[mapguide-commits] r7964 - trunk/Tools/Maestro/Maestro
svn_mapguide at osgeo.org
Mon Dec 23 07:45:35 PST 2013
Author: jng
Date: 2013-12-23 07:45:35 -0800 (Mon, 23 Dec 2013)
New Revision: 7964
trunk/Tools/Maestro/Maestro/changelog.txt
changelog.txt update
Modified: trunk/Tools/Maestro/Maestro/changelog.txt
--- trunk/Tools/Maestro/Maestro/changelog.txt 2013-12-23 15:28:39 UTC (rev 7963)
+++ trunk/Tools/Maestro/Maestro/changelog.txt 2013-12-23 15:45:35 UTC (rev 7964)
@@ -1,4 +1,6 @@
- - Added missing support for editing symbol instance properties
+ - Map Definition Editor now uses a PropertyGrid for editing layer/group properties
+ - Map Definition Editor can now batch edit properties of multiple selected groups/layers
+ - Added missing support for editing symbol instance properties
- Initial support for XML element auto-completion
- Initial API support for CREATERUNTIMEMAP and DESCRIBERUNTIMEMAP operations in MapGuide 2.6
- Resource ID "address bar" now has two buttons: One to open the resource using the designated editor and one to open using the Generic XML editor
@@ -6,6 +8,9 @@
- References tab in Resource Properties dialog now has quick access buttons to open upstream/downstream dependent resources in an editor
- Added open (Layer Definition) in editor shortcut for a selected layer in the Map Definition editor
- The resource of an active editor will now auto-focus on the Site Explorer
+ - Added support for proxy servers
+ - Runtime Map creation for resource previews now fail hard, allowing for immediate error diagnosis instead of waiting of all layers to be processed
+ - Fix: Some options (which do not require a restart) always prompting a restart when applied
- Fix: "Show In Legend" checkbox in Layer Definition editor does nothing for CompositeTypeStyle elements
- Fix: Error XML validating v2.4.0 Layer Definition documents
- Fix: Bad restore center command icon when new WebLayout document is created
More information about the mapguide-commits
