[mapguide-commits] r7960 - trunk/Tools/Maestro/MaestroAPITestRunner
svn_mapguide at osgeo.org
Mon Dec 23 00:58:44 PST 2013
Author: jng
Date: 2013-12-23 00:58:44 -0800 (Mon, 23 Dec 2013)
New Revision: 7960
Added:
trunk/Tools/Maestro/MaestroAPITestRunner/TestMaestroAPI.LocalNative.xml
trunk/Tools/Maestro/MaestroAPITestRunner/MaestroAPITestRunner.csproj
trunk/Tools/Maestro/MaestroAPITestRunner/TestMaestroAPI.xml
#2138: Include the Maestro API Test Runner as part of the SDK build output. This gives us the means to do basic verification of a LocalNative provider built with the ProviderTemplate tool. A SDK-specific test configuration is copied to the SDK build output in release mode, which disables Local connection tests as the SDK does not bundle mg-desktop and FDO dlls and data files.
Modified: trunk/Tools/Maestro/MaestroAPITestRunner/MaestroAPITestRunner.csproj
--- trunk/Tools/Maestro/MaestroAPITestRunner/MaestroAPITestRunner.csproj 2013-12-20 15:15:19 UTC (rev 7959)
+++ trunk/Tools/Maestro/MaestroAPITestRunner/MaestroAPITestRunner.csproj 2013-12-23 08:58:44 UTC (rev 7960)
@@ -54,8 +54,15 @@
<ErrorReport>prompt</ErrorReport>
<WarningLevel>4</WarningLevel>
<PlatformTarget>x86</PlatformTarget>
+ <UseVSHostingProcess>false</UseVSHostingProcess>
</PropertyGroup>
<ItemGroup>
+ <Reference Include="Ciloci.Flee">
+ <HintPath>..\Thirdparty\Flee\lib\Ciloci.Flee.dll</HintPath>
+ </Reference>
+ <Reference Include="NetTopologySuite.Merged">
+ <HintPath>..\Thirdparty\NTS\NetTopologySuite.Merged.dll</HintPath>
+ </Reference>
<Reference Include="nunit-console-runner, Version=2.5.5.10112, Culture=neutral, PublicKeyToken=96d09a1eb7f44a77, processorArchitecture=MSIL">
<SpecificVersion>False</SpecificVersion>
<HintPath>..\Thirdparty\NUnit\bin\net-2.0\lib\nunit-console-runner.dll</HintPath>
@@ -85,6 +92,7 @@
<ProjectReference Include="..\OSGeo.MapGuide.MaestroAPI.Local\OSGeo.MapGuide.MaestroAPI.Local.csproj">
<Project>{3ddf6501-0148-474c-8674-7c7da49c7f02}</Project>
<Name>OSGeo.MapGuide.MaestroAPI.Local</Name>
+ <Private>False</Private>
</ProjectReference>
<ProjectReference Include="..\OSGeo.MapGuide.MaestroAPI\OSGeo.MapGuide.MaestroAPI.csproj">
<Project>{80FA3158-8B5F-48D1-A393-0378AFE48A7E}</Project>
@@ -101,6 +109,7 @@
<Content Include="ConnectionProviders.xml">
<CopyToOutputDirectory>Always</CopyToOutputDirectory>
</Content>
+ <Content Include="TestMaestroAPI.LocalNative.xml" />
<Content Include="TestMaestroAPI.xml">
</Content>
@@ -131,11 +140,25 @@
</Target>
<PropertyGroup>
- <PostBuildEvent>IF EXIST "$(ProjectDir)Setup" XCOPY /Y /I "$(ProjectDir)Setup\*.*" "$(ProjectDir)$(OutDir)"
+ <PostBuildEvent>echo Performing post-build for Test Runner in $(ConfigurationName)
+IF "$(ConfigurationName)" == "Release" (
+IF NOT EXIST "$(SolutionDir)..\SDK\Test" MKDIR "$(SolutionDir)..\SDK\Test"
