSSingleCTSPNG8() { TestCase_RenderLegendMultiFTSSingleCTS(L"PNG8", L"png"); }
+ void TestCase_RenderLegendSingleFTSMultiCTSPNG8() { TestCase_RenderLegendSingleFTSMultiCTS(L"PNG8", L"png"); }
- //GIF output tests
- void TestCase_RenderDynamicOverlayGIF() { TestCase_RenderDynamicOverlay(L"GIF", L"gif"); }
+ //GIF output tests
+ void TestCase_RenderDynamicOverlayGIF() { TestCase_RenderDynamicOverlay(L"GIF", L"gif"); }
void TestCase_RenderDynamicOverlayTiledMapGIF() { TestCase_RenderDynamicOverlayTiledMap(L"GIF", L"gif"); }
void TestCase_RenderMapGIF() { TestCase_RenderMap(L"GIF", L"gif"); }
void TestCase_RenderMapWithWatermarkGIF() { TestCase_RenderMapWithWatermark(L"GIF", L"gif"); }
void TestCase_RenderLegendGIF() { TestCase_RenderLegend(L"GIF", L"gif"); }
+ void TestCase_RenderLegendEmptyGroupsGIF() { TestCase_RenderLegendEmptyGroups(L"GIF", L"gif"); }
void TestCase_SymbologyPointsGIF() { TestCase_SymbologyPoints(L"GIF", L"gif"); }
void TestCase_SymbologyPointsParamGIF() { TestCase_SymbologyPointsParam(L"GIF", L"gif"); }
void TestCase_SymbologyLinesGIF() { TestCase_SymbologyLines(L"GIF", L"gif"); }
@@ -166,13 +218,20 @@
void TestCase_Annotation1GIF() { TestCase_Annotation1(L"GIF", L"gif"); }
void TestCase_Annotation2GIF() { TestCase_Annotation2(L"GIF", L"gif"); }
void TestCase_Annotation3GIF() { TestCase_Annotation3(L"GIF", L"gif"); }
+ void TestCase_RenderLegendMultiFTSGIF() { TestCase_RenderLegendMultiFTS(L"GIF", L"gif"); }
+ void TestCase_RenderLegendMultiCTSGIF() { TestCase_RenderLegendMultiCTS(L"GIF", L"gif"); }
+ void TestCase_RenderLegendMultiFTSWithThemeGIF() { TestCase_RenderLegendMultiFTSWithTheme(L"GIF", L"gif"); }
+ void TestCase_RenderLegendMultiCTSWithThemeGIF() { TestCase_RenderLegendMultiCTSWithTheme(L"GIF", L"gif"); }
+ void TestCase_RenderLegendMultiFTSSingleCTSGIF() { TestCase_RenderLegendMultiFTSSingleCTS(L"GIF", L"gif"); }
+ void TestCase_RenderLegendSingleFTSMultiCTSGIF() { TestCase_RenderLegendSingleFTSMultiCTS(L"GIF", L"gif"); }
- //JPG output tests
- void TestCase_RenderDynamicOverlayJPG() { TestCase_RenderDynamicOverlay(L"JPG", L"jpg"); }
+ //JPG output tests
+ void TestCase_RenderDynamicOverlayJPG() { TestCase_RenderDynamicOverlay(L"JPG", L"jpg"); }
void TestCase_RenderDynamicOverlayTiledMapJPG() { TestCase_RenderDynamicOverlayTiledMap(L"JPG", L"jpg"); }
void TestCase_RenderMapJPG() { TestCase_RenderMap(L"JPG", L"jpg"); }
void TestCase_RenderMapWithWatermarkJPG() { TestCase_RenderMapWithWatermark(L"JPG", L"jpg"); }
void TestCase_RenderLegendJPG() { TestCase_RenderLegend(L"JPG", L"jpg"); }
+ void TestCase_RenderLegendEmptyGroupsJPG() { TestCase_RenderLegendEmptyGroups(L"JPG", L"jpg"); }
void TestCase_SymbologyPointsJPG() { TestCase_SymbologyPoints(L"JPG", L"jpg"); }
void TestCase_SymbologyPointsParamJPG() { TestCase_SymbologyPointsParam(L"JPG", L"jpg"); }
void TestCase_SymbologyLinesJPG() { TestCase_SymbologyLines(L"JPG", L"jpg"); }
@@ -181,9 +240,13 @@
void TestCase_Annotation1JPG() { TestCase_Annotation1(L"JPG", L"jpg"); }
void TestCase_Annotation2JPG() { TestCase_Annotation2(L"JPG", L"jpg"); }
void TestCase_Annotation3JPG() { TestCase_Annotation3(L"JPG", L"jpg"); }
+ void TestCase_RenderLegendMultiFTSJPG() { TestCase_RenderLegendMultiFTS(L"JPG", L"jpg"); }
+ void TestCase_RenderLegendMultiCTSJPG() { TestCase_RenderLegendMultiCTS(L"JPG", L"jpg"); }
+ void TestCase_RenderLegendMultiFTSWithThemeJPG() { TestCase_RenderLegendMultiFTSWithTheme(L"JPG", L"jpg"); }
+ void TestCase_RenderLegendMultiCTSWithThemeJPG() { TestCase_RenderLegendMultiCTSWithTheme(L"JPG", L"jpg"); }
+ void TestCase_RenderLegendMultiFTSSingleCTSJPG() { TestCase_RenderLegendMultiFTSSingleCTS(L"JPG", L"jpg"); }
+ void TestCase_RenderLegendSingleFTSMultiCTSJPG() { TestCase_RenderLegendSingleFTSMultiCTS(L"JPG", L"jpg"); }
- void TestCase_QueryFeatures();
//void TestCase_RendererPerformance();
private:
More information about the mapguide-commits