+echo Copy binaries to SDK output dir
+echo XCOPY /S /Y /I "$(TargetDir)*.*" "$(SolutionDir)..\SDK\Test"
+XCOPY /S /Y /I "$(TargetDir)*.*" "$(SolutionDir)..\SDK\Test"
+echo Copy SDK test configuration
+COPY /Y "$(ProjectDir)TestMaestroAPI.LocalNative.xml" "$(SolutionDir)..\SDK\Test\TestMaestroAPI.xml"
+) ELSE (
+echo Copy CS-Map Dictionaries
IF NOT EXIST "$(OutDir)Dictionaries" XCOPY /S /Y /I "$(SolutionDir)..\Maestro.AddIn.Local\Dictionaries\*.*" "$(ProjectDir)$(OutDir)Dictionaries"
+echo Copy FDO dlls
IF NOT EXIST "$(OutDir)FDO" XCOPY /S /Y /I "$(SolutionDir)..\Maestro.AddIn.Local\FDO\*.*" "$(ProjectDir)$(OutDir)FDO"
+echo Copy MapGuide XML schemas
IF NOT EXIST "$(OutDir)Schemas" XCOPY /S /Y /I "$(SolutionDir)..\OSGeo.MapGuide.MaestroAPI\Schemas\*.*" "$(ProjectDir)$(OutDir)Schemas"
+echo Copy mg-desktop string bundle
IF NOT EXIST "$(OutDir)Resources" XCOPY /S /Y /I "$(SolutionDir)..\Maestro.AddIn.Local\Resources\*.res" "$(ProjectDir)$(OutDir)Resources"
-COPY /Y "$(SolutionDir)..\Maestro.AddIn.Local\*.dll" "$(ProjectDir)$(OutDir)"</PostBuildEvent>
+echo Copy Maestro API Local connection dlls
+COPY /Y "$(SolutionDir)..\OSGeo.MapGuide.MaestroAPI.Local\bin\$(ConfigurationName)\OSGeo.MapGuide.MaestroAPI.Local.*" "$(ProjectDir)$(OutDir)"
+COPY /Y "$(SolutionDir)..\Maestro.AddIn.Local\*.dll" "$(ProjectDir)$(OutDir)" )</PostBuildEvent>
</PropertyGroup>
</Project>
\ No newline at end of file
Added: trunk/Tools/Maestro/MaestroAPITestRunner/TestMaestroAPI.LocalNative.xml
--- trunk/Tools/Maestro/MaestroAPITestRunner/TestMaestroAPI.LocalNative.xml (rev 0)
+++ trunk/Tools/Maestro/MaestroAPITestRunner/TestMaestroAPI.LocalNative.xml 2013-12-23 08:58:44 UTC (rev 7960)
@@ -0,0 +1,75 @@
+<?xml version="1.0" encoding="utf-8" ?>
+Maestro API test configuration file
+Configured for exercising the LocalNative provider created by the ProviderTemplate tool and everything else in the Maestro API
+except for Local Connection and GeoREST support
+<TestConfiguration>
+ <TestSettings>
+ The path to webconfig.ini required by the LocalNative provider to run its specific tests. Should come from the same
+ MapGuide installation where you have sourced the .net assemblies used to build your own LocalNative provider with the
+ ProviderTemplate tool in the Maestro SDK
+ <LocalNativeConfigFile>C:\Program Files\OSGeo\MapGuide\Web\www\webconfig.ini</LocalNativeConfigFile>
+ The MapGuide user account for running the LocalNative provider tests under
+ <LocalNativeUsername>Administrator</LocalNativeUsername>
+ The password for the MapGuide user account for running the LocalNative provider tests under
+ <LocalNativePassword>admin</LocalNativePassword>
+ The path to the Platform.ini required by the Local connection provider to run its specific tests.
+ <LocalConfigFile>Platform.ini</LocalConfigFile>
+ The mapagent URL required for running the HTTP provider tests
+ <HttpUrl>http://localhost/mapguide/mapagent/mapagent.fcgi</HttpUrl>
+ The MapGuide user account for running the HTTP provider tests under
+ <HttpUsername>Administrator</HttpUsername>
+ The password for the MapGuide user account for running the HTTP provider tests under
+ <HttpPassword>admin</HttpPassword>
+ The URL for the GeoREST endpoint for running the HTTP provider tests with GeoREST support
+ <GeoRestUrl>http://localhost:99/</GeoRestUrl>
+ The path to the GeoREST test configuration file, needed by this GeoREST test suite
+ <GeoRestConfig>UserTestData\GeoRestConfig.xml</GeoRestConfig>
+ </TestSettings>
+ <TestControl>
+ <!-- Core API -->
+ <IgnoreConfigurationTests>false</IgnoreConfigurationTests>
+ <IgnoreCapabilityTests>false</IgnoreCapabilityTests>
+ <IgnoreExpressionTests>false</IgnoreExpressionTests>
+ <IgnoreFeatureReaderTests>false</IgnoreFeatureReaderTests>
+ <IgnoreObjectTests>false</IgnoreObjectTests>
+ <IgnoreResourceTests>false</IgnoreResourceTests>
+ <IgnoreSchemaTests>false</IgnoreSchemaTests>
+ <IgnoreSerializationTests>false</IgnoreSerializationTests>
+ <IgnoreValidationTests>false</IgnoreValidationTests>
+ <IgnoreMiscTests>false</IgnoreMiscTests>
+ <!-- Functionality that uses the HTTP connection provider -->
+ <IgnoreHttpConnectionTests>false</IgnoreHttpConnectionTests>
+ <IgnoreHttpSiteTests>false</IgnoreHttpSiteTests>
+ <IgnoreHttpRuntimeMapTests>false</IgnoreHttpRuntimeMapTests>
+ <!-- Local Connection tests are disabled because the SDK Test Runner does not bundle mg-desktop and supporting libraries/datafiles -->
+ <IgnoreLocalRuntimeMapTests>true</IgnoreLocalRuntimeMapTests>
+ <IgnoreLocalFeatureTests>true</IgnoreLocalFeatureTests>
+ <!-- Functionality that uses the Local connection provider -->
+ <IgnoreLocalNativeRuntimeMapTests>false</IgnoreLocalNativeRuntimeMapTests>
+ <IgnoreLocalNativePerformanceTests>false</IgnoreLocalNativePerformanceTests>
+ <IgnoreLocalNativeFeatureTests>false</IgnoreLocalNativeFeatureTests>
+ <!-- GeoREST disabled because not every MapGuide installation has it installed -->
+ <IgnoreGeoRestTests>true</IgnoreGeoRestTests>
+ </TestControl>
+</TestConfiguration>
Modified: trunk/Tools/Maestro/MaestroAPITestRunner/TestMaestroAPI.xml
--- trunk/Tools/Maestro/MaestroAPITestRunner/TestMaestroAPI.xml 2013-12-20 15:15:19 UTC (rev 7959)
+++ trunk/Tools/Maestro/MaestroAPITestRunner/TestMaestroAPI.xml 2013-12-23 08:58:44 UTC (rev 7960)
@@ -1,35 +1,78 @@
+Configured for exercising everything in the Maestro API except for LocalNative connection providers and GeoREST
<TestConfiguration>
<TestSettings>
- <LocalNativeConfigFile>MGOS22\webconfig.ini</LocalNativeConfigFile>
</TestSettings>
<TestControl>
+ <!-- Core API -->
- <IgnoreObjectTests>false</IgnoreObjectTests>
- <IgnoreResourceTests>false</IgnoreResourceTests>
<IgnoreLocalRuntimeMapTests>false</IgnoreLocalRuntimeMapTests>
+ <IgnoreLocalFeatureTests>false</IgnoreLocalFeatureTests>
+ Local Native connection provider tests are disabled as the standard test profile does not cover
+ this functionality. The Test Runner configuration in the Maestro SDK enables such tests, while
+ disabling the Local Connection ones (because it doesn't include mg-desktop and supporting libs/datafiles)
<IgnoreLocalNativeRuntimeMapTests>true</IgnoreLocalNativeRuntimeMapTests>
<IgnoreLocalNativePerformanceTests>true</IgnoreLocalNativePerformanceTests>
<IgnoreLocalNativeFeatureTests>true</IgnoreLocalNativeFeatureTests>
- <IgnoreLocalFeatureTests>false</IgnoreLocalFeatureTests>
- <IgnoreSchemaTests>false</IgnoreSchemaTests>
- <IgnoreSerializationTests>false</IgnoreSerializationTests>
- <IgnoreValidationTests>false</IgnoreValidationTests>
- <IgnoreMiscTests>false</IgnoreMiscTests>
</TestControl>
More information about the mapguide-commits
